commit eef0342cf32689f77d78ee3302999e5caaa6a8f3 upstream.
Adds Microsoft LifeCam Cinema USB ID to the snd_usb_get_sample_rate_quirk list as the Lifecam Cinema does not appear to support getting the sample rate.
Fixes the issue where the LifeCam Cinema would wait for USB timeout and log the message "cannot get freq at ep 0x82" when accessed.
Addresses bug report https://bugzilla.kernel.org/show_bug.cgi?id=95961.
Signed-off-by: Adam Honse <calcprogrammer1@gmail.com>
Adds an entry for Creative USB X-Fi to the rc_config array in
mixer_quirks.c to allow use of volume knob on the device.
Adds support for newer X-Fi Pro card, known as "Model No. SB1095"
with USB ID "041e:3237"
Signed-off-by: Dmitry M. Fedin <dmitry.fedin@gmail.com>
Cc: <stable@vger.kernel.org>
Adding this quirk allows us to avoid the noisy
"cannot get freq at ep 0x1" message in dmesg output every time
playback starts.
This ought to affect other Benchmark DAC1 variations using the same
"Microchip Technology, Inc." chip as well, but I have only tested
with the "Pre" variant.
Signed-off-by: Eric Wong <normalperson@yhbt.net>
Cc: Joe Turner <joe@oampo.co.uk>
The device complies to the UAC1 standard but hides that fact with
proprietary descriptors. The autodetect quirk for Roland devices
catches the audio interface but misses the MIDI part, so a specific
quirk is needed.
Signed-off-by: Daniel Mack <daniel@zonque.org>
Reported-by: Rafa Lafuente <rafalafuente@gmail.com>
Tested-by: Raphaƫl Doursenaud <raphael@doursenaud.fr>
The usages of clamp() macro in sound/usb/line6/playback.c are just
wrong, the low and high values are swapped.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fix problem where playback of Denon DA-300USB DAC sometimes does not
start and leads to error messages like "clock source 41 is not valid,
cannot use".
Solution: Treat this device the same as other Denon/Marantz devices in
sound/usb/quirks.c.
Tested with both PCM and DSD formats.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=93261
Signed-off-by: Frank C Guenther <bugzilla.frnkcg@spamgourmet.com>
Adds a quirk to disable the check that the sample rate has been set correctly, as the Lifecam does not support getting the sample rate.
This means that we don't need to wait for the USB timeout when attempting to get the sample rate. Waiting for the timeout causes problems in some applications, which give up on the device acquisition process before it has had time to complete, resulting in no sound.
[minor tidy up by tiwai]
Signed-off-by: Joe Turner <joe@oampo.co.uk>
The address cannot be negative so make it unsigned. Also, an unsigned
int is always sufficient for the length, so no need to overdo it with a
size_t. Finally, add in range checks to see if the values passed in
actually fit where they are used.
Signed-off-by: Chris Rorvick <chris@rorvick.com>
The firmware version is a single byte so have the variable type agree.
Since the address to this member is passed to the read function, using
an int is not even portable.
The serial number (aka ESN) is a 32-bit value.
Put an upper bound on how long we will wait for the device to respond to
a read/write request (i.e., 100 milliseconds) and return an error if
this is reached.
The device indicates the result of a read/write operation by making the
status available on a subsequent request from the driver. This is not
ready immediately, though, so the driver is currently slamming the
device with hundreds of pointless requests before getting the expected
response. Add a two millisecond delay before each attempt. This is
approximately the behavior observed with version 4.2.7.1 of the Windows
driver.
The first URBs are submitted during the prepare stage. When .trigger is
called, the ALSA core saves a trigger tstamp that doesn't correspond to
the actual time when the samples are submitted. The trigger_tstamp is
now updated when the first data are submitted to avoid any time offsets.
A usb-specific trigger_tstamp_pending_update flag is used for now,
at some point the flag would need to move to the ALSA core, USB
is not the only interface where silent block transfers are programmed
as part of the prepare stage, with actual data enabled when .trigger
is called.
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
Provide a unique name for each driver instead of using "line6usb" for
all of them. This will allow for different configurations based on the
driver type.
It is unlikely this function would ever be used in a context without a
pointer to a `struct usb_line6_toneport', so grab the device type from
it rather than having the caller do it.
Add a predicate for testing if the device supports source selection to
make the conditional logic around this a bit cleaner.
Use the new helper function to create sysfs entries in the card more
gracefully without races.
line6_start_timer passes an unsigned int as argument to be used in mod_timer
which is then used by mod_timer as unsigned long, this just fixes up the
argument type. This change helps make static code checkers happy.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
This is only an API consolidation and should make things more readable
it replaces var * HZ / 1000 by msecs_to_jiffies(var).
Use of this function ended with commits 3e58c868db1d ("staging: line6:
drop midi_mask_receive") and af89d2897a71 ("staging: line6: drop
midi_mask_transmit".)
[Removed the corresponding line in midibuf.h, too -- tiwai]
This function has not been used since merging the driver into the kernel
(and a good while before that.)
It's just superfluous and doesn't give any better readability.
PODxt Live Variax doesn't have PCM and HWMON but only MIDI.
It's identical with struct usb_line6.
Most of them are rather relevant with the definitions in driver.h,
and there are only a few lines, so just rip it off.
The definition is no longer used.
Just reformatting the comments and typos fixed, no functional
changes. Particularly,
- avoid the kerneldoc marker "/**",
- reduce multiple comment lines into single lines,
- corrected wrongly referred function names
The user-space API definition for usb_stream stuff should be moved
to include/uapi/sound to be exposed publicly.
While we're at it, add the missing ifdef guard for double inclusion,
too.
Tested-by: Chris Rorvick <chris@rorvick.com>
Both playback and capture callbacks are identical, so let's merge
them.
The current code deals with the stream start / stop solely via
line6_pcm_acquire() and line6_pcm_release(). This was (supposedly)
intended to avoid the races, but it doesn't work as expected. The
concurrent acquire and release calls can be performed without proper
protections, thus this might result in memory corruption.
Furthermore, we can't take a mutex to protect the whole function
because it can be called from the PCM trigger callback that is an
atomic context. Also spinlock isn't appropriate because the function
allocates with kmalloc with GFP_KERNEL. That is, these function just
lead to singular problems.
This is an attempt to reduce the existing races. First off, separate
both the stream buffer management and the stream URB management. The
former is protected via a newly introduced state_mutex while the
latter is protected via each line6_pcm_stream lock.
Secondly, the stream state are now managed in opened and running bit
flags of each line6_pcm_stream. Not only this a bit clearer than
previous combined bit flags, this also gives a better abstraction.
These rewrites allows us to make common hw_params and hw_free
callbacks for both playback and capture directions.
For the monitor and impulse operations, still line6_pcm_acquire() and
line6_pcm_release() are used. They call internally the corresponding
functions for both playback and capture streams with proper lock or
mutex. Unlike the previous versions, these function don't take the
bit masks but the only single type value. Also they are supposed to
be applied only as duplex operations.
Clearing prev_fsize in line6_pcm_acquire() is pretty racy.
This can be called at any time while the stream is being played.
Rather better to clear prev_fbuf and prev_fsize at the proper place
like the stream stop for capture, and just after copying the monitor /
impulse data inside the spinlock.
The impulse and monitor handling in submit_audio_out_urb() isn't
protected thus this can be racy with the capture stream handling.
This patch extends the range to protect via each stream's spinlock
(now the whole submit_audio_*_urb() are covered), and take the capture
stream lock additionally for the impulse and monitor handling part.
Move the check of multi configurations before snd_card_new() as a
short path, and reduce superfluous pointer references.
Instead of allocating the private data individually in each driver's
probe at first, let snd_card_new() allocate the data that is called in
line6_probe(). This simplifies the primary probe functions.
The interface argument is used just for retrieving the assigned
device, which can be already found in line6->ifcdev. Drop them from
the callbacks. Also, pass the usb id to private_init so that the
driver can deal with it there. This is a preliminary work for the
further cleanup to move the whole allocation into driver.c.
A minor optimization; while pausing, the driver just copies the zero
that doesn't need any volume changes.
The PCM stream buffer allocation and free are identical for both
playback and capture streams. Provide single helper functions.
These are used only in pcm.c, thus they can be even static.
This is the last remaining snd_printk() usage in this driver.
The codes to unlink and sync URBs are identical for both playback and
capture streams. Consolidate to single helper functions.
Introduce a new line6_pcm_stream structure and group individual
fields of snd_line6_pcm struct to playback and capture groups.
This patch itself just does rename and nothing else. More
meaningful cleanups based on these fields shuffling will follow.
If the problem still really remains, we should fix it instead of
papering over it like this...
Using a decremental loop without particular reasons worsens the
readability a lot. Use incremental loops instead.
The trigger callback is already spinlocked, so we need no more lock
here (even for the linked substreams). Let's drop it.
