[ Upstream commit 15c665700bf6f4543f003ac0fbb1e9ec692e93f2 ]
The firmware ctls like "DSP1 Firmware" in wm_adsp codec driver are
enum, while the current driver accesses wrongly via
value.integer.value[]. They have to be via value.enumerated.item[]
instead.
Signed-off-by: Mark Brown <broonie@kernel.org>
Cc: stable@vger.kernel.org
[ Upstream commit 8019c0b37cd5a87107808300a496388b777225bf ]
The DRC Mode like "AIF1DRC1 Mode" and EQ Mode like "AIF1.1 EQ Mode" in
wm8994 codec driver are enum ctls, while the current driver accesses
wrongly via value.integer.value[]. They have to be via
value.enumerated.item[] instead.
[ Upstream commit d0784829ae3b0beeb69b476f017d5c8a2eb95198 ]
"MBC Mode", "VSS Mode", "VSS HPF Mode" and "Enhanced EQ Mode" ctls in
wm8958 codec driver are enum, while the current driver accesses
[ Upstream commit 741338f99f16dc24d2d01ac777b0798ae9d10a90 ]
snd_soc_dapm_dai_link_get() and _put() access the associated ctl
values as value.integer.value[]. However, this is an enum ctl, and it
has to be accessed via value.enumerated.item[]. The former is long
while the latter is unsigned int, so they don't align.
Fixes: c66150824b8a ('ASoC: dapm: add code to configure dai link parameters')
Cc: <stable@vger.kernel.org>
[ Upstream commit 316fa9e09ad76e095b9d7e9350c628b918370a22 ]
Lockdep warns of a potential lock inversion, i2s->lock is held numerous
times whilst we are under the substream lock (snd_pcm_stream_lock). If
we use the IRQ unsafe spin lock calls, you can also end up locking
snd_pcm_stream_lock whilst under i2s->lock (if an IRQ happens whilst we
are holding i2s->lock). This could result in deadlock.
[ 18.147001] CPU0 CPU1
[ 18.151509] ---- ----
[ 18.156022] lock(&(&pri_dai->spinlock)->rlock);
[ 18.160701] local_irq_disable();
[ 18.166622] lock(&(&substream->self_group.lock)->rlock);
[ 18.174595] lock(&(&pri_dai->spinlock)->rlock);
[ 18.181806] <Interrupt>
[ 18.184408] lock(&(&substream->self_group.lock)->rlock);
[ 18.190045]
[ 18.190045] *** DEADLOCK ***
This patch changes to using the irq safe spinlock calls, to avoid this
issue.
Fixes: ce8bcdbb61d9 ("ASoC: samsung: i2s: Protect more registers with a spinlock")
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Tested-by: Anand Moon <linux.amoon@gmail.com>
[ Upstream commit 02322ac9dee9aff8d8862e8d6660ebe102f492ea ]
This patch applies the microphone-related fix created for the Acer
Aspire E1-572 to the E1-472 as well, as it uses the same Realtek ALC282
CODEC and demonstrates the same issues.
This patch allows an external, headset microphone to be used and limits
the gain on the (quite noisy) internal microphone.
Signed-off-by: Simon South <simon@simonsouth.com>
[ Upstream commit 197b958c1e76a575d77038cc98b4bebc2134279f ]
The OSS sequencer client tries to drain the pending events at
releasing. Unfortunately, as spotted by syzkaller fuzzer, this may
lead to an unkillable process state when the event has been queued at
the far future. Since the process being released can't be signaled
any longer, it remains and waits for the echo-back event in that far
future.
Back to history, the draining feature was implemented at the time we
misinterpreted POSIX definition for blocking file operation.
Actually, such a behavior is superfluous at release, and we should
just release the device as is instead of keeping it up forever.
This patch just removes the draining call that may block the release
for too long time unexpectedly.
BugLink: http://lkml.kernel.org/r/CACT4Y+Y4kD-aBGj37rf-xBw9bH3GMU6P+MYg4W1e-s-paVD2pg@mail.gmail.com
[ Upstream commit 17e2df4613be57d0fab68df749f6b8114e453152 ]
Plantronics DA45 does not support reading the sample rate which leads
to many lines of "cannot get freq at ep 0x4" and "cannot get freq at
ep 0x84". This patch adds the USB ID of the DA45 to quirks.c and
avoids those error messages.
Signed-off-by: Dennis Kadioglu <denk@post.com>
[ Upstream commit eab3c4db193f5fcccf70e884de9a922ca2c63d80 ]
snd-hdsp driver accesses enum item values (int) instead of boolean
values (long) wrongly for some ctl elements. This patch fixes them.
[ Upstream commit c1099c3294c2344110085a38c50e478a5992b368 ]
HDSPM driver contains a code issuing zero-division potentially in
system sample rate ctl code. This patch fixes it by not processing
a zero or invalid rate value as a divisor, as well as excluding the
invalid value to be passed via the given ctl element.
[ Upstream commit 537e48136295c5860a92138c5ea3959b9542868b ]
snd-hdspm driver accesses enum item values (int) instead of boolean
[ Upstream commit b24e7ad1fdc22177eb3e51584e1cfcb45d818488 ]
X32 ABI takes the 64bit timespec, thus the timer user status ioctl becomes
incompatible with IA32. This results in NOTTY error when the ioctl is
issued.
Meanwhile, this struct in X32 is essentially identical with the one in
X86-64, so we can just bypassing to the existing code for this
specific compat ioctl.
Cc: <stable@vger.kernel.org> # v3.4+
[ Upstream commit 3a72494ac2a3bd229db941d51e7efe2f6ccd947b ]
The timer user status compat ioctl returned the bogus struct used for
64bit architectures instead of the 32bit one. This patch addresses
it to return the proper struct.
[ Upstream commit 2251fbbc1539f05b0b206b37a602d5776be37252 ]
Like the previous fixes for ctl and PCM, we need a fix for
incompatible X32 ABI regarding the rawmidi: namely, struct
snd_rawmidi_status has the timespec, and the size and the alignment on
X32 differ from IA32.
This patch fixes the incompatible ioctl for X32.
[ Upstream commit 513ace79b657e2022a592e77f24074e088681ecc ]
X32 ABI uses the 64bit timespec in addition to 64bit alignment of
64bit values. This leads to incompatibilities in some PCM ioctls
involved with snd_pcm_channel_info, snd_pcm_status and
snd_pcm_sync_ptr structs. Fix the PCM compat ABI for these ioctls
like the previous commit for ctl API.
Reported-by: Steven Newbury <steve@snewbury.org.uk>
[ Upstream commit 6236d8bb2afcfe71b88ecea554e0dc638090a45f ]
The X32 ABI takes the same alignment like x86-64, and this may result
in the incompatible struct size from ia32. Unfortunately, we hit this
in some control ABI: struct snd_ctl_elem_value differs between them
due to the position of 64bit variable array. This ends up with the
unknown ioctl (ENOTTY) error.
The fix is to add the compat entries for the new aligned struct.
Reported-and-tested-by: Steven Newbury <steve@snewbury.org.uk>
[ Upstream commit f883982dc1b117f04579f0896821cd9f2e397f94 ]
HP EliteBook 755 G2 with ALC3228 (ALC280) codec [103c:221c] requires
the known fixup (ALC269_FIXUP_HEADSET_MIC) for making the headset mic
working. Also, it suffers from the loopback noise problem, so we
should disable aamix path as well.
Reported-by: Derick Eddington <derick.eddington@gmail.com>
[ Upstream commit 2ae955774f29bbd7d16149cb0ae8d0319bf2ecc4 ]
On one of the machines we enable, we found that the actual speaker volume
did not always correspond to the volume set in alsamixer. This patch
fixes that problem.
This patch was orginally written by Kailang @ Realtek, I've rebased it
to fit sound git master.
BugLink: https://bugs.launchpad.net/bugs/1549660
Co-Authored-By: Kailang <kailang@realtek.com>
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
[ Upstream commit cfc5a845e62853edd36e564c23c64588f4adcae6 ]
Dell create new platform with ALC298 codec.
This patch will enable headset mode for ALC225/ALC3253 platform.
Signed-off-by: Kailang Yang <kailang@realtek.com>
Cc: <stable@vger.kernel.org> # v4.4+
[ Upstream commit 7cb32ae09a6490c27bc3c110ee42d808a5670142 ]
commit 3b43b71f05d3ecd01c4116254666d9492301697d upstream.
After login to the desktop on Dell Inspiron 3162,
there's a very loud background noise comes from the builtin speaker.
The noise does not go away even if the speaker is muted.
The noise disappears after using the aamix fixup.
Codec: Realtek ALC3234
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0255
Subsystem Id: 0x10280725
Revision Id: 0x100002
No Modem Function Group found
BugLink: http://bugs.launchpad.net/bugs/1549620
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
[ Upstream commit 3694cb2947db50753caf432db067487eafae7b9b ]
The Lenovo ThinkCenter AIO uses Line2 (NID 0x1b) to implement the
micmute hotkey, here we register an input device and use Line2 unsol
event to collect the hotkey pressing or releasing.
In the meanwhile, the micmute led is controlled by GPIO2, so we
use an existing function alc_fixup_gpio_mic_mute_hook() to control
the led.
[Hui: And there are two places to register the input device, to make
the code simple and clean, move the two same code sections into a
function.]
Signed-off-by: Kailang <kailang@realtek.com>
Signed-off-by: Hui Wang <hui.wang@canonical.com>
[ Upstream commit 23adc192b862b69ad80a40bd5206e337f41264ac ]
We have two latest thinkpad laptop models which are all based on the
Intel skylake platforms, and all of them have the codec alc293 on
them. When the machines boot to the desktop, an greeting dialogue
shows up with the notification sound. But on these two models, there
is noise with the notification sound. We have 3 SKUs for each of
the models, all of them have this problem.
So far, this problem is only specific to these two thinkpad models,
we did not find this problem on the old thinkpad models with the
codec alc293 or alc292.
A workaround for this problem is disabling the aamix.
BugLink: https://bugs.launchpad.net/bugs/1523517
[ Upstream commit 8c69729b4439bbda88c3073df7243f755cc418ed ]
We have a machine Dell XPS 13 with the codec alc256, after resume back
from S3, the headphone has noise when play sound.
Through comparing with the coeff vaule before and after S3, we found
restoring a coeff register will help remove noise.
BugLink: https://bugs.launchpad.net/bugs/1519168
Cc: Kailang Yang <kailang@realtek.com>
[ Upstream commit 6ed1131fe196ad7ffc13acc1a1eadc08a1db0303 ]
This machine had I2S codec for speaker output.
It need to refill the I2S codec initial verb after resume back.
Reported-and-tested-by: George Gugulea <gugulea@gmail.com>
[ Upstream commit 977e627684df0f60bdf2a768ec4772f42fe843fc ]
This patch will enable headset mode for ALC298/ALC3266 platform.
[ Upstream commit 67ec1072b053c15564e6090ab30127895dc77a89 ]
A non-atomic PCM stream may take snd_pcm_link_rwsem rw semaphore twice
in the same code path, e.g. one in snd_pcm_action_nonatomic() and
another in snd_pcm_stream_lock(). Usually this is OK, but when a
write lock is issued between these two read locks, the problem
happens: the write lock is blocked due to the first reade lock, and
the second read lock is also blocked by the write lock. This
eventually deadlocks.
The reason is the way rwsem manages waiters; it's queued like FIFO, so
even if the writer itself doesn't take the lock yet, it blocks all the
waiters (including reads) queued after it.
As a workaround, in this patch, we replace the standard down_write()
with an spinning loop. This is far from optimal, but it's good
enough, as the spinning time is supposed to be relatively short for
normal PCM operations, and the code paths requiring the write lock
aren't called so often.
Reported-by: Vinod Koul <vinod.koul@intel.com>
Tested-by: Ramesh Babu <ramesh.babu@intel.com>
Cc: <stable@vger.kernel.org> # v3.18+
[ Upstream commit 13d5e5d4725c64ec06040d636832e78453f477b7 ]
The commit [7f0973e973cd: ALSA: seq: Fix lockdep warnings due to
double mutex locks] split the management of two linked lists (source
and destination) into two individual calls for avoiding the AB/BA
deadlock. However, this may leave the possible double deletion of one
of two lists when the counterpart is being deleted concurrently.
It ends up with a list corruption, as revealed by syzkaller fuzzer.
This patch fixes it by checking the list emptiness and skipping the
deletion and the following process.
BugLink: http://lkml.kernel.org/r/CACT4Y+bay9qsrz6dQu31EcGaH9XwfW7o3oBzSQUG9fMszoh=Sg@mail.gmail.com
Fixes: 7f0973e973cd ('ALSA: seq: Fix lockdep warnings due to 'double mutex locks)
Tested-by: Dmitry Vyukov <dvyukov@google.com>
[ Upstream commit 0b8c82190c12e530eb6003720dac103bf63e146e ]
The commit [991f86d7ae4e: ALSA: hda - Flush the pending probe work at
remove] introduced the sync of async probe work at remove for fixing
the race. However, this may lead to another hangup when the module
removal is performed quickly before starting the probe work, because
it issues flush_work() and it's blocked forever.
The workaround is to use cancel_work_sync() instead of flush_work()
there.
Fixes: 991f86d7ae4e ('ALSA: hda - Flush the pending probe work at remove')
Cc: <stable@vger.kernel.org> # v3.17+
[ Upstream commit d99a36f4728fcbcc501b78447f625bdcce15b842 ]
When multiple concurrent writes happen on the ALSA sequencer device
right after the open, it may try to allocate vmalloc buffer for each
write and leak some of them. It's because the presence check and the
assignment of the buffer is done outside the spinlock for the pool.
The fix is to move the check and the assignment into the spinlock.
(The current implementation is suboptimal, as there can be multiple
unnecessary vmallocs because the allocation is done before the check
in the spinlock. But the pool size is already checked beforehand, so
this isn't a big problem; that is, the only possible path is the
multiple writes before any pool assignment, and practically seen, the
current coverage should be "good enough".)
The issue was triggered by syzkaller fuzzer.
BugLink: http://lkml.kernel.org/r/CACT4Y+bSzazpXNvtAr=WXaL8hptqjHwqEyFA+VN2AWEx=aurkg@mail.gmail.com
[ Upstream commit 07d86ca93db7e5cdf4743564d98292042ec21af7 ]
The 'umidi' object will be free'd on the error path by snd_usbmidi_free()
when tearing down the rawmidi interface. So we shouldn't try to free it
in snd_usbmidi_create() after having registered the rawmidi interface.
Found by KASAN.
Signed-off-by: Andrey Konovalov <andreyknvl@gmail.com>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
[ Upstream commit 4dff5c7b7093b19c19d3a100f8a3ad87cb7cd9e7 ]
snd_timer_user_read() has a potential race among parallel reads, as
qhead and qused are updated outside the critical section due to
copy_to_user() calls. Move them into the critical section, and also
sanitize the relevant code a bit.
[ Upstream commit 2ebab40eb74a0225d5dfba72bfae317dd948fa2d ]
The hda_jack_tbl entries are managed by snd_array for allowing
multiple jacks. It's good per se, but the problem is that struct
hda_jack_callback keeps the hda_jack_tbl pointer. Since snd_array
doesn't preserve each pointer at resizing the array, we can't keep the
original pointer but have to deduce the pointer at each time via
snd_array_entry() instead. Actually, this resulted in the deference
to the wrong pointer on codecs that have many pins such as CS4208.
This patch replaces the pointer to the NID value as the search key.
As an unexpected good side effect, this even simplifies the code, as
only NID is needed in most cases.
[ Upstream commit ed8b1d6d2c741ab26d60d499d7fbb7ac801f0f51 ]
A slave timer element also unlinks at snd_timer_stop() but it takes
only slave_active_lock. When a slave is assigned to a master,
however, this may become a race against the master's interrupt
handling, eventually resulting in a list corruption. The actual bug
could be seen with a syzkaller fuzzer test case in BugLink below.
As a fix, we need to take timeri->timer->lock when timer isn't NULL,
i.e. assigned to a master, while the assignment to a master itself is
protected by slave_active_lock.
BugLink: http://lkml.kernel.org/r/CACT4Y+Y_Bm+7epAb=8Wi=AaWd+DYS7qawX52qxdCfOfY49vozQ@mail.gmail.com
[ Upstream commit 117159f0b9d392fb433a7871426fad50317f06f7 ]
In snd_timer_notify1(), the wrong timer instance was passed for slave
ccallback function. This leads to the access to the wrong data when
an incompatible master is handled (e.g. the master is the sequencer
timer and the slave is a user timer), as spotted by syzkaller fuzzer.
This patch fixes that wrong assignment.
[ Upstream commit ddce57a6f0a2d8d1bfacfa77f06043bc760403c2 ]
Currently the selected timer backend is referred at any moment from
the running PCM callbacks. When the backend is switched, it's
possible to lead to inconsistency from the running backend. This was
pointed by syzkaller fuzzer, and the commit [7ee96216c31a: ALSA:
dummy: Disable switching timer backend via sysfs] disabled the dynamic
switching for avoiding the crash.
This patch improves the handling of timer backend switching. It keeps
the reference to the selected backend during the whole operation of an
opened stream so that it won't be changed by other streams.
Together with this change, the hrtimer parameter is reenabled as
writable now.
NOTE: this patch also turned out to fix the still remaining race.
Namely, ops was still replaced dynamically at dummy_pcm_open:
static int dummy_pcm_open(struct snd_pcm_substream *substream)
dummy->timer_ops = &dummy_systimer_ops;
if (hrtimer)
dummy->timer_ops = &dummy_hrtimer_ops;
Since dummy->timer_ops is common among all streams, and when the
replacement happens during accesses of other streams, it may lead to a
crash. This was actually triggered by syzkaller fuzzer and KASAN.
This patch rewrites the code not to use the ops shared by all streams
any longer, too.
BugLink: http://lkml.kernel.org/r/CACT4Y+aZ+xisrpuM6cOXbL21DuM0yVxPYXf4cD4Md9uw0C3dBQ@mail.gmail.com
[ Upstream commit c44d9b1181cf34e0860c72cc8a00e0c47417aac0 ]
Some Sony VAIO AiO models (VGC-JS4EF and VGC-JS25G, both with PCI SSID
104d:9044) need the same quirk to make the speaker working properly.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=112031
[ Upstream commit 6c361d10e0eb859233c71954abcd20d2d8700587 ]
This reverts commit 0c25ad80408e95e0a4fbaf0056950206e95f726f.
The original commit disabled the aamixer path due to the noise
problem, but it turned out that some mobo with the same PCI SSID
doesn't suffer from the issue, and the disabled function (analog
loopback) is still demanded by users.
Since the recent commit [e7fdd52779a6: ALSA: hda - Implement loopback
control switch for Realtek and other codecs], we have the dynamic
mixer switch to enable/disable the aamix path, and we don't have to
disable the path statically any longer. So, let's revert the
disablement, so that only the user suffering from the noise problem
can turn off the aamix on the fly.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=108301
Reported-by: <mutedbytes@gmail.com>
[ Upstream commit 360a8245680053619205a3ae10e6bfe624a5da1d ]
The static checker warning is:
sound/pci/hda/patch_hdmi.c:460 hdmi_eld_ctl_get()
error: __memcpy() 'eld->eld_buffer' too small (256 vs 512)
I have a hard time figuring out if this can ever cause an information leak
(I don't think so), but nonetheless it does not hurt to increase the
robustness of the code.
Fixes: 68e03de98507 ('ALSA: hda - hdmi: Do not expose eld data when eld is invalid')
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: <stable@vger.kernel.org> # v3.9+
[ Upstream commit 5e82d2be6ee53275c72e964507518d7964c82753 ]
While performing hw_free, DPCM checks the BE state but leaves out
the suspend state. The suspend state needs to be checked as well,
as we might be suspended and then usermode closes rather than
resuming the audio stream.
This was found by a stress testing of system with playback in
loop and killed after few seconds running in background and second
script running suspend-resume test in loop
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com>
[ Upstream commit b28785fa9cede0d4f47310ca0dd2a4e1d50478b5 ]
The shift bit of IN1 boost gain control is 12.
Signed-off-by: Bard Liao <bardliao@realtek.com>
[ Upstream commit 094fd3be87b0f102589e2d5c3fa5d06b7e20496d ]
In ALSA timer core, the active timer instance is managed in
active_list linked list. Each element is added / removed dynamically
at timer start, stop and in timer interrupt. The problem is that
snd_timer_interrupt() has a thinko and leaves the element in
active_list when it's the last opened element. This eventually leads
to list corruption or use-after-free error.
This hasn't been revealed because we used to delete the list forcibly
in snd_timer_stop() in the past. However, the recent fix avoids the
double-stop behavior (in commit [f784beb75ce8: ALSA: timer: Fix link
corruption due to double start or stop]), and this leak hits reality.
This patch fixes the link management in snd_timer_interrupt(). Now it
simply unlinks no matter which stream is.
BugLink: http://lkml.kernel.org/r/CACT4Y+Yy2aukHP-EDp8-ziNqNNmb-NTf=jDWXMP7jB8HDa2vng@mail.gmail.com
[ Upstream commit 7f0973e973cd74aa40747c9d38844560cd184ee8 ]
The port subscription code uses double mutex locks for source and
destination ports, and this may become racy once when wrongly set up.
It leads to lockdep warning splat, typically triggered by fuzzer like
syzkaller, although the actual deadlock hasn't been seen, so far.
This patch simplifies the handling by reducing to two single locks, so
that no lockdep warning will be trigger any longer.
By splitting to two actions, a still-in-progress element shall be
added in one list while handling another. For ignoring this element,
a new check is added in deliver_to_subscribers().
Along with it, the code to add/remove the subscribers list element was
cleaned up and refactored.
BugLink: http://lkml.kernel.org/r/CACT4Y+aKQXV7xkBW9hpQbzaDO7LrUvohxWh-UwMxXjDy-yBD=A@mail.gmail.com
[ Upstream commit 81f577542af15640cbcb6ef68baa4caa610cbbfc ]
The rawmidi read and write functions manage runtime stream status
such as runtime->appl_ptr and runtime->avail. These point where to
copy the new data and how many bytes have been copied (or to be
read). The problem is that rawmidi read/write call copy_from_user()
or copy_to_user(), and the runtime spinlock is temporarily unlocked
and relocked while copying user-space. Since the current code
advances and updates the runtime status after the spin unlock/relock,
the copy and the update may be asynchronous, and eventually
runtime->avail might go to a negative value when many concurrent
accesses are done. This may lead to memory corruption in the end.
For fixing this race, in this patch, the status update code is
performed in the same lock before the temporary unlock. Also, the
spinlock is now taken more widely in snd_rawmidi_kernel_read1() for
protecting more properly during the whole operation.
BugLink: http://lkml.kernel.org/r/CACT4Y+b-dCmNf1GpgPKfDO0ih+uZCL2JV4__j-r1kdhPLSgQCQ@mail.gmail.com
[ Upstream commit 06ab30034ed9c200a570ab13c017bde248ddb2a6 ]
A kernel WARNING in snd_rawmidi_transmit_ack() is triggered by
syzkaller fuzzer:
WARNING: CPU: 1 PID: 20739 at sound/core/rawmidi.c:1136
Call Trace:
[< inline >] __dump_stack lib/dump_stack.c:15
[<ffffffff82999e2d>] dump_stack+0x6f/0xa2 lib/dump_stack.c:50
[<ffffffff81352089>] warn_slowpath_common+0xd9/0x140 kernel/panic.c:482
[<ffffffff813522b9>] warn_slowpath_null+0x29/0x30 kernel/panic.c:515
[<ffffffff84f80bd5>] snd_rawmidi_transmit_ack+0x275/0x400 sound/core/rawmidi.c:1136
[<ffffffff84fdb3c1>] snd_virmidi_output_trigger+0x4b1/0x5a0 sound/core/seq/seq_virmidi.c:163
[< inline >] snd_rawmidi_output_trigger sound/core/rawmidi.c:150
[<ffffffff84f87ed9>] snd_rawmidi_kernel_write1+0x549/0x780 sound/core/rawmidi.c:1223
[<ffffffff84f89fd3>] snd_rawmidi_write+0x543/0xb30 sound/core/rawmidi.c:1273
[<ffffffff817b0323>] __vfs_write+0x113/0x480 fs/read_write.c:528
[<ffffffff817b1db7>] vfs_write+0x167/0x4a0 fs/read_write.c:577
[< inline >] SYSC_write fs/read_write.c:624
[<ffffffff817b50a1>] SyS_write+0x111/0x220 fs/read_write.c:616
[<ffffffff86336c36>] entry_SYSCALL_64_fastpath+0x16/0x7a arch/x86/entry/entry_64.S:185
Also a similar warning is found but in another path:
Call Trace:
[<ffffffff82be2c0d>] dump_stack+0x6f/0xa2 lib/dump_stack.c:50
[<ffffffff81355139>] warn_slowpath_common+0xd9/0x140 kernel/panic.c:482
[<ffffffff81355369>] warn_slowpath_null+0x29/0x30 kernel/panic.c:515
[<ffffffff8527e69a>] rawmidi_transmit_ack+0x24a/0x3b0 sound/core/rawmidi.c:1133
[<ffffffff8527e851>] snd_rawmidi_transmit_ack+0x51/0x80 sound/core/rawmidi.c:1163
[<ffffffff852d9046>] snd_virmidi_output_trigger+0x2b6/0x570 sound/core/seq/seq_virmidi.c:185
[<ffffffff85285a0b>] snd_rawmidi_kernel_write1+0x4bb/0x760 sound/core/rawmidi.c:1252
[<ffffffff85287b73>] snd_rawmidi_write+0x543/0xb30 sound/core/rawmidi.c:1302
[<ffffffff817ba5f3>] __vfs_write+0x113/0x480 fs/read_write.c:528
[<ffffffff817bc087>] vfs_write+0x167/0x4a0 fs/read_write.c:577
[<ffffffff817bf371>] SyS_write+0x111/0x220 fs/read_write.c:616
[<ffffffff86660276>] entry_SYSCALL_64_fastpath+0x16/0x7a arch/x86/entry/entry_64.S:185
In the former case, the reason is that virmidi has an open code
calling snd_rawmidi_transmit_ack() with the value calculated outside
the spinlock. We may use snd_rawmidi_transmit() in a loop just for
consuming the input data, but even there, there is a race between
snd_rawmidi_transmit_peek() and snd_rawmidi_tranmit_ack().
Similarly in the latter case, it calls snd_rawmidi_transmit_peek() and
snd_rawmidi_tranmit_ack() separately without protection, so they are
racy as well.
The patch tries to address these issues by the following ways:
- Introduce the unlocked versions of snd_rawmidi_transmit_peek() and
snd_rawmidi_transmit_ack() to be called inside the explicit lock.
- Rewrite snd_rawmidi_transmit() to be race-free (the former case).
- Make the split calls (the latter case) protected in the rawmidi spin
lock.
BugLink: http://lkml.kernel.org/r/CACT4Y+YPq1+cYLkadwjWa5XjzF1_Vki1eHnVn-Lm0hzhSpu5PA@mail.gmail.com
BugLink: http://lkml.kernel.org/r/CACT4Y+acG4iyphdOZx47Nyq_VHGbpJQK-6xNpiqUjaZYqsXOGw@mail.gmail.com
[ Upstream commit 2154cc0e2d4ae15132d005d17e473327c70c9a06 ]
Mac Mini 7,1 model with CS4208 codec reports the headphone jack
detection wrongly in an inverted way. Moreover, the advertised pins
for the audio input and SPDIF output have actually no jack detection.
This patch addresses these issues. The inv_jack_detect flag is set
for fixing the headphone jack detection, and the pin configs for audio
input and SPDIF output are marked as non-detectable.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=105161
Report-and-tested-by: moosotc@gmail.com
[ Upstream commit f784beb75ce82f4136f8a0960d3ee872f7109e09 ]
Although ALSA timer code got hardening for races, it still causes
use-after-free error. This is however rather a corrupted linked list,
not actually the concurrent accesses. Namely, when timer start is
triggered twice, list_add_tail() is called twice, too. This ends
up with the link corruption and triggers KASAN error.
The simplest fix would be replacing list_add_tail() with
list_move_tail(), but fundamentally it's the problem that we don't
check the double start/stop correctly. So, the right fix here is to
add the proper checks to snd_timer_start() and snd_timer_stop() (and
their variants).
BugLink: http://lkml.kernel.org/r/CACT4Y+ZyPRoMQjmawbvmCEDrkBD2BQuH7R09=eOkf5ESK8kJAw@mail.gmail.com
[ Upstream commit c3b1681375dc6e71d89a3ae00cc3ce9e775a8917 ]
This is a minor code cleanup without any functional changes:
- Kill keep_flag argument from _snd_timer_stop(), as all callers pass
only it false.
- Remove redundant NULL check in _snd_timer_stop().
[ Upstream commit 2cdc7b636d55cbcf42e1e6c8accd85e62d3e9ae8 ]
ALSA sequencer may open/close and control ALSA timer instance
dynamically either via sequencer events or direct ioctls. These are
done mostly asynchronously, and it may call still some timer action
like snd_timer_start() while another is calling snd_timer_close().
Since the instance gets removed by snd_timer_close(), it may lead to
a use-after-free.
This patch tries to address such a race by protecting each
snd_timer_*() call via the existing spinlock and also by avoiding the
access to timer during close call.
BugLink: http://lkml.kernel.org/r/CACT4Y+Z6RzW5MBr-HUdV-8zwg71WQfKTdPpYGvOeS7v4cyurNQ@mail.gmail.com
[ Upstream commit b248371628aad599a48540962f6b85a21a8a0c3f ]
There are potential deadlocks in PCM OSS emulation code while
accessing read/write and mmap concurrently. This comes from the
infamous mmap_sem usage in copy_from/to_user(). Namely,
snd_pcm_oss_write() ->
&runtime->oss.params_lock ->
copy_to_user() ->
&mm->mmap_sem
mmap() ->
&mm->mmap_sem ->
snd_pcm_oss_mmap() ->
Since we can't avoid taking params_lock from mmap code path, use
trylock variant and aborts with -EAGAIN as a workaround of this AB/BA
deadlock.
BugLink: http://lkml.kernel.org/r/CACT4Y+bVrBKDG0G2_AcUgUQa+X91VKTeS4v+wN7BSHwHtqn3kQ@mail.gmail.com
[ Upstream commit cc85f7a634cfaf9f0713c6aa06d08817424db37a ]
NULL user-space buffer can be passed even in a normal path, thus it's
not good to spew a kernel warning with stack trace at each time.
Just drop snd_BUG_ON() macro usage there.
BugLink: http://lkml.kernel.org/r/CACT4Y+YfVJ3L+q0i-4vyQVyyPD7V=OMX0PWPi29x9Bo3QaBLdw@mail.gmail.com
