path: root/sound
2015-08-25ALSA: hda - Fix path power activationTakashi Iwai
The widget power-saving code tries to turn up/down the power of each widget in the I/O paths that are modified at each jack plug/unplug. The recent report revealed that the power activation leaves some widgets unpowered after plugging. This is because snd_hda_activate_path() turns on path->active flag at the end of the function while the path power management is done before that. Then it's regarded as if nothing is active, and the driver turns off the power. The fix is simply to set the flag at the beginning of the function, before trying to power up. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102521 Cc: <stable@vger.kernel.org> [v4.1+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-25ALSA: hda - Check all inputs for is_active_nid_for_any()Takashi Iwai
The is_active_nid_for_any() function in the generic parser is supposed to check all connections from/to the given widget, but the current code checks only the first input connection (index = 0). This patch corrects the code to check all inputs by passing -1 to index argument. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102521 Cc: <stable@vger.kernel.org> [v4.1+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-24ALSA: hda: fix possible NULL dereferenceMarkus Osterhoff
After a for-loop was replaced by list_for_each_entry, see Commit bbbc7e8502c9 ("ALSA: hda - Allocate hda_pcm objects dynamically"), Commit 751e2216899c ("ALSA: hda: fix possible null dereference"), a possible NULL pointer dereference has been introduced; this patch adds the NULL check on pcm->pcm, while leaving a potentially superfluous check on pcm itself untouched. Signed-off-by: Markus Osterhoff <linux-kernel@k-raum.org> Cc: <stable@vger.kernel.org> #v4.1+ Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-21ALSA: hda - Shutdown CX20722 on reboot/free to avoid spurious noisesDavid Henningsson
On shutdown/reboot of CX20722, first shut down all EAPDs, then shut down the afg node to D3. Failure to do so can lead to spurious noises from the internal speaker directly after reboot (and before the codec is reinitialized again, i e in BIOS setup or GRUB menus). BugLink: https://bugs.launchpad.net/bugs/1487345 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-21ALSA: usb: Add native DSD support for Gustard DAC-X20UJurgen Kramer
This patch adds native DSD support for the Gustard DAC-X20U. Signed-off-by: Jurgen Kramer <gtmkramer@xs4all.nl> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-19Merge tag 'asoc-v4.2-disable-topology' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Disable topology support for v4.2 The topology code merged in the v4.2 merge window introduced a new ABI which was believed to be suitable for use but subsequently additional work by the developers of this feature have revealed some problems that need to be addressed. In order to allow this to be done without having to support the initial ABI add Kconfig to disable the build and also add some #error statements to the UAPI header so users can't use them.
2015-08-19ALSA: hda - Add dock support for Thinkpad W541 (17aa:2211)Rick Sherman
Tested with W541 and Ultra Dock 170w Signed-off-by: Rick Sherman <rick@shermdog.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-19ALSA: usb-audio: Fix runtime PM unbalanceTakashi Iwai
The fix for deadlock in PM in commit [1ee23fe07ee8: ALSA: usb-audio: Fix deadlocks at resuming] introduced a new check of in_pm flag. However, the brainless patch author evaluated it in a wrong way (logical AND instead of logical OR), thus usb_autopm_get_interface() is wrongly called at probing, leading to unbalance of runtime PM refcount. This patch fixes it by correcting the logic. Reported-by: Hans Yang <hansy@nvidia.com> Fixes: 1ee23fe07ee8 ('ALSA: usb-audio: Fix deadlocks at resuming') Cc: <stable@vger.kernel.org> [v3.15+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-17ASoC: topology: Add Kconfig option for topologyMark Brown
Allow the topology code to be compiled out so that users who don't need topology don't need to havve the code compiled in, saving them some memory. Some more configuration could be added to remove some of the hooks into the core data structures but that is probably best done with some refactoring to use functions to do the updates of the data structures rather than ifdefing in the code as we'd need to do at the minute. Suggested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-13ALSA: hda - Fix the white noise on Dell laptopWoodrow Shen
Dell laptop causes the white noise by login screen and headphone, and the fixup function ALC292_FIXUP_DISABLE_AAMIX can eliminate this noise. Codec: Realtek ALC3235 Vendor Id: 0x10ec0293 Subsystem Id: 0x102806db Cc: <stable@vger.kernel.org> BugLink: https://bugs.launchpad.net/bugs/1484334 Signed-off-by: Woodrow Shen <woodrow.shen@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-07Merge tag 'asoc-fix-v4.2-rc5' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v4.2 There are a couple of small driver specific fixes here but the overwhelming bulk of these changes are fixes to the topology ABI that has been newly introduced in v4.2. Once this makes it into a release we will have to firm this up but for now getting enhancements in before they've made it into a release is the most expedient thing.
2015-08-06Merge remote-tracking branches 'asoc/fix/cs4265', 'asoc/fix/intel' and ↵Mark Brown
'asoc/fix/topology' into asoc-linus
2015-08-06Merge remote-tracking branch 'asoc/fix/rt5645' into asoc-linusMark Brown
2015-08-06ASoC: topology: Update TLV support so we can support more TLV typesMengdong Lin
Currently the TLV topology structure is targeted at only supporting the DB scale data. This patch extends support for the other TLV types so they can be easily added at a later stage. TLV structure is moved to common topology control header since it's a common field for controls and can be processed in a general way. Users must set a proper access flag for a control since it's used to decide if the TLV field is valid and if a TLV callback is needed. Removed the following fields from topology TLV struct: - size/count: type can decide the size. - numid: not needed to initialize TLV for kcontrol. - data: replaced by the type specific struct. Added TLV structure to generic control header and removed TLV structure from mixer control. Signed-off-by: Mengdong Lin <mengdong.lin@intel.com> Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-06Merge tag 'asoc-fix-v4.2-rc3' into asoc-fix-topologyMark Brown
ASoC: Fixes for v4.2 A lot of small fixes here, a few to the core: - Fix for binding DAPM stream widgets on devices with prefixes assigned to them - Minor fixes for the newly added topology interfaces - Locking and memory leak fixes for DAPM - Driver specific fixes
2015-08-06ASoC: topology: Add subsequence in topologySubhransu S. Prusty
Some widgets may need sorting within, So add this support in topology. Signed-off-by: Subhransu S. Prusty <subhransu.s.prusty@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-05ALSA: hda - one Dell machine needs the headphone white noise fixupHui Wang
The fixup ALC292_FIXUP_DISABLE_AAMIX can fix the white noise of the headphone on this Dell machine. Cc: <stable@vger.kernel.org> Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-05ALSA: fireworks/firewire-lib: add support for recent firmware quirkTakashi Sakamoto
Fireworks uses TSB43CB43(IceLynx-Micro) as its IEC 61883-1/6 interface. This chip includes ARM7 core, and loads and runs program. The firmware is stored in on-board memory and loaded every powering-on from it. Echo Audio ships several versions of firmwares for each model. These firmwares have each quirk and the quirk changes a sequence of packets. As long as I investigated, AudioFire2/AudioFire4/AudioFirePre8 have a quirk to transfer a first packet with 0x02 in its dbc field. This causes ALSA Fireworks driver to detect discontinuity. In this case, firmware version 5.7.0, 5.7.3 and 5.8.0 are used. Payload CIP CIP quadlets header1 header2 02 00050002 90ffffff <- 42 0005000a 90013000 42 00050012 90014400 42 0005001a 90015800 02 0005001a 90ffffff 42 00050022 90019000 42 0005002a 9001a400 42 00050032 9001b800 02 00050032 90ffffff 42 0005003a 9001d000 42 00050042 9001e400 42 0005004a 9001f800 02 0005004a 90ffffff (AudioFire2 with firmware version 5.7.) $ dmesg snd-fireworks fw1.0: Detect discontinuity of CIP: 00 02 These models, AudioFire8 (since Jul 2009 ) and Gibson Robot Interface Pack series uses the same ARM binary as their firmware. Thus, this quirk may be observed among them. This commit adds a new member for AMDTP structure. This member represents the value of dbc field in a first AMDTP packet. Drivers can set it with a preferred value according to model's quirk. Tested-by: Johannes Oertei <johannes.oertel@uni-due.de> Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-05Revert "ALSA: fireworks: add support for AudioFire2 quirk"Takashi Sakamoto
This reverts commit 9c6893e0be38b6ca9a56a854226e51dee0a16a5a. The fix is superseded by the next commit as a better implementation for supporting AudioFire2/AudioFire4/AudioFirePre8 quirks. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-04ASoC: topology: fix typo in soc_tplg_kcontrol_bind_io()Mengdong Lin
2015-08-04ALSA: HDA: Dont check return for snd_hdac_chip_readlJeeja KP
The snd_hdac_chip_readl return can never be less than zeros, so no point in checking for the return value This fixes following static checker warnings in snd_hdac_ext_bus_parse_capabilities sound/hda/ext/hdac_ext_controller.c:47 snd_hdac_ext_bus_parse_capabilities() warn: unsigned 'offset' is never less than zero. sound/hda/ext/hdac_ext_controller.c:54 snd_hdac_ext_bus_parse_capabilities() warn: unsigned 'cur_cap' is never less than zero. Signed-off-by: Jeeja KP <jeeja.kp@intel.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-04ALSA: HDA: Fix stream assignment for host in decoupled modeJeeja KP
This fixes issue in assigning host stream in case of decoupled mode. The check to verify if the stream is already in use was wrong so fix that Signed-off-by: Jeeja KP <jeeja.kp@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-08-03ASoC: rt5645: Fix lost pin setting for DMIC1Bard Liao
I2S2_DAC pin can be used for I2S or GPIO. We should set it as GPIO if we use GPIO5 as DMIC1 data pin. Signed-off-by: Bard Liao <bardliao@realtek.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-03ALSA: oxygen: Fix logical-not-parentheses warningTomer Barletz
This fixes the following warning, that is seen with gcc 5.1: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]. Signed-off-by: Tomer Barletz <barletz@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-30ALSA: hda - Fix MacBook Pro 5,2 quirkTakashi Iwai
MacBook Pro 5,2 with ALC889 codec had already a fixup entry, but this seems not working correctly, a fix for pin NID 0x15 is needed in addition. It's equivalent with the fixup for MacBook Air 1,1, so use this instead. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102131 Reported-and-tested-by: Jeffery Miller <jefferym@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-29ALSA: hda - Fix race between PM ops and HDA init/probeU. Artie Eoff
PM ops could be triggered before HDA is done initializing and cause PM to set HDA controller to D3Hot. This can result in "CORB reset timeout#2, CORBRP = 65535" and "no codecs initialized". Additionally, PM ops can be triggered before azx_probe_continue finishes (async probe). This can result in a NULL deref kernel crash. To fix this, avoid PM ops if !chip->running. Signed-off-by: U. Artie Eoff <ullysses.a.eoff@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-29ASoC: Intel: sst_byt: fix initialize 'NULL device *' issueJie Yang
Add initialization for sst_byt.dev at init stage, which fix the 'NULL device *' warning issues. Signed-off-by: Jie Yang <yang.jie@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-07-29ASoC: Intel: haswell: fix initialize 'NULL device *' issueJie Yang
Add initialization for sst_hsw.dev at init stage, which fix the 'NULL device *' warning issues. Signed-off-by: Jie Yang <yang.jie@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-07-29ALSA: usb-audio: add dB range mapping for some devicesYao-Wen Mao
Add the correct dB ranges of Bose Companion 5 and Drangonfly DAC 1.2. Signed-off-by: Yao-Wen Mao <yaowen@google.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-29ALSA: hda - Apply a fixup to Dell Vostro 5480Takashi Iwai
Dell Vostro 5480 (1028:069a) needs the very same quirk used for Vostro 5470 model to make bass speakers properly working. Reported-and-tested-by: Paulo Roberto de Oliveira Castro <p.oliveira.castro@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-27ALSA: hda - Add pin quirk for the headset mic jack detection on Dell laptopWoodrow Shen
The new Dell laptop with codec 256 can't detect headset mic when headset was inserted on the machine. From alsa-info, we check init_pin_configs and need to define the new register value for pin 0x1d & 0x1e because the original macro ALC256_STANDARD_PINS can't match pin definition. Also, the macro ALC256_STANDARD_PINS is simplified by removing them. This makes headset mic works on laptop. Codec: Realtek ALC256 Vendor Id: 0x10ec0256 Subsystem Id: 0x102806f2 BugLink: https://bugs.launchpad.net/bugs/1478497 Signed-off-by: Woodrow Shen <woodrow.shen@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-27ALSA: hda - Apply fixup for another Toshiba Satellite S50DTakashi Iwai
Toshiba Satellite S50D has another model with a different PCI SSID (1179:fa93) while the previous fixup was for 1179:fa91. Adjust the fixup entry with SND_PCI_QUIRK_MASK() to match with both devices. Reported-by: Tim Sample <timsample@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-27ALSA: fireworks: add support for AudioFire2 quirkTakashi Sakamoto
Fireworks uses TSB43CB43(IceLynx-Micro) as its IEC 61883-1/6 interface. This chip includes ARM7 core, and loads and runs program. The firmware is stored in on-board memory and loaded every powering-on. Echo Audio ships several versions of firmwares for each model. These firmwares have each quirk and the quirk changes a sequence of packets. AudioFire2 has a quirk to transfer a first packet with non-zero in its dbc field. This causes ALSA Fireworks driver to detect discontinuity. As long as I investigated, firmware 5.7, 5.7.6 and 5.8 have this quirk. This commit adds a support for the quirk to handle AudioFire2 packets. For safe, CIP_SKIP_INIT_DBC_CHECK is applied to all versions of AudioFire2's firmwares. 02 00050002 90ffffff <- 42 0005000a 90013000 42 00050012 90014400 42 0005001a 90015800 02 0005001a 90ffffff 42 00050022 90019000 42 0005002a 9001a400 42 00050032 9001b800 02 00050032 90ffffff 42 0005003a 9001d000 42 00050042 9001e400 42 0005004a 9001f800 02 0005004a 90ffffff Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-25ALSA: hda - Fix the headset mic that will not work on Dell desktop machineWoodrow Shen
When the headset was plugged in the Dell desktop, the mic of headset can't be detected and workable. According to the alsa-info, we found the differece between alsa and init_pin_configs on the machine, so we need to add the pin configs to make headset work. Codec: Realtek ALC3234 Vendor Id: 0x10ec0255 Subsystem Id: 0x102806bb BugLink: https://bugs.launchpad.net/bugs/1477900 Signed-off-by: Woodrow Shen <woodrow.shen@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-25ALSA: hda - fix cs4210_spdif_automute()Dan Carpenter
Smatch complains that we have nested checks for "spdif_present". It turns out the current behavior isn't correct, we should remove the first check and keep the second. Fixes: 1077a024812d ('ALSA: hda - Use generic parser for Cirrus codec driver') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-24Merge tag 'asoc-fix-v4.2-rc3' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v4.2 A lot of small fixes here, a few to the core: - Fix for binding DAPM stream widgets on devices with prefixes assigned to them - Minor fixes for the newly added topology interfaces - Locking and memory leak fixes for DAPM - Driver specific fixes
2015-07-24ASoC: cs4265: Fix setting dai format for Left/Right JustifiedAxel Lin
The settings in current code does not match the datasheet, fix it. DAC Control - Address 03h DAC Digital Interface Format (Bits 5:4) DAC_DIF1 DAC_DIF0 Description 0 0 Left Justified, up to 24-bit data (default) 0 1 I²S, up to 24-bit data 1 0 Right-Justified, 16-bit Data 1 1 Right-Justified, 24-bit Data Transmitter Control 2 - Address 12h Transmitter Digital Interface Format (Bits 7:6) Tx_DIF1 Tx_DIF0 Description Format Figure 0 0 Left Justified, up to 24-bit data (default) 0 1 I²S, up to 24-bit data 1 0 Right-Justified, 16-bit Data 1 1 Right-Justified, 24-bit Data Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-07-24Merge remote-tracking branches 'asoc/fix/sgtl5000', 'asoc/fix/topology' and ↵Mark Brown
'asoc/fix/zx' into asoc-linus
2015-07-24Merge remote-tracking branches 'asoc/fix/fsl-ssi', 'asoc/fix/intel', ↵Mark Brown
'asoc/fix/intel-kconfig' and 'asoc/fix/mediatek' into asoc-linus
2015-07-24Merge remote-tracking branch 'asoc/fix/ssm4567' into asoc-linusMark Brown
2015-07-24Merge remote-tracking branch 'asoc/fix/rt5645' into asoc-linusMark Brown
2015-07-24Merge remote-tracking branch 'asoc/fix/pcm1681' into asoc-linusMark Brown
2015-07-24Merge remote-tracking branch 'asoc/fix/dapm' into asoc-linusMark Brown
2015-07-24ASoC: pcm1681: Fix setting de-emphasis sampling rate selectionAxel Lin
The de-emphasis sampling rate selection is controlled by BIT[3:4] of PCM1681_DEEMPH_CONTROL register. Do proper left shift to set it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Marek Belisko <marek.belisko@streamunlimited.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2015-07-22ASoC: ssm4567: Keep TDM_BCLKS in ssm4567_set_dai_fmtBen Zhang
The regmap_write in ssm4567_set_dai_fmt accidentally clears the TDM_BCLKS field which was set earlier by ssm4567_set_tdm_slot. This patch fixes it by using regmap_update_bits with proper mask. Signed-off-by: Ben Zhang <benzh@chromium.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Anatol Pomozov <anatol.pomozov@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2015-07-22ASoC: sgtl5000: Fix up define for SGTL5000_SMALL_POPAxel Lin
Currently, below code actually does not update any bit because SGTL5000_SMALL_POP is 0. snd_soc_update_bits(codec, SGTL5000_CHIP_REF_CTRL, SGTL5000_SMALL_POP, 1); The SGTL5000_SMALL_POP should be BIT(0) rather than 0, fix it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-By: Alexander Stein <alexander.stein@systec-electronic.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-07-22ALSA: hda - Add headset mic pin quirk for a Dell deviceDavid Henningsson
Without this patch, the headset mic will not work on this machine. BugLink: https://bugs.launchpad.net/bugs/1476987 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-22ALSA: hda - remove one pin from ALC292_STANDARD_PINSHui Wang
One more Dell laptop with alc293 codec needs ALC293_FIXUP_DELL1_MIC_NO_PRESENCE, but the pin 0x1e does not match the corresponding one in the ALC292_STANDARD_PINS. To use this macro for this machine, we need to remove pin 0x1e from it. BugLink: https://bugs.launchpad.net/bugs/1476888 Cc: <stable@vger.kernel.org> Signed-off-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2015-07-21ASoC: dapm: Don't add prefix to widget stream nameLars-Peter Clausen
Commit fdb6eb0a1287 ("ASoC: dapm: Modify widget stream name according to prefix") fixed the case where a DAPM route between a DAI widget and a DAC/ADC/AIF widget with a matching stream name was not created when the DAPM context was using a prefix. Unfortunately the patch introduced a few issues on its own like leaking the dynamically allocated stream name memory and also not checking whether the allocation succeeded in the first place. It is also incomplete in that it still does not handle the case where stream name of the widget is a substring of the stream name of the DAI, which is explicitly allowed and works fine if no DAPM prefix is used. Revert the commit and take a slightly different approach to solving the issue. Instead of comparing the widget's stream name to the name of the DAI widget compare it to the stream name of the DAI widget. The stream name of the DAI widget is identical to the name of the DAI widget except that it wont have the DAPM prefix added. So this approach behaves identical regardless to whether the DAPM context uses a prefix or not. We don't have to worry about potentially matching with a widget with the same stream name, but from a different DAPM context with a different prefix, since the code already makes sure that both the DAI widget and the matched widget are from the same DAPM context. Fixes: fdb6eb0a1287 ("ASoC: dapm: Modify widget stream name according to prefix") Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2015-07-21ALSA: hda - Add new GPU codec ID 0x10de007d to snd-hdaAaron Plattner
Vendor ID 0x10de007d is used by a yet-to-be-named GPU chip. This chip also has the 2-ch audio swapping bug, so patch_nvhdmi is appropriate here. Signed-off-by: Aaron Plattner <aplattner@nvidia.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
