commit ebf79091bf85d9b2270ab29191de9cd3aaf888c5 upstream.
Select DW_DMAC_CORE like the rest of glue drivers do, e.g.
drivers/dma/dw/Kconfig.
While here group selectors under SND_SOC_INTEL_HASWELL and
SND_SOC_INTEL_BAYTRAIL.
Make platforms, which are using a common SST firmware driver, to be
dependent on DMADEVICES.
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Cc: Ben Hutchings <ben@decadent.org.uk>
[ Upstream commit 2ad6f30de7087515a0bc2a718fca6681a57739a0 ]
Some SoCs have a reset line that must be asserted/deasserted.
This patch adds a quirk to handle the new compatible
"allwinner,sun6i-a31-i2s" which will deassert the reset
line on probe function and assert it on remove's one.
This new compatible is useful in case of A33 codec driver, for example.
Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[ Upstream commit a50477e55fff69e1028f25624ee9fc9182d59b1f ]
The existing code assumes a 19.2 MHz MCLK as the default
hardware configuration. This is valid for CherryTrail but
not for Baytrail.
Add explicit MCLK configuration to set the 19.2 clock on/off
depending on DAPM events.
This is a prerequisite step to enable devices with Baytrail
and RT5645 such as Asus X205TA
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
[ Upstream commit 42648c2270ca0c96935dfc5d0f5c4f8d2406cf75 ]
Fix classic issue of having multiple codecs listed in DSDT
but a single one actually enabled. The previous code did
not handle such errors and could also lead to uninitalized
configurations
[ Upstream commit fd0138dc5d17c636477b371d99265c406437c583 ]
the BIOS reports this codec as RT5640 but it's a rt5670. Use the
quirk mechanism to use the cht_bsw_rt5672 machine driver
[ Upstream commit 93ffeaa8ee3f10a0628ad135b552a2497e0bef2c ]
the BIOS incorrectly reports this codec as 5640 but it is
really a rt5670
[ Upstream commit d25280060835e1b2b84c242905da8334ab15c5b4 ]
rt5670 driver supports also RT5672 codec, but its ACPI ID is missing.
This was found on Dell Wyse 3040 box.
[ Upstream commit 571800487837263e914ef68681e4ad6a57d49c7f ]
There are literally dozens of Insyde devices with a different
name but with the same audio routing. Use a generic quirk to
match on vendor name only to avoid recurring edits of the
same thing.
Signed-off-by: youling257 <youling257@gmail.com>
[ Upstream commit 7f38ca047b0cb54df7f6d9e4110e292e45dba6ad ]
This patch adds native DSD support for the following devices.
- TEAC NT-503
- TEAC UD-503
- TEAC UD-501
(1) Add quirks for native DSD support for TEAC devices.
(2) A specific vendor command is needed to switch between PCM/DOP and
DSD mode, same as Denon/Marantz devices.
Signed-off-by: Nobutaka Okabe <nob77413@gmail.com>
[ Upstream commit 17f08b0d9aafccdb10038ab6dbd9ddb6433c13e2 ]
The Axe-Fx II implicit feedback end point and the data sync endpoint
are in different interface descriptors. Add quirk to ensure a sync
endpoint is properly configured.
Signed-off-by: Alberto Aguirre <albaguirre@gmail.com>
[ Upstream commit bf46241bee7bc3ec28703796f4fbd56085055fca ]
Most Baytrail-CR devices use analog differential microphones,
modify capture default to avoid DMI quirks. Keep digital mics
for all other configurations.
pointer
commit d1a6fe41d3c4ff0d26f0b186d774493555ca5282 upstream.
In 'skl_tplg_set_module_init_data()', a pointer to 'params' member of
'struct skl_algo_data' is calculated, then casted to (u32 *) and assigned
to a member of configuration data. The configuration data is passed to the
other functions and used to process intel IPC. In this processing, the
value of member is used to get message data, however this can bring invalid
memory access in 'skl_set_module_params()' as a result of calculation of
a pointer for actual message data.
(sound/soc/intel/skylake/skl-topology.c)
skl_tplg_init_pipe_modules()
->skl_tplg_set_module_init_data() (has this bug)
->skl_tplg_set_module_params()
(sound/soc/intel/skylake/skl-messages.c)
->skl_set_module_params()
((char *)param) + data_offset
This commit fixes the bug.
Fixes: abb740033b56 ("ASoC: Intel: Skylake: Add support to configure module params")
Signed-off-by: Takashi Sakamoto <takashi.sakamoto@miraclelinux.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
commit cd3ac9affc43b44f49d7af70d275f0bd426ba643 upstream.
Fix the audio clock rate according to the datasheet.
Reported-by: Dushara Jayasinghe <dushara@successful.com.au>
Signed-off-by: Songjun Wu <songjun.wu@microchip.com>
Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
commit 2f726aec19a9d2c63bec9a8a53a3910ffdcd09f8 upstream.
On this Dell AIO machine, the lineout jack does not work.
We found the pin 0x1a is assigned to lineout on this machine, and in
the past, we applied ALC298_FIXUP_DELL1_MIC_NO_PRESENCE to fix the
heaset-set mic problem for this machine, this fixup will redefine
the pin 0x1a to headphone-mic, as a result the lineout doesn't
work anymore.
After consulting with Dell, they told us this machine doesn't support
microphone via headset jack, so we add a new fixup which only defines
the pin 0x18 as the headset-mic.
[rearranged the fixup insertion position by tiwai in order to make the
merge with other branches easier -- tiwai]
Fixes: 59ec4b57bcae ("ALSA: hda - Fix headset mic detection problem for two dell machines")
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit 2d7d54002e396c180db0c800c1046f0a3c471597 upstream.
When a new event is queued while processing to resize the FIFO in
snd_seq_fifo_clear(), it may lead to a use-after-free, as the old pool
that is being queued gets removed. For avoiding this race, we need to
close the pool to be deleted and sync its usage before actually
deleting it.
The issue was spotted by syzkaller.
commit 3f307834e695f59dac4337a40316bdecfb9d0508 upstream.
A new Dell laptop needs to apply ALC269_FIXUP_DELL1_MIC_NO_PRESENCE to
fix the headset problem, and the pin definiton of this machine is not
in the pin quirk table yet, now adding it to the table.
commit f363a06642f28caaa78cb6446bbad90c73fe183c upstream.
In the commit [15c75b09f8d1: ALSA: ctxfi: Fallback DMA mask to 32bit],
I forgot to put "!" at dam_set_mask() call check in cthw20k1.c (while
cthw20k2.c is OK). This patch fixes that obvious bug.
(As a side note: although the original commit was completely wrong,
it's still working for most of machines, as it sets to 32bit DMA mask
in the end. So the bug severity is low.)
Fixes: 15c75b09f8d1 ("ALSA: ctxfi: Fallback DMA mask to 32bit")
commit c520ff3d03f0b5db7146d9beed6373ad5d2a5e0e upstream.
When snd_seq_pool_done() is called, it marks the closing flag to
refuse the further cell insertions. But snd_seq_pool_done() itself
doesn't clear the cells but just waits until all cells are cleared by
the caller side. That is, it's racy, and this leads to the endless
stall as syzkaller spotted.
This patch addresses the racy by splitting the setup of pool->closing
flag out of snd_seq_pool_done(), and calling it properly before
snd_seq_pool_done().
BugLink: http://lkml.kernel.org/r/CACT4Y+aqqy8bZA1fFieifNxR2fAfFQQABcBHj801+u5ePV0URw@mail.gmail.com
Reported-and-tested-by: Dmitry Vyukov <dvyukov@google.com>
commit 29693efcea0f38cf40d0055d2401490a4f9bf8be upstream.
On this machine, the micmute button is connected to Line2 of the
codec and the micmute led is connected to GPIO2 of the codec.
After applying this quirk, both hotkey and led work well.
commit 493de342748cc6f52938096f5480cf291da58a0b upstream.
Dell Inspiron 17 7000 Gaming laptop needs a similar quirk like
Inspiron 7599 to support its subwoofer speaker.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=194191
commit f3ac9f737603da80c2da3e84b89e74429836bb6d upstream.
The sequencer FIFO management has a bug that may lead to a corruption
(shortage) of the cell linked list. When a sequencer client faces an
error at the event delivery, it tries to put back the dequeued cell.
When the first queue was put back, this forgot the tail pointer
tracking, and the link will be screwed up.
Although there is no memory corruption, the sequencer client may stall
forever at exit while flushing the pending FIFO cells in
snd_seq_pool_done(), as spotted by syzkaller.
This patch addresses the missing tail pointer tracking at
snd_seq_fifo_cell_putback(). Also the patch makes sure to clear the
cell->enxt pointer at snd_seq_fifo_event_in() for avoiding a similar
mess-up of the FIFO linked list.
commit 15c75b09f8d190f89ab4db463b87d411ca349dfe upstream.
Currently ctxfi driver tries to set only the 64bit DMA mask on 64bit
architectures, and bails out if it fails. This causes a problem on
some platforms since the 64bit DMA isn't always guaranteed. We should
fall back to the default 32bit DMA when 64bit DMA fails.
Fixes: 6d74b86d3c0f ("ALSA: ctxfi - Allow 64bit DMA")
commit 71321eb3f2d0df4e6c327e0b936eec4458a12054 upstream.
When a user sets a too small ticks with a fine-grained timer like
hrtimer, the kernel tries to fire up the timer irq too frequently.
This may lead to the condensed locks, eventually the kernel spinlock
lockup with warnings.
For avoiding such a situation, we define a lower limit of the
resolution, namely 1ms. When the user passes a too small tick value
that results in less than that, the kernel returns -EINVAL now.
commit e7480b34ad1ab84a63540b2c884cb92c0764ab74 upstream.
Like for Sunrise Point, the total stream number of Lewisburg's
input and output stream exceeds 15 (GCAP is 0x9701), which will
cause some streams do not work because of the overflow on
SDxCTL.STRM field if using the legacy stream tag allocation method.
Fixes: 5cf92c8b3dc5 ("ALSA: hda - Add Intel Lewisburg device IDs Audio")
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit 9f1bc2c4c58fcb2d86e0e26437dc8f3a18ac3276 upstream.
The issue is the same as "dd9aa335c880 ALSA: hda/realtek - Can't adjust
speaker's volume on a Dell AIO", the output requires to connect to a node
with Amp-out capability.
Applying the same fixup "ALC298_FIXUP_SPK_VOLUME" can fix the issue.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit f3d83317a69e7d658e7c83e24f8b31ac533c39e3 upstream.
This reverts commit f6a0dd107ad0c8b59d1c9735eea4b8cb9f460949.
The commit caused a regression on LINE6 Transport that has no control
caps. Although reverting the commit may result back in a spurious
error message for some device again, it's the simplest regression fix,
hence it's taken as is at first. The further code fix will follow
later.
Fixes: f6a0dd107ad0 ("ALSA: line6: Only determine control port properties if needed")
Reported-by: Igor Zinovev <zinigor@gmail.com>
commit 37a7ea4a9b81f6a864c10a7cb0b96458df5310a3 upstream.
snd_seq_pool_done() syncs with closing of all opened threads, but it
aborts the wait loop with a timeout, and proceeds to the release
resource even if not all threads have been closed. The timeout was 5
seconds, and if you run a crazy stuff, it can exceed easily, and may
result in the access of the invalid memory address -- this is what
syzkaller detected in a bug report.
As a fix, let the code graduate from naiveness, simply remove the loop
timeout.
BugLink: http://lkml.kernel.org/r/CACT4Y+YdhDV2H5LLzDTJDVF-qiYHUHhtRaW4rbb4gUhTCQB81w@mail.gmail.com
commit 4842e98f26dd80be3623c4714a244ba52ea096a8 upstream.
When a sequencer queue is created in snd_seq_queue_alloc(),it adds the
new queue element to the public list before referencing it. Thus the
queue might be deleted before the call of snd_seq_queue_use(), and it
results in the use-after-free error, as spotted by syzkaller.
The fix is to reference the queue object at the right time.
commit af677166cf63c179dc2485053166e02c4aea01eb upstream.
Without this change, the HDMI/DP codec will be recognised as a
generic codec, and there is no sound when playing through this codec.
As suggested by NVidia side, after adding the new ID in the driver,
the sound playing works well.
commit 2e40795c3bf344cfb5220d94566205796e3ef19a upstream.
Plantronics BT600 does not support reading the sample rate which leads
to many lines of "cannot get freq at ep 0x1" and "cannot get freq at
ep 0x82". This patch adds the USB ID of the BT600 to quirks.c and
avoids those error messages.
Signed-off-by: Dennis Kadioglu <denk@post.com>
commit 6a2a2f45560a9cb7bc49820883b042e44f83726c upstream.
This module has a bug not to return error code in a case that data
structure for transmitted packets fails to be initialized.
Fixes: 35efa5c489de ("ALSA: firewire-tascam: add streaming functionality")
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
commit 5faf071d08ddd1c1be66deaa93a09ccf43f5b538 upstream.
Unfortunately, I seem to have missed a case where an IRQ safe spinlock was
required, in samsung_i2s_dai_remove, when I fixed up the other calls in
this patch:
316fa9e09ad7 ("ASoC: samsung: Use IRQ safe spin lock calls")
This causes a lockdep warning when unbinding and rebinding the audio card:
[ 104.357664] CPU0 CPU1
[ 104.362174] ---- ----
[ 104.366692] lock(&(&pri_dai->spinlock)->rlock);
[ 104.371372] local_irq_disable();
[ 104.377283] lock(&(&substream->self_group.lock)->rlock);
[ 104.385259] lock(&(&pri_dai->spinlock)->rlock);
[ 104.392469] <Interrupt>
[ 104.395072] lock(&(&substream->self_group.lock)->rlock);
[ 104.400710]
[ 104.400710] *** DEADLOCK ***
Fixes: ce8bcdbb61d9 ("ASoC: samsung: i2s: Protect more registers with a spinlock")
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
commit c8eabf821cac120afb78ca251b07cbf520406a7e upstream.
"*val" is a u64. It definitely looks like we intend to use the high 32
bits as well.
Fixes: 700a9a63f9c1 ("ASoC: Intel: Skylake: Add module instance id generation APIs")
Tested-by: Kranthi G <gudishax.kranthikumar@intel.com>
commit a823a17981a73faa115bc0f7eda0190763075e2c upstream.
cht_bsw_rt5645 driver allocates the own codec_id string but doesn't
release it. For simplicity, put the string in cht_mc_private; then
the string is allocated in a shot and released altogether.
Fixes: c8560b7c917f ("ASoC: cht_bsw_rt5645: Fix writing to string literal")
commit 3b89e4b77ef9c2f985964fab17032db98f074ed0 upstream.
A bugfix accidentally removed the implicit initialization of the
dma channel number, causing undefined behavior when
v->alloc_dma_channel is NULL:
sound/soc/qcom/lpass-platform.c: In function ‘lpass_platform_pcmops_open’:
sound/soc/qcom/lpass-platform.c:83:29: error: ‘dma_ch’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
This adds back an explicit initialization to zero, restoring the
previous behavior for that case.
Fixes: 022d00ee0b55 ("ASoC: lpass-platform: Fix broken pcm data usage")
Acked-by: Kenneth Westfield <kwestfie@codeaurora.org>
commit 4763601a56f155ddf94ef35fc2c41504a2de15f5 upstream.
The function returns -EINVAL even if it builds the stream properly.
The bogus error code sneaked in during the code refactoring, but it
wasn't noticed until now since the returned error code itself is
ignored in anyway. Kill it here, but there is no behavior change by
this patch, obviously.
Fixes: e5779998bf8b ('ALSA: usb-audio: refactor code')
commit 1d0f953086f090a022f2c0e1448300c15372db46 upstream.
Commit 16200948d83 ("ALSA: usb-audio: Fix race at stopping the stream") was
incomplete causing another more severe kernel panic, so it got reverted.
This fixes both the original problem and its fallout kernel race/crash.
The original fix is to move the endpoint member NULL clearing logic inside
wait_clear_urbs() so the irq triggering the urb completion doesn't call
retire_capture/playback_urb() after the NULL clearing and generate a panic.
However this creates a new race between snd_usb_endpoint_start()'s call
to wait_clear_urbs() and the irq urb completion handler which again calls
retire_capture/playback_urb() leading to a new NULL dereference.
We keep the EP deactivation code in snd_usb_endpoint_start() because
removing it will break the EP reference counting (see [1] [2] for info),
however we don't need the "can_sleep" mechanism anymore because a new
function was introduced (snd_usb_endpoint_sync_pending_stop()) which
synchronizes pending stops and gets called inside the pcm prepare callback.
It also makes sense to remove can_sleep because it was also removed from
deactivate_urbs() signature in [3] so we benefit from more simplification.
[1] commit 015618b90 ("ALSA: snd-usb: Fix URB cancellation at stream start")
[2] commit e9ba389c5 ("ALSA: usb-audio: Fix scheduling-while-atomic bug in PCM capture stream")
[3] commit ccc1696d5 ("ALSA: usb-audio: simplify endpoint deactivation code")
Fixes: f8114f8583bb ("Revert "ALSA: usb-audio: Fix race at stopping the stream"")
Signed-off-by: Ioan-Adrian Ratiu <adi@adirat.com>
commit c7efff9284dfde95a11aaa811c9d8ec8167f0f6e upstream.
Although the old quirk table showed ASUS X71SL with ALC663 codec being
compatible with asus-mode3 fixup, the bugzilla reporter explained that
asus-model8 fits better for the dual headphone controls. So be it.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=191781
commit 85bcf96caba8b4a7c0805555638629ba3c67ea0c upstream.
ASUS ROG Ranger VIII with ALC1150 codec requires the extra GPIO pin to
up for the front panel. Just use the existing fixup for setting up
the GPIO pins.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=189411
commit 2fc995a87f2efcd803438f07bfecd35cc3d90d32 upstream.
When ASoC Intel SST Medfield driver is probed but without codec / card
assigned, it causes an Oops and freezes the kernel at suspend/resume,
PM: Suspending system (freeze)
Suspending console(s) (use no_console_suspend to debug)
BUG: unable to handle kernel NULL pointer dereference at 0000000000000018
IP: [<ffffffffc09d9409>] sst_soc_prepare+0x19/0xa0 [snd_soc_sst_mfld_platform]
Oops: 0000 [#1] PREEMPT SMP
CPU: 0 PID: 1552 Comm: systemd-sleep Tainted: G W 4.9.0-rc6-1.g5f5c2ad-default #1
Call Trace:
[<ffffffffb45318f9>] dpm_prepare+0x209/0x460
[<ffffffffb4531b61>] dpm_suspend_start+0x11/0x60
[<ffffffffb40d3cc2>] suspend_devices_and_enter+0xb2/0x710
[<ffffffffb40d462e>] pm_suspend+0x30e/0x390
[<ffffffffb40d2eba>] state_store+0x8a/0x90
[<ffffffffb43c670f>] kobj_attr_store+0xf/0x20
[<ffffffffb42b0d97>] sysfs_kf_write+0x37/0x40
[<ffffffffb42b02bc>] kernfs_fop_write+0x11c/0x1b0
[<ffffffffb422be68>] __vfs_write+0x28/0x140
[<ffffffffb43728a8>] ? apparmor_file_permission+0x18/0x20
[<ffffffffb433b2ab>] ? security_file_permission+0x3b/0xc0
[<ffffffffb422d095>] vfs_write+0xb5/0x1a0
[<ffffffffb422e3d6>] SyS_write+0x46/0xa0
[<ffffffffb4719fbb>] entry_SYSCALL_64_fastpath+0x1e/0xad
Add proper NULL checks in the PM code of mdfld driver.
commit 5e0ad0d8747f3e4803a9c3d96d64dd7332506d3c upstream.
Commit [64047d7f4912 ALSA: hda - ignore the assoc and seq when comparing
pin configurations] intented to ignore both seq and assoc at pin
comparing, but it only ignored seq. So that commit may still fail to
match pins on some machines.
Change the bitmask to also ignore assoc.
v2: Use macro to do bit masking.
Thanks to Hui Wang for the analysis.
Fixes: 64047d7f4912 ("ALSA: hda - ignore the assoc and seq when comparing...")
commit f73cd43ac3b41c0f09a126387f302bbc0d9c726d upstream.
HP Z1 Gen3 AiO with Conexant codec doesn't give an unsolicited event
to the headset mic pin upon the jack plugging, it reports only to the
headphone pin. It results in the missing mic switching. Let's fix up
by simply gating the jack event.
commit 989dbe4a30728c047316ab87e5fa8b609951ce7c upstream.
This group of new pins is not in the pin quirk table yet, adding
them to the pin quirk table to fix the headset-mic problem.
commit 64047d7f4912de1769d1bf0d34c6322494b13779 upstream.
More and more pin configurations have been adding to the pin quirk
table, lots of them are only different from assoc and seq, but they
all apply to the same QUIRK_FIXUP, if we don't compare assoc and seq
when matching pin configurations, it will greatly reduce the pin
quirk table size.
We have tested this change on a couple of Dell laptops, it worked
well.
commit b5337cfe067e96b8a98699da90c7dcd2bec21133 upstream.
I'm using an Alienware 15 R2 and had to use the alienware quirks to
get my headphone output working.
I fixed it by adding, SND_PCI_QUIRK(0x1028, 0x0708, "Alienware 15 R2
2016", QUIRK_ALIENWARE) to the patch.
Signed-off-by: Sven Hahne <hahne@zeitkunst.eu>
commit 995c6a7fd9b9212abdf01160f6ce3193176be503 upstream.
Sampling rate changes after first set one are not reflected to the
hardware, while driver and ALSA think the rate has been changed.
Fix the problem by properly stopping the interface at the beginning of
prepare call, allowing new rate to be set to the hardware. This keeps
the hardware in sync with the driver.
Signed-off-by: Jussi Laako <jussi@sonarnerd.net>
commit 82ffb6fc637150b279f49e174166d2aa3853eaf4 upstream.
The Logitech QuickCam Communicate Deluxe/S7500 microphone fails with the
following warning.
[ 6.778995] usb 2-1.2.2.2: Warning! Unlikely big volume range (=3072),
cval->res is probably wrong.
[ 6.778996] usb 2-1.2.2.2: [5] FU [Mic Capture Volume] ch = 1, val =
4608/7680/1
Adding it to the list of devices in volume_control_quirks makes it work
properly, fixing related typo.
Signed-off-by: Con Kolivas <kernel@kolivas.org>
We accidentally introduced a dereference before the NULL check in
xmit_descs() as part of silencing a GCC warning.
Fixes: 16f46050e709 ("dbri: Fix compiler warning")
Pull sparc fixes from David Miller:
"Two ugly build warning fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
qlogicpti: Fix compiler warnings
dbri uses 'u32' for dma handle while invoking kernel DMA APIs,
instead of using dma_addr_t. This hasn't caused any 'incompatible
pointer type' warning on SPARC because until now dma_addr_t is of
type u32. However, recent changes in SPARC ATU (iommu) enabled 64bit
DMA and therefore dma_addr_t became of type u64. This makes
'incompatible pointer type' warnings inevitable.
e.g.
sound/sparc/dbri.c: In function ‘snd_dbri_create’:
sound/sparc/dbri.c:2538: warning: passing argument 3 of ‘dma_zalloc_coherent’ from incompatible pointer type
./include/linux/dma-mapping.h:608: note: expected ‘dma_addr_t *’ but argument is of type ‘u32 *’
For the record, dbri(sbus) driver never executes on sun4v. Therefore
even though 64bit DMA is enabled on SPARC, dbri continues to use
legacy iommu that guarantees DMA address is always in 32bit range.
This patch resolves above compiler warning.
Signed-off-by: Tushar Dave <tushar.n.dave@oracle.com>
Reviewed-by: thomas tai <thomas.tai@oracle.com>
