This patch adds SPI devices in the ALSA diretory, including the Kconfig and
Makefile.
Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com>
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
SND_S3C24XX_SOC_NEO1973_WM8753 depends on MACH_GTA01 but the Kconfig
entry which is going to be merged is MACH_NEO1973_GTA01.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks.
Added helper functions for frequenty used callbacks:
snd_ctl_boolean_mono_info() and snd_ctl_boolean_stereo_info()
Notebook.
Description: The .device=0x0008 chips have new, but different EMU32 in/out
channels. Driver updated to make use of these EMU32 channels.
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
This patch cleans up duplicate includes in
sound/core/
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
sound/soc/
sound/ppc/
sound/aoa/codecs/snd-aoa-codec-tas.c:750: warning: 'tas_suspend' defined but not used
sound/aoa/codecs/snd-aoa-codec-tas.c:760: warning: 'tas_resume' defined but not used
Acked-by: Johannes Berg <johannes@sipsolutions.net>
deal with signedness of the stuff passed to set_bit() et.al.
This changes the uevent buffer functions to use a struct instead of a
long list of parameters. It does no longer require the caller to do the
proper buffer termination and size accounting, which is currently wrong
in some places. It fixes a known bug where parts of the uevent
environment are overwritten because of wrong index calculations.
Many thanks to Mathieu Desnoyers for finding bugs and improving the
error handling.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Use seq_file for the proc file read/write of snd-page-alloc module.
This automatically fixes bugs in the old proc code.
Remove unnecessary sbus_dma_reset function and change sbus_dma_enable
to avoid occasional system crashes when stopping recording.
Signed-off-by: Georg Chini <georg.chini@triaton-webhosting.com>
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Acked-by: Jeff Garzik <jeff@garzik.org>
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6.23:
sh: Fix fs.h removal from mm.h regressions.
sh: fix get_wchan() for SH kernels without framepointers
sh: arch/sh/boot - fix shell usage
rtc: rtc-sh: Correct sh_rtc_set_time() for some SH-3 parts.
sh: remove support for sh7300 and solution engine 7300
sh: Add sh to the CC_OPTIMIZE_FOR_SIZE dependencies.
sh: Kill off virt_to_bus()/bus_to_virt().
sh: sh-sci - fix SH7708 support
sh: Restrict DSP support to specific CPUs.
sh: Silence sq compile warning on sh4 nommu.
sh: Kill the rest of the SE73180 cruft.
sh: remove support for sh73180 and solution engine 73180
sh: remove old broken pint code
sh: Reclaim beginning of P3 space for vmalloc area.
sh: Fix Dreamcast DMA issues.
sh: Add kmap_coherent()/kunmap_coherent() interface for SH-4.
Various gpio and mux settings for the Osprey 440 weren't correct. Fix them
and provide some documentation about how the gpios work.
The osprey eeprom routine wasn't run for the 440, add it. It was also crap,
re-written to be better.
Add the Osprey 440 to the Bt878 ALSA driver's whitelist. Currently the sample
rate is fixed at 32kHz, as the driver doesn't support different rates for
digital input mode, though the card can select the rate from 32, 44.1, or 48
kHz via gpio.
Setting the audio gain via ALSA isn't supported yet; a userspace tool that
programs the X9221 via i2c-dev must be used.
The Bt878 digital audio format isn't programmed correctly for the CS5331A ADC
used, resulting in extremely garbled sound. That is fixed in a followup
patch.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
due to CKEN_xxx definition and pxa_set_cken() change, the pxa27x
ac97 cold reset is broken in ASoC, fixed to use bit index instead
of bit mask
Signed-off-by: eric miao <eric.y.miao@gmail.com>
The current SH DMA API is somewhat broken, not correctly matching
virtual channel to the correct SH DMAC. This wasn't noticeable when
using g2 DMA for the sound driver - one channel 0 is as good as any
other! - but caused the pvr2 driver to fail.
This patch fixes the pvr2 problem and consequently fixes the sound
driver to ensure it continues to function.
Signed-off by: Adrian McMenamin <adrian@mcmen.demon.co.uk>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
The recent fix for STAC92xx surround outputs broke the input pin
setting for shared line-in and mic jacks. This patch fixes the
breakage.
Basic audio support for the iMac 24'' model released on 09/2006,
including
headphone jack detection with automatic speaker muting.
This iMac uses the Realtek ALC885 codec, not a Sigmatel one as in
other models.
Functionality has been tested for internal speakers, headphone and
microphone.
Signed-off-by: Nicola Fagnani <nicfagn@iol.it>
Without the proper model setting, the Asus P5LD2 rear outputs remain
completely silent unlike other systems where the front speakers usually
work. This patch adds the P5LD2 to the quirk table.
Signed-off-by: Claudio Matsuoka <cmatsuoka@gmail.com>
This card is just a normal SB Live 24bit,
but under a different marketing name.
Fixed PM resume of cs46xx devices. It now restores properly the DSP
image and kick-off the DSP.
Added support for some boards with SPDIF in/out, and cleaned up the GPIO
enable function.
Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com>
Convert the snd_assert()s to simple if()s to prevent crashes when one of
the timer instance ioctls is called before the file is bound to a timer
device.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Parse error in ifdef or bad use of macro.
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
HP dx2200 and dx2250 use Micro-Star International (MSI) motherboards
(models MS-7254 and MS-7297 respectively) with an ALC862 codec in
threestack configuration. Adding this quirk allows correct 5.1 sound
output in these systems.
Rename ALC888_HP_NETTLE and ALC888_HP_LUCKNOW models to the more generic
names ALC888_6ST_HP and ALC888_3ST_HP since HP seems to be consistent
in the wiring of their 3stack and 6stack ALC888-based systems.
This patch fixes 5.1 surround output for the HP Samba using the same
quirk as the HP Lucknow. If HP machines are uniform in their wiring,
we should rename ALC888_HP_NETTLE to ALC888_6ST_HP and ALC888_HP_LUCKNOW
to ALC888_3ST_HP for generic HP 6stack and 3stack configurations.
Add line-in to the list of LG LW20 capture sources. Also fix the LG LW
pin assignment list comment.
Fixed AC3 interface in device_setup=0x00 mode thanks to Hakan
Lennestal and updated documentation
Signed-off-by: Thibault Le Meur <Thibault.LeMeur@supelec.fr>
Added support for line out controls for STAC9202 cards, and fixed issue
where master mixer control was being created twice for headphone and
speaker outs.
Make s3c24xx_i2s_set_clkdiv() change the correct bits.
Signed-off-by: Matt Reimer <mreimer@vpop.net>
Audiophile-usb fix (corrects little-endianness in 16bit
modes, resets interfaces at device initialization, and updates the
documentation).
Add VIA HDA identification to use the HDA-based Motorola modem of
the Clevo m540 laptop.
This patch adds support for the MSI K9AGM2-FIH on-board audio.
Signed-off-by: Tobin Davis <tdavis@dsl-only.net>
This patch adds Logitech QuickCam USB ID for Dell's
XPS M1210 notebooks.
Signed-off-by: Ritesh Raj Sarraf <rrs@researchut.com>
This patch fixes the following compile error with
CONFIG_SND_CS5530=y, CONFIG_ISA=n:
<-- snip -->
LD .tmp_vmlinux1
sound/built-in.o: In function 'snd_sb16_capture_trigger':
sb16_main.c:(.text+0x212ad): undefined reference to 'snd_sbdsp_command'
sb16_main.c:(.text+0x212cc): undefined reference to 'snd_sbdsp_command'
sb16_main.c:(.text+0x212f7): undefined reference to 'snd_sbdsp_command'
sound/built-in.o: In function 'snd_sb16_playback_trigger':
sb16_main.c:(.text+0x2136d): undefined reference to 'snd_sbdsp_command'
sb16_main.c:(.text+0x2138c): undefined reference to 'snd_sbdsp_command'
<-- snip -->
Fix the default pin configuration of Abit AW9D-MAX. The board has a
broken BIOS that doesn't set the correct pin default configs, which
screws up the auto-configuration of snd-hda-intel driver.
The patch enables the override of default pin config values.
One of the newly added model entries causes a regression on Toshiba A100.
It works fine with model=auto. So, let's deselect the entry again.
Another case of ALSA ticket #3040: we need an explicit USB ID match for
another Logitech camera/microphone device.
Signed-off-by: Daniel Drake <dsd@gentoo.org>
Added a quirk for Roland EXR series. Reported by Andre Coetzee.
Fix behaviour in poor resource conditions. With this new patch,
tidied with indent and with SNDRV_PCM_TRIGGER_STOP being used.
Show the last issued command in warning messages when any communication
error with CORB/RIRB occurs.
Also, a bit code clean-up for composing the command value in
*_send_cmd().
Use ARRAY_SIZE() to calculate the number of pin widgets for each codec
chip.
This also fixes a typo in STAC9205 code that gives a wrong number (14
instead of 12), which resulted in fatal communication errors.
