This patch adds the device id for Nvidia GT220 cards to the nvhdmi
driver. I have tested it and confirmed it to be working.
Original patch download link:
https://gist.github.com/324070/
Signed-off-by: Derek Kelly <user.vdr@gmail.com>
BugLink: https://launchpad.net/bugs/420578
The OR has verified that his hardware distorts because of the 0 dB
offset not corresponding to the highest PCM level. Fix this by capping
said PCM level to 0 dB similarly to what we do for CX20549 (Venice).
Reported-by: Mike Pontillo <pontillo@gmail.com>
Tested-by: Mike Pontillo <pontillo@gmail.com>
Cc: <stable@kernel.org>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
Adding this PCI quirk fixes the board config detection.
This also fixes jack sensing by using "hp_detect=1" via properly detected
board config.
Signed-off-by: Kunal Gangakhedkar <kunal.gangakhedkar@gmail.com>
The constant DMA_ACTIVE is defined with the dma_buffparams structure rather
than with the audio_operations structure. Takashi Iwai suggested that the
dmap_out field of the audio_operations structure should be used instead.
This is not tested.
This fixes a warning ("pxa_free_dma: trying to free channel 0 which is
already freed") when a device was opened but the hw_params() call
failed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
We're keeping track of the number of times we've iterated but never
actually using this to bail out if the chip looks stuck.
During validation of the internal clocking setup it has
been found that the following settings were not configured
in an optimal way:
ASRC_CTRL_A: SRCLKDIV was incorrect, instad of divide ratio 3,
ratio of 2 has to be used (as the comment stated)
DAC_CTRL_A: Fs = Fsref is the desired configuration instead of
Fs = Fsref / 1.5
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
To make DSP_A mode working correctly the data delay should be
configured to 0. DSP_B mode thus can not be used with DAC33,
so remove it.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
sound: sequencer: clean up remove bogus check
ALSA: hda: Use LPIB and 6stack-dig for eMachines T5212
ALSA: hda - Disable MSI for Nvidia controller
ALSA: hda - Add PCI quirks for MSI NetOn AP1900 and Wind Top AE2220
ALSA: hda - Fix secondary ADC of ALC260 basic model
ALSA: hda - Add an error message for invalid mapping NID
ALSA: hda - New Intel HDA controller
The SIU ASoC driver must load firmware to program the DSP, therefore it
has to select FW_LOADER in its Kconfig entry.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
A few lines earlier bend is limited to 2399. So semitones is always
less than 24 here.
BugLink: https://bugs.launchpad.net/bugs/538895
The OR has verified that both position_fix=1 and model=6stack-dig are
necessary to have capture function properly. (The existing 3stack-6ch
model quirk seems to be incorrect.)
Reported-by: Reuben Bailey <reuben.e.bailey@gmail.com>
Tested-by: Reuben Bailey <reuben.e.bailey@gmail.com>
Judging from the member of enable_msi white-list, Nvidia controller
seems to cause troubles with MSI enabled, e.g. boot hang up or other
serious issue may come up. It's safer to disable MSI as default for
Nvidia controllers again for now.
This should make the speakers and jack detection work on MSI all-in-one
computers NetOn AP1900 and Wind Top AE2220.
Signed-off-by: Anisse Astier <anisse@astier.eu>
Fix adc_nids[] for ALC260 basic model to match with num_adc_nids.
Otherwise you get an invalid NID in the secondary "Input Source" mixer
element.
Add an error message to snd_hda_add_nid() for invalid mapping NID to make
easier to hunt the buggy code.
Also added a missing space to the error message in snd_hda_build_controls()
Added a PCI controller id on new Dell laptops.
Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com>
ALSA: hda - Sound MSI fallout on a Asus mobo NVIDIA MCP55
sound: fix opti92x-ad1848 build
ALSA: hda - Fix input source elements of secondary ADCs on Realtek
ALSA: hda - Fix wrong model range check for ALC268
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits)
doc: fix typo in comment explaining rb_tree usage
Remove fs/ntfs/ChangeLog
doc: fix console doc typo
doc: cpuset: Update the cpuset flag file
Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed
Remove drivers/parport/ChangeLog
Remove drivers/char/ChangeLog
doc: typo - Table 1-2 should refer to "status", not "statm"
tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments
No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h
devres/irq: Fix devm_irq_match comment
Remove reference to kthread_create_on_cpu
tree-wide: Assorted spelling fixes
tree-wide: fix 'lenght' typo in comments and code
drm/kms: fix spelling in error message
doc: capitalization and other minor fixes in pnp doc
devres: typo fix s/dev/devm/
Remove redundant trailing semicolons from macros
fix typo "definetly" -> "definitely" in comment
tree-wide: s/widht/width/g typo in comments
Fix trivial conflict in Documentation/laptops/00-INDEX
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (370 commits)
ARM: S3C2443: Add set_rate and round_rate calls for armdiv clock
ARM: S3C2443: Remove #if 0 for clk_mpll
ARM: S3C2443: Update notes on MPLLREF clock
ARM: S3C2443: Further clksrc-clk conversions
ARM: S3C2443: Change to using plat-samsung clksrc-clk implementation
USB: Fix s3c-hsotg build following Samsung platform header moves
ARM: S3C64XX: Reintroduce unconditional build of audio device
ARM: 5961/1: ux500: fix CLKRST addresses
ARM: 5977/1: arm: Enable backtrace printing on oops when PC is corrupted
ASoC: Fix S3C64xx IIS driver for Samsung header reorg
ARM: S3C2440: Fix plat-s3c24xx move of s3c2440/s3c2442 support
[ARM] pxa: fix typo in mxm8x10.h
[ARM] pxa/raumfeld: set GPIO drive bits for LED pins
[ARM] pxa/zeus: Add support for mcp2515 CAN bus
[ARM] pxa/zeus: Add support for onboard max6369 watchdog
[ARM] pxa/zeus: Add Eurotech as the manufacturer
[ARM] pxa/zeus: Correct the USB host initialisation flags
[ARM] pxa/zeus: Allow usage of 8250-compatible UART in uncompress
[ARM] pxa: refactor uncompress.h for non-PXA uarts
[ARM] mmp2: fix incorrect calling of chip->mask_ack() for 2nd level cascaded IRQs
without the following patch audio ssttuutteerrs on
ASUS M2N32-SLI PREMIUM ACPI BIOS Revision 1304
the sound device is:
00:0e.1 Audio device: nVidia Corporation MCP55 High Definition Audio (rev a2)
worked with 2.6.32
Signed-off-by: Ralf Gerbig <rge@quengel.org>
arch/arm/mach-mx2/devices.c
arch/arm/mach-mx2/devices.h
sound/soc/pxa/pxa-ssp.c
Fix 'else' placement in ifdef block so that build succeeds:
sound/isa/opti9xx/opti92x-ad1848.c:221: error: 'else' without a previous 'if'
devel-stable
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (26 commits)
ALSA: hdmi - show debug message on changing audio infoframe
ALSA: hdmi - merge common code for intelhdmi and nvhdmi
ALSA: hda - Add ASRock mobo to MSI blacklist
ALSA: hda: uninitialized variable fix
ALSA: hda: Use LPIB for a Biostar Microtech board
ALSA: usb/audio.h: Fix field order
ALSA: fix jazz16 compile (udelay)
ALSA: hda: Use LPIB for Dell Latitude 131L
ALSA: hda - Build hda_eld into snd-hda-codec module
ALSA: hda - Support NVIDIA MCP89 and GT21x hdmi audio
ALSA: hda - Support max codecs to 8 for nvidia hda controller
ALSA: riptide: clean up while loop
ALSA: usbaudio - remove debug "SAMPLE BYTES" printk line
ALSA: timer - pass real event in snd_timer_notify1() to instance callback
ALSA: oxygen: change || to &&
ALSA: opti92x: use PnP data to select Master Control port
ASoC: fix ak4104 register array access
ASoC: soc_pcm_open: Add missing bailout tag
ALSA: usbaudio: Fix wrong bitrate for Creative Creative VF0470 Live Cam
ALSA: ua101: removing debugging code
Since alc_auto_create_input_ctls() doesn't set the elements for the
secondary ADCs, "Input Source" elemtns for these also get empty, resulting
in buggy outputs of alsactl like:
control.14 {
comment.access 'read write'
comment.type ENUMERATED
comment.count 1
iface MIXER
name 'Input Source'
index 1
value 0
This patch fixes alc_mux_enum_*() (and others) to fall back to the
first entry if the secondary input mux is empty.
Fix a wrong value passed to snd_hda_check_board_codec_sid_config() as
the upper-limit in parse_alc268(), so that any wrong value can't be
passed.
So far, no bogus value was set in the quirk entries, so this won't give
any behavioral changes.
Also change printk level for the two others.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Create patch_hdmi.c to hold common code from intelhdmi and nvhdmi.
For now the patch_hdmi.c file is simply included by patch_intelhdmi.c
and patch_nvhdmi.c, and does not represent a real codec.
There are no behavior changes to intelhdmi. However nvhdmi made several
changes when copying code out of intelhdmi, which are all reverted in
this patch. Wei Ni confirmed that the reverted code actually works fine.
Tested-by: Wei Ni <wni@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (66 commits)
mfd: Fix ucb1x00 build failure for collie_defconfig
mfd: Fix lpc_sch related depends/selects, fix build error
gpio: Fix sch_gpio warning
gpio: add Intel SCH GPIO controller driver
i2c: convert i2c-isch to platform_device
mfd: Use completion interrupt for WM831x AUXADC
mfd: Use completion interrupt for WM835x AUXADC
mfd: Introduce remove_script function for twl4030
mfd/mmc: SDHI Kconfig update
mfd: sh_mobile_sdhi MMC_CAP_MMC_HIGHSPEED support
gpiolib: Force wm831x GPIOs into GPIO mode when requested
mfd: Add WM831x revision B support
gpiolib: Correct debugfs display of WM831x GPIO inversion
gpiolib: Actually set output state in wm831x_gpio_direction_output()
tmio_mmc: Balance cell enable()/disable() calls
tmio_mmc: Remove const from platform data V3
tmio_mmc: Use 100ms mmc_detect_change() delay
tmio_mmc: Add MMC_CAP_MMC_HIGHSPEED support V2
tmio_mmc: Keep card-detect interrupts enabled
mfd: Add twl6030 base addr for ID0, ID1, ID2
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (26 commits)
sh: Convert sh to use read/update_persistent_clock
sh: Move PMB debugfs entry initialization to later stage
sh: Fix up flush_cache_vmap() on SMP.
sh: fix up MMU reset with variable PMB mapping sizes.
sh: establish PMB mappings for NUMA nodes.
sh: check for existing mappings for bolted PMB entries.
sh: fixed virt/phys mapping helpers for PMB.
sh: make pmb iomapping configurable.
sh: reworked dynamic PMB mapping.
sh: Fix up cpumask_of_pcibus() for the NUMA build.
serial: sh-sci: Tidy up build warnings.
sh: Fix up ctrl_read/write stragglers in migor setup.
serial: sh-sci: Add DMA support.
dmaengine: shdma: extend .device_terminate_all() to record partial transfer
sh: merge sh7722 and sh7724 DMA register definitions
sh: activate runtime PM for dmaengine on sh7722 and sh7724
dmaengine: shdma: add runtime PM support.
dmaengine: shdma: separate DMA headers.
dmaengine: shdma: convert to platform device resources
dmaengine: shdma: fix DMA error handling.
The headphone detect and charger are using the IRQ numbers so need
to take account of irq_base with the genirq conversion. I obviously
picked the wrong system for initial testing.
To better match genirq.
This avoids a lockup at boot.
Signed-off-by: Michele Ballabio <barra_cuda@katamail.com>
Rename for_each_bit to for_each_set_bit in the kernel source tree. To
permit for_each_clear_bit(), should that ever be added.
The patch includes a macro to map the old for_each_bit() onto the new
for_each_set_bit(). This is a (very) temporary thing to ease the migration.
[akpm@linux-foundation.org: add temporary for_each_bit()]
Suggested-by: Alexey Dobriyan <adobriyan@gmail.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Artem Bityutskiy <dedekind@infradead.org>
Commit eaa9b3a748539651f50e3a234c8854e1b42a839a introduced the following
uninitialized warning:
sound/pci/hda/patch_realtek.c: In function 'set_capture_mixer':
sound/pci/hda/patch_realtek.c:4928: warning: 'pin' is used uninitialized in this function
sound/pci/hda/patch_realtek.c:4918: note: 'pin' was declared here
It appears indeed that 'pin' needs to be initialized to 0.
Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com>
BugLink: https://launchpad.net/bugs/523953
The OR has verified that position_fix=1 is necessary to work around
errors on his machine.
Reported-by: MMarking
While trying to compile jazz16 isa sound driver on alpha (2.6.33+git), I
found a compile failure in jazz16.c (udelay is unknown). Fix it by
including delay.h.
Signed-foo-by: Meelis Roos <mroos@linux.ee>
The reorgs of the Samsung headers have moved the GPIO bank definitions
from plat/ to mach/ - the IIS driver needs to be updated to take care
of this.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
