commit b3a81520bd37a28f77cb0f7002086fb14061824d upstream.
The very same problem is seen on Haier W18 laptop with ALC861 as seen
on ASUS A6Rp, which was fixed by the commit 3b25eb69.
Now we just need to add a new SSID entry pointing to the same fixup.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42656
commit 3b25eb690e8c7424eecffe1458c02b87b32aa001 upstream.
The refactoring of Realtek codec driver in 3.2 kernel caused a
regression for ASUS A6Rp laptop; it doesn't give any output.
The reason was that this machine has a secret master mute (or EAPD)
control via NID 0x0f VREF. Setting VREF50 on this node makes the
sound working again.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42588
commit a6a600d10aaddf1da38053c4c6b64f50f56176e6 upstream.
HP laptop models with buggy BIOS are apparently frequent, including
machines with different codecs. Set the polarity of the mute led based
on the SSID and include an entry for the HP Mini 110-3100.
Signed-off-by: Gustavo Maciel Dias Vieira <gustavo@sagui.org>
Tested-by: Predrag Ivanovic <predivan@open.telekom.rs>
commit a14304edcd5e8323205db34b08f709feb5357e64 upstream.
We should be allowing a 5ms delay after the charge pump is started in
order to ensure it has finished ramping.
commit 495174a8ffbaa0d15153d855cf206cdc46d51cf4 upstream.
These are all to either uncached registers or fixes to register defaults,
in the former case the cache won't do anything and in the latter case
we're fixing things so the cache sync will do the right thing.
commit fed22007113cb857e917913ce016d9b539dc3a80 upstream.
With a low frequency SYSCLK and a fast I2C clock register synchronisation
may occasionally take too long to take effect, causing I/O issues. Disable
synchronisation in order to avoid any issues.
commit e53e417331c57b9b97e3f8be870214a02c99265c upstream.
Writing to the registers won't work if we do actually manage to hit a fully
powered off state.
commit b4ead019afc201f71c39cd0dfcaafed4a97b3dd2 upstream.
The recent change of the power-widget handling for IDT codecs caused
the silent output from the docking-station line-out jack. This was
partially fixed by the commit f2cbba7602383cd9cdd21f0a5d0b8bd1aad47b33
"ALSA: hda - Fix the lost power-setup of seconary pins after PM resume".
But the line-out on the docking-station is still silent when booted
with the jack plugged even by this fix.
The remainig bug is that the power-widget is set off in stac92xx_init()
because the pins in cfg->line_out_pins[] aren't checked there properly
but only hp_pins[] are checked in is_nid_hp_pin().
This patch fixes the problem by checking both HP and line-out pins
and leaving the power-map correctly.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42637
commit 52409aa6a0e96337da137c069856298f4dd825a0 upstream.
The commit 2ae66c26550cd94b0e2606a9275eb0ab7070ad0e
ALSA: hda: option to enable arbitrary buffer/period sizes
introduced a regression on machines with Intel controller and Nvidia
HDMI. The reason is that the driver modifies the global variable
align_buffer_size when an Intel controller is found, and the Nvidia
HDMI controller is probed after Intel although Nvidia chips require
the aligned buffers.
This patch fixes the problem by moving the flag into the local struct
so that it's not affected by other controllers.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42567
commit ffe535edb9a9c5b4d5fe03dfa3d89a1495580f1b upstream.
More than one user reports that changing the model from "both" to
"dmic" makes their Internal Mic work.
Tested-by: Martin Ling <martin-launchpad@earth.li>
BugLink: https://bugs.launchpad.net/bugs/795823
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit f0e48b6bd4e407459715240cd241ddb6b89bdf81 upstream.
The two DACs for the front output and the surround/center/LFE/back
outputs are wired up out of phase, so when channels are duplicated,
their sound can cancel out each other and result in a weaker bass
response. To fix this, reverse the polarity of the neutron flow to
the front output.
Reported-any-tested-by: Daniel Hill <daniel@enemyplanet.geek.nz>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit b01de4fb40137fbda7530550ff0cd37171dafb0c upstream.
Several users have reported "choppy" audio under the 3.2 kernel,
and that changing position_fix to 1 has resolved their problem.
The chip is an nVidia Corporation MCP89 High Definition Audio,
[10de:0d94] (rev a2).
BugLink: https://bugs.launchpad.net/bugs/909419
commit f2cbba7602383cd9cdd21f0a5d0b8bd1aad47b33 upstream.
When multiple headphone or other detectable output pins are present,
the power-map has to be updated after resume appropriately, but the
current driver doesn't check all pins but only the first pin (since
it's enough to check it for the mute-behavior). This resulted in the
silent output from the secondary outputs after PM resume.
This patch fixes the problem by checking all pins at (re-)init time.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=740347
commit 4808d12d1dddb046ec86425e5f6766f02e950292 upstream.
Currently the driver checks only the out_mix_path[] for the primary
output route for judging whether to create the loopback-mixing control
or not. But, there are cases where aamix-routing is available only on
headphone or speaker paths but not on the primary output path. So, the
driver ignores such cases inappropriately.
This patch fixes the check of the loopback-mixing control by testing
all mix-routing paths.
commit 3a90274de3548ebb2aabfbf488cea8e275a73dc6 upstream.
When an invalid NID is given, get_wcaps() returns zero as the error,
but get_wcaps_type() takes it as the normal value and returns a bogus
AC_WID_AUD_OUT value. This confuses the parser.
With this patch, get_wcaps_type() returns -1 when value 0 is given,
i.e. an invalid NID is passed to get_wcaps().
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=740118
commit de4da59e480cdf1075b33dbaf8078fc87bc52241 upstream.
These laptops can work well with the auto-parser and their BIOS setups,
and in addition, the auto-parser fixes the problem with S3/S4 where
the unsol event handling is killed after resume due to fallback to the
single-cmd mode.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=740115
commit 80c8a2a372599e604b04a9c568952fe39cd1851d upstream.
With some buggy devices, the usb-audio driver may give "frame xxx active"
kernel messages too often. Better to keep it as debug-only using
snd_printdd(), and also add the rate-limit for avoiding floods.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=738681
commit e7848163aa2a649d9065f230fadff80dc3519775 upstream.
Cards with identical PCI ids but no AC97 config in EEPROM do not have
the ac97 field initialized. We must check for this case to avoid kernel oops.
Signed-off-by: Pavel Hofman <pavel.hofman@ivitera.com>
commit 78e2a928e377d5124932d4399c6c581908b027a0 upstream.
There was a bug in the automute logic causing speakers not to
mute when headphones were plugged in.
Tested-by: Hsin-Yi Chen <hychen@canonical.com>
commit 40d03e63e91af8ddccdfd5a536cc2a6e51433e1d upstream.
The control name "HP/Speakers" is non-standard, and since there is
only one DAC on this chip there is no need for a virtual master
anyway.
commit d0f3a2eb9062560bebca8b923424f3ca02a331ba upstream.
They are not needed here.
Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
* 'fix/asoc' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ASoC: wm8776: add missing break in sample size switch
Broken in commit d1dc698a54259cb454284456483b45f67c865cf8
Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: atmel/ac97c: using software reset instead hardware reset if not available
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
ALSA: HDA: Use LPIB Position fix for Intel SCH Poulsbo
ALSA: hda: fix mute led polarity for HP laptops with buggy BIOS
ALSA: HDA: Set position fix to LPIB for an Atom/Poulsbo based device
ASoC: Fix hx4700 error handling to free gpios if snd_soc_register_card fails
ASoC: WM8958: correctly show firmware magic on mismatch
ASoC: mxs: Add appropriate MODULE_ALIAS()
ASoC: mxs: Add missing MODULE_LICENSE("GPL")
ASoC: Fix WM8996 24.576MHz clock operation
ASoC: Include linux/module.h for smdk2443_wm9710
ASoC: Fix a typo in jive_wm8750
ASoC: Fix build dependency for SND_SOC_JZ4740_CODEC
ASoC: Include linux/io.h for jz4740 codec
Several people with this chipset have reported inconsistent/sloppy
values for position reporting when the DMA position buffer is used,
and that setting position_fix=1 have fixed their problems.
BugLink: https://bugs.launchpad.net/bugs/825709
Some HP laptop models do not have a properly filled OEM string used
to set the gpio and polarity of the mute led. Make the mute led
configuration work for this case.
For the Asus 1101HA, reporting position by reading the DMA position
buffer map seems unstable and often wrong. The reporter says that
position_fix=LPIB works much better (although not 100%, but this is
probably due to other issues).
The controller chip is an Intel Poulsbo 8086:811b (rev 07) controller,
and complete alsa-info is available here:
https://launchpadlibrarian.net/86691768/alsa-info.txt.1TNwyE5Ea7
Cc: stable@kernel.org (3.0+)
BugLink: http://bugs.launchpad.net/bugs/825709
Tested-by: Stefano Lodi
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net>
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
The sound driver refuses to load as module, because of the missing
MODULE_LICENSE("GPL").
The file header indicates that the driver is indeed published under
the GPL.
Record the clock after the divider as that is what all SYSCLK users see.
Without this the other clock configuration in the device comes out at
half rate.
ALSA: hda/realtek - Fix lost speaker volume controls
ALSA: hda/realtek - Create "Bass Speaker" for two speaker pins
ALSA: hda/realtek - Don't create extra controls with channel suffix
ALSA: hda - Fix remaining VREF mute-LED NID check in post-3.1 changes
ALSA: hda - Fix GPIO LED setup for IDT 92HD75 codecs
ASoC: Provide a more complete DMA driver stub
ASoC: Remove references to corgi and spitz from machine driver document
ASoC: Make SND_SOC_MX27VIS_AIC32X4 depend on I2C
ASoC: Fix dependency for SND_SOC_RAUMFELD and SND_PXA2XX_SOC_HX4700
ASoC: uda1380: Return proper error in uda1380_modinit failure path
ASoC: kirkwood: Make SND_KIRKWOOD_SOC_OPENRD and SND_KIRKWOOD_SOC_T5325 depend on I2C
ASoC: Mark WM8994 ADC muxes as virtual
ALSA: hda/realtek - Fix Oops in alc_mux_select()
ALSA: sis7019 - give slow codecs more time to reset
When there are the same or more number of HP pins are available, HP pins
are used as the primary outputs instead of the speaker pins. But, in
some cases (especially with ALC663 & co), some DACs are available only
with a later pin and it's assigned to a speaker, and since the driver
parses the pins from the lower NID, such a DAC was skipped eventually
without assignments. This resulted in a regression, the missing speaker
volume control in the new parser.
As a workaround for this, now the driver retries the pin->DAC mapping
again after restoring the speaker-pins as primary. This is still an ad
hoc fix, but it works so far for most of Realtek codecs.
On systems with two speaker pins, the secondary speaker pin is mostly
assigned to a bass speaker instead of a surround. Thus it makes more
sense to rename the control properly.
The multiple headphone or speaker pins are usually provided to
output the same stream unlike line-out jacks (which are supposed
to be multi-channel surrounds). Thus giving a mixer name like
"Headphone Surround" is rather confusing. Instead, when multiple
headphone volumes are available, use index with the same "Headphone"
name.
Include linux/module.h to fix below build error:
CC sound/soc/samsung/smdk2443_wm9710.o
sound/soc/samsung/smdk2443_wm9710.c:64: error: expected declaration specifiers or '...' before string constant
sound/soc/samsung/smdk2443_wm9710.c:64: warning: data definition has no type or storage class
sound/soc/samsung/smdk2443_wm9710.c:64: warning: type defaults to 'int' in declaration of 'MODULE_AUTHOR'
sound/soc/samsung/smdk2443_wm9710.c:64: warning: function declaration isn't a prototype
sound/soc/samsung/smdk2443_wm9710.c:65: error: expected declaration specifiers or '...' before string constant
sound/soc/samsung/smdk2443_wm9710.c:65: warning: data definition has no type or storage class
sound/soc/samsung/smdk2443_wm9710.c:65: warning: type defaults to 'int' in declaration of 'MODULE_DESCRIPTION'
sound/soc/samsung/smdk2443_wm9710.c:65: warning: function declaration isn't a prototype
sound/soc/samsung/smdk2443_wm9710.c:66: error: expected declaration specifiers or '...' before string constant
sound/soc/samsung/smdk2443_wm9710.c:66: warning: data definition has no type or storage class
sound/soc/samsung/smdk2443_wm9710.c:66: warning: type defaults to 'int' in declaration of 'MODULE_LICENSE'
sound/soc/samsung/smdk2443_wm9710.c:66: warning: function declaration isn't a prototype
make[3]: *** [sound/soc/samsung/smdk2443_wm9710.o] Error 1
make[2]: *** [sound/soc/samsung] Error 2
make[1]: *** [sound/soc] Error 2
make: *** [sound] Error 2
Fix a typo in jive_wm8750 that introduces below build error.
Also removes an unused err variable.
CC sound/soc/samsung/jive_wm8750.o
sound/soc/samsung/jive_wm8750.c: In function 'jive_wm8750_init':
sound/soc/samsung/jive_wm8750.c:104: warning: unused variable 'err'
sound/soc/samsung/jive_wm8750.c: At top level:
sound/soc/samsung/jive_wm8750.c:134: error: unknown field 'dapm_widgtets' specified in initializer
sound/soc/samsung/jive_wm8750.c:134: warning: initialization from incompatible pointer type
make[3]: *** [sound/soc/samsung/jive_wm8750.o] Error 1
Some HP laptops with IDT 92HD75 codecs may use a GPIO > 4 for the mute
LED, but currently the driver doesn't check this properly, and confuses
the mute LED behavior. This ended up with the silent output on some
HP laptops due to having another GPIO used as external amp control.
This patch fixes the problem by checking the max GPIO count and
comparing with the given value from DMI entry instead of magic fixed
value 4 and 8, and adding a new field to indicate the VREF mute-LED
behavior.
Reported-and-tested-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com>
Cc: <stable@kernel.org> [v3.1]
Currently SND_SOC_JZ4740_CODEC depends on SOC_JZ4740 but SOC_JZ4740 is not
defined in any Kconfig. Thus the codec driver will not be built when select
"Build all ASoC CODEC drivers".
(Unless it is selected by SND_JZ4740_SOC_QI_LB60).
Remove the dependency with SOC_JZ4740, then this code driver can be built when
select "Build all ASoC CODEC drivers".
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Include linux/io.h to fix below build errors:
CC sound/soc/codecs/jz4740.o
sound/soc/codecs/jz4740.c: In function 'jz4740_codec_read':
sound/soc/codecs/jz4740.c:82: error: implicit declaration of function 'readl'
sound/soc/codecs/jz4740.c: In function 'jz4740_codec_write':
sound/soc/codecs/jz4740.c:92: error: implicit declaration of function 'writel'
sound/soc/codecs/jz4740.c: In function 'jz4740_codec_probe':
sound/soc/codecs/jz4740.c:373: error: implicit declaration of function 'ioremap'
sound/soc/codecs/jz4740.c:373: warning: assignment makes pointer from integer without a cast
sound/soc/codecs/jz4740.c:393: error: implicit declaration of function 'iounmap'
make[3]: *** [sound/soc/codecs/jz4740.o] Error 1
make[2]: *** [sound/soc/codecs] Error 2
Allow userspace applications to do more parameter setting by providing a
more complete stub DMA driver specifying a wildcard set of formats and
channels and essentially random values for the DMA parameters. This is
required for useful runtime operation of the dummy DMA driver until we
are able to figure out how to power up links and do hw_params() from DAPM.
Sending to stable as without this the dummy driver is not terribly
useful.
Reported-by: Kyung-Kwee Ryu <Kyung-Kwee.Ryu@wolfsonmicro.com>
Tested-by: Kyung-Kwee Ryu <Kyung-Kwee.Ryu@wolfsonmicro.com>
SND_SOC_MX27VIS_AIC32X4 selects SND_SOC_TLV320AIC32X4,
but SND_SOC_TLV320AIC32X4 needs CONFIG_I2C.
So we need to make SND_SOC_MX27VIS_AIC32X4 depend on I2C.
otherwise I got below build error if CONFIG_I2C is not selected.
CC sound/soc/codecs/tlv320aic32x4.o
sound/soc/codecs/tlv320aic32x4.c: In function 'aic32x4_read':
sound/soc/codecs/tlv320aic32x4.c:323: error: implicit declaration of function 'i2c_smbus_read_byte_data'
sound/soc/codecs/tlv320aic32x4.c: In function 'aic32x4_probe':
sound/soc/codecs/tlv320aic32x4.c:641: error: 'i2c_master_send' undeclared (first use in this function)
sound/soc/codecs/tlv320aic32x4.c:641: error: (Each undeclared identifier is reported only once
sound/soc/codecs/tlv320aic32x4.c:641: error: for each function it appears in.)
sound/soc/codecs/tlv320aic32x4.c: In function 'aic32x4_modinit':
sound/soc/codecs/tlv320aic32x4.c:763: error: implicit declaration of function 'i2c_add_driver'
sound/soc/codecs/tlv320aic32x4.c: In function 'aic32x4_exit':
sound/soc/codecs/tlv320aic32x4.c:774: error: implicit declaration of function 'i2c_del_driver'
make[3]: *** [sound/soc/codecs/tlv320aic32x4.o] Error 1
SND_SOC_RAUMFELD selects SND_SOC_CS4270 which needs CONFIG_I2C,
and also selects SND_SOC_AK4104 which needs SPI_MASTER.
Thus make SND_SOC_RAUMFELD depend on I2C && SPI_MASTER.
Add depend on SPI_MASTER to fix below build error if CONFIG_SPI_MASTER
is not selected.
LD .tmp_vmlinux1
sound/built-in.o: In function `ak4104_spi_write':
last.c:(.text+0x290cc): undefined reference to `spi_sync'
sound/built-in.o: In function `ak4104_probe':
last.c:(.text+0x292a0): undefined reference to `spi_write_then_read'
sound/built-in.o: In function `ak4104_spi_probe':
last.c:(.text+0x29398): undefined reference to `spi_setup'
sound/built-in.o: In function `ak4104_init':
last.c:(.init.text+0x4ec): undefined reference to `spi_register_driver'
make: *** [.tmp_vmlinux1] Error 1
Add depend on I2C to fix below build error if CONFIG_I2C is not selected:
CC sound/soc/codecs/cs4270.o
sound/soc/codecs/cs4270.c: In function 'cs4270_i2c_probe':
sound/soc/codecs/cs4270.c:657: error: implicit declaration of function 'i2c_smbus_read_byte_data'
sound/soc/codecs/cs4270.c: In function 'cs4270_init':
sound/soc/codecs/cs4270.c:730: error: implicit declaration of function 'i2c_add_driver'
sound/soc/codecs/cs4270.c: In function 'cs4270_exit':
sound/soc/codecs/cs4270.c:736: error: implicit declaration of function 'i2c_del_driver'
make[3]: *** [sound/soc/codecs/cs4270.o] Error 1
SND_PXA2XX_SOC_HX4700 selects SND_SOC_AK4641 which needs CONFIG_I2C.
Thus make SND_PXA2XX_SOC_HX4700 depend on I2C.
CC sound/soc/codecs/ak4641.o
sound/soc/codecs/ak4641.c: In function 'ak4641_modinit':
sound/soc/codecs/ak4641.c:646: error: implicit declaration of function 'i2c_add_driver'
sound/soc/codecs/ak4641.c: In function 'ak4641_exit':
sound/soc/codecs/ak4641.c:656: error: implicit declaration of function 'i2c_del_driver'
make[3]: *** [sound/soc/codecs/ak4641.o] Error 1
