toradex_4.9-1.0.x-imx-next
This is the 4.9.87 stable release
drivers/dma/fsl-edma.c
commit 71db96ddfa72671bd43cacdcc99ca178d90ba267 upstream.
We've added a quirk to enable the recent Lenovo dock support, where it
overwrites the pin configs of NID 0x17 and 19, not only updating the
pin config cache. It works right after the boot, but the problem is
that the pin configs are occasionally cleared when the machine goes to
PM. Meanwhile the quirk writes the pin configs only at the pre-probe,
so this won't be applied any longer.
For addressing that issue, this patch moves the code to overwrite the
pin configs into HDA_FIXUP_ACT_INIT section so that it's always
applied at both probe and resume time.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195161
Fixes: 61fcf8ece9b6 ("ALSA: hda/realtek - Enable Thinkpad Dock device for ALC298 platform")
Cc: <stable@vger.kernel.org>
commit 1ba8f9d308174e647b864c36209b4d7934d99888 upstream.
On some boards setting power_save to a non 0 value leads to clicking /
popping sounds when ever we enter/leave powersaving mode. Ideally we would
figure out how to avoid these sounds, but that is not always feasible.
This commit adds a blacklist for devices where powersaving is known to
cause problems and disables it on these devices.
Note I tried to put this blacklist in userspace first:
https://github.com/systemd/systemd/pull/8128
But the systemd maintainers rightfully pointed out that it would be
impossible to then later remove entries once we actually find a way to
make power-saving work on listed boards without issues. Having this list
in the kernel will allow removal of the blacklist entry in the same commit
which fixes the clicks / plops.
The blacklist only applies to the default power_save module-option value,
if a user explicitly sets the module-option then the blacklist is not
used.
[ added an ifdef CONFIG_PM for the build error -- tiwai]
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1525104
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=198611
Cc: stable@vger.kernel.org
commit 240a8af929c7c57dcde28682725b29cf8474e8e5 upstream.
The capture interface doesn't work and the playback interface only
supports 48 kHz sampling rate even though it advertises more rates.
Signed-off-by: Erik Veijola <erik.veijola@gmail.com>
[ Upstream commit d070f7c703ef26e3db613f24206823f916272fc6 ]
In skylake platform, we hear a loud pop noise(0 dB) at start of
audio capture power up sequence. This patch removes the pop noise
from the recording by adding a delay before enabling ADC.
Signed-off-by: Abhijeet Kumar <abhijeet.kumar@intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
This is the 4.9.84 stable release
commit 46a049dae771b95e77ac6c823330f4a60f600236 upstream.
gcc-7 caught what it considers a NULL pointer dereference:
sound/pci/hda/patch_ca0132.c: In function 'dspio_scp.constprop':
sound/pci/hda/patch_ca0132.c:1487:4: error: argument 1 null where non-null expected [-Werror=nonnull]
This is plausible from looking at the function, as we compare 'reply'
to NULL earlier in it. I have not tried to analyze if there are constraints
that make it impossible to hit the bug, but adding another NULL check in
the end kills the warning and makes the function more robust.
[ Upstream commit c7b92172a61b91936be985cb9bc499a4ebc6489b ]
Disable the clocks in rk_spdif_probe when an error occurs after one
of the clocks has been enabled previously.
Found by Linux Driver Verification project (linuxtesting.org).
Fixes: f874b80e1571 ASoC: rockchip: Add rockchip SPDIF transceiver driver
Signed-off-by: Stefan Potyra <Stefan.Potyra@elektrobit.com>
commit 1783c9d7cb7bc3181b9271665959b87280d98d8e upstream.
This adds MODULE_LICENSE/AUTHOR/DESCRIPTION tags to the ux500
platform drivers, to avoid these build warnings:
WARNING: modpost: missing MODULE_LICENSE() in sound/soc/ux500/snd-soc-ux500-plat-dma.o
WARNING: modpost: missing MODULE_LICENSE() in sound/soc/ux500/snd-soc-ux500-mach-mop500.o
The company no longer exists, so the email addresses of the authors
don't work any more, but I've added them anyway for consistency.
commit d15d662e89fc667b90cd294b0eb45694e33144da upstream.
ALSA sequencer core initializes the event pool on demand by invoking
snd_seq_pool_init() when the first write happens and the pool is
empty. Meanwhile user can reset the pool size manually via ioctl
concurrently, and this may lead to UAF or out-of-bound accesses since
the function tries to vmalloc / vfree the buffer.
A simple fix is to just wrap the snd_seq_pool_init() call with the
recently introduced client->ioctl_mutex; as the calls for
snd_seq_pool_init() from other side are always protected with this
mutex, we can avoid the race.
Reported-by: 范龙飞 <long7573@126.com>
commit 5e35dc0338d85ccebacf3f77eca1e5dea73155e8 upstream.
Add quirk to ensure a sync endpoint is properly configured.
This patch is a fix for same symptoms on Behringer UFX1204 as patch
from Albertto Aquirre on Dec 8 2016 for Axe-Fx II.
Signed-off-by: Lassi Ylikojola <lassi.ylikojola@gmail.com>
commit fdcc968a3b290407bcba9d4c90e2fba6d8d928f1 upstream.
These laptops have a combined jack to attach headsets, the U727 on
the left, the U757 on the right, but a headsets microphone doesn't
work. Using hdajacksensetest I found that pin 0x19 changed the
present state when plugging the headset, in addition to 0x21, but
didn't have the correct configuration (shown as "Not connected").
So this sets the configuration to the same values as the headphone
pin 0x21 except for the device type microphone, which makes it
work correctly. With the patch the configured pins for U727 are
Pin 0x12 (Internal Mic, Mobile-In): present = No
Pin 0x14 (Internal Speaker): present = No
Pin 0x19 (Black Mic, Left side): present = No
Pin 0x1d (Internal Aux): present = No
Pin 0x21 (Black Headphone, Left side): present = No
Signed-off-by: Jan-Marek Glogowski <glogow@fbihome.de>
commit 61fcf8ece9b6b09450250c4ca40cc3b81a96a68d upstream.
Thinkpad Dock device support for ALC298 platform.
It need to use SSID for the quirk table.
Because IdeaPad also has ALC298 platform.
Use verb for the quirk table will confuse.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit 447cae58cecd69392b74a4a42cd0ab9cabd816af upstream.
The layout of the UAC2 Control request and response varies depending on
the request type. With the current implementation, only the Layout 2
Parameter Block (with the 2-byte sized RANGE attribute) is handled
properly. For the Control requests with the 1-byte sized RANGE attribute
(Bass Control, Mid Control, Tremble Control), the response is parsed
incorrectly.
This commit:
* fixes the wLength field value in the request
* fixes parsing the range values from the response
Fixes: 23caaf19b11e ("ALSA: usb-mixer: Add support for Audio Class v2.0")
Signed-off-by: Kirill Marinushkin <k.marinushkin@gmail.com>
commit 3f2f7c553d077be6a30cb96b2976a2c940bf5335 upstream.
One of them has the codec of alc256 and the other one has the codec
of alc289.
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit 20a1ea2222e7cbf96e9bf8579362e971491e6aea upstream.
I got the following kernel warning when loading snd-soc-skl module on
Dell Latitude 7270 laptop:
memremap attempted on mixed range 0x0000000000000000 size: 0x0
WARNING: CPU: 0 PID: 484 at kernel/memremap.c:98 memremap+0x8a/0x180
Call Trace:
skl_nhlt_init+0x82/0xf0 [snd_soc_skl]
skl_probe+0x2ee/0x7c0 [snd_soc_skl]
It seems that the machine doesn't support the SKL DSP gives the empty
NHLT entry, and it triggers the warning. For avoiding it, let do the
zero check before calling memremap().
commit c66234cfedfc3e6e3b62563a5f2c1562be09a35d upstream.
When restoring registers during runtime resume, we must not write to
I2S_TXDR which is the transmit FIFO as this queues up a sample to be
output and pushes all of the output channels down by one.
This can be demonstrated with the speaker-test utility:
for i in a b c; do speaker-test -c 2 -s 1; done
which should play a test through the left speaker three times but if the
I2S hardware starts runtime suspended the first sample will be played
through the right speaker.
Fix this by marking I2S_TXDR as volatile (which also requires marking it
as readble, even though it technically isn't). This seems to be the
most robust fix, the alternative of giving I2S_TXDR a default value is
more fragile since it does not prevent regcache writing to the register
in all circumstances.
While here, also fix the configuration of I2S_RXDR and I2S_FIFOLR; these
are not writable so they do not suffer from the same problem as I2S_TXDR
but reading from I2S_RXDR does suffer from a similar problem.
Fixes: f0447f6cbb20 ("ASoC: rockchip: i2s: restore register during runtime_suspend/resume cycle", 2016-09-07)
Signed-off-by: John Keeping <john@metanate.com>
commit e0936c3471a8411a5df327641fa3ffe12a2fb07b upstream.
commit 1f8754d4daea5f ("ASoC: rsnd: don't call free_irq() on
Parent SSI") fixed Parent SSI duplicate free_irq().
But on Renesas Sound, not only Parent SSI but also Multi SSI
have same issue.
This patch avoid duplicate free_irq() if it was not pure SSI.
Fixes: 1f8754d4daea5f ("ASoC: rsnd: don't call free_irq() on Parent SSI")
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: thongsyho <thong.ho.px@rvc.renesas.com>
Signed-off-by: Nhan Nguyen <nhan.nguyen.yb@renesas.com>
commit 1f8754d4daea5f257370a52a30fcb22798c54516 upstream.
If SSI uses shared pin, some SSI will be used as parent SSI.
Then, normal SSI's remove and Parent SSI's remove
(these are same SSI) will be called when unbind or remove timing.
In this case, free_irq() will be called twice.
This patch solve this issue.
Tested-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
Reported-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
commit 7ac45d1635a4cd2e99a4b11903d4a2815ca1b27b upstream.
In case cpu could not be found the error message would always refer to
/codec/ not being found in DT. Fix this by catching the cpu node not found
case explicitly.
Signed-off-by: Julian Scheel <julian@jusst.de>
commit 0cab20cec0b663b7be8e2be5998d5a4113647f86 upstream.
This change resolves a new compile-time warning
when built as a loadable module:
WARNING: modpost: missing MODULE_LICENSE() in sound/soc/codecs/snd-soc-pcm512x-spi.o
see include/linux/module.h for more information
This adds the license as "GPL v2", which matches the header of the file.
MODULE_DESCRIPTION and MODULE_AUTHOR are also added.
Signed-off-by: Jesse Chan <jc@linux.com>
This is the 4.9.76 stable release
Resolved conflicts
drivers/clk/imx/clk-imx6q.c
drivers/net/ethernet/freescale/fec_main.c
commit 031f335cda879450095873003abb03ae8ed3b74a upstream.
iMac 14,1 requires the same quirk as iMac 12,2, using GPIO 2 and 3 for
headphone and speaker output amps. Add the codec SSID quirk entry
(106b:0600) accordingly.
BugLink: http://lkml.kernel.org/r/CAEw6Zyteav09VGHRfD5QwsfuWv5a43r0tFBNbfcHXoNrxVz7ew@mail.gmail.com
Reported-by: Freaky <freaky2000@gmail.com>
commit e4c9fd10eb21376f44723c40ad12395089251c28 upstream.
There is another Dell XPS 13 variant (SSID 1028:082a) that requires
the existing fixup for reducing the headphone noise.
This patch adds the quirk entry for that.
BugLink: http://lkml.kernel.org/r/CAHXyb9ZCZJzVisuBARa+UORcjRERV8yokez=DP1_5O5isTz0ZA@mail.gmail.com
Reported-and-tested-by: Francisco G. <frangio.1@gmail.com>
commit 23b19b7b50fe1867da8d431eea9cd3e4b6328c2c upstream.
muldiv32() contains a snd_BUG_ON() (which is morphed as WARN_ON() with
debug option) for checking the case of 0 / 0. This would be helpful
if this happens only as a logical error; however, since the hw refine
is performed with any data set provided by user, the inconsistent
values that can trigger such a condition might be passed easily.
Actually, syzbot caught this by passing some zero'ed old hw_params
ioctl.
So, having snd_BUG_ON() there is simply superfluous and rather
harmful to give unnecessary confusions. Let's get rid of it.
Reported-by: syzbot+7e6ee55011deeebce15d@syzkaller.appspotmail.com
commit b3defb791b26ea0683a93a4f49c77ec45ec96f10 upstream.
The ALSA sequencer ioctls have no protection against racy calls while
the concurrent operations may lead to interfere with each other. As
reported recently, for example, the concurrent calls of setting client
pool with a combination of write calls may lead to either the
unkillable dead-lock or UAF.
As a slightly big hammer solution, this patch introduces the mutex to
make each ioctl exclusive. Although this may reduce performance via
parallel ioctl calls, usually it's not demanded for sequencer usages,
hence it should be negligible.
Reported-by: Luo Quan <a4651386@163.com>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 898dfe4687f460ba337a01c11549f87269a13fa2 upstream.
The aloop driver tries to update the hw constraints of the connected
target on the cable of the opened PCM substream. This is done by
adding the extra hw constraints rules referring to the substream
runtime->hw fields, while the other substream may update the runtime
hw of another side on the fly.
This is, however, racy and may result in the inconsistent values when
both PCM streams perform the prepare concurrently. One of the reason
is that it overwrites the other's runtime->hw field; which is not only
racy but also broken when it's called before the open of another side
finishes. And, since the reference to runtime->hw isn't protected,
the concurrent write may give the partial value update and become
inconsistent.
This patch is an attempt to fix and clean up:
- The prepare doesn't change the runtime->hw of other side any longer,
but only update the cable->hw that is referred commonly.
- The extra rules refer to the loopback_pcm object instead of the
runtime->hw. The actual hw is deduced from cable->hw.
- The extra rules take the cable_lock to protect against the race.
Fixes: b1c73fc8e697 ("ALSA: snd-aloop: Fix hw_params restrictions and checking")
commit b088b53e20c7d09b5ab84c5688e609f478e5c417 upstream.
The extra hw constraint rule for the formats the aloop driver
introduced has a slight flaw, where it doesn't return a positive value
when the mask got changed. It came from the fact that it's basically
a copy&paste from snd_hw_constraint_mask64(). The original code is
supposed to be a single-shot and it modifies the mask bits only once
and never after, while what we need for aloop is the dynamic hw rule
that limits the mask bits.
This difference results in the inconsistent state, as the hw_refine
doesn't apply the dependencies fully. The worse and surprisingly
result is that it causes a crash in OSS emulation when multiple
full-duplex reads/writes are performed concurrently (I leave why it
triggers Oops to readers as a homework).
For fixing this, replace a few open-codes with the standard
snd_mask_*() macros.
Reported-by: syzbot+3902b5220e8ca27889ca@syzkaller.appspotmail.com
commit 9685347aa0a5c2869058ca6ab79fd8e93084a67f upstream.
The aloop runtime object and its assignment in the cable are left even
when opening a substream fails. This doesn't mean any memory leak,
but it still keeps the invalid pointer that may be referred by the
another side of the cable spontaneously, which is a potential Oops
cause.
Clean up the cable assignment and the empty cable upon the error path
properly.
Fixes: 597603d615d2 ("ALSA: introduce the snd-aloop module for the PCM loopback")
commit 900498a34a3ac9c611e9b425094c8106bdd7dc1c upstream.
PCM OSS read/write loops keep taking the mutex lock for the whole
read/write, and this might take very long when the exceptionally high
amount of data is given. Also, since it invokes with mutex_lock(),
the concurrent read/write becomes unbreakable.
This patch tries to address these issues by replacing mutex_lock()
with mutex_lock_interruptible(), and also splits / re-takes the lock
at each read/write period chunk, so that it can switch the context
more finely if requested.
commit 29159a4ed7044c52e3e2cf1a9fb55cec4745c60b upstream.
The loops for read and write in PCM OSS emulation have no proper check
of pending signals, and they keep processing even after user tries to
break. This results in a very long delay, often seen as RCU stall
when a huge unprocessed bytes remain queued. The bug could be easily
triggered by syzkaller.
As a simple workaround, this patch adds the proper check of pending
signals and aborts the loop appropriately.
Reported-by: syzbot+993cb4cfcbbff3947c21@syzkaller.appspotmail.com
commit 6708913750344a900f2e73bfe4a4d6dbbce4fe8d upstream.
In the OSS emulation plugin builder where the frame size is parsed in
the plugin chain, some places miss the possible errors returned from
the plugin src_ or dst_frames callback.
This patch papers over such places.
commit fe08f34d066f4404934a509b6806db1a4f700c86 upstream.
syzkaller triggered kernel warnings through PCM OSS emulation at
closing a stream:
WARNING: CPU: 0 PID: 3502 at sound/core/pcm_lib.c:1635
snd_pcm_hw_param_first+0x289/0x690 sound/core/pcm_lib.c:1635
Call Trace:
snd_pcm_hw_param_near.constprop.27+0x78d/0x9a0 sound/core/oss/pcm_oss.c:457
snd_pcm_oss_change_params+0x17d3/0x3720 sound/core/oss/pcm_oss.c:969
snd_pcm_oss_make_ready+0xaa/0x130 sound/core/oss/pcm_oss.c:1128
snd_pcm_oss_sync+0x257/0x830 sound/core/oss/pcm_oss.c:1638
snd_pcm_oss_release+0x20b/0x280 sound/core/oss/pcm_oss.c:2431
__fput+0x327/0x7e0 fs/file_table.c:210
This happens while it tries to open and set up the aloop device
concurrently. The warning above (invoked from snd_BUG_ON() macro) is
to detect the unexpected logical error where snd_pcm_hw_refine() call
shouldn't fail. The theory is true for the case where the hw_params
config rules are static. But for an aloop device, the hw_params rule
condition does vary dynamically depending on the connected target;
when another device is opened and changes the parameters, the device
connected in another side is also affected, and it caused the error
from snd_pcm_hw_refine().
That is, the simplest "solution" for this is to remove the incorrect
assumption of static rules, and treat such an error as a normal error
path. As there are a couple of other places using snd_BUG_ON()
incorrectly, this patch removes these spurious snd_BUG_ON() calls.
Reported-by: syzbot+6f11c7e2a1b91d466432@syzkaller.appspotmail.com
commit 285d5ddcffafa5d5e68c586f4c9eaa8b24a2897d upstream.
It has the codec alc256, and add its pin definition to pin quirk
table to let it apply ALC255_FIXUP_DELL1_MIC_NO_PRESENCE.
commit a36c2638380c0a4676647a1f553b70b20d3ebce1 upstream.
Since the commit 97cc2ed27e5a ("ALSA: hda - Fix yet another i915
pointer leftover in error path") cleared hdac_acomp pointer, the
WARN_ON() non-NULL check in snd_hdac_i915_register_notifier() may give
a false-positive warning, as the function gets called no matter
whether the component is registered or not. For fixing it, let's get
rid of the spurious WARN_ON().
Fixes: 97cc2ed27e5a ("ALSA: hda - Fix yet another i915 pointer leftover in error path")
Reported-by: Kouta Okamoto <kouta.okamoto@toshiba.co.jp>
commit 737e0b7b67bdfe24090fab2852044bb283282fc5 upstream.
GPIO1 control register is number 51, fix this here.
Fixes: bafcbfe429eb ("ASoC: tlv320aic31xx: Make the register values human readable")
Signed-off-by: Andrew F. Davis <afd@ti.com>
commit 15f8c5f2415bfac73f33a14bcd83422bcbfb5298 upstream.
Fix child-node lookup during probe, which ended up searching the whole
device tree depth-first starting at the parent rather than just matching
on its children.
To make things worse, the parent codec node was also prematurely freed,
while the child node was leaked.
Fixes: 2d6d649a2e0f ("ASoC: twl4030: Support for DT booted kernel")
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 695b78b548d8a26288f041e907ff17758df9e1d5 upstream.
AC'97 ops (register read / write) need SSI regmap and clock, so they have
to be set after them.
We also need to set these ops back to NULL if we fail the probe.
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
Acked-by: Nicolin Chen <nicoleotsuka@gmail.com>
commit bc6476d6c1edcb9b97621b5131bd169aa81f27db upstream.
on its children.
To make things worse, the parent codec node was also prematurely freed.
Fixes: 4d50934abd22 ("ASoC: da7218: Add da7218 codec driver")
Acked-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com>
commit 50dd2ea8ef67a1617e0c0658bcbec4b9fb03b936 upstream.
The checks for whether another region/block header could be present
are subtracting the size from the current offset. Obviously we should
instead subtract the offset from the size.
The checks for whether the region/block data fit in the file are
adding the data size to the current offset and header size, without
checking for integer overflow. Rearrange these so that overflow is
impossible.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com>
Tested-by: Charles Keepax <ckeepax@opensource.cirrus.com>
commit 5a15f289ee87eaf33f13f08a4909ec99d837ec5f upstream.
The commit 89b89d121ffc ("ALSA: usb-audio: Add check return value for
usb_string()") added the check of the return value from
snd_usb_copy_string_desc(), which is correct per se, but it introduced
a regression. In the original code, either the "Clock Source",
"Playback Source" or "Capture Source" suffix is added after the
terminal string, while the commit changed it to add the suffix only
when get_term_name() is failing. It ended up with an incorrect ctl
name like "PCM" instead of "PCM Capture Source".
Also, even the original code has a similar bug: when the ctl name is
generated from snd_usb_copy_string_desc() for the given iSelector, it
also doesn't put the suffix.
This patch addresses these issues: the suffix is added always when no
static mapping is found. Also the patch tries to put more comments
and cleans up the if/else block for better readability in order to
avoid the same pitfall again.
Fixes: 89b89d121ffc ("ALSA: usb-audio: Add check return value for usb_string()")
Reported-and-tested-by: Mauro Santos <registo.mailling@gmail.com>
commit 866f7ed7d67936dcdbcddc111c8af878c918fe7c upstream.
Adds VID:PID of Esoteric D-05X to the TEAC device id's.
Renames the is_teac_50X_dac() function to is_teac_dsd_dac() to cover
broader device family from the same corporation sharing the same USB
audio implementation.
Signed-off-by: Jussi Laako <jussi@sonarnerd.net>
commit c1cfd9025cc394fd137a01159d74335c5ac978ce upstream.
The rawmidi also allows to obtaining the information via ioctl of ctl
API. It means that user can issue an ioctl to the rawmidi device even
when it's being removed as long as the control device is present.
Although the code has some protection via the global register_mutex,
its range is limited to the search of the corresponding rawmidi
object, and the mutex is already unlocked at accessing the rawmidi
object. This may lead to a use-after-free.
For avoiding it, this patch widens the application of register_mutex
to the whole snd_rawmidi_info_select() function. We have another
mutex per rawmidi object, but this operation isn't very hot path, so
it shouldn't matter from the performance POV.
[ Upstream commit c70458890ff15d858bd347fa9f563818bcd6e457 ]
Add pm_runtime_get_sync and pm_runtime_put calls to set_fmt callback
function. This fixes a bus error during boot when CONFIG_SUSPEND is
defined when this function gets called while the device is runtime
disabled and device registers are accessed while the clock is disabled.
Signed-off-by: Ed Blake <ed.blake@sondrel.com>
[ Upstream commit 3c9d3f1bc2defd418b5933bbc928096c9c686d3b ]
reader->substream is used in IRQ handler for error case but is never set.
Set value to pcm substream on DAI startup and clean it on dai shutdown.
Signed-off-by: Arnaud Pouliquen <arnaud.pouliquen@st.com>
[ Upstream commit cc3a47a248d7791ef0d2c81a35c46769e55e4c6c ]
This tested patch adds missing initialization for Line-In/Out PINs for
the docking station for HP 840 G3.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
[ Upstream commit 04d5466a976b096364a39a63ac264c1b3a5f8fa1 ]
the docking station for HP 820 G2.
