path: root/sound
2013-08-14ALSA: 6fire: fix DMA issues with URB transfer_buffer usageJussi Kivilinna
commit ddb6b5a964371e8e52e696b2b258bda144c8bd3f upstream. Patch fixes 6fire not to use stack as URB transfer_buffer. URB buffers need to be DMA-able, which stack is not. Furthermore, transfer_buffer should not be allocated as part of larger device structure because DMA coherency issues and patch fixes this issue too. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Tested-by: Torsten Schenk <torsten.schenk@zoho.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14ALSA: usb-audio: do not trust too-big wMaxPacketSize valuesClemens Ladisch
commit 57e6dae1087bbaa6b33d3dd8a8e90b63888939a3 upstream. The driver used to assume that the streaming endpoint's wMaxPacketSize value would be an indication of how much data the endpoint expects or sends, and compute the number of packets per URB using this value. However, the Focusrite Scarlett 2i4 declares a value of 1024 bytes, while only about 88 or 44 bytes are be actually used. This discrepancy would result in URBs with far too few packets, which would not work correctly on the EHCI driver. To get correct URBs, use wMaxPacketSize only as an upper limit on the packet size. Reported-by: James Stone <jamesmstone@gmail.com> Tested-by: James Stone <jamesmstone@gmail.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11ALSA: compress: fix the return value for SNDRV_COMPRESS_VERSIONVinod Koul
commit a8d30608eaed6cc759b8e2e8a8bbbb42591f797f upstream. the return value of SNDRV_COMPRESS_VERSION always return default -ENOTTY as the return value was never updated for this call assign return value from put_user() Reported-by: Haynes <hgeorge@codeaurora.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-11ALSA: hda - Fix missing fixup for Mac Mini with STAC9221Takashi Iwai
commit 697aebab78a88c6b164cfb74d19b86817d2ccd82 upstream. A fixup for Apple Mac Mini was lost during the adaption to the generic parser because the fallback for the generic ID 8384:7680 was dropped, and it resulted in the silence output (and maybe other problems). Unfortunately, just adding the missing subsystem ID wasn't enough, in this case. The subsystem ID of this machine is 0000:0100 (what Apple thought...?), and since snd_hda_pick_fixup() doesn't take the vendor id zero into account, the driver ignored this entry. Now it's fixed to regard the vendor id zero as a valid value. Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04ASoC: wm8962: Remove remaining direct register cache accessesNicolin Chen
commit 2e7ee15ced914e109a1a5b6dfcd463d846a13bd5 upstream. Also fix return values for headphone switch updates. Signed-off-by: Nicolin Chen <b42378@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04ASoC: tegra: correct playback_dma_data setupRichard Zhao
commit 647ab784c507763bfda79155f125b6edd1244806 upstream. The errors were caused by copy/paste mistake in below commit since v3.10: 3489d50 ASoC: tegra: Use common DAI DMA data struct It also corrects slave_id initialization in tegra20_ac97 driver. Signed-off-by: Richard Zhao <rizhao@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04ASoC: max98088 - fix element type of the register cache.Chih-Chung Chang
commit cb6f66a2d278e57a6c9d8fb59bd9ebd8ab3965c2 upstream. The registers of max98088 are 8 bits, not 16 bits. This bug causes the contents of registers to be overwritten with bad values when the codec is suspended and then resumed. Signed-off-by: Chih-Chung Chang <chihchung@chromium.org> Signed-off-by: Dylan Reid <dgreid@chromium.org> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04ASoC: sglt5000: Fix the default value of CHIP_SSS_CTRLFabio Estevam
commit 016fcab8ff46fca29375d484226ec91932aa4a07 upstream. According to the sgtl5000 reference manual, the default value of CHIP_SSS_CTRL is 0x10. Reported-by: Oskar Schirmer <oskar@scara.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04ALSA: hda - Guess what, it's two more Dell headset mic quirksDavid Henningsson
commit cd6fb6793a33e2b02af6e05a8d3f735f7c88a943 upstream. Add two more machines that need quirks for headset mics to work. Tested-by: Shawn Wang <shawn.wang@canonical.com> BugLink: https://bugs.launchpad.net/bugs/1195636 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04ALSA: hda - Yet another Dell headset mic quirkDavid Henningsson
commit 6c29d68a82ec68db18241b818d03e7864c052be9 upstream. This quirk is needed for the headset mic to work on this Dell machine. BugLink: https://bugs.launchpad.net/bugs/1195597 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ALSA: hda - Fix EAPD GPIO control for Sigmatel codecsTakashi Iwai
commit 1ea9a69d1a36a5b62bf281ba8bb304fcac656dad upstream. The EAPD GPIO is dynamically turned on/off for some machines with Sigmatel codecs, but this didn't work as expected, and it resulted in spontaneous lost of speaker outputs per HP plugging or power-saving. This patch fixes the bug by simply including spec->eapd_mask into spec->gpio_mask and spec->gpio_data bits. Reported-and-tested-by: Eric Shattow <lucent@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ALSA: usb-audio: 6fire: return correct XRUN indicationEldad Zack
commit be2f93a4c4981b3646b6f98f477154411b8516cb upstream. Return SNDRV_PCM_POS_XRUN (snd_pcm_uframes_t) instead of SNDRV_PCM_STATE_XRUN (snd_pcm_state_t) from the pointer function of 6fire, as expected by snd_pcm_update_hw_ptr0(). Caught by sparse. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28ALSA: hda - Remove NO_PRESENCE bit override for Dell 1420n LaptopTakashi Iwai
commit f3e351eef3a7fd1e36a3e18d4f2f069b00deb23c upstream. The quirk for Dell laptops with STAC9228 overrides the pin default config of NID 0x0f to the value with AC_DEFCFG_MISC_NO_PRESENCE bit on. I'm not quite sure why this was done so, but can guess that this was introduced for avoiding this to be muted by another headphone plug. Now, after transition to the generic parser, this workaround rather causes a problem (notably as unexpected speaker mutes) because the pin is seen as if it's always plugged in. Since the generic parser can handle multiple headphone plugging gracefully, we can get rid of this override now. Reported-and-tested-by: Eric Shattow <lucent@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ASoC: sglt5000: Fix SGTL5000_PLL_FRAC_DIV_MASKFabio Estevam
commit 5c78dfe87ea04b501ee000a7f03b9432ac9d008c upstream. SGTL5000_PLL_FRAC_DIV_MASK is used to mask bits 0-10 (11 bits in total) of register CHIP_PLL_CTRL, so fix the mask to accomodate all this bit range. Reported-by: Oskar Schirmer <oskar@scara.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ASoC: atmel: Fix unlocked snd_pcm_stop() callTakashi Iwai
commit 571185717f8d7f2a088a7ac38d94a9ad5fd9da5c upstream. snd_pcm_stop() must be called in the PCM substream lock context. Acked-by: Mark Brown <broonie@linaro.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ASoC: s6000: Fix unlocked snd_pcm_stop() callTakashi Iwai
commit 61be2b9a18ec70f3cbe3deef7a5f77869c71b5ae upstream. snd_pcm_stop() must be called in the PCM substream lock context. Acked-by: Mark Brown <broonie@linaro.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: usx2y: Fix unlocked snd_pcm_stop() callTakashi Iwai
commit 5be1efb4c2ed79c3d7c0cbcbecae768377666e84 upstream. snd_pcm_stop() must be called in the PCM substream lock context. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: asihpi: Fix unlocked snd_pcm_stop() callTakashi Iwai
commit 60478295d6876619f8f47f6d1a5c25eaade69ee3 upstream. snd_pcm_stop() must be called in the PCM substream lock context. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: atiixp: Fix unlocked snd_pcm_stop() callTakashi Iwai
commit cc7282b8d5abbd48c81d1465925d464d9e3eaa8f upstream. snd_pcm_stop() must be called in the PCM substream lock context. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: pxa2xx: Fix unlocked snd_pcm_stop() callTakashi Iwai
commit 46f6c1aaf790be9ea3c8ddfc8f235a5f677d08e2 upstream. snd_pcm_stop() must be called in the PCM substream lock context. Acked-by: Mark Brown <broonie@linaro.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: ua101: Fix unlocked snd_pcm_stop() callTakashi Iwai
commit 9538aa46c2427d6782aa10036c4da4c541605e0e upstream. snd_pcm_stop() must be called in the PCM substream lock context. Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: 6fire: Fix unlocked snd_pcm_stop() callTakashi Iwai
commit 5b9ab3f7324a1b94a5a5a76d44cf92dfeb3b5e80 upstream. snd_pcm_stop() must be called in the PCM substream lock context. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: seq-oss: Initialize MIDI clients asynchronouslyTakashi Iwai
commit 256ca9c3ad5013ff8a8f165e5a82fab437628c8e upstream. We've got bug reports that the module loading stuck on Debian system with 3.10 kernel. The debugging session revealed that the initial registration of OSS sequencer clients stuck at module loading time, which involves again with request_module() at the init phase. This is triggered only by special --install stuff Debian is using, but it's still not good to have such loops. As a workaround, call the registration part asynchronously. This is a better approach irrespective of the hang fix, in anyway. Reported-and-tested-by: Philipp Matthias Hahn <pmhahn@pmhahn.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: hda - Add new GPU codec ID to snd-hdaAaron Plattner
commit d52392b1a80458c0510810789c7db4a39b88022a upstream. Vendor ID 0x10de0060 is used by a yet-to-be-named GPU chip. Reviewed-by: Andy Ritger <aritger@nvidia.com> Signed-off-by: Aaron Plattner <aplattner@nvidia.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: hda - Fix the max length of control name in generic parserTakashi Iwai
commit 0c055b3413868227f2e85701c4e6938c9581f0e2 upstream. add_control_with_pfx() in hda_generic.c assumes a shorter name string for the control element, and this resulted in the truncation of the long but valid string like "Headphone Surround Switch" in the middle. This patch aligns the max size to the actual limit of snd_ctl_elem_id, 44. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: hda - Fix missing Mic Boost controls for VIA codecsTakashi Iwai
commit d045c5dc43d829df9f067d363c3b42b14dacf434 upstream. Some VIA codecs like VT1708S have Mic boost amps in the mic pins but they aren't exposed in the capability bits. In the past driver code, we override the pin caps and create mic boost controls forcibly. While transition to the generic parser, we lost the mic boost controls although the pin caps are still overridden, because the generic parser code checks the widget caps, too. So this patch adds a new helper function to allow the override of the given widget capability bits, and makes VIA codecs driver to add the missing input-amp capability bit. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59861 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: hda - Cache the MUX selection for generic HDMITakashi Iwai
commit bddee96b5d0db869f47b195fe48c614ca824203c upstream. When a selection to a converter MUX is changed in hdmi_pcm_open(), it should be cached so that the given connection can be restored properly at PM resume. We need just to replace the corresponding snd_hda_codec_write() call with snd_hda_codec_write_cache(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: hda - Fix return value of snd_hda_check_power_state()Takashi Iwai
commit 06ec56d3c60238f27bfa50d245592fccc1b4ef0f upstream. The refactoring by commit 9040d102 introduced the new function snd_hda_check_power_state(). This function is supposed to return true if the state already reached to the target state, but it actually returns false for that. An utterly stupid typo while copy & paste. Fortunately this didn't influence on much behavior because powering up AFG usually powers up the child widgets, too. But the finer power control must have been broken by this bug. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25ALSA: hda - Fix EAPD vmaster hook for AD1884 & coTakashi Iwai
commit 8f0b3b7e222383a21f7d58bd97d5552b3a5dbced upstream. ad1884_fixup_hp_eapd() tries to set the NID for controlling the speaker EAPD from the pin configuration. But the current code can't work expectedly since it sets spec->eapd_nid before calling the generic parser where the autocfg pins are set up. This patch changes the function to set spec->eapd_nid after the generic parser call while it sets vmaster hook unconditionally. The spec->eapd_nid check is moved in the hook function itself instead. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-17ALSA: hda - Add models for Dell headset jacksDavid Henningsson
These headset jacks keep coming in on more and more platforms, and it's possible I don't catch them all. Make it easier to test and verify by making models. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17ALSA: usb-audio: Fix invalid volume resolution for Logitech HD Webcam c310Takashi Iwai
Just like the previous fix for LogitechHD Webcam c270 in commit 11e7064f35bb87da8f427d1aa4bbd8b7473a3993, c310 model also requires the same workaround for avoiding the kernel warning. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59741 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17ALSA: hda - Fix pin configurations for MacBook Air 4,2Takashi Iwai
MacBook Air 4,2 requires the whole default pin configuration table to be overridden by the driver, as usual, as Apple's machines don't set up properly after boot. Otherwise mic won't work, and other ill effect may happen. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59381 Reported-and-tested-by: Peter John Hartman <peterjohnhartman@gmail.com> Cc: <stable@vger.kernel.org> [v3.9+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17ALSA: usb-audio: work around Android accessory firmware bugClemens Ladisch
When the Android firmware enables the audio interfaces in accessory mode, it always declares in the control interface's baInterfaceNr array that interfaces 0 and 1 belong to the audio function. However, the accessory interface itself, if also enabled, already is at index 0 and shifts the actual audio interface numbers to 1 and 2, which prevents the PCM streaming interface from being seen by the host driver. To get the PCM interface interface to work, detect when the descriptors point to the (for this driver useless) accessory interface, and redirect to the correct one. Reported-by: Jeremy Rosen <jeremy.rosen@openwide.fr> Tested-by: Jeremy Rosen <jeremy.rosen@openwide.fr> Cc: <stable@vger.kernel.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17ALSA: hda - Headset mic support for three more machinesDavid Henningsson
They need these quirks to have headset mic support. BugLink: https://bugs.launchpad.net/bugs/1189363 Tested-by: Shawn Wang <shawn.wang@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS fixes from Al Viro: "Several fixes + obvious cleanup (you've missed a couple of open-coded can_lookup() back then)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: snd_pcm_link(): fix a leak... use can_lookup() instead of direct checks of ->i_op->lookup move exit_task_namespaces() outside of exit_notify() fput: task_work_add() can fail if the caller has passed exit_task_work() ncpfs: fix rmdir returns Device or resource busy
2013-06-15snd_pcm_link(): fix a leak...Al Viro
in case when snd_pcm_stream_linked(substream) is true, we end up leaking group. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-10Merge remote-tracking branch 'asoc/fix/wm8994' into asoc-linusMark Brown
2013-06-10Merge remote-tracking branch 'asoc/fix/tlv320aic3x' into asoc-linusMark Brown
2013-06-10Merge remote-tracking branch 'asoc/fix/cs42l52' into asoc-linusMark Brown
2013-06-10Merge remote-tracking branch 'asoc/fix/core' into asoc-linusMark Brown
2013-06-10Merge remote-tracking branch 'asoc/fix/arizona' into asoc-linusMark Brown
2013-06-07ASoC: tlv320aic3x: Remove deadlock from snd_soc_dapm_put_volsw_aic3x()Andreas Irestål
When calling snd_soc_dapm_sync(), it eventually tries to lock the same mutex already locked in snd_soc_dapm_put_volsw_aic3x() and a deadlock occurs. By moving the mutex unlock to just before snd_soc_dapm_sync(), this deadlock is prevented. This problem was introduced in Linux 3.5 Signed-off-by: Andreas Irestål <Andreas.Irestal@axis.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-07ASoC: dapm: Treat DAI widgets like AIF widgets for powerMark Brown
Even though they are virtual widgets DAI widgets still get counted for the DAPM context power management so we can't just use the active state to check if they should be powered as they may not be part of a complete path. Instead split them into input and output widgets and do the same power checks as we perform on AIFs. Reported-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-05ASoC: arizona: Correct AEC loopback enableCharles Keepax
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-05ALSA: usb-audio - Fix invalid volume resolution on Logitech HD webcam c270Takashi Iwai
USB audio driver spews an error message when probing Logitech HD webcam c270: ALSA mixer.c:1300 usb_audio: Warning! Unlikely big volume range (=6144), cval->res is probably wrong. ALSA mixer.c:1304 usb_audio: [5] FU [Mic Capture Volume] ch = 1, val = 1536/7680/1 Obviously the device needs a fixed volume resolution (cval->res = 384) like other Logitech devices. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=821735 Reported-and-tested-by: Cristian Rodríguez <crrodriguez@opensuse.org> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-04ALSA: usb-audio - Apply Logitech QuickCam Pro 9000 quirk only to audio ifaceTakashi Iwai
... instead of applying to all interfaces. Reference: http://forums.gentoo.org/viewtopic-p-6886404.html Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-03ALSA: hda/via - Clean up duplicated codesTakashi Iwai
The previous commit was written in the way to make the backport to 3.9.y easier, and left the duplicated open codes intentionally. Now let's clean up the duplicated codes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-03ALSA: hda/via - Fix wrongly cleared pins after suspend on VT1802Takashi Iwai
VIA driver has a special suspend handling only for VT1802 to reduce the pop noise. During the transition to the generic parser, the behavior of snd_hda_set_pin_ctl() was also changed to modify the cached values, too. And this caused a regression where the pin is still cleared even after the resume (including the resume from power save), resulting in the silent output. The fix is simply to replace snd_hda_set_pin_ctl() with the explicit call of snd_hda_codec_write() again. Reported-by: Alex Riesen <raa.lkml@gmail.com> Cc: <stable@vger.kernel.org> [v3.9] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-03ALSA: hda - Add keep_eapd_on flag to generic parserTakashi Iwai
VT1802 codec seems to reset EAPD of other pins in the hardware level, and this was another reason of the silent headphone output on some machines. As a workaround, introduce a new flag indicating to keep the EPAD on to the generic parser, and set it in patch_via.c. Reported-by: Alex Riesen <raa.lkml@gmail.com> Cc: <stable@vger.kernel.org> [v3.9] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-03ALSA: hda - Allow setting automute/automic hooks after parsingTakashi Iwai
Some codec drivers (VIA codecs and some Realtek fixups) set the automute and automic hooks after calling snd_hda_gen_parse_auto_config(). In the current code, the hook pointers are referred only in snd_hda_gen_parse_auto_config() and passed to snd_hda_jack_detect_enable_callback(), thus changing the hook values won't change the actually called callbacks properly. This patch fixes this bug by setting the static functions as the primary callback functions for the jack detection, and let them calling the appropriate hooks dynamically. Cc: <stable@vger.kernel.org> [v3.9] Signed-off-by: Takashi Iwai <tiwai@suse.de>
