path: root/sound/sparc
2008-06-06ALSA: make sparc/dbri.c:snd_dbri_proc() staticAdrian Bunk
This patch makes the needlessly global snd_dbri_proc() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-27sound: Convert to menuconfigTakashi Iwai
Convert menu in sound Kconfig files to menuconfig and if. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] dbri - Fix broken change for value range checksTakashi Iwai
The last patch for value range checks included a broken merge result. Now fixed properly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly (in the rest drivers). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-23[ALSA] This simplifies and fixes waiting loops of the mce_down()Krzysztof Helt
function after Trent Piepho's patch for AD1848. It also makes busy_wait() function call not atomic. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Fix thinko in cs4231 mce down checkTakashi Iwai
The last patches to replace with schedule_timeout() don't work as expected. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] sun-cs4231: improved waiting after MCE downKrzysztof Helt
This patch sync sparc driver with x86 isa cs4231 driver patches. It fixes wrong waiting for the auto calibration bit and makes further waiting use much finer granularity. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] sun-cs4231: use cs4231-regs.hKrzysztof Helt
This patch replaces cs4231 registers definitions with common include. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
2007-10-16[ALSA] sun-cs4231: checkpatch fixesKrzysztof Helt
This patch fixes white spaces and issues pointed by the checkpatch.pl script. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] dbri - Use linux/of.h instead of asm/prom.hKrzysztof Helt
The linux/of.h header should be used instead of asm/prom.h. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] sun-cs4231: memory management fixKrzysztof Helt
The chip structure is now allocated by snd_card_new() and it must not be released by separate kfree(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] dbri: conversion to OpenFirmware frameworkKrzysztof Helt
This patch converts the dbri driver to use OF framework. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] dbri: more cleanupsKrzysztof Helt
This patch: - removes redundant constant suffices - removes redundant parentheses - removes redundant curly brackets - removes check if a spinlock is locked inside method which is only called with the spinlock locked - moves few functions to the __init section - removes line which appears twice after the previous patch - minor comments improvements Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] sun-cs4231: code improvementsKrzysztof Helt
This patch does some code improvements to make driver (both code and binary) shorter. It also make use of card->private_data pointer to store chip information. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] dbri: driver cleanupKrzysztof Helt
This patch fixes white spaces, spelling and formatting to conform closer to the coding standard of the kernel. It contains few fixes pointed out by the checkpatch.pl script. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-08-03[SOUND] CS4231 SBus: Two fixes.Georg Chini
Remove unnecessary sbus_dma_reset function and change sbus_dma_enable to avoid occasional system crashes when stopping recording. Signed-off-by: Georg Chini <georg.chini@triaton-webhosting.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-11[ALSA] Fix compilation error in sparc/cs4231.cTakashi Iwai
Removed the unnecessary line I forgot in the last clean-up patch wrt snd_pcm_group_for_each_entry(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] Add snd_pcm_group_for_each_entry() for code cleanupTakashi Iwai
Added a new macro snd_pcm_group_for_each_entry() just for code cleanup. Old macros, snd_pcm_group_for_each() and snd_pcm_group_substream_entry(), are removed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-09Fix misspellings collected by members of KJ list.Robert P. J. Day
Fix the misspellings of "propogate", "writting" and (oh, the shame :-) "kenrel" in the source tree. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-26[SPARC/64] constify of_get_property return: soundStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-09[ALSA] sparc dbri comment fixKrzysztof Helt
This is a comment fix to avoid misleading about locking in the dbri_cmdsend. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-01-03[SOUND] Sparc CS4231: Use 64 for period_bytes_minDavid S. Miller
This matches what the ISA cs4231 driver uses. Tested by Georg Chini. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-03[SOUND] Sparc CS4231: Fix IRQ return value and initialization.Georg Chini
SBUS: Change IRQ-handler return value from 0 to IRQ_HANDLED and fix some initialisation problems. Change period_bytes_min from 4096 to 256 to allow driver to work with low latency (VOIP) applications. Hope this does not break EBUS. Signed-off-by: Georg Chini <georg.chini@triaton-webhosting.com> Signed-off-by: David S. Miller <davem@davemloft.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-29[PATCH] sound/sparc/dbri: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[SOUND] sparc/amd7930: Use __devinit and __devinitdata as needed.David S. Miller
Fixes section-mismatch errors. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-24[PATCH] NULL noise removalAl Viro
2006-09-23[ALSA] sparc dbri: SMP fixesKrzysztof Helt
The dbri driver hangs when used in kernel compiled with SMP support due to inproper locking. The patch fixes it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: OSS layer fixKrzysztof Helt
This patch removes setting of incorrect stop_threshold value inside the driver. After the change, playback through the OSS layer works correctly. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] dbri sparc: fixes TS leakKrzysztof Helt
This patch fixes time slot leak in the dbri driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: recording is backKrzysztof Helt
This patch fixes sound recording after the driver convertion to ring buffered version. It also contains small clean ups to the driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: hardware constrains addedKrzysztof Helt
This patch adds ALSA hardware constrains so stereo is possible only with 16-bit format. It contains small cleanups to ring buffered code as well. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: ring buffered versionKrzysztof Helt
It is a complete rework of low level layer to work on ring buffers for comands and data descriptors. This removes annoying noise due to delay in data buffer switching. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: simplifed linking time slot functionKrzysztof Helt
A simplified routines to link and unlink time slots. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: fixed setting of burst size after resetKrzysztof Helt
A proper way to set DBRI's burst size. The size must be set after each chip reset. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: more driver cleanupKrzysztof Helt
A general clean up and redudant code removal. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: removal of dri_desc structKrzysztof Helt
The structure is in big part redudant. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: removal of redudant volatile keywordsKrzysztof Helt
It removes redudant volatile keywords. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri: removal of unused struct membersKrzysztof Helt
It removes unused or rarely used members of defined structures. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] sparc dbri removal of DBRI_NO_INTSKrzysztof Helt
This patch removes define DBR_NO_INTS and all code related to handling more than one dbri irq statuses block. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-09-23[ALSA] dbri driver cleanupKrzysztof Helt
This is a small clean up of the dbri driver for sparc machines. It contains also a fix to DBRI interrupt queue initialization. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-07-03[PATCH] sparc: resource warning fixAndrew Morton
sound/sparc/amd7930.c: In function 'amd7930_attach_common': sound/sparc/amd7930.c:1040: warning: format '%08lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' sound/sparc/cs4231.c:2043: warning: format '%016lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' sound/sparc/dbri.c: In function 'dbri_attach': sound/sparc/dbri.c:2650: warning: format '%016lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30typo fixes: specfic -> specificAdrian Bunk
2006-06-27[PATCH] 64bit resource: fix up printks for resources in sound driversGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-23[SOUND] sparc: Port amd7930 to new SBUS device layer.David S. Miller
2006-06-23[SPARC64]: Use in-kernel PROM tree for EBUS and ISA.David S. Miller
