path: root/sound
2017-01-11Merge tag 'v4.4.39' into toradex_vf_4.4-nextStefan Agner
This is the 4.4.39 stable release
2016-12-08ALSA: pcm : Call kill_fasync() in stream lockTakashi Iwai
commit 3aa02cb664c5fb1042958c8d1aa8c35055a2ebc4 upstream. Currently kill_fasync() is called outside the stream lock in snd_pcm_period_elapsed(). This is potentially racy, since the stream may get released even during the irq handler is running. Although snd_pcm_release_substream() calls snd_pcm_drop(), this doesn't guarantee that the irq handler finishes, thus the kill_fasync() call outside the stream spin lock may be invoked after the substream is detached, as recently reported by KASAN. As a quick workaround, move kill_fasync() call inside the stream lock. The fasync is rarely used interface, so this shouldn't have a big impact from the performance POV. Ideally, we should implement some sync mechanism for the proper finish of stream and irq handler. But this oneliner should suffice for most cases, so far. Reported-by: Baozeng Ding <sploving1@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18ASoC: sun4i-codec: return error code instead of NULL when create_card failsChen-Yu Tsai
commit 85915b63ad8b796848f431b66c9ba5e356e722e5 upstream. When sun4i_codec_create_card fails, we do not assign a proper error code to the return value. The return value would be 0 from the previous function call, or we would have bailed out sooner. This would confuse the driver core into thinking the device probe succeeded, when in fact it didn't, leaving various devres based resources lingering. Make the create_card function pass back a meaningful error code, and assign it to the return value. Fixes: 45fb6b6f2aa3 ("ASoC: sunxi: add support for the on-chip codec on early Allwinner SoCs") Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18ASoC: cs4270: fix DAPM stream name mismatchmurray foster
commit aa5f920993bda2095952177eea79bc8e58ae6065 upstream. Mismatching stream names in DAPM route and widget definitions are causing compilation errors. Fixing these names allows the cs4270 driver to compile and function. [Errors must be at probe time not compile time -- broonie] Signed-off-by: Murray Foster <mrafoster@gmail.com> Acked-by: Paul Handrigan <Paul.Handrigan@cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18ALSA: info: Limit the proc text input sizeTakashi Iwai
commit 027a9fe6835620422b6713892175716f3613dd9d upstream. The ALSA proc handler allows currently the write in the unlimited size until kmalloc() fails. But basically the write is supposed to be only for small inputs, mostly for one line inputs, and we don't have to handle too large sizes at all. Since the kmalloc error results in the kernel warning, it's better to limit the size beforehand. This patch adds the limit of 16kB, which must be large enough for the currently existing code. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18ALSA: info: Return error for invalid read/writeTakashi Iwai
commit 6809cd682b82dfff47943850d1a8c714f971b5ca upstream. Currently the ALSA proc handler allows read or write even if the proc file were write-only or read-only. It's mostly harmless, does thing but allocating memory and ignores the input/output. But it doesn't tell user about the invalid use, and it's confusing and inconsistent in comparison with other proc files. This patch adds some sanity checks and let the proc handler returning an -EIO error when the invalid read/write is performed. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ALSA: hda - Fix headset mic detection problem for two Dell laptopsHui Wang
commit 6aecd8715802d23dc6a0859b50c62d2b0a99de3a upstream. They uses the codec ALC255, and have the different pin cfg definition from the ones in the existing pin quirk table. Now adding them into the table to fix the problem. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ALSA: hda - Adding a new group of pin cfg into ALC295 pin quirk tableHui Wang
commit f771d5bb71d4df9573d12386400540516672208b upstream. We have a new Dell laptop model which uses ALC295, the pin definition is different from the existing ones in the pin quirk table, to fix the headset mic detection and mic mute led's problem, we need to add the new pin defintion into the pin quirk table. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ALSA: hda - allow 40 bit DMA mask for NVidia devicesArd Biesheuvel
commit 3ab7511eafdd5c4f40d2832f09554478dfbea170 upstream. Commit 49d9e77e72cf ("ALSA: hda - Fix system panic when DMA > 40 bits for Nvidia audio controllers") simply disabled any DMA exceeding 32 bits for NVidia devices, even though they are capable of performing DMA up to 40 bits. On some architectures (such as arm64), system memory is not guaranteed to be 32-bit addressable by PCI devices, and so this change prevents NVidia devices from working on platforms such as AMD Seattle. Since the original commit already mentioned that up to 40 bits of DMA is supported, and given that the code has been updated in the meantime to support a 40 bit DMA mask on other devices, revert commit 49d9e77e72cf and explicitly set the DMA mask to 40 bits for NVidia devices. Fixes: 49d9e77e72cf ('ALSA: hda - Fix system panic when DMA > 40 bits...') Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ALSA: hda - Raise AZX_DCAPS_RIRB_DELAY handling into top driversTakashi Iwai
commit 7d9a180895ee8c301df7f9447429009795c56c21 upstream. AZX_DCAPS_RIRB_DELAY is dedicated only for Nvidia and its purpose is just to set a flag in bus. So it's better to be set in the toplevel driver, either hda_intel.c or hda_tegra.c, instead of the common hda_controller.c. This also allows us to strip this flag from dcaps, so save one more bit there. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ALSA: hda - Merge RIRB_PRE_DELAY into CTX_WORKAROUND capsTakashi Iwai
commit ef85f299c74e6c5dd98ec0230183be33f4c2813d upstream. AZX_DCAPS_RIRB_PRE_DELAY is always tied with AZX_DCAPS_CTX_WORKAROUND, which is Creative's XFi specific. So, we can replace it and reduce one more bit free for DCAPS. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-10ALSA: usb-audio: Add quirk for Syntek STK1160Marcel Hasler
commit bdc3478f90cd4d2928197f36629d5cf93b64dbe9 upstream. The stk1160 chip needs QUIRK_AUDIO_ALIGN_TRANSFER. This patch resolves the issue reported on the mailing list (http://marc.info/?l=linux-sound&m=139223599126215&w=2) and also fixes bug 180071 (https://bugzilla.kernel.org/show_bug.cgi?id=180071). Signed-off-by: Marcel Hasler <mahasler@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31ASoC: dapm: Fix kcontrol creation for output driver widgetChen-Yu Tsai
commit a3930ed060df4ccf2a06cf0b68738dec3e6ff89a upstream. Commit d88429a695a4 ("ASoC: dapm: Add output driver widget") added the snd_soc_dapm_out_drv ID for the output driver widget, which is the same as the PGA widget, with a later power sequence number. Commit 19a2557b76d6 ("ASoC: dapm: Add kcontrol support for PGAs") then added kcontrol support for PGA widgets, but failed to account for output driver widgets. Attempts to use kcontrols with output driver widgets result in silent failures, with the developer having little idea about what went on. Add snd_soc_dapm_out_drv to the switch/case block under snd_soc_dapm_pga in dapm_create_or_share_kcontrol, since they are essentially the same. Fixes: 19a2557b76d6 (ASoC: dapm: Add kcontrol support for PGAs) Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31ASoC: dapm: Fix value setting for _ENUM_DOUBLE MUX's second channelChen-Yu Tsai
commit 071133a209354f39d4e5785d5a6a390e03241841 upstream. The value for the second channel in _ENUM_DOUBLE (double channel) MUXs is not correctly updated, due to using the wrong bit shift. Use the correct bit shift, so both channels toggle together. Fixes: 3727b4968453 (ASoC: dapm: Consolidate MUXs and value MUXs) Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31ASoC: dapm: Fix possible uninitialized variable in snd_soc_dapm_get_volsw()Chen-Yu Tsai
commit 01ad5e7de67b408d9b48b437b06a9938ddf460b5 upstream. If soc_dapm_read() fails, val will be uninitialized, and bogus values will be written later: ret = soc_dapm_read(dapm, reg, &val); val = (val >> shift) & mask; However, the compiler does not give a warning. Return on error before val is really used to avoid this. This is similar to the commit 6912831623c5 ("ASoC: dapm: Fix uninitialized variable in snd_soc_dapm_get_enum_double()") Fixes: ce0fc93ae56e (ASoC: Add DAPM support at the component level) Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31ASoC: topology: Fix error return code in soc_tplg_dapm_widget_create()Wei Yongjun
commit 8ae3ea48df0d746b663057cf0b972a18d0777b7b upstream. Fix to return error code -ENOMEM instead of 0 when failed to create widget, as done elsewhere in this function. Fixes: 8a9782346dcc ("ASoC: topology: Add topology core") Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28ALSA: hda - Fix a failure of micmute led when having multi adcsHui Wang
commit 4875a5f7218068cdeea5f998330dfa3d118b2fea upstream. On a Dell laptop, there is no global adcs for all input devices, so the input devices use the different adc, as a result, dyn_adc_switch is set to true. In this situation, it is safe to control the micmute led according to user's choice of muting/unmuting the current input device, since only current input device path is active, while other input device paths are inactive and powered down. Fixes: 00ef99408b6c ('ALSA: hda - add mic mute led hook for dell machines') Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-22ASoC: Intel: Atom: add a missing star in a memcpy callNicolas Iooss
commit 61ab0d403bbd9d5f6e000e3b5734049141b91f6f upstream. In sst_prepare_and_post_msg(), when a response is received in "block", the following code gets executed: *data = kzalloc(block->size, GFP_KERNEL); memcpy(data, (void *) block->data, block->size); The memcpy() call overwrites the content of the *data pointer instead of filling the newly-allocated memory (which pointer is hold by *data). Fix this by merging kzalloc+memcpy into a single kmemdup() call. Thanks Joe Perches for suggesting using kmemdup() Fixes: 60dc8dbacb00 ("ASoC: Intel: sst: Add some helper functions") Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16ALSA: usb-line6: use the same declaration as definition in header for MIDI ↵Takashi Sakamoto
manufacturer ID commit 8da08ca03b73593d5299893bf29fc08569c3fb5f upstream. Currently, usb-line6 module exports an array of MIDI manufacturer ID and usb-pod module uses it. However, the declaration is not the definition in common header. The difference is explicit length of array. Although compiler calculates it and everything goes well, it's better to use the same representation between definition and declaration. This commit fills the length of array for usb-line6 module. As a small good sub-effect, this commit suppress below warnings from static analysis by sparse v0.5.0. sound/usb/line6/driver.c:274:43: error: cannot size expression sound/usb/line6/driver.c:275:16: error: cannot size expression sound/usb/line6/driver.c:276:16: error: cannot size expression sound/usb/line6/driver.c:277:16: error: cannot size expression Fixes: 705ececd1c60 ("Staging: add line6 usb driver") Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16ALSA: usb-audio: Extend DragonFly dB scale quirk to cover other variantsAnssi Hannula
commit eb1a74b7bea17eea31915c4f76385cefe69d9795 upstream. The DragonFly quirk added in 42e3121d90f4 ("ALSA: usb-audio: Add a more accurate volume quirk for AudioQuest DragonFly") applies a custom dB map on the volume control when its range is reported as 0..50 (0 .. 0.2dB). However, there exists at least one other variant (hw v1.0c, as opposed to the tested v1.2) which reports a different non-sensical volume range (0..53) and the custom map is therefore not applied for that device. This results in all of the volume change appearing close to 100% on mixer UIs that utilize the dB TLV information. Add a fallback case where no dB TLV is reported at all if the control range is not 0..50 but still 0..N where N <= 1000 (3.9 dB). Also restrict the quirk to only apply to the volume control as there is also a mute control which would match the check otherwise. Fixes: 42e3121d90f4 ("ALSA: usb-audio: Add a more accurate volume quirk for AudioQuest DragonFly") Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Reported-by: David W <regulars@d-dub.org.uk> Tested-by: David W <regulars@d-dub.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-16ALSA: ali5451: Fix out-of-bound position reportingTakashi Iwai
commit db68577966abc1aeae4ec597b3dcfa0d56e92041 upstream. The pointer callbacks of ali5451 driver may return the value at the boundary occasionally, and it results in the kernel warning like snd_ali5451 0000:00:06.0: BUG: , pos = 16384, buffer size = 16384, period size = 1024 It seems that folding the position offset is enough for fixing the warning and no ill-effect has been seen by that. Reported-by: Enrico Mioso <mrkiko.rs@gmail.com> Tested-by: Enrico Mioso <mrkiko.rs@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07ALSA: hda - Add the top speaker pin config for HP Spectre x360Takashi Iwai
commit 0eec880966e77bdbee0112989a2be67d92e39929 upstream. HP Spectre x360 with CX20724 codec has two speaker outputs while the BIOS sets up only the bottom one (NID 0x17) and disables the top one (NID 0x1d). This patch adds a fixup simply defining the proper pincfg for NID 0x1d so that the top speaker works as is. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=169071 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07ALSA: hda - Fix headset mic detection problem for several Dell laptopsHui Wang
commit 3f640970a41429f0a076c01270bbd014c9eae61c upstream. One of the laptops has the codec ALC256 on it, applying the ALC255_FIXUP_DELL1_MIC_NO_PRESENCE can fix the problem, the rest of laptops have the codec ALC295 on them, they are similar to machines with ALC225, applying the ALC269_FIXUP_DELL1_MIC_NO_PRESENCE can fix the problem. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07ALSA: hda - Adding one more ALC255 pin definition for headset problemHui Wang
commit 392c9da24a994f238c5d7ea611c6245be4617014 upstream. We have two new Dell laptop models, they have the same ALC255 pin definition, but not in the pin quirk table yet, as a result, the headset microphone can't work. After adding the definition in the table, the headset microphone works well. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07ASoC: omap-mcpdm: Fix irq resource handlingPeter Ujfalusi
commit a8719670687c46ed2e904c0d05fa4cd7e4950cd1 upstream. Fixes: ddd17531ad908 ("ASoC: omap-mcpdm: Clean up with devm_* function") Managed irq request will not doing any good in ASoC probe level as it is not going to free up the irq when the driver is unbound from the sound card. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Reported-by: Russell King <linux@armlinux.org.uk> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07ASoC: Intel: Skylake: Fix error return code in skl_probe()Wei Yongjun
commit 979cf59acc9d634cc140aadd0d2915947ab303cc upstream. Fix to return error code -ENODEV from the error handling case instead of 0, as done elsewhere in this function. Fixes: 87b2bdf02278 ("ASoC: Intel: Skylake: Initialize NHLT table") Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com> Acked-By: Vinod Koul <vinod.kou@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-29Merge tag 'v4.4.21' into toradex_vf_4.4-nextStefan Agner
This is the 4.4.21 stable release
2016-09-15ALSA: timer: fix NULL pointer dereference on memory allocation failureVegard Nossum
commit 8ddc05638ee42b18ba4fe99b5fb647fa3ad20456 upstream. I hit this with syzkaller: kasan: CONFIG_KASAN_INLINE enabled kasan: GPF could be caused by NULL-ptr deref or user memory access general protection fault: 0000 [#1] PREEMPT SMP KASAN CPU: 0 PID: 1327 Comm: a.out Not tainted 4.8.0-rc2+ #190 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014 task: ffff88011278d600 task.stack: ffff8801120c0000 RIP: 0010:[<ffffffff82c8ba07>] [<ffffffff82c8ba07>] snd_hrtimer_start+0x77/0x100 RSP: 0018:ffff8801120c7a60 EFLAGS: 00010006 RAX: dffffc0000000000 RBX: 0000000000000000 RCX: 0000000000000007 RDX: 0000000000000009 RSI: 1ffff10023483091 RDI: 0000000000000048 RBP: ffff8801120c7a78 R08: ffff88011a5cf768 R09: ffff88011a5ba790 R10: 0000000000000002 R11: ffffed00234b9ef1 R12: ffff880114843980 R13: ffffffff84213c00 R14: ffff880114843ab0 R15: 0000000000000286 FS: 00007f72958f3700(0000) GS:ffff88011aa00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000603001 CR3: 00000001126ab000 CR4: 00000000000006f0 Stack: ffff880114843980 ffff880111eb2dc0 ffff880114843a34 ffff8801120c7ad0 ffffffff82c81ab1 0000000000000000 ffffffff842138e0 0000000100000000 ffff880111eb2dd0 ffff880111eb2dc0 0000000000000001 ffff880111eb2dc0 Call Trace: [<ffffffff82c81ab1>] snd_timer_start1+0x331/0x670 [<ffffffff82c85bfd>] snd_timer_start+0x5d/0xa0 [<ffffffff82c8795e>] snd_timer_user_ioctl+0x88e/0x2830 [<ffffffff8159f3a0>] ? __follow_pte.isra.49+0x430/0x430 [<ffffffff82c870d0>] ? snd_timer_pause+0x80/0x80 [<ffffffff815a26fa>] ? do_wp_page+0x3aa/0x1c90 [<ffffffff8132762f>] ? put_prev_entity+0x108f/0x21a0 [<ffffffff82c870d0>] ? snd_timer_pause+0x80/0x80 [<ffffffff816b0733>] do_vfs_ioctl+0x193/0x1050 [<ffffffff813510af>] ? cpuacct_account_field+0x12f/0x1a0 [<ffffffff816b05a0>] ? ioctl_preallocate+0x200/0x200 [<ffffffff81002f2f>] ? syscall_trace_enter+0x3cf/0xdb0 [<ffffffff815045ba>] ? __context_tracking_exit.part.4+0x9a/0x1e0 [<ffffffff81002b60>] ? exit_to_usermode_loop+0x190/0x190 [<ffffffff82001a97>] ? check_preemption_disabled+0x37/0x1e0 [<ffffffff81d93889>] ? security_file_ioctl+0x89/0xb0 [<ffffffff816b167f>] SyS_ioctl+0x8f/0xc0 [<ffffffff816b15f0>] ? do_vfs_ioctl+0x1050/0x1050 [<ffffffff81005524>] do_syscall_64+0x1c4/0x4e0 [<ffffffff83c32b2a>] entry_SYSCALL64_slow_path+0x25/0x25 Code: c7 c7 c4 b9 c8 82 48 89 d9 4c 89 ee e8 63 88 7f fe e8 7e 46 7b fe 48 8d 7b 48 48 b8 00 00 00 00 00 fc ff df 48 89 fa 48 c1 ea 03 <0f> b6 04 02 84 c0 74 04 84 c0 7e 65 80 7b 48 00 74 0e e8 52 46 RIP [<ffffffff82c8ba07>] snd_hrtimer_start+0x77/0x100 RSP <ffff8801120c7a60> ---[ end trace 5955b08db7f2b029 ]--- This can happen if snd_hrtimer_open() fails to allocate memory and returns an error, which is currently not checked by snd_timer_open(): ioctl(SNDRV_TIMER_IOCTL_SELECT) - snd_timer_user_tselect() - snd_timer_close() - snd_hrtimer_close() - (struct snd_timer *) t->private_data = NULL - snd_timer_open() - snd_hrtimer_open() - kzalloc() fails; t->private_data is still NULL ioctl(SNDRV_TIMER_IOCTL_START) - snd_timer_user_start() - snd_timer_start() - snd_timer_start1() - snd_hrtimer_start() - t->private_data == NULL // boom Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ALSA: timer: fix division by zero after SNDRV_TIMER_IOCTL_CONTINUEVegard Nossum
commit 6b760bb2c63a9e322c0e4a0b5daf335ad93d5a33 upstream. I got this: divide error: 0000 [#1] PREEMPT SMP KASAN CPU: 1 PID: 1327 Comm: a.out Not tainted 4.8.0-rc2+ #189 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014 task: ffff8801120a9580 task.stack: ffff8801120b0000 RIP: 0010:[<ffffffff82c8bd9a>] [<ffffffff82c8bd9a>] snd_hrtimer_callback+0x1da/0x3f0 RSP: 0018:ffff88011aa87da8 EFLAGS: 00010006 RAX: 0000000000004f76 RBX: ffff880112655e88 RCX: 0000000000000000 RDX: 0000000000000000 RSI: ffff880112655ea0 RDI: 0000000000000001 RBP: ffff88011aa87e00 R08: ffff88013fff905c R09: ffff88013fff9048 R10: ffff88013fff9050 R11: 00000001050a7b8c R12: ffff880114778a00 R13: ffff880114778ab4 R14: ffff880114778b30 R15: 0000000000000000 FS: 00007f071647c700(0000) GS:ffff88011aa80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000603001 CR3: 0000000112021000 CR4: 00000000000006e0 Stack: 0000000000000000 ffff880114778ab8 ffff880112655ea0 0000000000004f76 ffff880112655ec8 ffff880112655e80 ffff880112655e88 ffff88011aa98fc0 00000000b97ccf2b dffffc0000000000 ffff88011aa98fc0 ffff88011aa87ef0 Call Trace: <IRQ> [<ffffffff813abce7>] __hrtimer_run_queues+0x347/0xa00 [<ffffffff82c8bbc0>] ? snd_hrtimer_close+0x130/0x130 [<ffffffff813ab9a0>] ? retrigger_next_event+0x1b0/0x1b0 [<ffffffff813ae1a6>] ? hrtimer_interrupt+0x136/0x4b0 [<ffffffff813ae220>] hrtimer_interrupt+0x1b0/0x4b0 [<ffffffff8120f91e>] local_apic_timer_interrupt+0x6e/0xf0 [<ffffffff81227ad3>] ? kvm_guest_apic_eoi_write+0x13/0xc0 [<ffffffff83c35086>] smp_apic_timer_interrupt+0x76/0xa0 [<ffffffff83c3416c>] apic_timer_interrupt+0x8c/0xa0 <EOI> [<ffffffff83c3239c>] ? _raw_spin_unlock_irqrestore+0x2c/0x60 [<ffffffff82c8185d>] snd_timer_start1+0xdd/0x670 [<ffffffff82c87015>] snd_timer_continue+0x45/0x80 [<ffffffff82c88100>] snd_timer_user_ioctl+0x1030/0x2830 [<ffffffff8159f3a0>] ? __follow_pte.isra.49+0x430/0x430 [<ffffffff82c870d0>] ? snd_timer_pause+0x80/0x80 [<ffffffff815a26fa>] ? do_wp_page+0x3aa/0x1c90 [<ffffffff815aa4f8>] ? handle_mm_fault+0xbc8/0x27f0 [<ffffffff815a9930>] ? __pmd_alloc+0x370/0x370 [<ffffffff82c870d0>] ? snd_timer_pause+0x80/0x80 [<ffffffff816b0733>] do_vfs_ioctl+0x193/0x1050 [<ffffffff816b05a0>] ? ioctl_preallocate+0x200/0x200 [<ffffffff81002f2f>] ? syscall_trace_enter+0x3cf/0xdb0 [<ffffffff815045ba>] ? __context_tracking_exit.part.4+0x9a/0x1e0 [<ffffffff81002b60>] ? exit_to_usermode_loop+0x190/0x190 [<ffffffff82001a97>] ? check_preemption_disabled+0x37/0x1e0 [<ffffffff81d93889>] ? security_file_ioctl+0x89/0xb0 [<ffffffff816b167f>] SyS_ioctl+0x8f/0xc0 [<ffffffff816b15f0>] ? do_vfs_ioctl+0x1050/0x1050 [<ffffffff81005524>] do_syscall_64+0x1c4/0x4e0 [<ffffffff83c32b2a>] entry_SYSCALL64_slow_path+0x25/0x25 Code: e8 fc 42 7b fe 8b 0d 06 8a 50 03 49 0f af cf 48 85 c9 0f 88 7c 01 00 00 48 89 4d a8 e8 e0 42 7b fe 48 8b 45 c0 48 8b 4d a8 48 99 <48> f7 f9 49 01 c7 e8 cb 42 7b fe 48 8b 55 d0 48 b8 00 00 00 00 RIP [<ffffffff82c8bd9a>] snd_hrtimer_callback+0x1da/0x3f0 RSP <ffff88011aa87da8> ---[ end trace 6aa380f756a21074 ]--- The problem happens when you call ioctl(SNDRV_TIMER_IOCTL_CONTINUE) on a completely new/unused timer -- it will have ->sticks == 0, which causes a divide by 0 in snd_hrtimer_callback(). Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ALSA: timer: fix NULL pointer dereference in read()/ioctl() raceVegard Nossum
commit 11749e086b2766cccf6217a527ef5c5604ba069c upstream. I got this with syzkaller: ================================================================== BUG: KASAN: null-ptr-deref on address 0000000000000020 Read of size 32 by task syz-executor/22519 CPU: 1 PID: 22519 Comm: syz-executor Not tainted 4.8.0-rc2+ #169 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2 014 0000000000000001 ffff880111a17a00 ffffffff81f9f141 ffff880111a17a90 ffff880111a17c50 ffff880114584a58 ffff880114584a10 ffff880111a17a80 ffffffff8161fe3f ffff880100000000 ffff880118d74a48 ffff880118d74a68 Call Trace: [<ffffffff81f9f141>] dump_stack+0x83/0xb2 [<ffffffff8161fe3f>] kasan_report_error+0x41f/0x4c0 [<ffffffff8161ff74>] kasan_report+0x34/0x40 [<ffffffff82c84b54>] ? snd_timer_user_read+0x554/0x790 [<ffffffff8161e79e>] check_memory_region+0x13e/0x1a0 [<ffffffff8161e9c1>] kasan_check_read+0x11/0x20 [<ffffffff82c84b54>] snd_timer_user_read+0x554/0x790 [<ffffffff82c84600>] ? snd_timer_user_info_compat.isra.5+0x2b0/0x2b0 [<ffffffff817d0831>] ? proc_fault_inject_write+0x1c1/0x250 [<ffffffff817d0670>] ? next_tgid+0x2a0/0x2a0 [<ffffffff8127c278>] ? do_group_exit+0x108/0x330 [<ffffffff8174653a>] ? fsnotify+0x72a/0xca0 [<ffffffff81674dfe>] __vfs_read+0x10e/0x550 [<ffffffff82c84600>] ? snd_timer_user_info_compat.isra.5+0x2b0/0x2b0 [<ffffffff81674cf0>] ? do_sendfile+0xc50/0xc50 [<ffffffff81745e10>] ? __fsnotify_update_child_dentry_flags+0x60/0x60 [<ffffffff8143fec6>] ? kcov_ioctl+0x56/0x190 [<ffffffff81e5ada2>] ? common_file_perm+0x2e2/0x380 [<ffffffff81746b0e>] ? __fsnotify_parent+0x5e/0x2b0 [<ffffffff81d93536>] ? security_file_permission+0x86/0x1e0 [<ffffffff816728f5>] ? rw_verify_area+0xe5/0x2b0 [<ffffffff81675355>] vfs_read+0x115/0x330 [<ffffffff81676371>] SyS_read+0xd1/0x1a0 [<ffffffff816762a0>] ? vfs_write+0x4b0/0x4b0 [<ffffffff82001c2c>] ? __this_cpu_preempt_check+0x1c/0x20 [<ffffffff8150455a>] ? __context_tracking_exit.part.4+0x3a/0x1e0 [<ffffffff816762a0>] ? vfs_write+0x4b0/0x4b0 [<ffffffff81005524>] do_syscall_64+0x1c4/0x4e0 [<ffffffff810052fc>] ? syscall_return_slowpath+0x16c/0x1d0 [<ffffffff83c3276a>] entry_SYSCALL64_slow_path+0x25/0x25 ================================================================== There are a couple of problems that I can see: - ioctl(SNDRV_TIMER_IOCTL_SELECT), which potentially sets tu->queue/tu->tqueue to NULL on memory allocation failure, so read() would get a NULL pointer dereference like the above splat - the same ioctl() can free tu->queue/to->tqueue which means read() could potentially see (and dereference) the freed pointer We can fix both by taking the ioctl_lock mutex when dereferencing ->queue/->tqueue, since that's always held over all the ioctl() code. Just looking at the code I find it likely that there are more problems here such as tu->qhead pointing outside the buffer if the size is changed concurrently using SNDRV_TIMER_IOCTL_PARAMS. Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ALSA: hda - Enable subwoofer on Dell Inspiron 7559Kai-Heng Feng
commit fd06c77eb9200b53d421da5fffe0dcd894b5d72a upstream. The subwoofer on Inspiron 7559 was disabled originally. Applying a pin fixup to node 0x1b can enable it and make it work. Old pin: 0x411111f0 New pin: 0x90170151 Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ALSA: hda - Add headset mic quirk for Dell Inspiron 5468Shrirang Bagul
commit 311042d1b67d9a1856a8e1294e7729fb86f64014 upstream. This patch enables headset microphone on some variants of Dell Inspiron 5468. (Dell SSID 0x07ad) BugLink: https://bugs.launchpad.net/bugs/1617900 Signed-off-by: Shrirang Bagul <shrirang.bagul@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ALSA: rawmidi: Fix possible deadlock with virmidi registrationTakashi Iwai
commit 816f318b2364262a51024096da7ca3b84e78e3b5 upstream. When a seq-virmidi driver is initialized, it registers a rawmidi instance with its callback to create an associated seq kernel client. Currently it's done throughly in rawmidi's register_mutex context. Recently it was found that this may lead to a deadlock another rawmidi device that is being attached with the sequencer is accessed, as both open with the same register_mutex. This was actually triggered by syzkaller, as Dmitry Vyukov reported: ====================================================== [ INFO: possible circular locking dependency detected ] 4.8.0-rc1+ #11 Not tainted ------------------------------------------------------- syz-executor/7154 is trying to acquire lock: (register_mutex#5){+.+.+.}, at: [<ffffffff84fd6d4b>] snd_rawmidi_kernel_open+0x4b/0x260 sound/core/rawmidi.c:341 but task is already holding lock: (&grp->list_mutex){++++.+}, at: [<ffffffff850138bb>] check_and_subscribe_port+0x5b/0x5c0 sound/core/seq/seq_ports.c:495 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&grp->list_mutex){++++.+}: [<ffffffff8147a3a8>] lock_acquire+0x208/0x430 kernel/locking/lockdep.c:3746 [<ffffffff863f6199>] down_read+0x49/0xc0 kernel/locking/rwsem.c:22 [< inline >] deliver_to_subscribers sound/core/seq/seq_clientmgr.c:681 [<ffffffff85005c5e>] snd_seq_deliver_event+0x35e/0x890 sound/core/seq/seq_clientmgr.c:822 [<ffffffff85006e96>] > snd_seq_kernel_client_dispatch+0x126/0x170 sound/core/seq/seq_clientmgr.c:2418 [<ffffffff85012c52>] snd_seq_system_broadcast+0xb2/0xf0 sound/core/seq/seq_system.c:101 [<ffffffff84fff70a>] snd_seq_create_kernel_client+0x24a/0x330 sound/core/seq/seq_clientmgr.c:2297 [< inline >] snd_virmidi_dev_attach_seq sound/core/seq/seq_virmidi.c:383 [<ffffffff8502d29f>] snd_virmidi_dev_register+0x29f/0x750 sound/core/seq/seq_virmidi.c:450 [<ffffffff84fd208c>] snd_rawmidi_dev_register+0x30c/0xd40 sound/core/rawmidi.c:1645 [<ffffffff84f816d3>] __snd_device_register.part.0+0x63/0xc0 sound/core/device.c:164 [< inline >] __snd_device_register sound/core/device.c:162 [<ffffffff84f8235d>] snd_device_register_all+0xad/0x110 sound/core/device.c:212 [<ffffffff84f7546f>] snd_card_register+0xef/0x6c0 sound/core/init.c:749 [<ffffffff85040b7f>] snd_virmidi_probe+0x3ef/0x590 sound/drivers/virmidi.c:123 [<ffffffff833ebf7b>] platform_drv_probe+0x8b/0x170 drivers/base/platform.c:564 ...... -> #0 (register_mutex#5){+.+.+.}: [< inline >] check_prev_add kernel/locking/lockdep.c:1829 [< inline >] check_prevs_add kernel/locking/lockdep.c:1939 [< inline >] validate_chain kernel/locking/lockdep.c:2266 [<ffffffff814791f4>] __lock_acquire+0x4d44/0x4d80 kernel/locking/lockdep.c:3335 [<ffffffff8147a3a8>] lock_acquire+0x208/0x430 kernel/locking/lockdep.c:3746 [< inline >] __mutex_lock_common kernel/locking/mutex.c:521 [<ffffffff863f0ef1>] mutex_lock_nested+0xb1/0xa20 kernel/locking/mutex.c:621 [<ffffffff84fd6d4b>] snd_rawmidi_kernel_open+0x4b/0x260 sound/core/rawmidi.c:341 [<ffffffff8502e7c7>] midisynth_subscribe+0xf7/0x350 sound/core/seq/seq_midi.c:188 [< inline >] subscribe_port sound/core/seq/seq_ports.c:427 [<ffffffff85013cc7>] check_and_subscribe_port+0x467/0x5c0 sound/core/seq/seq_ports.c:510 [<ffffffff85015da9>] snd_seq_port_connect+0x2c9/0x500 sound/core/seq/seq_ports.c:579 [<ffffffff850079b8>] snd_seq_ioctl_subscribe_port+0x1d8/0x2b0 sound/core/seq/seq_clientmgr.c:1480 [<ffffffff84ffe9e4>] snd_seq_do_ioctl+0x184/0x1e0 sound/core/seq/seq_clientmgr.c:2225 [<ffffffff84ffeae8>] snd_seq_kernel_client_ctl+0xa8/0x110 sound/core/seq/seq_clientmgr.c:2440 [<ffffffff85027664>] snd_seq_oss_midi_open+0x3b4/0x610 sound/core/seq/oss/seq_oss_midi.c:375 [<ffffffff85023d67>] snd_seq_oss_synth_setup_midi+0x107/0x4c0 sound/core/seq/oss/seq_oss_synth.c:281 [<ffffffff8501b0a8>] snd_seq_oss_open+0x748/0x8d0 sound/core/seq/oss/seq_oss_init.c:274 [<ffffffff85019d8a>] odev_open+0x6a/0x90 sound/core/seq/oss/seq_oss.c:138 [<ffffffff84f7040f>] soundcore_open+0x30f/0x640 sound/sound_core.c:639 ...... other info that might help us debug this: Possible unsafe locking scenario: CPU0 CPU1 ---- ---- lock(&grp->list_mutex); lock(register_mutex#5); lock(&grp->list_mutex); lock(register_mutex#5); *** DEADLOCK *** ====================================================== The fix is to simply move the registration parts in snd_rawmidi_dev_register() to the outside of the register_mutex lock. The lock is needed only to manage the linked list, and it's not necessarily to cover the whole initialization process. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ALSA: fireworks: accessing to user space outside spinlockTakashi Sakamoto
commit 6b1ca4bcadf9ef077cc5f03c6822ba276ed14902 upstream. In hwdep interface of fireworks driver, accessing to user space is in a critical section with disabled local interrupt. Depending on architecture, accessing to user space can cause page fault exception. Then local processor stores machine status and handles the synchronous event. A handler corresponding to the event can call task scheduler to wait for preparing pages. In a case of usage of single core processor, the state to disable local interrupt is worse because it don't handle usual interrupts from hardware. This commit fixes this bug, performing the accessing outside spinlock. This commit also gives up counting the number of queued response messages to simplify ring-buffer management. Reported-by: Vaishali Thakkar <vaishali.thakkar@oracle.com> Fixes: 555e8a8f7f14('ALSA: fireworks: Add command/response functionality into hwdep interface') Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ALSA: firewire-tascam: accessing to user space outside spinlockTakashi Sakamoto
commit 04b2d9c9c319277ad4fbbb71855c256a9f4d5f98 upstream. In hwdep interface of firewire-tascam driver, accessing to user space is in a critical section with disabled local interrupt. Depending on architecture, accessing to user space can cause page fault exception. Then local processor stores machine status and handle the synchronous event. A handler corresponding to the event can call task scheduler to wait for preparing pages. In a case of usage of single core processor, the state to disable local interrupt is worse because it doesn't handle usual interrupts from hardware. This commit fixes this bug, by performing the accessing outside spinlock. Reported-by: Vaishali Thakkar <vaishali.thakkar@oracle.com> Fixes: e5e0c3dd257b('ALSA: firewire-tascam: add hwdep interface') Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ALSA: usb-audio: Add sample rate inquiry quirk for B850V3 CP2114Ken Lin
commit 83d9956b7e6b310c1062df7894257251c625b22e upstream. Avoid getting sample rate on B850V3 CP2114 as it is unsupported and causes noisy "current rate is different from the runtime rate" messages when playback starts. Signed-off-by: Ken Lin <ken.lin@advantech.com.tw> Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ASoC: atmel_ssc_dai: Don't unconditionally reset SSC on stream startupChristoph Huber
commit 3e103a65514c2947e53f3171b21255fbde8b60c6 upstream. commit cbaadf0f90d6 ("ASoC: atmel_ssc_dai: refactor the startup and shutdown") refactored code such that the SSC is reset on every startup; this breaks duplex audio (e.g. first start audio playback, then start record, causing the playback to stop/hang) Fixes: cbaadf0f90d6 (ASoC: atmel_ssc_dai: refactor the startup and shutdown) Signed-off-by: Christoph Huber <c.huber@bct-electronic.com> Signed-off-by: Peter Meerwald-Stadler <p.meerwald@bct-electronic.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ALSA: hda: add AMD Polaris-10/11 AZ PCI IDs with proper driver capsMaruthi Srinivas Bayyavarapu
[ Upstream commit 8eb22214b7cb0c0a28be6caf3b81201629d8ea7c ] This commit fixes garbled audio on Polaris-10/11 variants Signed-off-by: Maruthi Bayyavarapu <maruthi.bayyavarapu@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Acked-by: Christian König <christian.koenig@amd.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15ALSA: hda - add codec support for Kabylake display audio codecLibin Yang
[ Upstream commit 91815d8aa7e2f45d30e51caa297061ad893628d9 ] This patch adds codec ID (0x8086280b) for Kabylake display codec and apply the hsw fix-ups to Kabylake. Signed-off-by: Libin Yang <libin.yang@linux.intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07ALSA: line6: Fix POD sysfs attributes segfaultAndrej Krutak
commit b027d11263836a0cd335520175257dcb99b43757 upstream. The commit 02fc76f6a changed base of the sysfs attributes from device to card. The "show" callbacks dereferenced wrong objects because of this. Fixes: 02fc76f6a7db ('ALSA: line6: Create sysfs via snd_card_add_dev_attr()') Reviewed-by: Stefan Hajnoczi <stefanha@gmail.com> Signed-off-by: Andrej Krutak <dev@andree.sk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07ALSA: line6: Give up on the lock while URBs are released.Andrej Krutak
commit adc8a43a6d6688272ebffa81789fa857e603dec6 upstream. Done, because line6_stream_stop() locks and calls line6_unlink_audio_urbs(), which in turn invokes audio_out_callback(), which tries to lock 2nd time. Fixes: ============================================= [ INFO: possible recursive locking detected ] 4.4.15+ #15 Not tainted --------------------------------------------- mplayer/3591 is trying to acquire lock: (&(&line6pcm->out.lock)->rlock){-.-...}, at: [<bfa27655>] audio_out_callback+0x70/0x110 [snd_usb_line6] but task is already holding lock: (&(&line6pcm->out.lock)->rlock){-.-...}, at: [<bfa26aad>] line6_stream_stop+0x24/0x5c [snd_usb_line6] other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(&(&line6pcm->out.lock)->rlock); lock(&(&line6pcm->out.lock)->rlock); *** DEADLOCK *** May be due to missing lock nesting notation 3 locks held by mplayer/3591: #0: (snd_pcm_link_rwlock){.-.-..}, at: [<bf8d49a7>] snd_pcm_stream_lock+0x1e/0x40 [snd_pcm] #1: (&(&substream->self_group.lock)->rlock){-.-...}, at: [<bf8d49af>] snd_pcm_stream_lock+0x26/0x40 [snd_pcm] #2: (&(&line6pcm->out.lock)->rlock){-.-...}, at: [<bfa26aad>] line6_stream_stop+0x24/0x5c [snd_usb_line6] stack backtrace: CPU: 0 PID: 3591 Comm: mplayer Not tainted 4.4.15+ #15 Hardware name: Generic AM33XX (Flattened Device Tree) [<c0015d85>] (unwind_backtrace) from [<c001253d>] (show_stack+0x11/0x14) [<c001253d>] (show_stack) from [<c02f1bdf>] (dump_stack+0x8b/0xac) [<c02f1bdf>] (dump_stack) from [<c0076f43>] (__lock_acquire+0xc8b/0x1780) [<c0076f43>] (__lock_acquire) from [<c007810d>] (lock_acquire+0x99/0x1c0) [<c007810d>] (lock_acquire) from [<c06171e7>] (_raw_spin_lock_irqsave+0x3f/0x4c) [<c06171e7>] (_raw_spin_lock_irqsave) from [<bfa27655>] (audio_out_callback+0x70/0x110 [snd_usb_line6]) [<bfa27655>] (audio_out_callback [snd_usb_line6]) from [<c04294db>] (__usb_hcd_giveback_urb+0x53/0xd0) [<c04294db>] (__usb_hcd_giveback_urb) from [<c046388d>] (musb_giveback+0x3d/0x98) [<c046388d>] (musb_giveback) from [<c04647f5>] (musb_urb_dequeue+0x6d/0x114) [<c04647f5>] (musb_urb_dequeue) from [<c042ac11>] (usb_hcd_unlink_urb+0x39/0x98) [<c042ac11>] (usb_hcd_unlink_urb) from [<bfa26a87>] (line6_unlink_audio_urbs+0x6a/0x6c [snd_usb_line6]) [<bfa26a87>] (line6_unlink_audio_urbs [snd_usb_line6]) from [<bfa26acb>] (line6_stream_stop+0x42/0x5c [snd_usb_line6]) [<bfa26acb>] (line6_stream_stop [snd_usb_line6]) from [<bfa26fe7>] (snd_line6_trigger+0xb6/0xf4 [snd_usb_line6]) [<bfa26fe7>] (snd_line6_trigger [snd_usb_line6]) from [<bf8d47b7>] (snd_pcm_do_stop+0x36/0x38 [snd_pcm]) [<bf8d47b7>] (snd_pcm_do_stop [snd_pcm]) from [<bf8d462f>] (snd_pcm_action_single+0x22/0x40 [snd_pcm]) [<bf8d462f>] (snd_pcm_action_single [snd_pcm]) from [<bf8d46f9>] (snd_pcm_action+0xac/0xb0 [snd_pcm]) [<bf8d46f9>] (snd_pcm_action [snd_pcm]) from [<bf8d4b61>] (snd_pcm_drop+0x38/0x64 [snd_pcm]) [<bf8d4b61>] (snd_pcm_drop [snd_pcm]) from [<bf8d6233>] (snd_pcm_common_ioctl1+0x7fe/0xbe8 [snd_pcm]) [<bf8d6233>] (snd_pcm_common_ioctl1 [snd_pcm]) from [<bf8d6779>] (snd_pcm_playback_ioctl1+0x15c/0x51c [snd_pcm]) [<bf8d6779>] (snd_pcm_playback_ioctl1 [snd_pcm]) from [<bf8d6b59>] (snd_pcm_playback_ioctl+0x20/0x28 [snd_pcm]) [<bf8d6b59>] (snd_pcm_playback_ioctl [snd_pcm]) from [<c016714b>] (do_vfs_ioctl+0x3af/0x5c8) Fixes: 63e20df1e5b2 ('ALSA: line6: Reorganize PCM stream handling') Reviewed-by: Stefan Hajnoczi <stefanha@gmail.com> Signed-off-by: Andrej Krutak <dev@andree.sk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07ALSA: line6: Remove double line6_pcm_release() after failed acquire.Andrej Krutak
commit 7e4379eae0e31994ea645db1d13006ea8e5ce539 upstream. If there's an error, pcm is released in line6_pcm_acquire already. Fixes: 247d95ee6dd2 ('ALSA: line6: Handle error from line6_pcm_acquire()') Reviewed-by: Stefan Hajnoczi <stefanha@gmail.com> Signed-off-by: Andrej Krutak <dev@andree.sk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07ALSA: hda - Manage power well properly for resumeTakashi Iwai
commit a52ff34e5ec61749c62c6618b76a9d6dbecee450 upstream. For SKL and later Intel chips, we control the power well per codec basis via link_power callback since the commit [03b135cebc47: ALSA: hda - remove dependency on i915 power well for SKL]. However, there are a few exceptional cases where the gfx registers are accessed from the audio driver: namely the wakeup override bit toggling at (both system and runtime) resume. This seems causing a kernel warning when accessed during the power well down (and likely resulting in the bogus register accesses). This patch puts the proper power up / down sequence around the resume code so that the wakeup bit is fiddled properly while the power is up. (The other callback, sync_audio_rate, is used only in the PCM callback, so it's guaranteed in the power-on.) Also, by this proper power up/down, the instantaneous flip of wakeup bit in the resume callback that was introduced by the commit [033ea349a7cd: ALSA: hda - Fix Skylake codec timeout] becomes superfluous, as snd_hdac_display_power() already does it. So we can clean it up together. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=96214 Fixes: 03b135cebc47 ('ALSA: hda - remove dependency on i915 power well for SKL') Cc: <stable@vger.kernel.org> # v4.2+ Tested-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07ALSA: usb-audio: Add quirk for ELP HD USB CameraVittorio Gambaletta (VittGam)
commit 41f5e3bdbf706a9e98194bf0c4b62a875c02f170 upstream. The ELP HD USB Camera (05a3:9420) needs this quirk for suppressing the unsupported sample rate inquiry. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=98481 Signed-off-by: Vittorio Gambaletta <linuxbugs@vittgam.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07ALSA: usb-audio: Add a sample rate quirk for Creative Live! Cam Socialize HD ↵Piotr Karasinski
(VF0610) commit 7627e40c66b5547e12b6c5673646ceea84797a74 upstream. VF0610 does not support reading the sample rate which leads to many lines of "cannot get freq at ep 0x82". This patch adds the USB ID (0x041E:4080) to snd_usb_get_sample_rate_quirk() list. Signed-off-by: Piotr Karasinski <peter.karasinski@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20ALSA: hda - Fix headset mic detection problem for two dell machinesHui Wang
commit 59ec4b57bcaede46546d54d037a21004b9aa5cef upstream. One of the machines has ALC255 on it, another one has ALC298 on it. On the machine with the codec ALC298, it also has the speaker volume problem, so we add the fixup chained to ALC298_FIXUP_SPK_VOLUME rather than adding a group of pin definition in the pin quirk table, since the speak volume problem does not happen on other machines yet. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20ALSA: hda: add AMD Bonaire AZ PCI ID with proper driver capsMaruthi Srinivas Bayyavarapu
commit fd48331f9b71d2add941adaee3619f5b8527182d upstream. This commit fixes garbled audio on Bonaire HDMI Signed-off-by: Maruthi Bayyavarapu <maruthi.bayyavarapu@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20ALSA: hda/realtek - Can't adjust speaker's volume on a Dell AIOHui Wang
commit dd9aa335c88003d131ac874e7f6809902de0b847 upstream. We have a Dell AIO on which we can't adjust its speaker's volume. The problem is it is connected to a Audio Output node without Amp-out capability. To fix it, we change it to be connnected to a node with Amp-out capability. Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-20ALSA: hda: Fix krealloc() with __GFP_ZERO usageTakashi Iwai
commit 33baefe5e72f17a6df378e48196cd8cada11deec upstream. krealloc() doesn't work always properly with __GFP_ZERO flag as expected. For clearing the reallocated area, we need to clear explicitly instead. Reported-by: Joe Perches <joe@perches.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-08-10ALSA: timer: Fix leak in events via snd_timer_user_tinterruptKangjie Lu
commit e4ec8cc8039a7063e24204299b462bd1383184a5 upstream. The stack object “r1” has a total size of 32 bytes. Its field “event” and “val” both contain 4 bytes padding. These 8 bytes padding bytes are sent to user without being initialized. Signed-off-by: Kangjie Lu <kjlu@gatech.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
