commit 56cac413dd6d43af8355f5d1f90a199b540f73fc upstream.
hdmi_setup_fake_chmap() is supposed to set the reported channel map when
the channel map is not specified by the user.
However, the function indexes channel_allocations[] with a wrong value
and extracts the wrong nibble from hdmi_channel_mapping[], causing wrong
channel maps to be shown.
Fix those issues.
Tested on Intel HDMI to correctly generate various channel maps, for
example 3,4,14,15,7,8,5,6 (instead of incorrect 3,4,8,7,5,6,14,0) for
standard 7.1 channel audio. (Note that the side and rear channels are
reported as RL/RR and RLC/RRC, respectively, as per the CEA-861
standard, instead of the more traditional SL/SR and RL/RR.)
Note that this only fixes the layouts that only contain traditional 7.1
speakers (2.0, 2.1, 4.0, 5.1, 7.1, etc.). E.g. the rear center of 6.1
is still being shown wrongly due to an issue with from_cea_slot()
which will be fixed in a later patch.
Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi>
commit ff18620c2157671a8ee21ebb8e6a3520ea209b1f upstream.
... due to a copy & paste error.
Spotted by coverity CID 710923.
Signed-off-by: Mark Brown <broonie@linaro.org>
commit 268ff14525edba31da29a12a9dd693cdd6a7872e upstream.
Spotted by coverity CID 115170.
commit a4461f41b94cb52e0141af717dcf4ef6558c8e2e upstream.
Unable to handle kernel NULL pointer dereference at virtual address 00000008
pgd = d5300000
[00000008] *pgd=0d265831, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1] PREEMPT ARM
CPU: 0 PID: 2295 Comm: vlc Not tainted 3.11.0+ #755
task: dee74800 ti: e213c000 task.ti: e213c000
PC is at snd_pcm_info+0xc8/0xd8
LR is at 0x30232065
pc : [<c031b52c>] lr : [<30232065>] psr: a0070013
sp : e213dea8 ip : d81cb0d0 fp : c05f7678
r10: c05f7770 r9 : fffffdfd r8 : 00000000
r7 : d8a968a8 r6 : d8a96800 r5 : d8a96200 r4 : d81cb000
r3 : 00000000 r2 : d81cb000 r1 : 00000001 r0 : d8a96200
Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 15300019 DAC: 00000015
Process vlc (pid: 2295, stack limit = 0xe213c248)
[<c031b52c>] (snd_pcm_info) from [<c031b570>] (snd_pcm_info_user+0x34/0x9c)
[<c031b570>] (snd_pcm_info_user) from [<c03164a4>] (snd_pcm_control_ioctl+0x274/0x280)
[<c03164a4>] (snd_pcm_control_ioctl) from [<c0311458>] (snd_ctl_ioctl+0xc0/0x55c)
[<c0311458>] (snd_ctl_ioctl) from [<c00eca84>] (do_vfs_ioctl+0x80/0x31c)
[<c00eca84>] (do_vfs_ioctl) from [<c00ecd5c>] (SyS_ioctl+0x3c/0x60)
[<c00ecd5c>] (SyS_ioctl) from [<c000e500>] (ret_fast_syscall+0x0/0x48)
Code: e1a00005 e59530dc e3a01001 e1a02004 (e5933008)
---[ end trace cb3d9bdb8dfefb3c ]---
This is provoked when the ASoC front end is open along with its backend,
(which causes the backend to have a runtime assigned to it) and then the
SNDRV_CTL_IOCTL_PCM_INFO is requested for the (visible) backend device.
Resolve this by ensuring that ASoC internal backend devices are not
visible to userspace, just as the commentry for snd_pcm_new_internal()
says it should be.
Acked-by: Mark Brown <broonie@linaro.org>
commit 6fc16e58adf50c0f1e4478538983fb5ff6f453d4 upstream.
ASUS N76VZ needs the same fixup as N56VZ for supporting the boost
speaker.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=846529
commit e6bbe666673ab044a3d39ddb74e4d9a401cf1d6f upstream.
When a machine goes to S3/S4 after power-save is enabled, the runtime
PM refcount might be incorrectly decreased because the power-down
triggered soon after resume assumes that the controller was already
powered up, and issues the pm_notify down.
This patch fixes the incorrect pm_notify call simply by checking the
current value properly.
commit b63eae0a6c84839275a4638a7baa391be965cd0e upstream.
The generic parser has a support of vmaster hook, but this is
initialized only in the init callback with the check of the presence
of the corresponding kctl. However, since kctl is NULL at the very
first init callback that is called before build_controls callback, the
vmaster hook sync is skipped there. Eventually this leads to the
uninitialized state depending on the hook implementation.
This patch adds a simple workaround, just calling the sync function
explicitly at build_controls callback.
commit ccb041571b73888785ef7828a276e380125891a4 upstream.
The create_bind_cap_vol_ctl does not create any control indicating
that an inverted dmic is present. Therefore, create multiple
capture volumes in this scenario, so we always have some indication
that the internal mic is inverted.
This happens on the Lenovo Ideapad U310 as well as the Lenovo Yoga 13
(both are based on the CX20590 codec), but the fix is generic and
could be needed for other codecs/machines too.
Thanks to Szymon Acedański for the pointer and a draft patch.
BugLink: https://bugs.launchpad.net/bugs/1239392
BugLink: https://bugs.launchpad.net/bugs/1227491
Reported-by: Szymon Acedański <accek@mimuw.edu.pl>
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit ac536a848a1643e4b87e8fbd376a63091afc2ccc upstream.
The pcm_usb_stream plugin requires the mremap explicitly for the read
buffer, as it expands itself once after reading the required size.
But the commit [314e51b9: mm: kill vma flag VM_RESERVED and
mm->reserved_vm counter] converted blindly to a combination of
VM_DONTEXPAND | VM_DONTDUMP like other normal drivers, and this
resulted in the failure of mremap().
For fixing this regression, we need to remove VM_DONTEXPAND for the
read-buffer mmap.
Reported-and-tested-by: James Miller <jamesstewartmiller@gmail.com>
This is a backport for stable. The original commit SHA is
338cae565c53755de9f87d6a801517940d2d56f7.
On this machine, DAC on node 0x03 seems to give mono output.
Also, it needs additional patches for headset mic support.
It supports CTIA style headsets only.
Alsa-info available at the bug link below.
BugLink: https://bugs.launchpad.net/bugs/1236228
commit 88cfcf86aa3ada84d97195bcad74f4dadb4ae23b upstream.
The external mic showed up with a precense detect of "always present",
essentially disabling the internal mic. Therefore turn off presence
detection for this pin.
Note: The external mic seems not yet working, but an internal mic is
certainly better than no mic at all.
BugLink: https://bugs.launchpad.net/bugs/1227093
commit c6cc3d58b4042f5cadae653ff8d3df26af1a0169 upstream.
ASUS N56VZ needs a fixup for the bass speaker pin, which was already
provided via model=asus-mode4.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=841645
commit 39edac70e9aedf451fccaa851b273ace9fcca0bd upstream.
Currently hdmi_setup_audio_infoframe() reprograms the HDA channel
mapping only when the infoframe is not up-to-date or the non-PCM flag
has changed.
However, when just the channel map has been changed, the infoframe may
still be up-to-date and non-PCM flag may not have changed, so the new
channel map is not actually programmed into the HDA codec.
Notably, this failing case is also always triggered when the device is
already in a prepared state and a new channel map is configured while
changing only the channel positions (for example, plain
"speaker-test -c2 -m FR,FL").
Fix that by always programming the channel map in
hdmi_setup_audio_infoframe(). Tested on Intel HDMI.
commit a9d14bc0b188a822e42787d01e56c06fe9750162 upstream.
The frame check in i_usX2Y_urb_complete() and
i_usX2Y_usbpcm_urb_complete() is bogus and produces false positives as
described in this LAU thread:
http://linuxaudio.org/mailarchive/lau/2013/5/20/200177
This patch removes the check code entirely.
Cc: fzu@wemgehoertderstaat.de
Reported-by: Dr Nicholas J Bailey <nicholas.bailey@glasgow.ac.uk>
Suggested-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Daniel Mack <zonque@gmail.com>
commit 4a4370442c996be0fd08234a167c8a127c2488bb upstream.
Acer Aspire 3830TG seems requiring GPIO bit 0 as the primary mute
control. When a machine is booted after Windows 8, the GPIO pin is
turned off and it results in the silent output.
This patch adds the manual fixup of GPIO bit 0 for this model.
Reported-by: Christopher <DIDI2002@web.de>
commit d63733aed90b432e5cc489ddfa28e342f91b4652 upstream.
If the user passes an invalid value it leads to an info leak when we
print the error message or it could oops. This is called with user
supplied data from snd_ctl_elem_write().
commit d967967e8d1116fb38bad25e58714b5dddd03cca upstream.
This is called from snd_ctl_elem_write() with user supplied data so we
need to add some bounds checking.
commit f8d7b13e14357ed19d2ca2799539600418dc3939 upstream.
The ->put() function are called from snd_ctl_elem_write() with user
supplied data. The limit checks here could underflow leading to a
crash.
commit 4028b6c4c03f213260e9290ff3a6b5439aad07ce upstream.
snd_unregister_device() should return the device type and not stream
direction.
Signed-off-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
Acked-by: Vinod Koul <vinod.koul@intel.com>
Tested-by: Vinod Koul <vinod.koul@intel.com>
commit 83f72151352791836a1b9c1542614cc9bf71ac61 upstream.
Toshiba Satellite C870 shows interrupt problems occasionally when
certain mixer controls like "Mic Switch" is toggled. This seems
worked around by not using MSI.
Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=833585
commit 18e391862cceaf43ddb8eb5cca05e1a83abdebaa upstream.
hdmi_channel_allocation() tries to find a HDMI channel allocation that
matches the number channels in the playback stream and contains only
speakers that the HDMI sink has reported as available via EDID. If no
such allocation is found, 0 (stereo audio) is used.
Using CA 0 causes the audio causes the sink to discard everything except
the first two channels (front left and front right).
However, the sink may be capable of receiving more channels than it has
speakers (and then perform downmix or discard the extra channels), in
which case it is preferable to use a CA that contains extra channels
than to use CA 0 which discards all the non-stereo channels.
Additionally, it seems that HBR (HD) passthrough output does not work on
Intel HDMI codecs when CA is set to 0 (possibly the codec zeroes
channels not present in CA). This happens with all receivers that report
a 5.1 speaker mask since a HBR stream is carried on 8 channels to the
codec.
Add a fallback in the CA selection so that the CA channel count at least
matches the stream channel count, even if the stream contains channels
not present in the sink speaker descriptor.
Thanks to GrimGriefer at OpenELEC forums for discovering that changing
the sink speaker mask allowed HBR output.
Reported-by: GrimGriefer
Reported-by: Ashecrow
Reported-by: Frank Zafka <kafkaesque1978@gmail.com>
Reported-by: Peter Frühberger <fritsch@xbmc.org>
commit b054087dbacee30a9dddaef2c9a96312146be04e upstream.
When the transcoder:port mapping on Haswell HDMI/DP audio is changed
during the stream playback, the sound gets lost. Typically this
problem is seen when the user switches the graphics mode from eDP+DP
to DP-only configuration, where CRTC 1 is used for DP in the former
while CRTC 0 is used for the latter.
The graphics controller notifies the change via the normal ELD update
procedure, so we get the intrinsic event. For enabling the sound
again, the HDMI audio driver needs to reset the pin and set up the
audio infoframe again.
This patch achieves it by:
- keep the current status of channels and info frame setup in per_pin
struct,
- check the reconnection in the intrinsic event handler,
- reset the pin and the re-invoke hdmi_setup_audio_infoframe()
accordingly.
The hdmi_setup_audio_infoframe() function has been changed, too, so
that it can be invoked without passing the substream instance.
The patch is mostly based on the work by Mengdong Lin.
Cc: Mengdong Lin <mengdong.lin@intel.com>
commit 9f6f0afbb9fdabf6dcac642dfec457f28981e3f8 upstream.
The MC13783 Chip Errata, Rev. 4 says, that depending on SPI clock
and main audio clock speed, the Audio Codec or Stereo DAC do sometimes
not start when programmed to do so. This is due to an internal clock
timing issue related to the loading of the SPI bits into the audio block.
On an i.MX27 based system, this issue lead to switched audio channels under
certain circumstances: RTC + Touch + Audio are used and loaded at startup.
The mentioned workaround of writing registers 40 and 41 two times is implemented
here.
Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
commit 85fa532b6ef920b32598df86b194571a7059a77c upstream.
Bit 9 of PLL2,3 and 4 is reserved as '0'. The 24bit fractional part
should be split across each register in 8bit chunks.
Signed-off-by: Mike Dyer <mike.dyer@md-soft.co.uk>
commit 3f1a91aa25579ba5e7268a47a73d2a83e4802c62 upstream.
Building imx_v6_v7_defconfig with all audio drivers as modules results in
the folowing build error:
ERROR: "imx_pcm_fiq_init" [sound/soc/fsl/snd-soc-imx-ssi.ko] undefined!
ERROR: "imx_pcm_dma_init" [sound/soc/fsl/snd-soc-imx-ssi.ko] undefined!
ERROR: "imx_pcm_fiq_exit" [sound/soc/fsl/snd-soc-imx-ssi.ko] undefined!
ERROR: "imx_pcm_dma_exit" [sound/soc/fsl/snd-soc-imx-ssi.ko] undefined!
ERROR: "imx_pcm_dma_init" [sound/soc/fsl/snd-soc-fsl-ssi.ko] undefined!
ERROR: "imx_pcm_dma_exit" [sound/soc/fsl/snd-soc-fsl-ssi.ko] undefined!
Fix this by allowing SND_SOC_IMX_PCM_FIQ and SND_SOC_IMX_PCM_DMA to be also
built as modules and by using 'IS_ENABLED' to cover the module case.
Reported-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
[Guenter Roeck: back-ported to 3.11]
The recent commit to delay the release of kobject triggered NULL
dereferences of opti9xx drivers. The cause is that all
snd-opti92x-ad1848, snd-opti92x-cs4231 and snd-opti93x drivers
register the PnP card driver with the very same name, and also
snd-opti92x-ad1848 and -cs4231 drivers register the ISA driver with
the same name, too. When these drivers are built in, quick
"register-release-and-re-register" actions occur, and this results in
Oops because of the same name is assigned to the kobject.
The fix is simply to assign individual names. As a bonus, by using
KBUILD_MODNAME, the patch reduces more lines than it adds.
The fix is based on the suggestion by Russell King.
Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: <stable@vger.kernel.org>
Without the dynamic minor assignment, HDMI codec may have less PCM
instances than the number of pins, which eventually leads to Oops.
Reported-by: Stratos Karafotis <stratosk@semaphore.gr>
Yet another entry, just use the existing fixup for this machine, too.
Reported-by: "Nathanael D. Noblet" <nathanael@gnat.ca>
Gateway LT27 needs a fixup for the inverted digital mic.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus
ASoC: Fixes for v3.11
A few driver specific fixes here plus one core fix for a memory
corruption issue in DAPM initialisation which could lead to crashes.
The Tegra30 I2S driver was writing the AHUB interface parameters to the
playback path register rather than the capture path register. This
caused the capture parameters not to be configured at all, so if
capturing using non-HW-default parameters (e.g. 16-bit stereo rather
than 8-bit mono) the audio would be corrupted.
With this fixed, audio capture from an analog microphone works correctly
on the Cardhu board.
Cc: stable@vger.kernel.org
Add the volume control quirk for avoiding the kernel warning
for the Logitech HD Webcam C525
as in the similar commit 36691e1be6ec551eef4a5225f126a281f8c051c2
for the Logitech HD Webcam C310.
Reported-by: Maksim Boyko <maksim.a.boyko@gmail.com>
Tested-by: Maksim Boyko <maksim.a.boyko@gmail.com>
Cc: <stable@vger.kernel.org> # 3.10.5+
Signed-off-by: Maksim Boyko <maksim.a.boyko@gmail.com>
We've added a fake mute control (setting the amp volume to zero) for
CX5051 at commit [3868137e: ALSA: hda - Add a fake mute feature], but
this feature was overlooked in the generic parser implementation. Now
the driver lacks of mute controls on these codecs.
The fix is just to check both AC_AMPCAP_MUTE and AC_AMPCAP_MIN_MUTE
bits in each place checking the amp capabilities.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59001
Cc: <stable@vger.kernel.org> [v3.9+]
Commit aafe77cc45a5 (ALSA: usb-audio: add support for many Roland/Yamaha
devices) had several logic errors that prevented create_auto_midi_quirk
from enumerating any MIDI ports.
Reported-by: Keith A. Milner <maillist@superlative.org>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Patch makes midi output buffer DMA-able by allocating it separately.
Signed-off-by: Torsten Schenk <torsten.schenk@zoho.com>
Patch makes pcm buffers DMA-able by allocating each one separately.
Correct the pins for a line-in and a headphone on LG LW25 laptop with
ALC880 codec. Other pins seem fine.
Reported-and-tested-by: Joonas Saarinen <jonskunator@gmail.com>
The driver used to assume that the streaming endpoint's wMaxPacketSize
value would be an indication of how much data the endpoint expects or
sends, and compute the number of packets per URB using this value.
However, the Focusrite Scarlett 2i4 declares a value of 1024 bytes,
while only about 88 or 44 bytes are be actually used. This discrepancy
would result in URBs with far too few packets, which would not work
correctly on the EHCI driver.
To get correct URBs, use wMaxPacketSize only as an upper limit on the
packet size.
Reported-by: James Stone <jamesmstone@gmail.com>
Tested-by: James Stone <jamesmstone@gmail.com>
Cc: <stable@vger.kernel.org> # 2.6.35+
Patch fixes 6fire not to use stack as URB transfer_buffer. URB buffers need to
be DMA-able, which stack is not. Furthermore, transfer_buffer should not be
allocated as part of larger device structure because DMA coherency issues and
patch fixes this issue too.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
Tested-by: Torsten Schenk <torsten.schenk@zoho.com>
CS42L52 Beep control uses 2dB scale from -56dB
Signed-off-by: Brian Austin <brian.austin@cirrus.com>
Beep Volume Min/Max was backwards.
Change to SOC_SONGLE_SX_TLV for correct volume representation
Cc: stable@kernel.org
A fixup for Apple Mac Mini was lost during the adaption to the generic
parser because the fallback for the generic ID 8384:7680 was dropped,
and it resulted in the silence output (and maybe other problems).
Unfortunately, just adding the missing subsystem ID wasn't enough, in
this case. The subsystem ID of this machine is 0000:0100 (what Apple
thought...?), and since snd_hda_pick_fixup() doesn't take the vendor
id zero into account, the driver ignored this entry. Now it's fixed
to regard the vendor id zero as a valid value.
Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org>
list_first_entry() will always return a valid pointer, even if the list is
empty. So the check whether path is NULL will always be false. So we end up
calling dapm_create_or_share_mixmux_kcontrol() with a path struct that points
right in the middle of the widget struct and by trying to modify the path the
widgets memory will become corrupted. Fix this by using list_emtpy() to check if
the widget doesn't have any paths.
The SGTL5000 Capture Attenuate Switch (or "ADC Volume Range Reduction"
as it is called in the manual) is single bit only.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
When a sound capture/playback is terminated while a playback/capture
is running, power_vag_event() will clear SGTL5000_CHIP_ANA_POWER in
the SND_SOC_DAPM_PRE_PMD event, thus muting the respective other
channel.
Don't clear SGTL5000_CHIP_ANA_POWER when both DAC and ADC are active
to prevent this.
A fix to make sure userspace knows when control writes have caused a
change in value, fixing some UIs, plus a few few driver fixes mainly
cleaning up issues from recent refactorings on less mainstream platforms.
