commit d8009882e9f5e1a76986c741f071edd2ad760c97 upstream
The lock used in snd_ctl_dev_disconnect() should be card->ctl_files_rwlock
for protection of card->ctl_files entries, instead of card->controls_rwsem.
Reported-by: Vegard Nossum <vegard.nossum@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
Cc: Chris Wedgwood <cw@f00f.org>
commit 82e68f7ffec3800425f2391c8c86277606860442 upstream
snd_seq_oss_synth_make_info() incorrectly reports information
to userspace without first checking for the validity of the
device number, leading to possible information leak (CVE-2008-3272).
Reported-By: Tobias Klein <tk@trapkit.de>
Acked-and-tested-by: Takashi Iwai <tiwai@suse.de>
Cc: stable@kernel.org
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit 43785eaeb1cfb8aed3cf8027f298b242f88fdc45 upstream
Don't create mixer volume elements for Headphone and Speaker if they
use the same DAC as normal line-outs on AD1988. Otherwise the amp
value gets screwed up, e.g.
https://bugzilla.novell.com/show_bug.cgi?id=398255
commit 470eaf6be78424fc499a5039e5d5fe58bace2bc3 upstream
Added the missing SSID of Thinkpad Z60m for model=thinkpad with
AD1981HD.
Backport fixes for usb-audio Oops at reconnection.
9eb70e6... [ALSA] usb-audio - Fix race in reconnection
f18638d... [ALSA] Clean up snd_card_free*()
73d38b1... [ALSA] Fix the race of card instance unregistration
commit d2cd74b158d7214a556226e3312f9fb1de64d7ae upstream
On Audigy2 Platinum, the Analog/Digital mixer switch is inverted.
https://bugzilla.novell.com/show_bug.cgi?id=396204
The patch adds a simple workaround.
There might be another device requiring a similar fix, too (or fix for
audigy2 generically), but right now I fix only the known broken one.
commit 6c4cc3a8ed15aacc06a5fd369639fef633cee2bc upstream
Added more fallbacks to OSS PHONEOUT mixer mapping. This corresponds
to the speaker output in general, so now "Mono" and "Speaker" are
assigned.
commit e48d6d97bb6bd8c008045ea0522ea8278fdccc55 upstream
ASUS A9T laptop uses line-out pin as the real front-output while
other devices use it as the surround.
Commit 981bcead3f2279a1ec6fb5f2c57aff79ed61a700 upstream.
Stop the S/PDIF DMA engine and output when the device is told to pause.
It will keep on looping the current buffer contents if this isn't done.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
Tested-by: Rene Herman <rene.herman@gmail.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
[ALSA] hda - Fix "alc262_sony_unsol[]" hda_verb array
commit 7b1e8795ebfe1705153d1001f2a899119f4d9012 upstream
I think that hda_verb array must have "terminator (empty array)".
But alc262_sony_unsol[] does not have it.
And it causes gcc-4.3's buggy behavior
with snd_hda_sequence_write().
Signed-off-by: Akio Idehara <zbe64533@gmail.com>
upstream commit: 868e15dbd2940f9453b4399117686f408dc77299
When the Linux kernel is compiled with CONFIG_DEBUG_SHIRQ=y,
the Soundblaster Audigy2 ZS Notebook PCMCIA card causes the
system hang during boot (udev stage) or when the card is hot-plug.
The CONFIG_DEBUG_SHIRQ flag is by default 'y' with all Fedora
kernels since 2.6.23. The problem was reported as
https://bugzilla.redhat.com/show_bug.cgi?id=326411
The issue was hunted down to the snd_emu10k1_create() routine:
/* pseudo-code */
snd_emu10k1_create(...) {
request_irq(... IRQF_SHARED ...) {
register the irq handler
#ifdef CONFIG_DEBUG_SHIRQ
call the irq handler: snd_emu10k1_interrupt() {
poll I/O port // <---- !! system hangs
#endif
snd_emu10k1_cardbus_init(...) {
initialize I/O ports
The early access to I/O port in the interrupt handler causes
the freeze. Obviously it is necessary to init the I/O ports
before accessing them. This patch moves the registration of
the irq handler after the initialization of the I/O ports.
Signed-off-by: Jaroslav Franek <jarin.franek@post.cz>
Acked-by: James Courtier-Dutton <James@superbug.co.uk>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
upstream commit: 07bc76dfa19b10017b518dd9aa1b2719e8c863de
The auto-config mode of Realtek ALC codecs has a bug since 2.6.25
that it cannot resume properly. The problem was the wrong assignment
of init_hook that overrides the whole initialization.
Relevant bug reports:
http://bugzilla.kernel.org/show_bug.cgi?id=10662
https://bugzilla.novell.com/show_bug.cgi?id=385473
snd_es1968_ac97_read() calls snd_es1968_ac97_wait() first outside a locked
area, and later, while holding a lock.
snd_es1968_ac97_wait() has a polling loop with a cond_resched() inside it..
which sleeps, so the second call is invalid.
This patch adds a version of the wait function that just pure polls. While
this is not very elegant in principle, it's very likely the easiest thing to
do here, we already checked if the chip was ready (while yielding) just
before, so it is very unlikely to take a long time here.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
I accidentally removed the module license from sound/oss/ac97_codec.c in
commit 83bad1d764b836a482b88e0a1f44d7a5c3e1fee0 ("scheduled OSS driver
removal")
Spotted by Roland <devzero@web.de>.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Please stop using random I2C driver IDs.
Also removed a pointless initialization to 0 of a static struct member.
Acked-by: Takashi Iwai <tiwai@suse.de>
Cc: Jarkko Nikula <jarkko.nikula@nokia.com>
sound/usb/usbaudio.c (check_hw_params_convention): Handle kcalloc failure.
Signed-off-by: Jim Meyering <meyering@redhat.com>
Added the ac97_quirk hp_only for Compaq Deskpro EN.
Fix the line-out volume control of eeepc p701 to be a proper slave of
the virtual master control.
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com>
Don't need to declare a struct when defining a structure layout. Both
of these structs are unused.
sound/pci/ice1712/revo.c:39:3: warning: symbol 'revo51' was not declared. Should it be static?
sound/pci/ice1712/phase.c:54:3: warning: symbol 'phase28' was not declared. Should it be static?
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Add kcontrol argument to function since the API was changed by the commit
9af6d9562414568ecadf96aaef5b88e7e8b19821.
Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com>
Add kcontrol argument to functions since the API was changed by the commit
Some models like eeepc ep20 have invalid mixer names that aren't
handled properly by virtual master controls. Rename them to the
proper names.
Also fixed some typos in the mixer names but they are not compiled
in right now.
Added ac97_quirk=hp-only for Acer Travelmate 2310.
ALSA bug#3656
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3656
This adds a quirk to the Realtek ALC883 table for the Albatron KI690-AM2
motherboard to use the 6stack-dig model.
Signed-off-by: Andrew Paprocki <andrew@ishiboo.com>
I forgot to set the module owner for the HiFier/Xonar models.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Add the proper model entry for Fujitsu Lifebook E8410 with ALC262 codec.
The some indices of capture elements of AD1988 are wrongly assigned.
This patch fixes it. See ALSA bug#3795
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3795
Fix a wrong version check that would cause an invalid command to be sent
to SB 1.0 chips.
Add a workaround for the feedback pipe of E-Mu 0202/0404 USB devices
that reports the number of samples per packet instead of the number of
samples per microframe.
HP dv8000 laptop has a problem with Master volume. It's due to the
connection of the widget 0x13. When it's connected from the analog
amp mixer (0x19), it works as expected mysteriously (ALSA bug#3775):
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3775
Call free_irq() after iounmap() because other devices could trigger our
shared interrupt handler.
The driver gets Oops with ATI HDMI devices due to the wrong calculation
of index for playback streams. This patch fixes it. Reference:
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3746
Fix following warning:
WARNING: vmlinux.o(.text+0x11ec01a): Section mismatch in reference from the function setup_card() to the function .devinit.text:snd_usb_caiaq_control_init()
setup_card() are only used by init_card().
init_card() are only used by snd_probe()
snd_probe() are used for the .probe parameter in usb_driver.probe
Annotate them all __devinit to fix the warning.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Pin widgets have always one amp-input value regardless of number of
connections. The proc file showed values wrongly.
The capture source selection for ADC list with two elements is buggy
becaues of a wrong capture mux list. This patch fixes the starting
index based on spec->num_adc_nids.
The widget list of capture source selection for ALC883 contains the
wrong NIDs.
Don't create vmaster controls if no slaves are found in the given list.
This prevents the error due to an empty vmaster control.
Attached patch fix race condition in hd_codec generic bound volume/swtich
controls
oops on this bug can be easy reproduced by two mixer apps on SMP system with
PREEMPT kernel
dmesg:
ALSA /home/ss/ALSA/alsa-driver-1.0.16/pci/hda/../../alsa-kernel/pci/hda/hda_intel.c:596:
hda_intel: azx_get_response timeout, switching to polling mode: las
t cmd=0x014f0900
BUG: unable to handle kernel paging request at virtual address 00070006
printing eip: f8f43e95 *pde = 00000000
Oops: 0000 [#1] PREEMPT SMP
Modules linked in: i915 drm snd_seq_dummy snd_seq_oss snd_seq_midi_event
snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss bnep rfcomm hidp l2cap
bluetooth w
lan_wep acpi_cpufreq coretemp hwmon mmc_block pcspkr psmouse wlan_scan_sta
ath_rate_sample snd_hda_intel ath_pci serio_raw wlan tg3 sdhci snd_pcm
firewire_o
hci mmc_core i2c_i801 snd_timer firewire_core snd_page_alloc ath_hal(P)
snd_hwdep snd iTCO_wdt crc_itu_t iTCO_vendor_support shpchp video output
acer_acpi b
acklight led_class wmi_acer
Pid: 3969, comm: gkrellm Tainted: P (2.6.24-jm #4)
EIP: 0060:[<f8f43e95>] EFLAGS: 00010292 CPU: 0
EIP is at snd_hda_mixer_bind_ctls_info+0x20/0x43 [snd_hda_intel]
EAX: 00000000 EBX: f7478e00 ECX: f763e000 EDX: f764f788
ESI: 00070002 EDI: edce5e00 EBP: edc3fe64 ESP: edc3fe54
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
Process gkrellm (pid: 3969, ti=edc3e000 task=f1e4e000 task.ti=edc3e000)
Stack: f764f77c f7478e00 edce5e00 f6dd6000 edc3fe84 f8e590e8 edc7a239 f6d14034
f764f34c f6c0f7e0 edc3ff30 f6d14034 edc3fea8 f8e591b7 edc3ff30 edc3ff2c
00000000 f70aa668 f6d14034 f8e59165 bfbfadb0 edc3ff40 f8e587aa edc3ff2c
Call Trace:
[<c0104fbb>] show_trace_log_lvl+0x1a/0x2f
[<c010506d>] show_stack_log_lvl+0x9d/0xa5
[<c0105119>] show_registers+0xa4/0x1bd
[<c0105354>] die+0x122/0x206
[<c03daccc>] do_page_fault+0x535/0x623
[<c03d940a>] error_code+0x72/0x78
[<f8e590e8>] snd_mixer_oss_get_volume1_vol+0x74/0xf1 [snd_mixer_oss]
[<f8e591b7>] snd_mixer_oss_get_volume1+0x52/0xa5 [snd_mixer_oss]
[<f8e587aa>] snd_mixer_oss_ioctl1+0x673/0x71e [snd_mixer_oss]
[<f8e588af>] snd_mixer_oss_ioctl+0xb/0xd [snd_mixer_oss]
[<c017af0a>] do_ioctl+0x22/0x67
[<c017b186>] vfs_ioctl+0x237/0x24a
[<c017b1ca>] sys_ioctl+0x31/0x4b
[<c010402e>] syscall_call+0x7/0xb
Code: 3f 49 c7 89 f8 59 5b 5e 5f 5d c3 55 89 e5 57 89 d7 56 53 89 c3 83 ec 04
8b 70 5c 8b 40 60 05 7c 01 00 00 89 45 f0 e8 c0 3f 49 c7 <8b> 46 04 89 fa 89
4
3 5c 89 d8 8b 0e ff 11 89 73 5c 89 c7 8b 45
EIP: [<f8f43e95>] snd_hda_mixer_bind_ctls_info+0x20/0x43 [snd_hda_intel]
SS:ESP 0068:edc3fe54
---[ end trace 0a20bc209e9397cc ]---
similar issue report present in ALSA bugtracking system
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=3652
Signed-off-by: Serge A. Suchkov <Serge.A.S@tochka.ru>
In linus' git tree I found this problem. Is it also in the alsa tree?
please confirm it's the right fix. The patch was not yet tested.
Signed-off-by: Roel Kluin <12o3l@tiscali.nl>
Acked-by: Timur Tabi <timur@freescale.com>
The GPIO pin 0 of the CM9780 must be set when muting the line input even
on non-Xonar cards.
Fixed the SPDIF output on Conexant Cx5045 codec. Added the missing
pin output setting and fixed the wrong NID for digital audio-out widget.
This patch enables snoop on Intel SCH chipset, eliminating static during
playback.
Signed-off-by: Tobin Davis <tdavis@dsl-only.net>
Removed invalid __devinit from hdsp_request_fw_loader() and
snd_hwdep_create_hwdep() that aren't always init functions.
Removed invalid __devinit and __devexit that are remaining after
split to a helper module.
The driver resubmits URBs from an error handler and schedules the error
handler from the URBs' completion handlers. To reliably kill the cycle
a flag must be used.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Add proper ifdef's to the patch loading code moved from the old instr
layer so that opl3 driver can be compiled without the sequencer support.
The sound drivers and the pnpbios core test for current->root != NULL. This
test seems to be unnecessary since we always have rootfs mounted before
initializing the drivers.
Signed-off-by: Jan Blunck <jblunck@suse.de>
Acked-by: Christoph Hellwig <hch@lst.de>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
If count reaches zero, the loop ends, but the postfix decrement still
subtracts: testing for 'count == 0' will not work.
Reviewed-by: Ray Lee <ray-lk@madrabbit.org>
Acked-by: Muli Ben-Yehuda <muli@il.ibm.com>
