commit 3351e9fbb0fda6498ee149ee88c67f5849813c57 upstream.
These scales should be regular, not linear.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
commit e6a08c5a8990102bcd1f4bae84b668da6c23caa9 upstream.
These should be regular rather than linear scales.
commit 61bb42c37dfa9016dcacc86bcd41362ab2457d4a upstream.
BugLink: https://launchpad.net/bugs/551949
Symptom: On the reporter's Shuttle device, using PulseAudio in Ubuntu
10.04 LTS results in "popping clicking" audio with the PA crashing
shortly thereafter.
Test case: Using Ubuntu 10.04 LTS (Linux 2.6.32.12), Linux 2.6.33, or
Linux 2.6.34, adjust the HDA device's volume with PulseAudio.
Resolution: add SSID for this machine to the position_fix quirk table,
explicitly specifying the LPIB method.
Reported-and-Tested-By: Christian Mehlis <mehlis@inf.fu-berlin.de>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
commit e96d3127760a2fc509bca6bf7e61e8bc61497aeb upstream.
BugLink: https://launchpad.net/bugs/586347
Symptom: On the Sony VPCS11V9E, using GStreamer-based applications with
PulseAudio in Ubuntu 10.04 LTS results in stuttering audio. It appears
to worsen with increased I/O.
Test case: use Rhythmbox under increased I/O pressure. This symptom is
reproducible in the current daily stable alsa-driver snapshots (at least
up until 21 May 2010; later snapshots fail to build from source due to
missing preprocessor directives when compiled against 2.6.32).
Reported-and-Tested-By: Lauri Kainulainen <lauri@sokkelo.net>
commit 7a68be94e22e7643038726ebc14360752a91800b upstream.
BugLink: https://launchpad.net/bugs/583983
Symptom: on a significant number of hardware, booting from a live cd
results in capture working correctly, but once the distribution is
installed, booting from the install results in capture not working.
Test case: boot from Ubuntu 10.04 LTS live cd; capture works correctly.
Install to HD and reboot; capture does not work. Reproduced with 2.6.32
mainline build (vanilla kernel.org compile).
Resolution: add SSID for Acer Aspire 5110 to the position_fix quirk
table, explicitly specifying the LPIB method.
I'll be sending additional patches for these SSIDs as bug reports are
confirmed.
Reported-and-Tested-By: Leo
commit 4e0938dba7fccf37a4aecba4d937da7f312b5d55 upstream.
BugLink: https://launchpad.net/bugs/549560
Resolution: add SSID for Toshiba A100-259 to the position_fix quirk
confirmed.
This patch also trivially sorts the quirk table in ascending order by
subsystem vendor.
Reported-and-Tested-by: <davide.molteni@gmail.com>
commit 66668b6fb6861fad7f6bfef6646ac84693474c9a upstream.
BugLink: https://launchpad.net/bugs/576160
Symptom: Currently (2.6.32.12) the Dell M1730 uses the 3stack model
quirk. Unfortunately this means that capture is not functional out-
of-the-box despite ensuring that capture settings are unmuted and
raised fully.
Test case: boot from Ubuntu 10.04 LTS live cd; capture does not
work.
Resolution: Correct the model quirk for Dell M1730 to rely on the
BIOS configuration.
This patch also trivially sorts the quirk into the correct section
based on the comments.
Reported-and-Tested-By: <picdragon99@msn.com>
Tested-By: Daren Hayward
Tested-By: Tobias Krais
commit c602c8ad45d6ee6ad91fc544513cc96f70790983 upstream.
Added a PCI controller id on new Dell laptops.
Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com>
Cc: AmenophisIII <AmenophisIII@gmx.at>
commit 0ebf9e3692d640917fb792a7494d05e1f5b1058f upstream.
Reference: http://mailman.alsa-project.org/pipermail/alsa-devel/2010-May/027525.html
As reported on the mailing list, we also need to cap to the 0 dB offset
for Lenovo models, else the sound will be distorted.
Reported-and-Tested-by: Tim Starling <tstarling@wikimedia.org>
commit 8213466596bf10b75887754773ee13c10cf86f5c upstream.
The capture source control of maya44 was wrongly coded with the bit
shift instead of the bit mask. Also, the slot for line-in was
wrongly assigned (slot 5 instead of 4).
Reported-by: Alex Chernyshoff <alexdsp@gmail.com>
commit c53666813813a0ea3d0391e1911eefc05a5e6b4f upstream.
BugLink: https://launchpad.net/bugs/549267
The OR verified that using the olpc-xo-1_5 model quirk allows the
headphones to be audible when inserted into the jack. Capture was
also verified to work correctly.
Reported-by: Richard Gagne
Tested-by: Richard Gagne
commit 4442dd4613fe3795b4c8a5f42fc96b7ffb90d01a upstream.
BugLink: https://launchpad.net/bugs/573284
Reported-by: Andy Couldrake <acouldrake@googlemail.com>
Tested-by: Andy Couldrake <acouldrake@googlemail.com>
commit 8f0f5ff6777104084b4b2e1ae079541c2a6ed6d9 upstream.
BugLink: https://launchpad.net/bugs/541802
The OR's hardware distorts at PCM 100% because it does not correspond to
0 dB. Fix this in patch_cxt5045() for all Packard Bell models.
Reported-by: Valombre
CX20549 (Venice)
commit 0b587fc4d35afb1bc0fc3d890084bb14c78372dc upstream.
BugLink: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4792
Cristian reported that these models have really bad sound above 6 dB
and proposed the original patch. I've updated the comment to reflect
this change.
Reported-by: Cristian Klein
commit 715aa675338ce6e1a3b4f77cf87ea611f93058a8 upstream.
Ignore spurious HV interrupts during suspend / resume, this avoids
mistaking them for a mute button press. This is not very pretty but
it seems the only way to fix the master volume control gets muted
after suspend issue I'm seeing. Note that the es1968 driver is doing
exactly the same.
commit 7efbfd1ae98ef9efe06352e2a1ad83e8c14ceeb1 upstream.
Without this quirk sound stops working after suspend resume. With this quirk,
one still needs to manually unmute the master volume control after a suspend /
/ resume cycle. That is fixed in another patch in this set.
Note that this patch was submitted to the alsa bug tracker a long time ago:
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4319
commit 3353541fe533350a22a03e2fb7dc085b35912575 upstream.
BugLink: https://launchpad.net/bugs/567494
The OR has verified that the existing model quirk, ALC880_UNIWILL,
is insufficient for audible playback and capture by default. Instead,
the ALC880_F1734 model quirk needs to be used.
This change is necessary for both 2.6.32.11 and 2.6.33.2.
Reported-by: Arnaud Malpeyre <amalpeyre@gmail.com>
Tested-by: Arnaud Malpeyre <amalpeyre@gmail.com>
commit 5c1bccf645d4ab65e4c7502acb42e8b9afdb5bdc upstream.
BugLink: https://launchpad.net/bugs/568600
The OR has verified that the dell-m6 model quirk is necessary for audio
to be audible by default on the Dell Studio XPS 1645.
This change is necessary for 2.6.32.11 and 2.6.33.2 alike.
Reported-by: Andy Ross <andy@plausible.org>
Tested-by: Andy Ross <andy@plausible.org>
commit aac78daf8f37256283f56820ae858add7139c56c upstream.
BugLink: https://launchpad.net/bugs/553002
Reported-by: Robert Chambers
Tested-by: Robert Chambers
commit e3d2530a6cea80987f77b75d8784a00f3aaf22ff upstream.
Adding this PCI quirk fixes the board config detection.
This also fixes jack sensing by using "hp_detect=1" via properly detected
board config.
Signed-off-by: Kunal Gangakhedkar <kunal.gangakhedkar@gmail.com>
commit 0e0280dc2b0c7395a880d25544b47f3e3e3f79db upstream.
BugLink: https://launchpad.net/bugs/459083
The OR has verified with 2.6.32.11 and the latest alsa-driver stable
daily snapshot that position_fix=1 is necessary for the external mic
to work and for PulseAudio not to crash constantly.
This patch is necessary also for 2.6.32.11 and 2.6.33.2.
Reported-by: <imwithid@yahoo.com>
Tested-by: <imwithid@yahoo.com>
commit e2595322a3a353a59cecd7f57e7aa421ecb02d12 upstream.
BugLink: https://bugs.launchpad.net/bugs/479373
The OR has verified with hda-verb that the internal microphone needs
VREF50 set for audible capture.
commit 8815cd030fdd73932a791d1f06194c8db807cde7 upstream.
The Biostar mobo seems to give a wrong DMA position, resulting in
stuttering or skipping sounds on 2.6.34. Since the commit
7b3a177b0d4f92b3431b8dca777313a07533a710, "ALSA: pcm_lib: fix "something
must be really wrong" condition", makes the position check more strictly,
the DMA position problem is revealed more clearly now.
The fix is to use only LPIB for obtaining the position, i.e. passing
position_fix=1. This patch adds a static quirk to achieve it as default.
Reported-by: Frank Griffin <ftg@roadrunner.com>
Cc: Eric Piel <Eric.Piel@tremplin-utc.net>
Cc: maximilian attems <max@stro.at>
commit 32679f95cac3b1bdf27dce8b5273e06af186fd91 upstream.
This patch enables snoop, eliminating static during playback.
This patch supersedes the previous Cougar Point audio patch.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
commit d2f2fcd2541bae004db7f4798ffd9d2cb75ae817 upstream.
This patch adds the Intel Cougar Point (PCH) HD Audio Controller DeviceIDs.
commit 29aac005ff4dc8a5f50b80f4e5c4f59b21c0fb50 upstream.
usb-midi causes sometimes Oops at snd_usbmidi_output_drain() after
disconnection. This is due to the access to the endpoints which have
been already released at disconnection while the files are still alive.
This patch fixes the problem by checking disconnection state at
snd_usbmidi_output_drain() and by releasing urbs but keeping the
endpoint instances until really all freed.
Tested-by: Tvrtko Ursulin <tvrtko@ursulin.net>
commit d1501ea844eefdf925f6b711875b4b2b928fddf8 upstream.
Added the matching model for Clevo laptop M570U.
Signed-off-by: Joerg Schirottke <master@kanotix.com>
Tested-by: Maximilian Gerhard <maxbox@directbox.com>
commit b8e80cf386419453678b01bef830f53445ebb15d upstream.
BugLink: https://launchpad.net/bugs/551606
0 dB. Fix this in patch_ad1981() for all models using the Thinkpad
quirk.
Reported-by: Jane Silber
commit b0cc58a25d04160d39a80e436847eaa2fbc5aa09 upstream.
The original code doesn't take into consideration that the value of
MIXART_BA0_SIZE - pos can be less than zero which would lead to a large
unsigned value for "count".
Also I moved the check that read size is a multiple of 4 bytes below
the code that adjusts "count".
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 950200e2ff11daae1c5d9426703bdd494603f38b upstream.
BugLink: https://bugs.launchpad.net/bugs/418627
The original reporter states that this quirk is necessary to obtain
reasonable gain for playback. Without it, sound is inaudible. Tested
with playback (spkr and hp) and capture.
commit e1f7f02b45cf33a774d56e505ce1718af9392f5e upstream.
BugLink: https://launchpad.net/bugs/303789
This model needs both 'Headphone Jack Sense' and 'Line Jack Sense'
muted for audible audio, so just add its SSID to the blacklist and
don't enumerate the controls.
commit 5cd165e7057020884e430941c24454d3df9a799d upstream.
BugLink: https://launchpad.net/bugs/481058
The OR has verified that both 'Headphone Jack Sense' and 'Line Jack Sense'
need to be muted for sound to be audible, so just add the machine's SSID
to the ac97 jack sense blacklist.
commit 9ec8ddad59fadd8021adfea4cb716a49b0e232e9 upstream.
BugLink: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=575669
The OR states that position_fix=1 is necessary to work around glitching
during volume adjustments using PulseAudio.
Reported-by: Carlos Laviola <claviola@debian.org>
Tested-by: Carlos Laviola <claviola@debian.org>
commit 1c583063a5c769fe2ec604752e383972c69e6d9b upstream.
When the CMI8738 FRAME2 register is read, the chip sometimes (probably
when wrapping around) returns an invalid value that would be outside the
programmed DMA buffer. This leads to an inconsistent PCM pointer that is
likely to result in an underrun.
To work around this, read the register multiple times until we get a
valid value; the error state seems to be very short-lived.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Reported-and-tested-by: Matija Nalis <mnalis-alsadev@voyager.hr>
commit 025f206c9e0f96cc41567b01c07fb852d8900da1 upstream.
BugLink: https://launchpad.net/bugs/420578
The OR has verified that his hardware distorts because of the 0 dB
offset not corresponding to the highest PCM level. Fix this by capping
said PCM level to 0 dB similarly to what we do for CX20549 (Venice).
Reported-by: Mike Pontillo <pontillo@gmail.com>
Tested-by: Mike Pontillo <pontillo@gmail.com>
commit 9c4cc0bdede1c39bde60a0d5d9251aac71fbe719 upstream.
Fix adc_nids[] for ALC260 basic model to match with num_adc_nids.
Otherwise you get an invalid NID in the secondary "Input Source" mixer
element.
commit 80c43ed724797627d8f86855248c497a6161a214 upstream.
Judging from the member of enable_msi white-list, Nvidia controller
seems to cause troubles with MSI enabled, e.g. boot hang up or other
serious issue may come up. It's safer to disable MSI as default for
Nvidia controllers again for now.
commit 572c0e3c73341755f3e7dfaaef6b26df12bd709c upstream.
BugLink: https://bugs.launchpad.net/bugs/538895
The OR has verified that both position_fix=1 and model=6stack-dig are
necessary to have capture function properly. (The existing 3stack-6ch
model quirk seems to be incorrect.)
Reported-by: Reuben Bailey <reuben.e.bailey@gmail.com>
Tested-by: Reuben Bailey <reuben.e.bailey@gmail.com>
BugLink: https://bugs.launchpad.net/bugs/538918
The OR has verified that explicitly enabling MSI is necessary for audio
to be audible by default.
This patch is only applicable to 2.6.32.y; in 2.6.33, MSI is enabled by
default.
Reported-by: Sam Townsend <stownsend42@sbcglobal.net>
Tested-by: Sam Townsend <stownsend42@sbcglobal.net>
Acked-by: Takashi Iwai <tiwai@suse.de>
commit 5311114d4867113c00f78829d4ce14be458ec925 upstream.
Since alc_auto_create_input_ctls() doesn't set the elements for the
secondary ADCs, "Input Source" elemtns for these also get empty, resulting
in buggy outputs of alsactl like:
control.14 {
comment.access 'read write'
comment.type ENUMERATED
comment.count 1
iface MIXER
name 'Input Source'
index 1
value 0
This patch fixes alc_mux_enum_*() (and others) to fall back to the
first entry if the secondary input mux is empty.
commit e555317c083fda01f516d2153589e82514e20e70 upstream.
Don't touch the variable 'reg' to construct the value for the actual SPI
transport. This variable is again used to access the driver's register
cache, and so random memory is overwritten.
Compute the value in-place instead.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
commit 0708cc582f0fe2578eaab722841caf2b4f8cfe37 upstream.
With PulseAudio and an application accessing an input device like `gnome-volume-manager` both have high CPU load as reported in [1].
Loading `snd-hda-intel` with `position_fix=1` fixes this issue. Therefore add a quirk for ASUS M2V-MX SE.
The only downside is, when now exiting for example MPlayer when it is playing an audio file a high pitched sound is outputted by the speaker.
$ lspci -vvnn | grep -A10 Audio
20:01.0 Audio device [0403]: VIA Technologies, Inc. VT1708/A [Azalia HDAC] (VIA High Definition Audio Controller) [1106:3288] (rev 10)
Subsystem: ASUSTeK Computer Inc. Device [1043:8290]
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 17
Region 0: Memory at fbffc000 (64-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: HDA Intel
[1] http://sourceforge.net/mailarchive/forum.php?thread_name=1265550675.4642.24.camel%40mattotaupa&forum_name=alsa-user
Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net>
commit 2f703e7a2ea5f6d5ea14a7b2cd0d31be07839ac6 upstream.
HP dv3 requires position_fix=1.
Reference: Novell bnc#555935
https://bugzilla.novell.com/show_bug.cgi?id=555935
commit 45d4ebf1a6255f2234a041685789cbecac3453f1 upstream.
MSI Wind U115 seems to require position_fix=1 explicitly.
Otherwise it screws up PulseAudio.
commit 0321b69569eadbc13242922925a4316754c5f744 upstream.
BugLink: https://launchpad.net/bugs/523953
The OR has verified that position_fix=1 is necessary to work around
errors on his machine.
Reported-by: MMarking
commit 9919c7619c52d01e89103bca405cc3d4a2b1ac31 upstream.
BugLink: https://launchpad.net/bugs/530346
Reported-by: Tom Louwrier
commit d39e82db73eb876c60d00f00219d767b3be30307 upstream.
Here's a patch that adds MIDI support through USB for one of the Access
Music synths, the VirusTI.
The synth uses standard USBMIDI protocol on its USB interface 3, although
it does signal "vendor specific" class. A magic string has to be sent on
interface 3 to enable the sending of MIDI from the synth (this string was
found by sniffing usb communication of the Windows driver). This is all
my patch does, and it works on my computer.
Please note that the synth can also do standard usb audio I/O on its
interfaces 2&3, which already works with the current snd-usb-audio driver,
except for the audio input from the synth. I'm going to work on it when I
have some time.
Signed-off-by: Sebastien Alaiwan <sebastien.alaiwan@gmail.com>
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit 3be522a9514f58e0596db34898a514df206cadc5 upstream.
commit bf30a4309d4294d3eca248ea8a20c1c3570f5e74 upstream.
Add a headphones-only quirk for the Fujitsu Siemens D1289.
Reported-and-tested-by: Marc Haber <mh+alsa201002@zugschlus.de>
commit ba579eb7b30791751f556ee01905636cda50c864 upstream.
BugLink: https://bugs.launchpad.net/bugs/524948
The OR has verified that the existing model=laptop-eapd quirk does not
function correctly but instead needs model=3stack. Make this change
so that manual corrections to module-init-tools file(s) are not
required.
Reported-by: Lasse Havelund <lasse@havelund.org>
