commit d0e12f3ff3472cbd8f52d3c0e6ee07a841787c40 upstream.
commit 8dce30c89113e314d29d3b8f362aadff8087fccb upstream.
Also fix the calls to next_packet_size() for the pause case. This was
missed in 245baf983 ("ALSA: snd-usb: fix calls to next_packet_size").
Signed-off-by: Daniel Mack <zonque@gmail.com>
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Reported-and-tested-by: Christian Tefzer <ctrefzer@gmx.de>
[ Taking directly because Takashi is on vacation - Linus ]
commit 26b0d14106954ae46d2f4f7eec3481828a210f7d upstream.
The i2c-powermac driver now creates the i2c devices properly
from the device-tree, including workarounds for broken or
missing device-tree bits, so let's just use the normal probe
methods and get rid of the hand made device creation code.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Cc: Elimar Riesebieter <riesebie@lxtec.de>
Cc: Michel Dänzer <michel@daenzer.net>
commit 57b2d68863f281737d8596cb3d76d89d9cc54fd8 upstream.
The pause and resume operations indicate that the stream can be
un-paused/resumed from the exact location they were paused/suspended.
This is not true for this driver, the pause and suspend triggers share
the same code path with stop, they flush all pending DMA transfers.
This drops all pending samples. The pause_release/resume triggers are
the same as start, except that prepare won't be called beforehand,
nothing will be enqueued to the DMA engine and nothing will happen (no
audio). Removing the pause flag will let apps know that it isn't
supported. Removing the resume flag will cause user space to call
prepare and start instead of resume, so audio will continue playing when
the system wakes up.
Before removing the pause and resume flags, I tested this on an exynos
5250, using 'aplay -i'. Pause/un-pause leads to silence followed by a
write error. Suspend/resume testing led to the same result. Removing
the two flags fixes suspend/resume (since snd_pcm_prepare is called
again). And leads to a proper reporting of pause not supported.
Signed-off-by: Dylan Reid <dgreid@chromium.org>
commit c921928661eda599d73a6a86e58bdd5aecfa18cb upstream.
Both the schematics and practical testing show that the HP detect GPIO
is high when the headphones are plugged in. Hence, the snd_soc_jack_gpio
should not specify to invert the signal.
Acked-by: Andrey Danin <danindrey@mail.ru>
commit e427c2375646789ecd0ccaef1a1e41458559ab2d upstream.
On recent kernels, Realtek codec parser tries to optimize the routing
aggressively and take the headphone output as primary at first. This
caused a regression on VAIO Z with ALC889, the silent output from the
speaker.
The problem seems that the speaker pin must be connected to the first
DAC (0x02) on this machine by some reason although the codec itself
advertises the flexible routing with any DACs.
This patch adds a fix-up for choosing the speaker pin as the primary
so that the right DAC is assigned on this device.
Reported-and-tested-by: Adam Williamson <awilliam@redhat.com>
commit 3737e2be505d872bf2b3c1cd4151b2d2b413d7b5 upstream.
The AK4396 DAC has a linear-scale attentuator, but
sound/pci/ice1712/prodigy_hifi.c used a log scale instead, which is
not quite right. This patch restores the correct scale, borrowing
from the ak4396 code in sound/pci/oxygen/oxygen.c.
Signed-off-by: Matteo Frigo <athena@fftw.org>
commit 07dc59f0988cb54fd87bd373b3b27eb2401dd811 upstream.
snd_hda_codec_reset() calls restore_pincfgs() where the codec is
powered up again, which eventually tries to resume and initialize via
the callbacks of the codec. However, it's the place just after codec
free callback, thus no codec callbacks should be called after that.
On a codec like CS4206, it results in Oops due to the access in init
callback.
This patch fixes the issue by clearing the codec callbacks properly
after freeing codec.
Reported-by: Daniel J Blueman <daniel@quora.org>
commit 1213a205f9ed27d97de3d5bed28fb085ef4853e2 upstream.
The recent fix for the missing fine delayed time adjustment gives
strange error messages at each start of the playback stream, such as
delay: estimated 0, actual 352
delay: estimated 353, actual 705
These come from the sanity check in retire_playback_urb(). Before the
stream is activated via start_endpoints(), a few silent packets have
been already sent. And at this point the delay account is still in
the state as if the new packets are just queued, so the driver gets
confused and spews the bogus error messages.
For fixing the issue, we just need to check whether the received
packet is valid, whether it's zero sized or not.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
commit ab548d2dba63ba947287965e525cc02a15d9853d upstream.
With the commit [2faa3bf: ALSA: hda - Rewrite the mute-LED hook with
vmaster hook in patch_sigmatel.c], the former Master volume control
was converted to PCM. This was supposed to be covered by the vmaster
control. But due to the lack of "PCM" slave definition, this didn't
happen properly. The patch fixes the missing entry.
Reported-by: Andrew Shadura <bugzilla@tut.by>
commit 2e4a263ca80a203ac6109f5932722a716c265395 upstream.
Commit 68e67f40b ("ALSA: snd-usb: move calls to usb_set_interface")
saved us some unnecessary calls to snd_usb_set_interface() but ignored
the fact that there is at least one device out there which operates on
two endpoint in different interfaces simultaniously.
Take care for this by catching the case where data and sync endpoints
are located on different interfaces and calling snd_usb_set_interface()
between the start of the two endpoints.
Reported-by: Robert M. Albrecht <linux@romal.de>
commit 245baf983cc39524cce39c24d01b276e6e653c9e upstream.
In order to support devices with implicit feedback streaming models,
packet sizes are now stored with each individual urb, and the PCM
handling code which fills the buffers purely relies on the size fields
now.
However, calling snd_usb_audio_next_packet_size() for all possible
packets in an URB at once, prior to letting the PCM code do its job
does in fact not lead to the same behaviour than what the old code did:
The PCM code will break its loop once a period boundary is reached,
consequently using up less packets that it really could.
As snd_usb_audio_next_packet_size() implements a feedback mechanism to
the endpoints phase accumulator, the number of calls to that function
matters, and when called too often, the data rate runs out of bounds.
Fix this by making the next_packet function public, and call it from the
PCM code as before if the packet data sizes are not defined.
commit fbcfbf5f673847657ccd98afb4d8e13af7fdc372 upstream.
Parts of commit 294c4fb8 ("ALSA: usb: refine delay information with USB
frame counter") were unfortunately lost during the refactoring of the
snd-usb driver in 3.5.
This patch adds them back, restoring the correct delay information
behaviour.
Cc: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
commit 03d2f44e967b3c2cf79a6dfb904c8880616c7f83 upstream.
snd_usb_endpoint_free() frees the structure that contains its argument.
Signed-off-by: Pavel Roskin <proski@gnu.org>
commit 015618b902ae8e28705b7af9b4668615fea48ddd upstream.
Commit e9ba389c5 ("ALSA: usb-audio: Fix scheduling-while-atomic bug in
PCM capture stream") fixed a scheduling-while-atomic bug that happened
when snd_usb_endpoint_start was called from the trigger callback, which
is an atmic context. However, the patch breaks the idea of the endpoints
reference counting, which is the reason why the driver has been
refactored lately.
Revert that commit and let snd_usb_endpoint_start() take care of the URB
cancellation again. As this function is called from both atomic and
non-atomic context, add a flag to denote whether the function may sleep.
commit e9ba389c5ffc4dd29dfe17e00e48877302111135 upstream.
A PCM capture stream on usb-audio causes a scheduling-while-atomic
BUG, as reported in the bugzilla entry below. It's because
snd_usb_endpoint_start() is called at first at trigger START for a
capture stream, and this function contains the left-over EP
deactivation codes. The problem doesn't happen for a playback stream
because the function is called at PCM prepare time, which can sleep.
This patch fixes the BUG by moving the EP deactivation code into the
PCM prepare callback.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=46011
commit 535b6c51fe8293c88ce919cdfc4390c67a1cb6d1 upstream.
When the codec turn-on operation is canceled by the immediate
power-on, the driver left the power_transition flag as is.
This caused the persistent avoidance of power-save behavior.
commit c41999a23929f30808bae6009d8065052d4d73fd upstream.
It's possible that these amps are settable somehow, e g through
secret codec verbs, but for now, don't create the controls (as
they won't be working anyway, and cause errors in amixer).
BugLink: https://bugs.launchpad.net/bugs/1038651
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit d0db84e713eaaccea2a435e1625fb3150b335f4a upstream.
The check for the mux_signal callback was wrong which prevents us to
configure the 6pin port's FSR/CLKR signal mux.
Reported-by: CF Adad <cfadad@rocketmail.com>
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
commit ccf795847a38235ee4a56a24129ce75147d6ba8f upstream.
Currently the microphone input source is not selectable as while there is
a DAPM widget it's not connected to anything so it won't be properly
instantiated. Add something more correct for the input structure to get
things going, even though it's not hooked into the rest of the routing
map and so won't actually achieve anything except allowing the relevant
register bits to be written.
Reported-by: Christop Fritz <chf.fritz@googlemail.com>
commit 088c820b732dbfd515fc66d459d5f5777f79b406 upstream.
As spec said, 1 indicates no copyright is asserted.
Signed-off-by: Wang Xingchao <xingchao.wang@intel.com>
commit 012e7eb1e501d0120e0383b81477f63091f5e365 upstream.
The same ID is twice in the quirk table, so the second one is not used.
commit e9fc83cb2e5877801a255a37ddbc5be996ea8046 upstream.
This computer is confirmed working with model=auto on kernel 3.2.
Also, parsing fails with hda-emu with the current model.
commit c8415a48fcb7a29889f4405d38c57db351e4b50a upstream.
As with the ThinkPad Models X230 Tablet and T530 the X230 needs a qurik to
correctly set up the pins for the dock port.
Signed-off-by: Felix Kaechele <felix@fetzig.org>
commit 4407be6ba217514b1bc01488f8b56467d309e416 upstream.
Add a model/fixup string "lenovo-dock", for Thinkpad T430s, to allow
sound in docking station.
Tested on Lenovo T430s with ThinkPad Mini Dock Plus Series 3
Signed-off-by: Philipp A. Mohrenweiser <phiamo@googlemail.com>
commit b8edf3e5522735c8ce78b81845f7a1a2d4a08626 upstream.
Otherwise if someone tries to use all four channels on AIF1 with the
device in master mode we won't be able to clock out all the data.
commit 9d40e5582c9c4cfb6977ba2a0ca9c2ed82c56f21 upstream.
Required for reliable power up from cold.
commit 707fba3fa76a4c8855552f5d4c1a12430c09bce8 upstream.
Lenovo Thinkpad T530 with ALC269VC codec has a dock port but BIOS
doesn't set up the pins properly. Enable the pins as well as on
Thinkpad X230 Tablet.
Reported-and-tested-by: Mario <anyc@hadiko.de>
commit 1f43f6c1bc8d740e75b4177eb29110858bb5fea2 upstream.
The IDT codecs initializes the GPIO setup for mute LEDs via
snd_hda_sync_vmaster_hook(). This works in most cases except for the
very first call, which is called before PCM and control creations.
Thus before Master switch is set manually via alsactl, the mute LED
may show the wrong state, depending on the polarity.
Now it's fixed by calling the LED-status update function manually when
no vmaster is set yet.
commit ff8a1e274cbc11da6b57849f925b895a212b56c9 upstream.
The commit a3e199732b made the LED working again on HP Mini 210 but
with a wrong polarity. This patch fixes the polarity for this
machine, and also introduce a new model string "hp-inv-led".
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=772923
commit a3e199732b8e2b272e82cc1ccc49c35239ed6c5a upstream.
BIOS on HP Mini 210 doesn't provide the proper "HP_Mute_LED" DMI
string, thus the driver doesn't initialize the GPIO, too. In the
earlier kernel, the driver falls back to GPIO1, but since 3.3 we've
stopped this due to other wrongly advertised machines.
For fixing this particular case, add a new model type to specify the
default polarity explicitly so that the fallback to GPIO1 is handled.
commit 6162552b0de6ba80937c3dd53e084967851cd199 upstream.
We've got a bug report about the silent output from the headphone on a
mobo with VT2021, and spotted out that this was because of the wrong
D3 state on the DAC for the headphone output. The bug is triggered by
the incomplete check for this DAC in set_widgets_power_state_vt1718S().
It checks only the connectivity of the primary output (0x27) but
doesn't consider the path from the headphone pin (0x28).
Now this patch fixes the problem by checking both pins for DAC 0x0b.
commit bc733d495267a23ef8660220d696c6e549ce30b3 upstream.
The irq field of struct snd_mpu401 is supposed to be initialized to -1.
Since it's set to zero as of now, a probing error before the irq
installation results in a kernel warning "Trying to free already-free
IRQ 0".
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=44821
commit aff252a848ce21b431ba822de3dab9c4c94571cb upstream.
uac_clock_source_is_valid() uses the control selector value to access
the bmControls bitmap of the clock source unit. This is wrong, as
control selector values start from 1, while the bitmap uses all
available bits.
In other words, "Clock Validity Control" is stored in D3..2, not D5..4
of the clock selector unit's bmControls.
Reported-by: Andreas Koch <andreas@akdesigninc.com>
commit 108cc108a3bb42fe4705df1317ff98e1e29428a6 upstream.
Also add a model/fixup string "lenovo-dock", so that other Thinkpad
users will be able to test this fixup easily, to see if it enables
dock I/O for them as well.
BugLink: https://bugs.launchpad.net/bugs/1026953
Tested-by: John McCarron <john.mccarron@canonical.com>
commit b43d224767e426cf1a8b6622d1d172f2b2b0e857 upstream.
After cancel_delayed_work_sync returns, the power down work either never
started (power_on == 1) or finished (power_on == 0). In the former case
there is no need to power up again.
commit 9e76e6d031482194a5b24d8e9ab88063fbd6b4b5 upstream.
Turn on the pin widget's PIN_OUT bit from playback prepare. The pin is
enabled in open, but is disabled in hdmi_init_pin which is called during
system resume. This causes a system suspend/resume during playback to
mute HDMI/DP. Enabling the pin in prepare instead of open allows calling
snd_pcm_prepare after a system resume to restore audio.
commit 4e01ec636e64707d202a1ca21a47bbc6d53085b7 upstream.
This codec has a separate dmic path (separate dmic only ADC),
and thus it looks mostly like ALC275.
BugLink: https://bugs.launchpad.net/bugs/1025377
Tested-by: Ray Chen <ray.chen@canonical.com>
commit e4dd76788c7e5b27165890d712c8c4f6f0abd645 upstream.
Ensure robust startup of the part by going through the reset procedure
prior to resyncing the full register cache, avoiding potential intermittent
faults in some designs.
commit 0ff97ebf0804d2e519d578fcb4db03f104d2ca8c upstream.
Ever since the DAPM performance improvements we've been marking all widgets
as not dirty after each DAPM run. Since _PRE and _POST events aren't part
of the DAPM graph this has rendered them non-functional, they will never be
marked dirty again and thus will never be run again.
Fix this by skipping them when marking widgets as not dirty.
Acked-by: Liam Girdwood <lrg@ti.com>
commit 01005a729a17ab419f61a366e22f3419e7a2c3fe upstream.
Codec shutdown performs a DAPM power sequence that might cause conflicts
and/or race conditions if another stream power event is running simultaneously.
Use card's dapm mutex to protect any potential race condition between them.
Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Containing the regression fixes for USB-audio due to the transition to
the new streaming logic, mostly found on Logitech webcams."
* tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: usb-audio: Fix the first PCM interface assignment
The rework of the snd-usb endpoint logic moved the calls to
snd_usb_set_interface() into the snd_usb_endpoint implemenation. This
changed the order in which these calls are issued to the device, and
thereby caused regressions for some webcams.
Fix this by moving the calls back to pcm.c for now to make it work again
and use snd_usb_endpoint_activate() to really tear down all remaining
URBs in the flight, consequently fixing another regression caused by USB
packets on the wire after altsetting 0 has been selected.
Reported-and-tested-by: Philipp Dreimann <philipp@dreimann.net>
Reported-by: Joseph Salisbury <joseph.salisbury@canonical.com>
In the new PCM streaming logic, the interface number is assigned to
usb stream instance (subs->interface) after the format and rate setups
are succeeded, but some codes are still passing subs->interface as the
reference to helper functions. This leads to initializing with an
invalid iface number (-1).
This patch replaces the wrong references with the ones from the target
fmt correctly.
"Just a few driver-specific fixes for ASoC and HD-audio."
ALSA: hda - Fix no sound from ALC662 after Windows reboot
ASoC: tlv320aic3x: Fix codec pll configure bug
ASoC: wm2200: Add missing BCLK rate
Windows use hidden register to control EAPD.
Linux use verb to control EAPD.
If windows reboot to Linux, it must change the EAPD control to verb
control.
Signed-off-by: Kailang Yang <kailang@realtek.com>
In sound/soc/codecs/tlv320aic3x.c
data = snd_soc_read(codec, AIC3X_PLL_PROGA_REG);
snd_soc_write(codec, AIC3X_PLL_PROGA_REG,
data | (pll_p << PLLP_SHIFT));
In the above code, pll-p value is OR'ed with previous value without
clearing it. Bug is not seen if pll-p value doesn't change across
Sampling frequency.
However on some platforms (like AM335x EVM-SK), pll-p may have different
values across different sampling frequencies. In such case, above code
configures the pll with a wrong value.
Because of this bug, when a audio stream is played with pll value
different from previous stream, audio is heard as differently(like its
stretched).
Signed-off-by: Hebbar, Gururaja <gururaja.hebbar@ti.com>
Cc: stable@vger.kernel.org
Without this very high BCLKs will be configured incorrectly.
Reported-by: Axel Lin <axel.lin@gmail.com>
"Here you find quite a few changes for HD-audio and a copule of quirk
additions for USB-audio. All reasonably small and/or trivial."
ALSA: hda - Fix power-map regression for HP dv6 & co
ALSA: hda - Initialize caches at codec reconfiguration
ALSA: hda - Fix memory leaks at module unload
ALSA: hda - Fix memory leaks in Realtek & Conexant codec parsers
ALSA: hda - Add Realtek ALC280 codec support
ALSA: hda - Remove obsoleted CONFIG_SND_HDA_ENABLE_REALTEK_QUIRKS
ASoC: wm8994: remove duplicate code
ALSA: usb-audio: add BOSS GT-100 support
ALSA: HDA: Add inverted internal mic quirk for Lenovo S205
ALSA: hda - Fix ALC272X codec detection
ALSA: snd_usb_audio: ignore ctrl errors on QuickCam Pro for Notebooks
ALSA: snd_usb_audio: ignore ctrl errors on QuickCam E3500
The recent fix for power-map controls (commit b0791dda813) caused
regressions on some other HP laptops. They have fixed pins but these
pins are exposed as jack-detectable. Thus the driver tries to control
the power-map dynamically per jack detection where it never gets on.
This patch adds the check of connection and it assumes the no jack
detection is available for fixed pins no matter what pin capability
says.
BugLink: http://bugs.launchpad.net/bugs/1013183
Reported-by: Luis Henriques <luis.henriques@canonical.com>
