into imx_3.10.y_android
The recent addition of the USB audio mixer suspend/resume may lead to
deadlocks when the driver tries to call usb_autopm_get_interface()
recursively, since the function tries to sync with the finish of the
other calls. For avoiding it, introduce a flag indicating the resume
operation and avoids the recursive usb_autopm_get_interface() calls
during the resume.
Reported-and-tested-by: Bryan Quigley <gquigs@gmail.com>
The suspend callback of usb-audio driver may be called multiple times
per suspend when multiple USB interfaces are bound to a single sound
card instance. In such a case, it's superfluous to save the mixer
values multiple times. This patch fixes it by checking the counter.
Instead of SNDRV_DEV_LOWLEVEL, use SNDRV_DEV_CODEC type for mixer
objects so that they are managed in a proper release order.
No functional change at this point.
Implement reset_resume callback so that the mixer values are properly
restored. Still no boot quirks are called, so it might not work well
on some devices.
add "usb_audio" switch subsystem and uevent for usb audio
Signed-off-by: b02247 <b02247@freescale.com>
Signed-off-by: Fang Hui <b31070@freescale.com>
commit 4fa71c1550a857ff1dbfe9e99acc1f4cfec5f0d0 upstream.
The commit 44dcbbb1cd61 introduced the usage of bitreverse helpers but
forgot to add the dependency. This patch adds the selection for
CONFIG_BITREVERSE.
Fixes: 44dcbbb1cd61 ('ALSA: snd-usb: add support for bit-reversed byte formats')
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
commit 9b389a8a022110b4bc055a19b888283544d9eba6 upstream.
The probe code of snd-usb-6fire driver overrides the devices[] pointer
wrongly without checking whether it's already occupied or not. This
would screw up the device disconnection later.
Spotted by coverity CID 141423.
commit ac536a848a1643e4b87e8fbd376a63091afc2ccc upstream.
The pcm_usb_stream plugin requires the mremap explicitly for the read
buffer, as it expands itself once after reading the required size.
But the commit [314e51b9: mm: kill vma flag VM_RESERVED and
mm->reserved_vm counter] converted blindly to a combination of
VM_DONTEXPAND | VM_DONTDUMP like other normal drivers, and this
resulted in the failure of mremap().
For fixing this regression, we need to remove VM_DONTEXPAND for the
read-buffer mmap.
Reported-and-tested-by: James Miller <jamesstewartmiller@gmail.com>
commit a9d14bc0b188a822e42787d01e56c06fe9750162 upstream.
The frame check in i_usX2Y_urb_complete() and
i_usX2Y_usbpcm_urb_complete() is bogus and produces false positives as
described in this LAU thread:
http://linuxaudio.org/mailarchive/lau/2013/5/20/200177
This patch removes the check code entirely.
Cc: fzu@wemgehoertderstaat.de
Reported-by: Dr Nicholas J Bailey <nicholas.bailey@glasgow.ac.uk>
Suggested-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Daniel Mack <zonque@gmail.com>
commit 4c2aee0032b70083dafebd733ed9c774633b2fa3 upstream.
Patch makes midi output buffer DMA-able by allocating it separately.
Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com>
commit 5ece263f1d93fba8d992e67e3ab8a71acf674db9 upstream.
Patch makes pcm buffers DMA-able by allocating each one separately.
commit 140d37de62ffe8405282a1d6498f3b4099006384 upstream.
Add the volume control quirk for avoiding the kernel warning
for the Logitech HD Webcam C525
as in the similar commit 36691e1be6ec551eef4a5225f126a281f8c051c2
for the Logitech HD Webcam C310.
Reported-by: Maksim Boyko <maksim.a.boyko@gmail.com>
Tested-by: Maksim Boyko <maksim.a.boyko@gmail.com>
Signed-off-by: Maksim Boyko <maksim.a.boyko@gmail.com>
commit ddb6b5a964371e8e52e696b2b258bda144c8bd3f upstream.
Patch fixes 6fire not to use stack as URB transfer_buffer. URB buffers need to
be DMA-able, which stack is not. Furthermore, transfer_buffer should not be
allocated as part of larger device structure because DMA coherency issues and
patch fixes this issue too.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
Tested-by: Torsten Schenk <torsten.schenk@zoho.com>
commit 57e6dae1087bbaa6b33d3dd8a8e90b63888939a3 upstream.
The driver used to assume that the streaming endpoint's wMaxPacketSize
value would be an indication of how much data the endpoint expects or
sends, and compute the number of packets per URB using this value.
However, the Focusrite Scarlett 2i4 declares a value of 1024 bytes,
while only about 88 or 44 bytes are be actually used. This discrepancy
would result in URBs with far too few packets, which would not work
correctly on the EHCI driver.
To get correct URBs, use wMaxPacketSize only as an upper limit on the
packet size.
Reported-by: James Stone <jamesmstone@gmail.com>
Tested-by: James Stone <jamesmstone@gmail.com>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit be2f93a4c4981b3646b6f98f477154411b8516cb upstream.
Return SNDRV_PCM_POS_XRUN (snd_pcm_uframes_t) instead of
SNDRV_PCM_STATE_XRUN (snd_pcm_state_t) from the pointer
function of 6fire, as expected by snd_pcm_update_hw_ptr0().
Caught by sparse.
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
commit 5be1efb4c2ed79c3d7c0cbcbecae768377666e84 upstream.
snd_pcm_stop() must be called in the PCM substream lock context.
commit 9538aa46c2427d6782aa10036c4da4c541605e0e upstream.
Acked-by: Clemens Ladisch <clemens@ladisch.de>
commit 5b9ab3f7324a1b94a5a5a76d44cf92dfeb3b5e80 upstream.
Just like the previous fix for LogitechHD Webcam c270 in commit
11e7064f35bb87da8f427d1aa4bbd8b7473a3993, c310 model also requires the
same workaround for avoiding the kernel warning.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59741
Cc: <stable@vger.kernel.org>
When the Android firmware enables the audio interfaces in accessory
mode, it always declares in the control interface's baInterfaceNr array
that interfaces 0 and 1 belong to the audio function. However, the
accessory interface itself, if also enabled, already is at index 0 and
shifts the actual audio interface numbers to 1 and 2, which prevents the
PCM streaming interface from being seen by the host driver.
To get the PCM interface interface to work, detect when the descriptors
point to the (for this driver useless) accessory interface, and redirect
to the correct one.
Reported-by: Jeremy Rosen <jeremy.rosen@openwide.fr>
Tested-by: Jeremy Rosen <jeremy.rosen@openwide.fr>
USB audio driver spews an error message when probing Logitech HD
webcam c270:
ALSA mixer.c:1300 usb_audio: Warning! Unlikely big volume range (=6144), cval->res is probably wrong.
ALSA mixer.c:1304 usb_audio: [5] FU [Mic Capture Volume] ch = 1, val = 1536/7680/1
Obviously the device needs a fixed volume resolution (cval->res = 384)
like other Logitech devices.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=821735
Reported-and-tested-by: Cristian Rodríguez <crrodriguez@opensuse.org>
... instead of applying to all interfaces.
Reference: http://forums.gentoo.org/viewtopic-p-6886404.html
Commit 927c9423dd5f2d1c0b93d5e694ab84b4a5559713 (ALSA: usb-audio: add
Edirol UM-3G support) used a wrong quirk type, which would make the
driver refuse to attach with the error message "MIDIStreaming interface
descriptor not found".
Cc: <stable@vger.kernel.org> # 3.3 and later
Check only the uppermost 16 bits instead of the whole 32 bits of
the version information. Do this because all firmware version tested
with this version information worked correctly and the strict check
causes problems for several users.
freqshift is only set for the data endpoint and syncmaxsize is only set
for the sync endpoint. This results in a syncmaxsize of zero used in the
proc output feedback format calculation, which gives a feedback format
incorrectly shown as 8.16 for UAC2 devices.
As neither the data nor the sync endpoint gives all the relevant
content, output the two combined.
Also remove the sync_endpoint "packet size" which is always zero
and the sync_endpoint "momentary freq" which is constant.
Tested with UAC2 async and UAC1 adaptive, not tested with UAC1 async.
Reported-by: B. Zhang <bb.zhang@free.fr>
Signed-off-by: Torstein Hegge <hegge@resisty.net>
Current code does this:
be16_to_cpu(buf[i * 2] << 8 | buf[(i * 2) + 1])
Which is effectively (neglecting the index):
be16_to_cpu(be16_to_cpu(*((u16 *) buf)))
This means the int16 in the buffer is not converted at all.
Daniel Mack confirmed that the driver works on little endian
CPUs, leading to the conclusion that the device-side structure
is actually little endian.
This changes the code to use le16_to_cpu().
Caught by sparse.
Acked-by: Daniel Mack <zonque@gmail.com>
Add a function to handle conversion from snd_pcm_format_t
to bitwise with proper typing.
Change such conversions to use this function and silence sparse
warnings.
The recent changes in the USB API ("implement new semantics for
URB_ISO_ASAP") made the former meaning of the URB_ISO_ASAP flag the
default, and changed this flag to mean that URBs can be delayed.
This is not the behaviour wanted by any of the audio drivers because
it leads to discontinuous playback with very small period sizes.
Therefore, our URBs need to be submitted without this flag.
Reported-by: Joe Rayhawk <jrayhawk@fairlystable.org>
Cc: <stable@vger.kernel.org> # 3.8 only
The Scarlett 2i2 seems to take almost 500 ms to set the sample rate,
even if the clock is currently set to that value. This patch speeds
up prepare of the device, by avoiding setting the clock to something
it already is.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
This patch adds a USB quirk for the Yamaha THR10C amp.
Signed-off-by: Trulan Martin <trulanm@gmail.com>
This patch adds a USB quirk for the Yamaha THR5A amp.
This patch adds a USB quirk for the Yamaha THR10 amp.
We've got strange errors in get_ctl_value() in mixer.c during
probing, e.g. on Hercules RMX2 DJ Controller:
ALSA mixer.c:352 cannot get ctl value: req = 0x83, wValue = 0x201, wIndex = 0xa00, type = 4
ALSA mixer.c:352 cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0xa00, type = 4
It turned out that the culprit is autopm: snd_usb_autoresume() returns
-ENODEV when called during card->probing = 1.
Since the call itself during card->probing = 1 is valid, let's fix the
return value of snd_usb_autoresume() as success.
Reported-and-tested-by: Daniel Schürmann <daschuer@mixxx.org>
The USB_DT_CS_ENDPOINT class-specific endpoint descriptor is usually
stuffed directly after the standard USB endpoint descriptor, and this is
where the driver currently expects it to be.
There are, however, devices in the wild that have it the other way
around in their descriptor sets, so the USB_DT_CS_ENDPOINT comes
*before* the standard enpoint. Devices known to implement it that way
are "Sennheiser BTD-500" and Plantronics USB headsets.
When the driver can't find the USB_DT_CS_ENDPOINT, it won't be able to
change sample rates, as the bitmask for the validity of this command is
storen in bmAttributes of that descriptor.
Fix this by searching the entire interface instead of just the extra
bytes of the first endpoint, in case the latter fails.
Reported-and-tested-by: Torstein Hegge <hegge@resisty.net>
Reported-and-tested-by: Yves G <alsa-user@vivigatt.com>
Cc: stable@kernel.org
Set the timeout for USB control set messages according to the USB 2
spec, using the macros from include/linux/usb.h.
The get timout becomes 5000 ms even though it is 500 ms in the
spec. This patch is required to run the Hercules RMX2 which needs a
timeout of 1240 ms.
More notes from author:
I still distinguish between set and get but as long both are 5000 ms
GCC will remove it anyway. IMHO this is more easy read and there is no
need to explain why we use a get timeout for set messages.
Signed-off-by: Daniel Schürmann <daschuer@mixxx.org>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next
ASoC: More updates for v3.10
The main additional change here is Lars-Peter's DMA work plus the
platform conversions which have been tested - getting this in mainline
will make life easier for development after the merge window. These
factor a large chunk of code out of the drivers for the platforms using
dmaengine, greatly simplifying development.
Unfortunately, none of the UAC standards provides a way to identify DSD
(Direct Stream Digital) formats. Hence, this patch adds a quirks
handler to identify USB interfaces that are capable of handling DSD.
That quirks handler can augment the already parsed formats bit-field,
by any of the new SNDRV_PCM_FMTBIT_DSD_{U8_U16} and setting the dsd_dop
flag in the audio format, if the driver should take care for the DOP
byte stuffing.
The only devices that are known to work with this are the ones with
a 'Playback Designs' vendor id.
There is quite some confusion around the bit-ordering in DSD samples,
and no general agreement that defines whether hardware is supposed to
expect the oldest sample in the MSB or the LSB of a byte.
ALSA will hence set the rule that on the software API layer, bytes
always carry the oldest bit in the most significant bit of a byte, and
the driver has to translate that at runtime in order to match the
hardware layout.
This patch adds support for this by adding a boolean flag to the
audio format struct.
In order to provide a compatibility way for pushing DSD
samples through ordinary PCM channels, the "DoP open Standard" was
invented. See http://www.dsd-guide.com for the official document.
The host is required to stuff DSD marker bytes (0x05, 0xfa,
alternating) in the MSB of 24 bit wide samples on the bus, in addition
to the 16 bits of actual DSD sample payload.
To support this, the hardware and software stride logic in the driver
has to be tweaked a bit, as we make the userspace believe we're
operating on 16 bit samples, while we in fact push one more byte per
channel down to the hardware.
The DOP runtime information is stored in struct snd_usb_substream, so
we can keep track of our state across multiple calls to
prepare_playback_urb_dsd_dop().
For normal PCM transfer, this change has no effect, as the endpoint's
stride is always frame_bits/8. For DSD DOP streams, however, which is
added later, the hardware stride differs from the software stride, and
the endpoint has the correct information in these cases.
Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend)
introduced autopm for all USB audio/MIDI devices. However, many MIDI
devices, such as synthesizers, do not merely transmit MIDI messages but
use their MIDI inputs to control other functions. With autopm, these
devices would get powered down as soon as the last MIDI port device is
closed on the host.
Even some plain MIDI interfaces could get broken: they automatically
send Active Sensing messages while powered up, but as soon as these
messages cease, the receiving device would interpret this as an
accidental disconnection.
Commit f5f165418cab (ALSA: usb-audio: Fix missing autopm for MIDI input)
introduced another regression: some devices (e.g. the Roland GAIA SH-01)
are self-powered but do a reset whenever the USB interface's power state
changes.
To work around all this, just disable autopm for all USB MIDI devices.
Reported-by: Laurens Holst
When recording at 176.2KHz or 192Khz, the device adds a 32-bit length
header to the capture packets, which obviously needs to be ignored for
recording to work properly.
Userspace expected: L0 L1 L2 R0 R1 R2
...but actually got: R2 L0 L1 L2 R0 R1
Also, the last byte of the length header being interpreted as L0 of
the first sample caused spikes every 0.5ms, resulting in a loud 16KHz
tone (about the highest 'B' on a piano) being present throughout
captures.
Tested at all sample rates on an E-Mu 0404USB, and tested for
regressions on a generic USB headset.
Signed-off-by: Calvin Owens <jcalvinowens@gmail.com>
It turns out the devices from Playback Design need the delay quirk
after usb_set_interface from clocks.c as well. Make it a proper
quirks function and factor out the code to quirks.c.
The usb_control_msg() function expects __u16 types and performs
the endianness conversions by itself.
However, in three places, a conversion is performed before it is
handed over to usb_control_msg(), which leads to a double conversion
(= no conversion):
* snd_usb_nativeinstruments_boot_quirk()
* snd_nativeinstruments_control_get()
* snd_nativeinstruments_control_put()
Caught by sparse:
sound/usb/mixer_quirks.c:512:38: warning: incorrect type in argument 6 (different base types)
sound/usb/mixer_quirks.c:512:38: expected unsigned short [unsigned] [usertype] index
sound/usb/mixer_quirks.c:512:38: got restricted __le16 [usertype] <noident>
sound/usb/mixer_quirks.c:543:35: warning: incorrect type in argument 5 (different base types)
sound/usb/mixer_quirks.c:543:35: expected unsigned short [unsigned] [usertype] value
sound/usb/mixer_quirks.c:543:35: got restricted __le16 [usertype] <noident>
sound/usb/mixer_quirks.c:543:56: warning: incorrect type in argument 6 (different base types)
sound/usb/mixer_quirks.c:543:56: expected unsigned short [unsigned] [usertype] index
sound/usb/mixer_quirks.c:543:56: got restricted __le16 [usertype] <noident>
sound/usb/quirks.c:502:35: warning: incorrect type in argument 5 (different base types)
sound/usb/quirks.c:502:35: expected unsigned short [unsigned] [usertype] value
sound/usb/quirks.c:502:35: got restricted __le16 [usertype] <noident>
Some clocks might be read-only, e.g., external clocks (see also
UAC2 4.7.2.1).
In this case, setting the sample frequency will always fail
(even if the rate is equal to the current clock rate),
therefore do not write, but read the value and compare to the
requested rate.
If the clock is read only, avoid reading it twice.
If it doesn't match, return -ENXIO since the clock is invalid for
this configuration.
Show the error code returned from the USB subsystem in
the debug messages.
Add a module param to disable auto clock selection.
This is provided for users that expect the audio stream to
fail when the clock source is invalid (e.g., the word clock
was unintentionally disconnected).
If a selector is available on a device, it may be pointing to a
clock source which is currently invalid.
If there is a valid clock source which can be selected, switch
to it.
Move the check that parse_audio_format_rates_v2() do after
receiving the clock source entity ID directly into the find
function and add a validation flag to the function.
This patch does not introduce any logic flow change.
It is provided to allow introducing automatic clock switching
easier later. By moving this uac_clock_source_is_valid callsite,
2 additional callsites can be avoided.
