The PLL is disabled when the corresponding bit is set not the other
way around. This commit depends on my other commit with Subject
"ASoC: WM8804: Refactor set_pll code to avoid GCC warnings".
Signed-off-by: Dimitris Papastamos <dp@opensource.wolfsonmicro.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Ensure that no uninitialised variable warnings are generated by
GCC.
Make sure the DAI name does not include a '/' since we might have
per DAI debugfs or sysfs entries in the future.
GPIO2 and GPIO3 on the WM8962 are MFPs and need to be put into GPIO mode
before the GPIO block can be used to control them. We're already doing
this when used via gpiolib, factor out the code for use when setting static
configurations via platform data as well.
Allow microphone detection on WM8962 to be performed using the interrupt
signal, allowing the detection of both microphone presence and button
presses with a signal singal from the CODEC to CPU. Currently a 250ms
debounce time is applied to both short circuit and presence detection,
this has not been optimised.
The WM8962 features five GPIOs, add support for controlling their output
state via gpiolib.
While it is a generic serial port in practice the i.MX SSI is only supported
in Linux as an audio port (the i.MX has dedicated SPI controllers and so on).
This means we don't need to disambiguate against other uses of the hardware
and so can drop the -dai suffix from the driver name which fixes merge
issues with the i.MX tree in -next.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
The restrictions on configuring BCLK are overly cautious, other constraints
in the system should ensure that reconfiguration is not possible when the
device is sufficiently active to be unable to support reclocking.
The WM8804 is a high performance consumer mode S/PDIF transceiver with
support for 1 received channel and 1 transmitted channel.
No need to explicitly set the bus type, spi_register_driver does
that for us.
Add the widget for MICBIAS power control and allow configuration of the
microphone bias setup via the platform data for the WM8962. When
microphone status signals are brought out to GPIO this should be
sufficient to enable microphone detection.
There are some status bits for microphone detection in here.
Provide an initial hookup for interrupts on the WM8962. Currently we simply
report error status via log messages if an IRQ is provided for the device.
For consistency.
When configuring the FLL we preserve the FLL enable configuration in order
to allow us to reenable the FLL after configuration but we do not clear
the other bits in the register, causing old configuration to be preserved.
Since we are using custom get/put handlers
use SOC_ENUM_SINGLE_EXT_DECL instead of the original SOC_ENUM_SINGLE_DECL
macro.
sound/soc/codecs/wm8985.c: In function 'wm8985_hw_params':
sound/soc/codecs/wm8985.c:731:2: warning: format '%d' expects type 'int', but argument 4 has type 'size_t'
Actually the variable is fine as int.
We are not using the private data in this function, so get rid of it.
Remove version number and clean up some indentation.
Helps tracing errors further up the stack.
Acked-by: Jassi Brar <jassi.brar@samsung.com>
Could use dev_() but we'd have to remember the struct device somewhere
and it wouldn't make the logging clearer.
Otherwise we try to re-register the CODEC device if the module is reloaded
and sysfs becomes miserable.
At least some of the systems using this device have multiple audio
subsystems so provide some guidance to userspace about which one this
is.
We need to pass the register index and not the register value.
This patch depends on my previous patch "ASoC: Delegate to hw
specific read for volatile registers".
Ensure that reads on volatile registers will correctly delegate
to the bus specific read function.
Go back to the new world order.
(Also fixed indentation.)
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound-2.6 into topic/asoc
Spot the build testing.
The code can't really cope with I/O errors, so it would be better
to be consistent throughout all cache functions and return -1 instead
of -EINVAL.
The return value of snd_soc_read(...) is mostly checked in the probe
function and nowhere else.
Also clean up the error print a bit.
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into for-2.6.37
Make sure we stay within the cache boundaries when updating the
register cache.
register cache.
rtd->dev.init_name is set twice in soc_probe_dai_link. I removed the first
assignement from dai_link->stream_name since then there won't be sysfs name
changes and usually dai_link->name seems to fit anyway better for a sysfs
directory name.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Let's not add the core controls twice.
Helps with diagnostics.
So machine drivers can see the declaration.
Current FSI driver had data push/pop functions.
But the main operation of these 2 were very similar.
This mean it is possible to merge these to 1 function.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Current FSI driver is using
data-length / width / number / offset for variables.
But it was a very confusing name.
This patch rename them to easy to understand,
and add new functions for it.
Standardise on 'wm8978' as the name for the CODEC.
Reported-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Now codec hits the SND_SOC_BIAS_OFF also when it is idle. This is also
the default state after probing and codec is left unconfigured and
unpowered by default. Initialization will happen when the bias state changes
and aic3x_set_power does power-up and cache sync.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
There is no need to reset the codec and perform cache sync if none of the
supply regulators were not disabled. Patch registers a notifier callback for
each supply and callback then sets a flag to indicate when cache sync is
required.
HW writes are also needless when codec bias is off so cache_only flag is set
independently of actual supply regulators state.
Now all the regulators are disabled when entering into SND_SOC_BIAS_OFF
and enabled when coming back to SND_SOC_BIAS_STANDBY state. Currently this
runtime control happens only with suspend/resume as this patch does not
change the default idle behavior.
This patch manages all the regulators and reset since it seems that register
sync is needed even if only analog supplies AVDD and DRVDD are disabled.
This was noted when the system was running with idle behavior changed and
IOVDD and DVDD were on.
It is not known are all the registers needed to sync or only some subset of
them. Therefore patch plays safe and does always full shutdown/power-up.
It will be easier to keep regulator enable/disable calls in sync when dynamic
regulator management is added if regulator management is moved from
aic3x_i2c_probe/_remove to aic3x_probe/_remove.
Purpose of this virtual Detection pin is to keep codec bias on whenever the
GPIO or jack detection features are needed.
Jack detection needs a mic bias so machine drivers can construct a following
route for instance for keeping the path and codec bias on:
"Input Jack" -> "Mic Bias xV" -> "Detection" -> detection block inside codec.
For the GPIO the machine driver can force the pin on with
snd_soc_dapm_force_enable_pin.
