commit 83ea5d18d74f032a760fecde78c0210f66f7f70c upstream.
Creation of individual mixer controls may fail, but that shouldn't cause
the entire mixer creation to fail. Even worse, if the mixer creation
fails, that will error out the entire device probing.
All the functions called by parse_audio_unit() should return -EINVAL if
they find descriptors that are unsupported or believed to be malformed,
so we can safely handle this error code as a non-fatal condition in
snd_usb_mixer_controls().
That fixes a long standing bug which is commonly worked around by
adding quirks which make the driver ignore entire interfaces. Some of
them might now be unnecessary.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Reported-and-tested-by: Rodolfo Thomazelli <pe.soberbo@gmail.com>
commit 4d7b86c98e445b075c2c4c3757eb6d3d6efbe72e upstream.
In check_input_term() and parse_audio_feature_unit(), propagate the
error value that has been returned by a failing function instead of
-EINVAL. That helps cleaning up the error pathes in the mixer.
commit a686fd141e20244ad75f80ad54706da07d7bb90a upstream.
There is a typo in convert_to_spdif_status() about checking the
emphasis IEC958 status bit. It should check the given value instead
of the resultant value.
Reported-by: Martin Weishart <martin.weishart@telosalliance.com>
commit 66efdc71d95887b652a742a5dae51fa834d71465 upstream.
snd_seq_timer_open() didn't catch the whole error path but let through
if the timer id is a slave. This may lead to Oops by accessing the
uninitialized pointer.
BUG: unable to handle kernel NULL pointer dereference at 00000000000002ae
IP: [<ffffffff819b3477>] snd_seq_timer_open+0xe7/0x130
PGD 785cd067 PUD 76964067 PMD 0
Oops: 0002 [#4] SMP
CPU 0
Pid: 4288, comm: trinity-child7 Tainted: G D W 3.9.0-rc1+ #100 Bochs Bochs
RIP: 0010:[<ffffffff819b3477>] [<ffffffff819b3477>] snd_seq_timer_open+0xe7/0x130
RSP: 0018:ffff88006ece7d38 EFLAGS: 00010246
RAX: 0000000000000286 RBX: ffff88007851b400 RCX: 0000000000000000
RDX: 000000000000ffff RSI: ffff88006ece7d58 RDI: ffff88006ece7d38
RBP: ffff88006ece7d98 R08: 000000000000000a R09: 000000000000fffe
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: ffff8800792c5400 R14: 0000000000e8f000 R15: 0000000000000007
FS: 00007f7aaa650700(0000) GS:ffff88007f800000(0000) GS:0000000000000000
CR2: 00000000000002ae CR3: 000000006efec000 CR4: 00000000000006f0
Process trinity-child7 (pid: 4288, threadinfo ffff88006ece6000, task ffff880076a8a290)
Stack:
0000000000000286 ffffffff828f2be0 ffff88006ece7d58 ffffffff810f354d
65636e6575716573 2065756575712072 ffff8800792c0030 0000000000000000
ffff88006ece7d98 ffff8800792c5400 ffff88007851b400 ffff8800792c5520
Call Trace:
[<ffffffff810f354d>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff819b17e9>] snd_seq_queue_timer_open+0x29/0x70
[<ffffffff819ae01a>] snd_seq_ioctl_set_queue_timer+0xda/0x120
[<ffffffff819acb9b>] snd_seq_do_ioctl+0x9b/0xd0
[<ffffffff819acbe0>] snd_seq_ioctl+0x10/0x20
[<ffffffff811b9542>] do_vfs_ioctl+0x522/0x570
[<ffffffff8130a4b3>] ? file_has_perm+0x83/0xa0
[<ffffffff811b95ed>] sys_ioctl+0x5d/0xa0
[<ffffffff813663fe>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff81faed69>] system_call_fastpath+0x16/0x1b
Reported-and-tested-by: Tommi Rantala <tt.rantala@gmail.com>
commit 2069d483b39a603a5f3428a19d3b4ac89aa97f48 upstream.
When a value of a vmaster slave control is changed, the ctl change
notification is sometimes ignored. This happens when the master
control overrides, e.g. when the corresponding master control is
muted. The reason is that slave_put() returns the value of the actual
slave put callback, and it doesn't reflect the virtual slave value
change.
This patch fixes the function just to return 1 whenever a slave value
is changed.
commit 69a4cfdd444d1fe5c24d29b3a063964ac165d2cd upstream.
Set card->private_data in snd_ice1712_create for fixing NULL
dereference in snd_ice1712_remove().
Signed-off-by: Sean Connor <sconnor004@allyinics.org>
commit 7da58046482fceb17c4a0d4afefd9507ec56de7f upstream.
The quirk for the Roland/Cakewalk A-PRO keyboards accidentally used the
wrong interface number, which prevented the driver from attaching to the
device.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit f49a59c4471d81a233e09dda45187cc44fda009d upstream.
According to the other code in this driver and similar
code in rme96 it seems, that spin_lock_irq in
snd_rme32_capture_close function should be paired
with spin_unlock_irq.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Denis Efremov <yefremov.denis@gmail.com>
commit dacae5a19b4cbe1b5e3a86de23ea74cbe9ec9652 upstream.
snd_ali_pointer function is called with local
interrupts disabled. However it seems very strange to
reenable them in such way.
commit d56268fb108c7c21e19933588ca4d94652585183 upstream.
Commit 23caaf19b11e (ALSA: usb-mixer: Add support for Audio Class v2.0)
forgot to adjust the length check for UAC 2.0 feature unit descriptors.
This would make the code abort on encountering a feature unit without
per-channel controls, and thus prevented the driver to work with any
device having such a unit, such as the RME Babyface or Fireface UCX.
Reported-by: Florian Hanisch <fhanisch@uni-potsdam.de>
Tested-by: Matthew Robbetts <wingfeathera@gmail.com>
Tested-by: Michael Beer <beerml@sigma6audio.de>
Cc: Daniel Mack <daniel@caiaq.de>
commit 41b645c8624df6ace020a8863ad1449d69140f7d upstream.
Cold reset on the pxa27x currently fails and
pxa2xx_ac97_try_cold_reset: cold reset timeout (GSR=0x44)
appears in the kernel log. Through trial-and-error (the pxa270 developer's
manual is mostly incoherent on the topic of ac97 reset), I got cold reset to
complete by setting the WARM_RST bit in the GCR register (and later noticed that
pxa3xx does this for cold reset as well). Also, a timeout loop is needed to
wait for the reset to complete.
Tested on a palm treo 680 machine.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
commit 267f8fa2e1eef0612b2007e1f1846bcbc35cc1fa upstream.
commit f5f165418cabf2218eb466c0e94693b8b1aee88b upstream.
The commit [88a8516a: ALSA: usbaudio: implement USB autosuspend] added
the support of autopm for USB MIDI output, but it didn't take the MIDI
input into account.
This patch adds the following for fixing the autopm:
- Manage the URB start at the first MIDI input stream open, instead of
the time of instance creation
- Move autopm code to the common substream_open()
- Make snd_usbmidi_input_start/_stop() more robust and add the running
state check
Reviewd-by: Clemens Ladisch <clemens@ladisch.de>
Tested-by: Clemens Ladisch <clemens@ladisch.de>
commit 59866da9e4ae54819e3c4e0a8f426bdb0c2ef993 upstream.
Add a similar protection against the disconnection race and the
invalid use of usb instance after disconnection, as well as we've done
for the USB audio PCM.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51201
commit af02dde8a609d8d071c4b31a82df811a55690a4a upstream.
We found a new codec ID 292, and that just a simple quirk would enable
sound output/input on this ALC292 chip.
BugLink: https://bugs.launchpad.net/bugs/1081466
Tested-by: Acelan Kao <acelan.kao@canonical.com>
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 7110005e8d5c3cd418fc4b64f9f124f004422a9a upstream.
Signed-off-by: Duncan Roe <duncan_roe@acslink.net.au>
commit 7ff34ad80b7080fafaac8efa9ef0061708eddd51 upstream.
These are compatible with standard ALC269 parser.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit e99ddfde6ae0dd2662bb40435696002b590e4057 upstream.
Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend) added
autosuspend code to all files making up the snd-usb-audio driver.
However, midi.c is part of snd-usb-lib and is also used by other
drivers, not all of which support autosuspend. Thus, calls to
usb_autopm_get_interface() could fail, and this unexpected error would
result in the MIDI output being completely unusable.
Make it work by ignoring the error that is expected with drivers that do
not support autosuspend.
Reported-by: Colin Fletcher <colin.m.fletcher@googlemail.com>
Reported-by: Devin Venable <venable.devin@gmail.com>
Reported-by: Dr Nick Bailey <nicholas.bailey@glasgow.ac.uk>
Reported-by: Jannis Achstetter <jannis_achstetter@web.de>
Reported-by: Rui Nuno Capela <rncbc@rncbc.org>
Cc: Oliver Neukum <oliver@neukum.org>
commit 08ef79490dad6b88010e94795cf9f89b018ed504 upstream.
The drivers don't require the exclusive irqs. Let's fix the deprecated
warnings.
commit 445632ad6dda42f4d3f9df2569a852ca0d4ea608 upstream.
DAPM shutdown incorrectly uses "list" field of codec struct while
iterating over probed components (codec_dev_list). "list" field
refers to codecs registered in the system, "card_list" field is
used for probed components.
Signed-off-by: Misael Lopez Cruz <misael.lopez@ti.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
commit 55c6f4cb6ef49afbb86222c6a3ff85329199c729 upstream.
When MCLK is supplied externally and BCLK and LRC are configured as outputs
(codec is master), the PLL values are only calculated correctly on the first
transmission. On subsequent transmissions, at differenct sample rates, the
wrong PLL values are used. Test for f_opclk instead of f_pllout to determine
if the PLL values are needed.
Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
commit ae24c3191ba2ab03ec6b4be323e730e00404b4b6 upstream.
Several bug reports suggest that the forcibly resetting IEC958 status
bits is required for AD codecs to get the SPDIF output working
properly after changing streams.
Original fix credit to Javeed Shaikh.
BugLink: https://bugs.launchpad.net/ubuntu/+source/alsa-driver/+bug/359361
Reported-by: Robin Kreis <r.kreis@uni-bremen.de>
commit 5a83b4b5a391f07141b157ac9daa51c409e71ab5 upstream.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
commit 10e44239f67d0b6fb74006e61a7e883b8075247a upstream.
The recent change for USB-audio disconnection race fixes introduced a
mutex deadlock again. There is a circular dependency between
chip->shutdown_rwsem and pcm->open_mutex, depicted like below, when a
device is opened during the disconnection operation:
A. snd_usb_audio_disconnect() ->
card.c::register_mutex ->
chip->shutdown_rwsem (write) ->
snd_card_disconnect() ->
pcm.c::register_mutex ->
pcm->open_mutex
B. snd_pcm_open() ->
pcm->open_mutex ->
snd_usb_pcm_open() ->
chip->shutdown_rwsem (read)
Since the chip->shutdown_rwsem protection in the case A is required
only for turning on the chip->shutdown flag and it doesn't have to be
taken for the whole operation, we can reduce its window in
snd_usb_audio_disconnect().
Reported-by: Jiri Slaby <jslaby@suse.cz>
commit 8bb4d9ce08b0a92ca174e41d92c180328f86173f upstream.
There are uncovered cases whether the card refcount introduced by the
commit a0830dbd isn't properly increased or decreased:
- OSS PCM and mixer success paths
- When lookup function gets NULL
This patch fixes these places.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=50251
commit 0914f7961babbf28aaa2f19b453951fb4841c03f upstream.
When disconnect callback is called, each component should wake up
sleepers and check card->shutdown flag for avoiding the endless sleep
blocking the proper resource release.
commit a0830dbd4e42b38aefdf3fb61ba5019a1a99ea85 upstream.
For more strict protection for wild disconnections, a refcount is
introduced to the card instance, and let it up/down when an object is
referred via snd_lookup_*() in the open ops.
The free-after-last-close check is also changed to check this refcount
instead of the empty list, too.
Reported-by: Matthieu CASTET <matthieu.castet@parrot.com>
commit 888ea7d5ac6815ba16b3b3a20f665a92c7af6724 upstream.
Similar like the previous commit, cover with chip->shutdown_rwsem
and chip->shutdown checks.
commit 34f3c89fda4fba9fe689db22253ca8db2f5e6386 upstream.
Replace mutex with rwsem for codec->shutdown protection so that
concurrent accesses are allowed.
Also add the protection to snd_usb_autosuspend() and
snd_usb_autoresume(), too.
commit 978520b75f0a1ce82b17e1e8186417250de6d545 upstream.
Close some races at disconnection of a USB audio device by adding the
chip->shutdown_mutex and chip->shutdown check at appropriate places.
The spots to put bandaids are:
- PCM prepare, hw_params and hw_free
- where the usb device is accessed for communication or get speed, in
mixer.c and others; the device speed is now cached in subs->speed
instead of accessing to chip->dev
The accesses in PCM open and close don't need the mutex protection
because these are already handled in the core PCM disconnection code.
The autosuspend/autoresume codes are still uncovered by this patch
because of possible mutex deadlocks. They'll be covered by the
upcoming change to rwsem.
Also the mixer codes are untouched, too. These will be fixed in
another patch, too.
commit 9b0573c07f278e9888c352aa9724035c75784ea0 upstream.
Fix races at PCM disconnection:
- while a PCM device is being opened or closed
- while the PCM state is being changed without lock in prepare,
hw_params, hw_free ops
commit 10f571d09106c3eb85951896522c9650596eff2e upstream.
Add chip details for E-mu 1010 PCIe card. It has the same
chip as found in E-mu 1010b but it uses different PCI id.
Signed-off-by: Maxim Kachur <mcdebugger@duganet.ru>
commit 733a48e5ae5bf28b046fad984d458c747cbb8c21 upstream.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=44721
commit c05fce586d4da2dfe0309bef3795a8586e967bc3 upstream.
Added support for Xbox Communicator to USB quirks.
Signed-off-by: Marko Friedemann <mfr@bmx-chemnitz.de>
commit c10514394ef9e8de93a4ad8c8904d71dcd82c122 upstream.
While going through Ubuntu bugs, I discovered this patch being
posted and a confirmation that the patch works as expected.
Finding out how the hw volume really works would be preferrable
to just disabling the broken one, but this would be better than
nothing.
Credit: sndfnsdfin (qawsnews)
BugLink: https://bugs.launchpad.net/bugs/559939
commit d4f1e48bd11e3df6a26811f7a1f06c4225d92f7d upstream.
When the loopback timer handler is running, calling del_timer() (for STOP
trigger) will not wait for the handler to complete before deactivating the
timer. The timer gets rescheduled in the handler as usual. Then a subsequent
START trigger will try to start the timer using add_timer() with a timer pending
leading to a kernel panic.
Serialize the calls to add_timer() and del_timer() using a spin lock to avoid
this.
Signed-off-by: Omair Mohammed Abdullah <omair.m.abdullah@linux.intel.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
commit 689185b78ba6fbe0042f662a468b5565909dff7a upstream.
Help UIs associate it with the matching gain control.
commit 3737e2be505d872bf2b3c1cd4151b2d2b413d7b5 upstream.
The AK4396 DAC has a linear-scale attentuator, but
sound/pci/ice1712/prodigy_hifi.c used a log scale instead, which is
not quite right. This patch restores the correct scale, borrowing
from the ak4396 code in sound/pci/oxygen/oxygen.c.
Signed-off-by: Matteo Frigo <athena@fftw.org>
commit ccf795847a38235ee4a56a24129ce75147d6ba8f upstream.
Currently the microphone input source is not selectable as while there is
a DAPM widget it's not connected to anything so it won't be properly
instantiated. Add something more correct for the input structure to get
things going, even though it's not hooked into the rest of the routing
map and so won't actually achieve anything except allowing the relevant
register bits to be written.
Reported-by: Christop Fritz <chf.fritz@googlemail.com>
commit 088c820b732dbfd515fc66d459d5f5777f79b406 upstream.
As spec said, 1 indicates no copyright is asserted.
Signed-off-by: Wang Xingchao <xingchao.wang@intel.com>
commit b8edf3e5522735c8ce78b81845f7a1a2d4a08626 upstream.
Otherwise if someone tries to use all four channels on AIF1 with the
device in master mode we won't be able to clock out all the data.
commit 9d40e5582c9c4cfb6977ba2a0ca9c2ed82c56f21 upstream.
Required for reliable power up from cold.
commit bc733d495267a23ef8660220d696c6e549ce30b3 upstream.
The irq field of struct snd_mpu401 is supposed to be initialized to -1.
Since it's set to zero as of now, a probing error before the irq
installation results in a kernel warning "Trying to free already-free
IRQ 0".
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=44821
commit aff252a848ce21b431ba822de3dab9c4c94571cb upstream.
uac_clock_source_is_valid() uses the control selector value to access
the bmControls bitmap of the clock source unit. This is wrong, as
control selector values start from 1, while the bitmap uses all
available bits.
In other words, "Clock Validity Control" is stored in D3..2, not D5..4
of the clock selector unit's bmControls.
Reported-by: Andreas Koch <andreas@akdesigninc.com>
commit 4e01ec636e64707d202a1ca21a47bbc6d53085b7 upstream.
This codec has a separate dmic path (separate dmic only ADC),
and thus it looks mostly like ALC275.
BugLink: https://bugs.launchpad.net/bugs/1025377
Tested-by: Ray Chen <ray.chen@canonical.com>
commit c9fe573a6584034670c1a55ee8162d623519cbbf upstream.
In sound/soc/codecs/tlv320aic3x.c
data = snd_soc_read(codec, AIC3X_PLL_PROGA_REG);
snd_soc_write(codec, AIC3X_PLL_PROGA_REG,
data | (pll_p << PLLP_SHIFT));
In the above code, pll-p value is OR'ed with previous value without
clearing it. Bug is not seen if pll-p value doesn't change across
Sampling frequency.
However on some platforms (like AM335x EVM-SK), pll-p may have different
values across different sampling frequencies. In such case, above code
configures the pll with a wrong value.
Because of this bug, when a audio stream is played with pll value
different from previous stream, audio is heard as differently(like its
stretched).
Signed-off-by: Hebbar, Gururaja <gururaja.hebbar@ti.com>
commit befae82e2906cb7155020876a531b0b8c6c8d8c8 upstream.
This chip looks very similar to ALC269 and ALC27* variants. The bug reporter
has verified that sound was working after this patch had been applied.
BugLink: https://bugs.launchpad.net/bugs/1017017
Tested-by: Richard Crossley <richardcrossley@o2.co.uk>
commit 5cd5d7c44990658df6ab49f6253c39617c53b03d upstream.
The array of sample rates is reallocated every time when opening
the PCM device, but was freed only once when unplugging the device.
Reported-by: "Alexander E. Patrakov" <patrakov@gmail.com>
commit 32cf4023e689ad5b3a81a749d8cc99d7f184cb99 upstream.
When an IRQ for some reason gets lost, we wait up to a second using
udelay, which is CPU intensive. This patch improves the situation by
waiting about 30 ms in the CPU intensive mode, then stepping down to
using msleep(2) instead. In essence, we trade some granularity in
exchange for less CPU consumption when the waiting time is a bit longer.
As a result, PulseAudio should no longer be killed by the kernel
for taking up to much RT-prio CPU time. At least not for *this* reason.
Tested-by: Arun Raghavan <arun.raghavan@collabora.co.uk>
commit c914f55f7cdfafe9d7d5b248751902c7ab57691e upstream.
This assertion seems to imply that chip->dsp_code_to_load is a pointer.
It's actually an integer handle on the actual firmware, and 0 has no
special meaning.
The assertion prevents initialisation of a Darla20 card, but would also
affect other models. It seems it was introduced in commit dd7b254d.
ALSA sound/pci/echoaudio/echoaudio.c:2061 Echoaudio driver starting...
ALSA sound/pci/echoaudio/echoaudio.c:1969 chip=ebe4e000
ALSA sound/pci/echoaudio/echoaudio.c:2007 pci=ed568000 irq=19 subdev=0010 Init hardware...
ALSA sound/pci/echoaudio/darla20_dsp.c:36 init_hw() - Darla20
WARNING: at sound/pci/echoaudio/echoaudio_dsp.c:478 init_hw+0x1d1/0x86c [snd_darla20]()
Hardware name: Dell DM051
BUG? (!chip->dsp_code_to_load || !chip->comm_page)
Signed-off-by: Mark Hills <mark@pogo.org.uk>
