Add initialization for sst_hsw.dev at init stage, which fix the
'NULL device *' warning issues.
Signed-off-by: Jie Yang <yang.jie@intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Add the correct dB ranges of Bose Companion 5 and Drangonfly DAC 1.2.
Signed-off-by: Yao-Wen Mao <yaowen@google.com>
Cc: <stable@vger.kernel.org>
Dell Vostro 5480 (1028:069a) needs the very same quirk used for Vostro
5470 model to make bass speakers properly working.
Reported-and-tested-by: Paulo Roberto de Oliveira Castro <p.oliveira.castro@gmail.com>
The new Dell laptop with codec 256 can't detect headset mic when
headset was inserted on the machine. From alsa-info, we check
init_pin_configs and need to define the new register value for pin
0x1d & 0x1e because the original macro ALC256_STANDARD_PINS can't
match pin definition. Also, the macro ALC256_STANDARD_PINS is
simplified by removing them. This makes headset mic works on laptop.
Codec: Realtek ALC256
Vendor Id: 0x10ec0256
Subsystem Id: 0x102806f2
BugLink: https://bugs.launchpad.net/bugs/1478497
Signed-off-by: Woodrow Shen <woodrow.shen@canonical.com>
Toshiba Satellite S50D has another model with a different PCI SSID
(1179:fa93) while the previous fixup was for 1179:fa91. Adjust the
fixup entry with SND_PCI_QUIRK_MASK() to match with both devices.
Reported-by: Tim Sample <timsample@gmail.com>
Fireworks uses TSB43CB43(IceLynx-Micro) as its IEC 61883-1/6 interface.
This chip includes ARM7 core, and loads and runs program. The firmware
is stored in on-board memory and loaded every powering-on.
Echo Audio ships several versions of firmwares for each model. These
firmwares have each quirk and the quirk changes a sequence of packets.
AudioFire2 has a quirk to transfer a first packet with non-zero in
its dbc field. This causes ALSA Fireworks driver to detect discontinuity.
As long as I investigated, firmware 5.7, 5.7.6 and 5.8 have this quirk.
This commit adds a support for the quirk to handle AudioFire2 packets.
For safe, CIP_SKIP_INIT_DBC_CHECK is applied to all versions of
AudioFire2's firmwares.
02 00050002 90ffffff <-
42 0005000a 90013000
42 00050012 90014400
42 0005001a 90015800
02 0005001a 90ffffff
42 00050022 90019000
42 0005002a 9001a400
42 00050032 9001b800
02 00050032 90ffffff
42 0005003a 9001d000
42 00050042 9001e400
42 0005004a 9001f800
02 0005004a 90ffffff
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
When the headset was plugged in the Dell desktop, the mic of headset
can't be detected and workable.
According to the alsa-info, we found the differece between alsa and
init_pin_configs on the machine, so we need to add the pin configs to
make headset work.
Codec: Realtek ALC3234
Vendor Id: 0x10ec0255
Subsystem Id: 0x102806bb
BugLink: https://bugs.launchpad.net/bugs/1477900
Smatch complains that we have nested checks for "spdif_present". It
turns out the current behavior isn't correct, we should remove the first
check and keep the second.
Fixes: 1077a024812d ('ALSA: hda - Use generic parser for Cirrus codec driver')
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for v4.2
A lot of small fixes here, a few to the core:
- Fix for binding DAPM stream widgets on devices with prefixes assigned
to them
- Minor fixes for the newly added topology interfaces
- Locking and memory leak fixes for DAPM
- Driver specific fixes
The settings in current code does not match the datasheet, fix it.
DAC Control - Address 03h
DAC Digital Interface Format (Bits 5:4)
DAC_DIF1 DAC_DIF0 Description
0 0 Left Justified, up to 24-bit data (default)
0 1 I²S, up to 24-bit data
1 0 Right-Justified, 16-bit Data
1 1 Right-Justified, 24-bit Data
Transmitter Control 2 - Address 12h
Transmitter Digital Interface Format (Bits 7:6)
Tx_DIF1 Tx_DIF0 Description Format Figure
Signed-off-by: Axel Lin <axel.lin@ingics.com>
'asoc/fix/zx' into asoc-linus
'asoc/fix/intel-kconfig' and 'asoc/fix/mediatek' into asoc-linus
The de-emphasis sampling rate selection is controlled by BIT[3:4] of
PCM1681_DEEMPH_CONTROL register. Do proper left shift to set it.
Acked-by: Marek Belisko <marek.belisko@streamunlimited.com>
Cc: stable@vger.kernel.org
The regmap_write in ssm4567_set_dai_fmt accidentally clears the
TDM_BCLKS field which was set earlier by ssm4567_set_tdm_slot.
This patch fixes it by using regmap_update_bits with proper mask.
Signed-off-by: Ben Zhang <benzh@chromium.org>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Acked-by: Anatol Pomozov <anatol.pomozov@gmail.com>
Currently, below code actually does not update any bit because
SGTL5000_SMALL_POP is 0.
snd_soc_update_bits(codec, SGTL5000_CHIP_REF_CTRL, SGTL5000_SMALL_POP, 1);
The SGTL5000_SMALL_POP should be BIT(0) rather than 0, fix it.
Acked-By: Alexander Stein <alexander.stein@systec-electronic.com>
Without this patch, the headset mic will not work on this machine.
BugLink: https://bugs.launchpad.net/bugs/1476987
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
One more Dell laptop with alc293 codec needs
ALC293_FIXUP_DELL1_MIC_NO_PRESENCE, but the pin 0x1e does not match
the corresponding one in the ALC292_STANDARD_PINS. To use this macro
for this machine, we need to remove pin 0x1e from it.
BugLink: https://bugs.launchpad.net/bugs/1476888
Signed-off-by: Hui Wang <hui.wang@canonical.com>
Commit fdb6eb0a1287 ("ASoC: dapm: Modify widget stream name according to
prefix") fixed the case where a DAPM route between a DAI widget and a
DAC/ADC/AIF widget with a matching stream name was not created when the
DAPM context was using a prefix.
Unfortunately the patch introduced a few issues on its own like leaking the
dynamically allocated stream name memory and also not checking whether the
allocation succeeded in the first place.
It is also incomplete in that it still does not handle the case where
stream name of the widget is a substring of the stream name of the DAI,
which is explicitly allowed and works fine if no DAPM prefix is used.
Revert the commit and take a slightly different approach to solving the
issue. Instead of comparing the widget's stream name to the name of the DAI
widget compare it to the stream name of the DAI widget. The stream name of
the DAI widget is identical to the name of the DAI widget except that it
wont have the DAPM prefix added. So this approach behaves identical
regardless to whether the DAPM context uses a prefix or not.
We don't have to worry about potentially matching with a widget with the
same stream name, but from a different DAPM context with a different
prefix, since the code already makes sure that both the DAI widget and the
matched widget are from the same DAPM context.
Fixes: fdb6eb0a1287 ("ASoC: dapm: Modify widget stream name according to prefix")
Vendor ID 0x10de007d is used by a yet-to-be-named GPU chip.
This chip also has the 2-ch audio swapping bug, so patch_nvhdmi is
appropriate here.
Signed-off-by: Aaron Plattner <aplattner@nvidia.com>
Fixes audio problems on newer asics
Signed-off-by: Maruthi Bayyavarapu <maruthi.bayyavarapu@amd.com>
When the controller is powered up but the HDMI codec is powered down
on Skylake, the power well is turned off. When the codec is then
powered up again, we need to poke the codec a little extra to make
sure it wakes up. Otherwise we'll get sad "no response from codec"
messages and broken audio.
This also changes azx_runtime_resume to actually call
snd_hdac_set_codec_wakeup for Skylake (before STATETS read).
(Otherwise it would only have been called for Haswell and Broadwell,
which both do not need it, so this probably was not the author's
intention.)
Reviewed-by: Libin Yang <libin.yang@intel.com>
Acer Aspire V5 with the ALC282 codec is given the wrong value for the
0x19 PIN by the laptop's BIOS. Overriding it with the correct value
adds support for the headset microphone which would not otherwise be
visible in the system.
The fix is based on commit 7819717b1134 with a similar quirk for Acer
Aspire with the ALC269 codec.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=96201
Signed-off-by: Mateusz Sylwestrzak <matisec7@gmail.com>
If 'of_ioremap' fails, then 'amd' should be freed, otherwise, there is a
memory leak.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"There are two small fixes for HD-audio and USB LINE6, and the rest are
a few new quirks and device ID addition that are good enough to get
into 4.2"
* tag 'sound-4.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda/realtek: Enable HP amp and mute LED on HP Folio 9480m [v3]
ALSA: line6: Fix -EBUSY error during active monitoring
ALSA: hda - Fix a wrong busy check in alt PCM open
ALSA: hda - add codec ID for Broxton display audio codec
ALSA: usb-audio: Add MIDI support for Steinberg MI2/MI4
With the nonatomic PCM ops, the system may spew lockdep warnings like:
[ INFO: possible recursive locking detected ]
4.2.0-rc1-jeejaval3 #12 Not tainted
aplay/4029 is trying to acquire lock:
(snd_pcm_link_rwsem){.+.+.+}, at: [<ffffffff816fd473>] snd_pcm_stream_lock+0x43/0x60
but task is already holding lock:
(snd_pcm_link_rwsem){.+.+.+}, at: [<ffffffff816fcf29>] snd_pcm_action_nonatomic+0x29/0x80
Possible unsafe locking scenario:
CPU0
lock(snd_pcm_link_rwsem);
Although this is false-positive as the rwsem is taken always as
read-only for these code paths, it's certainly annoying to see this at
any occasion. A simple fix is to use down_read_nested() in
snd_pcm_stream_lock() that can be called inside another lock.
Reported-by: Vinod Koul <vinod.koul@intel.com>
Reported-by: Jeeja Kp <jeeja.kp@intel.com>
Tested-by: Jeeja Kp <jeeja.kp@intel.com>
This fixes kernel panic on boot, if rt5645->codec is NULL when
rt5645_jack_detect_work is first called.
rt5645_jack_detect_work needs rt5645->codec to be initialized to setup
dapm pins. Also, reporting jack events is useless, as the jacks cannot
be set before the codec is ready.
Since we manually call the interrupt handler in
rt5645_set_jack_detect, the initial jack state will be reported
correctly, and dapm pins will be setup at that time.
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
This laptop needs GPIO4 pulled high to enable the headphone amplifier,
and has a mute LED on GPIO3. I modelled the patch on the existing
GPIO4 code which pulls the line low for the same purpose; this time,
the HP amp line is pulled high.
v2: Disable the headphone amplifier when no headphone is connected.
Don't disable power savings to preserve the LED state.
v3: Remove headset-specific hooks and code; this is just a headphone.
Signed-off-by: Keith Packard <keithp@keithp.com>
The usage_count variable was read before it was set to the correct
value, due to which the firmware load was failing. Because of this
IPC messages sent to the firmware were timing out causing a delay
of about 1 second while playing audio from the internal speakers.
With this patch the usage_count is read after the function call
pm_runtime_get_sync which will increment the usage_count variable
and the firmware load is successful and all the IPC messages are
processed correctly.
Signed-off-by: Shilpa Sreeramalu <shilpa.sreeramalu@intel.com>
Signed-off-by: Fang, Yang A <yang.a.fang@intel.com>
When a monitor stream is active, the next PCM stream access results in
EBUSY error because of the check in line6_stream_start(). Fix this by
just skipping the submission of pending URBs when the stream is
already running instead.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=101431
Cc: <stable@vger.kernel.org> # v4.0+
Mixer control for widgets can't be created if the info is NULL. So assign
the correct info for this.
Signed-off-by: Jeeja KP <jeeja.kp@intel.com>
Signed-off-by: Subhransu S. Prusty <subhransu.s.prusty@intel.com>
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Value returned by devm_ioremap_resource() was checked for non-NULL but
devm_ioremap_resource() returns IOMEM_ERR_PTR, not NULL. In case of
error this could lead to dereference of ERR_PTR.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
Reviewed-by: Jun Nie <jun.nie@linaro.org>
This replaces the platform_name in snd_soc_dai_link by device tree node.
Signed-off-by: Koro Chen <koro.chen@mediatek.com>
Make sure the to free the card DAPM context if snd_soc_instantiate_card()
fails, otherwise the memory allocated for the DAPM widgets is leaked.
The name field of the widget template is only used inside
snd_soc_dapm_new_control_unlocked() which allocates a copy for the actual
widget. This means we need to free the name allocated for the template in
dapm_kcontrol_data_alloc() and not the name of the actual widget in
dapm_kcontrol_free(). Otherwise we get a double free on the widget name and
a memory leak on the template name.
Fixes: 773da9b358bf ("ASoC: dapm: Append "Autodisable" to autodisable widget names")
The Intel boards directory was under CONFIG_SND_SOC_INTEL_SST so the
machines which don't need these were not allowed to be
selected/compiled without enabling this symbol The machine should be
allowed to selected by ASoC and then they should select rest of
symbols required
Reported-by: Michele Curti <michele.curti@gmail.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Currently, the alt PCM open callback returns -EBUSY when an
independent HP is turned off, supposing that it conflicts with the
main PCM. However, obviously, this check is wrong when the
independent HP itself isn't enabled but the alt PCM was explicitly
created via alc_dac_nid by a codec driver.
Reported-and-tested-by: Kailang Yang <kailang@realtek.com>
According to the datasheet 'pm', 'psr' and 'div2' should never be all 0.
Since commit 541b03ad6cfe ("ASoC: fsl_ssi: Fix the incorrect limitation of
the bit clock rate") this can happen, because for some bitclock rates
'pm' = 0 seems to be a valid choice but does not work due to hardware
restrictions. This results into a bad hardware behaviour (slow audio for
example). Feature tested on a i.MX25.
Signed-off-by: Juergen Borleis <jbe@pengutronix.de>
Acked-by: Nicolin Chen <nicoleotsuka@gmail.com>
We should use "HiFi Playback" and "HiFi Capture".it will fix below err
cht-bsw-max98090: ASoC: no sink widget found for AIF1 Playback
cht-bsw-max98090: ASoC: Failed to add route ssp2 Tx -> direct ->
AIF1 Playback
cht-bsw-max98090: ASoC: no source widget found for AIF1 Capture
cht-bsw-max98090: ASoC: Failed to add route AIF1 Capture -> direct ->
ssp2 Rx
The DAPM lock must be held when accessing the DAPM graph status through
sysfs or debugfs, otherwise concurrent changes to the graph can result in
undefined behaviour.
This patch adds codec ID (0x8086280a) and module alias for Broxton
display codec.
Signed-off-by: Libin Yang <libin.yang@intel.com>
TLV size calculation was incorrectly calculated. Fix this according to
include/sound/tlv.h
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Merge third patchbomb from Andrew Morton:
- the rest of MM
- scripts/gdb updates
- ipc/ updates
- lib/ updates
- MAINTAINERS updates
- various other misc things
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (67 commits)
genalloc: rename of_get_named_gen_pool() to of_gen_pool_get()
genalloc: rename dev_get_gen_pool() to gen_pool_get()
x86: opt into HAVE_COPY_THREAD_TLS, for both 32-bit and 64-bit
MAINTAINERS: add zpool
MAINTAINERS: BCACHE: Kent Overstreet has changed email address
MAINTAINERS: move Jens Osterkamp to CREDITS
MAINTAINERS: remove unused nbd.h pattern
MAINTAINERS: update brcm gpio filename pattern
MAINTAINERS: update brcm dts pattern
MAINTAINERS: update sound soc intel patterns
MAINTAINERS: remove website for paride
MAINTAINERS: update Emulex ocrdma email addresses
bcache: use kvfree() in various places
libcxgbi: use kvfree() in cxgbi_free_big_mem()
target: use kvfree() in session alloc and free
IB/ehca: use kvfree() in ipz_queue_{cd}tor()
drm/nouveau/gem: use kvfree() in u_free()
drm: use kvfree() in drm_free_large()
cxgb4: use kvfree() in t4_free_mem()
cxgb3: use kvfree() in cxgb_free_mem()
"Here are a bunch of small fixes, mostly for HD-audio quirks, in
addition to a few regression fixes and trivial cleanups"
* tag 'sound-fix-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: Fix uninintialized error return
ALSA: hda: Delete an unnecessary check before the function call "snd_info_free_entry"
ALSA: hda - Add a fixup for Dell E7450
ALSA: hda - Fix the dock headphone output on Fujitsu Lifebook E780
ALSA: hda - Add headset support to Acer Aspire V5
ALSA: hda - restore the MIC FIXUP for some Dell machines
ALSA: jack: Fix endless loop at unique index detection
ALSA: hda - set proper caps for newer AMD hda audio in KB/KV
ALSA: hda - Disable widget power-save for VIA codecs
ALSA: hda - Fix Dock Headphone on Thinkpad X250 seen as a Line Out
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Main excitement here is Peter Zijlstra's lockless rbtree optimization
to speed module address lookup. He found some abusers of the module
lock doing that too.
A little bit of parameter work here too; including Dan Streetman's
breaking up the big param mutex so writing a parameter can load
another module (yeah, really). Unfortunately that broke the usual
suspects, !CONFIG_MODULES and !CONFIG_SYSFS, so those fixes were
appended too"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (26 commits)
modules: only use mod->param_lock if CONFIG_MODULES
param: fix module param locks when !CONFIG_SYSFS.
rcu: merge fix for Convert ACCESS_ONCE() to READ_ONCE() and WRITE_ONCE()
module: add per-module param_lock
module: make perm const
params: suppress unused variable error, warn once just in case code changes.
modules: clarify CONFIG_MODULE_COMPRESS help, suggest 'N'.
kernel/module.c: avoid ifdefs for sig_enforce declaration
kernel/workqueue.c: remove ifdefs over wq_power_efficient
kernel/params.c: export param_ops_bool_enable_only
kernel/params.c: generalize bool_enable_only
kernel/module.c: use generic module param operaters for sig_enforce
kernel/params: constify struct kernel_param_ops uses
sysfs: tightened sysfs permission checks
module: Rework module_addr_{min,max}
module: Use __module_address() for module_address_lookup()
module: Make the mod_tree stuff conditional on PERF_EVENTS || TRACING
module: Optimize __module_address() using a latched RB-tree
rbtree: Implement generic latch_tree
seqlock: Introduce raw_read_seqcount_latch()
The Steinberg MI2 and MI4 interfaces are compatible with the USB class
audio spec, but the MIDI part of the devices is reported as a vendor
specific interface.
This patch adds entries to quirks-table.h to recognize the MIDI
endpoints. Audio functionality was already working and is unaffected by
this change.
Signed-off-by: Dominic Sacré <dominic.sacre@gmx.de>
Signed-off-by: Albert Huitsing <albert@huitsing.nl>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
