Add "Capture" keyword in capture controls of WM8903
Required for correct identification of capture switch control
in nvaudioalsamixer
Bug 789860
Change-Id: I39cf7f6edd3552bba2c042edc3859a81b30e88af
Reviewed-on: http://git-master/r/40835
Tested-by: Viraj Karandikar <vkarandikar@nvidia.com>
Reviewed-by: Gautam Moharir <gmoharir@nvidia.com>
Adding two new dai-links to WM8753 soc layer for voice call and BT
voice call. Voice-call dai-link will link between WM8753 voice codec
and generic BT codec interface while BT voice-call dai-link will
link generic BT codec interface and generic BB codec interface.
Also adding error checks in tegra_pcm to handle pcm device
related operations on a dummy cpu-dai.
Bug 814490
Change-Id: I047171af18432d5932e7e1919d73ac3d483d8f80
Reviewed-on: http://git-master/r/37395
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Split Headset to Headset Out and Headset In
Use IN1L for Int mic and Headset (for WM8903)
Remove unused variables and warning
Bug 816278
Bug 830213
Bug:836150
Reviewed-on: http://git-master/r/30142
(cherry picked from commit 170ccc20d6227faaf196a920e7812792c305e2ff)
Change-Id: I97a149df932c07b365eb21502be7e386c94e1c06
Reviewed-on: http://git-master/r/36077
Tested-by: Sanjay Singh Chauhan <schauhan@nvidia.com>
Reviewed-by: Viraj Karandikar <vkarandikar@nvidia.com>
added code to support digital mic on wm8903 for ventana. By default
analog mic is enabled. To enable digital mic write 1 and to disable
write 0 to
/sys/devices/platform/soc-audio/enable_digital_mic
Change-Id: I36e239d10404a9bc8446e275e5c59e9829409608
Reviewed-on: http://git-master/r/29615
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
bug 816348
Change-Id: I6551a867fdfcddc6689d6fcc1daaee11d8879e7f
Reviewed-on: http://git-master/r/28182
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Removes the Sidetone enable code, sidetone should
not be enabled for normal capture.
For Bug: 808731
Change-Id: I7159c023624c9d3f759cf52510e8a48551454db1
Reviewed-on: http://git-master/r/28013
Tested-by: Manjula Gupta <magupta@nvidia.com>
This change mainly takes care of following things:
1) Codec_dai code will use dap apis to query the board specific dap
tables to find the codec configuration needed for a particular
routing and will configure codec accordingly. So long we were
configuring codec hardcodedly.
2) Moved all codec and board specific routing codes to codec specific
files from tegra_soc_controls.c.
3) Modifying the codec routing logic to make it simpler and robust.
4) Except DAP Mclk we will turn off all other audio related clocks
when not in use.
5) I2s and SPDIF bit clock frequencies will be dynamically calculated
based on the stream properties.
6) DAS power management and DAP MCLK related codes are moved to codec
dai since they are more closely related to codec than i2s.
Change-Id: I531558bec108af5828c8ff2ed932f4d25e00afdb
Reviewed-on: http://git-master/r/24683
Adding code to scan headphone and mix gpios during alsa init to check
if headphone/mic jacks are connected during bootup or not.
Also removing registering of headphone/mic DAPM pins with jack
detection mechanism. We should not enable DAPM paths just depending
on which jacks are connected. DAPM paths should be enabled/disabled
only when libaudio change alsa routing paths.
Change-Id: I2176176f71b35eaa0ad5405052a83b834cdca17e
Reviewed-on: http://git-master/r/27176
Adds a function to restore jack state after suspend, it will notify
the upper layer about the current states of the jack after suspend.
In suspend state the notifier function doesn't get triggered, leaving the
system in an unknown state. This function will be called on resume after
suspend.
Fix for Bug: 804328
Change-Id: I89ab32a6d775904fb1a71725d4e1fbda89002431
Reviewed-on: http://git-master/r/26853
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Boris Suvorov <bsuvorov@nvidia.com>
Tested-by: Boris Suvorov <bsuvorov@nvidia.com>
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Enable the external speaker amp on Ventana.
Requires that the avdd_amp regulator be enabled.
Bug 809015
Change-Id: I0ec741655ed9629f8ad45adc43f5dfcba7369c60
Reviewed-on: http://git-master/r/26653
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Reviewed-by: Ching Kuang (Roger) Hsieh <rhsieh@nvidia.com>
Tested-by: Ching Kuang (Roger) Hsieh <rhsieh@nvidia.com>
Currently the machine driver can only do bias level configuration before
the CODEC bias level is brought up. This means that the machine cannot do
any configuration which depends on the CODEC bias level being maintained.
Provide a post-CODEC callback which allows the machine driver to do things
like enable the FLL on a CODEC which is brought down to BIAS_OFF when idle.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cherry-picked from mainline kernel.
Change-Id: Ib0a8533e3762dfc67ee21209a28e9a6603d31a37
Reviewed-on: http://git-master/r/23058
Make dependency on Android switch class driver conditional
so driver compiles on configurations with switch disabled
Change-Id: If0b3ad9b4582bd07b79f27ca3252eeb45050b7c8
Signed-off-by: Allen Martin <amartin@nvidia.com>
Reviewed-on: http://git-master/r/24364
bug 804615
Change-Id: I11d450febb9ab7b5576f2f67cbf03b8d953c3669
Reviewed-on: http://git-master/r/23885
Bug 803444
Corrected the missing code to enable the Right channel with headset mode.
Change-Id: I2728b9d5a07ad9dad9cc64517ef3f4bc4990a8df
Reviewed-on: http://git-master/r/23418
Reviewed-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Tested-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Bug 783013
Bug 788021
Change-Id: I97425d5a24095fe8e8e5b76b9a30eb621999e507
Reviewed-on: http://git-master/r/22330
Reviewed-by: Vijay Mali <vmali@nvidia.com>
whistler not booting because switch device required
by jack driver not initialised
Change-Id: I447a9fd179f08f38fc9e2444650ce7511d2092ee
Reviewed-on: http://git-master/r/22993
Tested-by: Nikesh Oswal <noswal@nvidia.com>
Added support on Mic jack detection on Tegra.
- External mic jack detection could be probed by trigger an interrupt
via specific gpio or pull-up a generic gpio pin. The patch enabled the
later option.
- Tegra reference boards have gpio to switch external mic and internal
mic. The switching is done in the patch automatically once jack
happened.
fixes bug 766757
Change-Id: If530f237d4564d1de6c019b206910f2a0ffe4163
Reviewed-on: http://git-master/r/22033
Reviewed-by: Chao Jiang <chaoj@nvidia.com>
Tested-by: Chao Jiang <chaoj@nvidia.com>
Added support for built-in speaker. Although audio subsystem on
different boards have various topology, Tegra boards usually have
amplifier connected to codec. The patch added a control interface to
expose speaker control widget to user space. Amplifier could be driven
automatically if internal speaker turned on.
fixes bug 766757
Change-Id: Ic6b8d0c58830a71ff8d6c09d1268cbd97982d08b
Reviewed-on: http://git-master/r/21985
Ignore no-touched pins. This will help to set up gpio pins safely.
Change-Id: Iff9f3249b9e3594ede5c75cce59f38c2ad432f92
Reviewed-on: http://git-master/r/20895
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Exposed gpio pins on wm8903 via GPIOLIB. This will help ALSA control
drivers to manipulate the codec much more easier.
Change-Id: I070eafa6e9a533cc0c285c1780d1b8393105def1
Reviewed-on: http://git-master/r/20883
Added debugfs entries for wm8903.
Change-Id: I2b2801381a2e82fc4b8929853ba9653569059e33
Reviewed-on: http://git-master/r/20880
reset vimd and bias registers for wm8903 codec when codec bias level
is off.
fix for bug 773327
Change-Id: Iad67afef69f8c016b5f732947ad991c400cb7fd4
Reviewed-on: http://git-master/r/20934
Tested-by: Ravindra Lokhande <rlokhande@nvidia.com>
Bug 793968
Change-Id: Ia4ee5a83d18b409dd223f70fb1a5a78fad16a08e
Reviewed-on: http://git-master/r/20403
added headphone detection logic for WM8753 on whistler
Change-Id: I7c1c2a75480050ba03cb037393ead44761a7706f
Reviewed-on: http://git-master/r/20298
Caching das registers before system suspend and restoring
them during system resume. Also moved das power mode calls
from tegra_pcm to tegra_i2s interface.
Bug 792879
Bug 789967
Change-Id: I15a5f41a1aab6d74a8f5e29db25a93b26c4d4111
Reviewed-on: http://git-master/r/20292
In wm8903_resume() codec should be powered up after restoring cached
registers. Otherwise sequencer registers are getting overwritten after
powering up of codec which was shutting down the codec during resume.
Bug 792879
Bug 789967
Change-Id: Ic342a490f988ea1aa9597e6cd68e7d0a1000210a
Reviewed-on: http://git-master/r/20270
Restrict period size to be multiple of 8 and period count to be
integer. This is required to prevent audio breaks for playback
through BT SCO.
Bug 771510
Change-Id: If15631512bc5ce5a4358342b523da0a5a020cc2d
Reviewed-on: http://git-master/r/19731
Headphone jack detection is enabled with this patch. The jack will be
reported via /sys/class/switch interface to user space.
fixes bug 766757
Change-Id: I58908e7de1025b17cdf37079d5650aa5f503dcdd
Reviewed-on: http://git-master/r/18707
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
- use proper name for generic codec DAI
Change-Id: I29eacc43e6922b28f440596fdbb9c544e12537f6
Reviewed-on: http://git-master/r/18846
- use generic codec DAI for BT-SCO usecase
Change-Id: Ied03e0ce2617d7b9ce8c8fd176f0b601a8896796
Reviewed-on: http://git-master/r/18716
Change-Id: I210dea5af60e11326ad23bafa78e937d4932e58c
Reviewed-on: http://git-master/r/17564
use platform data to configure i2s2.
Change-Id: If655bc96853ee85114381b5ae979ba0984e25f65
Reviewed-on: http://git-master/r/18028
- Enabled Recording for WM8753.
- Fixed low Volume in Play Back by enabling LDO7
- Fixed noise in PlayBack and Recording by using a bclk of 2.82 Mhz
Bug 771506
Change-Id: I0c43adafa83969929cfdff700a71a68225ab4c22
Reviewed-on: http://git-master/r/16260
Tested-by: Sachin Nikam <snikam@nvidia.com>
-i2s will be configured by using platform data passed
to i2s driver.
- removed i2s code from tegra_pcm.c file
- clocks are enabled from i2s driver
Change-Id: I4ed30903b16ae86173d7a802d1006f5be474531b
Reviewed-on: http://git-master/r/16252
Added support in WM8753 soc file for second i2s dai
and corresponding voice dai
Change-Id: I93c2e06411b374108f72dfa7a58273575c856560
Reviewed-on: http://git-master/r/16091
-Added support for second i2s device.
-Moved i2s related code to tegra_i2s.c
-Added second i2s device in board file.
Change-Id: Ifa659dbceda840a15b445ea997882a2d3ef8ca50
Reviewed-on: http://git-master/r/14726
Adding support for Audio codec wm8753.
This is an interface between sound and codec driver.
Change-Id: Iabf5ab17b40617d62cfebda93a0742f77f4f9013
Reviewed-on: http://git-master/r/16014
Setting deafult gain to 19.2dB for record, as there is
no interface to change gain for the recorded audio setting
it to 80% of max gain by default.
This fixes the low volume level issue for the audio streams
recorded through mic.
For Bug 763227
Change-Id: Id141ed235c2a8d1ac3d26bc7d0ad03e26e7c8396
Reviewed-on: http://git-master/r/15790
Reviewed-by: Masood Shaikh <mshaikh@nvidia.com>
- separated codec and control code
- codec specific code is added to tegra_soc_xxx
- alsa controls code added to tegra_soc_controls
Fixes bug 759167
Change-Id: Ib8cd19364b3d4a0cb726d20b4eb1a7fab4017bf1
Reviewed-on: http://git-master/r/15637
Add three alsa controls to expose selection of playback
device, capture device and call mode.Alsa kernel will
route pcm data to the selected output/input port.
bug 771510
Change-Id: Ibdeebbd799b2ae36046a77327ec8b6a3b01553a9
Reviewed-on: http://git-master/r/14729
arch/arm/mach-tegra/fuse.c
drivers/misc/Makefile
Change-Id: I300b925d78b31efe00c342190d8dbd50e2e81230
This will provide option to select audio codec
for your board.
Bug 759167
Change-Id: I7a8a5fb6ee43df5eb439f0cbfbeb2bc9bdcf9794
Reviewed-on: http://git-master/r/15111
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Removed direct call to das registers, instead
using calls of das driver.
Change-Id: I230a98950b06a9b3d36cd983353ad810b1d52290
Reviewed-on: http://git-master/r/15008
commit e03fa055bc126e536c7f65862e08a9b143138ea9 upstream.
Sjoerd Simons reports that, without using position_fix=1, recording
experiences overruns. Work around that by applying the LPIB quirk
for his hardware.
Reported-and-tested-by: Sjoerd Simons <sjoerd@debian.org>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
commit d81a12bc29ae4038770e05dce4ab7f26fd5880fb upstream.
The load_mixer_volumes() function, which can be triggered by
unprivileged users via the SOUND_MIXER_SETLEVELS ioctl, is vulnerable to
a buffer overflow. Because the provided "name" argument isn't
guaranteed to be NULL terminated at the expected 32 bytes, it's possible
to overflow past the end of the last element in the mixer_vols array.
Further exploitation can result in an arbitrary kernel write (via
subsequent calls to load_mixer_volumes()) leading to privilege
escalation, or arbitrary kernel reads via get_mixer_levels(). In
addition, the strcmp() may leak bytes beyond the mixer_vols array.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
commit 6027277e77df2d2893d906c42f5c9f9abcb731e0 upstream.
Add a quirk entry for Thinkpad Edge 11 as well as other TP Edge models.
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
commit 3f343f8512c7882a3637d9aea4ec6b3801cbcdc5 upstream.
Deemphasis control's .get callback should update control's value instead
of returning it - return value of callback function is used for indicating
error or success of operation.
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
commit a0968628097380be52db8b4664da98fc425546a5 upstream.
Acc to WM8580 manual, the default value for R8 is 0x10, not 0x1c.
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
commit ed8cc471d75365f8590c76f580def899d58028c0 upstream.
SPKOUTL_BOOST start from third bit, SPKOUTLR_BOOST start from 0 bit.
Signed-off-by: Uk Kim <w0806.kim@samsung.com>
commit 77c4d5cdb81d25a45fbdfb84dd3348121219a072 upstream.
BugLink: https://launchpad.net/bugs/595482
The original reporter states that audible playback from the internal
speaker is inaudible despite the hardware being properly detected. To
work around this symptom, he uses the model=lg quirk to properly enable
both playback, capture, and jack sense. Another user corroborates this
workaround on separate hardware. Add this PCI SSID to the quirk table
to enable it for further LG P1 Expresses.
Reported-and-tested-by: Philip Peitsch <philip.peitsch@gmail.com>
Tested-by: nikhov
