path: root/sound
2013-06-17ALSA: hda - Add models for Dell headset jacksDavid Henningsson
These headset jacks keep coming in on more and more platforms, and it's possible I don't catch them all. Make it easier to test and verify by making models. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17ALSA: usb-audio: Fix invalid volume resolution for Logitech HD Webcam c310Takashi Iwai
Just like the previous fix for LogitechHD Webcam c270 in commit 11e7064f35bb87da8f427d1aa4bbd8b7473a3993, c310 model also requires the same workaround for avoiding the kernel warning. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59741 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17ALSA: hda - Fix pin configurations for MacBook Air 4,2Takashi Iwai
MacBook Air 4,2 requires the whole default pin configuration table to be overridden by the driver, as usual, as Apple's machines don't set up properly after boot. Otherwise mic won't work, and other ill effect may happen. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59381 Reported-and-tested-by: Peter John Hartman <peterjohnhartman@gmail.com> Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17ALSA: usb-audio: work around Android accessory firmware bugClemens Ladisch
When the Android firmware enables the audio interfaces in accessory mode, it always declares in the control interface's baInterfaceNr array that interfaces 0 and 1 belong to the audio function. However, the accessory interface itself, if also enabled, already is at index 0 and shifts the actual audio interface numbers to 1 and 2, which prevents the PCM streaming interface from being seen by the host driver. To get the PCM interface interface to work, detect when the descriptors point to the (for this driver useless) accessory interface, and redirect to the correct one. Reported-by: Jeremy Rosen <jeremy.rosen@openwide.fr> Tested-by: Jeremy Rosen <jeremy.rosen@openwide.fr> Cc: <stable@vger.kernel.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17ALSA: hda - Headset mic support for three more machinesDavid Henningsson
They need these quirks to have headset mic support. BugLink: https://bugs.launchpad.net/bugs/1189363 Tested-by: Shawn Wang <shawn.wang@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS fixes from Al Viro: "Several fixes + obvious cleanup (you've missed a couple of open-coded can_lookup() back then)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: snd_pcm_link(): fix a leak... use can_lookup() instead of direct checks of ->i_op->lookup move exit_task_namespaces() outside of exit_notify() fput: task_work_add() can fail if the caller has passed exit_task_work() ncpfs: fix rmdir returns Device or resource busy
2013-06-15snd_pcm_link(): fix a leak...Al Viro
in case when snd_pcm_stream_linked(substream) is true, we end up leaking group. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-10Merge remote-tracking branch 'asoc/fix/wm8994' into asoc-linusMark Brown
2013-06-10Merge remote-tracking branch 'asoc/fix/tlv320aic3x' into asoc-linusMark Brown
2013-06-10Merge remote-tracking branch 'asoc/fix/cs42l52' into asoc-linusMark Brown
2013-06-10Merge remote-tracking branch 'asoc/fix/core' into asoc-linusMark Brown
2013-06-10Merge remote-tracking branch 'asoc/fix/arizona' into asoc-linusMark Brown
2013-06-07ASoC: tlv320aic3x: Remove deadlock from snd_soc_dapm_put_volsw_aic3x()Andreas Irestål
When calling snd_soc_dapm_sync(), it eventually tries to lock the same mutex already locked in snd_soc_dapm_put_volsw_aic3x() and a deadlock occurs. By moving the mutex unlock to just before snd_soc_dapm_sync(), this deadlock is prevented. This problem was introduced in Linux 3.5 Signed-off-by: Andreas Irestål <Andreas.Irestal@axis.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-07ASoC: dapm: Treat DAI widgets like AIF widgets for powerMark Brown
Even though they are virtual widgets DAI widgets still get counted for the DAPM context power management so we can't just use the active state to check if they should be powered as they may not be part of a complete path. Instead split them into input and output widgets and do the same power checks as we perform on AIFs. Reported-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-05ASoC: arizona: Correct AEC loopback enableCharles Keepax
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-05ALSA: usb-audio - Fix invalid volume resolution on Logitech HD webcam c270Takashi Iwai
USB audio driver spews an error message when probing Logitech HD webcam c270: ALSA mixer.c:1300 usb_audio: Warning! Unlikely big volume range (=6144), cval->res is probably wrong. ALSA mixer.c:1304 usb_audio: [5] FU [Mic Capture Volume] ch = 1, val = 1536/7680/1 Obviously the device needs a fixed volume resolution (cval->res = 384) like other Logitech devices. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=821735 Reported-and-tested-by: Cristian Rodríguez <crrodriguez@opensuse.org> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-04ALSA: usb-audio - Apply Logitech QuickCam Pro 9000 quirk only to audio ifaceTakashi Iwai
... instead of applying to all interfaces. Reference: http://forums.gentoo.org/viewtopic-p-6886404.html Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-03ALSA: hda/via - Clean up duplicated codesTakashi Iwai
The previous commit was written in the way to make the backport to 3.9.y easier, and left the duplicated open codes intentionally. Now let's clean up the duplicated codes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-03ALSA: hda/via - Fix wrongly cleared pins after suspend on VT1802Takashi Iwai
VIA driver has a special suspend handling only for VT1802 to reduce the pop noise. During the transition to the generic parser, the behavior of snd_hda_set_pin_ctl() was also changed to modify the cached values, too. And this caused a regression where the pin is still cleared even after the resume (including the resume from power save), resulting in the silent output. The fix is simply to replace snd_hda_set_pin_ctl() with the explicit call of snd_hda_codec_write() again. Reported-by: Alex Riesen <raa.lkml@gmail.com> Cc: <stable@vger.kernel.org> [v3.9] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-03ALSA: hda - Add keep_eapd_on flag to generic parserTakashi Iwai
VT1802 codec seems to reset EAPD of other pins in the hardware level, and this was another reason of the silent headphone output on some machines. As a workaround, introduce a new flag indicating to keep the EPAD on to the generic parser, and set it in patch_via.c. Reported-by: Alex Riesen <raa.lkml@gmail.com> Cc: <stable@vger.kernel.org> [v3.9] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-03ALSA: hda - Allow setting automute/automic hooks after parsingTakashi Iwai
Some codec drivers (VIA codecs and some Realtek fixups) set the automute and automic hooks after calling snd_hda_gen_parse_auto_config(). In the current code, the hook pointers are referred only in snd_hda_gen_parse_auto_config() and passed to snd_hda_jack_detect_enable_callback(), thus changing the hook values won't change the actually called callbacks properly. This patch fixes this bug by setting the static functions as the primary callback functions for the jack detection, and let them calling the appropriate hooks dynamically. Cc: <stable@vger.kernel.org> [v3.9] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-03ALSA: hda/via - Disable broken dynamic power controlTakashi Iwai
Since the transition to the generic parser, the actual routes used there don't match always with the assumed static paths in some set_widgets_power_state callbacks. This results in the wrong power setup in the end. As a temporary workaround, we need to disable the calls together with the non-functional dynamic power control enum. Reported-by: Alex Riesen <raa.lkml@gmail.com> Cc: <stable@vger.kernel.org> [v3.9] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-03ASoC: pcm: Require both CODEC and CPU support when declaring stream capsMark Brown
When declaring playback and capture capabilities check for both CODEC side and CPU side support rather than only checking for CODEC side support. While it is unusual some CPUs do have unidirectional DAIs. Reported-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2013-06-03ALSA: usb-audio: fix Roland/Cakewalk UM-3G supportClemens Ladisch
Commit 927c9423dd5f2d1c0b93d5e694ab84b4a5559713 (ALSA: usb-audio: add Edirol UM-3G support) used a wrong quirk type, which would make the driver refuse to attach with the error message "MIDIStreaming interface descriptor not found". Cc: <stable@vger.kernel.org> # 3.3 and later Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-31ALSA: hda - Add headset quirk for two Dell machinesDavid Henningsson
This quirk is required for the headset mic to work on these two machines. BugLink: https://bugs.launchpad.net/bugs/1186170 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-31ALSA: hda - add dock support for Thinkpad T431sEbben Aries
Add a model/fixup string "lenovo-dock", for Thinkpad T431s, to allow sound in docking station. Tested on Lenovo T431s with ThinkPad Mini Dock Plus Series 3 Signed-off-by: Ebben Aries <earies@dscp.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-31ALSA: sis7019: fix error return code in sis_chip_create()Wei Yongjun
Fix to return a negative error code in the pci_set_dma_mask() error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-30ASoC: wm8994: Ensure microphone detection state is reset on removalMark Brown
2013-05-30ASoC: wm8994: Avoid leaking pm_runtime reference on removed jack raceMark Brown
2013-05-29ASoC: cs42l52: fix hp_gain_enum shift value.Nicolas Schichan
Signed-off-by: Nicolas Schichan <nschichan@freebox.fr> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-29ASoC: cs42l52: use correct PCM mixer TLV dB scale to match datasheet.Nicolas Schichan
2013-05-29Merge tag 'asoc-v3.10-rc3' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: Updates for v3.10 A series of driver specific updates, none particularly critical, plus one fix to the compressed API code to handle capture streams properly which is very safe for mainline as there's no current users.
2013-05-28Merge remote-tracking branch 'asoc/fix/wm8994' into asoc-linusMark Brown
2013-05-28Merge remote-tracking branch 'asoc/fix/max98090' into asoc-linusMark Brown
2013-05-28Merge remote-tracking branch 'asoc/fix/davinci' into asoc-linusMark Brown
2013-05-28Merge remote-tracking branch 'asoc/fix/cs42l52' into asoc-linusMark Brown
2013-05-28Merge remote-tracking branch 'asoc/fix/compress' into asoc-linusMark Brown
2013-05-28Merge remote-tracking branch 'asoc/fix/arizona' into asoc-linusMark Brown
2013-05-28ASoC: cs42l52: fix default value for MASTERA_VOL.Nicolas Schichan
The default register value for MASTERA_VOL is 0x00, the same as MASTERB_VOL. Signed-off-by: Nicolas Schichan <nschichan@freebox.fr> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2013-05-28ASoC: wm8994: check for array index returnedVinod Koul
The array 'drc_cfg' of size 3 may use index value -22 (EINVAL) The array 'retune_mobile_cfg' of size 3 may use index value -22 (EINVAL) Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-28ASoC: wm8994: Fix reporting of accessory removal on WM8958Mark Brown
During recent refactoring the code to report removal when MICDET reports an absent microphone was removed, causing problems for systems which rely solely on the MICDET for this functionality. Restore it. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-28ASoC: wm8994: use the correct pointer to get the control valueVinod Koul
2013-05-25ASoC: wm5110: Correct DSP4R Mixer control nameCharles Keepax
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2013-05-23ALSA: usb-6fire: Modify firmware version checkTorsten Schenk
Check only the uppermost 16 bits instead of the whole 32 bits of the version information. Do this because all firmware version tested with this version information worked correctly and the strict check causes problems for several users. Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-22ASoC: cs42l52: fix master playback mute mask.Nicolas Schichan
The mask should define the bits to change in the register, not the bits to preserve. This fixes the inadvertent changes of the "Headphone Analog Gain" value during mute/unmute. Signed-off-by: Nicolas Schichan <nschichan@freebox.fr> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-22ASoC: cs42l52: fix bogus shifts in "Speaker Volume" and "PCM Mixer Volume" ↵Nicolas Schichan
controls. Signed-off-by: Nicolas Schichan <nschichan@freebox.fr> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-22ASoC: cs42l52: microphone bias is controlled by IFACE_CTL2 register.Nicolas Schichan
2013-05-21ASoC: davinci: fix sample rotationDaniel Mack
McASP serial audio engine needs different rotation values on TX and RX channels. Commit dde109fb462 ("ASoC: McASP: Fix data rotation for playback. Enables 24bit audio playback") changed the calculation to fix the playback format, but broke the capture stream by doing it for both TXFMT and RXFMT. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org [3.9 only]
2013-05-20ASoC: wm5110: Add missing speaker initialisationMark Brown
Add callback to initialise the speaker in the core following the recent changes to handling of integration with the thermal interrupts. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-20ASoC: soc-compress: Send correct stream event for capture startCharles Keepax
