commit b91ab72b830e1494c2c7f8de05ccb2ab2c9cfb26 upstream.
Do not forget to program the MCLK ratio for the I2S output.
Otherwise, the master clock frequency can be too high for
the DACs at sample frequencies above 96 kHz.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 92653453c3015c083b9fe0ad48261c6b2267d482 upstream.
The card model detection code introduced in 2.6.30 that tries to work
around partially broken EEPROM contents by reading the EEPROM directly
does not handle cards where the EEPROM has been omitted. In this case,
we have to use the default ID to allow the driver to load.
Reported-and-tested-by: Ozan Çağlayan <ozan@pardus.org.tr>
commit a3f730af7e33cea10ea66f05b2565fde1f9512df upstream.
This patch fixes the wrong headphone output routing for MacBookPro 3,1/4,1
quirk with ALC889A codec, which caused the silent headphone output.
Also, this gives the individual Headphone and Speaker volume controls.
Reference: kernel bug#14078
http://bugzilla.kernel.org/show_bug.cgi?id=14078
commit b1ddaf681e362ed453182ddee1699d7487069a16 upstream.
snd_interval_list() expected a sorted list but did not document this, so
there are drivers that give it an unsorted list. To fix this, change
the algorithm to work with any list.
This fixes the "Slave PCM not usable" error with USB devices that have
multiple alternate settings with sample rates in decreasing order, such
as the Philips Askey VC010 WebCam.
http://bugzilla.kernel.org/show_bug.cgi?id=14028
Reported-and-tested-by: Andrzej <adkadk@gmail.com>
commit 100d5eb36ba20dc0b99a17ea2b9800c567bfc3d1 upstream.
Without the initialization of vmaster NID, the dB information got
confused for ALC269 codec.
Reference: Novell bnc#527361
https://bugzilla.novell.com/show_bug.cgi?id=527361
commit 1df892cba45f9856d369a6a317ad2d1e44bca423 upstream.
The wrong register cache variable was being used to provide the size for
the memcpy(), resulting in a copy of only a void * of data.
Reported-by: Lars-Peter Clausen <lars@metafoo.de>
commit 8de56b7deb2534a586839eda52843c1dae680dc5 upstream.
The master mute switch is wrongly implemented as checking the pointer
instead of its value, thus it can be never muted. This patch fixes
the issue.
Reference: Novell bnc#404873
https://bugzilla.novell.com/show_bug.cgi?id=404873
commit 42b95f0c6b524b5a670dd17533a3522db368f600 upstream.
Gateway T6834c laptops need EAPD always on while the default behavior
for the STAC9205 reference board is to turn it off upon every HP plug.
By using the special "eapd" model, which is first introduced for Gateway
T1616 laptops for this same reason, this peculiarity can be properly
handled.
Signed-off-by: Hao Song <baritono.tux@gmail.com>
commit b04add956616b6d89ff21da749b46ad2bd58ef32 upstream.
The recent rewrite of the codec parser for STAC9872 caused a regression
for some Sony VAIO models that don't give proper pin default configs
by BIOS. Even using model=vaio doesn't work because the pin definitions
are set after the pin overrides.
This patch fixes the pin definitions in patch_stac9872() to be put
in the right place before the pin overrides. Also the patch adds the
new quirk entry for VAIO F/S to have the correct pin default configs.
commit 34fdeb2d07102e07ecafe79dec170bd6733f2e56 upstream.
The capture buffer size with 64kB seems broken with CA0106.
At least, either the update timing or the DMA position is wrong,
and this screws up pulseaudio badly.
This patch restricts the max buffer size less than that to make life
a bit easier.
commit 8886f33f25083a47d5fa24ad7b57bb708c5c5403 upstream.
Blue Microphones USB devices have an alternate setting that sends two
channels of data to the computer. Unfortunately, the descriptors of
that altsetting have a wrong channel setting, which means that any
recorded data from such a device has twice the sample rate from what
would be expected.
This patch adds a workaround to ignore that altsetting. Since these
devices have only one actual channel, no data is lost.
commit 826390796d09444b93e1f957582f8970ddfd9b3d upstream.
When resuming, we better take the DACs out of the reset state before
trying to use them.
Reference: kernel bug #13599
http://bugzilla.kernel.org/show_bug.cgi?id=13599
commit 6423f9ea8035138d70bae1a278d3b57b743f8b3e upstream.
When decoding (N)RPN sequencer events into raw MIDI commands, the
extra_decode_xrpn() function had accidentally swapped the MSB and LSB
controller values of both the parameter number and the data value.
commit ba2533a47865ec0dbc72834287a8a048e9337a95 upstream.
These are not supported since performance can not be guaranteed
when they are in use.
commit c2a30d711852e4f39c8a79135b3caa701f7a8e02 upstream.
Fix copy&paste bug in PnP MPU-401 initialization.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
commit 376b508ffde3b17e105265f89b83bdb044b1c1ae upstream.
It needs model=toshiba-s06 to work with the digital-mic.
commit ae14ef68e8e67ca5b8b29f0eb640f7c106617f4e upstream.
The commit f9e336f65b666b8f1764d17e9b7c21c90748a37e
ALSA: hda - Unify capture mixer creation in realtek codes
removed the "Input Source" mixer element creation for toshiba-s06 model
because it contains a digital-mic input.
This patch take the control back.
commit f708eb1d71dc8ffb184da9f0bc53461c6dc10653 upstream.
The PCM pointer callback sometimes returns invalid positions and this
screws up the hw_ptr updater in PCM core. Especially since now the
jiffies check is optional with xrun_debug, the invalid position is
handled as is, and causes serious sound skips, etc.
This patch simplifies the position-fix strategy in intel8x0 to be more
robust:
- just falls back to the last position if bogus position is detected
- another sanity check for the backward move of the position due to
a race of register update and the base-index update
This patch is applicable also for 2.6.30.
Tested-by: David Miller <davem@davemloft.net>
commit 601e1cc5df940b59e71c947726640811897d30df upstream.
Although the vmaster controls are created, they aren't registered thus
they don't appear in the real world. Added the missing snd_ctl_add()
calls.
* fix/hda:
ALSA: hda - Compaq Presario CQ60 patching for Conexant
A docking mic control is shown by default. The Compaq Presario
CQ60 laptop has no docking connector, so designate it as a
CXT5051_HP model.
This makes the phantom mixer slider disappear.
Signed-off-by: Tony Vroon <tony@linx.net>
* fix/pcm-jiffies-check:
ALSA: Enable PCM hw_ptr_jiffies check only in xrun_debug mode
ALSA: Fix invalid jiffies check after pause
* fix/misc:
sound: usb-audio: make the MotU Fastlane work again
Kernel 2.6.18 broke the MotU Fastlane, which uses duplicate endpoint
numbers in a manner that is not only illegal but also confuses the
kernel's endpoint descriptor caching mechanism. To work around this, we
have to add a separate usb_set_interface() call to guide the USB core to
the correct descriptors.
Reported-and-tested-by: David Fries <david@fries.net>
Cc: <stable@kernel.org>
The PCM hw_ptr jiffies check results sometimes in problems when a
hardware doesn't give smooth hw_ptr updates. So far, au88x0 and some
other drivers appear not working due to this strict check.
However, this check is a nice debug tool, and the capability should be
still kept.
Hence, we disable this check now as default unless the user enables it
by setting the xrun_debug mode to the specific stream via a proc file.
The hw_ptr_jiffies has to be reset properly to avoid the invalid
check of jiffies delta in snd_pcm_update_hw_ptr*() functions.
Especailly this patch fixes the bogus jiffies check after the puase
and resume.
This patch is a modified version of the original patch by Jaroslav.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6:
ALSA: hda - Add missing check of pin vref 50 and others in Realtek codecs
ALSA: hda - Add 5stack-no-fp model for STAC927x
ALSA: hda - Add forced codec-slots for ASUS W5Fm
Some Realtek codecs like ALC861 seem to support only VREF50 while the
current driver assumes it's only VREF80. Check other VREF bits to set
the correct value.
The recent fix for the headphone volume control on IDT/STAC codecs
resulted in the removal of invalid "Side" volume eventually. But,
if the front panel doesn't exist, this setup could be regarded as a
sort of regression, as reported in kernel bug #13250.
Now as a workaround, a new model 5stack-no-fp is added so that the user
without the front panel can choose this one explicitly.
Reference: bko#13250
http://bugzilla.kernel.org/show_bug.cgi?id=13250
ASUS W5Fm needs the fixed codec-slots to probe to override the BIOS
problem like W5F.
Tested-by: Alp Kılıç <kilic.alp@gmail.com>
Signed-off-by: Ozan Çağlayan <ozan@pardus.org.tr>
* fix/misc:
ALSA: Kill truncate warning by shortening Sigmatel-specific AC97 control name
ALSA: pcsp - fix printk format warning again
ALSA sound/core/control.c:232: Control name 'Sigmatel Surround Phase
Inversion Playback Switch' truncated to 'Sigmatel Surround Phase
Inversion Playback ' bootup message by omitting weird Sigmatel prefix
in this case; also fix up the related ca0106 mixer control removal
part by using identical naming there.
Signed-off-by: Andreas Mohr <andi@lisas.de>
* fix/hda:
ALSA: hda - fix audio on HP TX25xx series notebooks
Fixes https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4121
Taken from https://bugzilla.redhat.com/show_bug.cgi?id=498060
Signed-off-by: Adam Williamson <awilliam@redhat.com>
The second argument of the probe method points to the amba_id
structure, so it's better passed with the correct type. None of the
current in-tree drivers uses the pointer, so they have only been
checked for a clean compile.
Change suggested by Russell King.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
The commit 5a641bcd6398841cc4606b0a732d41a09256fd94 changed the
printk format to '%lu', but the value passed seems to be dependent
on the architecture. On x86-64, I got a new warning now because an
int value is passed actaully.
As a workaround, just cast the value always to unsigned long.
* fix/asoc:
ASoC: DaVinci EVM board support buildfixes
ASoC: DaVinci I2S updates
ASoC: davinci-pcm buildfixes
pxa2xx-ac97: fix reset gpio mode setting
ASoC: soc-core: fix crash when removing not instantiated card
* fix/misc:
ALSA: pcsp: fix printk format warning
ALSA: riptide: postfix increment and off by one
This is a build fix, resyncing the DaVinci EVM ASoC board code
with the version in the DaVinci tree. That resync includes
support for the DM355 EVM, although that board isn't yet in
mainline.
(NOTE: also includes a bugfix to the platform_add_resources
call, recently sent by Chaithrika U S <chaithrika@ti.com> but
not yet merged into the DaVinci tree.)
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This resyncs the DaVinci I2S code with the version in the DaVinci
tree. The behavioral change uses updated clock interfaces which
recently merged to mainline. Two other changes include adding a
comment on the ASP/McBSP/McASP confusion, and dropping pdev->id in
order to support more boards than just the DM644x EVM.
This is a buildfix for the DaVinci PCM code, resyncing it with
the version in the DaVinci tree. The notable change is using
current EDMA interfaces, which recently merged to mainline.
(The older interfaces never made it into mainline.)
NOTE: open issue, the DMA should be to/from SRAM; see chip
errata for more info. The artifacts are extremely easy to
hear on DM355 hardware (not yet supported in mainline), but
don't seem as audible on DM6446 hardwaare (which does have
mainline support).
Fix printk format warning:
sound/drivers/pcsp/pcsp_mixer.c:54: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int'
With a postfix increment these variables are incremented beyond
CMDIF_TIMEOUT / MAX_WRITE_RETRY.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Eric Miao <eric.miao@marvell.com>
If the card was not instantiated in snd_soc_instantiate_card, calling
soc-remove will crash because some of codec, cpu_dai and card .remove
methods are called twice.
Fix this by returning from soc_remove immediately.
* fix/asoc:
ASoC: Fix errors in WM8990
* fix/hda:
ALSA: hda - Fix line-in on Mac Mini Core2 Duo
* fix/misc:
sound: via82xx: fix DXS volume range
sound: serial-u16550: fix buffer overflow
BIOS on Mac Mini Core2 Duo sets both INPUT and OUTPUT pinctl bits to
the line-in jack, and it confuses the driver as if it's a valid input.
This patch adds the check of OUTPUT bit so that the driver fixes the
invalid pin setup.
Tested-by: Tino Keitel <tino.keitel@gmx.de>
With 5 bits and 1.5 dB per step, the DXS volume range is only 48 dB.
