path: root/sound
2011-03-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: HDA: Realtek: Avoid unnecessary volume control index on Surround/Side ASoC: Support !REGULATOR build for sgtl5000 ALSA: hda - VIA: Fix VT1708 can't build up Headphone control issue ALSA: hda - VIA: Correct stream names for VT1818S ALSA: hda - VIA: Fix codec type for VT1708BCE at the right timing ALSA: hda - VIA: Fix invalid A-A path volume adjust issue ALSA: hda - VIA: Add missing support for VT1718S in A-A path ALSA: hda - VIA: Fix independent headphone no sound issue ALSA: hda - VIA: Fix stereo mixer recording no sound issue ALSA: hda - Set EAPD for Realtek ALC665 ALSA: usb - Remove trailing spaces from USB card name strings sound: read i_size with i_size_read() ASoC: Remove bogus check for register validity in debugfs write ASoC: mini2440: Fix uda134x codec problem.
2011-03-23Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-03-23ALSA: HDA: Realtek: Avoid unnecessary volume control index on Surround/SideDavid Henningsson
Similar to commit 7e59e097c09b82760bb0fe08b0fa2b704d76c3f4, this patch avoids unnecessary volume control indices for more Realtek auto-parsers, e g the ALC66x family, on the "Surround" and "Side" controls. These indices cause these volume controls to be ignored by PulseAudio and vmaster and should be removed whenever possible. Cc: stable@kernel.org Reported-by: Jan Losinski <losinski@wh2.tu-dresden.de> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-22ASoC: Support !REGULATOR build for sgtl5000Mark Brown
The regulator is optional depending on board design. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-22ALSA: hda - VIA: Fix VT1708 can't build up Headphone control issueLydia Wang
Since VT1708 didn't support the control of getting connection number, building of headphone control will fail in via_hp_build() function. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-22ALSA: hda - VIA: Correct stream names for VT1818SLydia Wang
Correct stream names of analog playback and capture streams for VT1818S. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-22ALSA: hda - VIA: Fix codec type for VT1708BCE at the right timingLydia Wang
Add get_codec_type() in via_new_spec() function to make sure getting correct codec type before building mixer controls. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-22ALSA: hda - VIA: Fix invalid A-A path volume adjust issueLydia Wang
Modify vt_auto_create_analog_input_ctls() function to fix invalid a-a path volume adjust issue for VT1708S, VT1702 and VT1716S codecs. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-22ALSA: hda - VIA: Add missing support for VT1718S in A-A pathLydia Wang
Modify mute_aa_path() function to support VT1718S codec. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-22ALSA: hda - VIA: Fix independent headphone no sound issueLydia Wang
Modify via_independent_hp_put() function to support VT1718S and VT1812 codecs, and fix independent headphone no sound issue. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-22ALSA: hda - VIA: Fix stereo mixer recording no sound issueLydia Wang
Modify function via_mux_enum_put() to fix stereo mixer recording no sound issue. Signed-off-by: Lydia Wang <lydiawang@viatech.com.cn> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-21ALSA: hda - Set EAPD for Realtek ALC665Andres Mejia
Set EAPD for Realtek ALC665 (Vendor Id: 0x10eSet EAPD for Realtek ALC665 (Vendor Id: 0x10ec0665). Signed-off-by: Andres Mejia <mcitadel@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-21ALSA: usb - Remove trailing spaces from USB card name stringsTakashi Iwai
Some USB devices give trailing spaces in strings returned from usb_string(). This confuses the automatic card-id creation, resulting always in "default". This patch fixes the behavior by removing trailing spaces. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (308 commits) ALSA: sound/pci/asihpi: check adapter index in hpi_ioctl ALSA: aloop - Fix possible IRQ lock inversion ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail() ALSA: ctxfi - use list_move() instead of list_del()/list_add() combination ALSA: firewire - msleep needs delay.h ALSA: firewire-lib, firewire-speakers: handle packet queueing errors ALSA: firewire-lib: allocate DMA buffer separately ALSA: firewire-lib: use no-info SYT for packets without SYT sample ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver ALSA: hda - Remove an unused variable in patch_realtek.c ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecs ALSA: hda - fix digital mic selection in mixer on 92HD8X codecs ALSA: hda - Move default input-src selection to init part ALSA: hda - Initialize special cases for input src in init phase ALSA: ctxfi - Clear input settings before initialization ALSA: ctxfi - Fix SPDIF status retrieval ALSA: ctxfi - Fix incorrect SPDIF status bit mask ALSA: ctxfi - Fix microphone boost codes/comments ALSA: atiixp - Fix wrong time-out checks during ac-link reset ALSA: intel8x0m: append 'm' to "r_intel8x0" ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-18sound: read i_size with i_size_read()Xiaochen Wang
Convert direct read of inode->i_size to using i_size_read(). i_size_read is guaranteed to return a valid value and its caller does not need to use addtional locking. Signed-off-by: Xiaochen Wang <wangxiaochen0@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-18ASoC: Remove bogus check for register validity in debugfs writeMark Brown
Since not all registers need to be cached and the cache is entirely optional anyway we shouldn't be checking that a register is in the cached range. If the register is invalid then the actual I/O code can determine that and report an error. Similarly, the step size can and should be enforced by the lower level code if it's important. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-18Merge branch 'topic/asoc' of ↵Mark Brown
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 into for-2.6.39
2011-03-18Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-03-18ALSA: sound/pci/asihpi: check adapter index in hpi_ioctlDan Rosenberg
The user-supplied index into the adapters array needs to be checked, or an out-of-bounds kernel pointer could be accessed and used, leading to potentially exploitable memory corruption. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-18ALSA: aloop - Fix possible IRQ lock inversionTakashi Iwai
loopback_pos_update() can be called in the timer callback, thus the lock held should be irq-safe. Otherwise you'll get AB/BA deadlock together with substream->self_group.lock. Reported-and-tested-by: Knut Petersen <Knut_Petersen@t-online.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-17Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits) omap: zoom: host should not pull up wl1271's irq line arm: plat-omap: iommu: fix request_mem_region() error path OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430 omap4: mux: Remove duplicate mux modes omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected omap4: board-omap4panda: Initialise the serial pads omap3: board-3430sdp: Initialise the serial pads omap4: board-4430sdp: Initialise the serial pads omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init omap2+: mux: Remove the use of IDLE flag omap2+: Add separate list for dynamic pads to mux perf: add OMAP support for the new power events OMAP4: Add IVA OPP enteries. OMAP4: Update Voltage Rail Values for MPU, IVA and CORE OMAP4: Enable 800 MHz and 1 GHz MPU-OPP OMAP3+: OPP: Replace voltage values with Macros OMAP3: wdtimer: Fix CORE idle transition Watchdog: omap_wdt: add fine grain runtime-pm ... Fix up various conflicts in - arch/arm/mach-omap2/board-omap3evm.c - arch/arm/mach-omap2/clock3xxx_data.c - arch/arm/mach-omap2/usb-musb.c - arch/arm/plat-omap/include/plat/usb.h - drivers/usb/musb/musb_core.h
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-17Merge branches 'defcfg', 'drivers' and 'cyberpro-next' of ↵Linus Torvalds
master.kernel.org:/home/rmk/linux-2.6-arm * 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6647/1: add Versatile Express defconfig ARM: 6644/1: mach-ux500: update the U8500 defconfig * 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6764/1: pl011: factor out FIFO to TTY code ARM: 6763/1: pl011: add optional RX DMA to PL011 v2 ARM: 6758/1: amba: support pm ops ARM: amba: make amba_driver id_table const ARM: amba: make internal ID table handling const ARM: amba: make probe() functions take const id tables ARM: 6662/1: amba: make amba_bustype non-static ARM: mmci: add dmaengine-based DMA support ARM: mmci: no need for separate host->data_xfered ARM: mmci: avoid unnecessary switch to data available PIO interrupts ARM: mmci: no need to call flush_dcache_page() with sg_miter API ARM: mmci: avoid reporting too many completed bytes on fifo overrun ALSA: AACI: make fifo variables more explanitory ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period ALSA: AACI: use snd_pcm_lib_period_bytes() ALSA: AACI: clean up AACI announcement printk ALSA: AACI: fix channel mask selection ALSA: AACI: fix number of channels for record ALSA: AACI: fix multiple IRQ claiming * 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm: VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var() VIDEO: cyberpro: remove useless function extreg pointers VIDEO: cyberpro: update handling of device structures VIDEO: cyberpro: add support for video capture I2C VIDEO: cyberpro: make 'reg_b0_lock' always present VIDEO: cyberpro: add I2C support VIDEO: cyberpro: select lowest multipler/divisor for PLL
2011-03-17Merge branches 'aaci', 'mmci-dma', 'pl' and 'pl011' into driversRussell King
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-16Merge branch 'topic/hda' into for-linusTakashi Iwai
2011-03-16Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-03-16ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail()Nicolas Kaiser
Merge list_del() + list_add_tail() to list_move_tail(). Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-16Merge branch 'for-2.6.39' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
2011-03-16ALSA: ctxfi - use list_move() instead of list_del()/list_add() combinationKirill A. Shutemov
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-16ALSA: firewire - msleep needs delay.hStephen Rothwell
fixes this error: sound/firewire/fcp.c: In function 'fcp_avc_transaction': sound/firewire/fcp.c:103: error: implicit declaration of function 'msleep' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into devel-stable Conflicts: arch/arm/mm/Kconfig
2011-03-15ALSA: firewire-lib, firewire-speakers: handle packet queueing errorsClemens Ladisch
Add an AMDTP stream error state that occurs when we fail to queue another packet. In this case, the stream is stopped, and the error can be reported when the application tries to restart the PCM stream. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: firewire-lib: allocate DMA buffer separatelyClemens Ladisch
For correct cache coherency on some architectures, DMA buffers must be allocated in a different cache line than data that is concurrently used by the CPU. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: firewire-lib: use no-info SYT for packets without SYT sampleClemens Ladisch
In non-blocking mode, the SYT_INTERVAL is larger than the number of audio frames in each packet, so there are packets that do not contain any frame to which the SYT could be applied. For these packets, the SYT must not be the timestamp of the next valid SYT frame, but the special no-info SYT value. This fixes broken playback on the FireWave at 44.1 kHz. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-15ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driverClemens Ladisch
Add a driver for two playback-only FireWire devices based on the OXFW970 chip. v2: better AMDTP API abstraction; fix fw_unit leak; small fixes v3: cache the iPCR value v4: FireWave constraints; fix fw_device reference counting; fix PCR caching; small changes and fixes v5: volume/mute support; fix crashing due to pcm stop races v6: fix build; one-channel volume for LaCie v7: use signed values to make volume (range checks) work; fix function block IDs for volume/mute; always use channel 0 for LaCie volume Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: Jay Fenlason <fenlason@redhat.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: hda - Remove an unused variable in patch_realtek.cTakashi Iwai
2011-03-14ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecsVitaliy Kulikov
This patch replaces use of the harcoded arrays of pins, muxes, digital mics and adcs with the auto-generated ones using codec parsing and auto-discovers all actually connected digital mic pins on 92HD8X-like codecs This patch also adds the support for d-mic on pin 0x20. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: hda - fix digital mic selection in mixer on 92HD8X codecsVitaliy Kulikov
When the mux for digital mic is different from the mux for other mics, the current auto-parser doesn't handle them in a right way but provides only one mic. This patch fixes the issue. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: hda - Move default input-src selection to init partTakashi Iwai
Move the default input-src selection code for alc268/269 to the init part instead of the parser. The input-src selection might be overwritten by init verbs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: hda - Initialize special cases for input src in init phaseTakashi Iwai
Currently some special handling for the unusual case like dual-ADCs or a single-input-src is done in the tree-parse time in set_capture_mixer(). But this setup could be overwritten by static init verbs. This patch moves the initialization into the init phase so that such input-src setup won't be lost. Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: ctxfi - Clear input settings before initializationPrzemyslaw Bruski
Clear input settings before initialization. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: ctxfi - Fix SPDIF status retrievalPrzemyslaw Bruski
SDPIF status retrieval always returned the default settings instead of the actual ones. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: ctxfi - Fix incorrect SPDIF status bit maskPrzemyslaw Bruski
SPDIF status mask creation was incorrect. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-14ALSA: ctxfi - Fix microphone boost codes/commentsPrzemyslaw Bruski
microphone boost was set at +12dB, not +20dB (like in Windows driver and in adc_conf structure declaration), some comments added. Signed-off-by: Przemyslaw Bruski <pbruskispam@op.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-13Merge branch 'fix/asoc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'fix/asoc' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ASoC: Ensure WM8958 gets all WM8994 late revision widgets ASoC: Fix typo in late revision WM8994 DAC2R name ASoC: Use the correct DAPM context when cleaning up final widget set ASoC: Fix broken bitfield definitions in WM8978 ASoC: AM3517: Update codec name after multi-component update
2011-03-12Merge branch 'master' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-tcc into devel-stable
2011-03-11ALSA: atiixp - Fix wrong time-out checks during ac-link resetTakashi Iwai
The time-out in snd_atiixp_aclink_reset() is wrongly checked, and it resulted in exiting from the loop at the first iteration. Reported-by: Amir Shamsuddin <AmirS2+alsa@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: intel8x0m: append 'm' to "r_intel8x0"Paul Bolle
Appending an 'm' will distinguish it from a similar struct in intel8x0.c Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
