path: root/sound/usb
2006-06-22[ALSA] USB midi: Remove duplicate CS_AUDIO_* #definesBen Williamson
Removed the CS_AUDIO_* #defines, which were duplicates of the class-specific USB_DT_CS_* #defines in <linux/usb_ch9.h>. Signed-off-by: Ben Williamson <ben.williamson@greyinnovation.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] usbaudio - Fix a typoTakashi Iwai
Fix a typo introduced by the last fix. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] usb-audio: add workaround for CSR Bluetooth Headphones (Saitek A-250)Clemens Ladisch
Some devices don't have the required class-specific endpoint descriptors. Instead of making this case an error, this patch makes the driver guess the endpoint attributes. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] add support for SB Live! 24-Bit External remote controlRaimonds Cicans
This patch rewrites the remote control code to use a table for the peculiarities of the various SB models, and adds support for a third model. Signed-off-by: Raimonds Cicans <ray@vardes.lv> Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] rawmidi: add get_port_info callback for sequencer information flagsClemens Ladisch
Add a get_port_info callback to the snd_rawmidi_global_ops structure to allow the USB MIDI driver to supply information flags for the sequencer ports created by seq_midi. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-06-22[ALSA] Add O_APPEND flag support to PCMTakashi Iwai
Added O_APPEND flag support to PCM to enable shared substreams among multiple processes. This mechanism is used by dmix and dsnoop plugins. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] Remove unneeded read/write_size fields in proc text opsTakashi Iwai
Remove unneeded read/write_size fields in proc text ops. snd_info_set_text_ops() is fixed, too. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-04-27[ALSA] add another Phase 26 quirkClemens Ladisch
Add a quirk entry for the TerraTec Phase 26 with yet another product ID. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-31[ALSA] Test volume resolution of usb audio at initializationTakashi Iwai
Test the volume of usb audio whether actually it works and adjusts the resolution value according to it. Some USB audio devices report a lower resolution than it reacts. The only possible check is to write and read a volume value. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-28[PATCH] Typo fixesAlexey Dobriyan
Fix a lot of typos. Eyeballed by jmc@ in OpenBSD. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[ALSA] fix resource leak in usbmixerJesper Juhl
Modules: USB generic driver We may leak 'namelist' in sound/usb/usbmixer.c::parse_audio_selector_unit() Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] usb-audio: add Maya44 mixer control namesClemens Ladisch
Modules: USB generic driver Add mixer control names for the AudioTrak Maya44 USB. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: add Casio PL-40R supportClemens Ladisch
Modules: USB generic driver Add a quirk entry for the Casio PL-40R. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: add MDP-5/EZ-J24 supportClemens Ladisch
Modules: USB generic driver Add support for the Yamaha MDP-5 and EZ-J24. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] Fixes audiophile usb analog capture with the new device_setup parameterThibault LE MEUR
Modules: Documentation,USB generic driver The patch adds the 'device_setup' module parameter and a specific quirk to correctly initialize the audiophile usb device: this fixes the distorted sound bug on the Analog capture port. Backward compatibility is achieved by simply omitting the new parameter. Signed-off-by: Thibault LE MEUR <Thibault.LeMeur@supelec.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] usb-audio: add error message about missing split iso supportClemens Ladisch
Modules: USB generic driver Add an error message for -ENOSYS for situations when split iso support is needed but not enabled. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: change Casio quirk product nameClemens Ladisch
Modules: USB generic driver Use a generic name for USB device 0x07cf:0x6802 because this ID is used by several devices without a product ID. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: show USB error descriptionsClemens Ladisch
Modules: USB generic driver When usb_submit_urb() fails, show an error description instead of just the error code. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: add Casio AP-80R supportClemens Ladisch
Modules: USB generic driver Add a quirk for the Casio AP-80R. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] fix usbmixer double kfreeDave Jones
Modules: USB generic driver snd_ctl_add() kfree's the kcontrol already if we fail there, so this driver is currently doing a double kfree. Coverity bug #959 Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] usb-audio: optimize snd_usbmidi_count_bits()Clemens Ladisch
Modules: USB generic driver Reduce the code size of the snd_usbmidi_count_bits() function by using simpler operations. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] no need to check pointers passed to vfree() for NULLJesper Juhl
Modules: Digigram VX core,USB generic driver There's no need to check pointers passed to vfree() for NULL. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] usb-audio: add Miditech Play'n Roll supportClemens Ladisch
Modules: USB generic driver Add a quirk entry for the Miditech Play'n Roll. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: rename QUIRK_MIDI_MIDITECH to QUIRK_MIDI_CMEClemens Ladisch
Modules: USB generic driver Rename QUIRK_MIDI_MIDITECH to QUIRK_MIDI_CME because Miditech keyboards are built by CME and use the same protocol, and don't force a Miditech product name for the USB ID used by both Miditech and CME UF-x keyboards. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: add UM-1EX/UM-2EX informationClemens Ladisch
Modules: USB generic driver Add comments with information about UM-1EX/UM-2EX devices. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: fix number of G-70 portsClemens Ladisch
Modules: USB generic driver The G-70 has one MIDI port in each direction, no two. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] snd_pcm_format_name() is no longer exportedJaroslav Kysela
Modules: PCM Midlevel,USB generic driver Because snd_pcm_format_name() function is used only for informational purposes, it is no longer exported from the PCM midlevel to reduce space and dependency. usbaudio module shows only numeric value for format. Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-03-22[ALSA] usb-audio: add Roland G-70 supportClemens Ladisch
Modules: USB generic driver Add a quirk entry for the Roland G-70. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] semaphore -> mutex (Archs, misc buses)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] usb-audio: add Edirol PC-50 supportClemens Ladisch
Modules: USB generic driver Add a quirk entry for the Edirol PC-50. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] PCM midlevel & PCM OSS - make procfs & OSS plugin code optionalJaroslav Kysela
Modules: ALSA Core,PCM Midlevel,ALSA<-OSS emulation,USB generic driver 1) The verbose procfs code for the PCM midlevel and usb audio can be removed now (more patches will follow). CONFIG_SND_VERBOSE_PROCFS 2) The PCM OSS plugin system can be also compiled optionaly. CONFIG_SND_PCM_OSS_PLUGINS Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-03-22[ALSA] usb-audio: factor out packet size calculation codeClemens Ladisch
Modules: USB generic driver Move the common packet size calculation code from prepare_startup_playback_urb() and prepare_playback_urb() to a new function. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: cosmetic changesClemens Ladisch
Modules: USB generic driver Move some entries around to keep them sorted by ID. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] Add support for EDIROL UM-3exBrent Cook
Modules: USB generic driver This is my naive attempt at adding ALSA device support. The attached patch provides support for the EDIROL UM-3ex. This is a 3-port USB midi interface with a built-in USB hub and the ability to chain 2 other UM-3x's in a master-slave configuration. I only have one, so I do not know how this works in practice. Though this is a 3-port device, I had to throw in that 4th 'Control' interface to the definition in order to make the 3rd port work. If I set in/out_cables to 0x000b, a 3rd interface appears on the driver, but it does nothing. Changing it to 0x000f allows the 3rd interface to work, but of course interface 4 does not work because it does not exist. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-22[ALSA] usb-audio: fix non-48k sample rates with SB Audigy 2 ZSClemens Ladisch
Modules: USB generic driver On the Audigy 2 ZS, disable all sample rate that are not a multiple of 48 kHz because the others work only with the digital output which is not yet supported. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-22[ALSA] usb-audio: don't use empty packets at start of playbackClemens Ladisch
Modules: USB generic driver Some widespread USB interface chips with adaptive iso endpoints hang after receiving a series of empty packets when they expect data (ALSA bug#1585). To avoid this, we have to send packets containing silence (zero samples) instead. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-03[ALSA] usb-audio: fix Edirol UA-20 supportClemens Ladisch
Modules: USB generic driver Somebody at Edirol fucked up and released a new revision of the UA-20 without class-specific descriptors, so now we have to hard-code the sample format. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Remove xxx_t typedefs: USB-USX2YTakashi Iwai
Modules: USB USX2Y Remove xxx_t typedefs from the USB-USX2Y driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: USB-AudioTakashi Iwai
Modules: USB generic driver Remove xxx_t typedefs from the USB-Audio driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] usx2y - Code clean upTakashi Iwai
Modules: USB USX2Y Clean up snd-usb-usx2y driver code: - Avoid unnecessary cast - Fix spaces/indents - Use kzalloc() - Remove weird debug prints Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove superfluous pcm_free callbacksTakashi Iwai
Remove superflous pcm_free callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-22[PATCH] unpaged: sound nopage get_pageHugh Dickins
Something noticed when studying use of VM_RESERVED in different drivers: snd_usX2Y_hwdep_pcm_vm_nopage omitted to get_page: fixed. And how did this work before? Aargh! That nopage is returning a page from within a buffer allocated by snd_malloc_pages, which allocates a high-order page, then does SetPageReserved on each 0-order page within. That would have worked in 2.6.14, because when the area was unmapped, PageReserved inhibited put_page. 2.6.15-rc1 removed that inhibition (while leaving ineffective PageReserveds around for now), but it hasn't caused trouble because.. we've not been freeing from VM_RESERVED at all. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-04[ALSA] usb-audio: remove duplicate fixup entry (Hercules DJ Console)Jaroslav Kysela
Modules: USB generic driver Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2005-11-04[ALSA] usb-audio: start submitting URBs in the prepared stateClemens Ladisch
Modules: USB generic driver If we submit all our URBs when a playback stream is started, the first hwptr_done update for each URB happens at the same time. This results in an underrun when there isn't enough PCM data available at this point for all URBs. To avoid this, we begin submitting our URBs earlier (when the stream is prepared), with empy packets. When the stream is started, the prepare_playback_urb() call for each URB will be run only when the respective URB has completed previously, so the first hwptr_done updates will be done nicely staggered. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] usb-audio: remove superfluous includeClemens Ladisch
Modules: USB generic driver Remove a superfluous include of the sound/minors.h header. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-11-04[ALSA] Fix schedule_timeout usageNishanth Aravamudan
Use schedule_timeout_{,un}interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Also use human-time conversion functions instead of hard-coded division to avoid rounding issues. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Add missing KERN_* prefixTakashi Iwai
Modules: ALSA<-OSS emulation,USB generic driver,USB USX2Y Added missing KERN_* prefix to printk. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] usb-audio: don't call usb_reset_configuration() when probingClemens Ladisch
Modules: USB generic driver Remove the usb_reset_configuration() call from the probe callback because it isn't needed and it may interfere with other drivers already loaded for the device. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
