* introduce 3 new flags to allow a more detailed configuration
of the SSI link :
IMX_SSI_NET : enable Network Mode
IMX_SSI_SYN : enable Synchronous Mode
IMX_SSI_USE_I2S_SLAVE : enable I2S Slave Mode
* new platform can use these settings without breaking actual
platforms.
Signed-off-by: Eric Bénard <eric@eukrea.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
The variable 'state' of structure 's3c_ac97_info' seems no use here,
so this patch is to remove the unnecessary variable.
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
The variable 'periods' of structure 'atmel_runtime_data'
seems no use in whole atmel alsa driver,so I make a patch
Use the resource_size function instead of manually calculating the
resource size.This patch can reduce the chance of introducing off-by-one
errors.
Acked-by: Manuel Lauss <manuel.lauss@googlemail.com>
The size calculation is end - start + 1. But,sometimes, the '1' can
be forgotten carelessly, witch will have potential risk, so use resource_size
for {request/release}_mem_region and ioremap here should be good habit.
Acked-by: Daniel Glöckner <dg@emlix.com>
This patch is to modify the ac97 delays to minimum, all these 1000 micro
seconds delays seem over spec for the AC97 interface.
I deleted some unnecessary delays here and changed the AC97 cold and warm reset
delays from 1000us to 100us.
Fix a '#include "nuc900-audio.h' typo, I think it should be 'audio'.
At the same time, this patch renames the 'nuc900-auido.h' file to
'nuc900-audio.h'.
The current implement meant ACTL_ACCON was only accessed once when read or write
proceeding, which is not right, if so,we have to wait the 'timeout=0x10000' to end
every times.
We need to polling the bit AC_R_FINISH and AC_W_FINISH of ACTL_ACCON
register to identify whether read or write is finished or not,so I make
the patch to fix the issue.
This patch is to remove the 'SUBSTREAM_TYPE','PCM_TX' and 'PCM_RX' definition.
There is no need to redefine SNDRV_PCM_STREAM_PLAYBACK as PCM_TX,
the SUBSTREAM_TYPE(substream) can be deleted too, the playback or record can be
judged by 'if (substream->stream == SNDRV_PCM_STREAM_PLAYBACK)' directly rather
than 'if (PCM_TX == stype)', which makes the codes easy to read.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into topic/asoc
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
This patch is adding support for openrd client platforms. It's using
the cs42l51 codec and has one mic and one speaker plugs.
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
This patch enables support for the i2s controller available on kirkwood
platforms
This patch is adding a ASoC driver for the cs42l51 from Cirrus Logic.
Master mode and spi mode are not supported.
Acked-by: Liam Girdwood <lrg@slimlogic.co.ul>
This patch adds spdif dummy codec driver for using spdif-dit as
a stand-alone. Until this, spdif-dit can be used only with other
codecs like tlv320aci3x in davinci platform.
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
Machine driver can instruct the codec driver to reset the
chip registers to their default values at probe time.
If machine driver does not provide setup data, then the
registers are going to be reseted to their defaults, to
be safe.
If the developer on the platform confirms that the register
reset is not needed, than it can be skipped, saving ~20ms
time in probe.
As safety measure do the register reset at remove time also.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Restructure the codec power code in order to be able to hit
off when the codec is not in use.
Since the audio registers are accessible while the codec is powered
down, there is no need for additional safety mechanism.
It seams at least on twl5031 that the ARXR2_APGA_CTL register
does not have the same default value as it is written in
the TRM.
Since the codec part of the PM chip has not been actually
changed according to TI, assuming, that all version has
the same problem, so writing there the TRM value.
Since the twl4030 codec driver supports different version
of the PM chip, a helper function can come handy, which
can check the driver's default versus the chip values.
Since the reg cache now contains the chip default values
for all registers (REG_OPTION is reset to it's default
within this patch), there is no longer need to rewrite
_all_ registers.
Initialize only few selected registers.
According to the latest information, the offset cancellation
need to be done only once, when the codec is powered on, so
there is no need for the power up wrapper.
Move all chip initialization code under chip_init, and do
it when the codec is initialized.
Add means for machine drivers to select the path for offset
cancellation.
Reset the reg cache value to the chip reset value at the
same time.
Machine drivers can specify which path need to be used for
offset cancellation via the twl4030_setup.offset_cncl_path.
For paths use the defines from
include/linux/mfd/twl4030-codec.h:
TWL4030_OFFSET_CNCL_SEL_*
There is no need for the power down wrapper.
Reset most of the codec registers to their chip reset
value.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits)
ALSA: snd-usb-caiaq: Bump version number to 1.3.21
ALSA: Revert "ALSA: snd-usb-caiaq: Set default input mode of A4DJ"
ALSA: snd-usb-caiaq: Simplify single case to an 'if'
ALSA: snd-usb-caiaq: Restore 'Control vinyl' input mode on A4DJ
ALSA: hda: Use LPIB for a Shuttle device
ALSA: hda: Add support for another Lenovo ThinkPad Edge in conexant codec
ALSA: hda: Use LPIB for Sony VPCS11V9E
ALSA: usb-audio: fix feature unit parser for UAC2
ALSA: asihpi - Minor code cleanup
ALSA: asihpi - Add support for new ASI8800 family
ALSA: asihpi - Fix bug preventing outstream_write preload from happening
ALSA: asihpi - Fix imbalanced lock path in hw_message
ALSA: asihpi - Remove support for old ASI8800 family
ALSA: asihpi - Add hd radio blend functions
ALSA: asihpi - Remove unused io map functions
ALSA: usb-audio: add support for UAC2 pitch control
ALSA: usb-audio: parse UAC2 endpoint descriptors correctly
ALSA: usb-audio: fix return values
ALSA: usb-audio: parse more format descriptors with structs
sound: Add missing spin_unlock
Acked-by: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Mark Hills <mark@pogo.org.uk>
Do not explicity set the default input mode. Use the hardware default
of mode 0 ('Control vinyl'), which is now available.
This reverts commit e3ca4c9.
After removing code, only one case remains. So use an 'if' instead.
This feature was undocumented on early A4DJ units. It is indicated
by lighting both the 'line' and 'phono' lamps at the same time.
Newer units document this and the newer Windows drivers enable this
for all units, so restore the functionality.
This patch simplifies the code and changes the mode mapping to match
the A8DJ, favouring simpler code and consistency over keeping the
existing mapping.
Both 'Control vinyl' and 'Phono' input modes enable the hardware
preamp. The difference is the input impedance.
This reverts commit 9a9527e.
BugLink: https://launchpad.net/bugs/551949
Symptom: On the reporter's Shuttle device, using PulseAudio in Ubuntu
10.04 LTS results in "popping clicking" audio with the PA crashing
shortly thereafter.
Test case: Using Ubuntu 10.04 LTS (Linux 2.6.32.12), Linux 2.6.33, or
Linux 2.6.34, adjust the HDA device's volume with PulseAudio.
Resolution: add SSID for this machine to the position_fix quirk table,
explicitly specifying the LPIB method.
Reported-and-Tested-By: Christian Mehlis <mehlis@inf.fu-berlin.de>
Cc: <stable@kernel.org>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
On a Thinkpad Edge 13 "01972NG" I had the problem that speakers played
sound although headphones were plugged in. Using model=ideapad with
latest alsa-git kernel fixed this. So adding this quirk to use ideapad
for another Thinkpad Edge variant seems sensible.
Cc: Jerone Young <jerone.young@canonical.com>
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
BugLink: https://launchpad.net/bugs/586347
Symptom: On the Sony VPCS11V9E, using GStreamer-based applications with
PulseAudio in Ubuntu 10.04 LTS results in stuttering audio. It appears
to worsen with increased I/O.
Test case: use Rhythmbox under increased I/O pressure. This symptom is
reproducible in the current daily stable alsa-driver snapshots (at least
up until 21 May 2010; later snapshots fail to build from source due to
missing preprocessor directives when compiled against 2.6.32).
Reported-and-Tested-By: Lauri Kainulainen <lauri@sokkelo.net>
Fix a small off-by-one bug which causes the feature unit to announce a
wrong number of channels. This leads to illegal requests sent to the
firmware eventually.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
The S5PV210 and S5PC110 has the AC97 controller same as S3C6410.
Simply enable the options to build the drivers for S5PC110 and
S5PV210 also.
Signed-off-by: Jassi Brar <jassi.brar@samsung.com>
The S5PC100 has the AC97 controller same as S3C6410.
S5PC100 also.
Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com>
Add hd radio blend functions. HPI version inc to 4.03.25.
This request is again handled differently in comparison to UAC1.
