It's not necessary to free memory allocated with devm_kzalloc
and using kfree leads to a double free.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Acked-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
This function is a bit unusual because it accepts negative values as
"conn_len". It's theoretically possible for both "cache_len" and
"conn_len" to be -ENOSPC and in that case we would oops trying to run
memcmp() on the uninitialized "list" pointer.
In case of error, the function devm_ioremap_resource() returns
ERR_PTR() and never returns NULL. The NULL test in the return
value check should be replaced with IS_ERR().
Reviewed-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
Cc: stable@vger.kernel.org
In case of error, the function devm_kzalloc() returns NULL
not ERR_PTR(). The IS_ERR() test in the return value check
should be replaced with NULL test.
Acked-by: Peter Rosin <peda@axentia.se>
We should check whether platform_get_irq() returns a negative number and
propagate the error in this case.
Merge third patchbomb from Andrew Morton:
- various misc things
- a couple of lib/ optimisations
- provide DIV_ROUND_CLOSEST_ULL()
- checkpatch updates
- rtc tree
- befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs
- ptrace fixes
- fork() fixes
- seccomp cleanups
- more mmap_sem hold time reductions from Davidlohr
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits)
proc: show locks in /proc/pid/fdinfo/X
docs: add missing and new /proc/PID/status file entries, fix typos
drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic
Documentation/spi/spidev_test.c: fix warning
drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type
.gitignore: ignore *.tar
MAINTAINERS: add Mediatek SoC mailing list
tomoyo: reduce mmap_sem hold for mm->exe_file
powerpc/oprofile: reduce mmap_sem hold for exe_file
oprofile: reduce mmap_sem hold for mm->exe_file
mips: ip32: add platform data hooks to use DS1685 driver
lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text
x86: switch to using asm-generic for seccomp.h
sparc: switch to using asm-generic for seccomp.h
powerpc: switch to using asm-generic for seccomp.h
parisc: switch to using asm-generic for seccomp.h
mips: switch to using asm-generic for seccomp.h
microblaze: use asm-generic for seccomp.h
arm: use asm-generic for seccomp.h
seccomp: allow COMPAT sigreturn overrides
Now that the kernel provides DIV_ROUND_CLOSEST_ULL(), drop the internal
implementation and use the kernel one.
Signed-off-by: Javi Merino <javi.merino@arm.com>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Cc: Peter Rosin <peda@axentia.se>
Acked-by: Mark Brown <broonie@kernel.org>
Cc: Liam Girdwood <lgirdwood@gmail.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux
Pull powerpc updates from Michael Ellerman:
- Numerous minor fixes, cleanups etc.
- More EEH work from Gavin to remove its dependency on device_nodes.
- Memory hotplug implemented entirely in the kernel from Nathan
Fontenot.
- Removal of redundant CONFIG_PPC_OF by Kevin Hao.
- Rewrite of VPHN parsing logic & tests from Greg Kurz.
- A fix from Nish Aravamudan to reduce memory usage by clamping
nodes_possible_map.
- Support for pstore on powernv from Hari Bathini.
- Removal of old powerpc specific byte swap routines by David Gibson.
- Fix from Vasant Hegde to prevent the flash driver telling you it was
flashing your firmware when it wasn't.
- Patch from Ben Herrenschmidt to add an OPAL heartbeat driver.
- Fix for an oops causing get/put_cpu_var() imbalance in perf by Jan
Stancek.
- Some fixes for migration from Tyrel Datwyler.
- A new syscall to switch the cpu endian by Michael Ellerman.
- Large series from Wei Yang to implement SRIOV, reviewed and acked by
Bjorn.
- A fix for the OPAL sensor driver from Cédric Le Goater.
- Fixes to get STRICT_MM_TYPECHECKS building again by Michael Ellerman.
- Large series from Daniel Axtens to make our PCI hooks per PHB rather
than per machine.
- Small patch from Sam Bobroff to explicitly abort non-suspended
transactions on syscalls, plus a test to exercise it.
- Numerous reworks and fixes for the 24x7 PMU from Sukadev Bhattiprolu.
- Small patch to enable the hard lockup detector from Anton Blanchard.
- Fix from Dave Olson for missing L2 cache information on some CPUs.
- Some fixes from Michael Ellerman to get Cell machines booting again.
- Freescale updates from Scott: Highlights include BMan device tree
nodes, an MSI erratum workaround, a couple minor performance
improvements, config updates, and misc fixes/cleanup.
* tag 'powerpc-4.1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (196 commits)
powerpc/powermac: Fix build error seen with powermac smp builds
powerpc/pseries: Fix compile of memory hotplug without CONFIG_MEMORY_HOTREMOVE
powerpc: Remove PPC32 code from pseries specific find_and_init_phbs()
powerpc/cell: Fix iommu breakage caused by controller_ops change
powerpc/eeh: Fix crash in eeh_add_device_early() on Cell
powerpc/perf: Cap 64bit userspace backtraces to PERF_MAX_STACK_DEPTH
powerpc/perf/hv-24x7: Fail 24x7 initcall if create_events_from_catalog() fails
powerpc/pseries: Correct memory hotplug locking
powerpc: Fix missing L2 cache size in /sys/devices/system/cpu
powerpc: Add ppc64 hard lockup detector support
oprofile: Disable oprofile NMI timer on ppc64
powerpc/perf/hv-24x7: Add missing put_cpu_var()
powerpc/perf/hv-24x7: Break up single_24x7_request
powerpc/perf/hv-24x7: Define update_event_count()
powerpc/perf/hv-24x7: Whitespace cleanup
powerpc/perf/hv-24x7: Define add_event_to_24x7_request()
powerpc/perf/hv-24x7: Rename hv_24x7_event_update
powerpc/perf/hv-24x7: Move debug prints to separate function
powerpc/perf/hv-24x7: Drop event_24x7_request()
powerpc/perf/hv-24x7: Use pr_devel() to log message
tools/testing/selftests/powerpc/Makefile
tools/testing/selftests/powerpc/tm/Makefile
The commit [a551d91473e5: ALSA: hda - Use regmap for command verb
caches, too] introduced a regression due to a typo in the conversion;
the IEC958 status bits of slave digital devices aren't updated
correctly. This patch corrects it.
Fixes: a551d91473e5 ('ALSA: hda - Use regmap for command verb caches, too')
Reported-and-tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
DEVICE_ALI previously would jump to port_inited after calling
pci_iomap(), bypassing the check for bmaddr being NULL.
Because AZX_DCAPS_PM_RUNTIME is always defined as non-zero, the
initial part of the expression can be skipped.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"There have been major modernization with the standard bus: in ALSA
sequencer core and HD-audio. Also, HD-audio receives the regmap
support replacing the in-house cache register cache code. These
changes shouldn't impact the existing behavior, but rather
refactoring.
In addition, HD-audio got the code split to a core library part and
the "legacy" driver parts. This is a preliminary work for adapting
the upcoming ASoC HD-audio driver, and the whole transition is still
work in progress, likely finished in 4.1.
Along with them, there are many updates in ASoC area as usual, too:
lots of cleanups, Intel code shuffling, etc.
Here are some highlights:
ALSA core:
- PCM: the audio timestamp / wallclock enhancement
- PCM: fixes in DPCM management
- Fixes / cleanups of user-space control element management
- Sequencer: modernization using the standard bus
HD-audio:
- Modernization using the standard bus
- Regmap support
- Use standard runtime PM for codec power saving
- Widget-path based power-saving for IDT, VIA and Realtek codecs
- Reorganized sysfs entries for each codec object
- More Dell headset support
ASoC:
- Move of jack registration to the card level
- Lots of ASoC cleanups, mainly moving things from the CODEC level to
the card level
- Support for DAPM routes specified by both the machine driver and DT
- Continuing improvements to rcar
- pcm512x enhacements
- Intel platforms updates
- rt5670 updates / fixes
- New platforms / devices: some non-DSP Qualcomm platforms, Google's
Storm platform, Maxmim MAX98925 CODECs and the Ingenic JZ4780 SoC
Misc:
- ice1724: Improved ESI W192M support
- emu10k1: Emu 1010 fixes/enhancement"
* tag 'sound-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (411 commits)
ALSA: hda - set GET bit when adding a vendor verb to the codec regmap
ALSA: hda/realtek - Enable the ALC292 dock fixup on the Thinkpad T450
ALSA: hda - Fix another race in runtime PM refcounting
ALSA: hda - Expose codec type sysfs
ALSA: ctl: fix to handle several elements added by one operation for userspace element
ASoC: Intel: fix array_size.cocci warnings
ASoC: n810: Automatically disconnect non-connected pins
ASoC: n810: Consistently pass the card DAPM context to n810_ext_control()
ASoC: davinci-evm: Use card DAPM context to access widgets
ASoC: mop500_ab8500: Use card DAPM context to access widgets
ASoC: wm1133-ev1: Use card DAPM context to access widgets
ASoC: atmel: Improve machine driver compile test coverage
ASoC: atmel: Add dependency to SND_SOC_I2C_AND_SPI where necessary
ALSA: control: Fix a typo of SNDRV_CTL_ELEM_ACCESS_TLV_* with SNDRV_CTL_TLV_OP_*
ALSA: usb-audio: Don't attempt to get Microsoft Lifecam Cinema sample rate
ASoC: rnsd: fix build regression without CONFIG_OF
ALSA: emu10k1: add toggles for E-mu 1010 optical ports
ALSA: ctl: fill identical information to return value when adding userspace elements
ALSA: ctl: fix a bug to return no identical information in info operation for userspace controls
ALSA: ctl: confirm to return all identical information in 'activate' event
Pull second vfs update from Al Viro:
"Now that net-next went in... Here's the next big chunk - killing
->aio_read() and ->aio_write().
There'll be one more pile today (direct_IO changes and
generic_write_checks() cleanups/fixes), but I'd prefer to keep that
one separate"
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (37 commits)
->aio_read and ->aio_write removed
pcm: another weird API abuse
infinibad: weird APIs switched to ->write_iter()
kill do_sync_read/do_sync_write
fuse: use iov_iter_get_pages() for non-splice path
fuse: switch to ->read_iter/->write_iter
switch drivers/char/mem.c to ->read_iter/->write_iter
make new_sync_{read,write}() static
coredump: accept any write method
switch /dev/loop to vfs_iter_write()
serial2002: switch to __vfs_read/__vfs_write
ashmem: use __vfs_read()
export __vfs_read()
autofs: switch to __vfs_write()
new helper: __vfs_write()
switch hugetlbfs to ->read_iter()
coda: switch to ->read_iter/->write_iter
ncpfs: switch to ->read_iter/->write_iter
net/9p: remove (now-)unused helpers
p9_client_attach(): set fid->uid correctly
kbuild robot reports following warning:
"sound/soc/intel/haswell/sst-haswell-ipc.c:2204:1-6:
WARNING: invalid free of devm_ allocated data"
As julia explains to me, the memory allocated with devm_kalloc
is freed automatically on failure of a probe function. So this
kfree should be removed otherwise the double free will be got in
error handler path.
Signed-off-by: Jin Yao <yao.jin@linux.intel.com>
rsnd_dmaen_quit() is assuming dmaen->chan is NULL if it failed
to get DMAEngine channel. but, current dmaen->chan might have
error value when error case (this driver is checking it by IS_ERR_OR_NULL())
This patch makes sure dmaen->chan is NULL when error case.
Otherwise, it will contact to unknown address in rsnd_dmaen_quit()
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Fix a compile warning
sound/soc/qcom/lpass-cpu.c: In function ‘lpass_cpu_daiops_trigger’:
sound/soc/qcom/lpass-cpu.c:224:2: warning: ‘ret’ may be used uninitialized in this function [-Wmaybe-uninitialized]
return ret;
Although switch () lists the most of existing cases, it's still better
to cover the rest as an error properly.
Acked-by: Kenneth Westfield <kwestfie@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Changes to existing drivers:
- Rename child driver [axp288_battery => axp288_fuel_gauge]; axp20x
- Rename child driver [max77693-flash => max77693-led]; max77693
- Error handling fixes; intel_soc_pmic
- GPIO tweaking; intel_soc_pmic
- Remove non-DT code; vexpress-sysreg, tc3589x
- Remove unused/legacy code; ti_am335x_tscadc, rts5249, rtsx_gops, rtsx_pcr,
rtc-s5m, sec-core, max77693, menelaus,
wm5102-tables
- Trivial fixups; rtsx_pci, da9150-core, sec-core, max7769, max77693,
mc13xxx-core, dln2, hi6421-pmic-core, rk808, twl4030-power,
lpc_ich, menelaus, twl6040
- Update register/address values; rts5227, rts5249
- DT and/or binding document fixups; arizona, da9150, mt6397, axp20x,
qcom-rpm, qcom-spmi-pmic
- Couple of trivial core Kconfig fixups
- Remove use of seq_printf return value; ab8500-debugfs
- Remove __exit markups; menelaus, tps65010
- Fix platform-device name collisions; mfd-core
New drivers/supported devices:
- Add support for wm8280/wm8281 into arizona
- Add support for COMe-cBL6 into kempld-core
- Add support for rts524a and rts525a into rts5249
- Add support for ipq8064 into qcom_rpm
- Add support for extcon into axp20x
- New MediaTek MT6397 PMIC driver
- New Maxim MAX77843 PMIC dirver
- New Intel Quark X1000 I2C-GPIO driver
- New Skyworks SKY81452 driver"
* tag 'mfd-for-linus-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (76 commits)
mfd: sec: Fix RTC alarm interrupt number on S2MPS11
mfd: wm5102: Remove registers for output 3R from readable list
mfd: tps65010: Remove incorrect __exit markups
mfd: devicetree: bindings: Add Qualcomm RPM regulator subnodes
mfd: axp20x: Add support for extcon cell
mfd: lpc_ich: Sort IDs
mfd: twl6040: Remove wrong and unneeded "platform:twl6040" modalias
mfd: qcom-spmi-pmic: Add specific compatible strings for Qualcomm's SPMI PMIC's
mfd: axp20x: Fix duplicate const for model names
mfd: menelaus: Use macro for magic number
mfd: menelaus: Drop support for SW controller VCORE
mfd: menelaus: Delete omap_has_menelaus
mfd: arizona: Correct type of gpio_defaults
mfd: Fix a typo in Kconfig
mfd: qcom_rpm: Add support for IPQ8064
mfd: devicetree: qcom_rpm: Document IPQ8064 resources
mfd: core: Fix platform-device name collisions
mfd: intel_quark_i2c_gpio: Don't crash if !DMI
dt-bindings: Add vendor-prefix for X-Powers
Pull vfs update from Al Viro:
"Part one:
- struct filename-related cleanups
- saner iov_iter_init() replacements (and switching the syscalls to
use of those)
- ntfs switch to ->write_iter() (Anton)
- aio cleanups and splitting iocb into common and async parts
(Christoph)
- assorted fixes (me, bfields, Andrew Elble)
There's a lot more, including the completion of switchover to
->{read,write}_iter(), d_inode/d_backing_inode annotations, f_flags
race fixes, etc, but that goes after #for-davem merge. David has
pulled it, and once it's in I'll send the next vfs pull request"
* 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (35 commits)
sg_start_req(): use import_iovec()
sg_start_req(): make sure that there's not too many elements in iovec
blk_rq_map_user(): use import_single_range()
sg_io(): use import_iovec()
process_vm_access: switch to {compat_,}import_iovec()
switch keyctl_instantiate_key_common() to iov_iter
switch {compat_,}do_readv_writev() to {compat_,}import_iovec()
aio_setup_vectored_rw(): switch to {compat_,}import_iovec()
vmsplice_to_user(): switch to import_iovec()
kill aio_setup_single_vector()
aio: simplify arguments of aio_setup_..._rw()
aio: lift iov_iter_init() into aio_setup_..._rw()
lift iov_iter into {compat_,}do_readv_writev()
NFS: fix BUG() crash in notify_change() with patch to chown_common()
dcache: return -ESTALE not -EBUSY on distributed fs race
NTFS: Version 2.1.32 - Update file write from aio_write to write_iter.
VFS: Add iov_iter_fault_in_multipages_readable()
drop bogus check in file_open_root()
switch security_inode_getattr() to struct path *
constify tomoyo_realpath_from_path()
Pull trivial tree from Jiri Kosina:
"Usual trivial tree updates. Nothing outstanding -- mostly printk()
and comment fixes and unused identifier removals"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
goldfish: goldfish_tty_probe() is not using 'i' any more
powerpc: Fix comment in smu.h
qla2xxx: Fix printks in ql_log message
lib: correct link to the original source for div64_u64
si2168, tda10071, m88ds3103: Fix firmware wording
usb: storage: Fix printk in isd200_log_config()
qla2xxx: Fix printk in qla25xx_setup_mode
init/main: fix reset_device comment
ipwireless: missing assignment
goldfish: remove unreachable line of code
coredump: Fix do_coredump() comment
stacktrace.h: remove duplicate declaration task_struct
smpboot.h: Remove unused function prototype
treewide: Fix typo in printk messages
mod_devicetable: fix comment for match_flags
Some HD-A codecs may add their own vendor 'set' verb to the regmap, thru func
snd_hdac_add_vendor_verb(). This patch sets the GET bit (bit 11) when adding
the verb so that its peer vendor 'get' verb is actually added. This can avoid
I/O error when writing the 'set' verb thru remap, since HD-A regmap internally
looks up a writable vendor verb with GET bit set at first.
Signed-off-by: Mengdong Lin <mengdong.lin@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Updates for v4.1
More updates for v4.1, pretty much all drivers:
- Lots of cleanups from Lars, mainly moving things from the CODEC level
to the card level.
- Continuing improvements to rcar from Morimoto-san, pcm512x from
Howard and Peter, the Intel platforms from Vinod, Jie, Jin and Han,
and to rt5670 from Bard.
- Support for some non-DSP Qualcomm platforms, Google's Storm
platform, Maxmim MAX98925 CODECs and the Ingenic JZ4780 SoC.
The Lenovo Thinkpad T450 requires the ALC292_FIXUP_TPT440_DOCK as well in
order to get working sound output on the docking stations headphone jack.
Patch tested on a Thinkpad T450 (20BVCTO1WW) using kernel 4.0-rc7 in
conjunction with a ThinkPad Ultradock.
Signed-off-by: Jo-Philipp Wich <jow@openwrt.org>
Cc: <stable@vger.kernel.org>
Although some races in runtime PM refcount was fixed by the commit
[664c715573c2: ALSA: hda - Work around races of power up/down with
runtime PM], there is still a race in the following case:
CPU0: CPU1 :
runtime suspend:
codec->in_pm = 1
snd_hdac_power_up_pm():
pm_runtime_get_sync() skipped
suspend finished:
codec->in_pm = 0
snd_hdac_power_down_pm():
pm_runtime_put_*() is called!
For avoiding this situation, increment in_pm flag atomically when it's
non-zero, and decrement accordingly, to ensure that in_pm is set
consistently for the whole concurrent operations.
Also, since atomic_inc_not_zero() and atomic_dec_if_positive() are
lengthy inline functions, move snd_hdac_power_up_pm() and _down_pm()
to sound/hda/hdac_device.c as no inline functions.
The type field of HD-audio codec object should be exposed to
user-space so that it can identify which driver type to bind (legacy /
asoc).
userspace element
An element instance can have several elements with the same feature.
Some userspace applications can add such an element instance by add
operation with the number of elements. Then, the element instance
gets a memory object to keep states of these elements.
But the element instance has just one memory object for the elements.
This causes the same result to each read/write operations to the
different elements.
This commit fixes this bug by allocating enough memory objects to the
element instance for each of elements.
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
'asoc/topic/wm8731', 'asoc/topic/wm8804' and 'asoc/topic/wm8996' into asoc-next
and 'asoc/topic/ux500' into asoc-next
'asoc/topic/sh-cleanup' into asoc-next
'asoc/topic/rcar' and 'asoc/topic/rt286' into asoc-next
'asoc/topic/max98090', 'asoc/topic/max98925' and 'asoc/topic/nuc900' into asoc-next
'asoc/topic/kirkwood' into asoc-next
'asoc/topic/fsl' and 'asoc/topic/fsl-ssi' into asoc-next
into asoc-next
'asoc/topic/ak4642', 'asoc/topic/arizona' and 'asoc/topic/atmel' into asoc-next
ASoC: Changes for v4.1
A selection of changes for v4.1 so far. The main things are:
- Move of jack registration to the card where it belongs.
- Support for DAPM routes specified by both the machine driver and DT.
# gpg: Signature made Thu 05 Mar 2015 01:10:27 GMT using RSA key ID 5D5487D0
# gpg: WARNING: digest algorithm MD5 is deprecated
# gpg: please see https://gnupg.org/faq/weak-digest-algos.html for more information
# gpg: Oops: keyid_from_fingerprint: no pubkey
# gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>"
# gpg: aka "Mark Brown <broonie@debian.org>"
# gpg: aka "Mark Brown <broonie@kernel.org>"
# gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>"
# gpg: aka "Mark Brown <broonie@linaro.org>"
# gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
'asoc/fix/cs4271', 'asoc/fix/davinci' and 'asoc/fix/rcar' into asoc-linus
ASoC: Last minute fix for v4.0
This patch backs out a change that came in during the merge window which
selects a configuration for GPIO4 on pcm512x CODECs that may not be
suitable for all systems using the device. Changes for v4.1 will make
this properly configurable but for now it's safest to revert to the
v3.19 behaviour and leave the pin configuration alone.
Sorry for sending this direct at the last minute but due to the GPIO
misuse it'd be really good to get it in the release and I'd not realised
it hadn't been sent yet - between some travel, a job change and other
non-urgent fixes coming in I'd lost track of the urgency. It's been in
-next for several weeks now, is isolated to the driver and fairly clear
to inspection.
# gpg: Signature made Sat 11 Apr 2015 22:14:17 BST using RSA key ID 5D5487D0
sound/soc/intel/haswell/sst-haswell-ipc.c:646:28-29: WARNING: Use ARRAY_SIZE
Use ARRAY_SIZE instead of dividing sizeof array with sizeof an element
Semantic patch information:
This makes an effort to find cases where ARRAY_SIZE can be used such as
where there is a division of sizeof the array by the sizeof its first
element or by any indexed element or the element type. It replaces the
division of the two sizeofs by ARRAY_SIZE.
Generated by: scripts/coccinelle/misc/array_size.cocci
CC: Jie Yang <yang.jie@intel.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
All CODEC input and output widgets are either in the DAPM routing table or
manually marked as non-connected. This means the card is fully routed and we
can let the core take care of disconnecting non-connected pins.
Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Some callers of n810_ext_control() pass the card DAPM context and some pass
the CODEC DAPM context. Given that some of the widgets that are accessed in
the function are in the card's context, always passing it is the obvious
choice.
The dapm field of the snd_soc_codec struct will eventually be removed
(replaced with the DAPM context from the component embedded inside the
CODEC). Replace its usage with the card's DAPM context. The idea is that
DAPM is hierarchical and with the card at the root it is possible to access
widgets from other contexts through the card context.
