commit d8009882e9f5e1a76986c741f071edd2ad760c97 upstream
The lock used in snd_ctl_dev_disconnect() should be card->ctl_files_rwlock
for protection of card->ctl_files entries, instead of card->controls_rwsem.
Reported-by: Vegard Nossum <vegard.nossum@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Cc: Chris Wedgwood <cw@f00f.org>
commit 0cbf00980f0fc4cc064a15ab3dfce19b5fae9130 upstream
The current snd-hda-intel driver seems blocking the power-off on some
devices like eeepc. Although this is likely a BIOS problem, we can add
a workaround by disabling IRQ lines before power-off operation.
This patch adds the reboot notifier to achieve it.
The detailed problem description is found in bug#11889:
http://bugme.linux-foundation.org/show_bug.cgi?id=11889
Tested-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
Correct headphone detection for 1st generation iMac G3 Slot-loading (Screamer).
This patch fixes the regression in the recent snd-powermac which
doesn't support some G3/G4 PowerMacs:
http://lkml.org/lkml/2008/10/1/220
Signed-off-by: Risto Suominen <Risto.Suominen@gmail.com>
Tested-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Cc: stable@kernel.org
Add mixer controls for PowerMac G4 AGP (Screamer).
Rob Sims wrote:
"I can't seem to turn on register 0x17, bit 3 in the sound chip, except
by codec_reg_write; the mixer lacks direct or indirect control. It
seems there are two names for the output of the rec mixer:
Capture ST Mixer
Playback Mixer
Would the following do the trick?"
I confirm that this solves the audio problems I was having.
Signed-off-by: Jonas Bonn <jonas.bonn@gmail.com>
Dell Inspiron 1525 seems to have a buggy BIOS setup and screws up
the recent codec parser, as reported by Oleksandr Natalenko:
http://lkml.org/lkml/2008/9/12/203
This patch adds the working model, dell-3stack, statically.
Cc: <stable@kernel.org>
The error path in cs4270_probe/cs4270_remove is pretty broken:
* If cs4270_probe fails, codec is leaked.
* If snd_soc_register_card fails, cs4270_i2c_driver stays registered.
* If I2C support is enabled but no I2C device is found, i2c_del_driver
is never called (neither in cs4270_probe nor in cs4270_remove.
Fix all 3 problems by implementing a clean error path in cs4270_probe
and jumping to its labels as needed.
Acked-by: Timur Tabi <timur@freescale.com>
Conversion to new-style i2c driver missed the error path of the
probe function. Fix it.
Cc: Timur Tabi <timur@freescale.com>
Update the CS4270 ALSA device driver to use the new-style I2C interface.
Starting with the 2.6.27 PowerPC kernel, I2C devices that have entries in the
device trees can no longer be probed by old-style I2C drivers. The device
tree for Freescale MPC8610 HPCD has included an entry for the CS4270 since
2.6.25, but that entry was previously ignored by the PowerPC I2C subsystem.
Since that's no longer the case, the best solution is to update the CS4270
driver to a new-style interface, rather than try to revert the behavior of
new PowerPC I2C subsystem.
The power_mutex lock in snd_pcm_drop may cause a possible deadlock
chain, and above all, it's unneeded. Let's get rid of it.
The PCM and rawmidi open callbacks have a lock against card->controls_list
but it takes a wrong one, card->controls_rwsem, instead of a right one
card->ctl_files_rwlock. This patch fixes them.
This change also fixes automatically the potential deadlocks due to
mm->mmap_sem in munmap and copy_from/to_user, reported by Sitsofe
Wheeler:
A: snd_ctl_elem_user_tlv(): card->controls_rwsem => mm->mmap_sem
B: snd_pcm_open(): card->open_mutex => card->controls_rwsem
C: munmap: mm->mmap_sem => snd_pcm_release(): card->open_mutex
The patch breaks the chain.
s/PDC_PTCR/ATMEL_PDC_PTCR/
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_AC97_BUS is used from both sound and ucb1400 drivers.
The recent change in Kconfig introduced the exclusive dependency on
CONFIG_SOUND, and disabled the ucb1400 build without sound.
This patch makes CONFIG_AC97_BUS independent.
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Fix the wrong DAC assignment for NID 0x17 mono-pin on ALC663.
pxa2xx-i2s: probe actual device and use it for clk_get call
thus fixing error during startup hook
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Added the EQ distortion fix to the dell_m6_core_init.
Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com>
When changing the sample rate, the CMI8788's master clock output becomes
unstable for a short time. The AK4396 needs the master clock to do SPI
writes, so writing to an AK4396 control register directly after a sample
rate change will garble the value. In our case, this leads to the DACs
being misconfigured to I2S sample format, which results in a wrong
output level and horrible distortions on samples louder than -6 dB.
To fix this, we need to wait until the new master clock signal has
become stable before doing SPI writes.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
This reverts commit 3e0e469fa216ec70c93b1593821b759d19ee2e6b.
The patch introduced a wrong detection of other intel Macs with
ALC88* codec because they share the same PCI SSID (but have different
codec subsystem-IDs). See http://lkml.org/lkml/2008/8/24/143
Reported-and-tested-by: Guillaume Chazarain <guichaz@gmail.com>
at exit
Thanks to Felipe Balbi <felipe.balbi@nokia.com> by noticing that if clk_get
to sys_clkout2_src fails, then n810_snd_device is never released.
Add also sys_clkout2_src release into error path, error code return and
release the clocks at exit.
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com>
The Xonar DX does not have CD Capture controls, so we have to check that
a control actually exists before muting it.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: ASoC: Fix double free and memory leak in many codec drivers
ALSA: CA0106 on MSI K8N Diamond PLUS Motherboard
Many SoC audio codec drivers have improper freeing of memory in error
paths.
* codec is allocated in the platform device probe function, but is not
freed there in case of error. Instead it is freed in the i2c device
probe function's error path. However the success or failure of both
functions is not linked, so this could result in a double free (if
the platform device is successfully probed, the i2c device probing
fails and then the platform driver is unregistered.)
* codec->private_data is allocated in many platform device probe
functions but not freed in their error paths.
This patch hopefully solves all these problems.
Correct a previous patch for the ca0106 onboard the MSI K8N Diamond PLUS
motherboard. Confirmed to have Line/Mic/Aux working for input, and sound
output working as expected.
Signed-off-by: Travis Place <wishie@wishie.net>
This patch lets the files using linux/version.h match the files that
#include it.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Using init_hook to call alc888_coef_init() is problematic for configurations
that already set another init_hook. Better to put it in alc_init() as is
(although it looks a bit hackish).
Enable the snoop for nvidia hda controller to avoid data coherence issue.
Signed-off-by: Peer Chen <peerchen@gmail.com>
On some Realtek codecs like ALC882 or ALC883, the capture source is
no mux but sum widget. We have to initialize all channels properly
for this type, otherwise noises may come in from the unused route.
The patch assures to mute unused routes, and unmute the currently
selected route.
Tested-by: Daniel J Blueman <daniel.blueman@gmail.com>
The latest revisions of the WM8990 provide a programmable gain amplifier
for the speaker - configure the register cache and implement controls
for this. Older revisions of the device ignore writes to these controls.
Add support for the Asus Xonar D1. It is the same as the DX, but
without the external power detection.
Signed-off-by: Libin Yang <libin.yang@amd.com>
This patch adds the Intel Ibex Peak (PCH) HD Audio Controller DeviceIDs.
Signed-off by: Seth Heasley <seth.heasley@intel.com>
Add missing output VREF. After a65f0568f6cc8433877fb71dd7d36b551854b0bc
it's critical, since it makes chip routing initialisation to fail.
Correct route name to be MONO1 instead of MONO to follow
recent fix in wm8750.
Since first commit wm8750 contained output named MONO, but
all routes mentioned MONO1. Correct MONO to be MONO1.
drivers/watchdog/at91rm9200_wdt.c
drivers/watchdog/davinci_wdt.c
drivers/watchdog/ep93xx_wdt.c
drivers/watchdog/ixp2000_wdt.c
drivers/watchdog/ixp4xx_wdt.c
drivers/watchdog/ks8695_wdt.c
drivers/watchdog/omap_wdt.c
drivers/watchdog/pnx4008_wdt.c
drivers/watchdog/sa1100_wdt.c
drivers/watchdog/wdt285.c
ALSA: ASoC: fix SNDCTL_DSP_SYNC support in Freescale 8610 sound drivers
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
There are 43 includes of asm/mach-types.h by files that don't
reference anything from that file. Remove these unnecessary
includes.
This reverts commit 680db0136e0778a0d7e025af7572c6a8d82279e2. The label
is actually used, but hidden behind CONFIG_SND_DEBUG and the horrible
snd_assert() macro.
That macro could probably be improved to be along the lines of
#define snd_assert(expr, args...) do { if ((void)(expr),0) { args; } } while (0)
or similar to make sure that we always both evaluate 'expr' and parse
'args', but while gcc should optimize it all away, I'm too lazy to
really verify that. So I'll just admit defeat and will continue to live
with the annoying warning.
Noted-by: Robert P. J. Day <rpjday@crashcourse.ca>
Signed-off-by: Linus "Grr.." Torvalds
This fixes the warning
sound/core/pcm_native.c: In function 'snd_pcm_fasync':
sound/core/pcm_native.c:3262: warning: label 'out' defined but not used
snd_seq_oss_synth_make_info() incorrectly reports information
to userspace without first checking for the validity of the
device number, leading to possible information leak (CVE-2008-3272).
Reported-By: Tobias Klein <tk@trapkit.de>
Acked-and-tested-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Willy Tarreau <w@1wt.eu>
If an OSS application calls SNDCTL_DSP_SYNC, then ALSA will call the driver's
_hw_params and _prepare functions again. On the Freescale MPC8610 DMA ASoC
driver, this caused the DMA controller to be unneccessarily re-programmed, and
apparently it doesn't like that. The DMA will then not operate when
instructed. This patch relocates much of the DMA programming to
fsl_dma_open(), which is called only once.
ALSA: ASoC: Export dapm_reg_event() fully
ALSA: ASoC: Update Poodle to current ASoC API
ALSA: asoc: restrict sample rate and size in Freescale MPC8610 sound drivers
ALSA: sound/soc/pxa/tosa.c: removed duplicated include
dapm_reg_event() is used by devices using SND_SOC_DAPM_REG() so needs to
be exported to support building them as modules and prototyped to avoid
sparse warnings and potential build issues.
