path: root/sound
2011-12-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: atmel/ac97c: using software reset instead hardware reset if not available
2011-12-19ALSA: atmel/ac97c: using software reset instead hardware reset if not availableBo Shen
Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: HDA: Use LPIB Position fix for Intel SCH Poulsbo ALSA: hda: fix mute led polarity for HP laptops with buggy BIOS ALSA: HDA: Set position fix to LPIB for an Atom/Poulsbo based device ASoC: Fix hx4700 error handling to free gpios if snd_soc_register_card fails ASoC: WM8958: correctly show firmware magic on mismatch ASoC: mxs: Add appropriate MODULE_ALIAS() ASoC: mxs: Add missing MODULE_LICENSE("GPL") ASoC: Fix WM8996 24.576MHz clock operation ASoC: Include linux/module.h for smdk2443_wm9710 ASoC: Fix a typo in jive_wm8750 ASoC: Fix build dependency for SND_SOC_JZ4740_CODEC ASoC: Include linux/io.h for jz4740 codec
2011-12-15Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-12-15ALSA: HDA: Use LPIB Position fix for Intel SCH PoulsboDavid Henningsson
Several people with this chipset have reported inconsistent/sloppy values for position reporting when the DMA position buffer is used, and that setting position_fix=1 have fixed their problems. BugLink: https://bugs.launchpad.net/bugs/825709 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-13ALSA: hda: fix mute led polarity for HP laptops with buggy BIOSGustavo Maciel Dias Vieira
Some HP laptop models do not have a properly filled OEM string used to set the gpio and polarity of the mute led. Make the mute led configuration work for this case. Signed-off-by: Gustavo Maciel Dias Vieira <gustavo@sagui.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-12ALSA: HDA: Set position fix to LPIB for an Atom/Poulsbo based deviceDavid Henningsson
For the Asus 1101HA, reporting position by reading the DMA position buffer map seems unstable and often wrong. The reporter says that position_fix=LPIB works much better (although not 100%, but this is probably due to other issues). The controller chip is an Intel Poulsbo 8086:811b (rev 07) controller, and complete alsa-info is available here: https://launchpadlibrarian.net/86691768/alsa-info.txt.1TNwyE5Ea7 Cc: stable@kernel.org (3.0+) BugLink: http://bugs.launchpad.net/bugs/825709 Tested-by: Stefano Lodi Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-12ASoC: Fix hx4700 error handling to free gpios if snd_soc_register_card failsAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-12ASoC: WM8958: correctly show firmware magic on mismatchJonathan Neuschäfer
Signed-off-by: Jonathan Neuschäfer <j.neuschaefer@gmx.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-11ASoC: mxs: Add appropriate MODULE_ALIAS()Lothar Waßmann
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-11ASoC: mxs: Add missing MODULE_LICENSE("GPL")Lothar Waßmann
The sound driver refuses to load as module, because of the missing MODULE_LICENSE("GPL"). The file header indicates that the driver is indeed published under the GPL. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-11ASoC: Fix WM8996 24.576MHz clock operationMark Brown
Record the clock after the divider as that is what all SYSCLK users see. Without this the other clock configuration in the device comes out at half rate. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/realtek - Fix lost speaker volume controls ALSA: hda/realtek - Create "Bass Speaker" for two speaker pins ALSA: hda/realtek - Don't create extra controls with channel suffix ALSA: hda - Fix remaining VREF mute-LED NID check in post-3.1 changes ALSA: hda - Fix GPIO LED setup for IDT 92HD75 codecs ASoC: Provide a more complete DMA driver stub ASoC: Remove references to corgi and spitz from machine driver document ASoC: Make SND_SOC_MX27VIS_AIC32X4 depend on I2C ASoC: Fix dependency for SND_SOC_RAUMFELD and SND_PXA2XX_SOC_HX4700 ASoC: uda1380: Return proper error in uda1380_modinit failure path ASoC: kirkwood: Make SND_KIRKWOOD_SOC_OPENRD and SND_KIRKWOOD_SOC_T5325 depend on I2C ASoC: Mark WM8994 ADC muxes as virtual ALSA: hda/realtek - Fix Oops in alc_mux_select() ALSA: sis7019 - give slow codecs more time to reset
2011-12-07ALSA: hda/realtek - Fix lost speaker volume controlsTakashi Iwai
When there are the same or more number of HP pins are available, HP pins are used as the primary outputs instead of the speaker pins. But, in some cases (especially with ALC663 & co), some DACs are available only with a later pin and it's assigned to a speaker, and since the driver parses the pins from the lower NID, such a DAC was skipped eventually without assignments. This resulted in a regression, the missing speaker volume control in the new parser. As a workaround for this, now the driver retries the pin->DAC mapping again after restoring the speaker-pins as primary. This is still an ad hoc fix, but it works so far for most of Realtek codecs. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-07ALSA: hda/realtek - Create "Bass Speaker" for two speaker pinsTakashi Iwai
On systems with two speaker pins, the secondary speaker pin is mostly assigned to a bass speaker instead of a surround. Thus it makes more sense to rename the control properly. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-07ALSA: hda/realtek - Don't create extra controls with channel suffixTakashi Iwai
The multiple headphone or speaker pins are usually provided to output the same stream unlike line-out jacks (which are supposed to be multi-channel surrounds). Thus giving a mixer name like "Headphone Surround" is rather confusing. Instead, when multiple headphone volumes are available, use index with the same "Headphone" name. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-08ASoC: Include linux/module.h for smdk2443_wm9710Axel Lin
Include linux/module.h to fix below build error: CC sound/soc/samsung/smdk2443_wm9710.o sound/soc/samsung/smdk2443_wm9710.c:64: error: expected declaration specifiers or '...' before string constant sound/soc/samsung/smdk2443_wm9710.c:64: warning: data definition has no type or storage class sound/soc/samsung/smdk2443_wm9710.c:64: warning: type defaults to 'int' in declaration of 'MODULE_AUTHOR' sound/soc/samsung/smdk2443_wm9710.c:64: warning: function declaration isn't a prototype sound/soc/samsung/smdk2443_wm9710.c:65: error: expected declaration specifiers or '...' before string constant sound/soc/samsung/smdk2443_wm9710.c:65: warning: data definition has no type or storage class sound/soc/samsung/smdk2443_wm9710.c:65: warning: type defaults to 'int' in declaration of 'MODULE_DESCRIPTION' sound/soc/samsung/smdk2443_wm9710.c:65: warning: function declaration isn't a prototype sound/soc/samsung/smdk2443_wm9710.c:66: error: expected declaration specifiers or '...' before string constant sound/soc/samsung/smdk2443_wm9710.c:66: warning: data definition has no type or storage class sound/soc/samsung/smdk2443_wm9710.c:66: warning: type defaults to 'int' in declaration of 'MODULE_LICENSE' sound/soc/samsung/smdk2443_wm9710.c:66: warning: function declaration isn't a prototype make[3]: *** [sound/soc/samsung/smdk2443_wm9710.o] Error 1 make[2]: *** [sound/soc/samsung] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-08ASoC: Fix a typo in jive_wm8750Axel Lin
Fix a typo in jive_wm8750 that introduces below build error. Also removes an unused err variable. CC sound/soc/samsung/jive_wm8750.o sound/soc/samsung/jive_wm8750.c: In function 'jive_wm8750_init': sound/soc/samsung/jive_wm8750.c:104: warning: unused variable 'err' sound/soc/samsung/jive_wm8750.c: At top level: sound/soc/samsung/jive_wm8750.c:134: error: unknown field 'dapm_widgtets' specified in initializer sound/soc/samsung/jive_wm8750.c:134: warning: initialization from incompatible pointer type make[3]: *** [sound/soc/samsung/jive_wm8750.o] Error 1 make[2]: *** [sound/soc/samsung] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-06Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-12-06ALSA: hda - Fix remaining VREF mute-LED NID check in post-3.1 changesTakashi Iwai
2011-12-06Merge branch 'fix/hda-idt-fix' into fix/hdaTakashi Iwai
2011-12-06ALSA: hda - Fix GPIO LED setup for IDT 92HD75 codecsTakashi Iwai
Some HP laptops with IDT 92HD75 codecs may use a GPIO > 4 for the mute LED, but currently the driver doesn't check this properly, and confuses the mute LED behavior. This ended up with the silent output on some HP laptops due to having another GPIO used as external amp control. This patch fixes the problem by checking the max GPIO count and comparing with the given value from DMI entry instead of magic fixed value 4 and 8, and adding a new field to indicate the VREF mute-LED behavior. Reported-and-tested-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Cc: <stable@kernel.org> [v3.1] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-06ASoC: Fix build dependency for SND_SOC_JZ4740_CODECAxel Lin
Currently SND_SOC_JZ4740_CODEC depends on SOC_JZ4740 but SOC_JZ4740 is not defined in any Kconfig. Thus the codec driver will not be built when select "Build all ASoC CODEC drivers". (Unless it is selected by SND_JZ4740_SOC_QI_LB60). Remove the dependency with SOC_JZ4740, then this code driver can be built when select "Build all ASoC CODEC drivers". Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-06ASoC: Include linux/io.h for jz4740 codecAxel Lin
Include linux/io.h to fix below build errors: CC sound/soc/codecs/jz4740.o sound/soc/codecs/jz4740.c: In function 'jz4740_codec_read': sound/soc/codecs/jz4740.c:82: error: implicit declaration of function 'readl' sound/soc/codecs/jz4740.c: In function 'jz4740_codec_write': sound/soc/codecs/jz4740.c:92: error: implicit declaration of function 'writel' sound/soc/codecs/jz4740.c: In function 'jz4740_codec_probe': sound/soc/codecs/jz4740.c:373: error: implicit declaration of function 'ioremap' sound/soc/codecs/jz4740.c:373: warning: assignment makes pointer from integer without a cast sound/soc/codecs/jz4740.c:393: error: implicit declaration of function 'iounmap' make[3]: *** [sound/soc/codecs/jz4740.o] Error 1 make[2]: *** [sound/soc/codecs] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-06ASoC: Provide a more complete DMA driver stubMark Brown
Allow userspace applications to do more parameter setting by providing a more complete stub DMA driver specifying a wildcard set of formats and channels and essentially random values for the DMA parameters. This is required for useful runtime operation of the dummy DMA driver until we are able to figure out how to power up links and do hw_params() from DAPM. Sending to stable as without this the dummy driver is not terribly useful. Reported-by: Kyung-Kwee Ryu <Kyung-Kwee.Ryu@wolfsonmicro.com> Tested-by: Kyung-Kwee Ryu <Kyung-Kwee.Ryu@wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@kernel.org
2011-12-04ASoC: Make SND_SOC_MX27VIS_AIC32X4 depend on I2CAxel Lin
SND_SOC_MX27VIS_AIC32X4 selects SND_SOC_TLV320AIC32X4, but SND_SOC_TLV320AIC32X4 needs CONFIG_I2C. So we need to make SND_SOC_MX27VIS_AIC32X4 depend on I2C. otherwise I got below build error if CONFIG_I2C is not selected. CC sound/soc/codecs/tlv320aic32x4.o sound/soc/codecs/tlv320aic32x4.c: In function 'aic32x4_read': sound/soc/codecs/tlv320aic32x4.c:323: error: implicit declaration of function 'i2c_smbus_read_byte_data' sound/soc/codecs/tlv320aic32x4.c: In function 'aic32x4_probe': sound/soc/codecs/tlv320aic32x4.c:641: error: 'i2c_master_send' undeclared (first use in this function) sound/soc/codecs/tlv320aic32x4.c:641: error: (Each undeclared identifier is reported only once sound/soc/codecs/tlv320aic32x4.c:641: error: for each function it appears in.) sound/soc/codecs/tlv320aic32x4.c: In function 'aic32x4_modinit': sound/soc/codecs/tlv320aic32x4.c:763: error: implicit declaration of function 'i2c_add_driver' sound/soc/codecs/tlv320aic32x4.c: In function 'aic32x4_exit': sound/soc/codecs/tlv320aic32x4.c:774: error: implicit declaration of function 'i2c_del_driver' make[3]: *** [sound/soc/codecs/tlv320aic32x4.o] Error 1 make[2]: *** [sound/soc/codecs] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-04ASoC: Fix dependency for SND_SOC_RAUMFELD and SND_PXA2XX_SOC_HX4700Axel Lin
SND_SOC_RAUMFELD selects SND_SOC_CS4270 which needs CONFIG_I2C, and also selects SND_SOC_AK4104 which needs SPI_MASTER. Thus make SND_SOC_RAUMFELD depend on I2C && SPI_MASTER. Add depend on SPI_MASTER to fix below build error if CONFIG_SPI_MASTER is not selected. LD .tmp_vmlinux1 sound/built-in.o: In function `ak4104_spi_write': last.c:(.text+0x290cc): undefined reference to `spi_sync' sound/built-in.o: In function `ak4104_probe': last.c:(.text+0x292a0): undefined reference to `spi_write_then_read' sound/built-in.o: In function `ak4104_spi_probe': last.c:(.text+0x29398): undefined reference to `spi_setup' sound/built-in.o: In function `ak4104_init': last.c:(.init.text+0x4ec): undefined reference to `spi_register_driver' make: *** [.tmp_vmlinux1] Error 1 Add depend on I2C to fix below build error if CONFIG_I2C is not selected: CC sound/soc/codecs/cs4270.o sound/soc/codecs/cs4270.c: In function 'cs4270_i2c_probe': sound/soc/codecs/cs4270.c:657: error: implicit declaration of function 'i2c_smbus_read_byte_data' sound/soc/codecs/cs4270.c: In function 'cs4270_init': sound/soc/codecs/cs4270.c:730: error: implicit declaration of function 'i2c_add_driver' sound/soc/codecs/cs4270.c: In function 'cs4270_exit': sound/soc/codecs/cs4270.c:736: error: implicit declaration of function 'i2c_del_driver' make[3]: *** [sound/soc/codecs/cs4270.o] Error 1 make[2]: *** [sound/soc/codecs] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 SND_PXA2XX_SOC_HX4700 selects SND_SOC_AK4641 which needs CONFIG_I2C. Thus make SND_PXA2XX_SOC_HX4700 depend on I2C. Add depend on I2C to fix below build error if CONFIG_I2C is not selected: CC sound/soc/codecs/ak4641.o sound/soc/codecs/ak4641.c: In function 'ak4641_modinit': sound/soc/codecs/ak4641.c:646: error: implicit declaration of function 'i2c_add_driver' sound/soc/codecs/ak4641.c: In function 'ak4641_exit': sound/soc/codecs/ak4641.c:656: error: implicit declaration of function 'i2c_del_driver' make[3]: *** [sound/soc/codecs/ak4641.o] Error 1 make[2]: *** [sound/soc/codecs] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-04ASoC: uda1380: Return proper error in uda1380_modinit failure pathAxel Lin
Return proper error for uda1380_modinit if i2c_add_driver() fails. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-03ASoC: kirkwood: Make SND_KIRKWOOD_SOC_OPENRD and SND_KIRKWOOD_SOC_T5325 ↵Axel Lin
depend on I2C SND_KIRKWOOD_SOC_T5325 selects SND_SOC_ALC5623, but SND_SOC_ALC5623 needs CONFIG_I2C. So we need to make SND_KIRKWOOD_SOC_T5325 depend on I2C, otherwise I got below build error if CONFIG_I2C is not selected. CC sound/soc/codecs/alc5623.o sound/soc/codecs/alc5623.c: In function 'alc5623_i2c_probe': sound/soc/codecs/alc5623.c:1002: error: implicit declaration of function 'i2c_smbus_read_word_data' sound/soc/codecs/alc5623.c:1009: error: implicit declaration of function 'i2c_smbus_read_byte_data' sound/soc/codecs/alc5623.c: In function 'alc5623_modinit': sound/soc/codecs/alc5623.c:1096: error: implicit declaration of function 'i2c_add_driver' sound/soc/codecs/alc5623.c: In function 'alc5623_modexit': sound/soc/codecs/alc5623.c:1108: error: implicit declaration of function 'i2c_del_driver' make[3]: *** [sound/soc/codecs/alc5623.o] Error 1 make[2]: *** [sound/soc/codecs] Error 2 make[1]: *** [sound/soc] Error 2 make: *** [sound] Error 2 Also fix the same issue for SND_KIRKWOOD_SOC_OPENRD. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-02ASoC: Mark WM8994 ADC muxes as virtualMark Brown
Since they don't actually have power bits but do have events associated with them it's important that we bootstrap their state properly which making them virtual does. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Fix S3/S4 problem on machines with VREF-pin mute-LED ALSA: hda_intel - revert a quirk that affect VIA chipsets ALSA: hda - Avoid touching mute-VREF pin for IDT codecs firmware: Sigma: Fix endianess issues firmware: Sigma: Skip header during CRC generation firmware: Sigma: Prevent out of bounds memory access ALSA: usb-audio - Support for Roland GAIA SH-01 Synthesizer ASoC: Supply dcs_codes for newer WM1811 revisions ASoC: Error out if we can't generate a LRCLK at all for WM8994 ASoC: Correct name of Speyside Main Speaker widget ASoC: skip resume of soc-audio devices without codecs ASoC: cs42l51: Fix off-by-one for reg_cache_size ASoC: drop support for PlayPaq with WM8510 ASoC: mpc8610: tell the CS4270 codec that it's the master ASoC: cs4720: use snd_soc_cache_sync() ASoC: SAMSUNG: Fix build error ASoC: max9877: Update register if either val or val2 is changed ASoC: Fix wrong define for AD1836_ADC_WORD_OFFSET
2011-12-02ALSA: hda/realtek - Fix Oops in alc_mux_select()Takashi Iwai
When no imux is available (e.g. a single capture source), alc_auto_init_input_src() may trigger an Oops due to the access to -1. Add a proper zero-check to avoid it. Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-02ALSA: sis7019 - give slow codecs more time to resetDavid Dillow
There are some AC97 codec and board combinations that have been observed to take a very long time to respond after the cold reset has completed. In one case, more than 350 ms was required. To allow users to have sound on those platforms, we'll wait up to 500ms for the codec to become ready. As a board may have multiple codecs, with some faster than others to reset, we add a module parameter to inform the driver which codecs should be present. Reported-by: KotCzarny <tjosko@yahoo.com> Signed-off-by: David Dillow <dave@thedillows.org> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-12-01Merge branch 'fixes' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'fixes' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: ARM: 7182/1: ARM cpu topology: fix warning ARM: 7181/1: Restrict kprobes probing SWP instructions to ARMv5 and below ARM: 7180/1: Change kprobes testcase with unpredictable STRD instruction ARM: 7177/1: GIC: avoid skipping non-existent PPIs in irq_start calculation ARM: 7176/1: cpu_pm: register GIC PM notifier only once ARM: 7175/1: add subname parameter to mfp_set_groupg callers ARM: 7174/1: Fix build error in kprobes test code on Thumb2 kernels ARM: 7172/1: dma: Drop GFP_COMP for DMA memory allocations ARM: 7171/1: unwind: add unwind directives to bitops assembly macros ARM: 7170/2: fix compilation breakage in entry-armv.S ARM: 7168/1: use cache type functions for arch_get_unmapped_area ARM: perf: check that we have a platform device when reserving PMU ARM: 7166/1: Use PMD_SHIFT instead of PGDIR_SHIFT in dma-consistent.c ARM: 7165/2: PL330: Fix typo in _prepare_ccr() ARM: 7163/2: PL330: Only register usable channels ARM: 7162/1: errata: tidy up Kconfig options for PL310 errata workarounds ARM: 7161/1: errata: no automatic store buffer drain ARM: perf: initialise used_mask for fake PMU during validation ARM: PMU: remove pmu_init declaration ARM: PMU: re-export release_pmu symbol to modules
2011-12-01Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-12-01ALSA: hda - Fix S3/S4 problem on machines with VREF-pin mute-LEDCharles Chin
The verb command in stac92xx_post_suspend caused the audio to stop working after resuming from S3 mode on HP laptops with the VREF-pin mute-LED control. Removing relevant post_suspend registering. Although removing D3 on AFG is no optimal solution, the impact should be small in comparison with the broken S3/S4. Signed-off-by: Charles Chin <Charles.Chin@idt.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-29ALSA: hda_intel - revert a quirk that affect VIA chipsetsMarc Vertes
This quirk sould be reverted. It has the following probems: 1) The quirk was intended to "ASUS MV2-MX SE" motherboards only, but the ID used matches a much broader range, potentially all boards containing a VIA chipset model in the family of vendor VIA 0x1106 and audio device ID 0x3288, which encompasses VIA-VT82xx, VIA-VT1xx and VIA-VT20xx chipsets. 2) VIA chipsets rely on azx_via_get_position() to handle correctly dma transfers during capture. Using POS_FIX_LPIB instead of POS_FIX_VIACOMBO leads to partially corrupted input buffers during capture. The effects of this bug are not immediately visible, it took strong DSP expertise, some expensive signal generator and a spectrum analyzer to identify it and verify correct behaviour using original default. 3) It's almost certain that the quirk did not fix the real problem, if there was one. Refer to original submission: http://mailman.alsa-project.org/pipermail/alsa-devel/2010-February/025109.html Signed-of-by: Marc Vertes <mvertes@sigfox.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-29ALSA: hda - Avoid touching mute-VREF pin for IDT codecsTakashi Iwai
Some HP laptops use a pin VREF for controlling the mute LED, and such a pin shouldn't be powered off. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-29ALSA: usb-audio - Support for Roland GAIA SH-01 SynthesizerJohn F Leach
Added table quirks entry for Roland GAIA SH-01 Synthesizer based upon Roland SH-201 table entry as template. USB MIDI and audio was tested with Muse and Audacity. Signed-off-by: John F Leach <jfleach@jfleach.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-28ASoC: Supply dcs_codes for newer WM1811 revisionsMark Brown
Based on initial data. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-28ASoC: Error out if we can't generate a LRCLK at all for WM8994Mark Brown
2011-11-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (28 commits) ALSA: hda - Fix jack-detection control of VT1708 ALSA: hda - cut and paste typo in cs420x_models[] ALSA: hda/realtek - Minor cleanup ALSA: hda/realtek - Fix missing inits of item indices for auto-mic ALSA: hda - Fix invalid pin and GPIO for Apple laptops with CS codecs ALSA: hda - Check subdevice mask in snd_hda_check_board_codec_sid_config() ALSA: hda - fail ELD reading early ALSA: lx6464es - fix device communication via command bus ALSA: lx6464es - command buffer API cleanup ALSA: hda - repoll ELD content for multiple times ALSA: hdspm - Fix PCI ID for PCIe RME MADI cards ASoC: Ensure WM8731 register cache is synced when resuming from disabled ALSA: cs5535 - Fix an endianness conversion ASoC: cs4271: Fix wrong mask parameter in some snd_soc_update_bits calls ASoC: wm_hubs: fix DB_RANGE size ASoC: wm9090: fix DB_RANGE size ASoC: wm8993: fix DB_RANGE size ASoC: wm8962: fix DB_RANGE size ASoC: sgtl5000: fix DB_RANGE size ASoC: rt5631: fix DB_RANGE size ...
2011-11-27Merge branch 'fix/hda' into for-linusTakashi Iwai
2011-11-27ALSA: hda - Fix jack-detection control of VT1708Takashi Iwai
VT1708 has no support for unsolicited events per jack-plug, the driver implements the workq for polling the jack-detection. The mixer element "Jack Detect" was supposed to control this behavior on/off, but this doesn't work properly as is now. The workq is always started and the HP automute is always enabled. This patch fixes the jack-detect control behavior by triggering / stopping the work appropriately at the state change. Also the work checks the internal state to continue scheduling or not. Cc: <stable@kernel.org> [v3.1] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-27ALSA: hda - cut and paste typo in cs420x_models[]Dan Carpenter
The CS420X_IMAC27 was copied from the line before but CS420X_APPLE was clearly intented. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-27ASoC: Correct name of Speyside Main Speaker widgetMark Brown
2011-11-26ARM: 7175/1: add subname parameter to mfp_set_groupg callersAxel Lin
commit 798681bf "ARM: 7158/1: add new MFP implement for NUC900" adds subname parameter for mfp_set_groupg. Thus add subname parameter to the callers. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Wan Zongshun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-23Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-11-23ASoC: skip resume of soc-audio devices without codecsEric Miao
There are cases where there is no working codec on the soc-audio devices, and snd_soc_suspend() will skip such device when suspending. Yet its counterpart snd_soc_resume() does not check this, causing complaints about spinlock lockup: [ 176.726087] BUG: spinlock lockup on CPU#0, kworker/0:2/1067, d8ab82a8 [ 176.732539] [<80014a14>] (unwind_backtrace+0x0/0xec) from [<805b3fc8>] (dump_stack+0x20/0x24) [ 176.741082] [<805b3fc8>] (dump_stack+0x20/0x24) from [<80322208>] (do_raw_spin_lock+0x118/0x158) [ 176.749882] [<80322208>] (do_raw_spin_lock+0x118/0x158) from [<805b7874>] (_raw_spin_lock_irqsave+0x5c/0x68) [ 176.759723] [<805b7874>] (_raw_spin_lock_irqsave+0x5c/0x68) from [<8002a020>] (__wake_up+0x2c/0x5c) [ 176.768781] [<8002a020>] (__wake_up+0x2c/0x5c) from [<804a6de8>] (soc_resume_deferred+0x3c/0x2b0) [ 176.777666] [<804a6de8>] (soc_resume_deferred+0x3c/0x2b0) from [<8004ee20>] (process_one_work+0x2e8/0x50c) [ 176.787334] [<8004ee20>] (process_one_work+0x2e8/0x50c) from [<8004fd08>] (worker_thread+0x1c8/0x2e0) [ 176.796566] [<8004fd08>] (worker_thread+0x1c8/0x2e0) from [<80053ec8>] (kthread+0xa4/0xb0) [ 176.804843] [<80053ec8>] (kthread+0xa4/0xb0) from [<8000ea70>] (kernel_thread_exit+0x0/0x8) Signed-off-by: Eric Miao <eric.miao@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23ASoC: cs42l51: Fix off-by-one for reg_cache_sizeAxel Lin
Just checking the code in cs42l51_fill_cache(): The cache pointer points to codec->reg_cache + 1. I think it is because CS42L51_FIRSTREG is 0x01, so codec->reg_cache[0] is not used here. Then we read CS42L51_NUMREGS bytes to cache. So we need reg_cache_size to be CS42L51_NUMREGS + 1. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
