commit e03fa055bc126e536c7f65862e08a9b143138ea9 upstream.
Sjoerd Simons reports that, without using position_fix=1, recording
experiences overruns. Work around that by applying the LPIB quirk
for his hardware.
Reported-and-tested-by: Sjoerd Simons <sjoerd@debian.org>
Signed-off-by: Daniel T Chen <crimsun@ubuntu.com>
commit 9919c7619c52d01e89103bca405cc3d4a2b1ac31 upstream.
BugLink: https://launchpad.net/bugs/530346
The OR has verified that position_fix=1 is necessary to work around
errors on his machine.
Reported-by: Tom Louwrier
commit d81a12bc29ae4038770e05dce4ab7f26fd5880fb upstream.
The load_mixer_volumes() function, which can be triggered by
unprivileged users via the SOUND_MIXER_SETLEVELS ioctl, is vulnerable to
a buffer overflow. Because the provided "name" argument isn't
guaranteed to be NULL terminated at the expected 32 bytes, it's possible
to overflow past the end of the last element in the mixer_vols array.
Further exploitation can result in an arbitrary kernel write (via
subsequent calls to load_mixer_volumes()) leading to privilege
escalation, or arbitrary kernel reads via get_mixer_levels(). In
addition, the strcmp() may leak bytes beyond the mixer_vols array.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
commit 77c4d5cdb81d25a45fbdfb84dd3348121219a072 upstream.
BugLink: https://launchpad.net/bugs/595482
The original reporter states that audible playback from the internal
speaker is inaudible despite the hardware being properly detected. To
work around this symptom, he uses the model=lg quirk to properly enable
both playback, capture, and jack sense. Another user corroborates this
workaround on separate hardware. Add this PCI SSID to the quirk table
to enable it for further LG P1 Expresses.
Reported-and-tested-by: Philip Peitsch <philip.peitsch@gmail.com>
Tested-by: nikhov
commit 0defe09ca70daccdc83abd9c3c24cd89ae6a1141 upstream.
BugLink: https://launchpad.net/bugs/683695
The original reporter states that headphone jacks do not appear to
work. Upon inspecting his codec dump, and upon further testing, it is
confirmed that the "alienware" model quirk is correct.
Reported-and-tested-by: Cody Thierauf
commit cc1c452e509aefc28f7ad2deed75bc69d4f915f7 upstream.
The patch enables ALC887-VD to use the DAC at nid 0x26,
which makes it possible to use this DAC for e g Headphone
volume.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
controls
commit 0613a59456980161d0cd468bae6c63d772743102 upstream.
BugLink: https://launchpad.net/bugs/669279
The original reporter states: "The Master mixer does not change the
volume from the headphone output (which is affected by the headphone
mixer). Instead it only seems to control the on-board speaker volume.
This confuses PulseAudio greatly as the Master channel is merged into
the volume mix."
Fix this symptom by applying the hp_only quirk for the reporter's SSID.
The fix is applicable to all stable kernels.
Reported-and-tested-by: Ben Gamari <bgamari@gmail.com>
commit aa73aec6c385e2c797ac25cc7ccf0318031de7c8 upstream.
When a driver module is unloaded and the last still open file is a raw
MIDI device, the card and its devices will be actually freed in the
snd_card_file_remove() call when that file is closed. Afterwards, rmidi
and rmidi->card point into freed memory, so the module pointer is likely
to be garbage.
(This was introduced by commit 9a1b64caac82aa02cb74587ffc798e6f42c6170a.)
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Reported-by: Krzysztof Foltman <wdev@foltman.com>
commit 5591bf07225523600450edd9e6ad258bb877b779 upstream.
The snd_ctl_new() function in sound/core/control.c allocates space for a
snd_kcontrol struct by performing arithmetic operations on a
user-provided size without checking for integer overflow. If a user
provides a large enough size, an overflow will occur, the allocated
chunk will be too small, and a second user-influenced value will be
written repeatedly past the bounds of this chunk. This code is
reachable by unprivileged users who have permission to open
a /dev/snd/controlC* device (on many distros, this is group "audio") via
the SNDRV_CTL_IOCTL_ELEM_ADD and SNDRV_CTL_IOCTL_ELEM_REPLACE ioctls.
commit 0f9f1ee9d1412d45a22bfd69dfd4d4324b506e9e upstream.
BugLink: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/643891
Set the Dell Latitude E6400 (1028:0233) SSID to use AD1984_DELL_DESKTOP
Signed-off-by: Luke Yelavich <luke.yelavich@canonical.com>
commit 0873a5ae747847ee55a63db409dff3476e45bcd9 upstream.
On the HT-Omega Claro halo card, the ADC data must be captured from the
second I2S input. Using the default first input, which isn't connected
to anything, would result in silence.
Signed-off-by: Erik J. Staab <ejs@insightbb.com>
commit e68d3b316ab7b02a074edc4f770e6a746390cb7d upstream.
The SNDRV_HDSP_IOCTL_GET_CONFIG_INFO and
SNDRV_HDSP_IOCTL_GET_CONFIG_INFO ioctls in hdspm.c and hdsp.c allow
unprivileged users to read uninitialized kernel stack memory, because
several fields of the hdsp{m}_config_info structs declared on the stack
are not altered or zeroed before being copied back to the user. This
patch takes care of it.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
commit b08b1637ce1c0196970348bcabf40f04b6b3d58e upstream.
The pin NID 0x1a should be handled as well as NID 0x1b.
Also added comments.
Cc: David Henningsson <david.henningsson@canonical.com>
commit 5d4abf93ea3192cc666430225a29a4978c97c57d upstream.
Since ALC259/269 use the same parser of ALC268, the pin 0x1b was ignored
as an invalid widget. Just add this NID to handle properly.
This will add the missing mixer controls for some devices.
commit 27f7ad53829f79e799a253285318bff79ece15bd upstream.
The error handling in snd_seq_oss_open() has several bad codes that
do dereferecing released pointers and double-free of kmalloc'ed data.
The object dp is release in free_devinfo() that is called via
private_free callback. The rest shouldn't touch this object any more.
The patch changes delete_port() to call kfree() in any case, and gets
rid of unnecessary calls of destructors in snd_seq_oss_open().
Fixes CVE-2010-3080.
Reported-and-tested-by: Tavis Ormandy <taviso@cmpxchg8b.com>
commit 531d8791accf1464bc6854ff69d08dd866189d17 upstream.
ALC269vb has an alternative HP pin 0x21 in addition.
Fix the parser to recognize it.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit 150b432f448281d5518f5229d240923f9a9c5459 upstream.
The non-standard name "iMic" makes PulseAudio ignore the microphone.
BugLink: https://launchpad.net/bugs/605101
commit 9c77b846ec8b4e0c7107dd7f820172462dc84a61 upstream.
BugLink: https://bugs.launchpad.net/bugs/619439
This ThinkPad model needs External Amplifier muted for audible playback,
so set the inv_eapd quirk for it.
Reported-and-tested-by: Dennis Bell <dennis.bell@parkerg.co.uk>
commit 53bacfbbb2ddd981287b58a511c8b8f5df179886 upstream.
I discovered tonight that ALSA no longer sets up a stream for the second ADC
provided by the Realtek ALC260 HDA codec. At some point alc_build_pcms()
started using stream_analog_alt_capture when constructing the second ADC
stream, but patch_alc260() was never updated accordingly. I have no idea
when this regression occurred. The trivial patch to patch_alc260() given
below fixes the problem as far as I can tell. The patch is against 2.6.35.
Signed-off-by: Jonathan Woithe <jwoithe@physics.adelaide.edu.au>
commit 56385a12d9bb9e173751f74b6c430742018cafc0 upstream.
With some hardware combinations, the PCM interrupts are acknowledged
before the period boundary from the emu10k1 chip. The midlevel PCM code
gets confused and the playback stream is interrupted.
It seems that the interrupt processing shift by 2 samples is enough
to fix this issue. This default value does not harm other,
non-affected hardware.
More information: Kernel bugzilla bug#16300
[A copmile warning fixed by tiwai]
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit a5ba6beb839cfa288960c92cd2668a2601c24dda upstream.
The detection and loading of firmeware on riptide driver has been broken
due to rewrite of some codes, checking the presense wrongly.
This patch fixes the logic again.
Reference: kernel bug 16596
https://bugzilla.kernel.org/show_bug.cgi?id=16596
commit b2c1e07b81a126e5846dfc3d36f559d861df59f4 upstream.
This is not supported by current hardware revisions.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
commit 4f0ed9a51bc8ef16c2589112fdb110479e4b0df1 upstream.
commit b721e68bdc5b39c51bf6a1469f8d3663fbe03243 upstream.
This patch fixes a division by zero error in the irq handler.
There is a small window between the hw_params() callback and when
runtime->frame_bits is set by ALSA middle layer. When another substream is
already running, if an interrupt is delivered during that window the irq
handler calls pcm_pointer() which does a division by zero. The patch below
makes the irq handler skip substreams that are initialized but not started
yet. Cc to Clemens Ladisch because he proposed an alternate fix.
For more information, please read the original thread in the linux-kernel
mailing list: http://lkml.org/lkml/2010/2/2/187
Signed-off-by: Giuliano Pochini <pochini@shiny.it>
commit 3c0709396df0869786f83e4b2d2d687c70ee886d upstream.
commit 3bfea98ff73d377ffce0d4c7f938b7ef958cdb35 upstream.
BugLink: https://bugs.launchpad.net/bugs/463178
Set Macbook 5,2 (106b:4a00) hardware to use ALC885_MB5
commit 9f75c1b12c5ef392ddcea575b13560842c28b1b3 upstream.
BugLink: https://launchpad.net/bugs/587546
Symptom: On the reporter's ASUS M2V, using PulseAudio in Ubuntu 10.04 LTS
results in the PA daemon crashing shortly after attempting playback of an
audio file.
Test case: Using Ubuntu 10.04 LTS (Linux 2.6.32.12), Linux 2.6.33, or
Linux 2.6.34, attempt playback of an audio file while PulseAudio is
active.
Resolution: add SSID for this machine to the position_fix quirk table,
explicitly specifying the LPIB method.
Reported-and-Tested-By: D Tangman
commit b90c076424da8166797bdc34187660fd0124f530 upstream.
BugLink: https://launchpad.net/bugs/580749
Symptom: on the original reporter's VIA VT1708-based board, the
PulseAudio daemon dies shortly after the user attempts to play an audio
file.
Test case: boot from Ubuntu 10.04 LTS live cd; attempt to play an audio
file.
Resolution: add SSID for the original reporter's hardware to the
position_fix quirk table, explicitly specifying the LPIB method.
Reported-and-Tested-By: Harald
commit 26fd74fc01991a18f0e3bd54f8b1b75945ee3dbb upstream.
BugLink: https://launchpad.net/bugs/542550
Symptom: On the reporter's iMac, in Ubuntu 10.04 LTS neither playback
nor capture appear audible out-of-the-box.
Test case: Boot from an Ubuntu 10.04 LTS live cd or from an installed
configuration and attempt to play or capture audio.
Resolution: Specify the mb31 quirk for this machine in the codec SSID
table.
Reported-and-Tested-By: f3a97
commit dd37f8e8659bc617c3f2a84e007a4824ccdac458 upstream.
BugLink: https://launchpad.net/bugs/465942
Symptom: On the reporter's ASUS device, using PulseAudio in Ubuntu 10.04
LTS results in the PA daemon crashing shortly after attempting to select
capture or to configure the audio hardware profile.
Linux 2.6.34, adjust the HDA device's capture volume with PulseAudio.
Reported-and-Tested-By: Irihapeti
commit f68596c6d8711650722b2a54328a088a2c21bc5b upstream.
These should be regular, not linear.
commit 3351e9fbb0fda6498ee149ee88c67f5849813c57 upstream.
These scales should be regular, not linear.
commit e6a08c5a8990102bcd1f4bae84b668da6c23caa9 upstream.
These should be regular rather than linear scales.
commit 61bb42c37dfa9016dcacc86bcd41362ab2457d4a upstream.
BugLink: https://launchpad.net/bugs/551949
Symptom: On the reporter's Shuttle device, using PulseAudio in Ubuntu
10.04 LTS results in "popping clicking" audio with the PA crashing
shortly thereafter.
Linux 2.6.34, adjust the HDA device's volume with PulseAudio.
Reported-and-Tested-By: Christian Mehlis <mehlis@inf.fu-berlin.de>
commit e96d3127760a2fc509bca6bf7e61e8bc61497aeb upstream.
BugLink: https://launchpad.net/bugs/586347
Symptom: On the Sony VPCS11V9E, using GStreamer-based applications with
PulseAudio in Ubuntu 10.04 LTS results in stuttering audio. It appears
to worsen with increased I/O.
Test case: use Rhythmbox under increased I/O pressure. This symptom is
reproducible in the current daily stable alsa-driver snapshots (at least
up until 21 May 2010; later snapshots fail to build from source due to
missing preprocessor directives when compiled against 2.6.32).
Reported-and-Tested-By: Lauri Kainulainen <lauri@sokkelo.net>
commit 7a68be94e22e7643038726ebc14360752a91800b upstream.
BugLink: https://launchpad.net/bugs/583983
Symptom: on a significant number of hardware, booting from a live cd
results in capture working correctly, but once the distribution is
installed, booting from the install results in capture not working.
Test case: boot from Ubuntu 10.04 LTS live cd; capture works correctly.
Install to HD and reboot; capture does not work. Reproduced with 2.6.32
mainline build (vanilla kernel.org compile).
Resolution: add SSID for Acer Aspire 5110 to the position_fix quirk
I'll be sending additional patches for these SSIDs as bug reports are
confirmed.
Reported-and-Tested-By: Leo
commit 4e0938dba7fccf37a4aecba4d937da7f312b5d55 upstream.
BugLink: https://launchpad.net/bugs/549560
Resolution: add SSID for Toshiba A100-259 to the position_fix quirk
confirmed.
This patch also trivially sorts the quirk table in ascending order by
subsystem vendor.
Reported-and-Tested-by: <davide.molteni@gmail.com>
commit 66668b6fb6861fad7f6bfef6646ac84693474c9a upstream.
BugLink: https://launchpad.net/bugs/576160
Symptom: Currently (2.6.32.12) the Dell M1730 uses the 3stack model
quirk. Unfortunately this means that capture is not functional out-
of-the-box despite ensuring that capture settings are unmuted and
raised fully.
Test case: boot from Ubuntu 10.04 LTS live cd; capture does not
work.
Resolution: Correct the model quirk for Dell M1730 to rely on the
BIOS configuration.
This patch also trivially sorts the quirk into the correct section
based on the comments.
Reported-and-Tested-By: <picdragon99@msn.com>
Tested-By: Daren Hayward
Tested-By: Tobias Krais
commit c602c8ad45d6ee6ad91fc544513cc96f70790983 upstream.
Added a PCI controller id on new Dell laptops.
Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com>
Cc: AmenophisIII <AmenophisIII@gmx.at>
commit 0ebf9e3692d640917fb792a7494d05e1f5b1058f upstream.
Reference: http://mailman.alsa-project.org/pipermail/alsa-devel/2010-May/027525.html
As reported on the mailing list, we also need to cap to the 0 dB offset
for Lenovo models, else the sound will be distorted.
Reported-and-Tested-by: Tim Starling <tstarling@wikimedia.org>
commit 8213466596bf10b75887754773ee13c10cf86f5c upstream.
The capture source control of maya44 was wrongly coded with the bit
shift instead of the bit mask. Also, the slot for line-in was
wrongly assigned (slot 5 instead of 4).
Reported-by: Alex Chernyshoff <alexdsp@gmail.com>
commit c53666813813a0ea3d0391e1911eefc05a5e6b4f upstream.
BugLink: https://launchpad.net/bugs/549267
The OR verified that using the olpc-xo-1_5 model quirk allows the
headphones to be audible when inserted into the jack. Capture was
also verified to work correctly.
Reported-by: Richard Gagne
Tested-by: Richard Gagne
commit 4442dd4613fe3795b4c8a5f42fc96b7ffb90d01a upstream.
BugLink: https://launchpad.net/bugs/573284
Reported-by: Andy Couldrake <acouldrake@googlemail.com>
Tested-by: Andy Couldrake <acouldrake@googlemail.com>
commit 8f0f5ff6777104084b4b2e1ae079541c2a6ed6d9 upstream.
BugLink: https://launchpad.net/bugs/541802
The OR's hardware distorts at PCM 100% because it does not correspond to
0 dB. Fix this in patch_cxt5045() for all Packard Bell models.
Reported-by: Valombre
CX20549 (Venice)
commit 0b587fc4d35afb1bc0fc3d890084bb14c78372dc upstream.
BugLink: https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4792
Cristian reported that these models have really bad sound above 6 dB
and proposed the original patch. I've updated the comment to reflect
this change.
Reported-by: Cristian Klein
commit 715aa675338ce6e1a3b4f77cf87ea611f93058a8 upstream.
Ignore spurious HV interrupts during suspend / resume, this avoids
mistaking them for a mute button press. This is not very pretty but
it seems the only way to fix the master volume control gets muted
after suspend issue I'm seeing. Note that the es1968 driver is doing
exactly the same.
commit 7efbfd1ae98ef9efe06352e2a1ad83e8c14ceeb1 upstream.
Without this quirk sound stops working after suspend resume. With this quirk,
one still needs to manually unmute the master volume control after a suspend /
/ resume cycle. That is fixed in another patch in this set.
Note that this patch was submitted to the alsa bug tracker a long time ago:
https://bugtrack.alsa-project.org/alsa-bug/view.php?id=4319
commit 3353541fe533350a22a03e2fb7dc085b35912575 upstream.
BugLink: https://launchpad.net/bugs/567494
The OR has verified that the existing model quirk, ALC880_UNIWILL,
is insufficient for audible playback and capture by default. Instead,
the ALC880_F1734 model quirk needs to be used.
This change is necessary for both 2.6.32.11 and 2.6.33.2.
Reported-by: Arnaud Malpeyre <amalpeyre@gmail.com>
Tested-by: Arnaud Malpeyre <amalpeyre@gmail.com>
commit 5c1bccf645d4ab65e4c7502acb42e8b9afdb5bdc upstream.
BugLink: https://launchpad.net/bugs/568600
The OR has verified that the dell-m6 model quirk is necessary for audio
to be audible by default on the Dell Studio XPS 1645.
This change is necessary for 2.6.32.11 and 2.6.33.2 alike.
Reported-by: Andy Ross <andy@plausible.org>
Tested-by: Andy Ross <andy@plausible.org>
commit aac78daf8f37256283f56820ae858add7139c56c upstream.
BugLink: https://launchpad.net/bugs/553002
Reported-by: Robert Chambers
Tested-by: Robert Chambers
