[ Upstream commit 9f169b9f52a4afccdab7a7d2311b0c53a78a1e6b ]
When multiple front-ends are using the same back-end, putting state of a
front-end to STOP state upon receiving pause command will result in backend
stream getting released by DPCM framework unintentionally. In order to
avoid backend to be released when another active front-end stream is
present, put the stream state to PAUSED state instead of STOP state.
Signed-off-by: Patrick Lai <plai@codeaurora.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit bc65a326c579e93a5c2120a65ede72f11369ee5a ]
Saved firmware ctx was not never released, so release Firmware
ctx in cleanup routine.
Signed-off-by: Jeeja KP <jeeja.kp@intel.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
[ Upstream commit 60448b077ed93d227e6c117a9e87db76ff0c1911 ]
Frequency value of zero did not make sense, use same 24.576MHz
setting and only change the clock source in idle mode
Suggested-by: Bard Liao <bardliao@realtek.com>
Signed-off-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com>
[ Upstream commit 13a6c8328e6056932dc680e447d4c5e8ad9add17 ]
Testing EP_FLAG_RUNNING in snd_complete_urb() before running the completion
logic allows us to save a few cpu cycles by returning early, skipping the
pending urb in case the stream was stopped; the stop logic handles the urb
and sets the completion callbacks to NULL.
Signed-off-by: Ioan-Adrian Ratiu <adi@adirat.com>
[ Upstream commit 4ee437fbf626b5ad756889d8bc0fcead3d66dde7 ]
The fsl_ssi fifo watermark is by default set to 2 free spaces (i.e.
activate DMA on FIFO when only 2 spaces are left.) This means the
DMA must service the fifo within 2 audio samples, which is just not
enough time for many use cases with high data rate. In many
configurations the audio channel slips (causing l/r swap in stereo
configurations, or channel slipping in multi-channel configurations).
This patch gives more breathing room and allows the SSI to operate
reliably by changing the fifio refill watermark to 8.
There is no change in behavior for older chips (with an 8-deep fifo).
Only the newer chips with a 15-deep fifo get the new behavior. I
suspect a new fifo depth setting could be optimized on the older
chips too, but I have not tested.
Signed-off-by: Caleb Crome <caleb@crome.org>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
[ Upstream commit a1792cda51300e15b03549cccf0b09f3be82e697 ]
The clk_ref_div is not configured in the correct position of the
register. The patch fixes that clk_ref_div, Pre-Scalar, is assigned
the wrong value.
Signed-off-by: John Hsu <KCHSU0@nuvoton.com>
[ Upstream commit 63c3194b82530bd71fd49db84eb7ab656b8d404a ]
The RESET register only have one self clearing bit and it should not be
cached. If it is cached, when we sync the registers back to the chip we
will initiate a software reset as well, which is not desirable.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Reviewed-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
commit 74ec118152ea494a25ebb677cbc83a75c982ac5f upstream.
Add codec IDs for several recently released, pending, and historical
NVIDIA GPU audio controllers to the patch table, to allow the correct
patch functions to be selected for them.
Signed-off-by: Daniel Dadap <ddadap@nvidia.com>
Reviewed-by: Andy Ritger <aritger@nvidia.com>
commit 610e1ae9b533be82b3aa118b907e0a703256913d upstream.
The commit b56fa687e02b ("ALSA: fm801: detect FM-only card earlier")
rearranged initialization calls, i.e. it makes snd_fm801_chip_init() to
be called before we register interrupt handler and set PCI bus
mastering.
Somehow it prevents FM801-AU to work properly. Thus, partially revert
initialization order changed by commit mentioned above.
Fixes: b56fa687e02b ("ALSA: fm801: detect FM-only card earlier")
Reported-by: Émeric MASCHINO <emeric.maschino@gmail.com>
Tested-by: Émeric MASCHINO <emeric.maschino@gmail.com>
commit 01b8cedfd0422326caae308641dcadaa85e0ca72 upstream.
Currently compress driver hardcodes direction as playback to get
substream from the stream. This results in getting the incorrect
substream for compressed capture usecase.
To fix this, remove the hardcoding and derive substream based on
the stream direction.
Signed-off-by: Satish Babu Patakokila <sbpata@codeaurora.org>
Signed-off-by: Banajit Goswami <bgoswami@codeaurora.org>
Acked-By: Vinod Koul <vinod.koul@intel.com>
commit fe0dfd6358a17c79bd7d6996af7512ba452a7059 upstream.
Thinkpad Helix 2 is a tablet PC, the audio is powered by Core M
broadwell-audio and rt286 codec. For all versions of Linux kernel,
the stereo output doesn't work properly when earphones are plugged
in, the sound was coming out from both channels even if the audio
contains only the left or right channel. Furthermore, if a music
recorded in stereo is played, the two channels cancle out each other
out, as a result, no voice but only distorted background music can be
heard, like a sound card with builtin a Karaoke sount effect.
Apparently this tablet uses a combo jack with polarity incorrectly
set by rt286 driver. This patch adds DMI information of Thinkpad Helix 2
to force_combo_jack_table[] and the issue is resolved. The microphone
input doesn't work regardless to the presence of this patch and still
needs help from other developers to investigate.
This is my first patch to LKML directly, sorry for CC-ing too many
people here.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=93841
Signed-off-by: Yifeng Li <tomli@tomli.me>
commit a8f20fd25bdce81a8e41767c39f456d346b63427 upstream.
Recently we met a problem, the codec has valid adcs and input pins,
and they can form valid input paths, but the driver does not build
valid controls for them like "Mic boost", "Capture Volume" and
"Capture Switch".
Through debugging, I found the driver needs to shrink the invalid
adcs and input paths for this machine, so it will move the whole
column bitmap value to the previous column, after moving it, the
driver forgets to set the original column bitmap value to zero, as a
result, the driver will invalidate the path whose index value is the
original colume bitmap value. After executing this function, all
valid input paths are invalidated by a mistake, there are no any
valid input paths, so the driver won't build controls for them.
Fixes: 3a65bcdc577a ("ALSA: hda - Fix inconsistent input_paths after ADC reduction")
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit d94815f917da770d42c377786dc428f542e38f71 upstream.
azx_codec_configure() loops over the codecs found on the given
controller via a linked list. The code used to work in the past, but
in the current version, this may lead to an endless loop when a codec
binding returns an error.
The culprit is that the snd_hda_codec_configure() unregisters the
device upon error, and this eventually deletes the given codec object
from the bus. Since the list is initialized via list_del_init(), the
next object points to the same device itself. This behavior change
was introduced at splitting the HD-audio code code, and forgotten to
adapt it here.
For fixing this bug, just use a *_safe() version of list iteration.
Fixes: d068ebc25e6e ("ALSA: hda - Move some codes up to hdac_bus struct")
Reported-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 2deaeaf102d692cb6f764123b1df7aa118a8e97c upstream.
The standard PCM chmap helper callbacks treat the NULL info->chmap as
a fatal error and spews the kernel warning with stack trace when
CONFIG_SND_DEBUG is on. This was OK, originally it was supposed to be
always static and non-NULL. But, as the recent addition of Intel LPE
audio driver shows, the chmap content may vary dynamically, and it can
be even NULL when disconnected. The user still sees the kernel
warning unnecessarily.
For clearing such a confusion, this patch simply removes the
snd_BUG_ON() in each place, just returns an error without warning.
commit 4a9bfafc64f44ef83de4e00ca1b57352af6cd8c2 upstream.
At Linux v3.5, packet processing can be done in process context of ALSA
PCM application as well as software IRQ context for OHCI 1394. Below is
an example of the callgraph (some calls are omitted).
ioctl(2) with e.g. HWSYNC
(sound/core/pcm_native.c)
->snd_pcm_common_ioctl1()
->snd_pcm_hwsync()
->snd_pcm_stream_lock_irq
(sound/core/pcm_lib.c)
->snd_pcm_update_hw_ptr()
->snd_pcm_udpate_hw_ptr0()
->struct snd_pcm_ops.pointer()
(sound/firewire/*)
= Each handler on drivers in ALSA firewire stack
(sound/firewire/amdtp-stream.c)
->amdtp_stream_pcm_pointer()
(drivers/firewire/core-iso.c)
->fw_iso_context_flush_completions()
->struct fw_card_driver.flush_iso_completion()
(drivers/firewire/ohci.c)
= flush_iso_completions()
->struct fw_iso_context.callback.sc
= in_stream_callback() or out_stream_callback()
->snd_pcm_stream_unlock_irq
When packet queueing error occurs or detecting invalid packets in
'in_stream_callback()' or 'out_stream_callback()', 'snd_pcm_stop_xrun()'
is called on local CPU with disabled IRQ.
->amdtp_stream_pcm_abort()
->snd_pcm_stop_xrun()
->snd_pcm_stream_lock_irqsave()
->snd_pcm_stop()
->snd_pcm_stream_unlock_irqrestore()
The process is stalled on the CPU due to attempt to acquire recursive lock.
[ 562.630853] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 562.630861] 2-...: (1 GPs behind) idle=37d/140000000000000/0 softirq=38323/38323 fqs=7140
[ 562.630862] (detected by 3, t=15002 jiffies, g=21036, c=21035, q=5933)
[ 562.630866] Task dump for CPU 2:
[ 562.630867] alsa-source-OXF R running task 0 6619 1 0x00000008
[ 562.630870] Call Trace:
[ 562.630876] ? vt_console_print+0x79/0x3e0
[ 562.630880] ? msg_print_text+0x9d/0x100
[ 562.630883] ? up+0x32/0x50
[ 562.630885] ? irq_work_queue+0x8d/0xa0
[ 562.630886] ? console_unlock+0x2b6/0x4b0
[ 562.630888] ? vprintk_emit+0x312/0x4a0
[ 562.630892] ? dev_vprintk_emit+0xbf/0x230
[ 562.630895] ? do_sys_poll+0x37a/0x550
[ 562.630897] ? dev_printk_emit+0x4e/0x70
[ 562.630900] ? __dev_printk+0x3c/0x80
[ 562.630903] ? _raw_spin_lock+0x20/0x30
[ 562.630909] ? snd_pcm_stream_lock+0x31/0x50 [snd_pcm]
[ 562.630914] ? _snd_pcm_stream_lock_irqsave+0x2e/0x40 [snd_pcm]
[ 562.630918] ? snd_pcm_stop_xrun+0x16/0x70 [snd_pcm]
[ 562.630922] ? in_stream_callback+0x3e6/0x450 [snd_firewire_lib]
[ 562.630925] ? handle_ir_packet_per_buffer+0x8e/0x1a0 [firewire_ohci]
[ 562.630928] ? ohci_flush_iso_completions+0xa3/0x130 [firewire_ohci]
[ 562.630932] ? fw_iso_context_flush_completions+0x15/0x20 [firewire_core]
[ 562.630935] ? amdtp_stream_pcm_pointer+0x2d/0x40 [snd_firewire_lib]
[ 562.630938] ? pcm_capture_pointer+0x19/0x20 [snd_oxfw]
[ 562.630943] ? snd_pcm_update_hw_ptr0+0x47/0x3d0 [snd_pcm]
[ 562.630945] ? poll_select_copy_remaining+0x150/0x150
[ 562.630947] ? poll_select_copy_remaining+0x150/0x150
[ 562.630952] ? snd_pcm_update_hw_ptr+0x10/0x20 [snd_pcm]
[ 562.630956] ? snd_pcm_hwsync+0x45/0xb0 [snd_pcm]
[ 562.630960] ? snd_pcm_common_ioctl1+0x1ff/0xc90 [snd_pcm]
[ 562.630962] ? futex_wake+0x90/0x170
[ 562.630966] ? snd_pcm_capture_ioctl1+0x136/0x260 [snd_pcm]
[ 562.630970] ? snd_pcm_capture_ioctl+0x27/0x40 [snd_pcm]
[ 562.630972] ? do_vfs_ioctl+0xa3/0x610
[ 562.630974] ? vfs_read+0x11b/0x130
[ 562.630976] ? SyS_ioctl+0x79/0x90
[ 562.630978] ? entry_SYSCALL_64_fastpath+0x1e/0xad
This commit fixes the above bug. This assumes two cases:
1. Any error is detected in software IRQ context of OHCI 1394 context.
In this case, PCM substream should be aborted in packet handler. On the
other hand, it should not be done in any process context. TO distinguish
these two context, use 'in_interrupt()' macro.
2. Any error is detect in process context of ALSA PCM application.
In this case, PCM substream should not be aborted in packet handler
because PCM substream lock is acquired. The task to abort PCM substream
should be done in ALSA PCM core. For this purpose, SNDRV_PCM_POS_XRUN is
returned at 'struct snd_pcm_ops.pointer()'.
Suggested-by: Clemens Ladisch <clemens@ladisch.de>
Fixes: e9148dddc3c7("ALSA: firewire-lib: flush completed packets when reading PCM position")
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
commit 4efda5f2130da033aeedc5b3205569893b910de2 upstream.
soc_cleanup_card_resources() call snd_card_free() at the last of its
procedure. This turned out to lead to a use-after-free.
PCM runtimes have been already removed via soc_remove_pcm_runtimes(),
while it's dereferenced later in soc_pcm_free() called via
snd_card_free().
The fix is simple: just move the snd_card_free() call to the beginning
of the whole procedure. This also gives another benefit: it
guarantees that all operations have been shut down before actually
releasing the resources, which was racy until now.
Reported-and-tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit ba3021b2c79b2fa9114f92790a99deb27a65b728 upstream.
snd_timer_user_tselect() reallocates the queue buffer dynamically, but
it forgot to reset its indices. Since the read may happen
concurrently with ioctl and snd_timer_user_tselect() allocates the
buffer via kmalloc(), this may lead to the leak of uninitialized
kernel-space data, as spotted via KMSAN:
BUG: KMSAN: use of unitialized memory in snd_timer_user_read+0x6c4/0xa10
CPU: 0 PID: 1037 Comm: probe Not tainted 4.11.0-rc5+ #2739
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16
dump_stack+0x143/0x1b0 lib/dump_stack.c:52
kmsan_report+0x12a/0x180 mm/kmsan/kmsan.c:1007
kmsan_check_memory+0xc2/0x140 mm/kmsan/kmsan.c:1086
copy_to_user ./arch/x86/include/asm/uaccess.h:725
snd_timer_user_read+0x6c4/0xa10 sound/core/timer.c:2004
do_loop_readv_writev fs/read_write.c:716
__do_readv_writev+0x94c/0x1380 fs/read_write.c:864
do_readv_writev fs/read_write.c:894
vfs_readv fs/read_write.c:908
do_readv+0x52a/0x5d0 fs/read_write.c:934
SYSC_readv+0xb6/0xd0 fs/read_write.c:1021
SyS_readv+0x87/0xb0 fs/read_write.c:1018
This patch adds the missing reset of queue indices. Together with the
previous fix for the ioctl/read race, we cover the whole problem.
Reported-by: Alexander Potapenko <glider@google.com>
Tested-by: Alexander Potapenko <glider@google.com>
commit d11662f4f798b50d8c8743f433842c3e40fe3378 upstream.
The read from ALSA timer device, the function snd_timer_user_tread(),
may access to an uninitialized struct snd_timer_user fields when the
read is concurrently performed while the ioctl like
snd_timer_user_tselect() is invoked. We have already fixed the races
among ioctls via a mutex, but we seem to have forgotten the race
between read vs ioctl.
This patch simply applies (more exactly extends the already applied
range of) tu->ioctl_lock in snd_timer_user_tread() for closing the
race window.
commit 1fc2e41f7af4572b07190f9dec28396b418e9a36 upstream.
This model is actually called 92XXM2-8 in Windows driver. But since pin
configs for M22 and M28 are identical, just reuse M22 quirk.
Fixes external microphone (tested) and probably docking station ports
(not tested).
Signed-off-by: Alexander Tsoy <alexander@tsoy.me>
commit 49b2e27ab9f66b0a22c21980ad8118a4038324ae upstream.
During reset "refactoring" the output configuration was lost.
This commit repairs sound on EDB93XX boards.
Fixes: 9a397f4 ("ASoC: cs4271: add regulator consumer support")
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
commit 960013762df0a214b57f2fce655422fb52bdfd2c upstream.
Using jiffies in hdac_wait_for_cmd_dmas() to determine when to time out
when interrupts are off (snd_hdac_bus_stop_cmd_io()/spin_lock_irq())
causes hard lockup so unlock while waiting using jiffies.
---<-snip->---
<0>[ 1211.603046] NMI watchdog: Watchdog detected hard LOCKUP on cpu 3
<4>[ 1211.603047] Modules linked in: snd_hda_intel i915 vgem
<4>[ 1211.603053] irq event stamp: 13366
<4>[ 1211.603053] hardirqs last enabled at (13365):
<4>[ 1211.603059] Call Trace:
<4>[ 1211.603059] ? delay_tsc+0x3d/0xc0
<4>[ 1211.603059] __delay+0xa/0x10
<4>[ 1211.603060] __const_udelay+0x31/0x40
<4>[ 1211.603060] snd_hdac_bus_stop_cmd_io+0x96/0xe0 [snd_hda_core]
<4>[ 1211.603060] ? azx_dev_disconnect+0x20/0x20 [snd_hda_intel]
<4>[ 1211.603061] snd_hdac_bus_stop_chip+0xb1/0x100 [snd_hda_core]
<4>[ 1211.603061] azx_stop_chip+0x9/0x10 [snd_hda_codec]
<4>[ 1211.603061] azx_suspend+0x72/0x220 [snd_hda_intel]
<4>[ 1211.603061] pci_pm_suspend+0x71/0x140
<4>[ 1211.603062] dpm_run_callback+0x6f/0x330
<4>[ 1211.603062] ? pci_pm_freeze+0xe0/0xe0
<4>[ 1211.603062] __device_suspend+0xf9/0x370
<4>[ 1211.603062] ? dpm_watchdog_set+0x60/0x60
<4>[ 1211.603063] async_suspend+0x1a/0x90
<4>[ 1211.603063] async_run_entry_fn+0x34/0x160
<4>[ 1211.603063] process_one_work+0x1f4/0x6d0
<4>[ 1211.603063] ? process_one_work+0x16e/0x6d0
<4>[ 1211.603064] worker_thread+0x49/0x4a0
<4>[ 1211.603064] kthread+0x107/0x140
<4>[ 1211.603064] ? process_one_work+0x6d0/0x6d0
<4>[ 1211.603065] ? kthread_create_on_node+0x40/0x40
<4>[ 1211.603065] ret_from_fork+0x2e/0x40
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=100419
Fixes: 38b19ed7f81ec ("ALSA: hda: fix to wait for RIRB & CORB DMA to set")
Reported-by: Marta Lofstedt <marta.lofstedt@intel.com>
Suggested-by: Takashi Iwai <tiwai@suse.de>
commit ab949d519601880fd46e8bc1445d6a453bf2dc09 upstream.
Imre Deak reported a deadlock of HD-audio driver at unbinding while
it's still in probing. Since we probe the codecs asynchronously in a
work, the codec driver probe may still be kicked off while the
controller itself is being unbound. And, azx_remove() tries to
process all pending tasks via cancel_work_sync() for fixing the other
races (see commit [0b8c82190c12: ALSA: hda - Cancel probe work instead
of flush at remove]), now we may meet a bizarre deadlock:
Unbind snd_hda_intel via sysfs:
device_release_driver() ->
device_lock(snd_hda_intel) ->
azx_remove() ->
cancel_work_sync(azx_probe_work)
azx_probe_work():
codec driver probe() ->
__driver_attach() ->
This deadlock is caused by the fact that both device_release_driver()
and driver_probe_device() take both the device and its parent locks at
the same time. The codec device sets the controller device as its
parent, and this lock is taken before the probe() callback is called,
while the controller remove() callback gets called also with the same
lock.
In this patch, as an ugly workaround, we unlock the controller device
temporarily during cancel_work_sync() call. The race against another
bind call should be still suppressed by the parent's device lock.
Reported-by: Imre Deak <imre.deak@intel.com>
Fixes: 0b8c82190c12 ("ALSA: hda - Cancel probe work instead of flush at remove")
commit 6e4cac23c5a648d50b107d1b53e9c4e1120c7943 upstream.
The FE setups of Intel SST bytcr_rt5640 and bytcr_rt5651 drivers carry
the ignore_suspend flag, and this prevents the suspend/resume working
properly while the stream is running, since SST core code has the
check of the running streams and returns -EBUSY. Drop these
superfluous flags for fixing the behavior.
Also, the bytcr_rt5640 driver lacks of nonatomic flag in some FE
definitions, which leads to the kernel Oops at suspend/resume like:
BUG: scheduling while atomic: systemd-sleep/3144/0x00000003
Call Trace:
dump_stack+0x5c/0x7a
__schedule_bug+0x55/0x70
__schedule+0x63c/0x8c0
schedule+0x3d/0x90
schedule_timeout+0x16b/0x320
? del_timer_sync+0x50/0x50
? sst_wait_timeout+0xa9/0x170 [snd_intel_sst_core]
? remove_wait_queue+0x60/0x60
? sst_prepare_and_post_msg+0x275/0x960 [snd_intel_sst_core]
? sst_pause_stream+0x9b/0x110 [snd_intel_sst_core]
This patch addresses these appropriately, too.
commit 4e7655fd4f47c23e5249ea260dc802f909a64611 upstream.
The snd_use_lock_sync() (thus its implementation
snd_use_lock_sync_helper()) has the 5 seconds timeout to break out of
the sync loop. It was introduced from the beginning, just to be
"safer", in terms of avoiding the stupid bugs.
However, as Ben Hutchings suggested, this timeout rather introduces a
potential leak or use-after-free that was apparently fixed by the
commit 2d7d54002e39 ("ALSA: seq: Fix race during FIFO resize"):
for example, snd_seq_fifo_event_in() -> snd_seq_event_dup() ->
copy_from_user() could block for a long time, and snd_use_lock_sync()
goes timeout and still leaves the cell at releasing the pool.
For fixing such a problem, we remove the break by the timeout while
still keeping the warning.
Suggested-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit dfb00a56935186171abb5280b3407c3f910011f1 upstream.
An abstraction of asynchronous transaction for transmission of MIDI
messages was introduced in Linux v4.4. Each driver can utilize this
abstraction to transfer MIDI messages via fixed-length payload of
transaction to a certain unit address. Filling payload of the transaction
is done by callback. In this callback, each driver can return negative
error code, however current implementation assigns the return value to
unsigned variable.
This commit changes type of the variable to fix the bug.
Reported-by: Julia Lawall <Julia.Lawall@lip6.fr>
Fixes: 585d7cba5e1f ("ALSA: firewire-lib: add helper functions for asynchronous transactions to transfer MIDI messages")
commit 3d016d57fdc5e6caa4cd67896f4b081bccad6e2c upstream.
At a commit 6c29230e2a5f ("ALSA: oxfw: delayed registration of sound
card"), ALSA oxfw driver fails to handle SCS.1m/1d, due to -EBUSY at a call
of snd_card_register(). The cause is that the driver manages to register
two rawmidi instances with the same device number 0. This is a regression
introduced since kernel 4.7.
This commit fixes the regression, by fixing up device property after
discovering stream formats.
Fixes: 6c29230e2a5f ("ALSA: oxfw: delayed registration of sound card")
commit ebf79091bf85d9b2270ab29191de9cd3aaf888c5 upstream.
Select DW_DMAC_CORE like the rest of glue drivers do, e.g.
drivers/dma/dw/Kconfig.
While here group selectors under SND_SOC_INTEL_HASWELL and
SND_SOC_INTEL_BAYTRAIL.
Make platforms, which are using a common SST firmware driver, to be
dependent on DMADEVICES.
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
[ Upstream commit 2ad6f30de7087515a0bc2a718fca6681a57739a0 ]
Some SoCs have a reset line that must be asserted/deasserted.
This patch adds a quirk to handle the new compatible
"allwinner,sun6i-a31-i2s" which will deassert the reset
line on probe function and assert it on remove's one.
This new compatible is useful in case of A33 codec driver, for example.
Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[ Upstream commit a50477e55fff69e1028f25624ee9fc9182d59b1f ]
The existing code assumes a 19.2 MHz MCLK as the default
hardware configuration. This is valid for CherryTrail but
not for Baytrail.
Add explicit MCLK configuration to set the 19.2 clock on/off
depending on DAPM events.
This is a prerequisite step to enable devices with Baytrail
and RT5645 such as Asus X205TA
[ Upstream commit 42648c2270ca0c96935dfc5d0f5c4f8d2406cf75 ]
Fix classic issue of having multiple codecs listed in DSDT
but a single one actually enabled. The previous code did
not handle such errors and could also lead to uninitalized
configurations
[ Upstream commit fd0138dc5d17c636477b371d99265c406437c583 ]
the BIOS reports this codec as RT5640 but it's a rt5670. Use the
quirk mechanism to use the cht_bsw_rt5672 machine driver
[ Upstream commit 93ffeaa8ee3f10a0628ad135b552a2497e0bef2c ]
the BIOS incorrectly reports this codec as 5640 but it is
really a rt5670
[ Upstream commit d25280060835e1b2b84c242905da8334ab15c5b4 ]
rt5670 driver supports also RT5672 codec, but its ACPI ID is missing.
This was found on Dell Wyse 3040 box.
[ Upstream commit 571800487837263e914ef68681e4ad6a57d49c7f ]
There are literally dozens of Insyde devices with a different
name but with the same audio routing. Use a generic quirk to
match on vendor name only to avoid recurring edits of the
same thing.
Signed-off-by: youling257 <youling257@gmail.com>
[ Upstream commit 7f38ca047b0cb54df7f6d9e4110e292e45dba6ad ]
This patch adds native DSD support for the following devices.
- TEAC NT-503
- TEAC UD-503
- TEAC UD-501
(1) Add quirks for native DSD support for TEAC devices.
(2) A specific vendor command is needed to switch between PCM/DOP and
DSD mode, same as Denon/Marantz devices.
Signed-off-by: Nobutaka Okabe <nob77413@gmail.com>
[ Upstream commit 17f08b0d9aafccdb10038ab6dbd9ddb6433c13e2 ]
The Axe-Fx II implicit feedback end point and the data sync endpoint
are in different interface descriptors. Add quirk to ensure a sync
endpoint is properly configured.
Signed-off-by: Alberto Aguirre <albaguirre@gmail.com>
[ Upstream commit bf46241bee7bc3ec28703796f4fbd56085055fca ]
Most Baytrail-CR devices use analog differential microphones,
modify capture default to avoid DMI quirks. Keep digital mics
for all other configurations.
pointer
commit d1a6fe41d3c4ff0d26f0b186d774493555ca5282 upstream.
In 'skl_tplg_set_module_init_data()', a pointer to 'params' member of
'struct skl_algo_data' is calculated, then casted to (u32 *) and assigned
to a member of configuration data. The configuration data is passed to the
other functions and used to process intel IPC. In this processing, the
value of member is used to get message data, however this can bring invalid
memory access in 'skl_set_module_params()' as a result of calculation of
a pointer for actual message data.
(sound/soc/intel/skylake/skl-topology.c)
skl_tplg_init_pipe_modules()
->skl_tplg_set_module_init_data() (has this bug)
->skl_tplg_set_module_params()
(sound/soc/intel/skylake/skl-messages.c)
->skl_set_module_params()
((char *)param) + data_offset
This commit fixes the bug.
Fixes: abb740033b56 ("ASoC: Intel: Skylake: Add support to configure module params")
Signed-off-by: Takashi Sakamoto <takashi.sakamoto@miraclelinux.com>
commit cd3ac9affc43b44f49d7af70d275f0bd426ba643 upstream.
Fix the audio clock rate according to the datasheet.
Reported-by: Dushara Jayasinghe <dushara@successful.com.au>
Signed-off-by: Songjun Wu <songjun.wu@microchip.com>
Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
commit 2f726aec19a9d2c63bec9a8a53a3910ffdcd09f8 upstream.
On this Dell AIO machine, the lineout jack does not work.
We found the pin 0x1a is assigned to lineout on this machine, and in
the past, we applied ALC298_FIXUP_DELL1_MIC_NO_PRESENCE to fix the
heaset-set mic problem for this machine, this fixup will redefine
the pin 0x1a to headphone-mic, as a result the lineout doesn't
work anymore.
After consulting with Dell, they told us this machine doesn't support
microphone via headset jack, so we add a new fixup which only defines
the pin 0x18 as the headset-mic.
[rearranged the fixup insertion position by tiwai in order to make the
merge with other branches easier -- tiwai]
Fixes: 59ec4b57bcae ("ALSA: hda - Fix headset mic detection problem for two dell machines")
commit 2d7d54002e396c180db0c800c1046f0a3c471597 upstream.
When a new event is queued while processing to resize the FIFO in
snd_seq_fifo_clear(), it may lead to a use-after-free, as the old pool
that is being queued gets removed. For avoiding this race, we need to
close the pool to be deleted and sync its usage before actually
deleting it.
The issue was spotted by syzkaller.
commit 3f307834e695f59dac4337a40316bdecfb9d0508 upstream.
A new Dell laptop needs to apply ALC269_FIXUP_DELL1_MIC_NO_PRESENCE to
fix the headset problem, and the pin definiton of this machine is not
in the pin quirk table yet, now adding it to the table.
commit f363a06642f28caaa78cb6446bbad90c73fe183c upstream.
In the commit [15c75b09f8d1: ALSA: ctxfi: Fallback DMA mask to 32bit],
I forgot to put "!" at dam_set_mask() call check in cthw20k1.c (while
cthw20k2.c is OK). This patch fixes that obvious bug.
(As a side note: although the original commit was completely wrong,
it's still working for most of machines, as it sets to 32bit DMA mask
in the end. So the bug severity is low.)
Fixes: 15c75b09f8d1 ("ALSA: ctxfi: Fallback DMA mask to 32bit")
commit c520ff3d03f0b5db7146d9beed6373ad5d2a5e0e upstream.
When snd_seq_pool_done() is called, it marks the closing flag to
refuse the further cell insertions. But snd_seq_pool_done() itself
doesn't clear the cells but just waits until all cells are cleared by
the caller side. That is, it's racy, and this leads to the endless
stall as syzkaller spotted.
This patch addresses the racy by splitting the setup of pool->closing
flag out of snd_seq_pool_done(), and calling it properly before
snd_seq_pool_done().
BugLink: http://lkml.kernel.org/r/CACT4Y+aqqy8bZA1fFieifNxR2fAfFQQABcBHj801+u5ePV0URw@mail.gmail.com
Reported-and-tested-by: Dmitry Vyukov <dvyukov@google.com>
commit 29693efcea0f38cf40d0055d2401490a4f9bf8be upstream.
On this machine, the micmute button is connected to Line2 of the
codec and the micmute led is connected to GPIO2 of the codec.
After applying this quirk, both hotkey and led work well.
commit 493de342748cc6f52938096f5480cf291da58a0b upstream.
Dell Inspiron 17 7000 Gaming laptop needs a similar quirk like
Inspiron 7599 to support its subwoofer speaker.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=194191
commit f3ac9f737603da80c2da3e84b89e74429836bb6d upstream.
The sequencer FIFO management has a bug that may lead to a corruption
(shortage) of the cell linked list. When a sequencer client faces an
error at the event delivery, it tries to put back the dequeued cell.
When the first queue was put back, this forgot the tail pointer
tracking, and the link will be screwed up.
Although there is no memory corruption, the sequencer client may stall
forever at exit while flushing the pending FIFO cells in
snd_seq_pool_done(), as spotted by syzkaller.
This patch addresses the missing tail pointer tracking at
snd_seq_fifo_cell_putback(). Also the patch makes sure to clear the
cell->enxt pointer at snd_seq_fifo_event_in() for avoiding a similar
mess-up of the FIFO linked list.
commit 15c75b09f8d190f89ab4db463b87d411ca349dfe upstream.
Currently ctxfi driver tries to set only the 64bit DMA mask on 64bit
architectures, and bails out if it fails. This causes a problem on
some platforms since the 64bit DMA isn't always guaranteed. We should
fall back to the default 32bit DMA when 64bit DMA fails.
Fixes: 6d74b86d3c0f ("ALSA: ctxfi - Allow 64bit DMA")
commit 71321eb3f2d0df4e6c327e0b936eec4458a12054 upstream.
When a user sets a too small ticks with a fine-grained timer like
hrtimer, the kernel tries to fire up the timer irq too frequently.
This may lead to the condensed locks, eventually the kernel spinlock
lockup with warnings.
For avoiding such a situation, we define a lower limit of the
resolution, namely 1ms. When the user passes a too small tick value
that results in less than that, the kernel returns -EINVAL now.
commit e7480b34ad1ab84a63540b2c884cb92c0764ab74 upstream.
Like for Sunrise Point, the total stream number of Lewisburg's
input and output stream exceeds 15 (GCAP is 0x9701), which will
cause some streams do not work because of the overflow on
SDxCTL.STRM field if using the legacy stream tag allocation method.
Fixes: 5cf92c8b3dc5 ("ALSA: hda - Add Intel Lewisburg device IDs Audio")
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
