this is about coverity id #100.
It seems the if statement is negated, since the else branch calls
remove_info() with sflist->currsf as a parameter where it gets
dereferenced.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Fixed a typo in 'PC Speaker Playback Switch' control name.
To permit use, in ice1712, of the mpu401 info flags recently added to
mpu401_uart, adds info_flags in snd_ice1712_card_info so that additional
flags can be set, if desired. 'MPU401_INFO_INTEGRATED' is always set with
the ice1712. The flags are passed on to snd_mpu401_uart_new().
_INFO_OUTPUT is set for DMX6fire mpu2.
Signed-off-by: Alan Horstmann <gineera@aspect135.co.uk>
Changed the assigned model for HP dc7600 with ALC260 codec
to match better with the actual I/O assignment.
Patch taken from ALSA bug#2157.
This patch adds support for useable front audio channels,
user controllable headphone channel and optical output.
Signed-off-by: Matt Taylor <mwtaylor@gmail.com>
Fix 64bit address of MPU401 MMIO port on au88x0 chip.
Consumer AC97 is not used by the Terratec DMX6fire, but eeprom bit indicates
it is; change the stored value to disable failing consumer mode.
Change the 5th argument of snd_mpu401_uart_new() to bit flags
instead of a boolean. The argument takes bits that consist of
MPU401_INFO_XXX flags.
The callers that used the value 1 there are replaced with
MPU401_INFO_INTEGRATED.
Fixed the compilation with hdsp driver built in kernel.
The traditional hwdep loader is used in this case.
As per Takashi's feedback, this is a cleanup to make cs5535audio be
single device per system. The diff is against 2.6.17-rc4 with
Takashi's patch adding the module_params for index, id and enable.
Signed-off-by: Jaya Kumar <jayakumar.alsa@gmail.com>
- fold lines and fix spaces to follow the standard style
- added some comments
- moved EXPORT_SYMBOL() near the definition
- some code clean up
Fix a typo introduced by the last fix.
Remove an unnecessary ENTER_UART instruction during au88x0 init as it makes
the first/subsequent midi open to fail.
Some devices don't have the required class-specific endpoint descriptors.
Instead of making this case an error, this patch makes the driver guess the
endpoint attributes.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Use the basic init verbs for ALC260 instead of hp init verbs
since hp init verbs seem incomplete and not working on some machines.
Removed zero-initializations of static variables.
A tiny optimization.
Fix the draining of PCM capture stream in the PCM middle layer.
snd_pcm_drain() ignored capture streams, but it should change
the state to SNDRV_PCM_DRAINING.
Add support for the ATI RS600 HDMI audio device. It has a one-stream
pure digital stereo codec that isn't handled by the generic codec
support.
Signed-off-by: Felix Kuehling <fkuehlin@ati.com>
Scope braces were not done the One True Kernel Way.
Signed-off-by: Andreas Mohr <andi@lisas.de>
- add 3D sound pre-3D/post-3D switch, as seen in standard AC-97
- rename controls to shorter and more accurate strings
- add suspend/resume handlers
- fix problem (private_data members not set)
Playing a file while suspending will resume correctly with this patch,
so I assume the hardware to get fully correctly reinitialized with
this patch.
Fixed rwlock around snd_iprintf() in sound core part.
Replaced with mutex.
Also, make mutex and flags static variables with addition of
snd_card_locked() function (just for sound.c).
Fixed the handling of capture controls on ALC882 3/6-stack models.
Now the driver checks the availability of NID 07h.
Added the missing support for Sony Vaio VGN-S3HP with ALC260 codec.
The patch taken from ALSA bug#2101.
Fixed a bug in rme96 driver that the full-duplex on OSS emulation
doesn't work due to the invalid period size parameter.
Add support for some audio quirks of the Apple Mac Mini (early 2006)
Signed-off-by: Sam Revitch <samr7@cs.washington.edu>
This patch rewrites the remote control code to use a table for
the peculiarities of the various SB models, and adds support
for a third model.
Signed-off-by: Raimonds Cicans <ray@vardes.lv>
Enable the support of mpu401 PCI port only when mpu_port=1 module
option is given, i.e. disabled as default.
It turned out that the check of integrated midi port isn't perfect
and caused hang-ups on some boards.
Change the order in vortex_probe to set the card details before creating the
components, meaning for example that card->shortname is available when
registering the midi port.
I have also added extra to card->shortname, and a line to overwrite the midi
name following snd_mpu401_uart_new.
Adds support for the 9227/9228/9229 sigmatel hda codecs.
Signed-off-by: Matt Porter <mporter@embeddedalley.com>
Fixed the master mute switch on VAIO laptops with STAC7661
codec chip.
Added missing module_param*() and MODULE_PARM_DESC() for
cs5535audio driver.
Added a workaround for ASUS A6KM board that requires EAPD
rather than SPDIF-in.
Added the model entry for LG S1 laptop.
Add a get_port_info callback to the snd_rawmidi_global_ops structure to
allow the USB MIDI driver to supply information flags for the sequencer
ports created by seq_midi.
Add four new information flags SNDRV_SEQ_PORT_TYPE_HARDWARE, _SOFTWARE,
_SYNTHESIZER, _PORT for sequencer ports. This makes it easier for apps
like Rosegarden to make policy decisions based on the port type.
Fix the port information about non-MIDI messages that had wrong values
for some OPL3 and EmuX ports.
fix a typo in the info locking code
Fix a compile warning in timer.c due to unused variables.
Move mmap_count to snd_pcm_substream instead of runtime struct
so that multiplly opened substreams via O_APPEND can be handled
correctly.
Added O_APPEND flag support to PCM to enable shared substreams
among multiple processes. This mechanism is used by dmix and
dsnoop plugins.
Inserted might_sleep() in snd_iprintf() for sanity check.
Don't lock during showing proc read. snd_iprintf() might sleep.
Remove unneeded read/write_size fields in proc text ops.
snd_info_set_text_ops() is fixed, too.
Make the read/write buffer size of proc text interface variable.
Clean up ugly hacks for sync with alsa-lib code in pcm_lib.c.
Also, optimize snd_pcm_hw_params_choose() with a loop.
Move EXPORT_SYMBOL()s to places adjacent to functions/variables.
Also move OSS-specific hw_params helper functions to pcm_oss.c.
Move EXPORT_SYMBOL() to adjacent to each exported function/variable.
