path: root/sound/usb
2010-04-16Merge branch 'fix/misc' into for-linusTakashi Iwai
2010-04-10ALSA: usb - Fix Oops after usb-midi disconnectionTakashi Iwai
usb-midi causes sometimes Oops at snd_usbmidi_output_drain() after disconnection. This is due to the access to the endpoints which have been already released at disconnection while the files are still alive. This patch fixes the problem by checking disconnection state at snd_usbmidi_output_drain() and by releasing urbs but keeping the endpoint instances until really all freed. Tested-by: Tvrtko Ursulin <tvrtko@ursulin.net> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03ALSA: usbaudio - remove debug "SAMPLE BYTES" printk lineJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-02ALSA: usbaudio: Fix wrong bitrate for Creative Creative VF0470 Live CamArseniy Lartsev
This patch works around misbehaviour of Creative Creative VF0470 Live Cam which reports 16 kHz sample rate for audio capture while actually producing 8 kHz stream. Signed-off-by: Arseniy Lartsev <arseniy@fizlesh.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-02Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
Conflicts: sound/usb/usbaudio.c
2010-03-02ALSA: ua101: removing debugging codeClemens Ladisch
Remove some code that is no longer needed now that the relevant parts of the driver have been tested. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-03-02ALSA: sound/usb/caiaq/midi.h: Checkpatch cleanupAndrea Gelmini
sound/usb/caiaq/midi.h:6: ERROR: "foo* bar" should be "foo *bar" Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-01ALSA: ua101: add Edirol UA-1000 supportClemens Ladisch
Add support for the Edirol UA-1000 to the UA-101 driver. Both devices behave the same, so we just have to shuffle around some interface numbers and name strings. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-02-23ALSA: usbaudio: consolidate header filesDaniel Mack
Use the definitions from linux/usb/audio.h all over the ALSA USB audio driver and add some missing definitions there as well. Use the endpoint attribute macros from linux/usb/ch9 and remove the own things from sound/usb/usbaudio.h. Now things are also nicely prefixed which makes understanding the code easier. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-23ALSA: usbmixer: bail out early when parsing audio class v2 descriptorsDaniel Mack
This is just a quick hack that needs to be removed once the new units defined by the audio class v2.0 standard are supported. However, it allows using these devices for now, without mixer support. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-23ALSA: usbaudio: implement basic set of class v2.0 parserDaniel Mack
This adds a number of parsers for audio class v2.0. In particular, the following internals are different and now handled by the code: * the number of streaming interfaces is now reported by an interface association descriptor. The old approach using a proprietary descriptor is deprecated. * The number of channels per interface is now stored in the AS_GENERAL descriptor (used to be part of the FORMAT_TYPE descriptor). * The list of supported sample rates is no longer stored in a variable length appendix of the format_type descriptor but is retrieved from the device using a class specific GET_RANGE command. * Supported sample formats are now reported as 32bit bitmap rather than a fixed value. For now, this is worked around by choosing just one of them. * A devices needs to have at least one CLOCK_SOURCE descriptor which denotes a clockID that is needed im the class request command. * Many descriptors (format_type, ...) have changed their layout. Handle this by casting the descriptors to the appropriate structs. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-23ALSA: usbaudio: introduce new types for audio class v2Daniel Mack
This patch adds some definitions for audio class v2. Unfortunately, the UNIT types PROCESSING_UNIT and EXTENSION_UNIT have different numerical representations in both standards, so there is need for a _V1 add-on now. usbmixer.c is changed accordingly. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-23ALSA: usbaudio: parse USB descriptors with structsDaniel Mack
In preparation of support for v2.0 audio class, use the structs from linux/usb/audio.h and add some new ones to describe the fields that are actually parsed by the descriptor decoders. Also, factor out code from usb_create_streams(). This makes it easier to adopt the new iteration logic needed for v2.0. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-22ALSA: usbaudio Mbox support, output onlyChris J Arges
Signed-off-by: Chris J Arges <christopherarges@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-17Merge branch 'fix/misc' into topic/miscTakashi Iwai
Conflicts: sound/pci/hda/patch_realtek.c
2010-02-17Merge remote branch 'alsa/fixes' into fix/miscTakashi Iwai
2010-02-16ALSA: usbmixer - use MAX_ID_ELEMS where possibleJaroslav Kysela
2010-02-16ALSA: usbmixer - add usb_id value to usbmixer proc fileJaroslav Kysela
2010-02-16ALSA: usbmixer - introduce /proc/asound/card#/usbmixer fileJaroslav Kysela
The usbmixer proc file contains mapping between ALSA control API and USB mixer control units. The purpose of this file is for debugging and a problem diagnostics. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-02-16Merge branch 'topic/misc' of ↵Jaroslav Kysela
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 into devel
2010-02-16Merge branch 'fixes' into develJaroslav Kysela
2010-02-16ALSA: USB MIDI support for Access Music VirusTISebastien Alaiwan
Here's a patch that adds MIDI support through USB for one of the Access Music synths, the VirusTI. The synth uses standard USBMIDI protocol on its USB interface 3, although it does signal "vendor specific" class. A magic string has to be sent on interface 3 to enable the sending of MIDI from the synth (this string was found by sniffing usb communication of the Windows driver). This is all my patch does, and it works on my computer. Please note that the synth can also do standard usb audio I/O on its interfaces 2&3, which already works with the current snd-usb-audio driver, except for the audio input from the synth. I'm going to work on it when I have some time. Signed-off-by: Sebastien Alaiwan <sebastien.alaiwan@gmail.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> (cosmetics, list terminator) Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-02-16ALSA: usb-audio: reduce MIDI packet size to work around broken firmwareClemens Ladisch
Extend the list of devices whose firmware does not expect more than one USB MIDI packet in one USB packet. bug report: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3752 Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-02-12Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
2010-02-11ALSA: usbmixer - add possibility to remap dB valuesJaroslav Kysela
USB devices tends to represent dB ranges in different way than ALSA expects. Add possibility to override these values and add guessed values for SoundBlaster MP3+. Also rename 'Capture Input Source' control to 'Capture Source' for SoundBlaster MP3+ and Extigy. Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-01-18ALSA: pcm - Call pgprot_noncached() for vmalloc'ed buffersTakashi Iwai
pgprot_noncached() can be set for vmalloc'ed buffers safely, and we'd need non-cached behavior more or less, even for the intermediate ring- buffers. Now snd_pcm_lib_mmap_vmalloc() is added as the common PCM mmap callback that is coupled with snd_pcm_lib_alloc_vmalloc_buffer() & co. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-28ALSA: usb-audio: use usbquirk.h for detection of HVR-950Q/850John S. Gruber
Detect the HVR-950Q HVR-850 urb data alignment quirk using usbquirk.h rather than using a case statement in snd_usb_audio_probe. Signed-off-by: John S. Gruber <JohnSGruber@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-28ALSA: usb-audio: relax urb data align. restriction HVR-950Q and HVR-850 onlyJohn S. Gruber
Addressing audio quality problem. In sound/usb/usbaudio.c, for the Hauppage HVR-950Q and HVR-850 only, change retire_capture_urb to allow transfers on audio sub-slot boundaries rather than audio slots boundaries. With these devices the left and right channel samples can be split between two different urbs. Throwing away extra channel samples causes a sound quality problem for stereo streams as the left and right channels are swapped repeatedly, perhaps many times per second. Urbs unaligned on sub-slot boundaries are still truncated to the next lowest stride (audio slot) to retain synchronization on samples even though left/right channel synchronization may be lost in this case. Detect the quirk using a case statement in snd_usb_audio_probe. BugLink: https://bugs.launchpad.net/ubuntu/+bug/495745 Signed-off-by: John S. Gruber <JohnSGruber@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-28ALSA: usb-audio: make buffer pointer based on bytes instead on framesClemens Ladisch
Since there are devices that do not align the size of their data packets to frame boundaries, the driver needs to be able to keep track of partial frames. This patch prepares for support for such devices by changing the hwptr_done variable from a frame counter to a byte counter. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-28ALSA: usb-audio - Added functionality for E-mu 0404USB/0202USB/TrackerPreSergiy Kovalchuk
Added functionality: 1) Extension Units support (all XU settings now available at alsamixer, kmix, etc): - "AnalogueIn soft limiter" switch; - "Sample rate" selector (values 0,1,2,3,4,5 corresponds to 44.1 48 ... 192 kHz); - "DigitalIn CLK source" selector (internal/external) (**); - "DigitalOut format SPDIF/AC3" switch (**); (**)E-mu-0404usb only. 2) Automatic device sample rate adjustment depending on substream samplerate for both capture and playback substream. [minor coding-style fixes by tiwai] Signed-off-by: Sergiy Kovalchuk <cnb_zerg@yahoo.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-28ALSA: usb-audio - Avoid Oops after disconnectTakashi Iwai
As the release of substreams may be done asynchronously from the disconnection, close callback needs to check the shutdown flag before actually accessing the usb interface. Reference: Novell bnc#505027 http://bugzilla.novell.com/show_bug.cgi?id=565027 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-18sound: ua101: use vmalloc buffer helper functionsClemens Ladisch
Remove this duplicate of snd_pcm_alloc_vmalloc_buffer and use the equivalent core functions instead. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-18sound: usb-audio: use vmalloc buffer helper functionsClemens Ladisch
2009-12-18Merge branch 'fix/misc' into topic/miscTakashi Iwai
2009-12-18sound: sgio2audio/pdaudiocf/usb-audio: initialize PCM bufferClemens Ladisch
When allocating the PCM buffer, use vmalloc_user() instead of vmalloc(). Otherwise, it would be possible for applications to play the previous contents of the kernel memory to the speakers, or to read it directly if the buffer is exported to userspace. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-14sound: add Edirol UA-101 supportClemens Ladisch
Add experimental support for the Edirol UA-101 audio/MIDI interface. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-08ALSA: snd-usb-us122l: add product IDs of US-122MKII and US-144MKIITobias Hansen
I added the product IDs of the new revisions of the devices, so owners can test whether this suffices to make them work. Patched against ALSA snapshot 20091207. Signed-off-by: Tobias Hansen <Tobias.Hansen at physik.uni-hamburg.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-01ALSA: usb - Fix mixer map for Hercules Gamesurround Muse Pocket LTAlexey Fisher
Muse Pocket use brocken mixer names, so alsamixer and PA can't use it correctly This patch add quirk to overwirte default mixers. Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-01Merge branch 'fix/misc' into topic/miscTakashi Iwai
2009-11-24sound: usxxx: cleanup chip fieldClemens Ladisch
The chip field is no longer needed. Move those of its fields that are actually used to the device structure itself. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-24sound: usb: make the USB MIDI module more independentClemens Ladisch
Remove the dependecy from the USB MIDI code on the snd_usb_audio structure. This allows using the USB MIDI module from another driver without having to pretend to be the generic USB audio driver. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-24sound: usb-audio: allow switching altsetting on Roland USB MIDI devicesClemens Ladisch
Add a mixer control to select between the two altsettings on Roland USB MIDI devices where the input endpoint is either bulk or interrupt. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-20ALSA: sound: usbmidi: Use hweight16Akinobu Mita
Use hweight16 instead of Brian Kernighan's/Peter Wegner's method Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-20sound: usb-audio: add Roland UA-1G supportClemens Ladisch
Add support for the Roland UA-1G audio interface. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-17ALSA: usb - Quirk to disable master volume control in PCM2702Javier Kohen
Disable the master volume control in the PCM2702 chipset. The datasheet documents two independent channel volume controls, one master mute control and one master volume control. All controls are fully functional except for the master volume control, which returns USB stalls on all GET requests. Signed-off-by: Javier Kohen <jkohen@users.sourceforge.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-14Merge branch 'fix/misc' into topic/miscTakashi Iwai
2009-11-07ALSA: usb-audio: fix combine_word problemJulian Anastasov
Fix combine_word problem where first octet is not read properly. The only affected place seems to be the INPUT_TERMINAL type. Before now, sound controls can be created with the output terminal's name which is a fallback mechanism used only for unknown input terminal types. For example, Line can wrongly appear as Speaker. After the change it should appear as Line. The side effect of this change can be that users can expect the wrong control name in their scripts or programs while now we return the correct one. Probably, these defines should use get_unaligned_le16 and friends. Signed-off-by: Julian Anastasov <ja@ssi.bg> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-01Merge branch 'fix/misc' into topic/miscTakashi Iwai
2009-10-30ALSA: snd-usb-caiaq: Bump version number to 1.3.20Mark Hills
Signed-off-by: Mark Hills <mark@pogo.org.uk> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
