Disable HDA related clocks when device is not connected
to HDMI. HDA clocks will be enabled from HDMI driver when
HDMI device is hot plugged.
Also register a reboot notifier so that HDA clocks can
be enabled during device reboot since HDA driver needs to
stop the azx chip during reboot.
Bug 820213
Change-Id: Ib962ac418edf25c5681f108b9a80577dc55c42af
Reviewed-on: http://git-master/r/40543
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Split Headset to Headset Out and Headset In
Use IN1L for Int mic and Headset (for WM8903)
Remove unused variables and warning
Bug 846205
Reviewed-on: http://git-master/r/30142
Tested-by: Viraj Karandikar <vkarandikar@nvidia.com>
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Manjula Gupta <magupta@nvidia.com>
Tested-by: Anssi Kalliolahti <akalliolahti@nvidia.com>
Reviewed-by: Vijay Mali <vmali@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
(cherry picked from commit 170ccc20d6227faaf196a920e7812792c305e2ff)
Change-Id: Iccf1736c4ba0d273c3c832d563374fc0afc63616
Reviewed-on: http://git-master/r/39374
This reverts commit c242bcd738fa47f833822f618eff4dbff092bde7.
Bug 820213
Bug 839572
Change-Id: I268a8c099ef75cd38b84aa31e35ab6417745cc10
Reviewed-on: http://git-master/r/40031
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
DAM rx1 is used for playback path.
DAM is added as default so for voicecall no need to teardown the
existing connection that is being used.
Needed for bug 804696
Change-Id: Iba4cec350595a32dfd71ede9e224620ebe84b1ba
Reviewed-on: http://git-master/r/38676
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Tested-by: Ravindra Lokhande <rlokhande@nvidia.com>
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Use continuous single DMA mode instead of continuous double
to reduce the number of CPU interrupts during audio playback.
bug 840372
Change-Id: Id15dac5e2b29c612f4851b6b1d2e675b79ca047c
Reviewed-on: http://git-master/r/39855
Bug 820213
Change-Id: I4e6839aab0dc5277b11c415cbb495766f72442b8
Reviewed-on: http://git-master/r/36517
Reviewed-by: Niranjan Wartikar <nwartikar@nvidia.com>
This reverts commit ba038f38e6c0edd77dc65c28324ddd18185389fb.
It caused regression in camcoder usecase.
fixes bug 835818
Change-Id: I008a27d70b4e7066ec12f7d66d9d60e66ace0447
Reviewed-on: http://git-master/r/35434
Reviewed-by: Zhijun He <zhhe@nvidia.com>
bug 804696
DAM ch1 is added to default playback and record path.
Change-Id: Iecfa01a8d55d13928ee2ae6bd490eb3d28b679c3
Reviewed-on: http://git-master/r/32479
Tested-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Reviewed-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Change-Id: Ib0662de97f4f98461f1003747340bb9e16f96ebb
Reviewed-on: http://git-master/r/34258
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Change-Id: Ie8c616482017c869cd46b8100f0428c1f92a3bcf
Reviewed-on: http://git-master/r/34238
Spdif driver resume was causing issue on resume stage.
Change-Id: I25c0d52889c4ff1b029053f744bee32023cf1a8f
Reviewed-on: http://git-master/r/32070
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Audio manager common interfaces are defined to be called from
SOC code. Audio manager will make the decision which all modules to
be controlled based on use case connection.
Correction added to the speaker amp and i2c gpio is provided for
controlling the speaker amplification. Removed the speakersetting call.
Change-Id: Id2c7f953fc78f66bee2e1d4773e03548de0ba5b4
Reviewed-on: http://git-master/r/30891
Exposed the baseband i2s port for cardhu.
Added separate audio init function.
Change-Id: I9ff38f101c5540ad6e2365ed93a8c88373164ea3
Reviewed-on: http://git-master/r/30087
Added the control code to enable/disable I2S Loopback accordingly.
Bug 725009
Change-Id: I3f172ef303dd4c6ac5bc41277e13e5405234a77e
Reviewed-on: http://git-master/r/30221
fixes bug 822278
Change-Id: I4444e3786660ab1402469543c0bc04020d4c5021
Reviewed-on: http://git-master/r/30234
Add max98088 codec driver what backported from 2.6.38 kernel.
Bug 816789
Change-Id: I5a0f6cfa0b29bd1f469ceb1e1d1d9e6634f7bed5
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/30337
added support for audio BT sco usecase. For BT sco, i2s is
programmed in pcm mode.
Change-Id: Iffcfb707cd2c025b78b82e70ba35f89d47a21263
Reviewed-on: http://git-master/r/30042
bug 820773
Fix the audio issue resulted from code merge.
Change-Id: I37999fabec7de077eac337db33eb2b01939349fc
Reviewed-on: http://git-master/r/29684
Original: http://git-master/r/28520
Change-Id: Ic6258c9a745e83595510789a6ed4c71c317ce1ba
Reviewed-on: http://git-master/r/29577
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Change-Id: I25391126c593bd4738800c03bf3a65a0aa62ba92
Change-Id: Ieaa90cf40a7a5e190b73f83b6a17f43908377af4
By changing the dma allocation API to take the client name, it is easy
to track who is allocated the DMA channels when we run out of the
DMA channels.
Original-Change-Id: I016011cfd74089fed0da1bc0f121800017ce124a
Reviewed-on: http://git-master/r/28031
Change-Id: I048bcb87f95ee6d8ad2fdce993a1758dc5071666
bug 793875
bug 818490
Merge spdif soc code from dev_hc.
Add clock and power mode calls to spdif
Fix the system suspend/resume issue caused by audio modules.
Original-Change-Id: Ie6d9c1e52596fa744dff893fd7340c1fa2f0f058
Reviewed-on: http://git-master/r/28520
Change-Id: I367a048727b5fbe1a8db70a140b6ed1d752cd3a5
Rearrange the i2s clock code so that it will be handled properly
using the audio_manager code.
Mclk code is moved to audio_manager from soc.
bug 804696
Original-Change-Id: Icf9e823154cf3b5a63426944c4864a413df82213
Reviewed-on: http://git-master/r/27255
Change-Id: I8acd9c5d5389b3d4ca574bd62a392c56fdfa35b7
Fixed suspicious sizeof() in call to snd_print_pcm_bits()
Bug 806009
Original-Change-Id: If8b0736b63a424329572e98c888f6e0ad71ea210
Reviewed-on: http://git-master/r/27479
Tested-by: Dara Ramesh <dramesh@nvidia.com>
Reviewed-by: Dara Ramesh <dramesh@nvidia.com>
Change-Id: Ic9a657c91c1b0c7f60466770aab3eb4e7b5eb53a
Increased the DMIC volume from 0db to 9db.
bug 811570
Original-Change-Id: I866d18d96f4d540c8512e9fc948600a2dd895332
Reviewed-on: http://git-master/r/26936
Change-Id: Ic2db12a9c41ea0391a3398c57eff10313c7164f6
Change-Id: I0a5f0bab3fb559158403c5bb51780cd26baa5291
Code cleanup to remove unused clock
Add the base frame to support audio manager.
Original-Change-Id: I5d241402d003370ea5f23202647d9a0a0619cfdd
Reviewed-on: http://git-master/r/26656
Change-Id: Idd960fa3942fcde79f1a1b9949b6cbe5140c4f38
Big 804696
Added the dynamic apbif channel allocation to be used among
various controller. Support added to more apbif function calls
Original-Change-Id: I5420751037eebb07e4c9a3be339ce5c72174d1be
Reviewed-on: http://git-master/r/24774
Change-Id: If38be7a842ed7684978a8853106dcadf04e6520d
Fix the gpio error happened with merge code.
Original-Change-Id: I25daf913bacdb9502f89e3838903f6206cf10402
Reviewed-on: http://git-master/r/24613
Change-Id: I885cd23c7d9673ea9285a4f34b09f35b8f265b47
adding support for suspend resume in hda driver
Bug 808190
Bug 808132
Original-Change-Id: I6f142312cffb990ce5dd724b93ecacfc9543e8ae
Reviewed-on: http://git-master/r/24617
Change-Id: Ibefd60e840c1bc7e3f646143434f071401f0b15d
Enabling the code to set the fifo attention level
based on buffersize.
Original-Change-Id: Iceac2add8f19e1dff014e0c0955f3a84cb98810b
Reviewed-on: http://git-master/r/22903
Change-Id: I977c28c6837d7c209d358f509ac335f9c776ec7c
Dynamically set audio sample rate and source selection to
hdmi from hda driver.
Original-Change-Id: I982137560d7d506d9f1cc680f7c39ee89112eb0f
Reviewed-on: http://git-master/r/22817
Change-Id: I0505fc4c5b994d72f463bfe63dd7f49bad321ff0
Adding the infrastructure to set the fifo attention
level based on the buffersize as the dma code is
using the same for setting the dma burst size.
Original-Change-Id: I54bf673d032ebf6edd534fb6a2e946db0db07402
Reviewed-on: http://git-master/r/22897
Change-Id: I3172582aa60978f4320e274fa9c9f9e765b0d947
Bug 796487
Remove the side tone for Digital Mic and it introduced sharp
tones in the background.
Original-Change-Id: I0819dcde53d83a427df64cf1bb0cc78c81d1da35
Reviewed-on: http://git-master/r/22873
Change-Id: I12dbabd2d32aff353fd6831323f91cf3ef4b3a06
Macros are added to support multiple dais in the code
Original-Change-Id: I2cf39faec57af5dd0170311773f77b1fa4f984d4
Reviewed-on: http://git-master/r/22465
Change-Id: I4e04ef5bfe9ace31445ebaa94efa4aab02fd74cd
Changes specific to separate the codecs based on board are
integrated from rel-2010-11 branch
Original-Change-Id: I9fe2e05d5347f02cd3047f453d03437b735e2c4b
Reviewed-on: http://git-master/r/21562
Tested-by: Scott Peterson <speterson@nvidia.com>
Change-Id: I06473d906c1043a8fcc511cd66cfb57e311afdae
Integrate the changes from main branch and latest code from alsa.
Original-Change-Id: Ifcfd19bfaa3897a0faed28b0b5357792b0b21a9f
Reviewed-on: http://git-master/r/21192
Change-Id: Ibc1bb27032e92da651ec356d6391d0ee0204c881
Added the support to do jack detection through gpio.
Original-Change-Id: I324234e5c87a7d3f660a1e33f5d4ddbb287f62e1
Reviewed-on: http://git-master/r/20605
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Change-Id: Ie579d2dfad980fe417e1a03564228ea4ae7d5e80
Setting the Digital mic as default source for recording.
Original-Change-Id: I92037183731cc53fbc7e05b97ca4266c20740571
Reviewed-on: http://git-master/r/18827
Change-Id: Ic37b122948c376b3949965b42ee56429f5221385
Removed the direct pmc register write, using clk_out_1 for pmc
Moved the apbif/ahub clock to audio_switch code.
Original-Change-Id: I1ee2b7d84dbf5707894834928d0fdc4ff8bc3b96
Reviewed-on: http://git-master/r/18369
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Change-Id: I8b55a30db47f2a5b18a5eecadf2d19f4eb7b1a44
Adding nvhdmi codec driver support for tegra
Original-Change-Id: If4a71b74850c8684b62f059d24c28dd2f433789a
Reviewed-on: http://git-master/r/18187
Change-Id: I27b51b0c88c2e173f42798a39d8c6eb8bbae89de
Adding HDA audio driver support for tegra
Original-Change-Id: I484177b4c8464d7e0084f60a2c51caa388ecae98
Reviewed-on: http://git-master/r/17871
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Change-Id: I737871669443db731987675f5cb89c377b272f2f
Add driver support to ahub, dam & i2s
Original-Change-Id: I7281f787f1dd747c780a2dd55e53412a229ed6c0
Reviewed-on: http://git-master/r/15902
Change-Id: I146604556290f3f72f7efc95f32541d667fb0d00
Adding HDA audio driver support for Tegra3
Original-Change-Id: I81a76a54f6ce5390051d96dbeadf447682f9ff0e
Reviewed-on: http://git-master/r/15405
Change-Id: I8525ef7317606b895818e73ec92ca174dddf609e
Bug 764354
Original-Change-Id: I807433ff825bed1fe91ce0cf50a2b3691c64ef0a
Reviewed-on: http://git-master/r/12227
Tested-by: Scott Williams <scwilliams@nvidia.com>
Change-Id: I3da91a438f98f2f51618446ce024f3fefd726a19
bug 816348
Change-Id: I6551a867fdfcddc6689d6fcc1daaee11d8879e7f
Reviewed-on: http://git-master/r/28182
Removes the Sidetone enable code, sidetone should
not be enabled for normal capture.
For Bug: 808731
Change-Id: I7159c023624c9d3f759cf52510e8a48551454db1
Reviewed-on: http://git-master/r/28013
Tested-by: Manjula Gupta <magupta@nvidia.com>
This change mainly takes care of following things:
1) Codec_dai code will use dap apis to query the board specific dap
tables to find the codec configuration needed for a particular
routing and will configure codec accordingly. So long we were
configuring codec hardcodedly.
2) Moved all codec and board specific routing codes to codec specific
files from tegra_soc_controls.c.
3) Modifying the codec routing logic to make it simpler and robust.
4) Except DAP Mclk we will turn off all other audio related clocks
when not in use.
5) I2s and SPDIF bit clock frequencies will be dynamically calculated
based on the stream properties.
6) DAS power management and DAP MCLK related codes are moved to codec
dai since they are more closely related to codec than i2s.
Change-Id: I531558bec108af5828c8ff2ed932f4d25e00afdb
Reviewed-on: http://git-master/r/24683
Adding code to scan headphone and mix gpios during alsa init to check
if headphone/mic jacks are connected during bootup or not.
Also removing registering of headphone/mic DAPM pins with jack
detection mechanism. We should not enable DAPM paths just depending
on which jacks are connected. DAPM paths should be enabled/disabled
only when libaudio change alsa routing paths.
Change-Id: I2176176f71b35eaa0ad5405052a83b834cdca17e
Reviewed-on: http://git-master/r/27176
