path: root/sound
2013-11-22Merge tag 'sound-fix2-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull second set of sound fixes from Takashi Iwai: "A collection of small fixes in HD-audio quirks and runtime PM, ASoC rcar, abs8500 and other codecs. Most of commits are for stable kernels, too" * tag 'sound-fix2-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Set current_headset_type to ALC_HEADSET_TYPE_ENUM (janitorial) ALSA: hda - Provide missing pin configs for VAIO with ALC260 ALSA: hda - Add headset quirk for Dell Inspiron 3135 ALSA: hda - Fix the headphone jack detection on Sony VAIO TX ALSA: hda - Fix missing bass speaker on ASUS N550 ALSA: hda - Fix unbalanced runtime PM notification at resume ASoC: arizona: Set FLL to free-run before disabling ALSA: hda - A casual Dell Headset quirk ASoC: rcar: fixup dma_async_issue_pending() timing ASoC: rcar: off by one in rsnd_scu_set_route() ASoC: wm5110: Add post SYSCLK register patch for rev D chip ASoC: ab8500: Revert to using custom I/O functions ALSA: hda - Also enable mute/micmute LED control for "Lenovo dock" fixup ALSA: firewire-lib: include sound/asound.h to refer to snd_pcm_format_t ALSA: hda - Select FW_LOADER from CONFIG_SND_HDA_CODEC_CA0132_DSP ALSA: hda - Enable mute/mic-mute LEDs for more Thinkpads with Realtek codec ASoC: rcar: fixup mod access before checking
2013-11-22ALSA: hda - Set current_headset_type to ALC_HEADSET_TYPE_ENUM (janitorial)David Henningsson
current_headset_type should be of the HEADSET_TYPE enum, not the HEADSET_MODE enum. Since ALC_HEADSET_TYPE_UNKNOWN and ALC_HEADSET_MODE_UNKNOWN are both 0, this patch is just janitorial. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-22ALSA: hda - Provide missing pin configs for VAIO with ALC260Takashi Iwai
Some models (or maybe depending on BIOS version) of Sony VAIO with ALC260 give no proper pin configurations as default, resulting in the non-working speaker, etc. Just provide the whole pin configurations via a fixup. Reported-by: Matthew Markus <mmarkus@hearit.co> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-21Merge tag 'asoc-v3.13-5' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.13 A bunch of device specific fixes, nothing with a general impact here.
2013-11-21ALSA: hda - Add headset quirk for Dell Inspiron 3135David Henningsson
Cc: stable@vger.kernel.org (3.10+) BugLink: https://bugs.launchpad.net/bugs/1253636 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-21ALSA: hda - Fix the headphone jack detection on Sony VAIO TXTakashi Iwai
BIOS sets MISC_NO_PRESENCE bit wrongly to the pin config on NID 0x0f. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-21ALSA: hda - Fix missing bass speaker on ASUS N550Takashi Iwai
The laptop has a built-in speaker on NID 0x1a. It's an LFE only on the right channel, so we need to provide an explicit chmap, too. There might be other surround speakers, but they can fixed in addition at later point, so let's fix the easier bass speaker at first. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=65091 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-20Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine changes from Vinod Koul: "This brings for slave dmaengine: - Change dma notification flag to DMA_COMPLETE from DMA_SUCCESS as dmaengine can only transfer and not verify validaty of dma transfers - Bunch of fixes across drivers: - cppi41 driver fixes from Daniel - 8 channel freescale dma engine support and updated bindings from Hongbo - msx-dma fixes and cleanup by Markus - DMAengine updates from Dan: - Bartlomiej and Dan finalized a rework of the dma address unmap implementation. - In the course of testing 1/ a collection of enhancements to dmatest fell out. Notably basic performance statistics, and fixed / enhanced test control through new module parameters 'run', 'wait', 'noverify', and 'verbose'. Thanks to Andriy and Linus [Walleij] for their review. - Testing the raid related corner cases of 1/ triggered bugs in the recently added 16-source operation support in the ioatdma driver. - Some minor fixes / cleanups to mv_xor and ioatdma" * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (99 commits) dma: mv_xor: Fix mis-usage of mmio 'base' and 'high_base' registers dma: mv_xor: Remove unneeded NULL address check ioat: fix ioat3_irq_reinit ioat: kill msix_single_vector support raid6test: add new corner case for ioatdma driver ioatdma: clean up sed pool kmem_cache ioatdma: fix selection of 16 vs 8 source path ioatdma: fix sed pool selection ioatdma: Fix bug in selftest after removal of DMA_MEMSET. dmatest: verbose mode dmatest: convert to dmaengine_unmap_data dmatest: add a 'wait' parameter dmatest: add basic performance metrics dmatest: add support for skipping verification and random data setup dmatest: use pseudo random numbers dmatest: support xor-only, or pq-only channels in tests dmatest: restore ability to start test at module load and init dmatest: cleanup redundant "dmatest: " prefixes dmatest: replace stored results mechanism, with uniform messages Revert "dmatest: append verify result to results" ...
2013-11-20ALSA: hda - Fix unbalanced runtime PM notification at resumeTakashi Iwai
When a codec is resumed, it keeps the power on while the resuming phase via hda_keep_power_on(), then turns down via snd_hda_power_down(). At that point, snd_hda_power_down() notifies the power down to the controller, and this may confuse the refcount if the codec was already powered up before the resume. In the end result, the controller goes to runtime suspend even before the codec is kicked off to the power save, and the communication stalls happens. The fix is to add the power-up notification together with hda_keep_power_on(), and clears the flag appropriately. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-20Merge remote-tracking branch 'asoc/fix/wm8962' into asoc-linusMark Brown
2013-11-20Merge remote-tracking branch 'asoc/fix/rcar' into asoc-linusMark Brown
2013-11-20Merge remote-tracking branch 'asoc/fix/fsl' into asoc-linusMark Brown
2013-11-20Merge remote-tracking branch 'asoc/fix/dma' into asoc-linusMark Brown
2013-11-20Merge remote-tracking branch 'asoc/fix/cs42l52' into asoc-linusMark Brown
2013-11-20Merge remote-tracking branch 'asoc/fix/blackfin' into asoc-linusMark Brown
2013-11-20Merge remote-tracking branch 'asoc/fix/arizona' into asoc-linusMark Brown
2013-11-20Merge remote-tracking branch 'asoc/fix/ab8500' into asoc-linusMark Brown
2013-11-20ASoC: arizona: Set FLL to free-run before disablingRichard Fitzgerald
The FLL must be placed into free-run mode before disabling to allow it to entirely shut down. Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2013-11-20ALSA: hda - A casual Dell Headset quirkDavid Henningsson
You're looking at a casual headset patch, for a specific hardware it will match, and suddenly, the headset jack will work, so please apply this simple quirk! BugLink: https://bugs.launchpad.net/bugs/1253038 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-19ASoC: rcar: fixup dma_async_issue_pending() timingKuninori Morimoto
DMAEngine will stall without this patch Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-11-19ASoC: rcar: off by one in rsnd_scu_set_route()Dan Carpenter
If "id == ARRAY_SIZE(routes)" then we read one space beyond the end of the routes[] array. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-11-19ASoC: wm5110: Add post SYSCLK register patch for rev D chipCharles Keepax
Certain registers require patching after the SYSCLK has been brought up add support for this into the CODEC driver. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2013-11-19ASoC: ab8500: Revert to using custom I/O functionsLee Jones
It's been reported that these break audio on Snowball so revert them until a Snowball user has time to investigate. Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-11-19ALSA: hda - Also enable mute/micmute LED control for "Lenovo dock" fixupDavid Henningsson
The docking station is a Thinkpad thing, so it makes sense to check for mute/micmute LEDs for that quirk type too. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-19ALSA: firewire-lib: include sound/asound.h to refer to snd_pcm_format_tTakashi Sakamoto
'snd_pcm_format_t' is used by amdtp_out_stream_set_pcm_format(). Currently, when just including amdtp.h, compiler cannot find this type because this type is defined in uapi/sound/asound.h and this header is not included by amdtp.h. Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-18Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c changes from Wolfram Sang: - new drivers for exynos5, bcm kona, and st micro - bigger overhauls for drivers mxs and rcar - typical driver bugfixes, cleanups, improvements - got rid of the superfluous 'driver' member in i2c_client struct This touches a few drivers in other subsystems. All acked. * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits) i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe() i2c: i2c-eg20t: do not print error message in syslog if no ACK received i2c: bcm-kona: Introduce Broadcom I2C Driver i2c: cbus-gpio: Fix device tree binding i2c: wmt: add missing clk_disable_unprepare() on error i2c: designware: add new ACPI IDs i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCH i2c: exynos5: Remove incorrect clk_disable_unprepare i2c: i2c-st: Add ST I2C controller i2c: exynos5: add High Speed I2C controller driver i2c: rcar: fixup rcar type naming i2c: scmi: remove some bogus NULL checks i2c: sh_mobile & rcar: Enable the driver on all ARM platforms i2c: sh_mobile: Convert to clk_prepare/unprepare i2c: mux: gpio: use reg value for i2c_add_mux_adapter i2c: mux: gpio: use gpio_set_value_cansleep() i2c: Include linux/of.h header i2c: mxs: Fix PIO mode on i.MX23 i2c: mxs: Rework the PIO mode operation i2c: mxs: distinguish i.MX23 and i.MX28 based I2C controller ...
2013-11-18ALSA: hda - Select FW_LOADER from CONFIG_SND_HDA_CODEC_CA0132_DSPTakashi Iwai
Use select FW_LOADER instead of depends on. It's more intuitive and more consistent with other entries. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-18ALSA: hda - Enable mute/mic-mute LEDs for more Thinkpads with Realtek codecDavid Henningsson
We're using the ACPI interface to detect whether we're dealing with a Thinkpad or not. This way we're not loading the thinkpad_acpi module when we're not on a Thinkpad, but at the same time, we give the opportunity to check for, and potentially enable, both present and future Thinkpad with mute/micmute LEDs. At least those running the ALC269 family (269 to 299) of Realtek codecs. Cc: Alex Hung <alex.hung@canonical.com> Tested-by: Hui Wang <hui.wang@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-18ASoC: rcar: fixup mod access before checkingKuninori Morimoto
rsnd_dai_connect() is using mod before NULL checking. This patch fixes it up Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-11-16Merge tag 'sound-fix-3.13-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Two peaks in diffstat are for the audio EQ init of IDT codecs and the EMU2004 usb mixer addition, both of which are pretty device-specific, so safe to apply. The rest are a bunch of small fixes, most of them are regression fixes" * tag 'sound-fix-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (26 commits) ALSA: hda - load EQ params into IDT codec on HP bNB13 systems ASoC: cs42l52: Correct MIC CTL mask ASoC: wm8962: Turn on regcache_cache_only before disabling regulator ALSA: jack: Unregister input device at disconnection ALSA: pcsp: Fix the order of input device unregistration ASoC: fsl: imx-pcm-fiq: omit fiq counter to avoid harm in unbalanced situations ASoC: blackfin: Fix missing break ALSA: usb-audio: add front jack channel selector for EMU0204 ALSA: hda - Don't clear the power state at snd_hda_codec_reset() ASoC: arizona: Fix typo in name of EQ coefficient controls ALSA: hda - Control EAPD for Master volume on Lenovo N100 ALSA: hda - Don't turn off EAPD for headphone on Lenovo N100 ALSA: isa: not allocating enough space ALSA: snd-aoa: two copy and paste bugs ASoC: wm8997: Correct typo in ISRC mux routes ALSA: hda - Check keep_eapd_on before inv_eapd ALSA: hda - Fix Line Out automute on Realtek multifunction jacks ALSA: msnd: Avoid duplicated driver name ALSA: compress_core: don't return -EBADFD from poll if paused ALSA: hda - hdmi: Fix wrong baseline length in ATI/AMD generated ELD ...
2013-11-16Merge tag 'asoc-v3.13-4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Fixes for v3.13 A few fixes in drivers, the i.MX and wm8962 fixes are for a pretty nasty issues for users of those drivers if they run into them.
2013-11-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual earth-shaking, news-breaking, rocket science pile from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) doc: usb: Fix typo in Documentation/usb/gadget_configs.txt doc: add missing files to timers/00-INDEX timekeeping: Fix some trivial typos in comments mm: Fix some trivial typos in comments irq: Fix some trivial typos in comments NUMA: fix typos in Kconfig help text mm: update 00-INDEX doc: Documentation/DMA-attributes.txt fix typo DRM: comment: `halve' -> `half' Docs: Kconfig: `devlopers' -> `developers' doc: typo on word accounting in kprobes.c in mutliple architectures treewide: fix "usefull" typo treewide: fix "distingush" typo mm/Kconfig: Grammar s/an/a/ kexec: Typo s/the/then/ Documentation/kvm: Update cpuid documentation for steal time and pv eoi treewide: Fix common typo in "identify" __page_to_pfn: Fix typo in comment Correct some typos for word frequency clk: fixed-factor: Fix a trivial typo ...
2013-11-15ALSA: hda - load EQ params into IDT codec on HP bNB13 systemsVitaliy Kulikov
Adds linear EQ filtering for integrated speaker protection Signed-off-by: Vitaliy Kulikov <vitaliy.kulikov@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-15Merge remote-tracking branch 'asoc/fix/wm8962' into asoc-linusMark Brown
2013-11-15Merge remote-tracking branch 'asoc/fix/fsl' into asoc-linusMark Brown
2013-11-15Merge remote-tracking branch 'asoc/fix/dma' into asoc-linusMark Brown
2013-11-15Merge remote-tracking branch 'asoc/fix/cs42l52' into asoc-linusMark Brown
2013-11-15Merge remote-tracking branch 'asoc/fix/blackfin' into asoc-linusMark Brown
2013-11-15Merge remote-tracking branch 'asoc/fix/arizona' into asoc-linusMark Brown
2013-11-15ASoC: cs42l52: Correct MIC CTL maskBrian Austin
The mask for CS42L52_MIC_CTL_TYPE_MASK was wrong keeping the mic config from being set correctly. Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2013-11-15sound/core/memalloc.c: use gen_pool_dma_alloc() to allocate iram bufferNicolin Chen
Since gen_pool_dma_alloc() is introduced, we implement it to simplify code. Signed-off-by: Nicolin Chen <b42378@freescale.com> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-14ASoC: wm8962: Turn on regcache_cache_only before disabling regulatorNicolin Chen
It's safer to turn on regcache_cache_only before disabling regulator since the driver will turn off the regcache_cache_only after enabling regulator. If we remain cache_only false, some command like 'amixer cset' would get failure if being run before wm8962_resume(). Signed-off-by: Nicolin Chen <b42378@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2013-11-14ALSA: jack: Unregister input device at disconnectionTakashi Iwai
The recent change in sysfs triggered a kernel WARNING at unloading a sound driver like WARNING: CPU: 3 PID: 2247 at fs/sysfs/group.c:214 sysfs_remove_group+0xe8/0xf0() sysfs group ffffffff81ab7b20 not found for kobject 'event14' for each jack instance. It's because the unregistration of jack input device is done in dev_free callback, which is called after snd_card_disconnect(). Since device_unregister(card->card_dev) is called in snd_card_disconnect(), the whole sysfs entries belonging to card->card_dev have been already removed recursively. Thus this results in a warning as input_unregister_device() yet tries to unregister the already removed sysfs entry. For fixing this mess, we need to unregister the jack input device at dev_disconnect callback so that it's called before unregistering the card->card_dev. Reviwed-by: Mark Brown <broonie@linaro.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-14ALSA: pcsp: Fix the order of input device unregistrationTakashi Iwai
The current code may access to the already freed object. The input device must be accessed and unregistered before freeing the top level sound object. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-14ASoC: fsl: imx-pcm-fiq: omit fiq counter to avoid harm in unbalanced situationsOskar Schirmer
Unbalanced calls to snd_imx_pcm_trigger() may result in endless FIQ activity and thus provoke eternal sound. While on the first glance, the switch statement looks pretty symmetric, the SUSPEND/RESUME pair is not: the suspend case comes along snd_pcm_suspend_all(), which for fsl/imx-pcm-fiq is called only at snd_soc_suspend(), but the resume case originates straight from the SNDRV_PCM_IOCTL_RESUME. This way userland may provoke an unbalanced resume, which might cause the fiq_enable counter to increase and never return to zero again, so eventually imx_pcm_fiq is never disabled. Simply removing the fiq_enable will solve the problem, as long as one never goes play and capture game simultaneously, but beware trying both at once, the early TRIGGER_STOP will cut off the other activity prematurely. So now playing and capturing is scrutinized separately, instead of by counting. Signed-off-by: Oskar Schirmer <oskar@scara.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2013-11-14Merge branch 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull DMA mask updates from Russell King: "This series cleans up the handling of DMA masks in a lot of drivers, fixing some bugs as we go. Some of the more serious errors include: - drivers which only set their coherent DMA mask if the attempt to set the streaming mask fails. - drivers which test for a NULL dma mask pointer, and then set the dma mask pointer to a location in their module .data section - which will cause problems if the module is reloaded. To counter these, I have introduced two helper functions: - dma_set_mask_and_coherent() takes care of setting both the streaming and coherent masks at the same time, with the correct error handling as specified by the API. - dma_coerce_mask_and_coherent() which resolves the problem of drivers forcefully setting DMA masks. This is more a marker for future work to further clean these locations up - the code which creates the devices really should be initialising these, but to fix that in one go along with this change could potentially be very disruptive. The last thing this series does is prise away some of Linux's addition to "DMA addresses are physical addresses and RAM always starts at zero". We have ARM LPAE systems where all system memory is above 4GB physical, hence having DMA masks interpreted by (eg) the block layers as describing physical addresses in the range 0..DMAMASK fails on these platforms. Santosh Shilimkar addresses this in this series; the patches were copied to the appropriate people multiple times but were ignored. Fixing this also gets rid of some ARM weirdness in the setup of the max*pfn variables, and brings ARM into line with every other Linux architecture as far as those go" * 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits) ARM: 7805/1: mm: change max*pfn to include the physical offset of memory ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit() ARM: DMA-API: better handing of DMA masks for coherent allocations ARM: 7857/1: dma: imx-sdma: setup dma mask DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks DMA-API: dcdbas: update DMA mask handing DMA-API: dma: edma.c: no need to explicitly initialize DMA masks DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks DMA-API: crypto: remove last references to 'static struct device *dev' DMA-API: crypto: fix ixp4xx crypto platform device support DMA-API: others: use dma_set_coherent_mask() DMA-API: staging: use dma_set_coherent_mask() DMA-API: usb: use new dma_coerce_mask_and_coherent() DMA-API: usb: use dma_set_coherent_mask() DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent() DMA-API: net: octeon: use dma_coerce_mask_and_coherent() DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent() ...
2013-11-13ASoC: blackfin: Fix missing breakTakashi Iwai
Fixes: 4b2ffc205cb9 ('ASoC: Blackfin I2S: add 8-bit sample support') Reported-by: David Binderman Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2013-11-13ALSA: usb-audio: add front jack channel selector for EMU0204Vasily Khoruzhick
Add support for front jack channel selector which is present on EMU0204. It allows to get 4 channels out of this soundcard. Tested-by: Yury Bushmelev <jay@jay-tech.ru> Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-11-13ALSA: hda - Don't clear the power state at snd_hda_codec_reset()Takashi Iwai
snd_hda_codec_reset() is called either in resetting the whole setup at error paths or hwdep clear/reconfig sysfs triggers. But all of these don't assume that the power has to be off, rather they want to keep the power state unchanged (e.g. reconfig_codec() calls the power up/down by itself). Thus, unconditionally clearing the power state in snd_hda_codec_reset() leads to the inconsistency, confuses the further operation. This patch gets rid of the lines doing that bad thing. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
