[ Upstream commit b027d11263836a0cd335520175257dcb99b43757 ]
The commit 02fc76f6a changed base of the sysfs attributes from device to card.
The "show" callbacks dereferenced wrong objects because of this.
Fixes: 02fc76f6a7db ('ALSA: line6: Create sysfs via snd_card_add_dev_attr()')
Cc: <stable@vger.kernel.org> # v4.0+
Reviewed-by: Stefan Hajnoczi <stefanha@gmail.com>
Signed-off-by: Andrej Krutak <dev@andree.sk>
[ Upstream commit adc8a43a6d6688272ebffa81789fa857e603dec6 ]
Done, because line6_stream_stop() locks and calls line6_unlink_audio_urbs(),
which in turn invokes audio_out_callback(), which tries to lock 2nd time.
Fixes:
[ INFO: possible recursive locking detected ]
4.4.15+ #15 Not tainted
mplayer/3591 is trying to acquire lock:
(&(&line6pcm->out.lock)->rlock){-.-...}, at: [<bfa27655>] audio_out_callback+0x70/0x110 [snd_usb_line6]
but task is already holding lock:
(&(&line6pcm->out.lock)->rlock){-.-...}, at: [<bfa26aad>] line6_stream_stop+0x24/0x5c [snd_usb_line6]
Possible unsafe locking scenario:
CPU0
lock(&(&line6pcm->out.lock)->rlock);
*** DEADLOCK ***
May be due to missing lock nesting notation
3 locks held by mplayer/3591:
#0: (snd_pcm_link_rwlock){.-.-..}, at: [<bf8d49a7>] snd_pcm_stream_lock+0x1e/0x40 [snd_pcm]
#1: (&(&substream->self_group.lock)->rlock){-.-...}, at: [<bf8d49af>] snd_pcm_stream_lock+0x26/0x40 [snd_pcm]
#2: (&(&line6pcm->out.lock)->rlock){-.-...}, at: [<bfa26aad>] line6_stream_stop+0x24/0x5c [snd_usb_line6]
stack backtrace:
CPU: 0 PID: 3591 Comm: mplayer Not tainted 4.4.15+ #15
Hardware name: Generic AM33XX (Flattened Device Tree)
[<c0015d85>] (unwind_backtrace) from [<c001253d>] (show_stack+0x11/0x14)
[<c001253d>] (show_stack) from [<c02f1bdf>] (dump_stack+0x8b/0xac)
[<c02f1bdf>] (dump_stack) from [<c0076f43>] (__lock_acquire+0xc8b/0x1780)
[<c0076f43>] (__lock_acquire) from [<c007810d>] (lock_acquire+0x99/0x1c0)
[<c007810d>] (lock_acquire) from [<c06171e7>] (_raw_spin_lock_irqsave+0x3f/0x4c)
[<c06171e7>] (_raw_spin_lock_irqsave) from [<bfa27655>] (audio_out_callback+0x70/0x110 [snd_usb_line6])
[<bfa27655>] (audio_out_callback [snd_usb_line6]) from [<c04294db>] (__usb_hcd_giveback_urb+0x53/0xd0)
[<c04294db>] (__usb_hcd_giveback_urb) from [<c046388d>] (musb_giveback+0x3d/0x98)
[<c046388d>] (musb_giveback) from [<c04647f5>] (musb_urb_dequeue+0x6d/0x114)
[<c04647f5>] (musb_urb_dequeue) from [<c042ac11>] (usb_hcd_unlink_urb+0x39/0x98)
[<c042ac11>] (usb_hcd_unlink_urb) from [<bfa26a87>] (line6_unlink_audio_urbs+0x6a/0x6c [snd_usb_line6])
[<bfa26a87>] (line6_unlink_audio_urbs [snd_usb_line6]) from [<bfa26acb>] (line6_stream_stop+0x42/0x5c [snd_usb_line6])
[<bfa26acb>] (line6_stream_stop [snd_usb_line6]) from [<bfa26fe7>] (snd_line6_trigger+0xb6/0xf4 [snd_usb_line6])
[<bfa26fe7>] (snd_line6_trigger [snd_usb_line6]) from [<bf8d47b7>] (snd_pcm_do_stop+0x36/0x38 [snd_pcm])
[<bf8d47b7>] (snd_pcm_do_stop [snd_pcm]) from [<bf8d462f>] (snd_pcm_action_single+0x22/0x40 [snd_pcm])
[<bf8d462f>] (snd_pcm_action_single [snd_pcm]) from [<bf8d46f9>] (snd_pcm_action+0xac/0xb0 [snd_pcm])
[<bf8d46f9>] (snd_pcm_action [snd_pcm]) from [<bf8d4b61>] (snd_pcm_drop+0x38/0x64 [snd_pcm])
[<bf8d4b61>] (snd_pcm_drop [snd_pcm]) from [<bf8d6233>] (snd_pcm_common_ioctl1+0x7fe/0xbe8 [snd_pcm])
[<bf8d6233>] (snd_pcm_common_ioctl1 [snd_pcm]) from [<bf8d6779>] (snd_pcm_playback_ioctl1+0x15c/0x51c [snd_pcm])
[<bf8d6779>] (snd_pcm_playback_ioctl1 [snd_pcm]) from [<bf8d6b59>] (snd_pcm_playback_ioctl+0x20/0x28 [snd_pcm])
[<bf8d6b59>] (snd_pcm_playback_ioctl [snd_pcm]) from [<c016714b>] (do_vfs_ioctl+0x3af/0x5c8)
Fixes: 63e20df1e5b2 ('ALSA: line6: Reorganize PCM stream handling')
[ Upstream commit 7e4379eae0e31994ea645db1d13006ea8e5ce539 ]
If there's an error, pcm is released in line6_pcm_acquire already.
Fixes: 247d95ee6dd2 ('ALSA: line6: Handle error from line6_pcm_acquire()')
[ Upstream commit 3e103a65514c2947e53f3171b21255fbde8b60c6 ]
commit cbaadf0f90d6 ("ASoC: atmel_ssc_dai: refactor the startup and
shutdown") refactored code such that the SSC is reset on every
startup; this breaks duplex audio (e.g. first start audio playback,
then start record, causing the playback to stop/hang)
Fixes: cbaadf0f90d6 (ASoC: atmel_ssc_dai: refactor the startup and shutdown)
Signed-off-by: Christoph Huber <c.huber@bct-electronic.com>
Signed-off-by: Peter Meerwald-Stadler <p.meerwald@bct-electronic.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Cc: stable@vger.kernel.org
[ Upstream commit e4ec8cc8039a7063e24204299b462bd1383184a5 ]
The stack object “r1” has a total size of 32 bytes. Its field
“event” and “val” both contain 4 bytes padding. These 8 bytes
padding bytes are sent to user without being initialized.
Signed-off-by: Kangjie Lu <kjlu@gatech.edu>
[ Upstream commit 9a47e9cff994f37f7f0dbd9ae23740d0f64f9fe6 ]
[ Upstream commit cec8f96e49d9be372fdb0c3836dcf31ec71e457e ]
The stack object “tread” has a total size of 32 bytes. Its field
[ Upstream commit 59ec4b57bcaede46546d54d037a21004b9aa5cef ]
One of the machines has ALC255 on it, another one has ALC298 on it.
On the machine with the codec ALC298, it also has the speaker volume
problem, so we add the fixup chained to ALC298_FIXUP_SPK_VOLUME rather
than adding a group of pin definition in the pin quirk table, since
the speak volume problem does not happen on other machines yet.
Signed-off-by: Hui Wang <hui.wang@canonical.com>
[ Upstream commit e9c28e16a0b7071c88a206ad8ce0c73f6605bba7 ]
When the headset was plugged in the Dell desktop, the mic of headset
can't be detected and workable.
According to the alsa-info, we found the differece between alsa and
init_pin_configs on the machine, so we need to add the pin configs to
make headset work.
Codec: Realtek ALC3234
Vendor Id: 0x10ec0255
Subsystem Id: 0x102806bb
BugLink: https://bugs.launchpad.net/bugs/1477900
Signed-off-by: Woodrow Shen <woodrow.shen@canonical.com>
[ Upstream commit 33baefe5e72f17a6df378e48196cd8cada11deec ]
krealloc() doesn't work always properly with __GFP_ZERO flag as
expected. For clearing the reallocated area, we need to clear
explicitly instead.
Reported-by: Joe Perches <joe@perches.com>
[ Upstream commit fd48331f9b71d2add941adaee3619f5b8527182d ]
This commit fixes garbled audio on Bonaire HDMI
Signed-off-by: Maruthi Bayyavarapu <maruthi.bayyavarapu@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit dd9aa335c88003d131ac874e7f6809902de0b847 ]
We have a Dell AIO on which we can't adjust its speaker's volume.
The problem is it is connected to a Audio Output node without Amp-out
capability. To fix it, we change it to be connnected to a node with
Amp-out capability.
[ Upstream commit 98973f2f083a5ec580da8bbb685e6baa93613546 ]
This laptop needs GPIO4 pulled high to enable the headphone amplifier,
and has a mute LED on GPIO3. I modelled the patch on the existing
GPIO4 code which pulls the line low for the same purpose; this time,
the HP amp line is pulled high.
v2: Disable the headphone amplifier when no headphone is connected.
Don't disable power savings to preserve the LED state.
v3: Remove headset-specific hooks and code; this is just a headphone.
Signed-off-by: Keith Packard <keithp@keithp.com>
[ Upstream commit d716fb03f76411fc7e138692e33b749cada5c094 ]
This allows the device to correctly show up as ATI HDMI
rather than a generic one and allows the driver to use
the available caps.
Signed-off-by: Awais Belal <awais_belal@mentor.com>
[ Upstream commit ab58d8cc870ef3f0771c197700441936898d1f1d ]
register_vga_switcheroo() sets the PM ops from the hda structure which
is freed later in azx_free. Make sure that these ops are cleared.
Caught by KASAN, initially noticed due to a general protection fault.
Fixes: 246efa4a072f ("snd/hda: add runtime suspend/resume on optimus support (v4)")
Signed-off-by: Peter Wu <peter@lekensteyn.nl>
[ Upstream commit a8ff48cb70835f48de5703052760312019afea55 ]
The chmap ctls assigned to PCM streams are freed in the PCM disconnect
callback. However, since the disconnect callback isn't called when
the card gets freed before registering, the chmap ctls may still be
left assigned. They are eventually freed together with other ctls,
but it may cause an Oops at pcm_chmap_ctl_private_free(), as the
function refers to the assigned PCM stream, while the PCM objects have
been already freed beforehand.
The fix is to free the chmap ctls also at PCM free callback, not only
at PCM disconnect.
Reported-by: Laxminath Kasam <b_lkasam@codeaurora.org>
[ Upstream commit f388cdcdd160687c6650833f286b9c89c50960ff ]
snd_ctl_remove() has a notification for the removal event. It's
superfluous when done during the device got disconnected. Although
the notification itself is mostly harmless, it may potentially be
harmful, and should be suppressed. Actually some components PCM may
free ctl elements during the disconnect or free callbacks, thus it's
no theoretical issue.
This patch adds the check of card->shutdown flag for avoiding
unnecessary notifications after (or during) the disconnect.
[ Upstream commit 8a132099f080d7384bb6ab4cc168f76cb4b47d08 ]
We have some Dell laptops which can't detect headset mic, the machines
use the codec ALC225, they have some new pin configuration values,
after adding them in the alc225 pin quirk table, they work well.
[ Upstream commit 9cd25743765cfe851aed8d655a62d60156aed293 ]
This solves the issue that a headphone is not working on the docking
unit.
Signed-off-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
[ Upstream commit 3fa6993fef634e05d200d141a85df0b044572364 ]
The user timer tu->qused counter may go to a negative value when
multiple concurrent reads are performed since both the check and the
decrement of tu->qused are done in two individual locked contexts.
This results in bogus read outs, and the endless loop in the
user-space side.
The fix is to move the decrement of the tu->qused counter into the
same spinlock context as the zero-check of the counter.
[ Upstream commit 62db7152c924e4c060e42b34a69cd39658e8a0dc ]
vortex_wtdma_bufshift() function does calculate the page index
wrongly, first masking then shift, which always results in zero.
The proper computation is to first shift, then mask.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
[ Upstream commit 9c6795a9b3cbb56a9fbfaf43909c5c22999ba317 ]
'commpage_bak' is allocated with 'sizeof(struct echoaudio)' bytes.
We then copy 'sizeof(struct comm_page)' bytes in it.
On my system, smatch complains because one is 2960 and the other is 3072.
This would result in memory corruption or a oops.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit 81e43960dce1c8e58e682fb3ec26c1d8f83a9afc ]
UBSAN reports the following warning from accessing path->path[-1]
in set_path_power():
[ 16.078040] ================================================================================
[ 16.078124] UBSAN: Undefined behaviour in sound/pci/hda/hda_generic.c:3981:17
[ 16.078198] index -1 is out of range for type 'hda_nid_t [10]'
[ 16.078270] CPU: 2 PID: 1738 Comm: modprobe Not tainted 4.7.0-rc1-wt+ #47
[ 16.078274] Hardware name: LENOVO 3443CTO/3443CTO, BIOS G6ET23WW (1.02 ) 08/14/2012
[ 16.078278] ffff8800cb246000 ffff8800cb3638b8 ffffffff815c4fe3 0000000000000032
[ 16.078286] ffff8800cb3638e0 ffffffffffffffff ffff8800cb3638d0 ffffffff8162443d
[ 16.078294] ffffffffa0894200 ffff8800cb363920 ffffffff81624af7 0000000000000292
[ 16.078302] Call Trace:
[ 16.078311] [<ffffffff815c4fe3>] dump_stack+0x86/0xd3
[ 16.078317] [<ffffffff8162443d>] ubsan_epilogue+0xd/0x40
[ 16.078324] [<ffffffff81624af7>] __ubsan_handle_out_of_bounds+0x67/0x70
[ 16.078335] [<ffffffffa087665f>] set_path_power+0x1bf/0x230 [snd_hda_codec_generic]
[ 16.078344] [<ffffffffa087880d>] add_pin_power_ctls+0x8d/0xc0 [snd_hda_codec_generic]
[ 16.078352] [<ffffffffa087f190>] ? pin_power_down_callback+0x20/0x20 [snd_hda_codec_generic]
[ 16.078360] [<ffffffffa0878947>] add_all_pin_power_ctls+0x107/0x150 [snd_hda_codec_generic]
[ 16.078370] [<ffffffffa08842b3>] snd_hda_gen_parse_auto_config+0x2d73/0x49e0 [snd_hda_codec_generic]
[ 16.078376] [<ffffffff81173360>] ? trace_hardirqs_on_caller+0x1b0/0x2c0
[ 16.078390] [<ffffffffa089df27>] alc_parse_auto_config+0x147/0x310 [snd_hda_codec_realtek]
[ 16.078402] [<ffffffffa08a332a>] patch_alc269+0x23a/0x560 [snd_hda_codec_realtek]
[ 16.078417] [<ffffffffa0838644>] hda_codec_driver_probe+0xa4/0x1a0 [snd_hda_codec]
[ 16.078424] [<ffffffff817bbac1>] driver_probe_device+0x101/0x380
[ 16.078430] [<ffffffff817bbdf9>] __driver_attach+0xb9/0x100
[ 16.078438] [<ffffffff817bbd40>] ? driver_probe_device+0x380/0x380
[ 16.078444] [<ffffffff817b8d20>] bus_for_each_dev+0x70/0xc0
[ 16.078449] [<ffffffff817bb087>] driver_attach+0x27/0x50
[ 16.078454] [<ffffffff817ba956>] bus_add_driver+0x166/0x2c0
[ 16.078460] [<ffffffffa0369000>] ? 0xffffffffa0369000
[ 16.078465] [<ffffffff817bd13d>] driver_register+0x7d/0x130
[ 16.078477] [<ffffffffa083816f>] __hda_codec_driver_register+0x6f/0x90 [snd_hda_codec]
[ 16.078488] [<ffffffffa036901e>] realtek_driver_init+0x1e/0x1000 [snd_hda_codec_realtek]
[ 16.078493] [<ffffffff8100215e>] do_one_initcall+0x4e/0x1d0
[ 16.078499] [<ffffffff8119f54d>] ? rcu_read_lock_sched_held+0x6d/0x80
[ 16.078504] [<ffffffff813701b1>] ? kmem_cache_alloc_trace+0x391/0x560
[ 16.078510] [<ffffffff812bb314>] ? do_init_module+0x28/0x273
[ 16.078515] [<ffffffff812bb387>] do_init_module+0x9b/0x273
[ 16.078522] [<ffffffff811e3782>] load_module+0x20b2/0x3410
[ 16.078527] [<ffffffff811df140>] ? m_show+0x210/0x210
[ 16.078533] [<ffffffff813b2b26>] ? kernel_read+0x66/0xe0
[ 16.078541] [<ffffffff811e4cfa>] SYSC_finit_module+0xba/0xc0
[ 16.078547] [<ffffffff811e4d1e>] SyS_finit_module+0xe/0x10
[ 16.078552] [<ffffffff81a860fc>] entry_SYSCALL_64_fastpath+0x1f/0xbd
[ 16.078556] ================================================================================
Fix by checking path->depth before use.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
[ Upstream commit 712a8038cc24dba668afe82f0413714ca87184e0 ]
When the ssm4567 is powered up the driver calles regcache_sync() to restore
the register map content. regcache_sync() assumes that the device is in its
power-on reset state. Make sure that this is the case by explicitly
resetting the ssm4567 register map before calling regcache_sync() otherwise
we might end up with a incorrect register map which leads to undefined
behaviour.
One such undefined behaviour was observed when returning from system
suspend while a playback stream is active, in that case the ssm4567 was
kept muted after resume.
Fixes: 1ee44ce03011 ("ASoC: ssm4567: Add driver for Analog Devices SSM4567 amplifier")
Reported-by: Harsha Priya <harshapriya.n@intel.com>
Tested-by: Fang, Yang A <yang.a.fang@intel.com>
[ Upstream commit ba4bc32eaa39ba7687f0958ae90eec94da613b46 ]
An older patch to convert the API in the s3c i2s driver
ended up passing a const pointer into a function that takes
a non-const pointer, so we now get a warning:
sound/soc/samsung/s3c2412-i2s.c: In function 's3c2412_iis_dev_probe':
sound/soc/samsung/s3c2412-i2s.c:172:9: error: passing argument 3 of 's3c_i2sv2_register_component' discards 'const' qualifier from pointer target type [-Werror=discarded-qualifiers]
However, the s3c_i2sv2_register_component() function again
passes the pointer into another function taking a const, so
we just need to change its prototype.
Fixes: eca3b01d0885 ("ASoC: switch over to use snd_soc_register_component() on s3c i2s")
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
[ Upstream commit 4a07083ed613644c96c34a7dd2853dc5d7c70902 ]
ALSA system timer backend stops the timer via del_timer() without sync
and leaves del_timer_sync() at the close instead. This is because of
the restriction by the design of ALSA timer: namely, the stop callback
may be called from the timer handler, and calling the sync shall lead
to a hangup. However, this also triggers a kernel BUG() when the
timer is rearmed immediately after stopping without sync:
kernel BUG at kernel/time/timer.c:966!
Call Trace:
<IRQ>
[<ffffffff8239c94e>] snd_timer_s_start+0x13e/0x1a0
[<ffffffff8239e1f4>] snd_timer_interrupt+0x504/0xec0
[<ffffffff8122fca0>] ? debug_check_no_locks_freed+0x290/0x290
[<ffffffff8239ec64>] snd_timer_s_function+0xb4/0x120
[<ffffffff81296b72>] call_timer_fn+0x162/0x520
[<ffffffff81296add>] ? call_timer_fn+0xcd/0x520
[<ffffffff8239ebb0>] ? snd_timer_interrupt+0xec0/0xec0
It's the place where add_timer() checks the pending timer. It's clear
that this may happen after the immediate restart without sync in our
cases.
So, the workaround here is just to use mod_timer() instead of
add_timer(). This looks like a band-aid fix, but it's a right move,
as snd_timer_interrupt() takes care of the continuous rearm of timer.
Reported-by: Jiri Slaby <jslaby@suse.cz>
[ Upstream commit 0ab1ace856205d10cbc1924b2d931c01ffd216a6 ]
The commit [d507941beb1e: ALSA: pcm: Correct PCM BUG error message]
made the warning prefix back to "BUG:" due to its previous wrong
prefix. But a kernel message containing "BUG:" seems taken as an Oops
message wrongly by some brain-dead daemons, and it annoys users in the
end. Instead of teaching daemons, change the string again to a more
reasonable one.
Fixes: 507941beb1e ('ALSA: pcm: Correct PCM BUG error message')
Cc: <stable@vger.kernel.org> # v3.19+
snd_usb_add_audio_stream() call
[ Upstream commit 836b34a935abc91e13e63053d0a83b24dfb5ea78 ]
create_fixed_stream_quirk(), snd_usb_parse_audio_interface() and
create_uaxx_quirk() functions allocate the audioformat object by themselves
and free it upon error before returning. However, once the object is linked
to a stream, it's freed again in snd_usb_audio_pcm_free(), thus it'll be
double-freed, eventually resulting in a memory corruption.
This patch fixes these failures in the error paths by unlinking the audioformat
object before freeing it.
Based on a patch by Takashi Iwai <tiwai@suse.de>
[Note for stable backports:
this patch requires the commit 902eb7fd1e4a ('ALSA: usb-audio: Minor
code cleanup in create_fixed_stream_quirk()')]
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1283358
Reported-by: Ralf Spenneberg <ralf@spenneberg.net>
Cc: <stable@vger.kernel.org> # see the note above
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
[ Upstream commit 902eb7fd1e4af3ac69b9b30f8373f118c92b9729 ]
Just a minor code cleanup: unify the error paths.
[ Upstream commit b9a1a743818ea3265abf98f9431623afa8c50c86 ]
ARM64 allmodconfig produces a bunch of warnings when building the
samsung ASoC code:
sound/soc/samsung/dmaengine.c: In function 'samsung_asoc_init_dma_data':
sound/soc/samsung/dmaengine.c:53:32: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
playback_data->filter_data = (void *)playback->channel;
sound/soc/samsung/dmaengine.c:60:31: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
capture_data->filter_data = (void *)capture->channel;
We could easily shut up the warning by adding an intermediate cast,
but there is a bigger underlying problem: The use of IORESOURCE_DMA
to pass data from platform code to device drivers is dubious to start
with, as what we really want is a pointer that can be passed into
a filter function.
Note that on s3c64xx, the pl08x DMA data is already a pointer, but
gets cast to resource_size_t so we can pass it as a resource, and it
then gets converted back to a pointer. In contrast, the data we pass
for s3c24xx is an index into a device specific table, and we artificially
convert that into a pointer for the filter function.
[ Upstream commit d5dbbe6569481bf12dcbe3e12cff72c5f78d272c ]
syzkaller fuzzer spotted a potential use-after-free case in snd-dummy
driver when hrtimer is used as backend:
> BUG: KASAN: use-after-free in rb_erase+0x1b17/0x2010 at addr ffff88005e5b6f68
> Read of size 8 by task syz-executor/8984
> BUG kmalloc-192 (Not tainted): kasan: bad access detected
> Disabling lock debugging due to kernel taint
> INFO: Allocated in 0xbbbbbbbbbbbbbbbb age=18446705582212484632
> [< none >] dummy_hrtimer_create+0x49/0x1a0 sound/drivers/dummy.c:464
> INFO: Freed in 0xfffd8e09 age=18446705496313138713 cpu=2164287125 pid=-1
> [< none >] dummy_hrtimer_free+0x68/0x80 sound/drivers/dummy.c:481
> Call Trace:
> [<ffffffff8179e59e>] __asan_report_load8_noabort+0x3e/0x40 mm/kasan/report.c:333
> [< inline >] rb_set_parent include/linux/rbtree_augmented.h:111
> [< inline >] __rb_erase_augmented include/linux/rbtree_augmented.h:218
> [<ffffffff82ca5787>] rb_erase+0x1b17/0x2010 lib/rbtree.c:427
> [<ffffffff82cb02e8>] timerqueue_del+0x78/0x170 lib/timerqueue.c:86
> [<ffffffff814d0c80>] __remove_hrtimer+0x90/0x220 kernel/time/hrtimer.c:903
> [< inline >] remove_hrtimer kernel/time/hrtimer.c:945
> [<ffffffff814d23da>] hrtimer_try_to_cancel+0x22a/0x570 kernel/time/hrtimer.c:1046
> [<ffffffff814d2742>] hrtimer_cancel+0x22/0x40 kernel/time/hrtimer.c:1066
> [<ffffffff85420531>] dummy_hrtimer_stop+0x91/0xb0 sound/drivers/dummy.c:417
> [<ffffffff854228bf>] dummy_pcm_trigger+0x17f/0x1e0 sound/drivers/dummy.c:507
> [<ffffffff85392170>] snd_pcm_do_stop+0x160/0x1b0 sound/core/pcm_native.c:1106
> [<ffffffff85391b26>] snd_pcm_action_single+0x76/0x120 sound/core/pcm_native.c:956
> [<ffffffff85391e01>] snd_pcm_action+0x231/0x290 sound/core/pcm_native.c:974
> [< inline >] snd_pcm_stop sound/core/pcm_native.c:1139
> [<ffffffff8539754d>] snd_pcm_drop+0x12d/0x1d0 sound/core/pcm_native.c:1784
> [<ffffffff8539d3be>] snd_pcm_common_ioctl1+0xfae/0x2150 sound/core/pcm_native.c:2805
> [<ffffffff8539ee91>] snd_pcm_capture_ioctl1+0x2a1/0x5e0 sound/core/pcm_native.c:2976
> [<ffffffff8539f2ec>] snd_pcm_kernel_ioctl+0x11c/0x160 sound/core/pcm_native.c:3020
> [<ffffffff853d9a44>] snd_pcm_oss_sync+0x3a4/0xa30 sound/core/oss/pcm_oss.c:1693
> [<ffffffff853da27d>] snd_pcm_oss_release+0x1ad/0x280 sound/core/oss/pcm_oss.c:2483
A workaround is to call hrtimer_cancel() in dummy_hrtimer_sync() which
is called certainly before other blocking ops.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
[ Upstream commit 0f087ee3f3b86a4507db4ff1d2d5a3880e4cfd16 ]
See: https://bugzilla.redhat.com/show_bug.cgi?id=1349539
See: https://bugzilla.kernel.org/show_bug.cgi?id=120961
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
[ Upstream commit 21e9d017b88ea0baa367ef0b6516d794fa23e85e ]
One more Dell laptop with alc293 codec needs
ALC293_FIXUP_DELL1_MIC_NO_PRESENCE, but the pin 0x1e does not match
the corresponding one in the ALC292_STANDARD_PINS. To use this macro
for this machine, we need to remove pin 0x1e from it.
BugLink: https://bugs.launchpad.net/bugs/1476888
[ Upstream commit 8198868f0a283eb23e264951632ce61ec2f82228 ]
Call path:
1) snd_hdac_power_up_pm()
2) snd_hdac_power_up()
3) pm_runtime_get_sync()
4) __pm_runtime_resume()
5) rpm_resume()
The rpm_resume() returns 1 when the device is already active.
Because the return value is unmodified, the hdac regmap read/write
functions should allow this value for the retry I/O operation, too.
[ Upstream commit 3194ed497939c6448005542e3ca4fa2386968fa0 ]
HD-audio driver uses regmap cache bypass feature for reading a raw
value without the cache. But this is racy since both the cached and
the uncached reads may occur concurrently. The former is done via the
normal control API access while the latter comes from the proc file
read.
Even though the regmap itself has the protection against the
concurrent accesses, the flag set/reset is done without the
protection, so it may lead to inconsistent state of bypass flag that
doesn't match with the current read and occasionally result in a
kernel WARNING like:
WARNING: CPU: 3 PID: 2731 at drivers/base/regmap/regcache.c:499 regcache_cache_only+0x78/0x93
One way to work around such a problem is to wrap with a mutex. But in
this case, the solution is simpler: for the uncached read, we just
skip the regmap and directly calls its accessor. The verb execution
there is protected by itself, so basically it's safe to call
individually.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=116171
[ Upstream commit dab38e43b298501a4e8807b56117c029e2e98383 ]
Tested with Lenovo Ultradock. Fixes the non-working headphone jack on
the docking unit.
Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
[ Upstream commit f90d83b301701026b2e4c437a3613f377f63290e ]
Add the pin configuration value of this machine into the pin_quirk
table to make DELL1_MIC_NO_PRESENCE apply to this machine.
Signed-off-by: AceLan Kao <acelan.kao@canonical.com>
[ Upstream commit e69e7e03ed225abf3e1c43545aa3bcb68dc81d5f ]
That is some different register for ALC255 and ALC256.
ALC256 can't fit with some ALC255 register.
This issue is cause from LDO output voltage control.
This patch is updated the right LDO register value.
Signed-off-by: Kailang Yang <kailang@realtek.com>
[ Upstream commit 423cd785619ac6778252fbdb916505aa1c153959 ]
The headphone has noise when playing sound or switching microphone sources.
It uses the same codec on XPS 13 9350, but with different subsystem ID.
Applying the fixup can solve the issue.
Also, changing the model name to better differentiate models.
v2: Reorder by device ID.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
[ Upstream commit c04017ea81dc1eccae87be7ac7b82b2972f9931f ]
These laptops support both headphone, headset and mic modes
for the 3.5mm jack.
BugLink: https://bugs.launchpad.net/bugs/1526330
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
[ Upstream commit d3030d11961a8c103cf07aed59905276ddfc06c2 ]
The ak4642 driver is using a regmap cache sync to restore the
configuration of the chip on resume but (as Peter observed) does not
actually define a register cache which means that the resume is never
going to work and we trigger asserts in regmap. Fix this by enabling
caching.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reported-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Tested-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit f8ea6cebcfa6499949392da71fc427567c9e5a0e ]
The max_register setting for ak4642, ak4643 and ak4648 are wrong, fix it.
According to the datasheet:
the maximum valid register for ak4642 is 0x1f
the maximum valid register for ak4643 is 0x24
the maximum valid register for ak4648 is 0x27
The default settings for ak4642 and ak4643 are the same for 0x0 ~ 0x1f
registers, so it's fine to use the same reg_default table with differnt
num_reg_defaults setting.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
[ Upstream commit 84add303ef950b8d85f54bc2248c2bc73467c329 ]
Phoenix Audio has yet another device with another id (even a different
vendor id, 0556:0014) that requires the same quirk for the sample
rate.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=110221
[ Upstream commit 3231e2053eaeee70bdfb216a78a30f11e88e2243 ]
Subwoofer does not work out of the box on ASUS N751/N551 laptops. This
patch fixes it. Patch tested on N751 laptop. N551 part is not tested,
but according to [1] and [2] this laptop requires similar changes, so I
included them in the patch.
1. https://github.com/honsiorovskyi/asus-n551-hda-fix
2. https://bugs.launchpad.net/ubuntu/+source/alsa-tools/+bug/1405691
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=117781
Signed-off-by: Yura Pakhuchiy <pakhuchiy@gmail.com>
[ Upstream commit 9d4dc5840f93bcb002fa311693349deae7702bc5 ]
For reducing the noise from the headphone output on ASUS N750JV,
call the existing fixup, alc_fixup_auto_mute_via_amp(), additionally.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=115181
Signed-off-by: Bobi Mihalca <bobbymihalca@touchtech.ro>
[ Upstream commit 70cf2cbd685e218c3ffd105d9fb6cf0f8d767481 ]
ASUS N750JV needs the same fixup as N550 for enabling its subwoofer.
[ Upstream commit addacd801e1638f41d659cb53b9b73fc14322cb1 ]
The HD-audio reconfig function got broken in the recent kernels,
typically resulting in a failure like:
snd_hda_intel 0000:00:1b.0: control 3:0:0:Playback Channel Map:0 is already present
This is because of the code restructuring to move the PCM and control
instantiation into the codec drive probe, by the commit [bcd96557bd0a:
ALSA: hda - Build PCMs and controls at codec driver probe]. Although
the commit above removed the calls of snd_hda_codec_build_pcms() and
*_build_controls() at the controller driver probe, the similar calls
in the reconfig were still left forgotten. This caused the
conflicting and duplicated PCMs and controls.
The fix is trivial: just remove these superfluous calls from
reconfig_codec().
Fixes: bcd96557bd0a ('ALSA: hda - Build PCMs and controls at codec driver probe')
Reported-by: Jochen Henneberg <jh@henneberg-systemdesign.com>
Cc: <stable@vger.kernel.org> # v4.1+
[ Upstream commit 2da2dc9ead232f25601404335cca13c0f722d41b ]
For reducing the noise from the headset output on ASUS UX501VW,
call the existing fixup, alc_fixup_headset_mode_alc668(), additionally.
Thread: https://bbs.archlinux.org/viewtopic.php?id=209554
Signed-off-by: Kaho Ng <ngkaho1234@gmail.com>
[ Upstream commit 83a9efb5b8170b7cffef4f62656656e1d8ad2ccd ]
Apply the new fixup that is used for ASUS N750JV to another similar
model, N500JV, too, for reducing the headphone noise.
[ Upstream commit 2d2c038a9999f423e820d89db2b5d7774b67ba49 ]
Phoenix Audio MT202pcs (1de7:0114) and MT202exe (1de7:0013) need the
same workaround as TMX320 for avoiding the firmware bug. It fixes the
frequent error about the sample rate inquiries and the slow device
probe as consequence.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=117321
