path: root/sound/spi/Makefile
2007-10-16[ALSA] ALSA sound driver for the AT73C213 DAC using Atmel SSC driverHans-Christian Egtvedt
This patch adds support for the AT73C213 DAC using the misc Atmel SSC driver in I2S mode. The driver also requires a SPI to setup the registers and control volume. It has been tested with an AT32AP7000 on the ATSTK1000 development board. The driver should also work with any Atmel device with an SSC module supported by the Atmel SSC driver (atmel-ssc). The atmel-ssc driver is just submitted to the Linux kernel. Please see mail thread http://lkml.org/lkml/2007/7/16/32 Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Add SPI devices to ALSA Kconfig and MakefileHans-Christian Egtvedt
This patch adds SPI devices in the ALSA diretory, including the Kconfig and Makefile. Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
