This patch adds support for the new Traktor Kontrol S4 by Native
Instruments. It features a new audio data streaming model, MIDI
in and out ports, a huge number of 174 dimmable LEDs, 96 buttons
and 46 absolute encoder axis, including some rotary encoders.
All features are supported by the driver now.
Did some code refactoring along the way.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
After removing code, only one case remains. So use an 'if' instead.
Acked-by: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Mark Hills <mark@pogo.org.uk>
This feature was undocumented on early A4DJ units. It is indicated
by lighting both the 'line' and 'phono' lamps at the same time.
Newer units document this and the newer Windows drivers enable this
for all units, so restore the functionality.
This patch simplifies the code and changes the mode mapping to match
the A8DJ, favouring simpler code and consistency over keeping the
existing mapping.
Both 'Control vinyl' and 'Phono' input modes enable the hardware
preamp. The difference is the input impedance.
This reverts commit 9a9527e.
This device does not have audio controllers and backlit buttons only.
Input data is handled over a dedicated USB endpoint.
All functions are supported by the driver now.
Cc: Dmitry Torokhov <dtor@mail.ru>
Cleanup only, no functional change.
