commit 82e68f7ffec3800425f2391c8c86277606860442 upstream
snd_seq_oss_synth_make_info() incorrectly reports information
to userspace without first checking for the validity of the
device number, leading to possible information leak (CVE-2008-3272).
Reported-By: Tobias Klein <tk@trapkit.de>
Acked-and-tested-by: Takashi Iwai <tiwai@suse.de>
Cc: stable@kernel.org
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit d2cd74b158d7214a556226e3312f9fb1de64d7ae upstream
On Audigy2 Platinum, the Analog/Digital mixer switch is inverted.
https://bugzilla.novell.com/show_bug.cgi?id=396204
The patch adds a simple workaround.
There might be another device requiring a similar fix, too (or fix for
audigy2 generically), but right now I fix only the known broken one.
commit 470eaf6be78424fc499a5039e5d5fe58bace2bc3 upstream
Added the missing SSID of Thinkpad Z60m for model=thinkpad with
AD1981HD.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit 9ad593f6d326e7a4664e3856520f6c042f82a37f upstream
Many HD-audio controllers seem inaccurate about the IRQ timing of
PCM period updates. This has caused problems on audio quality; e.g.
JACK doesn't work with two periods.
This patch fixes the problem by checking the current DMA position
at IRQ handler and delays the period-update via a workq if it's
inaccurate.
commit 43785eaeb1cfb8aed3cf8027f298b242f88fdc45 upstream
Don't create mixer volume elements for Headphone and Speaker if they
use the same DAC as normal line-outs on AD1988. Otherwise the amp
value gets screwed up, e.g.
https://bugzilla.novell.com/show_bug.cgi?id=398255
Commit 981bcead3f2279a1ec6fb5f2c57aff79ed61a700 upstream.
Stop the S/PDIF DMA engine and output when the device is told to pause.
It will keep on looping the current buffer contents if this isn't done.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
Tested-by: Rene Herman <rene.herman@gmail.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
snd_assert() in save_mixer() and restore_mixer() in sb_mixer.c is
just wrong. The debug code wasn't tested at all, obviously...
The irq handler may be called before the proper initialization of hardware.
Call snd_aw2_saa7146_setup() before the irq handler registration.
Check that model->control_filter is set before trying to call it.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
I think that hda_verb array must have "terminator (empty array)".
But alc262_sony_unsol[] does not have it.
And it causes gcc-4.3's buggy behavior
with snd_hda_sequence_write().
Signed-off-by: Akio Idehara <zbe64533@gmail.com>
When the Linux kernel is compiled with CONFIG_DEBUG_SHIRQ=y,
the Soundblaster Audigy2 ZS Notebook PCMCIA card causes the
system hang during boot (udev stage) or when the card is hot-plug.
The CONFIG_DEBUG_SHIRQ flag is by default 'y' with all Fedora
kernels since 2.6.23. The problem was reported as
https://bugzilla.redhat.com/show_bug.cgi?id=326411
The issue was hunted down to the snd_emu10k1_create() routine:
/* pseudo-code */
snd_emu10k1_create(...) {
request_irq(... IRQF_SHARED ...) {
register the irq handler
#ifdef CONFIG_DEBUG_SHIRQ
call the irq handler: snd_emu10k1_interrupt() {
poll I/O port // <---- !! system hangs
#endif
snd_emu10k1_cardbus_init(...) {
initialize I/O ports
The early access to I/O port in the interrupt handler causes
the freeze. Obviously it is necessary to init the I/O ports
before accessing them. This patch moves the registration of
the irq handler after the initialization of the I/O ports.
Signed-off-by: Jaroslav Franek <jarin.franek@post.cz>
Acked-by: James Courtier-Dutton <James@superbug.co.uk>
Use quirk table to assign ALC268_TOSHIBA to COMPAL IFL90/JFL-92 laptops.
No analog output on autoprobe.
Signed-off-by: Tony Vroon <tony@linx.net>
Tested-by: Guri <gurashka@gmail.com>
The auto-config mode of Realtek ALC codecs has a bug since 2.6.25
that it cannot resume properly. The problem was the wrong assignment
of init_hook that overrides the whole initialization.
Relevant bug reports:
http://bugzilla.kernel.org/show_bug.cgi?id=10662
https://bugzilla.novell.com/show_bug.cgi?id=385473
Set the proper model for LG LS75 with CM9880 codec.
See ALSA bug#2105:
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=2105
The mic pins are wrongly assigned on AD1884A mobile model.
The mic handling is fixed for the automatic mic selection, too.
ASUS A9T laptop uses line-out pin as the real front-output while
other devices use it as the surround.
Fix capture mute widget for STAC9250/9251 codecs. The widget 0x09
has no mute but 0x14 does actually.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
This solves the problem with mixers wrongly displaying the PWM freq.
Signed-off-by: Stas Sergeev <stsp@aknet.ru>
Added IDs for the Foxconn P35AX-S mainboard to patch_realtek.c, so
that ALC883_6ST_DIG is used by default.
Signed-off-by: Travis Place <wishie@wishie.net>
Fix the missing COEF and EAPD initialization in ALC889 auto-configuration
mode.
We get quite noisy output on the right channel on VT1708 codec
when 24bit samples are used. Suppress the 24bit support until any
real fix is found.
https://bugzilla.novell.com/show_bug.cgi?id=390473
Added a config table entry for the ASUS P5K-E/WIFI-AP mainboard (ID
1043:8227) to use AD1988_6STACK_DIG
There is a race from when a device is created with device_create() and
then the drvdata is set with a call to dev_set_drvdata() in which a
sysfs file could be open, yet the drvdata will be NULL, causing all
sorts of bad things to happen.
This patch fixes the problem by using the new function,
device_create_drvdata().
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Jaroslav Kysela <perex@perex.cz>
Corrected the model assignment for the ASUS P5GD1 w/SPDIF after reports of
surround sound not being possible.
Fixed the speaker auto-mute with two laptop and docking headphones.
Acked-by: Tony Vroon <tony@linx.net>
Change HRTIMER_CB_IRQSAFE to HRTIMER_CB_SOFTIRQ,
as suggested by Thomas Gleixner.
That solves the lock dependancy reported in
Bug #10701.
That also allows to call hrtimer_start()
directly, tasklet "stupid hack" removed.
It appears that alsa allows a sound buffer with size not
evenly devided by the period size. This triggers a warning in
snd-pcsp and floods the log. As a quick fix, the warning should
be disabled.
Considering all the feedbacks I got, depending snd-pcsp on
CONFIG_EXPERIMENTAL looks like the only safe way to get out
of all the troubles at one go. :)
The attached patch adds back the compatibility code, allowing the
driver to work with older alsa-libs.
The removal was premature, it breaks the real-life configs.
Added the warning text to the help of snd-pcsp about the possible problem
with this driver so that user can know of the problem in advance.
Also, removed the obsoleted text about ancient pc-speaker patch in
CONFIG_SOUND help.
Fix this typo and avoid similar errors by using ARRAY_SIZE macro.
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com>
There is no endpoint called MONOLOUT but MONO_LOUT.
This patch fixes following bug caught with PREEMPT enabled:
root@b1:~# cat /dev/dsp > /dev/null
BUG: scheduling while atomic: cat/965/0x00000003
Call Trace:
[df165ce0] [c0008e84] show_stack+0x4c/0x1ac (unreliable)
[df165d20] [c001c18c] __schedule_bug+0x64/0x78
[df165d30] [c02b3344] schedule+0x2d8/0x334
[df165d70] [c02b3674] schedule_timeout+0x64/0xe4
[df165db0] [c002c05c] msleep+0x1c/0x34
[df165dc0] [c01f2fe0] fsl_ssi_trigger+0x130/0x144
[df165dd0] [c01ece54] soc_pcm_trigger+0x94/0xb8
[df165df0] [c01da764] snd_pcm_do_start+0x48/0x60
[df165e00] [c01da630] snd_pcm_action_single+0x4c/0xb4
[df165e20] [c01e0f50] snd_pcm_lib_read1+0x2a0/0x2d4
[df165e70] [c01ec274] snd_pcm_oss_read3+0xf0/0x13c
[df165eb0] [c01ec2e4] snd_pcm_oss_read2+0x24/0x4c
[df165ec0] [c01ec4ac] snd_pcm_oss_read+0x1a0/0x1f0
[df165ef0] [c0076478] vfs_read+0xb4/0x108
[df165f10] [c00768cc] sys_read+0x4c/0x90
[df165f40] [c00117a4] ret_from_syscall+0x0/0x38
Acked-by: Timur Tabi <timur@freescale.com>
When the hardware wavetable synthesizer of an Creative SB Audigy or SB
Live! card (with emu10k chip) receives the MIDI SOFT_PEADAL-press event
(?? 67 127) the appropriate voice is attenuted. Unfortunately when the
pedal is released (event ?? 67 0) the voice does not get it's original
volume again.
Boolean MIDI controls should interpret 0..63 as false and 64..127 as true.
Thanks to Clemens Ladisch for review and correction.
Original patch from "Uwe Kraeger" <uwe_debbug@arcor.de>
Submitted to http://bugs.debian.org/474312
Signed-off-by: maximilian attems <max@stro.at>
Cc: uwe_debbug@arcor.de
Cc: Clemens Ladisch <clemens@ladisch.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
[ALSA] soc at91 minor bug fixes
[ALSA] soc - at91-pcm - Fix line wrapping
pcspkr: fix dependancies
drivers/md/raid10.c:889:17: warning: Using plain integer as NULL pointer
drivers/media/video/cx18/cx18-driver.c:616:12: warning: Using plain integer as NULL pointer
sound/oss/kahlua.c:70:12: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Found these two bugs while browsing through the code. The first one is
a cut-n-paste bug, instead of disabling the clock when request_irq()
fails, it enabled it once more. The second one fixes a debug printout,
AT91_SSC_IER is write only, AT91_SSC_IMR is readable (the printed string
actually says imr).
Frank Mandarino was busy so he asked me to send these to this list.
/Patrik
Signed-off-by: Patrik Sevallius <patrik.sevallius@enea.com>
Acked-by: Frank Mandarino <fmandarino@endrelia.com>
There's more checkpatch stuff to fix in the driver, this just fixes the
minimum required for the following patch to be clean.
fix pcspkr dependancies: make the pcspkr platform
drivers to depend on a platform device, and
not the other way around.
Acked-by: Dmitry Torokhov <dtor@mail.ru>
CC: Vojtech Pavlik <vojtech@suse.cz>
CC: Michael Opdenacker <michael-lists@free-electrons.com>
[fixed for 2.6.26-rc1 by tiwai]
S3C2410 i2s driver currently manages only i2s protocol (and not left
justified one) and slave mode.
With this small patch, other modes are possible.
Signed-off-by: Davide Rizzo <davide@elpa.it>
Acked-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
S3C2410 pcm doesn't work.
s3c2410_dma_request() now returns the channel number and not 0 if OK.
On boards with VT1617A codec, the sound disappears suddenly.
This looks like a problem with HPE-bit control that is supposed to be
set in patch_vt1617a(). However, on such problematic hardwares, the
bit is actually reset mysteriously.
The patch adds a workaround for the wrong quirk.
alc861_auto_set_output_and_unmute()
Change done by:
commit f6c7e5461e9046445d50c5c7a9a4587824239623
[ALSA] hda-codec - Fix auto-configuration of Realtek codecs
broke sound on ALC861 Analog.
Signed-off-by: Jacek Luczak <luczak.jacek@gmail.com>
FM801-tea575x tuner has a reverse selection to V4L1 and this causes
nasty dependency problems.
The patch simplifies the dependency with a normal
"depends on VIDEO_V4L1". This decreases the usability but fixes bugs,
yeah. If any better feature like "requires" is introduced to kbuild
in future, we'll be able to switch it...
Added the support for IDT 92HD206 codec chip.
It's compatible with STAC927x.
sound/drivers/pcsp/pcsp.c: In function 'pcsp_suspend':
sound/drivers/pcsp/pcsp.c:201: error: implicit declaration of function 'snd_pcm_suspend_all'
Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net>
CC: Stas Sergeev <stsp@aknet.ru>
Patch taken from the openmoko bugtracker
http://bugzilla.openmoko.org/cgi-bin/bugzilla/show_bug.cgi?id=781
This patch adds Suspend/Resume and Shutdown support for the lm4857 to
the driver.
Signed-off-by: Graeme Gregory <graeme@openmoko.org>
I have moved workplaces since I originally wrote this driver so update
the contact info for new employers.
