[NOTE: the regression below is found only in 3.2-3.4 stable trees, so
there is no upstream commit corresponding to this patch]
The recent fix for the race at disconnection of usb-audio devices
(upstream commit 978520b7) triggers Oops when a device is unplugged
while playing on 3.2 and 3.4 kernels. The culprit is that the
shutdown flag check was wrongly added around the urb deactivation code
snippet. The urb deactivation code has to be performed even after the
device disconnected. Otherwise it remains undead and pokes the wild
access in the end.
The regression fix is simply reverting the shutdown flag check in that
code.
Reported-and-tested-by: Chris J Arges <christopherarges@gmail.com>
commit b98ae2729dea161edc96c9d177459b6c28bcbba5 upstream.
A patch in the 3.2 kernel caused regression with hotplugging the
M-Audio Fast track pro, or sound after suspend. I don't have the
device so I haven't done a full analysis, but it seems userspace
(both udev and pulseaudio) got confused when a card was created,
immediately destroyed, and then created again.
However, at least one person in the bug report (martin djfun)
reports that this patch resolves the issue for him. It also leaves
a message in the log:
"snd-usb-audio: probe of 1-1.1:1.1 failed with error -5" which is
a bit misleading. It is better than non-working audio, but maybe
there's a more elegant solution?
BugLink: https://bugs.launchpad.net/bugs/1095315
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 9ddf1aeb2134e72275c97a2c6ff2e3eb04f2f27a upstream.
For non-snoop mode, we fiddle with the page attributes of CORB/RIRB
and the position buffer, but also the ring buffers. The problem is
that the current code blindly assumes that the buffer is contiguous.
However, the ring buffers may be SG-buffers, thus a wrong vmapped
address is passed there, leading to Oops.
This patch fixes the handling for SG-buffers.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=800701
[bwh: Backported to 3.2: open-code snd_pcm_get_dma_buf()]
commit d56268fb108c7c21e19933588ca4d94652585183 upstream.
Commit 23caaf19b11e (ALSA: usb-mixer: Add support for Audio Class v2.0)
forgot to adjust the length check for UAC 2.0 feature unit descriptors.
This would make the code abort on encountering a feature unit without
per-channel controls, and thus prevented the driver to work with any
device having such a unit, such as the RME Babyface or Fireface UCX.
Reported-by: Florian Hanisch <fhanisch@uni-potsdam.de>
Tested-by: Matthew Robbetts <wingfeathera@gmail.com>
Tested-by: Michael Beer <beerml@sigma6audio.de>
Cc: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 42c364ace52ae6b4699105b39f2559c256b6cd4c upstream.
These are just compatible with other CX2075x codecs.
commit 2d825fd82eb765412a558a56e193b77117d56699 upstream.
Never trust datasheet...
commit 61d648fb4726f8a89c07cd1904f9c2e11bf26df5 upstream.
These are almost compatible with the older Conexant codecs.
commit 7ed4165e2d01bdbbb4c1086eb73eadf0f64cbbf0 upstream.
This reverts commit 697c373e34613609cb5450f98b91fefb6e910588.
The original patch was meant to remove clicking, but in fact caused even
more clicking instead.
Thanks to c4pp4 for doing most of the work with this bug.
BugLink: https://bugs.launchpad.net/bugs/886975
[bwh: Backported to 3.2: adjust context]
commit 3b4bc7bccc7857274705b05cf81a0c72cfd0b0dd upstream.
This patch fixes some code that implements a work-around to a hardware bug in
the ac97 controller on the pxa27x. A bug in the controller's warm reset
functionality requires that the mfp used by the controller as the AC97_nRESET
line be temporarily reconfigured as a generic output gpio (AF0) and manually
held high for the duration of the warm reset cycle. This is what was done in
the original code, but it was broken long ago by commit fb1bf8cd
([ARM] pxa: introduce processor specific pxa27x_assert_ac97reset())
which changed the mfp to a GPIO input instead of a high output.
The fix requires the ac97 controller to obtain the gpio via gpio_request_one(),
with arguments that configure the gpio as an output initially driven high.
Tested on a palm treo 680 machine. Reportedly, this broken code only prevents a
warm reset on hardware that lacks a pull-up on the line, which appears to be the
case for me.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
commit 41b645c8624df6ace020a8863ad1449d69140f7d upstream.
Cold reset on the pxa27x currently fails and
pxa2xx_ac97_try_cold_reset: cold reset timeout (GSR=0x44)
appears in the kernel log. Through trial-and-error (the pxa270 developer's
manual is mostly incoherent on the topic of ac97 reset), I got cold reset to
complete by setting the WARM_RST bit in the GCR register (and later noticed that
pxa3xx does this for cold reset as well). Also, a timeout loop is needed to
wait for the reset to complete.
commit 267f8fa2e1eef0612b2007e1f1846bcbc35cc1fa upstream.
commit 5f960294e2031d12f10c8488c3446fecbf59628d upstream.
These are not supported
commit b78562b10fa66175e30b76073e32a0ad8d92aa83 upstream.
The workaround to force VREF50 for dallas/hp model with ALC861VD
was introduced in commit 8fdcb6fe4204bdb4c6991652717ab5063751414e,
but it contained wrong pincap override bits.
This patch fixes to exclude VREF80 pincap bit correctly.
commit 6169b673618bf0b2518ce413b54925782a603f06 upstream.
We've seen the broken HDMI *video* output on some machines with GM965,
and the debugging session pointed that the culprit is the disabled
audio output pins. Toggling these pins dynamically on demand caused
flickering of HDMI TV.
This patch changes the behavior to keep the pin ON constantly.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51421
commit 8ae5865ec77c22462c736846a0679947a6953548 upstream.
Fix the quirk entry for HP Pavilion dv7 in order to make the bass
speaker working.
Reported-and-tested-by: Tomas Pospisek <tpo2@sourcepole.ch>
commit 63a077e27648b4043b1ca1b4e29f0c42d99616b6 upstream.
Acer Aspire One 522 has the infamous digital mic unit that needs the
phase inversion fixup for stereo.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=715737
commit f5f165418cabf2218eb466c0e94693b8b1aee88b upstream.
The commit [88a8516a: ALSA: usbaudio: implement USB autosuspend] added
the support of autopm for USB MIDI output, but it didn't take the MIDI
input into account.
This patch adds the following for fixing the autopm:
- Manage the URB start at the first MIDI input stream open, instead of
the time of instance creation
- Move autopm code to the common substream_open()
- Make snd_usbmidi_input_start/_stop() more robust and add the running
state check
Reviewd-by: Clemens Ladisch <clemens@ladisch.de>
Tested-by: Clemens Ladisch <clemens@ladisch.de>
commit 59866da9e4ae54819e3c4e0a8f426bdb0c2ef993 upstream.
Add a similar protection against the disconnection race and the
invalid use of usb instance after disconnection, as well as we've done
for the USB audio PCM.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51201
commit 7110005e8d5c3cd418fc4b64f9f124f004422a9a upstream.
Signed-off-by: Duncan Roe <duncan_roe@acslink.net.au>
commit 6edc59e602b36cd3c95a426ef6e8cad0344af8c7 upstream.
[the order sorted by tiwai]
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
commit 8bc039a1e15a72da8426b84293723fb7181f0b5e upstream.
This patch adds the HD Audio DeviceIDs for the Intel Lynx Point PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
commit af02dde8a609d8d071c4b31a82df811a55690a4a upstream.
We found a new codec ID 292, and that just a simple quirk would enable
sound output/input on this ALC292 chip.
BugLink: https://bugs.launchpad.net/bugs/1081466
Tested-by: Acelan Kao <acelan.kao@canonical.com>
commit 7ff34ad80b7080fafaac8efa9ef0061708eddd51 upstream.
These are compatible with standard ALC269 parser.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit e99ddfde6ae0dd2662bb40435696002b590e4057 upstream.
Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend) added
autosuspend code to all files making up the snd-usb-audio driver.
However, midi.c is part of snd-usb-lib and is also used by other
drivers, not all of which support autosuspend. Thus, calls to
usb_autopm_get_interface() could fail, and this unexpected error would
result in the MIDI output being completely unusable.
Make it work by ignoring the error that is expected with drivers that do
not support autosuspend.
Reported-by: Colin Fletcher <colin.m.fletcher@googlemail.com>
Reported-by: Devin Venable <venable.devin@gmail.com>
Reported-by: Dr Nick Bailey <nicholas.bailey@glasgow.ac.uk>
Reported-by: Jannis Achstetter <jannis_achstetter@web.de>
Reported-by: Rui Nuno Capela <rncbc@rncbc.org>
Cc: Oliver Neukum <oliver@neukum.org>
commit 445632ad6dda42f4d3f9df2569a852ca0d4ea608 upstream.
DAPM shutdown incorrectly uses "list" field of codec struct while
iterating over probed components (codec_dev_list). "list" field
refers to codecs registered in the system, "card_list" field is
used for probed components.
Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
commit 55c6f4cb6ef49afbb86222c6a3ff85329199c729 upstream.
When MCLK is supplied externally and BCLK and LRC are configured as outputs
(codec is master), the PLL values are only calculated correctly on the first
transmission. On subsequent transmissions, at differenct sample rates, the
wrong PLL values are used. Test for f_opclk instead of f_pllout to determine
if the PLL values are needed.
Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
commit 10e44239f67d0b6fb74006e61a7e883b8075247a upstream.
The recent change for USB-audio disconnection race fixes introduced a
mutex deadlock again. There is a circular dependency between
chip->shutdown_rwsem and pcm->open_mutex, depicted like below, when a
device is opened during the disconnection operation:
A. snd_usb_audio_disconnect() ->
card.c::register_mutex ->
chip->shutdown_rwsem (write) ->
snd_card_disconnect() ->
pcm.c::register_mutex ->
pcm->open_mutex
B. snd_pcm_open() ->
pcm->open_mutex ->
snd_usb_pcm_open() ->
chip->shutdown_rwsem (read)
Since the chip->shutdown_rwsem protection in the case A is required
only for turning on the chip->shutdown flag and it doesn't have to be
taken for the whole operation, we can reduce its window in
snd_usb_audio_disconnect().
Reported-by: Jiri Slaby <jslaby@suse.cz>
commit 8bb4d9ce08b0a92ca174e41d92c180328f86173f upstream.
There are uncovered cases whether the card refcount introduced by the
commit a0830dbd isn't properly increased or decreased:
- OSS PCM and mixer success paths
- When lookup function gets NULL
This patch fixes these places.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=50251
commit 19a62823eae453619604636082085812c14ee391 upstream.
commit ef4da45828603df57e5e21b8aa21a66ce309f79b upstream.
VT1802 codec provides the invalid connection lists of NID 0x24 and
0x33 containing the routes to a non-exist widget 0x3e. This confuses
the auto-parser. Fix it up in the driver by overriding these
connections.
Reported-by: Massimo Del Fedele <max@veneto.com>
commit 5b3761954dac2d1393beef8210eb8cee81d16b8d upstream.
In via_auto_fill_adc_nids(), the parser tries to fill dac_nids[] at
the point of the current line-out (i). When no valid path is found
for this output, this results in dac = 0, thus it creates a hole in
dac_nids[]. This confuses is_empty_dac() and trims the detected DAC
in later reference.
This patch fixes the bug by appending DAC properly to dac_nids[] in
via_auto_fill_adc_nids().
commit ae24c3191ba2ab03ec6b4be323e730e00404b4b6 upstream.
Several bug reports suggest that the forcibly resetting IEC958 status
bits is required for AD codecs to get the SPDIF output working
properly after changing streams.
Original fix credit to Javeed Shaikh.
BugLink: https://bugs.launchpad.net/ubuntu/+source/alsa-driver/+bug/359361
Reported-by: Robin Kreis <r.kreis@uni-bremen.de>
commit 16337e028a6dae9fbdd718c0d42161540a668ff3 upstream.
Correctly enable the digital microphones with the right bits in the
right coeffecient registers on Cirrus CS4206/7 codecs. It also
prevents misconfiguring ADC1/2.
This fixes the digital mic on the Macbook Pro 10,1/Retina.
Based-on-patch-by: Alexander Stein <alexander.stein@systec-electronic.com>
Signed-off-by: Daniel J Blueman <daniel@quora.org>
commit 5a83b4b5a391f07141b157ac9daa51c409e71ab5 upstream.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
commit 0914f7961babbf28aaa2f19b453951fb4841c03f upstream.
When disconnect callback is called, each component should wake up
sleepers and check card->shutdown flag for avoiding the endless sleep
blocking the proper resource release.
commit a0830dbd4e42b38aefdf3fb61ba5019a1a99ea85 upstream.
For more strict protection for wild disconnections, a refcount is
introduced to the card instance, and let it up/down when an object is
referred via snd_lookup_*() in the open ops.
The free-after-last-close check is also changed to check this refcount
instead of the empty list, too.
Reported-by: Matthieu CASTET <matthieu.castet@parrot.com>
commit 888ea7d5ac6815ba16b3b3a20f665a92c7af6724 upstream.
Similar like the previous commit, cover with chip->shutdown_rwsem
and chip->shutdown checks.
commit 34f3c89fda4fba9fe689db22253ca8db2f5e6386 upstream.
Replace mutex with rwsem for codec->shutdown protection so that
concurrent accesses are allowed.
Also add the protection to snd_usb_autosuspend() and
snd_usb_autoresume(), too.
commit 978520b75f0a1ce82b17e1e8186417250de6d545 upstream.
Close some races at disconnection of a USB audio device by adding the
chip->shutdown_mutex and chip->shutdown check at appropriate places.
The spots to put bandaids are:
- PCM prepare, hw_params and hw_free
- where the usb device is accessed for communication or get speed, in
mixer.c and others; the device speed is now cached in subs->speed
instead of accessing to chip->dev
The accesses in PCM open and close don't need the mutex protection
because these are already handled in the core PCM disconnection code.
The autosuspend/autoresume codes are still uncovered by this patch
because of possible mutex deadlocks. They'll be covered by the
upcoming change to rwsem.
Also the mixer codes are untouched, too. These will be fixed in
another patch, too.
commit 9b0573c07f278e9888c352aa9724035c75784ea0 upstream.
Fix races at PCM disconnection:
- while a PCM device is being opened or closed
- while the PCM state is being changed without lock in prepare,
hw_params, hw_free ops
commit 10f571d09106c3eb85951896522c9650596eff2e upstream.
Add chip details for E-mu 1010 PCIe card. It has the same
chip as found in E-mu 1010b but it uses different PCI id.
Signed-off-by: Maxim Kachur <mcdebugger@duganet.ru>
commit 733a48e5ae5bf28b046fad984d458c747cbb8c21 upstream.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=44721
commit 84f98fdf7865fbd35b312eb39ea91e5618c514c7 upstream.
I have a Lenovo ThinkPad T430 and an UltraBase Series 3 docking
station.
Without this patch, if I plug my headphones into the jack on the
computer, everything works fine. The computer speakers mute and the
audio is played in the headphones. However, if I plug into the docking
station headphone jack the computer speakers are muted but there is no
audio in the headphones.
Addresses https://bugs.launchpad.net/bugs/1060372
Signed-off-by: Joseph Salisbury <joseph.salisbury@canonical.com>
commit 71aa5ebe36a4e936eff281b375a4707b6a8320f2 upstream.
Even when CONFIG_SND_DEBUG is not enabled, we don't want to
return an arbitrary memory location when the channel count is
larger than we expected.
commit f7f4b2322bf7b8c5929b7eb5a667091f32592580 upstream.
This caused the internal speaker to mute itself because it was
present, which happened after powersave.
It was found on Dell XPS 15 (L502x), ALC665.
Reported-by: Da Fox <da.fox.mail@gmail.com>
commit c5e0b6dbad9b4d18c561af90b384d02373f1c994 upstream.
The proper destructor should be called at the error path.
[bwh: Backported to 3.2: drop the change to nonexistent patch_cs4213()]
Ideapad U300s"
commit 83b0c6ba999643ee8ad6329f26e1cdc870e1a920 upstream.
Make sure we don't dereference the "quirk" pointer when it is null.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit d4f1e48bd11e3df6a26811f7a1f06c4225d92f7d upstream.
When the loopback timer handler is running, calling del_timer() (for STOP
trigger) will not wait for the handler to complete before deactivating the
timer. The timer gets rescheduled in the handler as usual. Then a subsequent
START trigger will try to start the timer using add_timer() with a timer pending
leading to a kernel panic.
Serialize the calls to add_timer() and del_timer() using a spin lock to avoid
this.
Signed-off-by: Omair Mohammed Abdullah <omair.m.abdullah@linux.intel.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
commit e4db0952e542090c605fd41d31d761f1b4624f4a upstream.
The Lenovo IdeaPad U310 has an internal mic where the right channel
is phase inverted.
Signed-off-by: Felix Kaechele <felix@fetzig.org>
commit b3c5dce81584391af8b6dedb0647e65c17aab3a2 upstream.
The Lenovo Ideapad S205 has an internal mic where the right channel
is phase inverted.
BugLink: https://bugs.launchpad.net/bugs/884652
