git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/soc
From Sekhar Nori:
DaVinci SoC changes for v3.11
This pull request moves DaVinci EDMA library to
arch/arm/common so it can be used by OMAP based AM335x.
This is a temporary step until all drivers are converted
to use the dmaengine driver in drivers/dma/edma.c.
Several drivers like SPI, MMC/SD have already been converted.
Some like audio are pending.
The other two patches in the pull request are cleanup in nature.
* tag 'davinci-for-v3.11/soc-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
ARM: edma: remove unused transfer controller handlers
ARM: davinci: move private EDMA API to arm/common
ARM: davinci: remove __init atrribute from function declaration
Move mach-davinci/dma.c to common/edma.c so it can be used
by OMAP (specifically AM33xx) as well.
Signed-off-by: Matt Porter <mporter@ti.com>
Acked-by: Chris Ball <cjb@laptop.org> # davinci_mmc.c
Acked-by: Mark Brown <broonie@linaro.org>
Acked-by: Olof Johansson <olof@lixom.net>
[nsekhar@ti.com: dropped davinci sffsdr changes]
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Pull VFS fixes from Al Viro:
"Several fixes + obvious cleanup (you've missed a couple of open-coded
can_lookup() back then)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
snd_pcm_link(): fix a leak...
use can_lookup() instead of direct checks of ->i_op->lookup
move exit_task_namespaces() outside of exit_notify()
fput: task_work_add() can fail if the caller has passed exit_task_work()
ncpfs: fix rmdir returns Device or resource busy
in case when snd_pcm_stream_linked(substream) is true, we end up leaking
group.
When calling snd_soc_dapm_sync(), it eventually tries to lock the same mutex
already locked in snd_soc_dapm_put_volsw_aic3x() and a deadlock occurs. By
moving the mutex unlock to just before snd_soc_dapm_sync(), this deadlock is
prevented. This problem was introduced in Linux 3.5
Signed-off-by: Andreas Irestål <Andreas.Irestal@axis.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Even though they are virtual widgets DAI widgets still get counted for the
DAPM context power management so we can't just use the active state to
check if they should be powered as they may not be part of a complete path.
Instead split them into input and output widgets and do the same power
checks as we perform on AIFs.
Reported-by: Stephen Warren <swarren@nvidia.com>
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
USB audio driver spews an error message when probing Logitech HD
webcam c270:
ALSA mixer.c:1300 usb_audio: Warning! Unlikely big volume range (=6144), cval->res is probably wrong.
ALSA mixer.c:1304 usb_audio: [5] FU [Mic Capture Volume] ch = 1, val = 1536/7680/1
Obviously the device needs a fixed volume resolution (cval->res = 384)
like other Logitech devices.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=821735
Reported-and-tested-by: Cristian Rodríguez <crrodriguez@opensuse.org>
Cc: <stable@vger.kernel.org>
... instead of applying to all interfaces.
Reference: http://forums.gentoo.org/viewtopic-p-6886404.html
The previous commit was written in the way to make the backport to
3.9.y easier, and left the duplicated open codes intentionally.
Now let's clean up the duplicated codes.
VIA driver has a special suspend handling only for VT1802 to reduce
the pop noise. During the transition to the generic parser, the
behavior of snd_hda_set_pin_ctl() was also changed to modify the
cached values, too. And this caused a regression where the pin is
still cleared even after the resume (including the resume from power
save), resulting in the silent output.
The fix is simply to replace snd_hda_set_pin_ctl() with the explicit
call of snd_hda_codec_write() again.
Reported-by: Alex Riesen <raa.lkml@gmail.com>
Cc: <stable@vger.kernel.org> [v3.9]
VT1802 codec seems to reset EAPD of other pins in the hardware level,
and this was another reason of the silent headphone output on some
machines. As a workaround, introduce a new flag indicating to keep
the EPAD on to the generic parser, and set it in patch_via.c.
Some codec drivers (VIA codecs and some Realtek fixups) set the
automute and automic hooks after calling
snd_hda_gen_parse_auto_config(). In the current code, the hook
pointers are referred only in snd_hda_gen_parse_auto_config() and
passed to snd_hda_jack_detect_enable_callback(), thus changing the
hook values won't change the actually called callbacks properly.
This patch fixes this bug by setting the static functions as the
primary callback functions for the jack detection, and let them
calling the appropriate hooks dynamically.
Since the transition to the generic parser, the actual routes used
there don't match always with the assumed static paths in some
set_widgets_power_state callbacks. This results in the wrong power
setup in the end. As a temporary workaround, we need to disable the
calls together with the non-functional dynamic power control enum.
When declaring playback and capture capabilities check for both CODEC
side and CPU side support rather than only checking for CODEC side
support. While it is unusual some CPUs do have unidirectional DAIs.
Reported-by: Fabio Estevam <fabio.estevam@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Commit 927c9423dd5f2d1c0b93d5e694ab84b4a5559713 (ALSA: usb-audio: add
Edirol UM-3G support) used a wrong quirk type, which would make the
driver refuse to attach with the error message "MIDIStreaming interface
descriptor not found".
Cc: <stable@vger.kernel.org> # 3.3 and later
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
This quirk is required for the headset mic to work on these
two machines.
BugLink: https://bugs.launchpad.net/bugs/1186170
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
Add a model/fixup string "lenovo-dock", for Thinkpad T431s, to allow sound in docking station.
Tested on Lenovo T431s with ThinkPad Mini Dock Plus Series 3
Signed-off-by: Ebben Aries <earies@dscp.org>
Fix to return a negative error code in the pci_set_dma_mask() error
handling case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Signed-off-by: Nicolas Schichan <nschichan@freebox.fr>
Acked-by: Brian Austin <brian.austin@cirrus.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Updates for v3.10
A series of driver specific updates, none particularly critical, plus
one fix to the compressed API code to handle capture streams properly
which is very safe for mainline as there's no current users.
The default register value for MASTERA_VOL is 0x00, the same as
MASTERB_VOL.
Cc: stable@vger.kernel.org
The array 'drc_cfg' of size 3 may use index value -22 (EINVAL)
The array 'retune_mobile_cfg' of size 3 may use index value -22 (EINVAL)
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
During recent refactoring the code to report removal when MICDET reports
an absent microphone was removed, causing problems for systems which rely
solely on the MICDET for this functionality. Restore it.
Check only the uppermost 16 bits instead of the whole 32 bits of
the version information. Do this because all firmware version tested
with this version information worked correctly and the strict check
causes problems for several users.
Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com>
The mask should define the bits to change in the register, not the
bits to preserve.
This fixes the inadvertent changes of the "Headphone Analog Gain"
value during mute/unmute.
controls.
McASP serial audio engine needs different rotation values on TX and RX
channels. Commit dde109fb462 ("ASoC: McASP: Fix data rotation for
playback. Enables 24bit audio playback") changed the calculation to fix
the playback format, but broke the capture stream by doing it for both
TXFMT and RXFMT.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Cc: stable@vger.kernel.org [3.9 only]
Add callback to initialise the speaker in the core following the recent
changes to handling of integration with the thermal interrupts.
request_threaded_irq() rejects calls which both do not specify a handler
(indicating that the primary IRQ handler should be used) and do not set
IRQF_ONESHOT because the combination is unsafe with level-triggered
interrupts. It is safe in this case, though, since max98090 IRQs are
edge-triggered and the interrupts aren't ACK'ed until the codec's IRQ
status register is read. Because of this, an IRQF_ONESHOT interrupt
doesn't really make a difference, but request one anyway in order to make
request_threaded_irq() happy.
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull devm usage cleanup from Wolfram Sang:
"Lately, I have been experimenting how to improve the devm interface to
make writing device drivers easier and less error prone while also
getting rid of its subtle issues. I think it has more potential but
still needs work and definately conistency, especiall in its usage.
The first thing I come up with is a low hanging fruit regarding
devm_ioremap_resouce(). This function already checks if the passed
resource is valid and gives an error message if not. So, we can
remove similar checks from the drivers and get rid of a bit of code
and a number of inconsistent error strings.
This series only removes the unneeded check iff devm_ioremap_resource
follows platform_get_resource directly. The previous version tried to
shuffle code if needed, too, what lead to an embarrasing bug. It
turned out to me that shuffling code for all cases found will make the
automated script too complex, so I am unsure if an automated cleanup
is the proper tool for this case. Removing the easy stuff seems
worthwhile to me, though.
Despite various architectures and platform dependencies, I managed to
compile test 45 out of 57 modified files locally using heuristics and
defconfigs."
Pulled because: 296 deletions, 0 additions.
* 'devm_no_resource_check' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (33 commits)
sound/soc/kirkwood: don't check resource with devm_ioremap_resource
sound/soc/fsl: don't check resource with devm_ioremap_resource
arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource
arch/arm/plat-samsung: don't check resource with devm_ioremap_resource
arch/arm/mach-tegra: don't check resource with devm_ioremap_resource
drivers/watchdog: don't check resource with devm_ioremap_resource
drivers/w1/masters: don't check resource with devm_ioremap_resource
drivers/video/omap2/dss: don't check resource with devm_ioremap_resource
drivers/video/omap2: don't check resource with devm_ioremap_resource
drivers/usb/phy: don't check resource with devm_ioremap_resource
drivers/usb/host: don't check resource with devm_ioremap_resource
drivers/usb/gadget: don't check resource with devm_ioremap_resource
drivers/usb/chipidea: don't check resource with devm_ioremap_resource
drivers/thermal: don't check resource with devm_ioremap_resource
drivers/staging/nvec: don't check resource with devm_ioremap_resource
drivers/staging/dwc2: don't check resource with devm_ioremap_resource
drivers/spi: don't check resource with devm_ioremap_resource
drivers/rtc: don't check resource with devm_ioremap_resource
drivers/pwm: don't check resource with devm_ioremap_resource
drivers/pinctrl: don't check resource with devm_ioremap_resource
devm_ioremap_resource does sanity checks on the given resource. No need to
duplicate this in the driver.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
