Digi 01262011 Release
Signed-off-by: Alejandro Gonzalez <alex.gonzalez@digi.com>
Due to an apparent hw bug we have to shift data in the audio buffer by
one byte to play out S/PDIF. ENGR00122025 and ENGR00122231 are a
workaround for playback with non-mmapped buffers. This patch is
the workaround for mmapped buffers.
Signed-off-by: Alan Tull <r80115@freescale.com>
Starting a mono record stream and doing stereo playback resulted in
wrong sample rate. Also starting stereo playback then doing mono
record.
Support S/PDIF playback on the mx23evk.
Record was broken by the patch that fixed 24 bit S/PDIF.
To resolve the problem of playing back wavfile with sample rate over 48khz.
Signed-off-by: Lionel Xu <r63889@freescale.com>
(cherry picked from commit f1af83a27357d7da1a89d79f8ed2d74fbfb7dc34)
The data in memory is 24 bit little endian in a 32 bit word.
We need to shift the data in memory out one byte to get the proper
alignment.
Support audio record through saif, support playback/record simultaneously
(cherry picked from commit 18627873f6332e03ebd03691f51937559bbdf03d)
To fix 'pop' sound for playback and noise for mic record
Signed-off-by: Jeremy Yao <r65161@freescale.com>
Add Support for ADC/DAC Audio
(cherry picked from commit 172fc1bb738b2c83979ced6e918635d055529b43)
Support S/PDIF audio playback
Porting from mxc sound asoc driver, to support audio playback on mx28 through
saif
correct the imx_ssi_irq handler's devid parameter
Pass the irq number in platform device resources.
Signed-off-by: Rob Herring <r.herring@freescale.com>
Also, test that the built image boots.
- put base address and irq in platform data.
- use clk usecounts instead of ssi_active struct
- allow up to MAX_SSI_CHANNELS in hardware
The spba defaults to all masters enabled and this is fine as
all chips only have ARM and SDMA as masters.
Convert i.MX ASoC driver to use iram allocator functions.
Rename audio card to ccwmx51js to be coherent with other products.
Adding audio support for the WM8753 chip.
Resolve the line-in record problem.
When bluetooth handsfree is enabled, sgtl5000 and bt
sound cards are both opened. BT sound card playback
can't use IRAM as sgtl5000 has used IRAM. The bt audio
platform data - ext_ram is not set when kernel porting
to 2.6.31.
Signed-off-by: Wallace Wang <r59996@freescale.com>
ASRC minmal output sample rate is 32000. When ASRC
is used as ASRC-ESAI per_2_per mode, the unsupported
sample rates should not be included in ASRC mixer.
No all regiser use _SCT. stmp3xxx_setl may write to wrong address.
please use __raw_write (value, REG_XXX_SET) to write date to SCT
register. Only REG_XXX_SCT is defined when it exist at hardware.
Signed-off-by: Frank.Li <Frank.Li@freescale.com>
Add ac97 mode support for SSI module
Fix shift direction.
Don't return left channel value for both channels.
To keep system runs well after plugin headphone, replace disable_irq with
disable_irq_nosync.
Signed-off-by: Guoqing Jiang <b22156@freescale.com>
Trying to free already-free IRQ 240 causes the warning dumped out
when boot up the kernel.
Return the error code in the probe function, which indicats the
failure of the platform driver probing. Then the platform driver remove
function will not be called, avoiding of freeing an already-free IRQ again.
Signed-off-by: William Lai <b04597@freescale.com>
The ak4647_codec is not initialized as there is no ak4647 codec existing
on MX35 board. In the 31 kernel, the card and codec drivers are
registered separately, and there is no check whether the codec is probed
successfully or not. On MX35 board, the card is sucessfully registered,
but there is no ak4647 codec. In this case, the system will crash if the
system try to invoke the codec's resume function.
To resolve the problem, add a check in registering the card. If the
codec does not exist, give up registering the card either.
wm8580 is using regulators that can't change state. The
regulator driver doesn't handle this case well so it crashes
during regulator_bulk_enable. Eventually this will be fixed in the
regulator driver. For now, remove regulators from list in
wm8580 driver.
Fix spi_rw err. hw_write needs to return transferred data length.
In WM8350_FLL_CONTROL_1, keep FLL_RATE at default.
Don't mute outputs by default.
Move regulator control into codec drivers.
Move codec platform data to machine layer.
Remove unused fields from mxc_audio_platform_data.
soc multiple audio cards support:
dai_list is a list for all registered codec/cpu dais.
One codec/cpu dais can't be registered twice, so move the
cpu dai registering into imx-ssi.c/imx-esai.c
Fix ak4647_read_reg error.
Put ssi/esai mode in the cpu_dai private_data.
sgtl5000: Fix the power for MX35
1. MX35 vddio and vddd are directly connected to
external 3V3. It has no regulator control.
2. sgtl5000 needs some time to be ready after vdda
is switched on so msleep(1) is added before regiter
read/write.
3. On MX35 platform, vdda is from VCAM.
Add basic support for integration with the regulator API to WM8580.
Since the core cannot yet disable biases when the CODEC is idle we
simply request and enable the regulators for the entire time the
driver is active.
It's the 8th enum of a zero indexed array. This is why I don't let
new drivers use these arrays of enums...
Cc: stable@kernel.org
For best performance the DAC sloping stopband filter should be enabled
below 24kHz and not enabled above that so remove the user visible
control for this and do it autonomously in the driver.
Fix the audio pop issue that is caused whenever the system enters and
exits LP-APM mode.
Added some more working points for DVFS-CORE.
Signed-off-by: Ranjani Vaidyanathan-RA5478 <Ranjani.Vaidyanathan@freescale.com>
This is i.MX BSP 5.0.0 release ported to 2.6.31
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
Add spi interface support to wm8580 codec.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'fix/oxygen' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
sound: oxygen: handle cards with missing EEPROM
sound: oxygen: fix MCLK rate for 192 kHz playback
The card model detection code introduced in 2.6.30 that tries to work
around partially broken EEPROM contents by reading the EEPROM directly
does not handle cards where the EEPROM has been omitted. In this case,
we have to use the default ID to allow the driver to load.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Reported-and-tested-by: Ozan Çağlayan <ozan@pardus.org.tr>
Cc: <stable@kernel.org>
Do not forget to program the MCLK ratio for the I2S output.
Otherwise, the master clock frequency can be too high for
the DACs at sample frequencies above 96 kHz.
* 'fix/hda' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda - Fix MacBookPro 3,1/4,1 quirk with ALC889A
ALSA: hda - Add missing mux check for VT1708
This patch fixes the wrong headphone output routing for MacBookPro 3,1/4,1
quirk with ALC889A codec, which caused the silent headphone output.
Also, this gives the individual Headphone and Speaker volume controls.
Reference: kernel bug#14078
http://bugzilla.kernel.org/show_bug.cgi?id=14078
In patch_vt1708(), the check of MUX nids is missing and this results in
the -EINVAL error in accessing Input Source mixer element. Simpliy
adding the call of get_mux_nids() fixes the problem.
Reference: Novell bnc#534904
https://bugzilla.novell.com/show_bug.cgi?id=534904
* 'fix/misc' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
sound: pcm_lib: fix unsorted list constraint handling
sound: vx222: fix input level control range check
ALSA: ali5451: fix timeout handling in snd_ali_{codecs,timer}_ready()
snd_interval_list() expected a sorted list but did not document this, so
there are drivers that give it an unsorted list. To fix this, change
the algorithm to work with any list.
This fixes the "Slave PCM not usable" error with USB devices that have
multiple alternate settings with sample rates in decreasing order, such
as the Philips Askey VC010 WebCam.
http://bugzilla.kernel.org/show_bug.cgi?id=14028
Reported-and-tested-by: Andrzej <adkadk@gmail.com>
