commit 2d1cb7f658fb9c3ba8f9dab8aca297d4dfdec835 upstream.
Add the correct dB ranges of Bose Companion 5 and Drangonfly DAC 1.2.
Signed-off-by: Yao-Wen Mao <yaowen@google.com>
commit 0689a86ae814f39af94a9736a0a5426dd82eb107 upstream.
The Steinberg MI2 and MI4 interfaces are compatible with the USB class
audio spec, but the MIDI part of the devices is reported as a vendor
specific interface.
This patch adds entries to quirks-table.h to recognize the MIDI
endpoints. Audio functionality was already working and is unaffected by
this change.
Signed-off-by: Dominic Sacré <dominic.sacre@gmx.de>
Signed-off-by: Albert Huitsing <albert@huitsing.nl>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
commit 044bddb9ca8d49edb91bc22b9940a463b0dbb97f upstream.
Add mixer control names for the ESI Maya44 USB+ (which appears to be
identical width the AudioTrak Maya44 USB).
Reported-by: nightmixes <nightmixes@gmail.com>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 1ef9f0583514508bc93427106ceef3215e4eb1a5 upstream.
Fix this from the logs:
usb 7-1: New USB device found, idVendor=046d, idProduct=08ca
usb 7-1: Warning! Unlikely big volume range (=3072), cval->res is probably wrong.
usb 7-1: [5] FU [Mic Capture Volume] ch = 1, val = 4608/7680/1
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 3dc8523fa7412e731441c01fb33f003eb3cfece1 upstream.
Adds an entry for Creative USB X-Fi to the rc_config array in
mixer_quirks.c to allow use of volume knob on the device.
Adds support for newer X-Fi Pro card, known as "Model No. SB1095"
with USB ID "041e:3237"
Signed-off-by: Dmitry M. Fedin <dmitry.fedin@gmail.com>
commit fcdcd1dec6d2c7b718385ec743ae5a9a233edad4 upstream.
The device complies to the UAC1 standard but hides that fact with
proprietary descriptors. The autodetect quirk for Roland devices
catches the audio interface but misses the MIDI part, so a specific
quirk is needed.
Signed-off-by: Daniel Mack <daniel@zonque.org>
Reported-by: Rafa Lafuente <rafalafuente@gmail.com>
Tested-by: Raphaël Doursenaud <raphael@doursenaud.fr>
commit 6455931186bff407493135e74c5f32efd30860e2 upstream.
Signed-off-by: Jason Lee Cragg <jcragg@gmail.com>
commit 678fa12fb8e75c6dc1e781a02e3ddbbba7e1a904 upstream.
The au0828 quirks table is currently not in sync with the au0828
media driver.
Syncronize it and put them on the same order as found at au0828
driver, as all the au0828 devices with analog TV need the
same quirks.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit 5d1f00a20d2d56ed480e64e938a2391353ee565b upstream.
Add a macro to simplify au0828 quirk table. That makes easier
to check it against the USB IDs at drivers/media/usb/au0828/au0828-cards.c.
commit d70a1b9893f820fdbcdffac408c909c50f2e6b43 upstream.
The Arcam rPAC seems to have the same problem - whenever anything
(alsamixer, udevd, 3.9+ kernel from 60af3d037eb8c, ..) attempts to
access mixer / control interface of the card, the firmware "locks up"
the entire device, resulting in
SNDRV_PCM_IOCTL_HW_PARAMS failed (-5): Input/output error
from alsa-lib.
Other operating systems can somehow read the mixer (there seems to be
playback volume/mute), but any manipulation is ignored by the device
(which has hardware volume controls).
Signed-off-by: Jiri Jaburek <jjaburek@redhat.com>
commit 66139a48cee1530c91f37c145384b4ee7043f0b7 upstream.
In snd_usbmidi_error_timer(), the driver tries to resubmit MIDI input
URBs to reactivate the MIDI stream, but this causes the error when
some of URBs are still pending like:
WARNING: CPU: 0 PID: 0 at ../drivers/usb/core/urb.c:339 usb_submit_urb+0x5f/0x70()
URB ef705c40 submitted while active
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.16.6-2-desktop #1
Hardware name: FOXCONN TPS01/TPS01, BIOS 080015 03/23/2010
c0984bfa f4009ed4 c078deaf f4009ee4 c024c884 c09a135c f4009f00 00000000
c0984bfa 00000153 c061ac4f c061ac4f 00000009 00000001 ef705c40 e854d1c0
f4009eec c024c8d3 00000009 f4009ee4 c09a135c f4009f00 f4009f04 c061ac4f
Call Trace:
[<c0205df6>] try_stack_unwind+0x156/0x170
[<c020482a>] dump_trace+0x5a/0x1b0
[<c0205e56>] show_trace_log_lvl+0x46/0x50
[<c02049d1>] show_stack_log_lvl+0x51/0xe0
[<c0205eb7>] show_stack+0x27/0x50
[<c078deaf>] dump_stack+0x45/0x65
[<c024c884>] warn_slowpath_common+0x84/0xa0
[<c024c8d3>] warn_slowpath_fmt+0x33/0x40
[<c061ac4f>] usb_submit_urb+0x5f/0x70
[<f7974104>] snd_usbmidi_submit_urb+0x14/0x60 [snd_usbmidi_lib]
[<f797483a>] snd_usbmidi_error_timer+0x6a/0xa0 [snd_usbmidi_lib]
[<c02570c0>] call_timer_fn+0x30/0x130
[<c0257442>] run_timer_softirq+0x1c2/0x260
[<c0251493>] __do_softirq+0xc3/0x270
[<c0204732>] do_softirq_own_stack+0x22/0x30
[<c025186d>] irq_exit+0x8d/0xa0
[<c0795228>] smp_apic_timer_interrupt+0x38/0x50
[<c0794a3c>] apic_timer_interrupt+0x34/0x3c
[<c0673d9e>] cpuidle_enter_state+0x3e/0xd0
[<c028bb8d>] cpu_idle_loop+0x29d/0x3e0
[<c028bd23>] cpu_startup_entry+0x53/0x60
[<c0bfac1e>] start_kernel+0x415/0x41a
For avoiding these errors, check the pending URBs and skip
resubmitting such ones.
Reported-and-tested-by: Stefan Seyfried <stefan.seyfried@googlemail.com>
commit 6e84a8d7ac3ba246ef44e313e92bc16a1da1b04a upstream.
This patch adds a USB control message delay quirk for a few specific Marantz/Denon
devices. Without the delay the DACs will not work properly and produces the
following type of messages:
Nov 15 10:09:21 orwell kernel: [ 91.342880] usb 3-13: clock source 41 is not valid, cannot use
Nov 15 10:09:21 orwell kernel: [ 91.343775] usb 3-13: clock source 41 is not valid, cannot use
There are likely other Marantz/Denon devices using the same USB module which exhibit the
same problems. But as this cannot be verified I limited the patch to the devices
I could test.
The following two devices are covered by this path:
- Marantz SA-14S1
- Marantz HD-DAC1
Signed-off-by: Jurgen Kramer <gtmkramer@xs4all.nl>
commit 1a290581ded60e87276741f8ca97b161d2b226fc upstream.
M-audio FastTrack Ultra quirk doesn't release the kzalloc'ed memory.
This patch adds the private_free callback to release it properly.
commit 0725dda207e95ff25f1aa01432250323e0ec49d6 upstream.
Some USB-audio devices show weird sysfs warnings at disconnecting the
devices, e.g.
usb 1-3: USB disconnect, device number 3
WARNING: CPU: 0 PID: 973 at fs/sysfs/group.c:216 device_del+0x39/0x180()
sysfs group ffffffff8183df40 not found for kobject 'midiC1D0'
Call Trace:
[<ffffffff814a3e38>] ? dump_stack+0x49/0x71
[<ffffffff8103cb72>] ? warn_slowpath_common+0x82/0xb0
[<ffffffff8103cc55>] ? warn_slowpath_fmt+0x45/0x50
[<ffffffff813521e9>] ? device_del+0x39/0x180
[<ffffffff81352339>] ? device_unregister+0x9/0x20
[<ffffffff81352384>] ? device_destroy+0x34/0x40
[<ffffffffa00ba29f>] ? snd_unregister_device+0x7f/0xd0 [snd]
[<ffffffffa025124e>] ? snd_rawmidi_dev_disconnect+0xce/0x100 [snd_rawmidi]
[<ffffffffa00c0192>] ? snd_device_disconnect+0x62/0x90 [snd]
[<ffffffffa00c025c>] ? snd_device_disconnect_all+0x3c/0x60 [snd]
[<ffffffffa00bb574>] ? snd_card_disconnect+0x124/0x1a0 [snd]
[<ffffffffa02e54e8>] ? usb_audio_disconnect+0x88/0x1c0 [snd_usb_audio]
[<ffffffffa015260e>] ? usb_unbind_interface+0x5e/0x1b0 [usbcore]
[<ffffffff813553e9>] ? __device_release_driver+0x79/0xf0
[<ffffffff81355485>] ? device_release_driver+0x25/0x40
[<ffffffff81354e11>] ? bus_remove_device+0xf1/0x130
[<ffffffff813522b9>] ? device_del+0x109/0x180
[<ffffffffa01501d5>] ? usb_disable_device+0x95/0x1f0 [usbcore]
[<ffffffffa014634f>] ? usb_disconnect+0x8f/0x190 [usbcore]
[<ffffffffa0149179>] ? hub_thread+0x539/0x13a0 [usbcore]
[<ffffffff810669f5>] ? sched_clock_local+0x15/0x80
[<ffffffff81066c98>] ? sched_clock_cpu+0xb8/0xd0
[<ffffffff81070730>] ? bit_waitqueue+0xb0/0xb0
[<ffffffffa0148c40>] ? usb_port_resume+0x430/0x430 [usbcore]
[<ffffffff8105973e>] ? kthread+0xce/0xf0
[<ffffffff81059670>] ? kthread_create_on_node+0x1c0/0x1c0
[<ffffffff814a8b7c>] ? ret_from_fork+0x7c/0xb0
---[ end trace 40b1928d1136b91e ]---
This comes from the fact that usb-audio driver may receive the
disconnect callback multiple times, per each usb interface. When a
device has both audio and midi interfaces, it gets called twice, and
currently the driver tries to release resources at the last call.
At this point, the first parent interface has been already deleted,
thus deleting a child of the first parent hits such a warning.
For fixing this problem, we need to call snd_card_disconnect() and
cancel pending operations at the very first disconnect while the
release of the whole objects waits until the last disconnect call.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=80931
Reported-and-tested-by: Tomas Gayoso <tgayoso@gmail.com>
Reported-and-tested-by: Chris J Arges <chris.j.arges@canonical.com>
commit f0b127fbfdc8756eba7437ab668f3169280bd358 upstream.
Adding support for Steinberg UR22 USB interface via quirks table patch
See Ubuntu bug report:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1317244
Also see threads:
http://linux-audio.4202.n7.nabble.com/Support-for-Steinberg-UR22-Yamaha-USB-chipset-0499-1509-tc82888.html#a82917
http://www.steinberg.net/forums/viewtopic.php?t=62290
Tested by at least 4 people judging by the threads.
Did not test MIDI interface, but audio output and capture both are
functional. Built 3.17 kernel with this driver on Ubuntu 14.04 & tested with mpg123
Patch applied to 3.13 Ubuntu kernel works well enough for daily use.
Signed-off-by: Vlad Catoi <vladcatoi@gmail.com>
commit 53da5ebfef66ea6e478ad9c6add3781472b79475 upstream.
The BOSS ME-25 turns out not to have any useful descriptors in its MIDI
interface, so its needs a quirk entry after all.
Reported-and-tested-by: Kees van Veen <kees.vanveen@gmail.com>
Fixes: 8e5ced83dd1c ("ALSA: usb-audio: remove superfluous Roland quirks")
commit 542baf94ec3c5526955b4c9fd899c7f30fae4ebe upstream.
Original patch fixed the original problem, but the sound was far too low
for most users. This patch references a compare matrix to allow the
volume levels to act normally. I personally tested this patch myself,
and volume levels returned to normal. Please see this discussion for
more details: https://bugzilla.kernel.org/show_bug.cgi?id=65251
Signed-off-by: Paul S McSpadden <fisch602@gmail.com>
DEBUG not defined
commit b7a7723513dc89f83d6df13206df55d4dc26e825 upstream.
This (widely used) construction:
if(printk_ratelimit())
dev_dbg()
Causes the ratelimiting to spam the kernel log with the "callbacks suppressed"
message below, even while the dev_dbg it is supposed to rate limit wouldn't
print anything because DEBUG is not defined for this device.
[ 533.803964] retire_playback_urb: 852 callbacks suppressed
[ 538.807930] retire_playback_urb: 852 callbacks suppressed
[ 543.811897] retire_playback_urb: 852 callbacks suppressed
[ 548.815745] retire_playback_urb: 852 callbacks suppressed
[ 553.819826] retire_playback_urb: 852 callbacks suppressed
So use dev_dbg_ratelimited() instead of this construction.
Signed-off-by: Sander Eikelenboom <linux@eikelenboom.it>
commit a5065eb6da55b226661456e6a7435f605df98111 upstream.
BugLink: http://bugs.launchpad.net/bugs/1305133
Malfunctioning or slow devices can cause a flood of dmesg SPAM.
I've ignored checkpatch.pl complaints about the use of printk_ratelimit() in favour
of prior art in sound/usb/pcm.c.
WARNING: Prefer printk_ratelimited or pr_<level>_ratelimited to printk_ratelimit
+ if (printk_ratelimit() &&
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Eldad Zack <eldad@fogrefinery.com>
Cc: Daniel Mack <zonque@gmail.com>
Cc: Clemens Ladisch <clemens@ladisch.de>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit 92a586bdc06de6629dae1b357dac221253f55ff8 upstream.
When a USB-audio device is disconnected while PCM is still running, we
still see some race: the disconnect callback calls
snd_usb_endpoint_free() that calls release_urbs() and then kfree()
while a PCM stream would be closed at the same time and calls
stop_endpoints() that leads to wait_clear_urbs(). That is, the EP
object might be deallocated while a PCM stream is syncing with
wait_clear_urbs() with the same EP.
Basically calling multiple wait_clear_urbs() would work fine, also
calling wait_clear_urbs() and release_urbs() would work, too, as
wait_clear_urbs() just reads some fields in ep. The problem is the
succeeding kfree() in snd_pcm_endpoint_free().
This patch moves out the EP deallocation into the later point, the
destructor callback. At this stage, all PCMs must have been already
closed, so it's safe to free the objects.
Reported-by: Alan Stern <stern@rowland.harvard.edu>
commit 7040b6d1febfdbd9c1595efb751d492cd2503f96 upstream.
The TEAC UD-H01 firmware sends wrong feedback frequency values, thus
causing the PC to send the samples at a wrong rate, which results in
clicks and crackles in the output.
Add a workaround to detect and fix the corruption.
[mick37@gmx.de: use sender->udh01_fb_quirk rather than
ep->udh01_fb_quirk in snd_usb_handle_sync_urb()]
Reported-and-tested-by: Mick <mick37@gmx.de>
Reported-and-tested-by: Andrea Messa <andr.messa@tiscali.it>
Logitech C500 (046d:0807) needs the same workaround like other
Logitech Webcams.
Cc: <stable@vger.kernel.org>
When the driver tries to access Function Unit 10, the KEF X300A
speakers' firmware apparently locks up, making even PCM streaming
impossible. Work around this by ignoring this FU.
The commit 44dcbbb1cd61 introduced the usage of bitreverse helpers but
forgot to add the dependency. This patch adds the selection for
CONFIG_BITREVERSE.
Fixes: 44dcbbb1cd61 ('ALSA: snd-usb: add support for bit-reversed byte formats')
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
No code change, just a cosmetic cleanup to keep entries ordered by the
device ID within a block of unique vendor IDs.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Creative Live! Cam Vista IM (VF0420) reports rate of 16kHz while working
at 8kHz. The patch adds its USB ID to the existing quirk.
Signed-off-by: Pavel Hofman <pavel.hofman@ivitera.com>
Signed-off-by: Eduard Gilmutdinov <edgilmutdinov@gmail.com>
The Vaughan device support the 352800 rate and not
the 352000
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Plantronics Gamecom 780 headset has a firmware problem, and when the
FU 0x09 volume is changed, it results in either too loud or silence
except for a very narrow range. This patch provides a workaround,
ignoring the node, initialize the volume in a sane value and keep
untouched.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=65251
Fix the following warning when optimizing for size with gcc-4.6.4:
sound/usb/mixer_quirks.c:1514:6: warning: 'err' may be used uninitialized in this function [-Wuninitialized]
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
For Wireless USB audio devices, use multiple isoc packets per URB for
inbound endpoints with a datainterval < 5. This allows the WUSB host
controller to take advantage of bursting to service endpoints whose
logical polling interval is less than the 4ms minimum polling interval
limit in WUSB.
Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com>
Add support for front jack channel selector which is present on EMU0204.
It allows to get 4 channels out of this soundcard.
Tested-by: Yury Bushmelev <jay@jay-tech.ru>
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
According to USB Audio spec v2 bits 25 and 26 of bmChannelConfig are
"Back Left of Center - BLC" and "Back Right of Center - BRC",
respectively.
They are currently assigned to ALSA channels BLC/BRC. However, the ALSA
BLC/BRC are actually the rather nonsensical "bottom left center" and
"bottom right center", so the channels will be assigned wrongly. The
comments in the USB code are also similarly wrong, so this is not
readily apparent without looking at the actual specification.
Fix the channel mapping by mapping bits 25 and 26 to RLC (Rear Left
Center) and RRC (Rear Right Center), respectively, instead.
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
In case the channel count of the input terminal is not the same as
the channel count of the streaming descriptor, the channel config of
the input terminal can not be trusted. Instead fall back to a default
(guessed) channel map.
This was found on a Logitech USB Headset.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
The channel config from the streaming descriptor is probably a
better indicator of the channel map than the input terminal.
Use the input terminal's channel map as fallback only.
If wChannelconfig is given for some formats but not others, userspace
might not be able to set the channel map.
This is RFC because I'm not sure what the best behaviour is - to guess
the channel map from the given number of channels (it's quite likely
that one channel is MONO and two channels is FL FR), or just to supply
UNKNOWN for all channels.
But the complete lack of channel map for a format leads userspace to
believe that the format is not available at all. Or am I
misunderstanding how this should be used?
The probe code of snd-usb-6fire driver overrides the devices[] pointer
wrongly without checking whether it's already occupied or not. This
would screw up the device disconnection later.
Spotted by coverity CID 141423.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next
ASoC: Updates for v3.13
- Further work on the dmaengine helpers, including support for
configuring the parameters for DMA by reading the capabilities of the
DMA controller which removes some guesswork and magic numbers fromm
drivers.
- A refresh of the documentation.
- Conversions of many drivers to direct regmap API usage in order to
allow the ASoC level register I/O code to be removed, this will
hopefully be completed by v3.14.
- Support for using async register I/O in DAPM, reducing the time taken
to implement power transitions on systems that support it.
The pcm_usb_stream plugin requires the mremap explicitly for the read
buffer, as it expands itself once after reading the required size.
But the commit [314e51b9: mm: kill vma flag VM_RESERVED and
mm->reserved_vm counter] converted blindly to a combination of
VM_DONTEXPAND | VM_DONTDUMP like other normal drivers, and this
resulted in the failure of mremap().
For fixing this regression, we need to remove VM_DONTEXPAND for the
read-buffer mmap.
Reported-and-tested-by: James Miller <jamesstewartmiller@gmail.com>
module_usb_driver makes code simpler by removing the boilerplate.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
For updating the HDMI chmap fix.
sound/pci/hda/patch_hdmi.c
This patch adds support for dev speed USB_SPEED_WIRELESS in
snd_usb_parse_datainterval which allows the usb sound core to create
ISO urbs with the correct number and size of buffers.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
This patch updates snd_usb_audio_create also support devices whose
speed == USB_SPEED_WIRELESS.
EP_FLAG_ACTIVATED is never tested for, remove it.
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
As Clemens Ladisch kindly explained:
"Please note that there are two methods to identify alternate settings:
the number, which is the value in bAlternateSetting, and the index,
which is the index in the descriptor array. There might be some wording
in the USB spec that these two values must be the same, but in reality,
[insert standard rant about firmware writers], bAlternateSetting
must be treated as a random ID value."
This patch changes the name to express the correct usage semantics.
No functional change.
If setting the interface fails, the SUBSTREAM_FLAG_SYNC_EP_STARTED
should be cleared.
The return value of snd_usb_endpoint_deactivate() is not used,
make the function have no return value.
Update the documentation to reflect what the function is actually
doing.
If an endpoint in use, its associated URBs should not be
deactivated.
The only call site for deactivate_endpoints() at snd_usb_hw_free().
The return value is not checked there, as it is irrelevant if it
fails on hw_free.
This patch moves the deactivation of the endpoints directly into
snd_usb_hw_free().
