commit 9b389a8a022110b4bc055a19b888283544d9eba6 upstream.
The probe code of snd-usb-6fire driver overrides the devices[] pointer
wrongly without checking whether it's already occupied or not. This
would screw up the device disconnection later.
Spotted by coverity CID 141423.
commit a9d14bc0b188a822e42787d01e56c06fe9750162 upstream.
The frame check in i_usX2Y_urb_complete() and
i_usX2Y_usbpcm_urb_complete() is bogus and produces false positives as
described in this LAU thread:
http://linuxaudio.org/mailarchive/lau/2013/5/20/200177
This patch removes the check code entirely.
Cc: fzu@wemgehoertderstaat.de
Reported-by: Dr Nicholas J Bailey <nicholas.bailey@glasgow.ac.uk>
Suggested-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Daniel Mack <zonque@gmail.com>
commit be2f93a4c4981b3646b6f98f477154411b8516cb upstream.
Return SNDRV_PCM_POS_XRUN (snd_pcm_uframes_t) instead of
SNDRV_PCM_STATE_XRUN (snd_pcm_state_t) from the pointer
function of 6fire, as expected by snd_pcm_update_hw_ptr0().
Caught by sparse.
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
commit 342cda29343a6272c630f94ed56810a76740251b upstream.
When the Android firmware enables the audio interfaces in accessory
mode, it always declares in the control interface's baInterfaceNr array
that interfaces 0 and 1 belong to the audio function. However, the
accessory interface itself, if also enabled, already is at index 0 and
shifts the actual audio interface numbers to 1 and 2, which prevents the
PCM streaming interface from being seen by the host driver.
To get the PCM interface interface to work, detect when the descriptors
point to the (for this driver useless) accessory interface, and redirect
to the correct one.
Reported-by: Jeremy Rosen <jeremy.rosen@openwide.fr>
Tested-by: Jeremy Rosen <jeremy.rosen@openwide.fr>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 36691e1be6ec551eef4a5225f126a281f8c051c2 upstream.
Just like the previous fix for LogitechHD Webcam c270 in commit
11e7064f35bb87da8f427d1aa4bbd8b7473a3993, c310 model also requires the
same workaround for avoiding the kernel warning.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59741
commit 11e7064f35bb87da8f427d1aa4bbd8b7473a3993 upstream.
USB audio driver spews an error message when probing Logitech HD
webcam c270:
ALSA mixer.c:1300 usb_audio: Warning! Unlikely big volume range (=6144), cval->res is probably wrong.
ALSA mixer.c:1304 usb_audio: [5] FU [Mic Capture Volume] ch = 1, val = 1536/7680/1
Obviously the device needs a fixed volume resolution (cval->res = 384)
like other Logitech devices.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=821735
Reported-and-tested-by: Cristian Rodríguez <crrodriguez@opensuse.org>
commit 8eafc0a161123d90617c9ca2eddfe87b382b1b89 upstream.
... instead of applying to all interfaces.
Reference: http://forums.gentoo.org/viewtopic-p-6886404.html
commit a0c6d309c6df14655f9962f666d1da96318b0b7c upstream.
Commit 927c9423dd5f2d1c0b93d5e694ab84b4a5559713 (ALSA: usb-audio: add
Edirol UM-3G support) used a wrong quirk type, which would make the
driver refuse to attach with the error message "MIDIStreaming interface
descriptor not found".
commit 60af3d037eb8c670dcce31401501d1271e7c5d95 upstream.
We've got strange errors in get_ctl_value() in mixer.c during
probing, e.g. on Hercules RMX2 DJ Controller:
ALSA mixer.c:352 cannot get ctl value: req = 0x83, wValue = 0x201, wIndex = 0xa00, type = 4
ALSA mixer.c:352 cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0xa00, type = 4
It turned out that the culprit is autopm: snd_usb_autoresume() returns
-ENODEV when called during card->probing = 1.
Since the call itself during card->probing = 1 is valid, let's fix the
return value of snd_usb_autoresume() as success.
Reported-and-tested-by: Daniel Schürmann <daschuer@mixxx.org>
commit cbc200bca4b51a8e2406d4b654d978f8503d430b upstream.
Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend)
introduced autopm for all USB audio/MIDI devices. However, many MIDI
devices, such as synthesizers, do not merely transmit MIDI messages but
use their MIDI inputs to control other functions. With autopm, these
devices would get powered down as soon as the last MIDI port device is
closed on the host.
Even some plain MIDI interfaces could get broken: they automatically
send Active Sensing messages while powered up, but as soon as these
messages cease, the receiving device would interpret this as an
accidental disconnection.
Commit f5f165418cab (ALSA: usb-audio: Fix missing autopm for MIDI input)
introduced another regression: some devices (e.g. the Roland GAIA SH-01)
are self-powered but do a reset whenever the USB interface's power state
changes.
To work around all this, just disable autopm for all USB MIDI devices.
Reported-by: Laurens Holst
commit ebfc594c02148b6a85c2f178cf167a44a3c3ce10 upstream.
The USB_DT_CS_ENDPOINT class-specific endpoint descriptor is usually
stuffed directly after the standard USB endpoint descriptor, and this is
where the driver currently expects it to be.
There are, however, devices in the wild that have it the other way
around in their descriptor sets, so the USB_DT_CS_ENDPOINT comes
*before* the standard enpoint. Devices known to implement it that way
are "Sennheiser BTD-500" and Plantronics USB headsets.
When the driver can't find the USB_DT_CS_ENDPOINT, it won't be able to
change sample rates, as the bitmask for the validity of this command is
storen in bmAttributes of that descriptor.
Fix this by searching the entire interface instead of just the extra
bytes of the first endpoint, in case the latter fails.
Reported-and-tested-by: Torstein Hegge <hegge@resisty.net>
Reported-and-tested-by: Yves G <alsa-user@vivigatt.com>
commit 889d66848b12d891248b03abcb2a42047f8e172a upstream.
The usb_control_msg() function expects __u16 types and performs
the endianness conversions by itself.
However, in three places, a conversion is performed before it is
handed over to usb_control_msg(), which leads to a double conversion
(= no conversion):
* snd_usb_nativeinstruments_boot_quirk()
* snd_nativeinstruments_control_get()
* snd_nativeinstruments_control_put()
Caught by sparse:
sound/usb/mixer_quirks.c:512:38: warning: incorrect type in argument 6 (different base types)
sound/usb/mixer_quirks.c:512:38: expected unsigned short [unsigned] [usertype] index
sound/usb/mixer_quirks.c:512:38: got restricted __le16 [usertype] <noident>
sound/usb/mixer_quirks.c:543:35: warning: incorrect type in argument 5 (different base types)
sound/usb/mixer_quirks.c:543:35: expected unsigned short [unsigned] [usertype] value
sound/usb/mixer_quirks.c:543:35: got restricted __le16 [usertype] <noident>
sound/usb/mixer_quirks.c:543:56: warning: incorrect type in argument 6 (different base types)
sound/usb/mixer_quirks.c:543:56: expected unsigned short [unsigned] [usertype] index
sound/usb/mixer_quirks.c:543:56: got restricted __le16 [usertype] <noident>
sound/usb/quirks.c:502:35: warning: incorrect type in argument 5 (different base types)
sound/usb/quirks.c:502:35: expected unsigned short [unsigned] [usertype] value
sound/usb/quirks.c:502:35: got restricted __le16 [usertype] <noident>
Acked-by: Daniel Mack <zonque@gmail.com>
commit 83ea5d18d74f032a760fecde78c0210f66f7f70c upstream.
Creation of individual mixer controls may fail, but that shouldn't cause
the entire mixer creation to fail. Even worse, if the mixer creation
fails, that will error out the entire device probing.
All the functions called by parse_audio_unit() should return -EINVAL if
they find descriptors that are unsupported or believed to be malformed,
so we can safely handle this error code as a non-fatal condition in
snd_usb_mixer_controls().
That fixes a long standing bug which is commonly worked around by
adding quirks which make the driver ignore entire interfaces. Some of
them might now be unnecessary.
Reported-and-tested-by: Rodolfo Thomazelli <pe.soberbo@gmail.com>
commit 4d7b86c98e445b075c2c4c3757eb6d3d6efbe72e upstream.
In check_input_term() and parse_audio_feature_unit(), propagate the
error value that has been returned by a failing function instead of
-EINVAL. That helps cleaning up the error pathes in the mixer.
commit 7da58046482fceb17c4a0d4afefd9507ec56de7f upstream.
The quirk for the Roland/Cakewalk A-PRO keyboards accidentally used the
wrong interface number, which prevented the driver from attaching to the
device.
commit d56268fb108c7c21e19933588ca4d94652585183 upstream.
Commit 23caaf19b11e (ALSA: usb-mixer: Add support for Audio Class v2.0)
forgot to adjust the length check for UAC 2.0 feature unit descriptors.
This would make the code abort on encountering a feature unit without
per-channel controls, and thus prevented the driver to work with any
device having such a unit, such as the RME Babyface or Fireface UCX.
Reported-by: Florian Hanisch <fhanisch@uni-potsdam.de>
Tested-by: Matthew Robbetts <wingfeathera@gmail.com>
Tested-by: Michael Beer <beerml@sigma6audio.de>
Cc: Daniel Mack <daniel@caiaq.de>
[NOTE: the regression below is found only in 3.2-3.4 stable trees, so
there is no upstream commit corresponding to this patch]
The recent fix for the race at disconnection of usb-audio devices
(upstream commit 978520b7) triggers Oops when a device is unplugged
while playing on 3.2 and 3.4 kernels. The culprit is that the
shutdown flag check was wrongly added around the urb deactivation code
snippet. The urb deactivation code has to be performed even after the
device disconnected. Otherwise it remains undead and pokes the wild
access in the end.
The regression fix is simply reverting the shutdown flag check in that
code.
Reported-and-tested-by: Chris J Arges <christopherarges@gmail.com>
commit b98ae2729dea161edc96c9d177459b6c28bcbba5 upstream.
A patch in the 3.2 kernel caused regression with hotplugging the
M-Audio Fast track pro, or sound after suspend. I don't have the
device so I haven't done a full analysis, but it seems userspace
(both udev and pulseaudio) got confused when a card was created,
immediately destroyed, and then created again.
However, at least one person in the bug report (martin djfun)
reports that this patch resolves the issue for him. It also leaves
a message in the log:
"snd-usb-audio: probe of 1-1.1:1.1 failed with error -5" which is
a bit misleading. It is better than non-working audio, but maybe
there's a more elegant solution?
BugLink: https://bugs.launchpad.net/bugs/1095315
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
Cc: CAI Qian <caiqian@redhat.com>
commit f5f165418cabf2218eb466c0e94693b8b1aee88b upstream.
The commit [88a8516a: ALSA: usbaudio: implement USB autosuspend] added
the support of autopm for USB MIDI output, but it didn't take the MIDI
input into account.
This patch adds the following for fixing the autopm:
- Manage the URB start at the first MIDI input stream open, instead of
the time of instance creation
- Move autopm code to the common substream_open()
- Make snd_usbmidi_input_start/_stop() more robust and add the running
state check
Reviewd-by: Clemens Ladisch <clemens@ladisch.de>
Tested-by: Clemens Ladisch <clemens@ladisch.de>
commit 59866da9e4ae54819e3c4e0a8f426bdb0c2ef993 upstream.
Add a similar protection against the disconnection race and the
invalid use of usb instance after disconnection, as well as we've done
for the USB audio PCM.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51201
commit e99ddfde6ae0dd2662bb40435696002b590e4057 upstream.
Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend) added
autosuspend code to all files making up the snd-usb-audio driver.
However, midi.c is part of snd-usb-lib and is also used by other
drivers, not all of which support autosuspend. Thus, calls to
usb_autopm_get_interface() could fail, and this unexpected error would
result in the MIDI output being completely unusable.
Make it work by ignoring the error that is expected with drivers that do
not support autosuspend.
Reported-by: Colin Fletcher <colin.m.fletcher@googlemail.com>
Reported-by: Devin Venable <venable.devin@gmail.com>
Reported-by: Dr Nick Bailey <nicholas.bailey@glasgow.ac.uk>
Reported-by: Jannis Achstetter <jannis_achstetter@web.de>
Reported-by: Rui Nuno Capela <rncbc@rncbc.org>
Cc: Oliver Neukum <oliver@neukum.org>
commit da185443c12f5ef7416af50293833a5654854186 upstream.
Fixes the following warning:
CC [M] sound/usb/caiaq/device.o
sound/usb/caiaq/device.c: In function ‘snd_probe’:
sound/usb/caiaq/device.c:500:16: warning: ‘card’ may be used
uninitialized in this function [-Wmaybe-uninitialized]
commit 10e44239f67d0b6fb74006e61a7e883b8075247a upstream.
The recent change for USB-audio disconnection race fixes introduced a
mutex deadlock again. There is a circular dependency between
chip->shutdown_rwsem and pcm->open_mutex, depicted like below, when a
device is opened during the disconnection operation:
A. snd_usb_audio_disconnect() ->
card.c::register_mutex ->
chip->shutdown_rwsem (write) ->
snd_card_disconnect() ->
pcm.c::register_mutex ->
pcm->open_mutex
B. snd_pcm_open() ->
pcm->open_mutex ->
snd_usb_pcm_open() ->
chip->shutdown_rwsem (read)
Since the chip->shutdown_rwsem protection in the case A is required
only for turning on the chip->shutdown flag and it doesn't have to be
taken for the whole operation, we can reduce its window in
snd_usb_audio_disconnect().
Reported-by: Jiri Slaby <jslaby@suse.cz>
commit 888ea7d5ac6815ba16b3b3a20f665a92c7af6724 upstream.
Similar like the previous commit, cover with chip->shutdown_rwsem
and chip->shutdown checks.
Reported-by: Matthieu CASTET <matthieu.castet@parrot.com>
commit 34f3c89fda4fba9fe689db22253ca8db2f5e6386 upstream.
Replace mutex with rwsem for codec->shutdown protection so that
concurrent accesses are allowed.
Also add the protection to snd_usb_autosuspend() and
snd_usb_autoresume(), too.
commit 978520b75f0a1ce82b17e1e8186417250de6d545 upstream.
Close some races at disconnection of a USB audio device by adding the
chip->shutdown_mutex and chip->shutdown check at appropriate places.
The spots to put bandaids are:
- PCM prepare, hw_params and hw_free
- where the usb device is accessed for communication or get speed, in
mixer.c and others; the device speed is now cached in subs->speed
instead of accessing to chip->dev
The accesses in PCM open and close don't need the mutex protection
because these are already handled in the core PCM disconnection code.
The autosuspend/autoresume codes are still uncovered by this patch
because of possible mutex deadlocks. They'll be covered by the
upcoming change to rwsem.
Also the mixer codes are untouched, too. These will be fixed in
another patch, too.
commit c05fce586d4da2dfe0309bef3795a8586e967bc3 upstream.
Added support for Xbox Communicator to USB quirks.
Signed-off-by: Marko Friedemann <mfr@bmx-chemnitz.de>
commit c10514394ef9e8de93a4ad8c8904d71dcd82c122 upstream.
While going through Ubuntu bugs, I discovered this patch being
posted and a confirmation that the patch works as expected.
Finding out how the hw volume really works would be preferrable
to just disabling the broken one, but this would be better than
nothing.
Credit: sndfnsdfin (qawsnews)
BugLink: https://bugs.launchpad.net/bugs/559939
commit aff252a848ce21b431ba822de3dab9c4c94571cb upstream.
uac_clock_source_is_valid() uses the control selector value to access
the bmControls bitmap of the clock source unit. This is wrong, as
control selector values start from 1, while the bitmap uses all
available bits.
In other words, "Clock Validity Control" is stored in D3..2, not D5..4
of the clock selector unit's bmControls.
Reported-by: Andreas Koch <andreas@akdesigninc.com>
commit 5cd5d7c44990658df6ab49f6253c39617c53b03d upstream.
The array of sample rates is reallocated every time when opening
the PCM device, but was freed only once when unplugging the device.
Reported-by: "Alexander E. Patrakov" <patrakov@gmail.com>
Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com>
Add a stereo volume control for analog input channel pair 1/2.
Add a mute control for every analog output channel.
Add a stereo volume control for every analog output pair 1/2, 3/4, 5/6.
Remove the soft log-conversion and add a dB scale according to
the DAC documentation instead.
Remove unused driver version information from the individual files.
Commit 3702b08 added a lock, but did not account for the case of
SNDRV_PCM_POS_XRUN, which would get immediately overwritten.
This could be bundled into one if-else-if statement, but the goto
helps to clarify the 'exceptional' case.
Thanks to Andreas Pape for spotting this.
Signed-off-by: Mark Hills <mark@pogo.org.uk>
A malicious USB device could feed in a large nr_rates value. This would
cause the subsequent call to kmemdup() to allocate a smaller buffer than
expected, leading to out-of-bounds access.
This patch validates the nr_rates value and reuses the limit introduced
in commit 4fa0e81b ("ALSA: usb-audio: fix possible hang and overflow
in parse_uac2_sample_rate_range()").
Signed-off-by: Xi Wang <xi.wang@gmail.com>
Correct spelling "propably" to "probably" and "activ" to "active"
in sound/usb/usx2y/usbusx2yaudio.c and usx2yhwdeppcm.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (526 commits)
ASoC: twl6040 - Add method to query optimum PDM_DL1 gain
ALSA: hda - Fix the lost power-setup of seconary pins after PM resume
ALSA: usb-audio: add Yamaha MOX6/MOX8 support
ALSA: virtuoso: add S/PDIF input support for all Xonars
ALSA: ice1724 - Support for ooAoo SQ210a
ALSA: ice1724 - Allow card info based on model only
ALSA: ice1724 - Create capture pcm only for ADC-enabled configurations
ALSA: hdspm - Provide unique driver id based on card serial
ASoC: Dynamically allocate the rtd device for a non-empty release()
ASoC: Fix recursive dependency due to select ATMEL_SSC in SND_ATMEL_SOC_SSC
ALSA: hda - Fix the detection of "Loopback Mixing" control for VIA codecs
ALSA: hda - Return the error from get_wcaps_type() for invalid NIDs
ALSA: hda - Use auto-parser for HP laptops with cx20459 codec
ALSA: asihpi - Fix potential Oops in snd_asihpi_cmode_info()
ALSA: hdsp - Fix potential Oops in snd_hdsp_info_pref_sync_ref()
ALSA: hda/cirrus - support for iMac12,2 model
ASoC: cx20442: add bias control over a platform provided regulator
ALSA: usb-audio - Avoid flood of frame-active debug messages
ALSA: snd-usb-us122l: Delete calls to preempt_disable
mfd: Put WM8994 into cache only mode when suspending
Fix up trivial conflicts in:
- arch/arm/mach-s3c64xx/mach-crag6410.c:
renamed speyside_wm8962 to tobermory, added littlemill right
next to it
- drivers/base/regmap/{regcache.c,regmap.c}:
duplicate diff that had already come in with other changes in
the regmap tree
With some buggy devices, the usb-audio driver may give "frame xxx active"
kernel messages too often. Better to keep it as debug-only using
snd_printdd(), and also add the rate-limit for avoiding floods.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=738681
Cc: <stable@kernel.org>
They are not needed here.
Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de>
Cc: stable@kernel.org
A malicious USB device may feed in carefully crafted min/max/res values,
so that the inner loop in parse_uac2_sample_rate_range() could run for
a long time or even never terminate, e.g., given max = INT_MAX.
Also nr_rates could be a large integer, which causes an integer overflow
in the subsequent call to kmalloc() in parse_audio_format_rates_v2().
Thus, kmalloc() would allocate a smaller buffer than expected, leading
to a memory corruption.
To exploit the two vulnerabilities, an attacker needs physical access
to the machine to plug in a malicious USB device.
This patch makes two changes.
1) The type of "rate" is changed to unsigned int, so that the loop could
stop once "rate" is larger than INT_MAX.
2) Limit nr_rates to 1024.
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file,
and it fixes the build error in the arch/x86/kernel/microcode_core.c
file, that the merge did not catch.
The microcode_core.c patch was provided by Stephen Rothwell
<sfr@canb.auug.org.au> who was invaluable in the merge issues involved
with the large sysdev removal process in the driver-core tree.
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Signed-off-by: Sergiusz Urbaniak <sergiusz.urbaniak@googlemail.com>
