path: root/sound
2015-10-22ASoC: tas2552: fix dBscale-min declarationAndreas Dannenberg
commit e2600460bc3aa14ca1df86318a327cbbabedf9a8 upstream. The minimum volume level for the TAS2552 (control register value 0x00) is -7dB however the driver declares it as -0.07dB. Running amixer before the patch reports: dBscale-min=-0.07dB,step=1.00dB,mute=0 Running amixer with the patch applied reports: dBscale-min=-7.00dB,step=1.00dB,mute=0 Signed-off-by: Andreas Dannenberg <dannenberg@ti.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ASoC: sgtl5000: fix wrong register MIC_BIAS_VOLTAGE setup on probeGianluca Renzi
commit e256da84a04ea31c3c215997c847609af224e8f4 upstream. Signed-off-by: Gianluca Renzi <gianlucarenzi@eurekelettronica.it> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ASoC: db1200: Fix DAI link format for db1300 and db1550Lars-Peter Clausen
commit e74679b38c9417c1c524081121cdcdb36f82264d upstream. Commit b4508d0f95fa ("ASoC: db1200: Use static DAI format setup") switched the db1200 driver over to using static DAI format setup instead of a callback function. But the commit only added the dai_fmt field to one of the three DAI links in the driver. This breaks audio on db1300 and db1550. Add the two missing dai_fmt settings to fix the issue. Fixes: b4508d0f95fa ("ASoC: db1200: Use static DAI format setup") Reported-by: Manuel Lauss <manuel.lauss@gmail.com> Tested-by: Manuel Lauss <manuel.lauss@gmail.com> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ASoC: dwc: correct irq clear methodYitian Bu
commit 4873867e5f2bd90faad861dd94865099fc3140f3 upstream. from Designware I2S datasheet, tx/rx XRUN irq is cleared by reading register TOR/ROR, rather than by writing into them. Signed-off-by: Yitian Bu <yitian.bu@tangramtek.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ASoC: fix broken pxa SoC supportRobert Jarzmik
commit 3c8f7710c1c44fb650bc29b6ef78ed8b60cfaa28 upstream. The previous fix of pxa library support, which was introduced to fix the library dependency, broke the previous SoC behavior, where a machine code binding pxa2xx-ac97 with a coded relied on : - sound/soc/pxa/pxa2xx-ac97.c - sound/soc/codecs/XXX.c For example, the mioa701_wm9713.c machine code is currently broken. The "select ARM" statement wrongly selects the soc/arm/pxa2xx-ac97 for compilation, as per an unfortunate fate SND_PXA2XX_AC97 is both declared in sound/arm/Kconfig and sound/soc/pxa/Kconfig. Fix this by ensuring that SND_PXA2XX_SOC correctly triggers the correct pxa2xx-ac97 compilation. Fixes: 846172dfe33c ("ASoC: fix SND_PXA2XX_LIB Kconfig warning") Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ASoC: pxa: pxa2xx-ac97: fix dma requestor linesRobert Jarzmik
commit 8811191fdf7ed02ee07cb8469428158572d355a2 upstream. PCM receive and transmit DMA requestor lines were reverted, breaking the PCM playback interface for PXA platforms using the sound/soc/ variant instead of the sound/arm variant. The commit below shows the inversion in the requestor lines. Fixes: d65a14587a9b ("ASoC: pxa: use snd_dmaengine_dai_dma_data") Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ALSA: hda - Disable power_save_node for IDT 92HD73xx chipsTakashi Iwai
commit c7e1008048a97148d3aecae742f66fb2f944644c upstream. The recent widget power saving introduced some unavoidable click noises on old IDT 92HD73xx chips while it still seems working on the compatible new chips. In the bugzilla, we tried lots of tests and workarounds, but they didn't help much. So, let's disable the feature for these specific chips as the least (but safest) fix. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=104981 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ALSA: hda - Apply SPDIF pin ctl to MacBookPro 12,1John Flatness
commit e8ff581f7ac2bc3b8886094b7ca635dcc4d1b0e9 upstream. The MacBookPro 12,1 has the same setup as the 11 for controlling the status of the optical audio light. Simply apply the existing workaround to the subsystem ID for the 12,1. [sorted the fixup entry by tiwai] Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=105401 Signed-off-by: John Flatness <john@zerocrates.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ALSA: hda: Add dock support for ThinkPad T550Laura Abbott
commit d05ea7da0e8f6df3c62cfee75538f347cb3d89ef upstream. Much like all the other Lenovo laptops, add a quirk to make sound work with docking. Reported-and-tested-by: lacknerflo@gmail.com Signed-off-by: Laura Abbott <labbott@fedoraproject.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ALSA: synth: Fix conflicting OSS device registration on AWE32Takashi Iwai
commit 225db5762dc1a35b26850477ffa06e5cd0097243 upstream. When OSS emulation is loaded on ISA SB AWE32 chip, we get now kernel warnings like: WARNING: CPU: 0 PID: 2791 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x51/0x80() sysfs: cannot create duplicate filename '/devices/isa/sbawe.0/sound/card0/seq-oss-0-0' It's because both emux synth and opl3 drivers try to register their OSS device object with the same static index number 0. This hasn't been a big problem until the recent rewrite of device management code (that exposes sysfs at the same time), but it's been an obvious bug. This patch works around it just by using a different index number of emux synth object. There can be a more elegant way to fix, but it's enough for now, as this code won't be touched so often, in anyway. Reported-and-tested-by: Michael Shell <list1@michaelshell.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ALSA: hda - Disable power_save_node for ThinkpadsTakashi Iwai
commit 7f57d803ee03730d570dc59a9e3e4842b58dd5cc upstream. Lenovo Thinkpads with recent Realtek codecs seem suffering from click noises at power transition since the introduction of widget power saving in 4.1 kernel. Although this might be solved by some delays in appropriate points, as a quick workaround, just disable the power_save_node feature for now. The gain it gives is relatively small, and this makes the situation back to pre 4.1 time. This patch ended up with a bit more code changes than usual because the existing fixup for Thinkpads is highly chained. Instead of adding yet another chain, combine a few of them into a single fixup entry, as a gratis cleanup. Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=943982 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22ALSA: hda/tegra - async probe for avoiding module loading deadlockTakashi Iwai
commit 83510441bc08bee201c0ded9d81da6dfd008d69a upstream. The Tegra HD-audio controller driver causes deadlocks when loaded as a module since the driver invokes request_module() at binding with the codec driver. This patch works around it by deferring the probe in a work like Intel HD-audio controller driver does. Although hovering the codec probe stuff into udev would be a better solution, it may cause other regressions, so let's try this band-aid fix until the more proper solution gets landed. Reported-by: Thierry Reding <treding@nvidia.com> Tested-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-29ALSA: hda - Fix white noise on Dell M3800Niranjan Sivakumar
commit 467e1436ba85f78b8c4610c4549eb255a8211c42 upstream. The M3800 is very minor workstation variant of the XPS 15 which has already been patched for this issue. I figured it's probably more important for this version of the laptop to be patched than the regular XPS as Dell sells is pre-configured with Ubuntu to be used as a Linux workstation. I have tested the patch on my the hardware on Linux 4.2.0. Signed-off-by: Niranjan Sivakumar <ns253@cornell.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-29ALSA: hda - Add some FIXUP quirks for white noise on Dell laptop.Woodrow Shen
commit 1adecc6755e1e4193b5618ddb2e107f6d6e88f4b upstream. Dell laptop has a series model to use the same codec but different subsystem ID. At the same time they happens the white noise by login screen and headphone; for fixing them together, I only can add these IDs to FIXUP function ALC292_FIXUP_DISABLE_AAMIX, then try to solve such the similar issues. Codec: Realtek ALC3235 Vendor Id: 0x10ec0293 Subsystem Id: 0x102806dd Subsystem Id: 0x102806df Subsystem Id: 0x102806e0 BugLink: https://bugs.launchpad.net/bugs/1492132 Signed-off-by: Woodrow Shen <woodrow.shen@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-29ALSA: hda - Use ALC880_FIXUP_FUJITSU for FSC Amilo M1437Takashi Iwai
commit a161574e200ae63a5042120e0d8c36830e81bde3 upstream. It turned out that the machine has a bass speaker, so take a correct fixup entry. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102501 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-29ALSA: hda - Enable headphone jack detect on old Fujitsu laptopsTakashi Iwai
commit bb148bdeb0ab16fc0ae8009799471e4d7180073b upstream. According to the bug report, FSC Amilo laptops with ALC880 can detect the headphone jack but currently the driver disables it. It's partly intentionally, as non-working jack detect was reported in the past. Let's enable now. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102501 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-29ALSA: usb-audio: correct the value cache check.Yao-Wen Mao
commit 6aa6925cad06159dc6e25857991bbc4960821242 upstream. The check of cval->cached should be zero-based (including master channel). Signed-off-by: Yao-Wen Mao <yaowen@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-21ASoC: arizona: Poll for FLL clock OK rather than use interruptsCharles Keepax
commit 0e7659712836ca59b4735bc5cc94de38698a5e01 upstream. The extcon driver takes the DAPM mutex from within the interrupt thread in several places, which makes it possible to get into a situation where the interrupt thread is blocked waiting on the DAPM mutex whilst a DAPM sequence is running which is attempting to configure the FLL. In this case the FLL completion can't be completed as as the IRQ handler is ONE_SHOT, which cause the FLL lock to use the full time out (250mS) and report that the process timed out. It is not really practical to make the extcon driver not take the DAPM mutex from within the interrupt thread, at least not without extensive modification. So this patch fixes the issue by switching the wait for the FLL lock to polling. A few fast polls are done first as the FLL should lock quickly for a good quality reference clock, (indeed it hits on the first poll on my system) and it will poll every 20mS after that until it times out. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-21ASoC: arizona: Fix gain settings of FLL in free-run modeNikesh Oswal
commit 1cf5a330c05ae37a0a98ac7c9800a6f50d5579ec upstream. The wrong register was used to set the gain of ref loop, when changing the FLL output on an active FLL. This patch corrects the offset of the gain register. Signed-off-by: Nikesh Oswal <Nikesh.Oswal@wolfsonmicro.com> Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-21ASoC: adav80x: Remove .read_flag_mask setting from adav80x_regmap_configAxel Lin
commit 9d8352864907f0ad76124c5b28f65b5a382d7d7c upstream. Don't set .read_flag_mask for adav803, it's for adav801 only. Fixes: 0c2d69645628 ("ASoC: adav80x: Split SPI and I2C code into different modules") Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-21ASoC: samsung: Remove redundant arndale_audio_removeVaishali Thakkar
commit 14a500fe1396934c6b3ed8f009459a4723da7862 upstream. There is no use of snd_soc_unregister_card in remove function as devm_snd_soc_register_card in probe function automatically handles it. So, remove use of snd_soc_unregister_card and with this change remove arndale_audio_remove as it is now redundant. Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-21ASoC: rt5645: Add struct dmi_system_id "Google Celes" for chrome platformOder Chiou
commit c1713485f9fc06e1f4de9800b43f6486f2527379 upstream. Signed-off-by: Oder Chiou <oder_chiou@realtek.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-21ASoC: rt5640: fix line out no sound issueJohn Lin
commit 9b850ca4f1c5acd7fcbbd4b38a2d27132801a8d5 upstream. The power for line out was not turned on when line out is enabled. So we add "LOUT amp" widget to turn on the power for line out. Signed-off-by: John Lin <john.lin@realtek.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-25ALSA: hda - Fix path power activationTakashi Iwai
The widget power-saving code tries to turn up/down the power of each widget in the I/O paths that are modified at each jack plug/unplug. The recent report revealed that the power activation leaves some widgets unpowered after plugging. This is because snd_hda_activate_path() turns on path->active flag at the end of the function while the path power management is done before that. Then it's regarded as if nothing is active, and the driver turns off the power. The fix is simply to set the flag at the beginning of the function, before trying to power up. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102521 Cc: <stable@vger.kernel.org> [v4.1+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-25ALSA: hda - Check all inputs for is_active_nid_for_any()Takashi Iwai
The is_active_nid_for_any() function in the generic parser is supposed to check all connections from/to the given widget, but the current code checks only the first input connection (index = 0). This patch corrects the code to check all inputs by passing -1 to index argument. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102521 Cc: <stable@vger.kernel.org> [v4.1+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-24ALSA: hda: fix possible NULL dereferenceMarkus Osterhoff
After a for-loop was replaced by list_for_each_entry, see Commit bbbc7e8502c9 ("ALSA: hda - Allocate hda_pcm objects dynamically"), Commit 751e2216899c ("ALSA: hda: fix possible null dereference"), a possible NULL pointer dereference has been introduced; this patch adds the NULL check on pcm->pcm, while leaving a potentially superfluous check on pcm itself untouched. Signed-off-by: Markus Osterhoff <linux-kernel@k-raum.org> Cc: <stable@vger.kernel.org> #v4.1+ Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-21ALSA: hda - Shutdown CX20722 on reboot/free to avoid spurious noisesDavid Henningsson
On shutdown/reboot of CX20722, first shut down all EAPDs, then shut down the afg node to D3. Failure to do so can lead to spurious noises from the internal speaker directly after reboot (and before the codec is reinitialized again, i e in BIOS setup or GRUB menus). BugLink: https://bugs.launchpad.net/bugs/1487345 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-21ALSA: usb: Add native DSD support for Gustard DAC-X20UJurgen Kramer
This patch adds native DSD support for the Gustard DAC-X20U. Signed-off-by: Jurgen Kramer <gtmkramer@xs4all.nl> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-19Merge tag 'asoc-v4.2-disable-topology' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Disable topology support for v4.2 The topology code merged in the v4.2 merge window introduced a new ABI which was believed to be suitable for use but subsequently additional work by the developers of this feature have revealed some problems that need to be addressed. In order to allow this to be done without having to support the initial ABI add Kconfig to disable the build and also add some #error statements to the UAPI header so users can't use them.
2015-08-19ALSA: hda - Add dock support for Thinkpad W541 (17aa:2211)Rick Sherman
Tested with W541 and Ultra Dock 170w Signed-off-by: Rick Sherman <rick@shermdog.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-19ALSA: usb-audio: Fix runtime PM unbalanceTakashi Iwai
The fix for deadlock in PM in commit [1ee23fe07ee8: ALSA: usb-audio: Fix deadlocks at resuming] introduced a new check of in_pm flag. However, the brainless patch author evaluated it in a wrong way (logical AND instead of logical OR), thus usb_autopm_get_interface() is wrongly called at probing, leading to unbalance of runtime PM refcount. This patch fixes it by correcting the logic. Reported-by: Hans Yang <hansy@nvidia.com> Fixes: 1ee23fe07ee8 ('ALSA: usb-audio: Fix deadlocks at resuming') Cc: <stable@vger.kernel.org> [v3.15+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-17ASoC: topology: Add Kconfig option for topologyMark Brown
Allow the topology code to be compiled out so that users who don't need topology don't need to havve the code compiled in, saving them some memory. Some more configuration could be added to remove some of the hooks into the core data structures but that is probably best done with some refactoring to use functions to do the updates of the data structures rather than ifdefing in the code as we'd need to do at the minute. Suggested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-13ALSA: hda - Fix the white noise on Dell laptopWoodrow Shen
Dell laptop causes the white noise by login screen and headphone, and the fixup function ALC292_FIXUP_DISABLE_AAMIX can eliminate this noise. Codec: Realtek ALC3235 Vendor Id: 0x10ec0293 Subsystem Id: 0x102806db Cc: <stable@vger.kernel.org> BugLink: https://bugs.launchpad.net/bugs/1484334 Signed-off-by: Woodrow Shen <woodrow.shen@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-07Merge tag 'asoc-fix-v4.2-rc5' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v4.2 There are a couple of small driver specific fixes here but the overwhelming bulk of these changes are fixes to the topology ABI that has been newly introduced in v4.2. Once this makes it into a release we will have to firm this up but for now getting enhancements in before they've made it into a release is the most expedient thing.
2015-08-06Merge remote-tracking branches 'asoc/fix/cs4265', 'asoc/fix/intel' and ↵Mark Brown
'asoc/fix/topology' into asoc-linus
2015-08-06Merge remote-tracking branch 'asoc/fix/rt5645' into asoc-linusMark Brown
2015-08-06ASoC: topology: Update TLV support so we can support more TLV typesMengdong Lin
Currently the TLV topology structure is targeted at only supporting the DB scale data. This patch extends support for the other TLV types so they can be easily added at a later stage. TLV structure is moved to common topology control header since it's a common field for controls and can be processed in a general way. Users must set a proper access flag for a control since it's used to decide if the TLV field is valid and if a TLV callback is needed. Removed the following fields from topology TLV struct: - size/count: type can decide the size. - numid: not needed to initialize TLV for kcontrol. - data: replaced by the type specific struct. Added TLV structure to generic control header and removed TLV structure from mixer control. Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-06Merge tag 'asoc-fix-v4.2-rc3' into asoc-fix-topologyMark Brown
ASoC: Fixes for v4.2 A lot of small fixes here, a few to the core: - Fix for binding DAPM stream widgets on devices with prefixes assigned to them - Minor fixes for the newly added topology interfaces - Locking and memory leak fixes for DAPM - Driver specific fixes
2015-08-06ASoC: topology: Add subsequence in topologySubhransu S. Prusty
Some widgets may need sorting within, So add this support in topology. Signed-off-by: Subhransu S. Prusty <subhransu.s.prusty@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-05ALSA: hda - one Dell machine needs the headphone white noise fixupHui Wang
The fixup ALC292_FIXUP_DISABLE_AAMIX can fix the white noise of the headphone on this Dell machine. Cc: <stable@vger.kernel.org> Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-05ALSA: fireworks/firewire-lib: add support for recent firmware quirkTakashi Sakamoto
Fireworks uses TSB43CB43(IceLynx-Micro) as its IEC 61883-1/6 interface. This chip includes ARM7 core, and loads and runs program. The firmware is stored in on-board memory and loaded every powering-on from it. Echo Audio ships several versions of firmwares for each model. These firmwares have each quirk and the quirk changes a sequence of packets. As long as I investigated, AudioFire2/AudioFire4/AudioFirePre8 have a quirk to transfer a first packet with 0x02 in its dbc field. This causes ALSA Fireworks driver to detect discontinuity. In this case, firmware version 5.7.0, 5.7.3 and 5.8.0 are used. Payload CIP CIP quadlets header1 header2 02 00050002 90ffffff <- 42 0005000a 90013000 42 00050012 90014400 42 0005001a 90015800 02 0005001a 90ffffff 42 00050022 90019000 42 0005002a 9001a400 42 00050032 9001b800 02 00050032 90ffffff 42 0005003a 9001d000 42 00050042 9001e400 42 0005004a 9001f800 02 0005004a 90ffffff (AudioFire2 with firmware version 5.7.) $ dmesg snd-fireworks fw1.0: Detect discontinuity of CIP: 00 02 These models, AudioFire8 (since Jul 2009 ) and Gibson Robot Interface Pack series uses the same ARM binary as their firmware. Thus, this quirk may be observed among them. This commit adds a new member for AMDTP structure. This member represents the value of dbc field in a first AMDTP packet. Drivers can set it with a preferred value according to model's quirk. Tested-by: Johannes Oertei <johannes.oertel@uni-due.de> Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-05Revert "ALSA: fireworks: add support for AudioFire2 quirk"Takashi Sakamoto
This reverts commit 9c6893e0be38b6ca9a56a854226e51dee0a16a5a. The fix is superseded by the next commit as a better implementation for supporting AudioFire2/AudioFire4/AudioFirePre8 quirks. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-04ASoC: topology: fix typo in soc_tplg_kcontrol_bind_io()Mengdong Lin
2015-08-04ALSA: HDA: Dont check return for snd_hdac_chip_readlJeeja KP
The snd_hdac_chip_readl return can never be less than zeros, so no point in checking for the return value This fixes following static checker warnings in snd_hdac_ext_bus_parse_capabilities sound/hda/ext/hdac_ext_controller.c:47 snd_hdac_ext_bus_parse_capabilities() warn: unsigned 'offset' is never less than zero. sound/hda/ext/hdac_ext_controller.c:54 snd_hdac_ext_bus_parse_capabilities() warn: unsigned 'cur_cap' is never less than zero. Signed-off-by: Jeeja KP <jeeja.kp@intel.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-04ALSA: HDA: Fix stream assignment for host in decoupled modeJeeja KP
This fixes issue in assigning host stream in case of decoupled mode. The check to verify if the stream is already in use was wrong so fix that Signed-off-by: Jeeja KP <jeeja.kp@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-03ASoC: rt5645: Fix lost pin setting for DMIC1Bard Liao
I2S2_DAC pin can be used for I2S or GPIO. We should set it as GPIO if we use GPIO5 as DMIC1 data pin. Signed-off-by: Bard Liao <bardliao@realtek.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-03ALSA: oxygen: Fix logical-not-parentheses warningTomer Barletz
This fixes the following warning, that is seen with gcc 5.1: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]. Signed-off-by: Tomer Barletz <barletz@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-30ALSA: hda - Fix MacBook Pro 5,2 quirkTakashi Iwai
MacBook Pro 5,2 with ALC889 codec had already a fixup entry, but this seems not working correctly, a fix for pin NID 0x15 is needed in addition. It's equivalent with the fixup for MacBook Air 1,1, so use this instead. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102131 Reported-and-tested-by: Jeffery Miller <jefferym@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-29ALSA: hda - Fix race between PM ops and HDA init/probeU. Artie Eoff
PM ops could be triggered before HDA is done initializing and cause PM to set HDA controller to D3Hot. This can result in "CORB reset timeout#2, CORBRP = 65535" and "no codecs initialized". Additionally, PM ops can be triggered before azx_probe_continue finishes (async probe). This can result in a NULL deref kernel crash. To fix this, avoid PM ops if !chip->running. Signed-off-by: U. Artie Eoff <ullysses.a.eoff@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-29ASoC: Intel: sst_byt: fix initialize 'NULL device *' issueJie Yang
Add initialization for sst_byt.dev at init stage, which fix the 'NULL device *' warning issues. Signed-off-by: Jie Yang <yang.jie@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
