Bug 1034241
Change-Id: I205a74a8f27237470a3cd1266bb925971654459c
Signed-off-by: Manoj Gangwal <mgangwal@nvidia.com>
Reviewed-on: http://git-master/r/125280
Reviewed-by: Simone Willett <swillett@nvidia.com>
Bug 1034241
Change-Id: Id0037f18afa58be82cbeeb43e97b606614fb8ba8
Reviewed-on: http://git-master/r/125273
GVS: Gerrit_Virtual_Submit
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Add support for latest TI codec aic326x driver.
Bug 1034241
Change-Id: I387693ed2de466d1704c6f7ff0a1b15c7cbff32f
Reviewed-on: http://git-master/r/125180
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Add latest TI aic326x driver.
Bug 1034241
Change-Id: I8457538025b2989c4baa5eaefef48bdd5535def9
Reviewed-on: http://git-master/r/125167
change 8843c49092b6ed903e88eded1f1c9b9a7f432dfe introduced
a compliation error if CONFIG_SWITCH is not enabled.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Change-Id: I4b4c547394f424bd90837726b08d9feccd4207de
Reviewed-on: http://git-master/r/120444
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
change 4b70cc537cadc787b748c7c246d703a240b08985 introduced
a compilation error.
Change-Id: I59e54537d9bb4b30e807478e5b7634db0813a739
Reviewed-on: http://git-master/r/120443
Reviewed-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com>
98088 codec register value is altered to fix no audio issue after
reset. Previously after reset the register value was getting wiped
out.
Bug 1017782
Change-Id: I060929bfb868c48dc4db9def171a3bdd167a3913
Reviewed-on: http://git-master/r/120319
Tested-by: Sayak Choudhury <sayakc@nvidia.com>
Reviewed-by: Vijay Mali <vmali@nvidia.com>
add alsa ctl to query maximum supported
channels
Bug: 998697
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Change-Id: Id2f0e6a62d2413615f13a0c18757c05610ef0c2c
Reviewed-on: http://git-master/r/118602
audio_clock_2x parent needs to be set first before
changing the rate, else it will not work.
Bug 1019017
Signed-off-by: Nitin Pai <npai@nvidia.com>
Reviewed-on: http://git-master/r/116682
(cherry picked from commit fdc4da6d96e7be4aa2accf098de48543e745cf11)
Change-Id: I93aeb1afed8732e8a1b1cff4ab03b9a9f654804f
Reviewed-on: http://git-master/r/118250
Reviewed-by: Bob Johnston <bjohnston@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
regsiter android switch device which is used to convey device plug-in
and plug-out to userspace.
Bugs 1009921, 1019877
Change-Id: I8e3c2fce420cc0ce094a6d8f2cf00abb630fcf2f
Reviewed-on: http://git-master/r/119033
Tested-by: Ravindra Lokhande <rlokhande@nvidia.com>
Add master/slave configurability support interface for
all codecs. Currently, complete slave mode functionality
is added only for MAX98088 and WM8903 codec only. By
default, board parameters will set i2s master mode for
all codecs.
asoc: tegra: utils: add support for i2s master/slave mode.
Support for i2s in master or slave mode is made generic by
obtaining information from platform data.
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Change-Id: Ided0fcefb6cdb124b78aab423bfd8c7dccd4bf6e
Reviewed-on: http://git-master/r/111553
(cherry picked from commit bb1ad7222f9c75424a45976d16de418bc927dc04)
asoc: tegra: wm8903 machine: add support for i2s in slave mode.
Add support for i2s as slave for playback and capture use cases.
Change-Id: I1f6b73a0a1b690ecd311b0ff4107aadbb1f037d8
Reviewed-on: http://git-master/r/111472
(cherry picked from commit 0434f8ba74adefe60597d95d30a455b9b2ece9b8)
asoc: tegra: wm8753 machine: add support for i2s in slave mode.
Change-Id: Ib0596955cd0c6ac5ec57b0f3c6ecc9e4ed41268c
Reviewed-on: http://git-master/r/113208
(cherry picked from commit 0fc6b5e3a98d9f8866f73d7914b0c590334ce862)
asoc: tegra: aic326x machine: add support for i2s in slave mode.
Support for i2s in slave mode is added for playabck and capture
use cases.
Change-Id: I41f6459765f075703ad7f5f8dc9d4628dd853820
Reviewed-on: http://git-master/r/112874
(cherry picked from commit 9a89ede36a1dca6f53250444e819443fb6f28d09)
asoc: tegra: rt5640 machine: add support for i2s in slave mode.
Change-Id: I850ec62149b8a8d244445b70658b632dbce06558
Reviewed-on: http://git-master/r/112878
(cherry picked from commit 1d51561c8edf47d8557a825450a48ee8743a185b)
asoc: tegra: max98088 machine: add support for codec i2s as slave.
Add support for codec i2s as slave during voice Call.
(Bug 998682)
Change-Id: I8fc54d367e9acd5417d270869cb5a9398b3b527f
Reviewed-on: http://git-master/r/110559
(cherry picked from commit 78a490867e131b1cc892094ddd844c2b892cafb6)
asoc: tegra: max98095 machine: add support for i2s in slave mode.
Change-Id: I80944d403be94c55ad2ce31aea921d80ea7c088a
Reviewed-on: http://git-master/r/112875
Reviewed-on: http://git-master/r/118080
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Renamed P1852 machine driver to VCM so that can be used
for P1852/P852 and E1853 as well.
Bug 1008391
Reviewed-on: http://git-master/r/113886
(cherry picked from commit 5eb23e30bab716b28146b85438989e58761c7136)
Change-Id: I8d1363a6419c6381b8d23ebd38d625fb482084dc
Reviewed-on: http://git-master/r/116056
Add code for headset detection according to that
state transitions mentioned for JKSNS field in the
max98088 codec datasheet
Bug: 110529
Bug: 1008246
Reviewed-on: http://git-master/r/112127
(cherry picked from commit 12a2259e0e9cf7da4bf64bad2a97c32cec41477c)
Change-Id: I7d45b210dd02f181e71a08d9b3de7cff109dd88b
Reviewed-on: http://git-master/r/114445
Tested-by: Nikesh Oswal <noswal@nvidia.com>
Change HW disabling dequence and I2S clock parent in slave mode
for voice call use-case
Bug: 1005176
Reviewed-on: http://git-master/r/110529
(cherry picked from commit 4b138cdeb3374575bde9f49d0c644faa91ced68f)
Change-Id: Ia037ed5ef45d38972c3e1e1a78b4b7b7f39d8f72
Reviewed-on: http://git-master/r/114444
Several compilation errors popped up when building the 3.1 kernel for
chrome. Warnings included callback structure changing and not being
updated in the max98095 codec driver and unused labels.
With these change I am able to compile in the max98095 codec support
and wm8903 without build errors.
Bug 986933
Change-Id: Ia8b2511f54b031eadcad8c74efa88be9288f25fb
Reviewed-on: http://git-master/r/105464
There is path through which registering a card will fail to probe,
but that error code is not propogated back to the tegra machine
driver. To catch this case in the machine driver's probe routine,
we need to ensure that after registering the card, the card is
instantiated and fail probe if not.
Change-Id: I64ba952685ef193a3b248502943771c518396808
Reviewed-on: http://git-master/r/106837
- For slave mode, clk_audio_2x needs to be
programmed to bitclock value. Setting this frequency
is not possible if the parent clock has different
frequency. Hence change the parent of this clock
to i2s_sync clock first before setting the rate.
- Fixed setting uninitialized variables.
Bug 948478
Change-Id: Ieb4656e6e114d3a9b815f44003a476c4b9892059
Reviewed-on: http://git-master/r/104445
Use the pcm-driver specified from platform/board
specified file.
Bug 991926
Change-Id: I9e4c9a3f76bacb22de817273a2281ac9b8959c43
Reviewed-on: http://git-master/r/105415
Ensure i2s_client_bits and i2s_audio_bits do not get used
uninitialized.
Bug 949219
Change-Id: Ibdd7f2598278639388d2c2afb5843f2471375ea2
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/105426
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Bug 964287
1) Add support for resetting the codec while entering in lp0
state to save codec power in lpo for KAI.
2) Fix for cache sync.
3) Add index sync functionality.
Change-Id: I04039eb55944bfe7f06e6a1405ac3c810c5688a1
Reviewed-on: http://git-master/r/104480
Tested-by: Daniel Solomon <daniels@nvidia.com>
Add alsa controls to specify which alsa device is used by AVP to render
audio. Also add support for disabling DMA interrupt when AVP renders
audio. Also add couple of alsa controls to query DMA channel ID and
DMA buffer physical address.
Bug 968814
Signed-off-by: Sumit Bhattacharya <sumitb@nvidia.com>
Change-Id: If593329db72bf00d97f7433f5c54e13500281253
Reviewed-on: http://git-master/r/97916
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Bug 949219
Change-Id: Ic8976b008772220299369369427a80dd370df596
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/104419
Bug 949219
Change-Id: If7b4dd928cc5a808fd1a674bcc5f31c9a396a043
Reviewed-on: http://git-master/r/103772
The extern1 codec clock was not getting switched off whenever
codec goes below BIAS_OFF level. Moreover, there were two
instances of extern1 clock whenever codec was on. Reason behind
this was that, those codecs for which probe function was called
and were not present on board, turned on their extern1 clock, but
clean up routine (for switch device register failure) was not able
to turn off the clock. With this change, a conditional check is
put to turn off the clock.
(Bug 984678)
Change-Id: I585ecf73c0cabca856592dcd84e67588dfe13beb
Reviewed-on: http://git-master/r/104073
Tested-by: Ankit Gupta (Engrg-SW) <ankitgupta@nvidia.com>
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Pass TDM mode variables for CPU dai.
Codec Id is not passed properly, hence use dual instances
of the dai_link operations.
Bug 948478
Change-Id: I13188d5001b8f9c2f2f67ee7a9d3bec89311037d
Signed-off-by: Bob Johnston <bjohnston@nvidia.com>
Reviewed-on: http://git-master/r/103793
Reviewed-by: Nitin Pai <npai@nvidia.com>
Added TDM mode support in I2S driver.
Added support functions in AHUB to pass audio/client bits.
Added support functions in AHUB to pass audio/client channels.
Fixed the stopping of I2S/TDM by clearing the fifo.
Bug 948478
Change-Id: I560f4ab5b71e4833931934275272a094241241fe
Reviewed-on: http://git-master/r/103840
disable the compilation of minidsp specific code,
we are disabling the minidsp in codec because the driver is
not stable and different customers are using different process flows
for mini dsp
Change-Id: I08f8f485f1a379773f2f1f7ae2fd1b3a89c45d07
Reviewed-on: http://git-master/r/101232
Allow setting bias level to turn off clock extern1 when codec
is idle for enterprise board. (Maxim 98088 codec)
Bug 984678
Change-Id: Ib01be71362ab0c5525f570693b41db73777875e6
Reviewed-on: http://git-master/r/102240
Reviewed-by: Manoj Gangwal <mgangwal@nvidia.com>
Associated with I2S there is a playback ref count, when
we open the I2S for plyabck it is incremented and during
voice call we check if its not zero then enable the tX.
This logic fails if the start-trigger is not called for the prior
playback stream. Hence we unconditionally enable the tx,
which is harmless
Bug: 981806
Change-Id: I66aafda596e2b2b03745e93f3e851dedc3b8ef5d
Reviewed-on: http://git-master/r/101996
Allow setting bias level to turn off clock extern1 on enterprise
when codec is idle. Added a dummy widget to make the
target_bias_level to BIAS_OFF as per required by the new ALSA
kernel.
Bug 984678
Change-Id: I29de405c26286eee0a49e655f1d4236f6093ce8a
Reviewed-on: http://git-master/r/100287
is idle for Enterprise (Maxim 98088 codec).
Bug 984678
Change-Id: I09538dafe6c6f01547ff989de3c23933c9745db0
Reviewed-on: http://git-master/r/100286
Bug 949219
Change-Id: I9c2a0aa22432c586a7e72273ad935d42332e873f
Reviewed-on: http://git-master/r/95087
This reverts commit dfa00e184b5fe0d4d48fa62a15fc956de9b6b65c.
This is causing a regresssion.
Bug: 977319
Change-Id: I4fe6daf88b2988978f089194f2931691eeb0eb09
Reviewed-on: http://git-master/r/101687
Reviewed-by: Vijaya Bhaskar <vbhaskar@nvidia.com>
This reverts commit 774fa71fc9834fbdcb297048d9e9a4bc7b944b48
Change-Id: Ib187dff51d3b2fd2b2ac0c98a53abe07c99148aa
Reviewed-on: http://git-master/r/101359
bug 949219
Change-Id: I4409eaff4042967133cc948452ca8e52d15b2d18
Reviewed-on: http://git-master/r/92279
If there is no dma information exit from trigger, this is required
for the dummy voice call playback and capture streams
Change-Id: I5276e7ebb72c17268a9785204fea9f395b2e5d3a
Reviewed-on: http://git-master/r/101235
Use non-inverting type alsa control for headphones as same have
been used for spk and recv
Change-Id: I39d2613071063782dff8151b07ef46ca8e16db5c
Reviewed-on: http://git-master/r/101234
disable the flags for turning off the mini dsp support
Change-Id: Ieb0b18fc3cc1143cbd0a315c85688d2f1ae4efe1
Reviewed-on: http://git-master/r/101233
Change-Id: I0931f4ef7a5464dd32d8c703288a137fc77857ce
Signed-off-by: Linqiang Pu <dpu@nvidia.com>
Reviewed-on: http://git-master/r/100090
Allow setting bias level to turn off clock extern1 on KAI when
codec is idle. Added a dummy widgets to make the target_bias_level
to BIAS_OFF as per required by the new ALSA kernel.
Bug 964287
Change-Id: I628744040866a9879eedc41ed4ee25af38ed86fb
Reviewed-on: http://git-master/r/99667
Tested-by: Hunk Lin <hulin@nvidia.com>
is idle.
Bug 964287
Change-Id: I48056b86a9fdaea70202bee9326debaaddf69c0c
Reviewed-on: http://git-master/r/99665
is idle.
Bug 964287
Reviewed on: http://git-master/r/#change,93950
Change-Id: Icc11e8bfb359b432f0bfd9ba214877259188de2b
Reviewed-on: http://git-master/r/99659
condition to check bit-format is always false
because TEGRA20_I2S_CTRL_BIT_FORMAT_I2S is zero.
Bug 947429
Change-Id: Ieb92f0732b092100dc1bf323ad60aff4439d5b3d
Signed-off-by: Jubeom Kim <jubeomk@nvidia.com>
Reviewed-on: http://git-master/r/99341
Modified existing pcm driver to take dma mode/ hw structure.
Exported the functions needed for other pcm mode driver.
Added new TDM mode hw param structure.
Added pass SINGLE/DOUBLE buffered dma mode params.
Bug 948478
Change-Id: I58309d52748f813b3303a8d6a052fbb6cc7ca87a
Reviewed-on: http://git-master/r/99146
Set maximum supported channels of HDA driver based on the LPCM channel
capability of the HDMI device. This is needed because user space
decides number of PCM channels to be sent to kernel based on this
information.
Bug 960940
Change-Id: I59ae3b7d47dcf26f697bfb0877ca24556f0ab1fa
Reviewed-on: http://git-master/r/94831
Reviewed-on: http://git-master/r/98783
Add Support to detect the HP insertion or removal during
LP0 state.
Bug 969405
Change-Id: Ibedf1769338e16877240ea9cc82fa7469eb7ff9e
Reviewed-on: http://git-master/r/98745
Instead of always using 2 dma_req count pass max dma_req_count
through a macro. Ensure dma_req_count does not cross
period_count.
Bug 968814
Change-Id: Iddfbd77017992ccb8c90441213e191133dadb347
Reviewed-on: http://git-master/r/97915
Change prototype of tegra_asoc_utils_init to pass snd_soc_card handle.
It is needed to move common tegra machine driver codes to
tegra_asoc_utils interface.
Bug 968814
Change-Id: I98490ffdda51cf7d0b89adadb23c31892183bc0e
Reviewed-on: http://git-master/r/97914
Bug 953210
Change-Id: Id40b3fe90174a2a8c9a6faf3f35f61d9f7eeb642
Signed-off-by: Sayak Ghosh Choudhury <sayakc@nvidia.com>
Reviewed-on: http://git-master/r/98477
Bug 948478
Change-Id: I246942b3a07ffcfbcfafbc820208190bd3acc5d4
Reviewed-on: http://git-master/r/98456
