commit 1f91ecc14deea9461aca93273d78871ec4d98fcd upstream.
When selecting the audio output destinations (headphones, FP headphones,
multichannel output), unnecessary I2S channels are digitally muted to
avoid invalid signal levels on the other outputs.
Signed-off-by: Roman Volkov <v1ron@mail.ru>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 3dd77654fb1d7f68b9739f3039bad8dbbc0739f8 upstream.
Actually CS4245 connected to the I2S channel 1 for
capture, not channel 2. Otherwise capturing and
playback does not work for CS4245.
[bwh: Backported to 3.2: adjust context]
commit e805ca8b0a9b6c91099c0eaa4b160a1196a4ae25 upstream.
Logitech C500 (046d:0807) needs the same workaround like other
Logitech Webcams.
commit b3619b288b621e63f66908045f48495869a996a6 upstream.
There is a typo in the Limiter2 Release Rate control, a wrong enum for
Limiter1 is assigned. It must point to Limiter2.
Spotted by a compile warning:
In file included from sound/soc/codecs/sta32x.c:34:0:
sound/soc/codecs/sta32x.c:223:29: warning: ‘sta32x_limiter2_release_rate_enum’ defined but not used [-Wunused-variable]
static SOC_ENUM_SINGLE_DECL(sta32x_limiter2_release_rate_enum,
include/sound/soc.h:275:18: note: in definition of macro ‘SOC_ENUM_DOUBLE_DECL’
struct soc_enum name = SOC_ENUM_DOUBLE(xreg, xshift_l, xshift_r, \
sound/soc/codecs/sta32x.c:223:8: note: in expansion of macro ‘SOC_ENUM_SINGLE_DECL’
Signed-off-by: Mark Brown <broonie@linaro.org>
commit 7a6c0a58dc824523966f212c76322d47c5b0e6fe upstream.
wm8770 codec driver defines ain_enum with a wrong number of items.
Use SOC_ENUM_DOUBLE_DECL() macro and it's automatically fixed.
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
commit 025c3fa9256d4c54506b7a29dc3befac54f5c68d upstream.
Preset EQ enum of sta32x codec driver declares too many number of
items and it may lead to the access over the actual array size.
Use SOC_ENUM_SINGLE_DECL() helper and it's automatically fixed.
commit 624aef494f86ed0c58056361c06347ad62b26806 upstream.
When the driver tries to access Function Unit 10, the KEF X300A
speakers' firmware apparently locks up, making even PCM streaming
impossible. Work around this by ignoring this FU.
commit d3c56568f43807135f2c2a09582a69f809f0d8b7 upstream.
We've seen often problems after suspend/resume on Acer Aspire One
AO725 with ALC271X codec as reported in kernel bugzilla, and it turned
out that some COEFs doesn't work and triggers the codec communication
stall.
Since these magic COEF setups are specific to ALC269VB for some PLL
configurations, the machine works even without these manual
adjustment. So, let's simply avoid applying them for ALC271X.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=52181
[bwh: Backported to 3.2: return 0]
commit 80ab8eae70e51d578ebbeb228e0f7a562471b8b7 upstream.
The PCI devices with DMA masks smaller than 32bit should enable
CONFIG_ZONE_DMA. Since the recent change of page allocator, page
allocations via dma_alloc_coherent() with the limited DMA mask bits
may fail more frequently, ended up with no available buffers, when
CONFIG_ZONE_DMA isn't enabled. With CONFIG_ZONE_DMA, the system has
much more chance to obtain such pages.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=68221
commit e20970ada3f699c113fe64b04492af083d11a7d8 upstream.
The driver defines ADAU1701_SEROCTL_WORD_LEN_16 as 0x10 while it should be b10,
so 0x2. This patch fixes it.
Reported-by: Magnus Reftel <magnus.reftel@lockless.no>
commit 770bd4bf2e664939a9dacd3d26ec9ff7a3933210 upstream.
The lack of comma leads to the wrong channel for an SPDIF channel.
Unfortunately this wasn't caught by compiler because it's still a
valid expression.
Reported-by: Alexander Aristov <aristov.alexander@gmail.com>
commit f0199bc5e3a3ec13f9bc938556517ec430b36437 upstream.
When wm8904 work in DSP mode B, we still need to configure it to
work in DSP mode. Or else, it will work in Right Justified mode.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
commit ed697e1aaf7237b1a62af39f64463b05c262808d upstream.
When the process is sleeping at the SNDRV_PCM_STATE_PAUSED
state from the wait_for_avail function, the sleep process will be woken by
timeout(10 seconds). Even if the sleep process wake up by timeout, by this
patch, the process will continue with sleep and wait for the other state.
Signed-off-by: JongHo Kim <furmuwon@gmail.com>
commit 693e0cb052c607e2d41edf9e9f1fa99ff8c266c1 upstream.
While enabling these machines, we found we would sometimes lose an
interrupt if we change hardware volume during playback, and that
disabling msi fixed this issue. (Losing the interrupt caused underruns
and crackling audio, as the one second timeout is usually bigger than
the period size.)
The machines were all machines from HP, running AMD Hudson controller,
and Realtek ALC282 codec.
BugLink: https://bugs.launchpad.net/bugs/1260225
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit b4af6ef99a60c5b56df137d7accd81ba1ee1254e upstream.
According to WM8731 "PD, Rev 4.9 October 2012" datasheet, when it
works in DSP mode A, LRP = 1, while works in DSP mode B, LRP = 0.
So, fix LRP for DSP mode as the datesheet specification.
commit 9ad54547cf6f4410eba83bb95dfd2a0966718d6d upstream.
Set the missing pcbeep default amp for ALC668.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit ba4c4d0a9021ab034554d532a98133d668b87599 upstream.
It's compatible with ALC269.
commit 2ab2b74277a86afe0dd92976db695a2bb8b93366 upstream.
Otherwise we'll skip sync on resume.
commit 6408eac2665955343cd0e4bcd7d6237ce39611ed upstream.
The current code may access to the already freed object. The input
device must be accessed and unregistered before freeing the top level
sound object.
commit 092f9cd16aac7d054af1755c945f37c1b33399e6 upstream.
msnd_pinnacle.c is used for both snd-msnd-pinnacle and
snd-msnd-classic drivers, and both should have different driver
names. Using the same driver name results in the sysfs warning for
duplicated entries like
kobject: 'msnd-pinnacle.7' (cec33408): kobject_release, parent (null) (delayed)
kobject: 'msnd-pinnacle' (cecd4980): kobject_release, parent cf3ad9b0 (delayed)
WARNING: CPU: 0 PID: 1 at fs/sysfs/dir.c:486 sysfs_warn_dup+0x7d/0xa0()
sysfs: cannot create duplicate filename '/bus/isa/drivers/msnd-pinnacle'
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
commit 8f42d7698751a45cd9f7134a5da49bc5b6206179 upstream.
It's a superset of the existing CX2075x codecs, so we can reuse the
existing parser code.
commit 7b5bfb82882b9b1c8423ce0ed6852ca3762d967a upstream.
If you record the sound during playback,
the playback sound becomes silent.
Modify so that the codec driver does not clear
SG_SL1::DACL bit which is controlled under widget
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
commit 9b389a8a022110b4bc055a19b888283544d9eba6 upstream.
The probe code of snd-usb-6fire driver overrides the devices[] pointer
wrongly without checking whether it's already occupied or not. This
would screw up the device disconnection later.
Spotted by coverity CID 141423.
commit 268ff14525edba31da29a12a9dd693cdd6a7872e upstream.
Spotted by coverity CID 115170.
commit 6fc16e58adf50c0f1e4478538983fb5ff6f453d4 upstream.
ASUS N76VZ needs the same fixup as N56VZ for supporting the boost
speaker.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=846529
commit ff18620c2157671a8ee21ebb8e6a3520ea209b1f upstream.
... due to a copy & paste error.
Spotted by coverity CID 710923.
commit c6cc3d58b4042f5cadae653ff8d3df26af1a0169 upstream.
ASUS N56VZ needs a fixup for the bass speaker pin, which was already
provided via model=asus-mode4.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=841645
commit a9d14bc0b188a822e42787d01e56c06fe9750162 upstream.
The frame check in i_usX2Y_urb_complete() and
i_usX2Y_usbpcm_urb_complete() is bogus and produces false positives as
described in this LAU thread:
http://linuxaudio.org/mailarchive/lau/2013/5/20/200177
This patch removes the check code entirely.
Cc: fzu@wemgehoertderstaat.de
Reported-by: Dr Nicholas J Bailey <nicholas.bailey@glasgow.ac.uk>
Suggested-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Daniel Mack <zonque@gmail.com>
commit d967967e8d1116fb38bad25e58714b5dddd03cca upstream.
This is called from snd_ctl_elem_write() with user supplied data so we
need to add some bounds checking.
commit f8d7b13e14357ed19d2ca2799539600418dc3939 upstream.
The ->put() function are called from snd_ctl_elem_write() with user
supplied data. The limit checks here could underflow leading to a
crash.
commit 83f72151352791836a1b9c1542614cc9bf71ac61 upstream.
Toshiba Satellite C870 shows interrupt problems occasionally when
certain mixer controls like "Mic Switch" is toggled. This seems
worked around by not using MSI.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=833585
commit 18e391862cceaf43ddb8eb5cca05e1a83abdebaa upstream.
hdmi_channel_allocation() tries to find a HDMI channel allocation that
matches the number channels in the playback stream and contains only
speakers that the HDMI sink has reported as available via EDID. If no
such allocation is found, 0 (stereo audio) is used.
Using CA 0 causes the audio causes the sink to discard everything except
the first two channels (front left and front right).
However, the sink may be capable of receiving more channels than it has
speakers (and then perform downmix or discard the extra channels), in
which case it is preferable to use a CA that contains extra channels
than to use CA 0 which discards all the non-stereo channels.
Additionally, it seems that HBR (HD) passthrough output does not work on
Intel HDMI codecs when CA is set to 0 (possibly the codec zeroes
channels not present in CA). This happens with all receivers that report
a 5.1 speaker mask since a HBR stream is carried on 8 channels to the
codec.
Add a fallback in the CA selection so that the CA channel count at least
matches the stream channel count, even if the stream contains channels
not present in the sink speaker descriptor.
Thanks to GrimGriefer at OpenELEC forums for discovering that changing
the sink speaker mask allowed HBR output.
Reported-by: GrimGriefer
Reported-by: Ashecrow
Reported-by: Frank Zafka <kafkaesque1978@gmail.com>
Reported-by: Peter Frühberger <fritsch@xbmc.org>
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
commit 85fa532b6ef920b32598df86b194571a7059a77c upstream.
Bit 9 of PLL2,3 and 4 is reserved as '0'. The 24bit fractional part
should be split across each register in 8bit chunks.
Signed-off-by: Mike Dyer <mike.dyer@md-soft.co.uk>
commit fb615499f0ad28ed74201c1cdfddf9e64e205424 upstream.
The recent commit to delay the release of kobject triggered NULL
dereferences of opti9xx drivers. The cause is that all
snd-opti92x-ad1848, snd-opti92x-cs4231 and snd-opti93x drivers
register the PnP card driver with the very same name, and also
snd-opti92x-ad1848 and -cs4231 drivers register the ISA driver with
the same name, too. When these drivers are built in, quick
"register-release-and-re-register" actions occur, and this results in
Oops because of the same name is assigned to the kobject.
The fix is simply to assign individual names. As a bonus, by using
KBUILD_MODNAME, the patch reduces more lines than it adds.
The fix is based on the suggestion by Russell King.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
commit a62ee234a572b4c98fe98cf5fb18e4e8b0f6e43d upstream.
Commit d4702b189c ("sound: Fix make allmodconfig on MIPS") added a
(negative) dependency on ISA_DMA_SUPPORT_BROKEN. Since that Kconfig
symbol doesn't exist, this dependency will always evaluate to true.
Apparently GENERIC_ISA_DMA_SUPPORT_BROKEN was meant to be used here.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
commit d4702b189c6b951c1cb3260036ff998f719bfb62 upstream.
The compile of soundcard.c is broken on MIPS when allmodconfig is used
because of the missing MAX_DMA_CHANNELS definition. As a simple
workaround, just add a Kconfig dependency.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
commit 4c2aee0032b70083dafebd733ed9c774633b2fa3 upstream.
Patch makes midi output buffer DMA-able by allocating it separately.
Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com>
commit 5ece263f1d93fba8d992e67e3ab8a71acf674db9 upstream.
Patch makes pcm buffers DMA-able by allocating each one separately.
commit ddb6b5a964371e8e52e696b2b258bda144c8bd3f upstream.
Patch fixes 6fire not to use stack as URB transfer_buffer. URB buffers need to
be DMA-able, which stack is not. Furthermore, transfer_buffer should not be
allocated as part of larger device structure because DMA coherency issues and
patch fixes this issue too.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
Tested-by: Torsten Schenk <torsten.schenk@zoho.com>
commit bd5fe738e388ceaa32e5171481e0d3ec59f0ccfe upstream.
"idx" is controled by the user and can be a negative offset into the
input_names[] array.
commit 61ac51301e6c6d4ed977d7674ce2b8e713619a9b upstream.
UAC2_EXTENSION_UNIT_V2 differs from UAC1_EXTENSION_UNIT, but can be handled in
the same way when parsing the unit. Otherwise parse_audio_unit() fails when it
sees an extension unit on a UAC2 device.
UAC2_EXTENSION_UNIT_V2 is outside the range allocated by UAC1.
Signed-off-by: Torstein Hegge <hegge@resisty.net>
Acked-by: Daniel Mack <zonque@gmail.com>
commit 5dae5fd24071319bb67d3375217d5b0b6d16cb0b upstream.
Current code mishandles the case where the device is a UAC2
and the bDescriptorSubtype is a UAC2 Effect Unit (0x07).
It tries to parse it as a Processing Unit (which is similar to two
other UAC1 units with overlapping subtypes), but since the structure
is different (See: 4.7.2.10, 4.7.2.11 in UAC2 standard), the parsing
is done incorrectly and prevents the device from initializing.
For now, just ignore the unit.
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
commit be2f93a4c4981b3646b6f98f477154411b8516cb upstream.
Return SNDRV_PCM_POS_XRUN (snd_pcm_uframes_t) instead of
SNDRV_PCM_STATE_XRUN (snd_pcm_state_t) from the pointer
function of 6fire, as expected by snd_pcm_update_hw_ptr0().
Caught by sparse.
commit d52392b1a80458c0510810789c7db4a39b88022a upstream.
Vendor ID 0x10de0060 is used by a yet-to-be-named GPU chip.
Reviewed-by: Andy Ritger <aritger@nvidia.com>
Signed-off-by: Aaron Plattner <aplattner@nvidia.com>
commit 7ae48b56f8d9c836259bc02f3e2ea4962d6b5d1b upstream.
Vendor ID 0x10de0051 is used by a yet-to-be-named GPU chip.
Acked-by: Andy Ritger <aritger@nvidia.com>
Reviewed-by: Daniel Dadap <ddadap@nvidia.com>
commit 61be2b9a18ec70f3cbe3deef7a5f77869c71b5ae upstream.
snd_pcm_stop() must be called in the PCM substream lock context.
Acked-by: Mark Brown <broonie@linaro.org>
commit 46f6c1aaf790be9ea3c8ddfc8f235a5f677d08e2 upstream.
commit 5be1efb4c2ed79c3d7c0cbcbecae768377666e84 upstream.
commit 9538aa46c2427d6782aa10036c4da4c541605e0e upstream.
Acked-by: Clemens Ladisch <clemens@ladisch.de>
commit cb6f66a2d278e57a6c9d8fb59bd9ebd8ab3965c2 upstream.
The registers of max98088 are 8 bits, not 16 bits. This bug causes the
contents of registers to be overwritten with bad values when the codec
is suspended and then resumed.
Signed-off-by: Chih-Chung Chang <chihchung@chromium.org>
Signed-off-by: Dylan Reid <dgreid@chromium.org>
