commit e2656412f2a7343ecfd13eb74bac0a6e6e9c5aad upstream.
Broxton and Skylake have the same behavior on display audio. So this patch
applys Skylake fix-ups to Broxton.
Signed-off-by: Lu, Han <han.lu@intel.com>
commit a91e627e3f0ed820b11d86cdc04df38f65f33a70 upstream.
One of the many faults of the QinHeng CH345 USB MIDI interface chip is
that it does not handle received SysEx messages correctly -- every second
event packet has a wrong code index number, which is the one from the last
seen message, instead of 4. For example, the two messages "FE F0 01 02 03
04 05 06 07 08 09 0A 0B 0C 0D 0E F7" result in the following event
packets:
correct: CH345:
0F FE 00 00 0F FE 00 00
04 F0 01 02 04 F0 01 02
04 03 04 05 0F 03 04 05
04 06 07 08 04 06 07 08
04 09 0A 0B 0F 09 0A 0B
04 0C 0D 0E 04 0C 0D 0E
05 F7 00 00 05 F7 00 00
A class-compliant driver must interpret an event packet with CIN 15 as
having a single data byte, so the other two bytes would be ignored. The
message received by the host would then be missing two bytes out of six;
in this example, "F0 01 02 03 06 07 08 09 0C 0D 0E F7".
These corrupted SysEx event packages contain only data bytes, while the
CH345 uses event packets with a correct CIN value only for messages with
a status byte, so it is possible to distinguish between these two cases by
checking for the presence of this status byte.
(Other bugs in the CH345's input handling, such as the corruption resulting
from running status, cannot be worked around.)
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 1ca8b201309d842642f221db7f02f71c0af5be2d upstream.
The CH345 USB MIDI chip has two output ports. However, they are
multiplexed through one pin, and the number of ports cannot be reduced
even for hardware that implements only one connector, so for those
devices, data sent to either port ends up on the same hardware output.
This becomes a problem when both ports are used at the same time, as
longer MIDI commands (such as SysEx messages) are likely to be
interrupted by messages from the other port, and thus to get lost.
It would not be possible for the driver to detect how many ports the
device actually has, except that in practice, _all_ devices built with
the CH345 have only one port. So we can just ignore the device's
descriptors, and hardcode one output port.
commit 98d362becb6621bebdda7ed0eac7ad7ec6c37898 upstream.
commit 16771c7c704769c5f3d70c024630b6e5b3eafa67 upstream.
This patch adds native DSD support for the Aune X1S 32BIT/384 DSD DAC
Signed-off-by: Jurgen Kramer <gtmkramer@xs4all.nl>
commit 34198710f55b5f359f43e67d9a08fe5aadfbca1b upstream.
SX_TLV controls are intended for situations where the register behind
the control has some non-zero value indicating the minimum gain
and then gains increasing from there and eventually overflowing through
zero.
Currently every CODEC implementing these controls specifies the minimum
as the non-zero value for the minimum and the maximum as the number of
gain settings available.
This means when the info callback subtracts the minimum value from the
maximum value to calculate the number of gain levels available it is
actually under reporting the available levels. This patch fixes this
issue by adding a new snd_soc_info_volsw_sx callback that does not
subtract the minimum value.
Fixes: 1d99f2436d0d ("ASoC: core: Rework SOC_DOUBLE_R_SX_TLV add SOC_SINGLE_SX_TLV")
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Acked-by: Brian Austin <brian.austin@cirrus.com>
Tested-by: Brian Austin <brian.austin@cirrus.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit d289619a219dd01e255d7b5e30f9171b25efea48 upstream.
The HDA codec driver issues snd_hda_codec_reset() at the error path of
PCM build. This was needed in the earlier code base, but the recent
rewrite to use the standard bus binding made this a deadlock:
modprobe D 0000000000000005 0 720 716 0x00000080
Call Trace:
[<ffffffff816a5dbe>] schedule+0x3e/0x90
[<ffffffff816a61a5>] schedule_preempt_disabled+0x15/0x20
[<ffffffff816a7ae5>] __mutex_lock_slowpath+0xb5/0x120
[<ffffffff816a7b6b>] mutex_lock+0x1b/0x30
[<ffffffff8148656b>] device_release_driver+0x1b/0x30
[<ffffffff81485c15>] bus_remove_device+0x105/0x180
[<ffffffff814822b9>] device_del+0x139/0x260
[<ffffffffa05e0ec5>] snd_hdac_device_unregister+0x25/0x30 [snd_hda_core]
[<ffffffffa074fa6a>] snd_hda_codec_reset+0x2a/0x70 [snd_hda_codec]
[<ffffffffa075007b>] snd_hda_codec_build_pcms+0x18b/0x1b0 [snd_hda_codec]
[<ffffffffa074a44e>] hda_codec_driver_probe+0xbe/0x140 [snd_hda_codec]
[<ffffffff81486ac4>] driver_probe_device+0x1f4/0x460
[<ffffffff81486dc0>] __driver_attach+0x90/0xa0
[<ffffffff81484844>] bus_for_each_dev+0x64/0xa0
[<ffffffff814862de>] driver_attach+0x1e/0x20
[<ffffffff81485e7b>] bus_add_driver+0x1eb/0x280
[<ffffffff81487680>] driver_register+0x60/0xe0
[<ffffffffa074a0da>] __hda_codec_driver_register+0x5a/0x60 [snd_hda_codec]
[<ffffffffa070a01e>] realtek_driver_init+0x1e/0x1000 [snd_hda_codec_realtek]
[<ffffffff810002f3>] do_one_initcall+0xb3/0x200
[<ffffffff816a1fc5>] do_init_module+0x60/0x1f8
[<ffffffff810ee5c3>] load_module+0x1653/0x1bd0
[<ffffffff810eed48>] SYSC_finit_module+0x98/0xc0
[<ffffffff810eed8e>] SyS_finit_module+0xe/0x10
[<ffffffff816aa032>] entry_SYSCALL_64_fastpath+0x16/0x75
The simple fix is just to remove this call, since we don't need to
think about unbinding at there any longer.
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=948758
commit e8d65a8d985271a102f07c7456da5b86c19ffe16 upstream.
Add the appropriate quirk to indicate the Lenovo G50-80 has a stereo
mic input where one channel has reverse polarity.
Alsa-info available at:
https://launchpadlibrarian.net/220846272/AlsaInfo.txt
BugLink: https://bugs.launchpad.net/bugs/1504778
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit e256da84a04ea31c3c215997c847609af224e8f4 upstream.
Signed-off-by: Gianluca Renzi <gianlucarenzi@eurekelettronica.it>
commit e74679b38c9417c1c524081121cdcdb36f82264d upstream.
Commit b4508d0f95fa ("ASoC: db1200: Use static DAI format setup") switched
the db1200 driver over to using static DAI format setup instead of a
callback function. But the commit only added the dai_fmt field to one of
the three DAI links in the driver. This breaks audio on db1300 and db1550.
Add the two missing dai_fmt settings to fix the issue.
Fixes: b4508d0f95fa ("ASoC: db1200: Use static DAI format setup")
Reported-by: Manuel Lauss <manuel.lauss@gmail.com>
Tested-by: Manuel Lauss <manuel.lauss@gmail.com>
commit 4873867e5f2bd90faad861dd94865099fc3140f3 upstream.
from Designware I2S datasheet, tx/rx XRUN irq is cleared by
reading register TOR/ROR, rather than by writing into them.
Signed-off-by: Yitian Bu <yitian.bu@tangramtek.com>
commit 3c8f7710c1c44fb650bc29b6ef78ed8b60cfaa28 upstream.
The previous fix of pxa library support, which was introduced to fix the
library dependency, broke the previous SoC behavior, where a machine
code binding pxa2xx-ac97 with a coded relied on :
- sound/soc/pxa/pxa2xx-ac97.c
- sound/soc/codecs/XXX.c
For example, the mioa701_wm9713.c machine code is currently broken. The
"select ARM" statement wrongly selects the soc/arm/pxa2xx-ac97 for
compilation, as per an unfortunate fate SND_PXA2XX_AC97 is both declared
in sound/arm/Kconfig and sound/soc/pxa/Kconfig.
Fix this by ensuring that SND_PXA2XX_SOC correctly triggers the correct
pxa2xx-ac97 compilation.
Fixes: 846172dfe33c ("ASoC: fix SND_PXA2XX_LIB Kconfig warning")
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit 8811191fdf7ed02ee07cb8469428158572d355a2 upstream.
PCM receive and transmit DMA requestor lines were reverted, breaking the
PCM playback interface for PXA platforms using the sound/soc/ variant
instead of the sound/arm variant.
The commit below shows the inversion in the requestor lines.
Fixes: d65a14587a9b ("ASoC: pxa: use snd_dmaengine_dai_dma_data")
commit c7e1008048a97148d3aecae742f66fb2f944644c upstream.
The recent widget power saving introduced some unavoidable click
noises on old IDT 92HD73xx chips while it still seems working on the
compatible new chips. In the bugzilla, we tried lots of tests and
workarounds, but they didn't help much. So, let's disable the feature
for these specific chips as the least (but safest) fix.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=104981
commit e8ff581f7ac2bc3b8886094b7ca635dcc4d1b0e9 upstream.
The MacBookPro 12,1 has the same setup as the 11 for controlling the
status of the optical audio light. Simply apply the existing workaround
to the subsystem ID for the 12,1.
[sorted the fixup entry by tiwai]
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=105401
Signed-off-by: John Flatness <john@zerocrates.org>
commit d05ea7da0e8f6df3c62cfee75538f347cb3d89ef upstream.
Much like all the other Lenovo laptops, add a quirk to make
sound work with docking.
Reported-and-tested-by: lacknerflo@gmail.com
Signed-off-by: Laura Abbott <labbott@fedoraproject.org>
commit 225db5762dc1a35b26850477ffa06e5cd0097243 upstream.
When OSS emulation is loaded on ISA SB AWE32 chip, we get now kernel
warnings like:
WARNING: CPU: 0 PID: 2791 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x51/0x80()
sysfs: cannot create duplicate filename '/devices/isa/sbawe.0/sound/card0/seq-oss-0-0'
It's because both emux synth and opl3 drivers try to register their
OSS device object with the same static index number 0. This hasn't
been a big problem until the recent rewrite of device management code
(that exposes sysfs at the same time), but it's been an obvious bug.
This patch works around it just by using a different index number of
emux synth object. There can be a more elegant way to fix, but it's
enough for now, as this code won't be touched so often, in anyway.
Reported-and-tested-by: Michael Shell <list1@michaelshell.org>
commit 7f57d803ee03730d570dc59a9e3e4842b58dd5cc upstream.
Lenovo Thinkpads with recent Realtek codecs seem suffering from click
noises at power transition since the introduction of widget power
saving in 4.1 kernel. Although this might be solved by some delays in
appropriate points, as a quick workaround, just disable the
power_save_node feature for now. The gain it gives is relatively
small, and this makes the situation back to pre 4.1 time.
This patch ended up with a bit more code changes than usual because
the existing fixup for Thinkpads is highly chained. Instead of adding
yet another chain, combine a few of them into a single fixup entry, as
a gratis cleanup.
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=943982
commit 467e1436ba85f78b8c4610c4549eb255a8211c42 upstream.
The M3800 is very minor workstation variant of the XPS 15 which has
already been patched for this issue. I figured it's probably more
important for this version of the laptop to be patched than the
regular XPS as Dell sells is pre-configured with Ubuntu to be used as
a Linux workstation. I have tested the patch on my the hardware on
Linux 4.2.0.
Signed-off-by: Niranjan Sivakumar <ns253@cornell.edu>
commit 1adecc6755e1e4193b5618ddb2e107f6d6e88f4b upstream.
Dell laptop has a series model to use the same codec but different subsystem ID.
At the same time they happens the white noise by login screen and headphone;
for fixing them together, I only can add these IDs to FIXUP function ALC292_FIXUP_DISABLE_AAMIX,
then try to solve such the similar issues.
Codec: Realtek ALC3235
Vendor Id: 0x10ec0293
Subsystem Id: 0x102806dd
Subsystem Id: 0x102806df
Subsystem Id: 0x102806e0
BugLink: https://bugs.launchpad.net/bugs/1492132
Signed-off-by: Woodrow Shen <woodrow.shen@canonical.com>
commit a161574e200ae63a5042120e0d8c36830e81bde3 upstream.
It turned out that the machine has a bass speaker, so take a correct
fixup entry.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102501
commit bb148bdeb0ab16fc0ae8009799471e4d7180073b upstream.
According to the bug report, FSC Amilo laptops with ALC880 can detect
the headphone jack but currently the driver disables it. It's partly
intentionally, as non-working jack detect was reported in the past.
Let's enable now.
commit 6aa6925cad06159dc6e25857991bbc4960821242 upstream.
The check of cval->cached should be zero-based (including master channel).
Signed-off-by: Yao-Wen Mao <yaowen@google.com>
commit 0e7659712836ca59b4735bc5cc94de38698a5e01 upstream.
The extcon driver takes the DAPM mutex from within the interrupt thread
in several places, which makes it possible to get into a situation where
the interrupt thread is blocked waiting on the DAPM mutex whilst a DAPM
sequence is running which is attempting to configure the FLL. In this
case the FLL completion can't be completed as as the IRQ handler is
ONE_SHOT, which cause the FLL lock to use the full time out (250mS) and
report that the process timed out.
It is not really practical to make the extcon driver not take the DAPM
mutex from within the interrupt thread, at least not without extensive
modification. So this patch fixes the issue by switching the wait for
the FLL lock to polling. A few fast polls are done first as the FLL
should lock quickly for a good quality reference clock, (indeed it hits
on the first poll on my system) and it will poll every 20mS after that
until it times out.
commit 1cf5a330c05ae37a0a98ac7c9800a6f50d5579ec upstream.
The wrong register was used to set the gain of ref loop, when changing
the FLL output on an active FLL. This patch corrects the offset of the
gain register.
Signed-off-by: Nikesh Oswal <Nikesh.Oswal@wolfsonmicro.com>
commit 9d8352864907f0ad76124c5b28f65b5a382d7d7c upstream.
Don't set .read_flag_mask for adav803, it's for adav801 only.
Fixes: 0c2d69645628 ("ASoC: adav80x: Split SPI and I2C code into different modules")
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
commit 14a500fe1396934c6b3ed8f009459a4723da7862 upstream.
There is no use of snd_soc_unregister_card in remove function
as devm_snd_soc_register_card in probe function automatically
handles it. So, remove use of snd_soc_unregister_card and with
this change remove arndale_audio_remove as it is now redundant.
Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com>
commit 9b850ca4f1c5acd7fcbbd4b38a2d27132801a8d5 upstream.
The power for line out was not turned on when line out is enabled.
So we add "LOUT amp" widget to turn on the power for line out.
Signed-off-by: John Lin <john.lin@realtek.com>
commit c7e69ae6b4ff49edf50180c0a32f3dd9d7967e31 upstream.
After a for-loop was replaced by list_for_each_entry, see
Commit bbbc7e8502c9 ("ALSA: hda - Allocate hda_pcm objects dynamically"),
Commit 751e2216899c ("ALSA: hda: fix possible null dereference"),
a possible NULL pointer dereference has been introduced; this patch adds
the NULL check on pcm->pcm, while leaving a potentially superfluous
check on pcm itself untouched.
Signed-off-by: Markus Osterhoff <linux-kernel@k-raum.org>
commit c7cd0ef66aade29e37ee08821a0e195ee776c6e6 upstream.
The widget power-saving code tries to turn up/down the power of each
widget in the I/O paths that are modified at each jack plug/unplug.
The recent report revealed that the power activation leaves some
widgets unpowered after plugging. This is because
snd_hda_activate_path() turns on path->active flag at the end of the
function while the path power management is done before that. Then
it's regarded as if nothing is active, and the driver turns off the
power.
The fix is simply to set the flag at the beginning of the function,
before trying to power up.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102521
commit 9d2b48f7304aafaefbf0794a556ab4e307929d24 upstream.
The is_active_nid_for_any() function in the generic parser is supposed
to check all connections from/to the given widget, but the current
code checks only the first input connection (index = 0).
This patch corrects the code to check all inputs by passing -1 to
index argument.
commit f6b28e4ded45bb91bc4cd115d55e35badedfce5f upstream.
On shutdown/reboot of CX20722, first shut down all EAPDs, then
shut down the afg node to D3.
Failure to do so can lead to spurious noises from the internal speaker
directly after reboot (and before the codec is reinitialized again, i e
in BIOS setup or GRUB menus).
BugLink: https://bugs.launchpad.net/bugs/1487345
commit 9544f8b6e2ee9ed02d2322ff018837b185f51d45 upstream.
This patch adds native DSD support for the Gustard DAC-X20U.
commit 7ccb0a9917a511de1d5f92980f26885484d9a914 upstream.
Dell laptop causes the white noise by login screen and headphone,
and the fixup function ALC292_FIXUP_DISABLE_AAMIX can eliminate this
noise.
Subsystem Id: 0x102806db
BugLink: https://bugs.launchpad.net/bugs/1484334
commit 9003ebb13f61e8c78a641e0dda7775183ada0625 upstream.
The fix for deadlock in PM in commit [1ee23fe07ee8: ALSA: usb-audio:
Fix deadlocks at resuming] introduced a new check of in_pm flag.
However, the brainless patch author evaluated it in a wrong way
(logical AND instead of logical OR), thus usb_autopm_get_interface()
is wrongly called at probing, leading to unbalance of runtime PM
refcount.
This patch fixes it by correcting the logic.
Reported-by: Hans Yang <hansy@nvidia.com>
Fixes: 1ee23fe07ee8 ('ALSA: usb-audio: Fix deadlocks at resuming')
commit 18f5ed365d3f188a91149d528c853000330a4a58 upstream.
Fireworks uses TSB43CB43(IceLynx-Micro) as its IEC 61883-1/6 interface.
This chip includes ARM7 core, and loads and runs program. The firmware
is stored in on-board memory and loaded every powering-on from it.
Echo Audio ships several versions of firmwares for each model. These
firmwares have each quirk and the quirk changes a sequence of packets.
As long as I investigated, AudioFire2/AudioFire4/AudioFirePre8 have a
quirk to transfer a first packet with 0x02 in its dbc field. This causes
ALSA Fireworks driver to detect discontinuity. In this case, firmware
version 5.7.0, 5.7.3 and 5.8.0 are used.
Payload CIP CIP
quadlets header1 header2
02 00050002 90ffffff <-
42 0005000a 90013000
42 00050012 90014400
42 0005001a 90015800
02 0005001a 90ffffff
42 00050022 90019000
42 0005002a 9001a400
42 00050032 9001b800
02 00050032 90ffffff
42 0005003a 9001d000
42 00050042 9001e400
42 0005004a 9001f800
02 0005004a 90ffffff
(AudioFire2 with firmware version 5.7.)
$ dmesg
snd-fireworks fw1.0: Detect discontinuity of CIP: 00 02
These models, AudioFire8 (since Jul 2009 ) and Gibson Robot Interface
Pack series uses the same ARM binary as their firmware. Thus, this
quirk may be observed among them.
This commit adds a new member for AMDTP structure. This member represents
the value of dbc field in a first AMDTP packet. Drivers can set it with
a preferred value according to model's quirk.
Tested-by: Johannes Oertei <johannes.oertel@uni-due.de>
Signed-off-by: Takashi Sakamoto <o-takashi@sakamocchi.jp>
commit 73851b36fe73819f8c201971e913324d4846a7ea upstream.
The fixup ALC292_FIXUP_DISABLE_AAMIX can fix the white noise of
the headphone on this Dell machine.
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit 44008f0896ae205b02b0882dbf807f0de149efc4 upstream.
Smatch complains that we have nested checks for "spdif_present". It
turns out the current behavior isn't correct, we should remove the first
check and keep the second.
Fixes: 1077a024812d ('ALSA: hda - Use generic parser for Cirrus codec driver')
commit a798c24a69b64f09e2d323ac8155a36373e5d5fd upstream.
Commit fdb6eb0a1287 ("ASoC: dapm: Modify widget stream name according to
prefix") fixed the case where a DAPM route between a DAI widget and a
DAC/ADC/AIF widget with a matching stream name was not created when the
DAPM context was using a prefix.
Unfortunately the patch introduced a few issues on its own like leaking the
dynamically allocated stream name memory and also not checking whether the
allocation succeeded in the first place.
It is also incomplete in that it still does not handle the case where
stream name of the widget is a substring of the stream name of the DAI,
which is explicitly allowed and works fine if no DAPM prefix is used.
Revert the commit and take a slightly different approach to solving the
issue. Instead of comparing the widget's stream name to the name of the DAI
widget compare it to the stream name of the DAI widget. The stream name of
the DAI widget is identical to the name of the DAI widget except that it
wont have the DAPM prefix added. So this approach behaves identical
regardless to whether the DAPM context uses a prefix or not.
We don't have to worry about potentially matching with a widget with the
same stream name, but from a different DAPM context with a different
prefix, since the code already makes sure that both the DAI widget and the
matched widget are from the same DAPM context.
Fixes: fdb6eb0a1287 ("ASoC: dapm: Modify widget stream name according to prefix")
commit e50b1e06b79e9d51efbff9627b4dd407184ef43f upstream.
The DAPM lock must be held when accessing the DAPM graph status through
sysfs or debugfs, otherwise concurrent changes to the graph can result in
undefined behaviour.
commit fa8173a3ef0570affde7da352de202190b3786c2 upstream.
The de-emphasis sampling rate selection is controlled by BIT[3:4] of
PCM1681_DEEMPH_CONTROL register. Do proper left shift to set it.
Acked-by: Marek Belisko <marek.belisko@streamunlimited.com>
commit a6c2a32ac83567f15e9af3dcbc73148ce68b2ced upstream.
The regmap_write in ssm4567_set_dai_fmt accidentally clears the
TDM_BCLKS field which was set earlier by ssm4567_set_tdm_slot.
This patch fixes it by using regmap_update_bits with proper mask.
Signed-off-by: Ben Zhang <benzh@chromium.org>
Acked-by: Anatol Pomozov <anatol.pomozov@gmail.com>
commit 412efa73dcd3bd03c1838c91e094533a95529039 upstream.
The usage_count variable was read before it was set to the correct
value, due to which the firmware load was failing. Because of this
IPC messages sent to the firmware were timing out causing a delay
of about 1 second while playing audio from the internal speakers.
With this patch the usage_count is read after the function call
pm_runtime_get_sync which will increment the usage_count variable
and the firmware load is successful and all the IPC messages are
processed correctly.
Signed-off-by: Shilpa Sreeramalu <shilpa.sreeramalu@intel.com>
Signed-off-by: Fang, Yang A <yang.a.fang@intel.com>
commit 649ccd08534ee26deb2e5b08509800d0e95167f5 upstream.
MacBook Pro 5,2 with ALC889 codec had already a fixup entry, but this
seems not working correctly, a fix for pin NID 0x15 is needed in
addition. It's equivalent with the fixup for MacBook Air 1,1, so use
this instead.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=102131
Reported-and-tested-by: Jeffery Miller <jefferym@gmail.com>
commit 2d1cb7f658fb9c3ba8f9dab8aca297d4dfdec835 upstream.
Add the correct dB ranges of Bose Companion 5 and Drangonfly DAC 1.2.
commit 3a05d12f46cb95a6a685114819363a56e6170996 upstream.
Dell Vostro 5480 (1028:069a) needs the very same quirk used for Vostro
5470 model to make bass speakers properly working.
Reported-and-tested-by: Paulo Roberto de Oliveira Castro <p.oliveira.castro@gmail.com>
commit b9d9c9efc292dd0ffe172780f915ed74eba3556c upstream.
Toshiba Satellite S50D has another model with a different PCI SSID
(1179:fa93) while the previous fixup was for 1179:fa91. Adjust the
fixup entry with SND_PCI_QUIRK_MASK() to match with both devices.
Reported-by: Tim Sample <timsample@gmail.com>
commit cba59972a1191a0c1647a52fe745eed7a4b34b38 upstream.
Without this patch, the headset mic will not work on this machine.
BugLink: https://bugs.launchpad.net/bugs/1476987
commit 6c3d91193d829bf58a35a10650415b05a736ca6c upstream.
Vendor ID 0x10de007d is used by a yet-to-be-named GPU chip.
This chip also has the 2-ch audio swapping bug, so patch_nvhdmi is
appropriate here.
Signed-off-by: Aaron Plattner <aplattner@nvidia.com>
commit 5022813ddb28b7679e8285812d52aaeb7e1e7657 upstream.
Fixes audio problems on newer asics
Signed-off-by: Maruthi Bayyavarapu <maruthi.bayyavarapu@amd.com>
