commit 433897f7408b556f7dfbb98c94deea02e634d2a7 upstream.
We no longer have a flat ASoC cache so can't peer directly into the array
any more but should instead use the register I/O functions to update the
cache.
commit edfe3bfc1b779ddda9bcff523eb022dda37b93c8 upstream.
Pin 0x1b was connected to the front panel connector, which according to
the HDA standard should contain a mic and a headphone. In this case,
the headphone was listed as "line out" by BIOS.
BugLink: https://bugs.launchpad.net/bugs/993162
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit bfd37bb5f681961e255fd2f346c20fdae2ef3f27 upstream.
Volume updates may not be acted upon if there is no clock applied when
the volume update is written. Ensure this doesn't happen by writing out
registers with volume updates after we enable each of the clocks.
There are more registers updated than before as previously we were
relying on wm_hubs to set those for controls it manages.
commit c8fdc1b56611faa7b38eab6b99da5e20113661ff upstream.
Ensure that all the actions get taken at appropriate times by calling the
_PRE and _POST events for the aifNclk_ev functions explicitly.
commit 5cd5d7c44990658df6ab49f6253c39617c53b03d upstream.
The array of sample rates is reallocated every time when opening
the PCM device, but was freed only once when unplugging the device.
Reported-by: "Alexander E. Patrakov" <patrakov@gmail.com>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"A few last-minute regression fixes for 3.4 final kernel. All trivial,
and Cc'ed to stable kernel."
* tag 'sound-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ASoC: wm8994: Fix AIF2ADC power down
ALSA: hda/idt - Fix power-map for speaker-pins with some HP laptops
ASoC: cs42l73: Sync digital mixer kcontrols to allow for 0dB
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Last minute fixes
Some last minute fixes for ASoC. Small, focused changes to specific
drivers.
Cc: stable@vger.kernel.org
BIOS on some HP laptops don't set the speaker-pins as fixed but expose
as jacks, and this confuses the driver as if these pins are
jack-detectable. As a result, the machine doesn't get sounds from
speakers because the driver prepares the power-map update via jack
unsol events which never come up in reality. The bug was introduced
in some time in 3.2 for enabling the power-mapping feature.
This patch fixes the problem by replacing the check of the persistent
power-map bits with a proper is_jack_detectable() call.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43240
Cc: <stable@vger.kernel.org> [v3.2+]
Some of the Digital mixer kcontrol max values were off by 1 not allowing a max of 0dB.
Signed-off-by: Brian Austin <brian.austin@cirrus.com>
"Slightly more than expected as rc7, but all are reasonablly small
fixes. A few additions of HD-audio fixup entries, a couple of other
regression fixes including a revert, and a few other trivial
oneliners."
ASoC: sh: fix migor.c compilation
ALSA: HDA: Lessen CPU usage when waiting for chip to respond
Revert "ALSA: hda - Set codec to D3 forcibly even if not used"
ALSA: hda/realtek - Call alc_auto_parse_customize_define() always after fixup
ALSA: hdsp - Provide ioctl_compat
ALSA: hda/realtek - Add missing CD-input pin for MSI-7350 mobo
ALSA: hda/realtek - Add a fixup for Acer Aspire 5739G
ALSA: echoaudio: Remove incorrect part of assertion
ASoC: Build fix for SH in 3.4
An API update which wasn't sufficiently thorough in updating the tree...
Fix a recent compilation breakage, caused by a change in SH clock API.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
When an IRQ for some reason gets lost, we wait up to a second using
udelay, which is CPU intensive. This patch improves the situation by
waiting about 30 ms in the CPU intensive mode, then stepping down to
using msleep(2) instead. In essence, we trade some granularity in
exchange for less CPU consumption when the waiting time is a bit longer.
As a result, PulseAudio should no longer be killed by the kernel
for taking up to much RT-prio CPU time. At least not for *this* reason.
Tested-by: Arun Raghavan <arun.raghavan@collabora.co.uk>
Cc: <stable@kernel.org>
This reverts commit 785f857d1cb0856b612b46a0545b74aa2596e44a.
The commit causes a problem with the wrong D3 state after suspend
because the call of hda_set_power_state() involves with the power-up
sequence, which changes the power_count, and this confuses the resume
sequence that checks the power_count as well.
Originally, this go-to-D3 sequence should be a simple task without the
power-up sequence. But, it'd need some proper sanity checks in the
case of power-saved state, so it's not too easy to write now in the
3.4-rc cycle.
In short, the safest option now is to revert this affecting commit.
Of course, we need to clean up and robustify the power-saving code
better for 3.5 kernel.
Reported-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
The call for alc_auto_parse_customize_define() must be done after the
fixup pre-probe initialization. Otherwise SKU_IGNORE fixup won't work
properly (e.g. HP RP5800 with ALC662 codec).
snd_hdsp uses its own ioctls to acquire config- and status information.
Expose the corresponding ioctl handler via ioctl_compat, so that 32bit applications can use it on 64bit kernels.
Signed-off-by: Andre Schramm <andre.schramm@iosono-sound.com>
Reviewed-by: Adrian Knoth <adi@drcomp.erfurt.thur.de>
Signed-off-by: Adrian Knoth <adi@drcomp.erfurt.thur.de>
Reported-by: Philipp Matthias Hahn <pmhahn@pmhahn.de>
Cc: <stable@kernel.org> [v3.3+]
Acer Aspire 5739G requires the same fix-up for 4930G to support the
surround / bass speakers.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43180
This assertion seems to imply that chip->dsp_code_to_load is a pointer.
It's actually an integer handle on the actual firmware, and 0 has no
special meaning.
The assertion prevents initialisation of a Darla20 card, but would also
affect other models. It seems it was introduced in commit dd7b254d.
ALSA sound/pci/echoaudio/echoaudio.c:2061 Echoaudio driver starting...
ALSA sound/pci/echoaudio/echoaudio.c:1969 chip=ebe4e000
ALSA sound/pci/echoaudio/echoaudio.c:2007 pci=ed568000 irq=19 subdev=0010 Init hardware...
ALSA sound/pci/echoaudio/darla20_dsp.c:36 init_hw() - Darla20
WARNING: at sound/pci/echoaudio/echoaudio_dsp.c:478 init_hw+0x1d1/0x86c [snd_darla20]()
Hardware name: Dell DM051
BUG? (!chip->dsp_code_to_load || !chip->comm_page)
Signed-off-by: Mark Hills <mark@pogo.org.uk>
Pull sound sound fixes from Takashi Iwai:
"As good as nothing exciting here; just a few trivial fixes for various
ASoC stuff."
ASoC: omap-pcm: Free dma buffers in case of error.
ASoC: s3c2412-i2s: Fix dai registration
ASoC: wm8350: Don't use locally allocated codec struct
ASoC: tlv312aic23: unbreak resume
ASoC: bf5xx-ssm2602: Set DAI format
ASoC: core: check of_property_count_strings failure
ASoC: dt: sgtl5000.txt: Add description for 'reg' field
ASoC: wm_hubs: Make sure we don't disable differential line outputs
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc into fix/asoc
ASoC: Updates for 3.4
Nothing terribly exciting here, a bunch of small and simple fixes
scattered around the place.
Signed-off-by: Oleg Matcovschi <oleg.matcovschi@ti.com>
Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@ti.com>
As s3c2412-i2s is using the s3c_i2sv2 it should call the more specialised
s3c_i2sv2_register_dai instead of simply calling snd_soc_register_dai.
Without this call the snd_soc_dai_ops structure isn't initialised correctly.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
The core allocates the live copies, we shouldn't try to duplicate it and
were buggy trying to do so as we were using uninitialised data for the
control data.
* commit f9dfbf9 "ASoC: tlv320aic23: convert to soc-cache" leads to
a bug preventing resumeof the codec as regmap expects a 9 bits data
register but 0xFFFF is passed in tlv320aic23_set_bias_level and this
values gets cached preventing any write to the TLV320AIC23_PWR
register as the final value produced by regmap is (register << 9) | value
* this patch solves the problem by only working on the 9 bits the
register contains.
Signed-off-by: Eric Bénard <eric@eukrea.com>
"A workaround for an ASUS laptop and a few ASoC changes; most of the
commits are tagged for stable, too."
ASoC: wm8994: Improve sequencing of AIF channel enables
ALSA: HDA: Add external mic quirk for Asus Zenbook UX31E
ASoC: fsi: update for dmaengine prep_slave_sg fallout.
ASoC: core: Fix card RTD count for deferred probe.
ASoC: cs42l73: don't use negative array index
ASoC: dapm: Ensure power gets managed for line widgets
Commit 980b0bc69 ("ASoC: blackfin: Use dai_fmt") converted the blackfin ASoC
machine drivers to use the dai_links dai_fmt field to setup their DAI format.
For the bf5xx-ssm2602 the commit removed the manual call to snd_soc_dai_set_fmt,
but missed to set the dai_links dai_fmt field.
Signed-off-by: Richard Zhao <richard.zhao@freescale.com>
While we need to clean up unused single ended line outputs we don't want
to do this if the outputs are in differential mode.
ASoC: updates for 3.4
Slightly larger than normal - the DAPM fix is a "this should always have
worked" type of thing which is very clear and should have no impact on
systems that don't need it. The WM8994 fix is driver specific but
pretty important for that driver.
This ensures a clean startup of the channels, without this change some
use cases could result in issues in a small proportion of cases.
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFD fixes from Samuel Ortiz:
"We have 3 build fixes, a OMAP USB host PHY reset fix and the twl6040
conversion to an i2c driver. The latter may not sound like a fix but
the twl6040 MFD driver won't probe without it, triggering an OMAP4
audio regression."
* tag 'mfd-for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6:
mfd: Fix modular builds of rc5t583 regulator support
mfd: Fix asic3_gpio_to_irq
ARM: OMAP3: USB: Fix the EHCI ULPI PHY reset issue
mfd: Convert twl6040 to i2c driver, and separate it from twl core
mfd : Fix dbx500 compilation error
"Fixes for a few regressions of HD-audio, originated partly from 3.4
and partly 3.3.
The fixes for ThinkPad docking-station are for 3.3 kernels, thus they
are based on 3.3 then merged back to 3.4, so that they can be merged
to stable tree cleanly. The non-trivial merge conflicts are because
of this action.
In addition, a couple of trivial fixes for documentation and a long-
standing issue in the listing of built-in sound driver at boot time."
ALSA: hda/conexant - Set up the missing docking-station pins
ALSA: hda/conexant - Don't set HP pin-control bit unconditionally
ALSA: workaround: change the timing of alsa_sound_last_init()
ALSA: hda/sigmatel - Fix inverted mute LED
ALSA: hda/realtek - Fix regression on Quanta/Gericom KN1
ALSA: fix core/vmaster.c kernel-doc warning
According to the reporter, external mic starts to work if the
laptop-dmic model is used. According to BIOS pin config, all
pins are consistent with the alc269vb_laptop_dmic fixup, except
for the external mic, which is not present.
Cc: stable@kernel.org
BugLink: https://bugs.launchpad.net/bugs/950490
Merge fixes for Thinkpad docking-station regressions for 3.3 kernels
back to 3.4. These were committed in that branch to make the stable
merging easier.
sound/pci/hda/patch_conexant.c
ThinkPad 410,420,510,520 and X201 with cx50585 & co chips have the
docking-station ports, but BIOS doesn't initialize for these pins.
Thus, like the former X200, we need to set up the pins manually in the
driver.
The odd part is that the same PCI SSID is used for X200 and T400, thus
we need to prepare individual fixup tables for cx5051 and others.
Bugzilla entries:
https://bugzilla.redhat.com/show_bug.cgi?id=808559
https://bugzilla.redhat.com/show_bug.cgi?id=806217
https://bugzilla.redhat.com/show_bug.cgi?id=810697
Reported-by: Josh Boyer <jwboyer@redhat.com>
Reported-by: Jens Taprogge <jens.taprogge@taprogge.org>
Tested-by: Jens Taprogge <jens.taprogge@taprogge.org>
Some output pins on Conexant chips have no HP control bit, but the
auto-parser initializes these pins unconditionally with PIN_HP.
Check the pin-capability and avoid the HP bit if not supported.
Current alsa_sound_last_init() was called as __initcall().
So, on current ALSA, only devices that had been properly
registered at this point were shown.
So, it will show "No soundcards found" if driver requests
probe deferment. it's often misleading.
This patch delays the timing of alsa_sound_last_init()
as workaround.
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Reviwed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
While refactoring the mute-LED handling for HP laptops, I messed up
the polarity check in a wrong way. The red (or the mute-LED if any)
should appear in the muted state, corresponding to GPIO on.
Reported-by: Mikko Vinni <mmvinni@yahoo.com>
Through the transition to the auto-parser, the support for
Quanta/Gericom KN1 got broken. There are two problems behind it:
- This machine doesn't like the default COEF setup for ALC260 we take
now as default
- BIOS doesn't set the pins correctly at all; especially the machine
uses only the pin 0x0f for both headphone and speaker
This patch adds the fixup as a workaround for these issues.
Reported-and-tested-by: Uros Vampl <mobile.leecher@gmail.com>
Leading up to the ->device_prep_slave_sg change in
185ecb5f4fd43911c35956d4cc7d94a1da30417f 'dmaengine: add context
parameter to prep_slave_sg and prep_dma_cyclic' a generic wrapper was
added in place to guard against the API change, though the fsi driver
wasn't updated in the process (presumably its dmaengine support hadn't
been merged yet at the time). This trivially switches over to the new
wrapper and gets it building again.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Fix kernel-doc warning in sound/core/vmaster.c:
Warning(sound/core/vmaster.c:429): No description found for parameter 'private_data'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Currently we increment the number of RTD's per card during the DAI link
bind. This can cause an incorrect RTD count when we cannot find a component
and defer the probe (and hence perform the DAI link bind for the card again).
Fix the count so that it is cleared before every card registration
and bind attempt.
Complete the separation of the twl6040 from the twl core since
it is a separate chip, not part of the twl6030 PMIC.
Make the needed Kconfig changes for the depending drivers at the
same time to avoid breaking the kernel build (vibra, ASoC components).
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Reviewed-by: Mark Brown <broonie@opensource.wolfsonicro.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Pull another round of sound fixes from Takashi Iwai:
"A few regression fixes for Realtek HD-audio codecs, mainly specific to
some laptop models."
ALSA: hda/realtek - Fix mem leak (and rid us of trailing whitespace).
ALSA: hda/realtek - Add quirk for Mac Pro 5,1 machines
ALSA: hda/realtek - Add a fixup entry for Acer Aspire 8940G
ALSA: hda/realtek - Fix GPIO1 setup for Acer Aspire 4930 & co
ALSA: hda/realtek - Add a few ALC882 model strings back
If cs42l73_get_mclkx_coeff() returns < 0 (which it can) in
sound/soc/codecs/cs42l73.c::cs42l73_set_mclk(), then we'll be using
the (negative) return value as array index on the very next line of
code - that's bad.
Catch the negative return value and propagate it to the caller (which
checks for it) and things are a bit more sane :-)
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
In sound/pci/hda/patch_realtek.c::alc_auto_fill_dac_nids(), in the
'for (;;)' loop, if the 'badness' value returned from
fill_and_eval_dacs() is negative, then we'll return from the function
without freeing the memory we allocated for 'best_cfg', thus leaking.
Fix the leak by kfree()'ing the memory when badness is negative.
While I was there I also noticed some trailing whitespace in the
function that I removed (along with all other trailing whitespace in
the file) - it didn't seem worth-while to do that as two patches, so I
hope it's OK that I just did it all as one patch.
