path: root/sound/spi/at73c213.c
2008-04-24[ALSA] at73c213: remove redundant private_free routineAtsushi Nemoto
snd_pcm_lib_preallocate_free_for_all() is called from snd_pcm_free() just after calling the private_free routine. So there should be no need to call it in driver's private_free routine. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] at73c213: monaural supportAtsushi Nemoto
Add support for monaural playback to at73c213 driver. The sound will be apear on L-channel. Tested on AT91SAM9260-EK. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] at73c213: fix error checking for clk APIAtsushi Nemoto
The clk_round_rate() and clk_set_rate() will return int, so not store thier return value to unsigned long variable. This bug hides real error on these API. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-04-24[ALSA] Add __devinit macro to at73c213 sound driver probe functionsHans-Christian Egtvedt
This patch adds __devinit to the functions used when probing. Will also reduce the memory footprint a bit if CONFIG_HOTPLUG is not enabled. Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] at73c213: replace spinlock in mixer functions with a mutexHans-Christian Egtvedt
This patch fixes the locking bug in the at73c213 SPI sound driver. This bug was triggered because spinlocks were wrapped around the spi_sync call which might sleep. The fix was to add a mutex to the sound driver and replace the spinlocks in the mixer functions with mutex lock/unlock. Tested on STK1000/STK1002. Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] at73c213 - Use common callbackTakashi Iwai
Use snd_ctl_boolean_mono_info callback to simplify. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] ALSA sound driver for the AT73C213 DAC using Atmel SSC driverHans-Christian Egtvedt
This patch adds support for the AT73C213 DAC using the misc Atmel SSC driver in I2S mode. The driver also requires a SPI to setup the registers and control volume. It has been tested with an AT32AP7000 on the ATSTK1000 development board. The driver should also work with any Atmel device with an SSC module supported by the Atmel SSC driver (atmel-ssc). The atmel-ssc driver is just submitted to the Linux kernel. Please see mail thread http://lkml.org/lkml/2007/7/16/32 Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
