path: root/sound
2018-06-06ASoC: Intel: sst: remove redundant variable dma_dev_nameColin Ian King
commit 271ef65b5882425d500e969e875c98e47a6b0c86 upstream. The pointer dma_dev_name is assigned but never read, it is redundant and can therefore be removed. Cleans up clang warning: sound/soc/intel/common/sst-firmware.c:288:3: warning: Value stored to 'dma_dev_name' is never read Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Pierre-Louis Bossart <pierre-louis.bossart@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30ASoC: samsung: i2s: Ensure the RCLK rate is properly determinedSylwester Nawrocki
[ Upstream commit 647d04f8e07afc7c3b7a42b3ee01a8b28db29631 ] If the RCLK mux clock configuration is specified in DT and no set_sysclk() callback is used in the sound card driver the sclk_srcrate field will remain set to 0, leading to an incorrect PSR divider setting. To fix this the frequency value is retrieved from the CLK_I2S_RCLK_SRC clock, so the actual RCLK mux selection is taken into account. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Krzysztof Kozlowski <krzk@kernel.org> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30ALSA: vmaster: Propagate slave errorTakashi Iwai
[ Upstream commit 2e2c177ca84aff092c3c96714b0f6a12900f3946 ] In slave_update() of vmaster code ignores the error from the slave get() callback and copies the values. It's not only about the missing error code but also that this may potentially lead to a leak of uninitialized variables when the slave get() don't clear them. This patch fixes slave_update() not to copy the potentially uninitialized values when an error is returned from the slave get() callback, and to propagate the error value properly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30ASoC: topology: create TLV data for dapm widgetsRanjani Sridharan
[ Upstream commit bde8b3887add8368ecf0ca71117baf2fd56a6fc9 ] This patch adds the change required to create the TLV data for dapm widget kcontrols from topology. This also fixes the following TLV read error shown in amixer while showing the card control contents. "amixer: Control hw:1 element TLV read error: No such device or address" Signed-off-by: Ranjani Sridharan <ranjani.sridharan@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30ASoC: au1x: Fix timeout tests in au1xac97c_ac97_read()Dan Carpenter
[ Upstream commit 123af9043e93cb6f235207d260d50f832cdb5439 ] The loop timeout doesn't work because it's a post op and ends with "tmo" set to -1. I changed it from a post-op to a pre-op and I changed the initial the starting value from 5 to 6 so we still iterate 5 times. I left the other as it was because it's a large number. Fixes: b3c70c9ea62a ("ASoC: Alchemy AC97C/I2SC audio support") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30ALSA: hda - Use IS_REACHABLE() for dependency on inputTakashi Iwai
[ Upstream commit c469652bb5e8fb715db7d152f46d33b3740c9b87 ] The commit ffcd28d88e4f ("ALSA: hda - Select INPUT for Realtek HD-audio codec") introduced the reverse-selection of CONFIG_INPUT for Realtek codec in order to avoid the mess with dependency between built-in and modules. Later on, we obtained IS_REACHABLE() macro exactly for this kind of problems, and now we can remove th INPUT selection in Kconfig and put IS_REACHABLE(INPUT) to the appropriate places in the code, so that the driver doesn't need to select other subsystem forcibly. Fixes: ffcd28d88e4f ("ALSA: hda - Select INPUT for Realtek HD-audio codec") Reported-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Randy Dunlap <rdunlap@infradead.org> # and build-tested Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30ALSA: timer: Fix pause event notificationBen Hutchings
commit 3ae180972564846e6d794e3615e1ab0a1e6c4ef9 upstream. Commit f65e0d299807 ("ALSA: timer: Call notifier in the same spinlock") combined the start/continue and stop/pause functions, and in doing so changed the event code for the pause case to SNDRV_TIMER_EVENT_CONTINUE. Change it back to SNDRV_TIMER_EVENT_PAUSE. Fixes: f65e0d299807 ("ALSA: timer: Call notifier in the same spinlock") Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Cc: stable@vger.kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-26ALSA: control: fix a redundant-copy issueWenwen Wang
commit 3f12888dfae2a48741c4caa9214885b3aaf350f9 upstream. In snd_ctl_elem_add_compat(), the fields of the struct 'data' need to be copied from the corresponding fields of the struct 'data32' in userspace. This is achieved by invoking copy_from_user() and get_user() functions. The problem here is that the 'type' field is copied twice. One is by copy_from_user() and one is by get_user(). Given that the 'type' field is not used between the two copies, the second copy is *completely* redundant and should be removed for better performance and cleanup. Also, these two copies can cause inconsistent data: as the struct 'data32' resides in userspace and a malicious userspace process can race to change the 'type' field between the two copies to cause inconsistent data. Depending on how the data is used in the future, such an inconsistency may cause potential security risks. For above reasons, we should take out the second copy. Signed-off-by: Wenwen Wang <wang6495@umn.edu> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-26ALSA: hda: Add Lenovo C50 All in one to the power_save blacklistHans de Goede
commit c8beccc19b92f5172994c0732db689c08f4f98e5 upstream. Power-saving is causing loud plops on the Lenovo C50 All in one, add it to the blacklist. BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1572975 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-26ALSA: usb: mixer: volume quirk for CM102-A+/102S+Federico Cuello
commit 21493316a3c4598f308d5a9fa31cc74639c4caff upstream. Currently it's not possible to set volume lower than 26% (it just mutes). Also fixes this warning: Warning! Unlikely big volume range (=9472), cval->res is probably wrong. [13] FU [PCM Playback Volume] ch = 2, val = -9473/-1/1 , and volume works fine for full range. Signed-off-by: Federico Cuello <fedux@fedux.com.ar> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-26ALSA: timer: Call notifier in the same spinlockTakashi Iwai
commit f65e0d299807d8a11812845c972493c3f9a18e10 upstream. snd_timer_notify1() is called outside the spinlock and it retakes the lock after the unlock. This is rather racy, and it's safer to move snd_timer_notify() call inside the main spinlock. The patch also contains a slight refactoring / cleanup of the code. Now all start/stop/continue/pause look more symmetric and a bit better readable. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-16ALSA: aloop: Add missing cable lock to ctl API callbacksTakashi Iwai
commit 76b3421b39bd610546931fc923edcf90c18fa395 upstream. Some control API callbacks in aloop driver are too lazy to take the loopback->cable_lock and it results in possible races of cable access while it's being freed. It eventually lead to a UAF, as reported by fuzzer recently. This patch covers such control API callbacks and add the proper mutex locks. Reported-by: DaeRyong Jeong <threeearcat@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-16ALSA: aloop: Mark paused device as inactiveRobert Rosengren
commit 306a4f3ca7f3c7dfa473ebd19d66e40e59d99734 upstream. Show paused ALSA aloop device as inactive, i.e. the control "PCM Slave Active" set as false. Notification sent upon state change. This makes it possible for client capturing from aloop device to know if data is expected. Without it the client expects data even if playback is paused. Signed-off-by: Robert Rosengren <robert.rosengren@axis.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-16ALSA: seq: Fix races at MIDI encoding in snd_virmidi_output_trigger()Takashi Iwai
commit 8f22e52528cc372b218b5f100457469615c733ce upstream. The sequencer virmidi code has an open race at its output trigger callback: namely, virmidi keeps only one event packet for processing while it doesn't protect for concurrent output trigger calls. snd_virmidi_output_trigger() tries to process the previously unfinished event before starting encoding the given MIDI stream, but this is done without any lock. Meanwhile, if another rawmidi stream starts the output trigger, this proceeds further, and overwrites the event package that is being processed in another thread. This eventually corrupts and may lead to the invalid memory access if the event type is like SYSEX. The fix is just to move the spinlock to cover both the pending event and the new stream. The bug was spotted by a new fuzzer, RaceFuzzer. BugLink: http://lkml.kernel.org/r/20180426045223.GA15307@dragonet.kaist.ac.kr Reported-by: DaeRyong Jeong <threeearcat@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-16ALSA: pcm: Check PCM state at xfern compat ioctlTakashi Iwai
commit f13876e2c33a657a71bcbb10f767c0951b165020 upstream. Since snd_pcm_ioctl_xfern_compat() has no PCM state check, it may go further and hit the sanity check pcm_sanity_check() when the ioctl is called right after open. It may eventually spew a kernel warning, as triggered by syzbot, depending on kconfig. The lack of PCM state check there was just an oversight. Although it's no real crash, the spurious kernel warning is annoying, so let's add the proper check. Reported-by: syzbot+1dac3a4f6bc9c1c675d4@syzkaller.appspotmail.com Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ASoC: fsl_esai: Fix divisor calculation failure at lower ratioNicolin Chen
commit c656941df9bc80f7ec65b92ca73c42f8b0b62628 upstream. When the desired ratio is less than 256, the savesub (tolerance) in the calculation would become 0. This will then fail the loop- search immediately without reporting any errors. But if the ratio is smaller enough, there is no need to calculate the tolerance because PM divisor alone is enough to get the ratio. So a simple fix could be just to set PM directly instead of going into the loop-search. Reported-by: Marek Vasut <marex@denx.de> Signed-off-by: Nicolin Chen <nicoleotsuka@gmail.com> Tested-by: Marek Vasut <marex@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ALSA: hda/realtek - Add some fixes for ALC233Kailang Yang
commit ea04a1dbf8b1d6af759d58e705636fde48583f8f upstream. Fill COEF to change EAPD to verb control. Assigned codec type. This is an additional fix over 92f974df3460 ("ALSA: hda/realtek - New vendor ID for ALC233"). [ More notes: according to Kailang, the chip is 10ec:0235 bonding for ALC233b, which is equivalent with ALC255. It's only used for Lenovo. The chip needs no alc_process_coef_fw() for headset unlike ALC255. ] Signed-off-by: Kailang Yang <kailang@realtek.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ALSA: hda: Hardening for potential Spectre v1Takashi Iwai
commit 69fa6f19b95597618ab30438a27b67ad93daa7c7 upstream. As recently Smatch suggested, one place in HD-audio hwdep ioctl codes may expand the array directly from the user-space value with speculation: sound/pci/hda/hda_local.h:467 get_wcaps() warn: potential spectre issue 'codec->wcaps' As get_wcaps() itself is a fairly frequently called inline function, and there is only one single call with a user-space value, we replace only the latter one to open-code locally with array_index_nospec() hardening in this patch. BugLink: https://marc.info/?l=linux-kernel&m=152411496503418&w=2 Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ALSA: seq: oss: Hardening for potential Spectre v1Takashi Iwai
commit 8d218dd8116695ecda7164f97631c069938aa22e upstream. As Smatch recently suggested, a few places in OSS sequencer codes may expand the array directly from the user-space value with speculation, namely there are a significant amount of references to either info->ch[] or dp->synths[] array: sound/core/seq/oss/seq_oss_event.c:315 note_on_event() warn: potential spectre issue 'info->ch' (local cap) sound/core/seq/oss/seq_oss_event.c:362 note_off_event() warn: potential spectre issue 'info->ch' (local cap) sound/core/seq/oss/seq_oss_synth.c:470 snd_seq_oss_synth_load_patch() warn: potential spectre issue 'dp->synths' (local cap) sound/core/seq/oss/seq_oss_event.c:293 note_on_event() warn: potential spectre issue 'dp->synths' sound/core/seq/oss/seq_oss_event.c:353 note_off_event() warn: potential spectre issue 'dp->synths' sound/core/seq/oss/seq_oss_synth.c:506 snd_seq_oss_synth_sysex() warn: potential spectre issue 'dp->synths' sound/core/seq/oss/seq_oss_synth.c:580 snd_seq_oss_synth_ioctl() warn: potential spectre issue 'dp->synths' Although all these seem doing only the first load without further reference, we may want to stay in a safer side, so hardening with array_index_nospec() would still make sense. We may put array_index_nospec() at each place, but here we take a different approach: - For dp->synths[], change the helpers to retrieve seq_oss_synthinfo pointer directly instead of the array expansion at each place - For info->ch[], harden in a normal way, as there are only a couple of places As a result, the existing helper, snd_seq_oss_synth_is_valid() is replaced with snd_seq_oss_synth_info(). Also, we cover MIDI device where a similar array expansion is done, too, although it wasn't reported by Smatch. BugLink: https://marc.info/?l=linux-kernel&m=152411496503418&w=2 Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ALSA: seq: oss: Fix unbalanced use lock for synth MIDI deviceTakashi Iwai
commit f5e94b4c6ebdabe0f602d796e0430180927521a0 upstream. When get_synthdev() is called for a MIDI device, it returns the fixed midi_synth_dev without the use refcounting. OTOH, the caller is supposed to unreference unconditionally after the usage, so this would lead to unbalanced refcount. This patch corrects the behavior and keep up the refcount balance also for the MIDI synth device. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ALSA: core: Report audio_tstamp in snd_pcm_sync_ptrDavid Henningsson
commit f853dcaae2f5bbe021161e421bd1576845bae8f6 upstream. It looks like a simple mistake that this struct member was forgotten. Audio_tstamp isn't used much, and on some archs (such as x86) this ioctl is not used by default, so that might be the reason why this has slipped for so long. Fixes: 4eeaaeaea1ce ("ALSA: core: add hooks for audio timestamps") Signed-off-by: David Henningsson <diwic@ubuntu.com> Reviewed-by: Takashi Sakamoto <o-takashi@sakamocchi.jp> Cc: <stable@vger.kernel.org> # v3.8+ Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ALSA: rme9652: Hardening for potential Spectre v1Takashi Iwai
commit f526afcd8f71945c23ce581d7864ace93de8a4f7 upstream. As recently Smatch suggested, one place in RME9652 driver may expand the array directly from the user-space value with speculation: sound/pci/rme9652/rme9652.c:2074 snd_rme9652_channel_info() warn: potential spectre issue 'rme9652->channel_map' (local cap) This patch puts array_index_nospec() for hardening against it. BugLink: https://marc.info/?l=linux-kernel&m=152411496503418&w=2 Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ALSA: hdspm: Hardening for potential Spectre v1Takashi Iwai
commit 10513142a7114d251670361ad40cba2c61403406 upstream. As recently Smatch suggested, a couple of places in HDSP MADI driver may expand the array directly from the user-space value with speculation: sound/pci/rme9652/hdspm.c:5717 snd_hdspm_channel_info() warn: potential spectre issue 'hdspm->channel_map_out' (local cap) sound/pci/rme9652/hdspm.c:5734 snd_hdspm_channel_info() warn: potential spectre issue 'hdspm->channel_map_in' (local cap) This patch puts array_index_nospec() for hardening against them. BugLink: https://marc.info/?l=linux-kernel&m=152411496503418&w=2 Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ALSA: asihpi: Hardening for potential Spectre v1Takashi Iwai
commit f9d94b57e30fd1575b4935045b32d738668aa74b upstream. As recently Smatch suggested, a couple of places in ASIHPI driver may expand the array directly from the user-space value with speculation: sound/pci/asihpi/hpimsginit.c:70 hpi_init_response() warn: potential spectre issue 'res_size' (local cap) sound/pci/asihpi/hpioctl.c:189 asihpi_hpi_ioctl() warn: potential spectre issue 'adapters' This patch puts array_index_nospec() for hardening against them. BugLink: https://marc.info/?l=linux-kernel&m=152411496503418&w=2 Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ALSA: opl3: Hardening for potential Spectre v1Takashi Iwai
commit 7f054a5bee0987f1e2d4e59daea462421c76f2cb upstream. As recently Smatch suggested, one place in OPL3 driver may expand the array directly from the user-space value with speculation: sound/drivers/opl3/opl3_synth.c:476 snd_opl3_set_voice() warn: potential spectre issue 'snd_opl3_regmap' This patch puts array_index_nospec() for hardening against it. BugLink: https://marc.info/?l=linux-kernel&m=152411496503418&w=2 Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-02ALSA: usb-audio: Skip broken EU on Dell dock USB-audioTakashi Iwai
commit 1d8d6428d1da642ddd75b0be2d1bb1123ff8e017 upstream. The Dell Dock USB-audio device with 0bda:4014 is behaving notoriously bad, and we have already applied some workaround to avoid the firmware hiccup. Yet we still need to skip one thing, the Extension Unit at ID 4, which doesn't react correctly to the mixer ctl access. Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=1090658 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ALSA: hda - New VIA controller suppor no-snoop pathDavid Wang
commit af52f9982e410edac21ca4b49563053ffc9da1eb upstream. This patch is used to tell kernel that new VIA HDAC controller also support no-snoop path. [ minor coding style fix by tiwai ] Signed-off-by: David Wang <davidwang@zhaoxin.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ALSA: rawmidi: Fix missing input substream checks in compat ioctlsTakashi Iwai
commit 8a56ef4f3ffba9ebf4967b61ef600b0a7ba10f11 upstream. Some rawmidi compat ioctls lack of the input substream checks (although they do check only for rfile->output). This many eventually lead to an Oops as NULL substream is passed to the rawmidi core functions. Fix it by adding the proper checks before each function call. The bug was spotted by syzkaller. Reported-by: syzbot+f7a0348affc3b67bc617@syzkaller.appspotmail.com Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ALSA: line6: Use correct endpoint type for midi outputFabián Inostroza
commit 7ecb46e9ee9af18e304eb9e7d6804c59a408e846 upstream. Sending MIDI messages to a PODxt through the USB connection shows "usb_submit_urb failed" in dmesg and the message is not received by the POD. The error is caused because in the funcion send_midi_async() in midi.c there is a call to usb_sndbulkpipe() for endpoint 3 OUT, but the PODxt USB descriptor shows that this endpoint it's an interrupt endpoint. Patch tested with PODxt only. [ The bug has been present from the very beginning in the staging driver time, but Fixes below points to the commit moving to sound/ directory so that the fix can be cleanly applied -- tiwai ] Fixes: 61864d844c29 ("ALSA: move line6 usb driver into sound/usb") Signed-off-by: Fabián Inostroza <fabianinostroza@udec.cl> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ALSA: pcm: Fix endless loop for XRUN recovery in OSS emulationTakashi Iwai
commit e15dc99dbb9cf99f6432e8e3c0b3a8f7a3403a86 upstream. The commit 02a5d6925cd3 ("ALSA: pcm: Avoid potential races between OSS ioctls and read/write") split the PCM preparation code to a locked version, and it added a sanity check of runtime->oss.prepare flag along with the change. This leaded to an endless loop when the stream gets XRUN: namely, snd_pcm_oss_write3() and co call snd_pcm_oss_prepare() without setting runtime->oss.prepare flag and the loop continues until the PCM state reaches to another one. As the function is supposed to execute the preparation unconditionally, drop the invalid state check there. The bug was triggered by syzkaller. Fixes: 02a5d6925cd3 ("ALSA: pcm: Avoid potential races between OSS ioctls and read/write") Reported-by: syzbot+150189c103427d31a053@syzkaller.appspotmail.com Reported-by: syzbot+7e3f31a52646f939c052@syzkaller.appspotmail.com Reported-by: syzbot+4f2016cf5185da7759dc@syzkaller.appspotmail.com Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ALSA: pcm: Fix mutex unbalance in OSS emulation ioctlsTakashi Iwai
commit f6d297df4dd47ef949540e4a201230d0c5308325 upstream. The previous fix 40cab6e88cb0 ("ALSA: pcm: Return -EBUSY for OSS ioctls changing busy streams") introduced some mutex unbalance; the check of runtime->oss.rw_ref was inserted in a wrong place after the mutex lock. This patch fixes the inconsistency by rewriting with the helper functions to lock/unlock parameters with the stream check. Fixes: 40cab6e88cb0 ("ALSA: pcm: Return -EBUSY for OSS ioctls changing busy streams") Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ALSA: pcm: Return -EBUSY for OSS ioctls changing busy streamsTakashi Iwai
commit 40cab6e88cb0b6c56d3f30b7491a20e803f948f6 upstream. OSS PCM stream management isn't modal but it allows ioctls issued at any time for changing the parameters. In the previous hardening patch ("ALSA: pcm: Avoid potential races between OSS ioctls and read/write"), we covered these races and prevent the corruption by protecting the concurrent accesses via params_lock mutex. However, this means that some ioctls that try to change the stream parameter (e.g. channels or format) would be blocked until the read/write finishes, and it may take really long. Basically changing the parameter while reading/writing is an invalid operation, hence it's even more user-friendly from the API POV if it returns -EBUSY in such a situation. This patch adds such checks in the relevant ioctls with the addition of read/write access refcount. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ALSA: pcm: Avoid potential races between OSS ioctls and read/writeTakashi Iwai
commit 02a5d6925cd34c3b774bdb8eefb057c40a30e870 upstream. Although we apply the params_lock mutex to the whole read and write operations as well as snd_pcm_oss_change_params(), we may still face some races. First off, the params_lock is taken inside the read and write loop. This is intentional for avoiding the too long locking, but it allows the in-between parameter change, which might lead to invalid pointers. We check the readiness of the stream and set up via snd_pcm_oss_make_ready() at the beginning of read and write, but it's called only once, by assuming that it remains ready in the rest. Second, many ioctls that may change the actual parameters (i.e. setting runtime->oss.params=1) aren't protected, hence they can be processed in a half-baked state. This patch is an attempt to plug these holes. The stream readiness check is moved inside the read/write inner loop, so that the stream is always set up in a proper state before further processing. Also, each ioctl that may change the parameter is wrapped with the params_lock for avoiding the races. The issues were triggered by syzkaller in a few different scenarios, particularly the one below appearing as GPF in loopback_pos_update. Reported-by: syzbot+c4227aec125487ec3efa@syzkaller.appspotmail.com Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ALSA: pcm: Use ERESTARTSYS instead of EINTR in OSS emulationTakashi Iwai
commit c64ed5dd9feba193c76eb460b451225ac2a0d87b upstream. Fix the last standing EINTR in the whole subsystem. Use more correct ERESTARTSYS for pending signals. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ALSA: oss: consolidate kmalloc/memset 0 call to kzallocNicholas Mc Guire
commit 46325371b230cc66c743925c930a17e7d0b8211e upstream. This is an API consolidation only. The use of kmalloc + memset to 0 is equivalent to kzalloc. Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ALSA: pcm: Fix UAF at PCM release via PCM timer accessTakashi Iwai
commit a820ccbe21e8ce8e86c39cd1d3bc8c7d1cbb949b upstream. The PCM runtime object is created and freed dynamically at PCM stream open / close time. This is tracked via substream->runtime, and it's cleared at snd_pcm_detach_substream(). The runtime object assignment is protected by PCM open_mutex, so for all PCM operations, it's safely handled. However, each PCM substream provides also an ALSA timer interface, and user-space can access to this while closing a PCM substream. This may eventually lead to a UAF, as snd_pcm_timer_resolution() tries to access the runtime while clearing it in other side. Fortunately, it's the only concurrent access from the PCM timer, and it merely reads runtime->timer_resolution field. So, we can avoid the race by reordering kfree() and wrapping the substream->runtime clearance with the corresponding timer lock. Reported-by: syzbot+8e62ff4e07aa2ce87826@syzkaller.appspotmail.com Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24ASoC: ssm2602: Replace reg_default_raw with reg_defaultJames Kelly
commit a01df75ce737951ad13a08d101306e88c3f57cb2 upstream. SSM2602 driver is broken on recent kernels (at least since 4.9). User space applications such as amixer or alsamixer get EIO when attempting to access codec controls via the relevant IOCTLs. Root cause of these failures is the regcache_hw_init function in drivers/base/regmap/regcache.c, which prevents regmap cache initalization from the reg_defaults_raw element of the regmap_config structure when registers are write only. It also disables the regmap cache entirely when all registers are write only or volatile as is the case for the SSM2602 driver. Using the reg_defaults element of the regmap_config structure rather than the reg_defaults_raw element to initalize the regmap cache avoids the logic in the regcache_hw_init function entirely. It also makes this driver consistent with other ASoC codec drivers, as this driver was the ONLY codec driver that used the reg_defaults_raw element to initalize the cache. Tested on Digilent Zybo Z7 development board which has a SSM2603 codec chip connected to a Xilinx Zynq SoC. Signed-off-by: James Kelly <jamespeterkelly@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-13ASoC: Intel: sst: Fix the return value of 'sst_send_byte_stream_mrfld()'Christophe JAILLET
[ Upstream commit eaadb1caa966a91128297b754e90b7c92b350a00 ] In some error handling paths, an error code is assiegned to 'ret'. However, the function always return 0. Fix it and return the error code if such an error paths is taken. Fixes: 3d9ff34622ba ("ASoC: Intel: sst: add stream operations") Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-13ASoC: Intel: cht_bsw_rt5645: Analog Mic supportHans de Goede
[ Upstream commit b70b309950418437bbd2a30afd169c4f09dee3e5 ] Various Cherry Trail boards with a rt5645 codec have an analog mic connected to IN2P + IN2N. The mic on this boards also needs micbias to be enabled, on some boards micbias1 is used and on others micbias2, so we enable both. This commit adds a new "Int Analog Mic" DAPM widget for this, so that we do not end up enabling micbias on boards with a digital mic which uses the already present "Int Mic" widget. Some existing UCM files already refer to "Int Mic" for their "Internal Analog Microphones" SectionDevice, but these don't work anyways since they enable the RECMIX BST1 Switch instead of the BST2 switch. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-13ASoC: rsnd: SSI PIO adjust to 24bit modeKuninori Morimoto
[ Upstream commit 7819a942de7b993771bd9377babc80485fe7606b ] commit 90431eb49bff ("ASoC: rsnd: don't use PDTA bit for 24bit on SSI") fixups 24bit mode data alignment, but PIO was not cared. This patch fixes PIO mode 24bit data alignment Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08ALSA: pcm: potential uninitialized return valuesDan Carpenter
commit 5607dddbfca774fb38bffadcb077fe03aa4ac5c6 upstream. Smatch complains that "tmp" can be uninitialized if we do a zero size write. Fixes: 02a5d6925cd3 ("ALSA: pcm: Avoid potential races between OSS ioctls and read/write") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-08ALSA: pcm: Use dma_bytes as size parameter in dma_mmap_coherent()Stefan Roese
commit 9066ae7ff5d89c0b5daa271e2d573540097a94fa upstream. When trying to use the driver (e.g. aplay *.wav), the 4MiB DMA buffer will get mmapp'ed in 16KiB chunks. But this fails with the 2nd 16KiB area, as the page offset is outside of the VMA range (size), which is currently used as size parameter in snd_pcm_lib_default_mmap(). By using the DMA buffer size (dma_bytes) instead, the complete DMA buffer can be mmapp'ed and the issue is fixed. This issue was detected on an ARM platform (TI AM57xx) using the RME HDSP MADI PCIe soundcard. Fixes: 657b1989dacf ("ALSA: pcm - Use dma_mmap_coherent() if available") Signed-off-by: Stefan Roese <sr@denx.de> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-28ALSA: hda/realtek - Always immediately update mute LED with pin VREFTakashi Iwai
commit e40bdb03d3cd7da66bd0bc1e40cbcfb49351265c upstream. Some HP laptops have a mute mute LED controlled by a pin VREF. The Realtek codec driver updates the VREF via vmaster hook by calling snd_hda_set_pin_ctl_cache(). This works fine as long as the driver is running in a normal mode. However, when the VREF change happens during the codec being in runtime PM suspend, the regmap access will skip and postpone the actual register change. This ends up with the unchanged LED status until the next runtime PM resume even if you change the Master mute switch. (Interestingly, the machine keeps the LED status even after the codec goes into D3 -- but it's another story.) For improving this usability, let the driver temporarily powering up / down only during the pin VREF change. This can be achieved easily by wrapping the call with snd_hda_power_up_pm() / *_down_pm(). Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=199073 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-28ALSA: aloop: Fix access to not-yet-ready substream via cableTakashi Iwai
commit 8e6b1a72a75bb5067ccb6b56d8ca4aa3a300a64e upstream. In loopback_open() and loopback_close(), we assign and release the substream object to the corresponding cable in a racy way. It's neither locked nor done in the right position. The open callback assigns the substream before its preparation finishes, hence the other side of the cable may pick it up, which may lead to the invalid memory access. This patch addresses these: move the assignment to the end of the open callback, and wrap with cable->lock for avoiding concurrent accesses. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-28ALSA: aloop: Sync stale timer before releaseTakashi Iwai
commit 67a01afaf3d34893cf7d2ea19b34555d6abb7cb0 upstream. The aloop driver tries to stop the pending timer via timer_del() in the trigger callback and in the close callback. The former is correct, as it's an atomic operation, while the latter expects that the timer gets really removed and proceeds the resource releases after that. But timer_del() doesn't synchronize, hence the running timer may still access the released resources. A similar situation can be also seen in the prepare callback after trigger(STOP) where the prepare tries to re-initialize the things while a timer is still running. The problems like the above are seen indirectly in some syzkaller reports (although it's not 100% clear whether this is the only cause, as the race condition is quite narrow and not always easy to trigger). For addressing these issues, this patch adds the explicit alls of timer_del_sync() in some places, so that the pending timer is properly killed / synced. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-24ASoC: Intel: Skylake: Uninitialized variable in probe_codec()Dan Carpenter
[ Upstream commit e6a33532affd14c12688c0e9b2e773e8b2550f3b ] My static checker complains that if snd_hdac_bus_get_response() returns -EIO then "res" is uninitialized. Fix this by initializing it to -1 so that the error is handled correctly. Fixes: d8c2dab8381d ("ASoC: Intel: Add Skylake HDA audio driver") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-24ALSA: hda - Fix headset microphone detection for ASUS N551 and N751Mikhail Paulyshka
[ Upstream commit fc7438b1eb12b6c93d7b7a62423779eb5dfc673c ] Headset microphone does not work out of the box on ASUS Nx51 laptops. This patch fixes it. Patch tested on Asus N551 laptop. Asus N751 part is not tested, but according to [1] this laptop uses the same audiosystem. 1. https://bugzilla.kernel.org/show_bug.cgi?id=117781 Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=195437 Signed-off-by: Mikhail Paulyshka <me@mixaill.tk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-22ALSA: seq: Clear client entry before deleting else at closingTakashi Iwai
commit a2ff19f7b70118ced291a28d5313469914de451b upstream. When releasing a client, we need to clear the clienttab[] entry at first, then call snd_seq_queue_client_leave(). Otherwise, the in-flight cell in the queue might be picked up by the timer interrupt via snd_seq_check_queue() before calling snd_seq_queue_client_leave(), and it's delivered to another queue while the client is clearing queues. This may eventually result in an uncleared cell remaining in a queue, and the later snd_seq_pool_delete() may need to wait for a long time until the event gets really processed. By moving the clienttab[] clearance at the beginning of release, any event delivery of a cell belonging to this client will fail at a later point, since snd_seq_client_ptr() returns NULL. Thus the cell that was picked up by the timer interrupt will be returned immediately without further delivery, and the long stall of snd_seq_delete_pool() can be avoided, too. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-22ALSA: seq: Fix possible UAF in snd_seq_check_queue()Takashi Iwai
commit d0f833065221cbfcbadf19fd4102bcfa9330006a upstream. Although we've covered the races between concurrent write() and ioctl() in the previous patch series, there is still a possible UAF in the following scenario: A: user client closed B: timer irq -> snd_seq_release() -> snd_seq_timer_interrupt() -> snd_seq_free_client() -> snd_seq_check_queue() -> cell = snd_seq_prioq_cell_peek() -> snd_seq_prioq_leave() .... removing all cells -> snd_seq_pool_done() .... vfree() -> snd_seq_compare_tick_time(cell) ... Oops So the problem is that a cell is peeked and accessed without any protection until it's retrieved from the queue again via snd_seq_prioq_cell_out(). This patch tries to address it, also cleans up the code by a slight refactoring. snd_seq_prioq_cell_out() now receives an extra pointer argument. When it's non-NULL, the function checks the event timestamp with the given pointer. The caller needs to pass the right reference either to snd_seq_tick or snd_seq_realtime depending on the event timestamp type. A good news is that the above change allows us to remove the snd_seq_prioq_cell_peek(), too, thus the patch actually reduces the code size. Reviewed-by: Nicolai Stange <nstange@suse.de> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-22ALSA: hda - Revert power_save option default valueTakashi Iwai
commit 40088dc4e1ead7df31728c73f5b51d71da18831d upstream. With the commit 1ba8f9d30817 ("ALSA: hda: Add a power_save blacklist"), we changed the default value of power_save option to -1 for processing the power-save blacklist. Unfortunately, this seems breaking user-space applications that actually read the power_save parameter value via sysfs and judge / adjust the power-saving status. They see the value -1 as if the power-save is turned off, although the actual value is taken from CONFIG_SND_HDA_POWER_SAVE_DEFAULT and it can be a positive. So, overall, passing -1 there was no good idea. Let's partially revert it -- at least for power_save option default value is restored again to CONFIG_SND_HDA_POWER_SAVE_DEFAULT. Meanwhile, in this patch, we keep the blacklist behavior and make is adjustable via the new option, pm_blacklist. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=199073 Fixes: 1ba8f9d30817 ("ALSA: hda: Add a power_save blacklist") Acked-by: Hans de Goede <hdegoede@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
